你好,
我安装官方镜像:Firefly-rk3399_xubuntu1604_201705111112.7z
第一次能够进入lightdm, GUI很棒
但是在我运行
sudo apt update
sudo apt upgrade
以及安装ROS及一些软件后,重新启动后,再也无法进入lightdm
lightdm log显示
sudo cat /var/log/lightdm/x-0.log
X.Org X Server 1.18.4
Release Date: 2016-07-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-83-generic aarch64 Ubuntu
Current Operating System: Linux firefly 4.4.52 #19 SMP Tue May 2 11:36:30 HKT 2017 aarch64
Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-04-25_15:10:21 androidboot.mode=emmc
Build Date: 17 July 2017 05:05:58PM
xorg-server 2:1.18.4-0ubuntu0.3 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.33.6
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
b Log file: “/var/log/Xorg.0.log”, Time: Fri Feb 12 00:28:08 2016[/b]
b Using config directory: “/etc/X11/xorg.conf.d”[/b]
b Using system config directory “/usr/share/X11/xorg.conf.d”[/b]
b[/b]
b Backtrace:[/b]
b 0: /usr/lib/xorg/Xorg (xorg_backtrace+0x58) [0x5581f49ce0][/b]
b[/b]
b Segmentation fault at address 0x7f9fa00000[/b]
b[/b]
Fatal server error:
b Caught signal 11 (Segmentation fault). Server aborting[/b]
b[/b]
b[/b]
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
b Please also check the log file at “/var/log/Xorg.0.log” for additional information.[/b]
b[/b]
b Server terminated with error (1). Closing log file.[/b]
我尝试了删除lightdm及重新安装
sudo apt purge lightdm
sudo apt install lightdm
还是不行。
请问有什么办法在不重新刷机得情况下能进入lightdm
多谢!
