这是reboot recovery启动时调试信息,能给看看是什么问题吗?
shell@firefly:/ $ reboot recovery
[ 54.389770] SysRq : Emergency Remount R/O
[ 54.393350] EXT4-fs (mmcblk0p8): re-mounted. Opts: (null)
[ 54.395527] EXT4-fs (mmcblk0p11): re-mounted. Opts: (null)
[ 54.408762] EXT4-fs (mmcblk0p13): re-mounted. Opts: (null)
[ 54.431592] Emergency Remount complete
[ 54.498547] cpufreq: cpufreq: reboot set core rate=1200000000, volt=1100000
[ 54.498566] mali_reboot_notifier_event enter
[ 54.498574] mali_reboot_notifier_event exit
[ 54.498773] mmcblk mmc0:0001: Unbalanced pm_runtime_enable!
[ 55.111930] Chenzy-------hkw-------es8323_i2c_shutdown
[ 55.217916] dwc_otg_driver_shutdown: disconnect USB device mode
﨑DR Version 1.00 20150318system with command ‘recovery’.
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10-g65679f1 (Jul 20 2015 - 10:28:11)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
remotectl v0.1
storage init OK!
GetParam
check parameter success
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2015-07-20#2.19
empty serial no.
unknown reboot type 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x006941b0)
ramdisk @ 0x05bf0000 (0x002c75ec)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c154 … OK
[ 0.000000] Linux version 3.10.0 (zq@zq-VirtualBox) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #95 SMP PREEMPT Mon Aug 28 15:57:36 CST 2017
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7cc00000
[ 0.000000] ion_reserve: cma reserved base 7cc00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ef8000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00400000@0x0039C000(userdata),0x00020000@0x0079C000(radical_update),-@0x007BC000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2015-07-20_10:28:11 hdmi.vic=-1
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1992268k/1992268k available, 104884k reserved, 1523712K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b8e454 (11802 kB)
[ 0.000000] .init : 0xc0b8f000 - 0xc0be8440 ( 358 kB)
[ 0.000000] .data : 0xc0bea000 - 0xc0d7b440 (1606 kB)
[ 0.000000] .bss : 0xc0d7b440 - 0xc0e9c77c (1157 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:15
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:13
[ 0.492201] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.492216] pid_max: default: 32768 minimum: 301
[ 0.492334] Security Framework initialized
[ 0.492350] SELinux: Initializing.
[ 0.492425] Mount-cache hash table entries: 512
[ 0.493069] Initializing cgroup subsys debug
[ 0.493084] Initializing cgroup subsys memory
[ 0.493110] Initializing cgroup subsys freezer
[ 0.493138] CPU: Testing write buffer coherency: ok
[ 0.493452] /cpus/cpu@0 missing clock-frequency property
[ 0.493465] /cpus/cpu@1 missing clock-frequency property
[ 0.493475] /cpus/cpu@2 missing clock-frequency property
[ 0.493484] /cpus/cpu@3 missing clock-frequency property
[ 0.493538] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.493587] Setting up static identity map for 0xc08502a0 - 0xc08502f8
[ 0.496696] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x187b (version 3.1)
[ 0.570363] CPU1: Booted secondary processor
[ 0.570395] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.590033] CPU2: Booted secondary processor
[ 0.590056] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.609744] CPU3: Booted secondary processor
[ 0.609768] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.609869] Brought up 4 CPUs
[ 0.609897] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.609906] CPU: All CPU(s) started in SVC mode.
[ 0.610645] devtmpfs: initialized
[ 0.614900] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.615992] pinctrl core: initialized pinctrl subsystem
[ 0.616240] regulator-dummy: no parameters
[ 0.630091] NET: Registered protocol family 16
[ 0.631881] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.632197] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e77a4c (version 0.1)
[ 0.632429] Registered FIQ tty driver
[ 0.632825] fiq-debugger is disabled in device tree
[ 0.633486] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.633507] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.633524] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.633541] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.633633] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.633698] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.633758] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.633819] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.633880] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.633940] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.634001] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.634061] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.634128] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.634191] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.634204] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.634215] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.634232] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.634850] rockchip_interrupts_register:bank_num=7
[ 0.636730] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.636791] rockchip_pinctrl_probe:init ok
[ 0.643642] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.643730] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.643743] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.643907] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.643975] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.643987] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.644152] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.644222] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.644234] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.644395] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.644466] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.644479] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.644658] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.644735] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.644747] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.644910] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.644980] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.644992] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.645165] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.645245] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.645257] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.646983] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.646996] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.647567] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.647589] DDR DEBUG: version 1.00 20150126
[ 0.647619] DDR DEBUG: Channel a:
[ 0.647627] DDR DEBUG: DDR3 Device
[ 0.647641] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.647650] DDR DEBUG: Channel b:
[ 0.647657] DDR DEBUG: DDR3 Device
[ 0.647670] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.647679] DDR DEBUG: addr=0xd85000
[ 0.647688] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.647697] DDR DEBUG: socAddr[0]=0xd85000, socAddr[1]=0xd85100
[ 0.647707] DDR DEBUG: chAddr[0]=0xd85000, chAddr[1]=0xd85000
[ 0.647718] DDR DEBUG: dtar[0]=0x501b0000, dtar[1]=0x501b0000
[ 0.647772] DDR DEBUG: init success!!! freq=200MHz
[ 0.647779] DDR DEBUG: Channel a:
[ 0.647792] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.647805] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.647818] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.647830] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.647842] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.647851] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.647860] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.647867] DDR DEBUG: Channel b:
[ 0.647878] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.647891] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.647903] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.647915] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.647926] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.647934] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.647943] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.672548] bio: create slab at 0
[ 0.673051] Rockchip hdmi driver version 2.0
[ 0.673051] .
[ 0.674197] SCSI subsystem initialized
[ 0.674353] usbcore: registered new interface driver usbfs
[ 0.674400] usbcore: registered new interface driver hub
[ 0.674489] usbcore: registered new device driver usb
[ 0.677123] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.677760] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.678418] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.678875] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.679496] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.679618] media: Linux media interface: v0.10
[ 0.679662] Linux video capture interface: v2.00
[ 0.679727] pps_core: LinuxPPS API ver. 1 registered
[ 0.679737] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.679757] PTP clock support registered
[ 0.679818] i2c-core: driver [bq24296] using legacy suspend method
[ 0.679828] i2c-core: driver [bq24296] using legacy resume method
[ 0.680516] ion_drm_heap_create: 0@0
[ 0.680640] Rockchip ion module is successfully loaded (v1.1)
[ 0.680807] Advanced Linux Sound Architecture Driver Initialized.
[ 0.681212] Bluetooth: Core ver 2.16
[ 0.681268] NET: Registered protocol family 31
[ 0.681278] Bluetooth: HCI device and connection manager initialized
[ 0.681294] Bluetooth: HCI socket layer initialized
[ 0.681308] Bluetooth: L2CAP socket layer initialized
[ 0.681334] Bluetooth: SCO socket layer initialized
[ 0.681571] cfg80211: Calling CRDA to update world regulatory domain
[ 0.682271] act8846_i2c_probe,line=899
[ 0.683241] act8846_parse_dt,line=746
[ 0.683700] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.683721] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.683737] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.685811] act_dcdc1: 1200 mV
[ 0.688786] vccio: 3300 mV
[ 0.690640] vdd_logic: 700 ↔ 1500 mV at 1125 mV
[ 0.693584] act_dcdc4: 2000 mV
[ 0.694805] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.697098] act_ldo2: 1050 mV
[ 0.699396] act_ldo3: 3300 mV
[ 0.701691] act_ldo4: 3300 mV
[ 0.703984] act_ldo5: 3300 mV
[ 0.706298] act_ldo6: 1100 mV
[ 0.708597] vcc_18: 1800 mV
[ 0.710893] act_ldo8: 1850 mV
[ 0.715634] vdd_arm: 712 ↔ 1500 mV at 1100 mV
[ 0.720324] vdd_gpu: 712 ↔ 1500 mV at 900 mV
[ 0.721086] rk808_i2c_probe,line=1355
[ 0.722417] The device is not rk808 -11
[ 0.722501] rk808: probe of 0-001b failed with error -11
[ 0.722576] i2c-core: driver [rk818] using legacy suspend method
[ 0.722586] i2c-core: driver [rk818] using legacy resume method
[ 0.724319] Switching to clocksource arch_sys_counter
[ 0.748001] rga: Module initialized.
[ 0.748706] rga2 ff920000.rga: rga ion client create success!
[ 0.748865] rga: Driver loaded succesfully
[ 0.749056] fb disp policy is box
[ 0.749099] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.749111] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.749445] rk-screen rk_screen.8: rockchip screen probe success
[ 0.749681] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 0.750040] rk32-edp ff970000.edp: screen is not edp!
[ 0.750061] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.750539] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.750759] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.751058] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.751231] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.751394] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.752153] vop ver:3007236,unsupport output color:1
[ 0.752287] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 0.752311] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.776134] rk_battery_charger_detect_cb , battery_charger_dete0.798089] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.798118] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa6000
[ 0.798134] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 0.798352] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.798366] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.798647] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.798995] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.799168] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.799359] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.800122] unknow screen type: 0
[ 0.800137] vop ver:3007236,unsupport output color:1
[ 0.800197] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:60
[ 0.800211] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.803947] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 0.803963] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 0.804794] rockchip_set_mux:warning ignore bank num 15
[ 0.804936] rockchip_set_mux:warning ignore bank num 15
[ 0.805053] rockchip_set_mux:warning ignore bank num 15
[ 0.805167] rockchip_set_mux:warning ignore bank num 15
[ 0.805283] rockchip_set_mux:warning ignbank num 15
[ 0.805974] rockchip_set_mux:warning ignore bank num 15
[ 0.806139] rockchip_set_mux:warning ignore bank num 15
[ 0.806680] rockchip_set_mux:warning ignore bank num 15
[ 0.806823] rockchip_set_mux:warning ignore bank num 15
[ 0.807354] rockchip_set_mux:warning ignore bank num 15
[ 0.807503] rockchip_set_mux:warning ignore bank num 15
[ 0.808038] rockchip_set_mux:warning ignore bank num 15
[ 0.808191] rockchip_set_mux:warning ignore bank num 15
[ 0.809284] tc358749_hdmiin_probe!
[ 0.809485] tc358749_hdmiin_probe OK!
[ 0.809940] NET: Registered protocol family 2
[ 0.810596] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.810673] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.810746] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.810797] TCP: reno registered
[ 0.810814] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.810837] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.811030] NET: Registered protocol family 1
[ 0.811638] Unpacking initramfs…
[ 0.949749] Freeing initrd memory: 2844K (c5bf0000 - c5eb7000)
[ 0.950498] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.951123] vcodec_service: probe device ff9a0000.vpu_service
[ 0.951334] vcodec_service: No reset resource define
[ 0.951510] vcodec_service: ff9a0000.vpu_service: power on
[ 0.951595] vcodec_service: probe device ff9a0000.vpu_service
[ 0.951609] vcodec_service: checking hw id 4831
[ 0.952603] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.952649] vcodec_service: done
[ 0.952657] vcodec_service: init success
[ 0.952718] vcodec_service: probe device ff9c0000.hevc_service
[ 0.953046] vcodec_service: ff9c0000.hevc_service: power on
[ 0.953105] vcodec_service: probe device ff9c0000.hevc_service
[ 0.953118] vcodec_service: checking hw id 6867
[ 0.953668] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.953709] vcodec_service: done
[ 0.953717] vcodec_service: init success
[ 0.953845] rknandbase v1.0 2014-03-31
[ 0.953975] rknand: probe of ff400000.nandc failed with error -1
[ 0.954083] rknand_driver:ret = 0
[ 0.955973] audit: initializing netlink socket (disabled)
[ 0.956018] type=2000 audit(0.460:1): initialized
[ 0.956838] bounce pool size: 64 pages
[ 0.961468] fuse init (API version 7.22)
[ 0.961846] msgmni has been set to 952
[ 0.963724] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.963740] io scheduler noop registered
[ 0.963750] io scheduler deadline registered
[ 0.963839] io scheduler cfq registered (default)
[ 0.965057] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.965756] IEP Power ON
[ 0.965798] iep ion client create success!
[ 0.966262] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa1000
[ 0.966272] IEP Power OFF
[ 0.966291] IEP Driver loaded succesfully
[ 0.966387] Module initialized.
[ 0.967205] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.967222] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.968552] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.968568] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.968853] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 0.968868] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 0.968877] pwm_regulator_probe:error
[ 0.968897] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 0.969102] rk_serial.c v1.8 2014-03-04
[ 0.969321] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.969509] serial ff180000.serial: membase e097e000
[ 0.969670] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.969851] serial ff190000.serial: membase e2192000
[ 0.969987] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.971685] console [ttyS2] enabled
[ 0.971872] serial ff690000.serial: membase fed60000
[ 0.972066] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.972237] serial ff1b0000.serial: membase e219c000
[ 0.975066] loop: module loaded
[ 0.975440] zram: Created 1 device(s) …
[ 0.975528] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.975541] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.975558] mpu_init: Probe name mpu6050B1
[ 0.975714] ak8963_mod_init: Probe name ak8963_mod
[ 0.976432] SCSI Media Changer driver v0.25
[ 0.976752] tun: Universal TUN/TAP device driver, 1.6
[ 0.976764] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.976885] vmac_init.
[ 0.977461] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.977478] stmmac_probe_config_dt: clock input/output? (input).
[ 0.977491] stmmac_probe_config_dt: TX delay(0x30).
[ 0.977503] stmmac_probe_config_dt: RX delay(0x20).
[ 0.977553] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.977563] stmmc_pltfr_init:
[ 0.977573] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.977596] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.977608] stmmc_pltfr_init: init for RGMII
[ 0.977619] tx delay=0x30
[ 0.977619] rx delay=0x20
[ 0.977636] tx delay=0x30
[ 0.977636] rx delay=0x20
[ 0.978103] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.978114] Normal descriptors
[ 0.978123] Ring mode enabled
[ 0.978134] DMA HW capability register supported
[ 0.978146] RX Checksum Offload Engine supported (type 2)
[ 0.978156] TX Checksum insertion supported
[ 0.978165] Wake-Up On Lan supported
[ 0.978200] Enable RX Mitigation via HW Watchdog Timer
[ 0.978641] PPP generic driver version 2.4.2
[ 0.978790] PPP BSD Compression module registered
[ 0.978804] PPP Deflate Compression module registered
[ 0.978827] PPP MPPE Compression module registered
[ 0.978840] NET: Registered protocol family 24
[ 0.978878] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.978891] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.978904] Rockchip WiFi SYS interface (V1.00) …
[ 0.978940] esp_mem_init enter date May 16 2017 10:14:53
[ 0.978950] esp_mem_init VERSION [V2.5]
[ 0.978995] esp_mem_init complete
[ 0.979087] usbcore: registered new interface driver catc
[ 0.979128] usbcore: registered new interface driver kaweth
[ 0.979142] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.979181] usbcore: registered new interface driver pegasus
[ 0.979220] usbcore: registered new interface driver rtl8150
[ 0.979258] usbcore: registered new interface driver r8152
[ 0.979271] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.979336] usbcore: registered new interface driver hso
[ 0.979384] usbcore: registered new interface driver asix
[ 0.979426] usbcore: registered new interface driver ax88179_178a
[ 0.979465] usbcore: registered new interface driver cdc_ether
[ 0.979503] usbcore: registered new interface driver cdc_eem
[ 0.979541] usbcore: registered new interface driver dm9601
[ 0.979578] usbcore: registered new interface driver dm9620
[ 0.979624] usbcore: registered new interface driver smsc75xx
[ 0.979675] usbcore: registered new interface driver smsc95xx
[ 0.979715] usbcore: registered new interface driver gl620a
[ 0.979755] usbcore: registered new interface driver net1080
[ 0.979795] usbcore: registered new interface driver plusb
[ 0.979834] usbcore: registered new interface driver rndis_host
[ 0.979874] usbcore: registered new interface driver cdc_subset
[ 0.979913] usbcore: registered new interface driver zaurus
[ 0.979960] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.980025] usbcore: registered new interface driver int51x1
[ 0.980065] usbcore: registered new interface driver kalmia
[ 0.980106] usbcore: registered new interface driver ipheth
[ 0.980148] usbcore: registered new interface driver sierra_net
[ 0.980189] usbcore: registered new interface driver cx82310_eth
[ 0.980275] usbcore: registered new interface driver cdc_ncm
[ 0.980321] usbcore: registered new interface driver qmi_wwan
[ 0.980362] usbcore: registered new interface driver cdc_mbim
[ 0.980375] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.982829] EHCI: ehci_rk_probe e2240000 e2240010
[ 0.982849] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.982884] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.983230] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.999918] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.000004] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.000021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.000036] usb usb1: Product: EHCI Host Controller
[ 1.000049] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.000063] usb usb1: SerialNumber: ff500000.usb
[ 1.000510] hub 1-0:1.0: USB hub found
[ 1.000535] hub 1-0:1.0: 1 port detected
[ 1.000705] EHCI: ehci_rk_probe ok
[ 1.000810] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.001098] usbcore: registered new interface driver cdc_acm
[ 1.001111] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.001165] usbcore: registered new interface driver usblp
[ 1.001210] usbcore: registered new interface driver cdc_wdm
[ 1.001280] usbcore: registered new interface driver usb-storage
[ 1.001322] usbcore: registered new interface driver ums-alauda
[ 1.001361] usbcore: registered new interface driver ums-cypress
[ 1.001401] usbcore: registered new interface driver ums-datafab
[ 1.001438] usbcore: registered new interface driver ums_eneub6250
[ 1.001477] usbcore: registered new interface driver ums-freecom
[ 1.001515] usbcore: registered new interface driver ums-isd200
[ 1.001555] usbcore: registered new interface driver ums-jumpshot
[ 1.001596] usbcore: registered new interface driver ums-karma
[ 1.001636] usbcore: registered new interface driver ums-onetouch
[ 1.001681] usbcore: registered new interface driver ums-sddr09
[ 1.001723] usbcore: registered new interface driver ums-sddr55
[ 1.001763] usbcore: registered new interface driver ums-usbat
[ 1.001850] usbcore: registered new interface driver usbserial
[ 1.001891] usbcore: registered new interface driver usbserial_generic
[ 1.001924] usbserial: USB Serial support registered for generic
[ 1.001965] usbcore: registered new interface driver option
[ 1.001996] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.002077] usbcore: registered new interface driver trancevibrator
[ 1.002091] usb20_otg: version 3.10a 21-DEC-2012
[ 1.002515] e2280040
[ 1.002530] Core Release: 3.10a
[ 1.002547] Setting default values for core params
[ 1.002690] Using Buffer DMA mode
[ 1.002703] Periodic Transfer Interrupt Enhancement - disabled
[ 1.002714] Multiprocessor Interrupt Enhancement - disabled
[ 1.002726] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.002737] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.002756] Dedicated Tx FIFOs mode
[ 1.002776] pcd_init otg_dev = dde7c340
[ 1.002929] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.002958] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.002993] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.003061] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.003077] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.003091] usb usb2: Product: DWC OTG Controller
[ 1.003104] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.003118] usb usb2: SerialNumber: ff580000.usb
[ 1.003542] hub 2-0:1.0: USB hub found
[ 1.003565] hub 2-0:1.0: 1 port detected
[ 1.003870] usb20_host: version 3.10a 21-DEC-2012
[ 1.006391] e2300040
[ 1.006406] Core Release: 3.10a
[ 1.006422] Setting default values for core params
[ 1.006536] Using Buffer DMA mode
[ 1.006548] Periodic Transfer Interrupt Enhancement - disabled
[ 1.006558] Multiprocessor Interrupt Enhancement - disabled
[ 1.006569] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.006580] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.006608] usb20_host ff540000.usb: DWC OTG Controller
[ 1.006635] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.006677] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.006770] Init: Power Port (0)
[ 1.006827] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.006843] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.006858] usb usb3: Product: DWC OTG Controller
[ 1.006871] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.006884] usb usb3: SerialNumber: ff540000.usb
[ 1.007323] hub 3-0:1.0: USB hub found
[ 1.007345] hub 3-0:1.0: 1 port detected
[ 1.008087] usbcore: registered new interface driver xpad
[ 1.008147] usbcore: registered new interface driver usb_acecad
[ 1.008198] usbcore: registered new interface driver aiptek
[ 1.008252] usbcore: registered new interface driver gtco
[ 1.008300] usbcore: registered new interface driver hanwang
[ 1.008346] usbcore: registered new interface driver kbtab
[ 1.008401] usbcore: registered new interface driver wacom
[ 1.008737] sensor_register_slave:mma8452,id=17
[ 1.008751] sensor_register_slave:gs_mc3230,id=23
[ 1.008761] gsensor_init
[ 1.008771] sensor_register_slave:mpu6880_acc,id=24
[ 1.008782] sensor_register_slave:mpu6500_acc,id=25
[ 1.008793] sensor_register_slave:cm3217,id=48
[ 1.008804] sensor_register_slave:cm3218,id=49
[ 1.009029] .. rk pwm remotectl v1.1 init
[ 1.009263] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.014243] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.014303] i2c /dev entries driver
[ 1.014984] IR NEC protocol handler initialized
[ 1.014997] IR RC5(x) protocol handler initialized
[ 1.015008] IR RC6 protocol handler initialized
[ 1.015018] IR JVC protocol handler initialized
[ 1.015027] IR Sony protocol handler initialized
[ 1.015038] IR RC5 (streamzap) protocol handler initialized
[ 1.015048] IR SANYO protocol handler initialized
[ 1.015059] IR MCE Keyboard/mouse protocol handler initialized
[ 1.015212] usbcore: registered new interface driver uvcvideo
[ 1.015224] USB Video Class driver (1.1.1)
[ 1.015237] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.016727] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.016751] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.016772] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.016794] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.016833] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.016833]
[ 1.016907] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.017051] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe21f8000 size: 0x4000)
[ 1.017693] D1:camsys_platform_probe(1447): ff910000.isp memory:
[ 1.017711] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe2220000 size: 0x10000)
[ 1.017727] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1df80000 vir: 0xddf80000 size: 0x1000)
[ 1.017742] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.017755] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
[ 1.018188] test power disabled
[ 1.018246] i2c-core: driver [bq27320] using legacy suspend method
[ 1.018258] i2c-core: driver [bq27320] using legacy resume method
[ 1.018589] rockchip_temp_probe,line=364
[ 1.068791] tsadc ff280000.tsadc: initialized
[ 1.069178] device-mapper: uevent: version 1.0.3
[ 1.069428] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.069731] Bluetooth: HCI UART driver ver 2.2
[ 1.069748] Bluetooth: HCI H4 protocol initialized
[ 1.069760] Bluetooth: HCILL protocol initialized
[ 1.069771] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.069783] rtk_btusb: Register usb char device interface for BT driver
[ 1.069980] usbcore: registered new interface driver rtk_btusb
[ 1.070621] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 1.074661] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.074859] cpuidle: using governor ladder
[ 1.074873] cpuidle: using governor menu
[ 1.074910] Synopsys Designware Multimedia Card Interface Driver
[ 1.074921] MHSC version = Ver 2.00 2015-06-10
[ 1.075235] dw cru_regsbase addr 0x1d8.
[ 1.075248] dw cru_reset_offset val 3.
[ 1.075263] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.075309] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.075632] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.075806] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.075933] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.088488] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.108190] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.108206] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.108216] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.108509] dw cru_regsbase addr 0x1d8.
[ 1.108522] dw cru_reset_offset val 0.
[ 1.108536] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.108572] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.109360] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.109533] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.110004] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.110081] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.127829] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.140290] mmc0: BKOPS_EN bit is not set
[ 1.142163] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.144452] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.144476] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.144498] [mmc0] tuning regsbase addr 0x218.
[ 1.145071] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[ 1.145082] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.145103] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 1.145123] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.145395] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-180 (17 len)
[ 1.145406] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 203-282 (8 len)
[ 1.145417] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-180 (17 len)
[ 1.145428] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 90
[ 1.145472] mmc0: new HS200 MMC card at address 0001
[ 1.145758] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
[ 1.146097] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.146109] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.146118] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.146128] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.146137] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.146145] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.146153] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.146161] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.146169] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.146178] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.146186] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.146194] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.146202] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.146210] userdata: 0x073800000 – 0x0f3800000 (2048 MB)
[ 1.146219] radical_update: 0x0f3800000 – 0x0f7800000 (64 MB)
[ 1.146228] user: 0x0f7800000 – 0x3a3a00000 (10946 MB)
[ 1.146254] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16[ 1.147576] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.147591] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.147896] dw cru_regsbase addr 0x1d8.
[ 1.147905] dw cru_reset_offset val 1.
[ 1.147915] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.147951] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.148181] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.148314] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.148563] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.167188] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.186893] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.186906] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.186918] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.187197] leds-gpio leds.27: pins are not configured from the driver
[ 1.187349] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.188795] usbcore: registered new interface driver usbhid
[ 1.188805] usbhid: USB HID core driver
[ 1.188922] ashmem: initialized
[ 1.189037] logger: created 256K log ‘log_main’
[ 1.189145] logger: created 256K log ‘log_events’
[ 1.189239] logger: created 256K log ‘log_radio’
[ 1.189335] logger: created 256K log ‘log_system’
[ 1.190431] input: rk29-keypad as /devices/ff100000.adc/key.31/input/input1
[ 1.191287] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.191304] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.191316] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.191327] ES8323 2-0010: Error applying setting, reverse things back
[ 1.191619] es8323 probe i2c recv ok
[ 1.192585] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.193159] es8323_probe
[ 1.826834] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 1.826847] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 1.826856] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 1.826864] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 1.826872] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 1.826879] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 1.826888] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 1.826896] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 1.826904] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 1.826911] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 1.826920] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 1.826926] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 1.826935] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 1.826942] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 1.826949] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 1.826956] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 1.826964] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 1.826970] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 1.826979] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 1.826985] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 1.826993] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 1.827000] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 1.827007] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 1.827014] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 1.827022] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 1.827029] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 1.827037] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 1.827044] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 1.827051] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 1.827058] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 1.827065] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 1.827073] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 1.827095] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 1.827102] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 1.827110] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 1.827116] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 1.827124] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 1.827131] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 1.827139] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 1.827145] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 1.827153] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 1.827160] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 1.827168] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 1.827174] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 1.827293] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 1.827304] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 1.827312] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 1.827321] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 1.827343] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 1.833433] rockchip-es8323 rockchip-es8323.26: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 1.833789] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.26/sound/card0/input2
[ 1.834199] u32 classifier
[ 1.834206] Actions configured
[ 1.834217] Netfilter messages via NETLINK v0.30.
[ 1.834266] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.834533] ctnetlink v0.93: registering with nfnetlink.
[ 1.834592] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.834599] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.834812] xt_time: kernel timezone is -0000
[ 1.834968] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.835080] arp_tables: (C) 2002 David S. Miller
[ 1.835115] TCP: cubic registered
[ 1.835121] Initializing XFRM netlink socket
[ 1.835283] NET: Registered protocol family 10
[ 1.835702] mip6: Mobile IPv6
[ 1.835724] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.835825] sit: IPv6 over IPv4 tunneling driver
[ 1.836101] NET: Registered protocol family 17
[ 1.836119] NET: Registered protocol family 15
[ 1.836162] Bridge firewalling registered
[ 1.836171] Ebtables v2.0 registered
[ 1.836331] Bluetooth: RFCOMM TTY layer initialized
[ 1.836354] Bluetooth: RFCOMM socket layer initialized
[ 1.836360] Bluetooth: RFCOMM ver 1.11
[ 1.836366] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.836371] Bluetooth: BNEP filters: protocol multicast
[ 1.836380] Bluetooth: BNEP socket layer initialized
[ 1.836387] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.836395] Bluetooth: HIDP socket layer initialized
[ 1.836422] l2tp_core: L2TP core driver, V2.0
[ 1.836432] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.836439] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.836627] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.836639] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 1.836646] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 1.836653] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.836660] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 1.836668] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.836686] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 1.836703] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 1.836709] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.836733] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 1.836740] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.836777] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.836898] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 1.836916] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 1.836928] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 1.836939] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 1.836975] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.837064] [BT_RFKILL]: ** disable irq
[ 1.837131] [BT_RFKILL]: ap6335 device registered.
[ 1.837727] rk3288_init_suspend
[ 1.837737] rk3288_suspend_init enter
[ 1.837933] rk3288_suspend_init: pm_ctrbits =200007
[ 1.837965] gpio_get_dts_info suspend:4
[ 1.837971] gpio_get_dts_info resume:4
[ 1.837976] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.837999] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 1.838114] clks_gating_suspend_init:clkgt info ok
[ 1.838183] Registering SWP/SWPB emulation handler
[ 1.838194] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 1.840474] ddrfreq: verion 1.2 20140526
[ 1.840486] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 1.840494] ddrfreq: auto-freq=0
[ 1.840498] ddrfreq: auto-freq-table[0] 240MHz
[ 1.840503] ddrfreq: auto-freq-table[1] 324MHz
[ 1.840507] ddrfreq: auto-freq-table[2] 456MHz
[ 1.840512] ddrfreq: auto-freq-table[3] 528MHz
[ 1.849715] act_ldo3: operation not allowed
[ 1.849723] rgb2hdmi_probe: turn on ldo3 done.
[ 1.849963] act_ldo4: operation not allowed
[ 1.849968] rgb2hdmi_probe: turn on ldo done.
[ 1.850207] act_ldo2: operation not allowed
[ 1.850212] rgb2hdmi_probe: turn on ldo2 done.
[ 1.850459] act_ldo8: operation not allowed
[ 1.850465] rgb2hdmi_probe: turn on ldo done.
[ 1.850510] rgb2hdmi_probe: success. 7
[ 1.850555] firefly_rgb2hdmi_get_enable 201, 0
[ 1.850561] firefly_rgb2hdmi_get_status 207
[ 1.850565] firefly_rgb2hdmi_set_enable 183 enable:1
[ 1.850570] firefly_rgb2hdmi_enable 150 start
[ 1.850575] firefly_switch_to_rgb 75
[ 1.850582] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.101978] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.102027] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:50
[ 2.102056] HDMI ENABLE
[ 2.102065] HDMI Devie connected 7
[ 2.102069] firefly_rgb2hdmi_set_mode 226
[ 2.102075] firefly_rgb2hdmi_set_mode 242 1280 720 50 74250000
[ 2.102079] firefly_rgb2hdmi_enable 150 start
[ 2.102084] firefly_switch_to_rgb 75
[ 2.102090] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.357820] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.357832] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:50
[ 2.357872] regulator-dummy: disabling
[ 2.358082] =======================================================
[ 2.358090] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.358095] =======================================================
[ 2.358101] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.358143] dhd_module_init: in
[ 2.358150] ======== bcm_wlan_set_plat_data ========
[ 2.358156] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.358173] host_oob_irq: 196
[ 2.358177] host_oob_irq_flags=4
[ 2.358181] dhd_wifi_platform_load: Enter
[ 2.358196] pcd_pullup, is_on 0
[ 2.358199] Power-up adapter ‘DHD generic adapter’
[ 2.358215] wifi_platform_set_power = 1
[ 2.358219] ======== PULL WL_REG_ON HIGH! ========
[ 2.358224] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.358229] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.358233] file system registered
[ 2.358238] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.358694] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.358701] android_usb gadget: Number of LUNs=2
[ 2.358708] lun0: LUN: removable file: (no medium)
[ 2.358713] lun1: LUN: removable file: (no medium)
[ 2.358831] android_usb gadget: android_usb ready
[ 2.358909] sensor_init: Probe name sensors
[ 2.358925] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.359448] rtc_hym8563 0-0051: setting system clock to 2011-01-02 02:54:57 UTC (1293936897)
[ 2.365144] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 2.365782] usbcore: registered new interface driver snd-usb-audio
[ 2.365789] ALSA device list:
[ 2.365794] #0: RK_ES8323
[ 2.365798] #1: RK-SPDIF-CARD
[ 2.366115] Freeing unused kernel memory: 356K (c0b8f000 - c0be8000)
[ 2.466058] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.577622] type=1403 audit(1293936897.710:2): policy loaded auid=4294967295 ses=4294967295
[ 2.602419] init: could not import file ‘/init.recovery.rk30board.rc’ from ‘/init.rc’
[ 2.603934] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 2.603989] bat_cap: oldcap_path no exist
[ 2.604098] init: invalid gid ‘trace’
[ 2.604135] healthd: No charger supplies found
[ 2.604153] healthd: No battery devices found
[ 2.672707] wifi_platform_bus_enumerate device present 1
[ 2.672725] ======== Card detection to detect SDIO card! ========
[ 2.672732] mmc2:mmc host rescan start!
[ 2.712148] init: /dev/hw_random not found
[ 2.713275] init: /dev/hw_random not found
[ 2.714154] android_usb: already disabled
[ 2.714337] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 2.714358] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 2.889186] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 2.923863] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.925371] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.926874] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.929588] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.977740] EHCI: rk_ehci_hcd_enable, disable host controller
[ 2.977748] dwc_otg_hcd_enable, enable host controller
[ 2.982440] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 2.982467] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 2.982518] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 2.984104] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 2.984129] mmc2: new high speed SDIO card at address 0001
[ 3.000305] bcmsdh_register: register client driver
[ 3.000382] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.000452] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.000463] bus num (host idx)=2, slot num (rca)=1
[ 3.000472] found adapter info ‘DHD generic adapter’
[ 3.000697] F1 signature read @0x18000000=0x16224335
[ 3.002551] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 3.002824] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.002871] wifi_platform_get_mac_addr
[ 3.002882] ======== bcm_wlan_get_mac_address ========
[ 3.002891] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.002902] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.002911] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.002922] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 3.002966] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.003274] wl_create_event_handler(): thread:wl_event_handler:81 started
[ 3.003279] tsk Enter, tsk = 0xc5b4149c
[ 3.003422] dhd_attach(): thread:dhd_watchdog_thread:82 started
[ 3.003469] dhd_attach(): thread:dhd_dpc:83 started
[ 3.003481] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 3.003535] dhd_attach(): thread:dhd_rxf:84 started
[ 3.003552] dhd_deferred_work_init: work queue initialized
[ 3.003659] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 3.008563] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 3.008563] Compiled in drivers/net/wireless/bcmdhd on May 16 2017 at 10:15:03
[ 3.008922] Register interface [wlan0] MAC: 94:a1:a2:f7:cc:97
[ 3.008922]
[ 3.008940] dhd_prot_ioctl : bus is down. we have nothing to do
[ 3.008976] bcmsdh_oob_intr_unregister: Enter
[ 3.008986] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.008998] dhd_txglom_enable: enable 0
[ 3.009006] dhd_bus_devreset: WLAN OFF DONE
[ 3.009038] wifi_platform_set_power = 0
[ 3.009047] ======== PULL WL_REG_ON LOW! ========
[ 3.009055] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.081105] Using Buffer DMA mode
[ 3.081119] Periodic Transfer Interrupt Enhancement - disabled
[ 3.081125] Multiprocessor Interrupt Enhancement - disabled
[ 3.081136] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.081145] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.115494] [WLAN_RFKILL]: wifi shut off power.
[ 3.115508] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.115515] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.115567] dhd_module_init: Exit err=0
[ 3.125409] Init: Power Port (0)
[ 3.400884] Indeed it is in host mode hprt0 = 00021501
[ 3.578002] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.578082] Indeed it is in host mode hprt0 = 00001101
[ 3.775013] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.775028] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.775039] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.775446] hub 3-1:1.0: USB hub found
[ 3.775515] hub 3-1:1.0: 4 ports detected
[ 7.391904] drmboot: module license ‘unspecified’ taints kernel.
[ 7.391934] Disabling lock debugging due to kernel taint
[ 7.392192] drm init, 20140910
[ 7.392697] drm init ok
[ 7.392826] init: Unable to open persistent property directory /data/property errno: 2
[ 7.393553] android_usb: already disabled
[ 7.393699] init: using deprecated syntax for specifying property ‘ro.product.manufacturer’, use ${name} instead
[ 7.393754] init: using deprecated syntax for specifying property ‘ro.product.model’, use ${name} instead
[ 7.393804] init: using deprecated syntax for specifying property ‘ro.serialno’, use ${name} instead
[ 7.393820] init: property ‘ro.serialno’ doesn’t exist while expanding ‘$ro.serialno’
[ 7.393831] init: cannot expand ‘$ro.serialno’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 7.394838] init: Warning! Service console needs a SELinux domain defined; please fix!
[ 7.396844] read descriptors
[ 7.396859] read strings
[ 7.396885] pcd_pullup, is_on 1
[ 7.400290] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts:
[ 7.436928] rk3288-lcdc lcdc0: blank mode:0
[ 8.881745] [otg id chg] last id -1 current id 1
[ 8.881759] PortPower off
[ 8.881764] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 8.981183] Using Buffer DMA mode
[ 8.981189] Periodic Transfer Interrupt Enhancement - disabled
[ 8.981195] Multiprocessor Interrupt Enhancement - disabled
[ 8.981201] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 8.981206] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.078576] type=1400 audit(1293936904.320:3): avc: denied { create } for pid=31 comm=“kworker/3:1” name=“es8323_mic_state” scontext=u:r:kernel:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 9.078615] type=1400 audit(1293936904.320:4): avc: denied { write } for pid=31 comm=“kworker/3:1” path=“/data/es8323_mic_state” dev=“rootfs” ino=7925 scontext=u:r:kernel:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=1
[ 9.078658] es8323_mic_state_ctrl read:
[ 9.078670] mic_state_switch 0
[ 9.078675] hp_det = 0,insert hp
[ 9.078679] hp mic use intern
[ 9.472140] vbus detect**
[ 9.474318] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 9.651376] Using Buffer DMA mode
[ 9.651384] Periodic Transfer Interrupt Enhancement - disabled
[ 9.651389] Multiprocessor Interrupt Enhancement - disabled
[ 9.651395] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.651400] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.651438] soft connect!!!
[ 9.761034] USB RESET
[ 9.798540] android_work: sent uevent USB_STATE=CONNECTED
[ 9.802184] USB RESET
[ 9.871703] android_usb gadget: high-speed config #1: android
[ 9.871776] android_work: sent uevent USB_STATE=CONFIGURED
/sbin/sh: No controlling tty: open /dev/tty: No such device or address
/sbin/sh: warning: won’t have full job control
# [ 11.522615] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts:
