平台:rk3288
系统:
Android:6.0.1
Linux:3.10.0
下面是系统启动日志
DDR Version 1.00 20160217
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10 (Sep 20 2017 - 12:22:52)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-09-20#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
pll_src = 0, dclk_hz = 205000000, dclk_div = 2
edp pll locked
Aux Transaction fail!
hw lt err:1
link train failed!
unable to config video
no fuel gauge found
got recovery cmd from misc.
Secure Boot state: 0
kernel @ 0x02000000 (0x006e95cc)
ramdisk @ 0x05bf0000 (0x00235914)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0563c303 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (guoys@qzlsv) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #8 SMP PREEMPT Wed Sep 20 19:48:58 CST 2017 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x01000000 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(drm): base(0) size(0) align(0) [ 0.000000] ion heap(cma): base(0) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 55c00000 [ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 1e000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1f17000 s13440 r8192 d15232 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523296 [ 0.000000] Kernel command line: vmalloc=512M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00200000@0x0039C000(userdata),0x00020000@0x0059C000(radical_update),-@0x005BC000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000:0x01000000 loader.timestamp=2017-09-20_12:22:52 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1353624k/1353624k available, 743528k reserved, 901120K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xdf800000 - 0xff000000 ( 504 MB) [ 0.000000] lowmem : 0xc0000000 - 0xdf000000 ( 496 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0c23e7c (12400 kB) [ 0.000000] .init : 0xc0c24000 - 0xc0c7f480 ( 366 kB) [ 0.000000] .data : 0xc0c80000 - 0xc0d9ba58 (1135 kB) [ 0.000000] .bss : 0xc0d9ba58 - 0xc0ebf5dc (1167 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! [ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div [ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 28 [ 0.000000] rk3288 set GPLL BW 20 for HDMI! [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 3 [ 0.000000] channel:0, lkg:18 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] channel:0, lkg:18 [ 0.000000] channel:1, lkg:16 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.347697] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.347712] pid_max: default: 32768 minimum: 301 [ 0.347827] Security Framework initialized [ 0.347844] SELinux: Initializing. [ 0.347918] Mount-cache hash table entries: 512 [ 0.348542] Initializing cgroup subsys debug [ 0.348555] Initializing cgroup subsys memory [ 0.348581] Initializing cgroup subsys freezer [ 0.348609] CPU: Testing write buffer coherency: ok [ 0.348918] /cpus/cpu@0 missing clock-frequency property [ 0.348931] /cpus/cpu@1 missing clock-frequency property [ 0.348941] /cpus/cpu@2 missing clock-frequency property [ 0.348950] /cpus/cpu@3 missing clock-frequency property [ 0.349000] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.349052] Setting up static identity map for 0xc08be930 - 0xc08be988 [ 0.351364] last_log: 0x1d900000 map to 0xdf804000 and copy to 0xdf886000, size 0x80000 early 0x184f (version 3.1) [ 0.425887] CPU1: Booted secondary processor [ 0.425919] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.445558] CPU2: Booted secondary processor [ 0.445581] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.465264] CPU3: Booted secondary processor [ 0.465287] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.465387] Brought up 4 CPUs [ 0.465416] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.465425] CPU: All CPU(s) started in SVC mode. [ 0.466147] devtmpfs: initialized [ 0.470415] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 0.471498] pinctrl core: initialized pinctrl subsystem [ 0.471743] regulator-dummy: no parameters [ 0.495829] NET: Registered protocol family 16 [ 0.497627] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.497962] ion_snapshot: 0x1da90000 map to 0xdf907000 and copy to 0xc0e9808c (version 0.1) [ 0.498239] Registered FIQ tty driver [ 0.499553] console [ttyFIQ0] enabled [ 0.499788] Registered fiq debugger ttyFIQ0 [ 0.500400] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.500424] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.500444] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.500462] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.500552] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.500618] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.500682] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.500746] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.500811] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.500875] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.500939] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.501003] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.501075] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.501144] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.501160] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.501174] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.501188] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.501808] rockchip_interrupts_register:bank_num=7 [ 0.503724] of_get_gpio_init_config:gpio[0] = 6, value = 0 [ 0.503781] rockchip_pinctrl_probe:init ok [ 0.509829] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.509916] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.509933] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.510104] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.510180] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.510196] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.510368] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.510440] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.510456] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.510623] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.510701] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.510717] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.510897] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.510973] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.510989] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.511157] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.511231] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.511247] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.511428] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.511504] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.511520] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.513158] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.513174] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.513763] rk3368_init_rockchip_pmu_ops: could not find pmu dt node [ 0.513788] DDR DEBUG: version 1.00 20150126 [ 0.513818] DDR DEBUG: Channel a: [ 0.513827] DDR DEBUG: DDR3 Device [ 0.513842] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.513854] DDR DEBUG: Channel b: [ 0.513863] DDR DEBUG: DDR3 Device [ 0.513876] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.513888] DDR DEBUG: addr=0xda5000 [ 0.513899] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.513910] DDR DEBUG: socAddr[0]=0xda5000, socAddr[1]=0xda5100 [ 0.513922] DDR DEBUG: chAddr[0]=0xda5000, chAddr[1]=0xda5000 [ 0.513936] DDR DEBUG: dtar[0]=0x501b4000, dtar[1]=0x501b4000 [ 0.513993] DDR DEBUG: init success!!! freq=200MHz [ 0.514003] DDR DEBUG: Channel a: [ 0.514017] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.514032] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.514048] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.514063] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.514078] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.514090] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.514100] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.514110] DDR DEBUG: Channel b: [ 0.514122] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.514137] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.514153] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.514168] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270 [ 0.514182] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.514193] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.514237] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.540535] bio: create slab at 0 [ 0.541084] Rockchip hdmi driver version 2.0 . [ 0.541484] SCSI subsystem initialized [ 0.541642] usbcore: registered new interface driver usbfs [ 0.541690] usbcore: registered new interface driver hub [ 0.541782] usbcore: registered new device driver usb [ 0.544387] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.545058] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.545512] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.545768] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.545879] media: Linux media interface: v0.10 [ 0.545926] Linux video capture interface: v2.00 [ 0.546039] pps_core: LinuxPPS API ver. 1 registered [ 0.546051] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.546075] PTP clock support registered [ 0.546555] ion_drm_heap_create: 0@0 [ 0.546690] Rockchip ion module is successfully loaded (v1.1) [ 0.546854] Advanced Linux Sound Architecture Driver Initialized. [ 0.547251] Bluetooth: Core ver 2.16 [ 0.547290] NET: Registered protocol family 31 [ 0.547303] Bluetooth: HCI device and connection manager initialized [ 0.547321] Bluetooth: HCI socket layer initialized [ 0.547336] Bluetooth: L2CAP socket layer initialized [ 0.547364] Bluetooth: SCO socket layer initialized [ 0.547619] cfg80211: Calling CRDA to update world regulatory domain [ 0.548230] act8846_i2c_probe,line=880 [ 0.549251] act8846_parse_dt,line=744 [ 0.549688] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.549713] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.551789] act_dcdc1: 1200 mV [ 0.554779] vccio: 3300 mV [ 0.556660] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 0.559620] act_dcdc4: 2000 mV [ 0.560882] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.563199] act_ldo2: 1000 mV [ 0.565554] act_ldo3: 3300 mV [ 0.567874] act_ldo4: 3300 mV [ 0.570200] act_ldo5: 3300 mV [ 0.572517] act_ldo6: 1000 mV [ 0.574878] vcc_18: 1800 mV [ 0.577199] act_ldo8: 1800 mV [ 0.582004] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.586746] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.588441] Switching to clocksource arch_sys_counter [ 0.613110] rga: Module initialized. [ 0.613827] rga2 ff920000.rga: rga ion client create success! [ 0.614051] rga: Driver loaded succesfully [ 0.614238] uboot-logo-on:1 [ 0.614271] rk-fb rockchip-fb: rk fb ion client create success! [ 0.614286] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.614591] rk-screen rk_screen.9: rockchip screen probe success [ 0.614745] rk32-lvds ff96c000.lvds: screen is not lvds/rgb! [ 0.614768] rk32-lvds: probe of ff96c000.lvds failed with error -22 [ 0.615256] rk32-edp rk32-edp: failed to get reset [ 0.615272] rk32-edp rk32-edp: failed to get reset [ 0.615371] rk32-edp rk32-edp: rk32 edp driver probe success [ 0.616105] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.616427] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.616593] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.616764] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.616992] rk3288-lcdc lcdc0: lcdc0: dclk:205000000>>fps:61 [ 0.640037] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.641668] rk3288-lcdc lcdc0: wakeup from standby! [ 0.692654] alloc_buffer:ion_phy_addr=0x55c00000 [ 0.712163] fb0:phy:55c00000>>vir:df991000>>len:0x2500000 [ 0.718316] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.718521] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1 [ 0.718537] rk_fb_trsm_ops_get: unsupported transmitter: 0! [ 0.718799] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.719139] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.719316] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.719478] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.719748] unknow screen type: 0 [ 0.719814] rk3288-lcdc lcdc1: lcdc1: dclk:205000000>>fps:1991 [ 0.744437] rk3288-lcdc lcdc1: wakeup from standby! [ 0.744453] fb4:phy:55c00000>>vir:df991000>>len:0x2500000 [ 0.744467] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.745227] rockchip_set_mux:warning ignore bank num 15 [ 0.745364] rockchip_set_mux:warning ignore bank num 15 [ 0.745487] rockchip_set_mux:warning ignore bank num 15 [ 0.745604] rockchip_set_mux:warning ignore bank num 15 [ 0.745724] rockchip_set_mux:warning ignore bank num 15 [ 0.745835] rockchip_set_mux:warning ignore bank num 15 [ 0.746430] rockchip_set_mux:warning ignore bank num 15 [ 0.746594] rockchip_set_mux:warning ignore bank num 15 [ 0.747170] rockchip_set_mux:warning ignore bank num 15 [ 0.747316] rockchip_set_mux:warning ignore bank num 15 [ 0.747889] rockchip_set_mux:warning ignore bank num 15 [ 0.748054] rockchip_set_mux:warning ignore bank num 15 [ 0.748605] rockchip_set_mux:warning ignore bank num 15 [ 0.748770] rockchip_set_mux:warning ignore bank num 15 [ 0.750205] NET: Registered protocol family 2 [ 0.750897] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.750981] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) [ 0.751057] TCP: Hash tables configured (established 4096 bind 4096) [ 0.751119] TCP: reno registered [ 0.751136] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.751161] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.751352] NET: Registered protocol family 1 [ 0.751641] RPC: Registered named UNIX socket transport module. [ 0.751656] RPC: Registered udp transport module. [ 0.751667] RPC: Registered tcp transport module. [ 0.751678] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.751900] Unpacking initramfs... [ 0.862575] Freeing initrd memory: 2260K (c5bf0000 - c5e25000) [ 0.863305] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 0.865275] vcodec_service: No core reset resource define [ 0.865497] vcodec_service: probe device ff9a0000.vpu_service [ 0.865535] vcodec_service: checking hw id 4831 [ 0.865934] vcodec_service: init success [ 0.866323] vcodec_service: probe device ff9c0000.hevc_service [ 0.866356] vcodec_service: checking hw id 6867 [ 0.866610] vcodec_service: init success [ 0.866761] rknandbase v1.0 2014-03-31 [ 0.866889] rknand: probe of ff400000.nandc0 failed with error -1 [ 0.866995] rknand_driver:ret = 0 [ 0.868163] audit: initializing netlink socket (disabled) [ 0.868229] type=2000 audit(0.520:1): initialized [ 0.869055] bounce pool size: 64 pages [ 0.873692] NFS: Registering the id_resolver key type [ 0.873759] Key type id_resolver registered [ 0.873771] Key type id_legacy registered [ 0.874154] fuse init (API version 7.22) [ 0.874528] msgmni has been set to 920 [ 0.874916] [ 0.874916] TEE Core Framework initialization (ver 1:0.1) [ 0.874949] TEE armv7 Driver initialization [ 0.875275] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ 0.875294] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ 0.875466] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=60) [ 0.877125] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.877143] io scheduler noop registered [ 0.877154] io scheduler deadline registered [ 0.877242] io scheduler cfq registered (default) [ 0.878447] hdmi phy_table not exist [ 0.878867] reset hdmi [ 0.879001] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess. [ 0.879695] iep ion client create success! [ 0.879710] IEP Driver loaded succesfully [ 0.879793] Module initialized. [ 0.880775] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.880796] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 0.882142] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.882163] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.882486] rk_serial.c v1.8 2014-03-04 [ 0.882715] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 0.882917] serial ff180000.serial: membase df97e000 [ 0.883158] arm_release_ver of this mali_ko is 'r6p0-02rel0', rk_ko_ver is '13', built at '14:16:43', on 'Sep 20 2017'. [ 0.883225] mali ffa30000.gpu: Continuing without Mali clock control [ 0.883263] mali pd enabled [ 0.883278] clk enabled [ 0.883291] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.883305] MALI_DVFS_STEP = 5, div_dvfs = 7 [ 0.883318] mali_dvfs_infotbl[0].clock=100000,min_threshold=0,max_threshold=70 [ 0.883332] mali_dvfs_infotbl[1].clock=200000,min_threshold=65,max_threshold=77 [ 0.883346] mali_dvfs_infotbl[2].clock=300000,min_threshold=75,max_threshold=84 [ 0.883359] mali_dvfs_infotbl[3].clock=420000,min_threshold=82,max_threshold=91 [ 0.883372] mali_dvfs_infotbl[4].clock=500000,min_threshold=93,max_threshold=100 [ 0.883480] turn on mali power [ 0.883494] kbase_platform_rk_init,register_reboot_notifier [ 0.883561] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.883569] hrtimer: interrupt took 27125 ns [ 0.883729] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1 [ 0.884453] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.884762] mali ffa30000.gpu: Probed as mali0 [ 0.884867] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 389; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-c5a435b', rk_ko_ver is '5', built at '14:16:30', on 'Sep 20 2017'. [ 0.885110] Mali: Mali device driver loaded [ 0.887761] loop: module loaded [ 0.888122] zram: Created 1 device(s) ... [ 0.888289] i2c i2c-1: mpu_probe: 0 [ 0.888401] 6mldl_cfg:Reset MPU6050 B1 [ 0.889381] drivers/misc/inv_mpu/mlsl-kernel.c|inv_i2c_write|48 returning -11 [ 0.889398] drivers/misc/inv_mpu/mldl_cfg.c|mpu60xx_pwr_mgmt|563 returning -11 [ 0.889413] drivers/misc/inv_mpu/mldl_cfg.c|inv_mpu_open|1461 returning -11 [ 0.889429] i2c i2c-1: Unable to open mpu6050B1 -11 [ 0.889444] i2c i2c-1: mpu_probe failed -19 [ 0.889503] i2c-core: driver [mpu6050B1] using legacy suspend method [ 0.889516] i2c-core: driver [mpu6050B1] using legacy resume method [ 0.889533] mpu_init: Probe name mpu6050B1 [ 0.889715] bus=0,adapt_num=0,addr=d [ 0.889727] 1 0 0 0 1 0 0 0 -1 [ 0.889756] i2c i2c-1: ak8963_mod_probe: (null) [ 0.889767] yemk:ak8963_mod_probe [ 0.889781] i2c i2c-1: inv_mpu_register_slave: Null mpu_private_data [ 0.889793] invensense: in ak8963_mod_probe, result is -22 [ 0.889807] i2c i2c-1: Slave registration failed: (null), -22 [ 0.889821] i2c i2c-1: ak8963_mod_probe failed -22 [ 0.889837] ak8963_mod: probe of 1-000d failed with error -22 [ 0.889869] ak8963_mod_init: Probe name ak8963_mod [ 0.890533] SCSI Media Changer driver v0.25 [ 0.890854] tun: Universal TUN/TAP device driver, 1.6 [ 0.890868] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 0.891006] vmac_init. [ 0.891325] PPP generic driver version 2.4.2 [ 0.891490] PPP BSD Compression module registered [ 0.891503] PPP Deflate Compression module registered [ 0.891533] PPP MPPE Compression module registered [ 0.891547] NET: Registered protocol family 24 [ 0.891586] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 0.891599] CSLIP: code copyright 1989 Regents of the University of California. [ 0.891619] Rockchip WiFi SYS interface (V1.00) ... [ 0.891657] esp_mem_init enter date Sep 20 2017 14:16:52 [ 0.891668] esp_mem_init VERSION [V2.5] [ 0.891713] esp_mem_init complete [ 0.891800] usbcore: registered new interface driver catc [ 0.891840] usbcore: registered new interface driver kaweth [ 0.891853] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 0.891893] usbcore: registered new interface driver pegasus [ 0.891945] usbcore: registered new interface driver rtl8150 [ 0.892000] usbcore: registered new interface driver r8152 [ 0.892012] hso: drivers/net/usb/hso.c: Option Wireless [ 0.892085] usbcore: registered new interface driver hso [ 0.892131] usbcore: registered new interface driver asix [ 0.892171] usbcore: registered new interface driver ax88179_178a [ 0.892210] usbcore: registered new interface driver cdc_ether [ 0.892257] usbcore: registered new interface driver cdc_eem [ 0.892297] usbcore: registered new interface driver dm9601 [ 0.892335] usbcore: registered new interface driver dm9620 [ 0.892383] usbcore: registered new interface driver smsc75xx [ 0.892432] usbcore: registered new interface driver smsc95xx [ 0.892487] usbcore: registered new interface driver gl620a [ 0.892536] usbcore: registered new interface driver net1080 [ 0.892576] usbcore: registered new interface driver plusb [ 0.892616] usbcore: registered new interface driver rndis_host [ 0.892655] usbcore: registered new interface driver cdc_subset [ 0.892693] usbcore: registered new interface driver zaurus [ 0.892733] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 0.892795] usbcore: registered new interface driver int51x1 [ 0.892835] usbcore: registered new interface driver kalmia [ 0.892883] usbcore: registered new interface driver ipheth [ 0.892926] usbcore: registered new interface driver sierra_net [ 0.892972] usbcore: registered new interface driver cx82310_eth [ 0.893022] usbcore: registered new interface driver cdc_ncm [ 0.893062] usbcore: registered new interface driver qmi_wwan [ 0.893102] usbcore: registered new interface driver cdc_mbim [ 0.893114] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.893127] ehci-platform: EHCI generic platform driver [ 0.895771] EHCI: ehci_rk_probe e2f40000 e2f40010 [ 0.895790] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 0.895821] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 0.896191] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 0.904125] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.913238] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 0.913325] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.913342] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.913358] usb usb1: Product: EHCI Host Controller [ 0.913370] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 0.913384] usb usb1: SerialNumber: ff500000.usb [ 0.913869] hub 1-0:1.0: USB hub found [ 0.913902] hub 1-0:1.0: 1 port detected [ 0.914060] EHCI: ehci_rk_probe ok [ 0.914152] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.914296] ohci-platform: OHCI generic platform driver [ 0.914467] usbcore: registered new interface driver cdc_acm [ 0.914479] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 0.914531] usbcore: registered new interface driver usblp [ 0.914571] usbcore: registered new interface driver cdc_wdm [ 0.914634] usbcore: registered new interface driver usb-storage [ 0.914679] usbcore: registered new interface driver ums-alauda [ 0.914718] usbcore: registered new interface driver ums-cypress [ 0.914755] usbcore: registered new interface driver ums-datafab [ 0.914791] usbcore: registered new interface driver ums_eneub6250 [ 0.914827] usbcore: registered new interface driver ums-freecom [ 0.914863] usbcore: registered new interface driver ums-isd200 [ 0.914900] usbcore: registered new interface driver ums-jumpshot [ 0.914936] usbcore: registered new interface driver ums-karma [ 0.914972] usbcore: registered new interface driver ums-onetouch [ 0.915011] usbcore: registered new interface driver ums-sddr09 [ 0.915048] usbcore: registered new interface driver ums-sddr55 [ 0.915091] usbcore: registered new interface driver ums-usbat [ 0.915178] usbcore: registered new interface driver usbserial [ 0.915220] usbcore: registered new interface driver usbserial_generic [ 0.915252] usbserial: USB Serial support registered for generic [ 0.915291] usbcore: registered new interface driver option [ 0.915321] usbserial: USB Serial support registered for GSM modem (1-port) [ 0.915414] usbcore: registered new interface driver trancevibrator [ 0.915427] usb20_otg: version 3.10a 21-DEC-2012 [ 0.915853] e2f80040 [ 0.915867] Core Release: 3.10a [ 0.915878] Setting default values for core params [ 0.916003] Using Buffer DMA mode [ 0.916015] Periodic Transfer Interrupt Enhancement - disabled [ 0.916027] Multiprocessor Interrupt Enhancement - disabled [ 0.916039] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 0.916049] ^^^^^^^^^^^^^^^^^Device Mode [ 0.916064] Dedicated Tx FIFOs mode [ 0.916083] pcd_init otg_dev = dcf4e080 [ 0.916244] usb20_otg ff580000.usb: DWC OTG Controller [ 0.916273] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 0.916305] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 0.916364] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.916380] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.916394] usb usb2: Product: DWC OTG Controller [ 0.916407] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 0.916420] usb usb2: SerialNumber: ff580000.usb [ 0.916826] hub 2-0:1.0: USB hub found [ 0.916850] hub 2-0:1.0: 1 port detected [ 0.917151] usb20_host: version 3.10a 21-DEC-2012 [ 0.919643] e3000040 [ 0.919657] Core Release: 3.10a [ 0.919667] Setting default values for core params [ 0.919790] Using Buffer DMA mode [ 0.919802] Periodic Transfer Interrupt Enhancement - disabled [ 0.919812] Multiprocessor Interrupt Enhancement - disabled [ 0.919824] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 0.919833] ^^^^^^^^^^^^^^^^^^Host Mode [ 0.919862] usb20_host ff540000.usb: DWC OTG Controller [ 0.919888] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 0.919920] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 0.920012] Init: Power Port (0) [ 0.920069] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.920086] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.920101] usb usb3: Product: DWC OTG Controller [ 0.920119] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 0.920145] usb usb3: SerialNumber: ff540000.usb [ 0.920542] hub 3-0:1.0: USB hub found [ 0.920564] hub 3-0:1.0: 1 port detected [ 0.921257] usbcore: registered new interface driver xpad [ 0.921315] usbcore: registered new interface driver usb_acecad [ 0.921361] usbcore: registered new interface driver aiptek [ 0.921405] usbcore: registered new interface driver gtco [ 0.921456] usbcore: registered new interface driver hanwang [ 0.921501] usbcore: registered new interface driver kbtab [ 0.921553] usbcore: registered new interface driver wacom [ 0.921940] sensor_register_slave:mma8452,id=17 [ 0.921955] sensor_register_slave:mma7660,id=18 [ 0.921967] sensor_register_slave:gs_mc3230,id=23 [ 0.921977] gsensor_init [ 0.921987] sensor_register_slave:mpu6880_acc,id=24 [ 0.921999] sensor_register_slave:mpu6500_acc,id=25 [ 0.922010] sensor_register_slave:cm3217,id=48 [ 0.922021] sensor_register_slave:cm3218,id=49 [ 0.923822] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.926932] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 0.926979] i2c /dev entries driver [ 0.927596] IR NEC protocol handler initialized [ 0.927610] IR RC5(x) protocol handler initialized [ 0.927620] IR RC6 protocol handler initialized [ 0.927631] IR JVC protocol handler initialized [ 0.927640] IR Sony protocol handler initialized [ 0.927650] IR RC5 (streamzap) protocol handler initialized [ 0.927660] IR SANYO protocol handler initialized [ 0.927671] IR MCE Keyboard/mouse protocol handler initialized [ 0.927824] usbcore: registered new interface driver uvcvideo [ 0.927836] USB Video Class driver (1.1.1) [ 0.927848] CamSys driver version: v0.33.0, CamSys head file version: v0.11.0 [ 0.928847] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288 [ 0.928847] [ 0.928926] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 0.929097] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe2ef8000 size: 0x4000) [ 0.929770] D1:camsys_platform_probe(1394): ff910000.isp memory: [ 0.929789] D1:camsys_platform_probe(1404): Register memory (phy: 0xff910000 vir: 0xe2f20000 size: 0x10000) [ 0.929805] D1:camsys_platform_probe(1399): I2c memory (phy: 0x5801000 vir: 0xc5801000 size: 0x1000) [ 0.929820] D1:camsys_init_ext_fsh_module(20): init external flash module [ 0.929832] D1:camsys_platform_probe(1419): Probe ff910000.isp device success [ 0.930182] not find test_power_init dev node [ 0.930706] rockchip_temp_probe,line=375 [ 0.931020] tsadc ff280000.tsadc: Missing tsadc_low_temp in the DT. [ 0.932956] DVFS ERR: dvfs_target: clk_gpu is disable, set rate error [ 0.982110] tsadc ff280000.tsadc: initialized [ 0.982541] device-mapper: uevent: version 1.0.3 [ 0.982795] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 0.983021] Bluetooth: HCI UART driver ver 2.2 [ 0.983036] Bluetooth: HCI H4 protocol initialized [ 0.983048] Bluetooth: HCILL protocol initialized [ 0.983060] rtk_btusb: Realtek Bluetooth USB driver module init, version 3.0 [ 0.983072] rtk_btusb: Register usb char device interface for BT driver [ 0.983245] usbcore: registered new interface driver rtk_btusb [ 0.986621] cpufreq version 1.0, suspend freq 1200 MHz [ 0.987170] cpuidle: using governor ladder [ 0.987186] cpuidle: using governor menu [ 0.987224] Synopsys Designware Multimedia Card Interface Driver [ 0.987236] MHSC version = Ver 2.00 2015-06-10 [ 0.987540] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 0.987625] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc [ 0.987917] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 0.988082] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 0.988227] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_set_ios: no card. [mmc0] [ 1.001802] dwmmc_rockchip ff0f0000.rksdmmc: dw_mci_set_ios: no card. [mmc0] [ 1.011709] dwc_otg_hcd_suspend, usb device mode [ 1.021575] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 1.021589] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 1.021599] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 1.021961] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 1.022096] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc [ 1.022779] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 1.023216] dwmmc_rockchip ff0c0000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1] [ 1.023633] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found! [ 1.023700] dwmmc_rockchip ff0c0000.rksdmmc: dw_mci_set_ios: no card. [mmc1] [ 1.041161] dwmmc_rockchip ff0c0000.rksdmmc: dw_mci_set_ios: no card. [mmc1] [ 1.053615] mmc0: BKOPS_EN bit is not set [ 1.055505] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1) [ 1.055528] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 1.055581] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0] [ 1.055690] mmc0: new high speed MMC card at address 0001 [ 1.055957] mmcblk0: mmc0:0001 8WPD3R 7.28 GiB [ 1.056076] mmcblk0rpmb: mmc0:0001 8WPD3R partition 3 512 KiB [ 1.056386] parameter: 0x000000000 -- 0x000400000 (4 MB) [ 1.056397] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 1.056407] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 1.056416] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 1.056424] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 1.056433] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 1.056441] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 1.056450] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 1.056458] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 1.056466] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 1.056475] system: 0x012400000 -- 0x072400000 (1536 MB) [ 1.056483] metadata: 0x072400000 -- 0x073400000 (16 MB) [ 1.056492] baseparamer: 0x073400000 -- 0x073800000 (4 MB) [ 1.056500] userdata: 0x073800000 -- 0x0b3800000 (1024 MB) [ 1.056509] radical_update: 0x0b3800000 -- 0x0b7800000 (64 MB) [ 1.056532] user: 0x0b7800000 -- 0x1d1c00000 (4516 MB) [ 1.056564] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 [ 1.060874] dwmmc_rockchip ff0c0000.rksdmmc: dw_mci_set_ios: no card. [mmc1] [ 1.060882] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 1.060889] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 1.061194] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 1.061286] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc [ 1.061479] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 1.061611] dwmmc_rockchip ff0d0000.rksdmmc: dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 1.061865] dwmmc_rockchip ff0d0000.rksdmmc: dw_mci_set_ios: no card. [mmc2] [ 1.080522] dwmmc_rockchip ff0d0000.rksdmmc: dw_mci_set_ios: no card. [mmc2] [ 1.100206] dwmmc_rockchip ff0d0000.rksdmmc: dw_mci_set_ios: no card. [mmc2] [ 1.100224] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 1.100237] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 1.100598] hidraw: raw HID events driver (C) Jiri Kosina [ 1.102051] usbcore: registered new interface driver usbhid [ 1.102061] usbhid: USB HID core driver [ 1.102169] ashmem: initialized [ 1.102282] logger: created 256K log 'log_main' [ 1.102387] logger: created 256K log 'log_events' [ 1.102491] logger: created 256K log 'log_radio' [ 1.102583] logger: created 256K log 'log_system' [ 1.103628] input: rk29-keypad as /devices/ff100000.adc/key.31/input/input0 [ 1.105245] es8323 probe error [ 1.105265] ES8323: probe of 2-0010 failed with error -11 [ 1.107825] rockchip-hdmi-i2s rockchip-hdmi-i2s.27: rk-hdmi-i2s-hifi <-> ff890000.rockchip-i2s mapping ok [ 1.108366] u32 classifier [ 1.108375] Actions configured [ 1.108386] Netfilter messages via NETLINK v0.30. [ 1.108445] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 1.108776] ctnetlink v0.93: registering with nfnetlink. [ 1.108843] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 1.108852] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 1.109115] xt_time: kernel timezone is -0000 [ 1.109319] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.109451] arp_tables: (C) 2002 David S. Miller [ 1.109489] TCP: cubic registered [ 1.109496] Initializing XFRM netlink socket [ 1.109718] NET: Registered protocol family 10 [ 1.110248] mip6: Mobile IPv6 [ 1.110279] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.110397] sit: IPv6 over IPv4 tunneling driver [ 1.110745] NET: Registered protocol family 17 [ 1.110773] NET: Registered protocol family 15 [ 1.110827] Bridge firewalling registered [ 1.110840] Ebtables v2.0 registered [ 1.110991] Bluetooth: RFCOMM TTY layer initialized [ 1.111020] Bluetooth: RFCOMM socket layer initialized [ 1.111028] Bluetooth: RFCOMM ver 1.11 [ 1.111037] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 1.111044] Bluetooth: BNEP filters: protocol multicast [ 1.111057] Bluetooth: BNEP socket layer initialized [ 1.111065] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.111076] Bluetooth: HIDP socket layer initialized [ 1.111133] l2tp_core: L2TP core driver, V2.0 [ 1.111152] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 1.111160] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.111380] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 1.111392] [WLAN_RFKILL]: can't find rockchip,grf property [ 1.111402] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8723bs [ 1.111411] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 1.111421] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 1.111431] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 1.111455] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 148, flags = 0. [ 1.111478] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0. [ 1.111487] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 1.111514] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 1.111523] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.111566] [BT_RFKILL]: Enter rfkill_rk_init [ 1.111707] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139. [ 1.111726] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 147. [ 1.111741] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149. [ 1.111756] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146. [ 1.111772] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151. [ 1.111825] [BT_RFKILL]: Request irq for bt wakeup host [ 1.111922] [BT_RFKILL]: ** disable irq [ 1.112006] [BT_RFKILL]: bt_default device registered. [ 1.112065] Key type dns_resolver registered [ 1.112811] rk3288_init_suspend [ 1.112825] rk3288_suspend_init enter [ 1.113033] rk3288_suspend_init: pm_ctrbits =200007 [ 1.113073] gpio_get_dts_info suspend:4 [ 1.113081] gpio_get_dts_info resume:4 [ 1.113089] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.113122] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 1.113283] clks_gating_suspend_init:clkgt info ok [ 1.113376] Registering SWP/SWPB emulation handler [ 1.113390] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000 [ 1.116674] ddrfreq: verion 1.2 20140526 [ 1.116689] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz [ 1.116699] ddrfreq: auto-freq=1 [ 1.116706] ddrfreq: auto-freq-table[0] 240MHz [ 1.116713] ddrfreq: auto-freq-table[1] 324MHz [ 1.116719] ddrfreq: auto-freq-table[2] 396MHz [ 1.116725] ddrfreq: auto-freq-table[3] 528MHz [ 1.122759] regulator-dummy: disabling [ 1.122843] [ 1.122849] ======================================================= [ 1.122855] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 1.122860] ======================================================= [ 1.122866] Realtek 8723BS SDIO WiFi driver (Powered by Rockchip) init. [ 1.122873] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 1.122879] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1 [ 1.122885] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled. [ 1.228119] [WLAN_RFKILL]: wifi turn on power. 148 [ 1.228128] mmc2:mmc host rescan start! [ 1.228138] RTL871X: module init start [ 1.228144] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844 [ 1.228149] RTL871X: build time: Sep 20 2017 19:46:05 [ 1.228155] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844 [ 1.228199] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 1.228221] rtw_android_wifictrl_func_add: rockchip_wifi_get_oob_irq :196 [ 1.228227] RTL871X: module init ret=0 [ 1.228290] pcd_pullup, is_on 0 [ 1.228326] file system registered [ 1.228879] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 1.228887] android_usb gadget: Number of LUNs=2 [ 1.228895] lun0: LUN: removable file: (no medium) [ 1.228901] lun1: LUN: removable file: (no medium) [ 1.229066] android_usb gadget: android_usb ready [ 1.229130] sensor_init: Probe name sensors [ 1.229148] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 1.229678] rtc_hym8563 0-0051: setting system clock to 2011-01-04 09:43:30 UTC (1294134210) [ 1.234912] rockchip_headset_probe() headset have hook adc mode [ 1.235060] input: rockchip_headset.30 as /devices/ff100000.adc/rockchip_headset.30/input/input1 [ 1.235675] usbcore: registered new interface driver snd-usb-audio [ 1.235684] ALSA device list: [ 1.235689] #0: RK-HDMI-I2S [ 1.235942] Freeing unused kernel memory: 364K (c0c24000 - c0c7f000) [ 1.236634] init: error to open scaling_available_frequencies [ 1.444593] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2] [ 1.479846] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 1.479867] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2] [ 1.479914] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2] [ 1.480549] mmc2: new high speed SDIO card at address 0001 [ 1.512164] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter. [ 1.512182] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00] [ 1.512197] [WLAN_RFKILL]: This mac address is not valid, ignored... [ 1.512833] RTL871X: rtw_ndev_init(wlan0) [ 1.513287] RTL871X: rtw_ndev_init(p2p0) [ 1.536284] type=1403 audit(1294134210.800:2): policy loaded auid=4294967295 ses=4294967295 [ 1.541564] init: property_set("ro.hardware", "rk30board") failed [ 1.563742] init: waitpid failed: No child processes [ 1.564767] init: property_set("ro.kernel.android.checkjni", "1") failed [ 1.565254] init: /init.rc: 10: invalid command 'setcon' [ 1.565302] init: /init.rc: 68: invalid command 'load_all_props' [ 1.565398] init: could not import file '/init.recovery.rk30board.rc' from '/init.rc' [ 1.565483] type=1400 audit(1294134210.830:3): avc: denied { setcheckreqprot } for pid=1 comm="init" scontext=u:r:init:s0 tcontext=u:object_r:kernel:s0 tclass=security permissive=1 [ 1.566444] ueventd: ueventd started! [ 1.566776] type=1400 audit(1294134210.830:4): avc: denied { write } for pid=140 comm="healthd" name="/" dev="tmpfs" ino=2131 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 1.566802] type=1400 audit(1294134210.830:5): avc: denied { mknod } for pid=140 comm="healthd" capability=27 scontext=u:r:healthd:s0 tcontext=u:r:healthd:s0 tclass=capability permissive=1 [ 1.566821] type=1400 audit(1294134210.830:6): avc: denied { add_name } for pid=140 comm="healthd" name="__kmsg__" scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 1.566836] ueventd: invalid gid 'trace' [ 1.566852] type=1400 audit(1294134210.830:7): avc: denied { create } for pid=140 comm="healthd" name="__kmsg__" scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1 [ 1.566889] type=1400 audit(1294134210.830:8): avc: denied { write } for pid=140 comm="healthd" name="__kmsg__" dev="tmpfs" ino=8399 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1 [ 1.566914] type=1400 audit(1294134210.830:9): avc: denied { open } for pid=140 comm="healthd" path="/dev/__kmsg__" dev="tmpfs" ino=8399 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1 [ 1.566943] type=1400 audit(1294134210.830:10): avc: denied { remove_name } for pid=140 comm="healthd" name="__kmsg__" dev="tmpfs" ino=8399 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=dir permissive=1 [ 1.566968] bat_cap: oldcap path is /sys/devices/ff100000.adc [ 1.567004] bat_cap: oldcap_path no exist [ 1.567135] healthd: No charger supplies found [ 1.567146] healthd: No battery devices found [ 1.658196] ueventd: Coldboot took 0.09s. [ 1.665081] init: /dev/hw_random not found [ 1.666150] init: /dev/hw_random not found [ 1.666716] android_usb: already disabled [ 1.666845] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 1.666863] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' [ 2.891072] dwc_otg_hcd_enable, enable host controller [ 2.891078] EHCI: rk_ehci_hcd_enable, disable host controller [ 2.994442] Using Buffer DMA mode [ 2.994449] Periodic Transfer Interrupt Enhancement - disabled [ 2.994455] Multiprocessor Interrupt Enhancement - disabled [ 2.994461] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 2.994467] ^^^^^^^^^^^^^^^^^^Host Mode [ 3.038734] Init: Power Port (0) [ 3.038771] ff540000.usb resume, HPRT0:0x21401 [ 3.176452] Indeed it is in host mode hprt0 = 00021501 [ 3.353555] usb 3-1: new high-speed USB device number 2 using usb20_host [ 3.353627] Indeed it is in host mode hprt0 = 00001101 [ 3.550558] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101 [ 3.550568] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 3.550575] usb 3-1: Product: USB 2.0 Hub [ 3.550964] hub 3-1:1.0: USB hub found [ 3.551024] hub 3-1:1.0: 4 ports detected [ 3.648942] dwc_otg_hc_halt: hcchar.b.chen 1, ep_type 3 [ 3.668432] ff540000.usb suspend, HPRT0:0x1485 [ 3.835721] yemk:mpu6050_load_cablic [ 3.835728] mpu6050_load_cablic: open file /dev/mtd/mtd6 [ 6.591388] drmboot: module license 'unspecified' taints kernel. [ 6.591410] Disabling lock debugging due to kernel taint [ 6.591868] drm init, 20140910 [ 6.592447] drm init ok [ 6.593047] init: service 'recovery' requires console [ 6.593106] android_usb: already disabled [ 6.593238] init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead [ 6.593286] init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead [ 6.593329] init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead [ 6.593345] init: property 'ro.serialno' doesn't exist while expanding '$ro.serialno' [ 6.593357] init: cannot expand '$ro.serialno' while writing to '/sys/class/android_usb/android0/iSerial' [ 6.593371] init: service 'console' requires console [ 8.785222] [otg id chg] last id -1 current id 1 [ 8.785242] PortPower off [ 8.785249] rk_battery_charger_detect_cb , battery_charger_detect 6 [ 8.884672] Using Buffer DMA mode [ 8.884683] Periodic Transfer Interrupt Enhancement - disabled [ 8.884689] Multiprocessor Interrupt Enhancement - disabled [ 8.884696] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 8.884702] ^^^^^^^^^^^^^^^^^Device Mode [ 8.884714] dwc_otg_hcd_resume, usb device mode [ 8.991896] dwc_otg_hcd_suspend, usb device mode [ 9.375626] ***************vbus detect***************** [ 9.377810] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 16.635456] read descriptors [ 16.635473] read descriptors [ 16.635481] read strings [ 16.635516] pcd_pullup, is_on 1 [ 17.247626] **************soft reconnect************** [ 17.426869] Using Buffer DMA mode [ 17.426882] Periodic Transfer Interrupt Enhancement - disabled [ 17.426889] Multiprocessor Interrupt Enhancement - disabled [ 17.426896] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 17.426902] ^^^^^^^^^^^^^^^^^Device Mode [ 17.426942] *******************soft connect!!!******************* [ 17.532914] USB RESET [ 17.689058] android_work: sent uevent USB_STATE=CONNECTED [ 17.692636] USB RESET [ 17.917499] android_usb gadget: high-speed config #1: android [ 17.917572] android_work: sent uevent USB_STATE=CONFIGURED [ 60.150141] pcd_pullup, is_on 0 [ 60.150242] android_work: sent uevent USB_STATE=DISCONNECTED [ 60.607246] healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a 2011-01-04 09:44:30.842916112 UTC [ 70.191824] read descriptors [ 70.191839] read descriptors [ 70.191846] read strings [ 70.191870] pcd_pullup, is_on 1 [ 70.383623] **************soft reconnect************** [ 70.562865] Using Buffer DMA mode [ 70.562879] Periodic Transfer Interrupt Enhancement - disabled [ 70.562885] Multiprocessor Interrupt Enhancement - disabled [ 70.562892] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 70.562898] ^^^^^^^^^^^^^^^^^Device Mode [ 70.562936] *******************soft connect!!!******************* [ 70.669366] USB RESET [ 70.825622] android_work: sent uevent USB_STATE=CONNECTED [ 70.829205] USB RESET [ 71.038707] android_usb gadget: high-speed config #1: android [ 71.038739] WARN::do_gadget_setup:1320: do_gadget_setup warning: pcd->lock locked without unlock [ 71.038739] [ 71.038787] android_work: sent uevent USB_STATE=CONFIGURED [ 3630.493788] pcd_pullup, is_on 0 [ 3630.493853] android_work: sent uevent USB_STATE=DISCONNECTED [ 3640.535396] read descriptors [ 3640.535413] read descriptors [ 3640.535421] read strings [ 3640.535444] pcd_pullup, is_on 1 [ 3641.319618] **************soft reconnect************** [ 3641.498855] Using Buffer DMA mode [ 3641.498868] Periodic Transfer Interrupt Enhancement - disabled [ 3641.498874] Multiprocessor Interrupt Enhancement - disabled [ 3641.498881] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 3641.498887] ^^^^^^^^^^^^^^^^^Device Mode [ 3641.498926] *******************soft connect!!!******************* [ 3641.605673] USB RESET [ 3641.761891] android_work: sent uevent USB_STATE=CONNECTED [ 3641.765594] USB RESET [ 3641.974099] android_usb gadget: high-speed config #1: android [ 3641.974161] android_work: sent uevent USB_STATE=CONFIGURED
