RK3288 一直卡在 Starting kernel ...
在rk3288 上移植 kernel 4.4 ,按照wiki 步骤操作的,现在一直停在 Starting kernel …,
该从哪里开始分析,解决,求大神指点
log如下:
DDR Version 1.00 20160530
SRX
Channel a: LPDDR3 200MHz
MR0=0x88774458
MR1=0x88774458
MR2=0x88774458
MR3=0x88774458
MR4=0x88774403
MR5=0x88774401
MR6=0x88774403
MR7=0x88774400
MR8=0x8877441B
MR9=0x8877441B
MR10=0x8877441B
MR11=0x8877441B
MR12=0x8877441B
MR13=0x8877441B
MR14=0x8877441B
MR15=0x8877441B
MR16=0x8877441B
Bus Width=32 Col=10 Bank=8 Row=14/14 CS=2 Die Bus-Width=32 Size=1024MB
Channel b: LPDDR3 200MHz
MR0=0x88774458
MR1=0x88774458
MR2=0x88774458
MR3=0x88774458
MR4=0x88774403
MR5=0x88774401
MR6=0x88774403
MR7=0x88774400
MR8=0x8877441B
MR9=0x8877441B
MR10=0x8877441B
MR11=0x8877441B
MR12=0x8877441B
MR13=0x8877441B
MR14=0x8877441B
MR15=0x8877441B
MR16=0x8877441B
U-Boot 2014.10-RK3288-10-gc28aaca-dirty (Jul 10 2017 - 16:11:05)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
no key node
pmic:act8846
can’t find dts node for pwm1
decode dc_det_gpio err
#Boot ver: 2017-07-10#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
[jxw] lcd power ldo6,ldo8,swout2 on.
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x007870c8)
ramdisk @ 0x05bf0000 (0x001393e4)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0562f6af … OK
先烧入firefly的官方固件看会不会有问题
