firefly-reload3288 编译内核 烧录更新进不了系统?
目前使firefly-reload32888 ,烧录Firefly-rk3288_Ubuntu_1604_201705250940.img 后,可以正常启动,HDMI有输出。但是直接编译内核,更新出现如下启动进不了内核,是什么原因?该如何解决!
根据维基下载编译firefly-rk3288-kernel内核:
1、git fetch origin lollipop:lollipop
2、git checkout lollipop
3、make firefly-rk3288-reload-linux_defconfig
4、make -j8 firefly-rk3288-reload-linux.img
5、打包boot
./mkbootimg --kernel arch/arm/boot/zImage --ramdisk initrd.img --second resource.img -o boot.img
烧录:
!(file:///C:/Users/sunzh/AppData/Roaming/Foxmail7/Temp-7780-20170922155819/Attach/Catch(09-22-16-3(09-22-16-32-02).jpg)
启动,无法进入Ubuntu。
[ 4.180799] usb 3-1.2: Manufacturer: Logitech
[ 4.265484] input: Logitech USB Receiver as /devices/ff540000.usb/usb3/3-1/3-1.2/3-1.2:1.0/input/input2
[ 4.265683] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-ff540000.usb-1.2/input0
[ 4.314646] input: Logitech USB Receiver as /devices/ff540000.usb/usb3/3-1/3-1.2/3-1.2:1.1/input/input3
[ 4.315075] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-ff540000.usb-1.2/input1
e or directory
FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
done.
Begin: Running /scripts/init-premount … Waiting for eMMC storage…
Timeout!
done.
[ 8.959286] [otg id chg] last id -1 current id 1
[ 9.254534] es8323_create file error
Gave up waiting for root device. Common problems:
  • Boot args (cat /proc/cmdline)
    • Check rootdelay= (did the system wait long enough?)
    • Check root= (did the system wait for the right device?)
  • Missing modules (cat /proc/modules; ls /dev)
    ALERT! /dev/mmcblk0p3 does not exist. Dropping to a shell!
    /bin/sh: can’t access tty; job control turned off
出现一样的问题,你解决了么?
今夕何夕 发表于 2017-10-15 15:04
出现一样的问题,你解决了么?
这个你更新下parater…
出现一样的问题,你解决了么?
这个你更新下parater..
出现一样的问题,你解决了么?
parater 里面的参数root=/dev/mmcblk0pxx 这个
谢谢,这个我也解决了
谢谢这个我也解决了
今夕何夕 发表于 2017-10-17 10:37
谢谢这个我也解决了
哥们这个怎么解决的{:4_122:}
