Firefly-rk3288-reload使用kernel4.4+ubuntu16.04编译的软件启动出现问题
Firefly-rk3288-reload按照http://dev.t-firefly.com/thread-12393-1-1.html编译的linux固件 启动rootfs部分出现问题,打印信息如下
[ OK ] Stopped Braille Device Support.
[ OK ] Started Braille Device Support.
{DR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-01-gc0494ea (Sep 08 2017 - 02:04:40)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
2 GiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
ERROR: [get_entry]: Not a resource image!
failed to prepare fdt from resource!
no adc node
can’t find dts node for act8846
can’t find dts node for rk808
can’t find dts node for rk818
#Boot ver: 2017-09-08#2.19
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to load fdt from boot!
failed to load fdt!
kernel @ 0x02000000 (0x00361a75)
ramdisk @ 0x04bf0000 (0x00275a49)
Secure Boot state: 0
bootrk: do_bootm_linux…
Uncompressing Linux… done, booting the kernel.
Booting Linux on physical CPU 0x500
Initializing cgroup subsys cpu
Initializing cgroup subsys cpuacct
Linux version 4.0.0-rc1+ (liuzi@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP Fri Sep 8 02:03:59 PDT 2017
CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Firefly-RK3288
bootconsole [earlycon0] enabled
Memory policy: Data cache writealloc
PERCPU: Embedded 10 pages/cpu @ee7ac000 s11712 r8192 d21056 u40960
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768
Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 init=/sbin/init root=/dev/block/mtd/by-name/linuxroot rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(boot),0x0001a000@0x0001d000(backup),-@0x0037000(linuxroot) storagemedia=emmc loader.timestamp=2017-09-08_02:04:40
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 2070300K/2097152K available (4559K kernel code, 185K rwdata, 1480K rodata, 256K init, 302K bss, 26852K reserved, 0K cma-reserved, 1318912K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc05edf74 (6040 kB)
.init : 0xc05ee000 - 0xc062e000 ( 256 kB)
.data : 0xc062e000 - 0xc065c620 ( 186 kB)
.bss : 0xc065c620 - 0xc06a8174 ( 303 kB)
Hierarchical RCU implementation.
Additional per-CPU info printed with stalls.
NR_IRQS:16 nr_irqs:16 16
L2C: failed to init: -19
rockchip: enabling rk3288-timer7 workaround
Architected cp15 timer(s) running at 24.00MHz (phys).
sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns
Switching to timer-based delay loop, resolution 41ns
Console: colour dummy device 80x30
console [tty0] enabled
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Initializing cgroup subsys freezer
Initializing cgroup subsys debug
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
Setting up static identity map for 0x47a010 - 0x47a068
CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
Brought up 4 CPUs
SMP: Total of 4 processors activated (192.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
reg-fixed-voltage sdmmc-regulator: Failed to find supply vin
reg-fixed-voltage sdmmc-regulator: Failed to register regulator: -517
platform sdmmc-regulator: Driver reg-fixed-voltage requests probe deferral
reg-fixed-voltage flash-regulator: Failed to find supply vin
reg-fixed-voltage flash-regulator: Failed to register regulator: -517
platform flash-regulator: Driver reg-fixed-voltage requests probe deferral
vcc_5v: supplied by vcc_sys
vcc_host_5v: supplied by vcc_5v
vcc_otg_5v: supplied by vcc_5v
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource arch_sys_counter
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Trying to unpack rootfs image as initramfs…
Freeing initrd memory: 2520K (c4bf0000 - c4e66000)
futex hash table entries: 1024 (order: 4, 65536 bytes)
bounce: pool size: 64 pages
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
io scheduler noop registered
io scheduler deadline registered (default)
dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 33, base_baud = 1500000) is a 16550A
ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 34, base_baud = 1500000) is a 16550A
console [ttyS2] disabled
ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 35, base_baud = 1500000) is a 16550A
console [ttyS2] enabled
bootconsole [earlycon0] disabled
ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 36, base_baud = 1500000) is a 16550A
[drm] Initialized drm 1.1.0 20060810
rockchip-drm display-subsystem: bound ff940000.vop (ops vop_component_ops)
rockchip-drm display-subsystem: bound ff930000.vop (ops vop_component_ops)
rockchip-drm display-subsystem: failed to bind ff980000.hdmi (ops dw_hdmi_rockchip_ops): -517
rockchip-drm display-subsystem: master bind failed: -517
platform ff940000.vop: Driver rockchip-vop requests probe deferral
brd: module loaded
loop: module loaded
stmmaceth ff290000.ethernet: phy regulator is not available yet, deferred probing
platform ff290000.ethernet: Driver stmmaceth requests probe deferral
dwc2 ff540000.usb: DWC OTG Controller
dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
dwc2 ff540000.usb: irq 38, io mem 0x00000000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DWC OTG Controller
usb usb1: Manufacturer: Linux 4.0.0-rc1+ dwc2_hsotg
usb usb1: SerialNumber: ff540000.usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb 1-1: new high-speed USB device number 2 using dwc2
usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product: USB 2.0 Hub [MTT]
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
dwc2 ff580000.usb: DWC OTG Controller
dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
dwc2 ff580000.usb: irq 39, io mem 0x00000000
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: DWC OTG Controller
usb usb2: Manufacturer: Linux 4.0.0-rc1+ dwc2_hsotg
usb usb2: SerialNumber: ff580000.usb
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
rk3x-i2c ff140000.i2c: using default SCL frequency: 100000
rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f00d6000
rk3x-i2c ff160000.i2c: using default SCL frequency: 100000
rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f00d8000
rk3x-i2c ff170000.i2c: using default SCL frequency: 100000
rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f00da000
fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
vdd_cpu: supplied by vcc_sys
fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
vdd_gpu: supplied by vcc_sys
rtc-hym8563 0-0051: no valid clock/calendar values available
rtc (null): read_time: fail to read
rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f00dc000
rk3x-i2c ff660000.i2c: using default SCL frequency: 100000
rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f00de000
lirc_dev: IR Remote Control driver registered, major 247
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR LIRC bridge handler initialized
IR XMP protocol handler initialized
Registered IR keymap rc-empty
input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0/input0
rc0: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc0
input: MCE IR Keyboard/Mouse (gpio-rc-recv) as /devices/virtual/input/input1
rc rc0: lirc_dev: driver ir-lirc-codec (gpio-rc-recv) registered at minor = 0
softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
Driver ‘mmcblk’ needs updating - please use bus_type methods
Synopsys Designware Multimedia Card Interface Driver
dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
dwmmc_rockchip ff0c0000.dwmmc: Using PIO mode.
dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 25, 32 bit host data width, 256 deep fifo
platform ff0c0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
dwmmc_rockchip ff0d0000.dwmmc: Using PIO mode.
dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 26, 32 bit host data width, 256 deep fifo
dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found
mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
dwmmc_rockchip ff0f0000.dwmmc: Using PIO mode.
dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 27, 32 bit host data width, 256 deep fifo
platform ff0f0000.dwmmc: Driver dwmmc_rockchip requests probe deferral
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usbcore: registered new interface driver r8188eu
usbcore: registered new interface driver rtl8723au
TCP: cubic registered
NET: Registered protocol family 17
Registering SWP/SWPB emulation handler
vcc_sd: supplied by vcc_io
vcc_flash: supplied by vcc_io
dwhdmi-rockchip ff980000.hdmi: Detected HDMI controller 0x20:0xa:0xa0:0xc1
rockchip-drm display-subsystem: bound ff980000.hdmi (ops dw_hdmi_rockchip_ops)
[drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[drm] No driver support for vblank timestamp query.
rockchip-drm display-subsystem: No connectors reported connected with modes
[drm] Cannot find any crtc or sizes - going 1024x768
Console: switching to colour frame buffer device 128x48
rockchip-drm display-subsystem: fb0: frame buffer device
rockchip-drm display-subsystem: registered panic notifier
stmmaceth ff290000.ethernet: rk_gmac_setup: clock input or output? (input).
stmmaceth ff290000.ethernet: rk_gmac_setup: TX delay(0x30).
stmmaceth ff290000.ethernet: rk_gmac_setup: RX delay(0x10).
stmmaceth ff290000.ethernet: rk_gmac_setup: init for RGMII
stmmaceth ff290000.ethernet: gmac_clk_init: clock input from PHY
stmmaceth ff290000.ethernet: no reset control found
stmmac - user ID: 0x10, Synopsys ID: 0x35
Ring mode enabled
DMA HW capability register supported
Normal descriptors
RX Checksum Offload Engine supported (type 2)
TX Checksum insertion supported
Wake-Up On Lan supported
Enable RX Mitigation via HW Watchdog Timer
libphy: stmmac: probed
eth0: PHY ID 00000000 at 0 IRQ POLL (stmmac-0:00) active
eth0: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
eth0: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
eth0: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
eth0: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
eth0: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
eth0: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
eth0: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
eth0: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
eth0: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
eth0: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
eth0: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
eth0: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
eth0: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
eth0: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
eth0: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
eth0: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
eth0: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
eth0: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
eth0: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
eth0: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
eth0: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
eth0: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
eth0: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
eth0: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
eth0: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
eth0: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
eth0: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
eth0: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
eth0: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
eth0: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
eth0: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
dwmmc_rockchip ff0c0000.dwmmc: No vqmmc regulator found
mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
input: gpio-keys as /devices/platform/gpio-keys/input/input2
rtc rtc0: read_time: fail to read
rtc-hym8563 0-0051: hctosys: unable to read the hardware clock
mmc2: MAN_BKOPS_EN bit is not set
vcc_sd: disabling
mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
mmc2: new high speed MMC card at address 0001
mmcblk0: mmc2:0001 AGND3R 14.5 GiB
mmcblk0boot0: mmc2:0001 AGND3R partition 1 4.00 MiB
mmcblk0boot1: mmc2:0001 AGND3R partition 2 4.00 MiB
mtd: partition size too small (4)
uboot: 0x000400000 – 0x000800000 (4 MB)
misc: 0x000800000 – 0x000c00000 (4 MB)
resource: 0x000c00000 – 0x001c00000 (16 MB)
kernel: 0x001c00000 – 0x002c00000 (16 MB)
boot: 0x002c00000 – 0x003c00000 (16 MB)
backup: 0x003a00000 – 0x006e00000 (52 MB)
linuxroot: 0x006e00000 – 0x3a3a00000 (14796 MB)
mmcblk0: p1 p2 p3 p4 p5 p6 p7
ttyS2 - failed to request DMA
Freeing unused kernel memory: 256K (c05ee000 - c062e000)
Loading, please wait…
udevd[149]: starting version 175
Begin: Loading essential drivers … FATAL: Could not load /lib/modules/4.0.0-rc1+/modules.dep: No such file or directory
done.
Begin: Running /scripts/init-premount … done.
ext4
Begin: Running /scripts/local-premount … FATAL: Could not load /lib/modules/4.0.0-rc1+/modules.dep: No such file or directory
done.
EXT4-fs (mmcblk0p7): recovery complete
EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
Begin: Running /scripts/local-bottom … done.
done.
Begin: Running /scripts/init-bottom … done.
systemd[1]: System time before build time, advancing clock.
systemd[1]: Failed to insert module ‘autofs4’: No such file or directory
random: systemd urandom read with 66 bits of entropy available
systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
systemd[1]: Detected architecture arm.
Welcome to Ubuntu 16.04 LTS!
systemd[1]: Set hostname to <localhost.localdomain>.
systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
systemd[1]: Starting Set console keymap…
systemd[1]: Mounting Debug File System…
systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
systemd[1]: Starting Create Static Device Nodes in /dev…
systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
systemd[1]: Starting Load Kernel Modules…
systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
systemd[1]: Started Braille Device Support.
systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
systemd[1]: Starting Remount Root and Kernel File Systems…
systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
systemd[1]: Reached target Encrypted Volumes.
[ OK ] Reached target Encrypted Volumes.
systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
systemd[1]: Reached target Remote File Systems (Pre).
[ OK ] Reached target Remote File Systems (Pre).
systemd[1]: Reached target User and Group Name Lookups.
[ OK ] Reached target User and Group Name Lookups.
systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
systemd[1]: Starting Journal Service…
systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
systemd[1]: Started Set console keymap.
[ OK ] Started Set console keymap.
systemd[1]: Started Create Static Device Nodes in /dev.
[ OK ] Started Create Static Device Nodes in /dev.
systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
systemd[1]: Failed to start Load Kernel Modules.
[FAILED] Failed to start Load Kernel Modules.
See ‘systemctl status systemd-modules-load.service’ for details.
systemd[1]: systemd-modules-load.service: Unit entered failed state.
systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
systemd[1]: brltty.service: Main process exited, code=exited, status=228/SECCOMP
systemd[1]: brltty.service: Unit entered failed state.
systemd[1]: brltty.service: Failed with result ‘exit-code’.
systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
Starting Load/Save Random Seed…
Starting udev Coldplug all Devices…
Starting Flush Journal to Persistent Storage…
Starting Apply Kernel Variables…
Starting udev Kernel Device Manager…
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Clean up any mess left by 0dns-up…
Starting LSB: AppArmor initialization…
Starting Set console font and keymap…
Starting Tell Plymouth To Write Out Runtime Data…
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Tell Plymouth To Write Out Runtime Data.
[ OK ] Started Clean up any mess left by 0dns-up.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Set console font and keymap.
[ OK ] Started LSB: AppArmor initialization.
[ OK ] Started ifup for eth0.
[ OK ] Created slice system-getty.slice.
Starting Create Volatile Files and Directories…
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
Starting Raise network interfaces…
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Started Timer to automatically refresh installed snaps.
[ OK ] Started CUPS Scheduler.
[ OK ] Reached target Paths.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Started Timer to automatically fetch and run repair assertions.
stmmac_open: Cannot attach to PHY (error: -19)
Starting Socket activation for snappy daemon.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Listening on CUPS Scheduler.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on Socket activation for snappy daemon.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Login Service…
Starting System Logging Service…
Starting Modem Manager…
Starting LSB: automatic crash report generation…
Starting LSB: Set the CPU Frequency Scaling governor to “ondemand”…
[ OK ] Started Regular background program processing daemon.
Starting Permit User Sessions…
Starting LSB: Speech Dispatcher…
Starting Restore /etc/resolv.conf i…re the ppp link was shut down…
Starting Accounts Service…
Starting Avahi mDNS/DNS-SD Stack…
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Make remote CUPS printers available locally.
[ OK ] Started Run anacron jobs.
Starting Network Manager…
Starting Snappy daemon…
[ OK ] Started System Logging Service.
[ OK ] Started Permit User Sessions.
[ OK ] Started Restore /etc/resolv.conf if…fore the ppp link was shut down.
[ OK ] Started LSB: automatic crash report generation.
[ OK ] Started LSB: Set the CPU Frequency Scaling governor to “ondemand”.
[ OK ] Started Snappy daemon.
[ OK ] Started LSB: Speech Dispatcher.
[ OK ] Started Network Manager.
[ OK ] Started Login Service.
Starting Network Manager Script Dispatcher Service…
Starting Network Manager Wait Online…
Starting Authenticate and Authorize Users to Run Privileged Tasks…
Starting Auto import assertions from block devices…
Starting Light Display Manager…
[ OK ] Started Auto import assertions from block devices.
[ OK ] Started Network Manager Script Dispatcher Service.
[ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks.
[ OK ] Started Accounts Service.
[ OK ] Started Modem Manager.
[ OK ] Started Light Display Manager.
Starting Hostname Service…
[ OK ] Started Hostname Service.
[ OK ] Started Network Manager Wait Online.
[ OK ] Stopped target Graphical Interface.
[FAILED] Failed to start Clean up any mess left by 0dns-up.
See ‘systemctl status dns-clean.service’ for details.
第一次接触linux软件制作 麻烦各位高手帮忙解答下,谢谢
大神,这个kernel4.4的移植,这个打印信息从串口打印的吗?
ubuntu 不是都起来了吗? 你根文件系统自己没做好吧
