双MIPI DSI屏两路都无时钟输出,有数据输出
RK3288 RELOAD板子 按照wiki说明配置CONFIG_LCD_MIPI=y,CONFIG_MIPI_DSI=y,CONFIG_RK32_MIPI_DSI=y,并把RGBHDMIdisable了,自己重写了lcd-xxx-mipi.dtsi文件,dsihost0和dsihost1都打开了status = “okay”,添加了电源与复位相关引脚,现在用示波器查看数据口都有方波输出1V左右,时钟0.2V没波形输出,正常的话接不接屏时钟应该都有输出吧下面是启动LOG
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (May 27 2017 - 16:08:14)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-05-27#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00697718)
ramdisk @ 0x05bf0000 (0x00146410)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c902 … OK
[ 0.000000] Linux version 3.10.0 (zq@zq-VirtualBox) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Sun Sep 24 21:37:16 CST 2017
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1efe000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00400000@0x0039C000(userdata),0x00020000@0x0079C000(radical_update),-@0x007BC000(user) storagemedia=emmc loader.timestamp=2017-05-27_16:08:14
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 2026552k/2026552k available, 70600k reserved, 1556480K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b9574c (11830 kB)
[ 0.000000] .init : 0xc0b96000 - 0xc0bef440 ( 358 kB)
[ 0.000000] .data : 0xc0bf0000 - 0xc0d813c0 (1605 kB)
[ 0.000000] .bss : 0xc0d813c0 - 0xc0ea277c (1157 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:12
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:10
[ 0.499993] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.500008] pid_max: default: 32768 minimum: 301
[ 0.500124] Security Framework initialized
[ 0.500141] SELinux: Initializing.
[ 0.500214] Mount-cache hash table entries: 512
[ 0.500859] Initializing cgroup subsys debug
[ 0.500873] Initializing cgroup subsys memory
[ 0.500899] Initializing cgroup subsys freezer
[ 0.500928] CPU: Testing write buffer coherency: ok
[ 0.501242] /cpus/cpu@0 missing clock-frequency property
[ 0.501255] /cpus/cpu@1 missing clock-frequency property
[ 0.501265] /cpus/cpu@2 missing clock-frequency property
[ 0.501274] /cpus/cpu@3 missing clock-frequency property
[ 0.501326] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.501378] Setting up static identity map for 0xc0854760 - 0xc08547b8
[ 0.504619] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x170a (version 3.1)
[ 0.578137] CPU1: Booted secondary processor
[ 0.578169] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.597806] CPU2: Booted secondary processor
[ 0.597830] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.617516] CPU3: Booted secondary processor
[ 0.617539] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.617639] Brought up 4 CPUs
[ 0.617667] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.617676] CPU: All CPU(s) started in SVC mode.
[ 0.618408] devtmpfs: initialized
[ 0.622567] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.623655] pinctrl core: initialized pinctrl subsystem
[ 0.623903] regulator-dummy: no parameters
[ 0.637880] NET: Registered protocol family 16
[ 0.639600] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.639922] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e7da4c (version 0.1)
[ 0.640141] Registered FIQ tty driver
[ 0.640524] fiq-debugger is disabled in device tree
[ 0.641119] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.641140] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.641157] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.641174] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.641265] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.641328] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.641391] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.641453] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.641514] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.641576] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.641637] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.641699] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.641765] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.641829] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.641843] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.641854] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.641866] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.642495] rockchip_interrupts_register:bank_num=7
[ 0.644432] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.644489] rockchip_pinctrl_probe:init ok
[ 0.651721] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.651808] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651821] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.651997] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.652064] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652077] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.652237] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.652310] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652322] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.652489] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.652559] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652571] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.652742] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.652815] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652828] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.653000] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.653071] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653083] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.653253] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.653328] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653341] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.655209] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.655222] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.655812] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.655834] DDR DEBUG: version 1.00 20150126
[ 0.655863] DDR DEBUG: Channel a:
[ 0.655872] DDR DEBUG: DDR3 Device
[ 0.655886] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.655894] DDR DEBUG: Channel b:
[ 0.655901] DDR DEBUG: DDR3 Device
[ 0.655914] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.655923] DDR DEBUG: addr=0xd8b000
[ 0.655932] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.655940] DDR DEBUG: socAddr[0]=0xd8b000, socAddr[1]=0xd8b10000
[ 0.655961] DDR DEBUG: dtar[0]=0x301b1000, dtar[1]=0x301b1000
[ 0.656014] DDR DEBUG: init success!!! freq=200MHz
[ 0.656022] DDR DEBUG: Channel a:
[ 0.656034] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656048] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656061] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656074] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656085] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.656094] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.656103] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.656111] DDR DEBUG: Channel b:
[ 0.656122] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656135] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656147] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656159] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656170] [ 0.656179] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.656188] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.679760] bio: create slab at 0
[ 0.680255] Rockchip hdmi driver version 2.0
[ 0.680255] .
[ 0.681442] SCSI subsystem initialized
[ 0.681595] usbcore: registered new interface driver usbfs
[ 0.681648] usbcore: registered new interface driver hub
[ 0.681731] usbcore: registered new device driver usb
[ 0.684401] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.685035] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.685476] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.685728] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.685979] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.686099] media: Linux media interface: v0.10
[ 0.686178] Linux video capture interface: v2.00
[ 0.686240] pps_core: LinuxPPS API ver. 1 registered
[ 0.686250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.686275] PTP clock support registered
[ 0.686332] i2c-core: driver [bq24296] using legacy suspend method
[ 0.686342] i2c-core: driver [bq24296] using legacy resume method
[ 0.687041] ion_drm_heap_create: 0@0
[ 0.687168] Rockchip ion module is successfully loaded (v1.1)
[ 0.687336] Advanced Linux Sound Architecture Driver Initialized.
[ 0.687742] Bluetooth: Core ver 2.16
[ 0.687795] NET: Registered protocol family 31
[ 0.687805] Bluetooth: HCI device and connection manager initialized
[ 0.687822] Bluetooth: HCI socket layer initialized
[ 0.687835] Bluetooth: L2CAP socket layer initialized
[ 0.687861] Bluetooth: SCO socket layer initialized
[ 0.688110] cfg80211: Calling CRDA to update world regulatory domain
[ 0.689030] rk_mipi_screen_init_dt: lcd->screen_init = 1.
[ 0.689043] rk_mipi_screen_init_dt: mipi_lcd->dsi_lane = 4.
[ 0.689054] rk_mipi_screen_init_dt: lcd->screen->hs_tx_clk = 940000000.
[ 0.689064] rk_mipi_screen_init_dt: lcd->screen.mipi_dsi_num = 2.
[ 0.689132] rk_mipi_screen_init_dt: lcd->screen->lcd_rst_delay = 10.
[ 0.689172] lcd->lcd_rst_gpio=113,dsi->lcd_rst_atv_val=1, lcd_rst_value = 0
[ 0.689185] rk_mipi_screen_init_dt: lcd->screen.lcd_en_delay = 10.
[ 0.689215] dsi->lcd_en_gpio=177, dsi->screen.lcd_en_atv_val=1, lcd_en_value = 0
[ 0.689227] rk_mipi_screen_init_dt: lcd->screen.lcd_vsp_delay = 10.
[ 0.689255] dsi->lcd_vsp_gpio=18, dsi->screen.lcd_vsp_atv_val=1, lcd_vsp_value = 0
[ 0.689267] rk_mipi_screen_init_dt: lcd->screen.lcd_vsn_delay = 20.
[ 0.689294] dsi->lcd_vsn_gpio=178, dsi->screen.lcd_vsn_atv_val=1, lcd_vsn_value = 0
[ 0.689362]
[ 0.689362] childnode->name =rockchip,on-cmds1:length=2
[ 0.689377] cmd[1]=05,
[ 0.689384] cmd[2]=11,[ 0.689391] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689404]
[ 0.689404] childnode->name =rockchip,on-cmds2:length=3
[ 0.689417] cmd[1]=15,
[ 0.689424] cmd[2]=51,cmd[3]=ff,
[ 0.689436] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689448]
[ 0.689448] childnode->name =rockchip,on-cmds3:length=3
[ 0.689461] cmd[1]=15,
[ 0.689468] cmd[2]=55,cmd[3]=02,
[ 0.689479] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689491]
[ 0.689491] childnode->name =rockchip,on-cmds4:length=3
[ 0.689504] cmd[1]=15,
[ 0.689510] cmd[2]=53,cmd[3]=2c,
[ 0.689521] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689532]
[ 0.689532] childnode->name =rockchip,on-cmds5:length=2
[ 0.689545] cmd[1]=05,
[ 0.689551] cmd[2]=11,[ 0.689557] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689573]
[ 0.689573] childnode->name =rockchip,on-cmds6:length=2
[ 0.689586] cmd[1]=05,
[ 0.689593] cmd[2]=29,[ 0.689598] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689609] —close cmd debug—
[ 0.689616] —rk_mipi_screen_probe–end
[ 0.689721] act8846_i2c_probe,line=898
[ 0.690698] act8846_parse_dt,line=746
[ 0.691164] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.691184] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.691199] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.691214] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.693269] act_dcdc1: 1200 mV
[ 0.696231] vccio: 3300 mV
[ 0.698080] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.701033] act_dcdc4: 2000 mV
[ 0.702248] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.704550] act_ldo2: 1050 mV
[ 0.706844] act_ldo3: 3300 mV
[ 0.709142] act_ldo4: 3300 mV
[ 0.711446] act_ldo5: 3300 mV
[ 0.713765] act_ldo6: 1100 mV
[ 0.716069] vcc_18: 1800 mV
[ 0.718363] act_ldo8: 1850 mV
[ 0.723101] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.727802] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.728571] rk808_i2c_probe,line=1355
[ 0.729904] The device is not rk808 -11
[ 0.729988] rk808: probe of 0-001b failed with error -11
[ 0.730060] i2c-core: driver [rk818] using legacy suspend method
[ 0.730069] i2c-core: driver [rk818] using legacy resume method
[ 0.731704] Switching to clocksource arch_sys_counter
[ 0.755381] rga: Module initialized.
[ 0.756091] rga2 ff920000.rga: rga ion client create success!
[ 0.756255] rga: Driver loaded succesfully
[ 0.756462] fb disp policy is box
[ 0.756506] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.756517] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.756815] rk-screen rk_screen.8: rockchip screen probe success
[ 0.756978] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.756998] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.757346] rk32-edp ff970000.edp: screen is not edp!
[ 0.757363] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.757532] rk32-dsi
[ 0.757668] dsi->host.irq =51
[ 0.757683] dsi->dsi_id = 0
[ 0.757697] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
[ 0.757705] mipi_dsi v1.3 2014-04-17
[ 0.757731] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 0.757743] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.757789] rk32-dsi
[ 0.757shell@firefly:/ $ 899] dsi->host.irq =52
[ 0.757910] dsi->dsi_id = 1
[ 0.757920] load mipi dsi chip:rk_mipi_dsi.1 id:3133302a
[ 0.757928] mipi_dsi v1.3 2014-04-17
[ 0.757948] rk32-mipi ff964000.mipi: rk mipi_dsi probe success!
[ 0.757959] rk32-mipi ff964000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.758499] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.758722] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.759025] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.759197] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.759366] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.760913] rk3288-lcdc lcdc0: lcdc0: dclk:200000000>>fps:55
[ 0.760926] rk32_dsi_enable-------
[ 0.760935] rk32_init_phy_mode----------lcdc_id=0
[ 0.760946] dsi->phy.sys_clk =24000000
[ 0.760958] prediv:1, fbdiv:39,dsi->phy.ddr_clk:936000000
[ 0.760967] dsi->phy.ddr_clk =936000000
[ 0.760976] UI:1068
[ 0.760983] ref_clk:24000000
[ 0.760991] pclk:200000000, Tpclk:5000
[ 0.760999] sys_clk:24000000, Tsys_clk:41666
[ 0.761008] ddr_clk:936000000, Tddr_clk:1068
[ 0.761016] txbyte_clk:117000000, Ttxbyte_clk:8547
[ 0.761025] txclkesc:19500000, Ttxclkesc:51282
[ 0.770970] test_code=0x10,test_data=0xab
[ 0.770984] rk32_dwc_phy_test_wr:0000abab
[ 0.770992] test_code=0x11,test_data=0x8
[ 0.771004] rk32_dwc_phy_test_wr:00000808
[ 0.771012] test_code=0x12,test_data=0xc0
[ 0.771023] rk32_dwc_phy_test_wr:0000c0c0
[ 0.771032] test_code=0x44,test_data=0x14
[ 0.771043] rk32_dwc_phy_test_wr:00001414
[ 0.771051] test_code=0x17,test_data=0x0
[ 0.771062] rk32_dwc_phy_test_wr:00000100
[ 0.773038] test_code=0x18,test_data=0x6
[ 0.773050] rk32_dwc_phy_test_wr:00000506
[ 0.775026] test_code=0x18,test_data=0x81
[ 0.775037] rk32_dwc_phy_test_wr:00000281
[ 0.777013] test_code=0x19,test_data=0x30
[ 0.777024] rk32_dwc_phy_test_wr:00003030
[ 0.779001] test_code=0x20,test_data=0x4d
[ 0.779013] rk32_dwc_phy_test_wr:0000cd4d
[ 0.779021] test_code=0x21,test_data=0x3d
[ 0.779033] rk32_dwc_phy_test_wr:0000313d
[ 0.779040] test_code=0x21,test_data=0xdf
[ 0.779052] rk32_dwc_phy_test_wr:00009fdf
[ 0.779059] test_code=0x22,test_data=0x7
[ 0.779071] rk32_dwc_phy_test_wr:00000707
[ 0.779079] test_code=0x22,test_data=0x87
[ 0.779090] rk32_dwc_phy_test_wr:00000787
[ 0.779097] test_code=0x70,test_data=0x8f
[ 0.779109] rk32_dwc_phy_test_wr:00008f8f
[ 0.779117] test_code=0x71,test_data=0xd5
[ 0.779128] rk32_dwc_phy_test_wr:0000d5d5
[ 0.779135] test_code=0x72,test_data=0x4a
[ 0.779147] rk32_dwc_phy_test_wr:00004a4a
[ 0.779161] dsi->phy.Tpclk = 5000
[ 0.779169] screen->left_margin = 90
[ 0.779177] dsi->phy.Ttxbyte_clk = 8547
[ 0.779184] screen->hsync_len = 24
[ 0.779208] dsi->phy.sys_clk =24000000
[ 0.779218] prediv:1, fbdiv:39,dsi->phy.ddr_clk:936000000
[ 0.779226] dsi->phy.ddr_clk =936000000
[ 0.779236] UI:1068
[ 0.779242] ref_clk:24000000
[ 0.779250] pclk:200000000, Tpclk:5000
[ 0.779258] sys_clk:24000000, Tsys_clk:41666
[ 0.779267] ddr_clk:936000000, Tddr_clk:1068
[ 0.779275] txbyte_clk:117000000, Ttxbyte_clk:8547
[ 0.779283] txclkesc:19500000, Ttxclkesc:51282
[ 0.783322] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.791300] test_code=0x10,test_data=0xab
[ 0.791313] rk32_dwc_phy_test_wr:0000abab
[ 0.791321] test_code=0x11,test_data=0x8
[ 0.791333] rk32_dwc_phy_test_wr:00000808
[ 0.791341] test_code=0x12,test_data=0xc0
[ 0.791352] rk32_dwc_phy_test_wr:0000c0c0
[ 0.791360] test_code=0x44,test_data=0x14
[ 0.791371] rk32_dwc_phy_test_wr:00001414
[ 0.791379] test_code=0x17,test_data=0x0
[ 0.791390] rk32_dwc_phy_test_wr:00000100
[ 0.793366] test_code=0x18,test_data=0x6
[ 0.793377] rk32_dwc_phy_test_wr:00000506
[ 0.795353] test_code=0x18,test_data=0x81
[ 0.795364] rk32_dwc_phy_test_wr:00000281
[ 0.797340] test_code=0x19,test_data=0x30
[ 0.797352] rk32_dwc_phy_test_wr:00003030
[ 0.799328] test_code=0x20,test_data=0x4d
[ 0.799340] rk32_dwc_phy_test_wr:0000cd4d
[ 0.799347] test_code=0x21,test_data=0x3d
[ 0.799359] rk32_dwc_phy_test_wr:0000313d
[ 0.799366] test_code=0x21,test_data=0xdf
[ 0.799377] rk32_dwc_phy_test_wr:00009fdf
[ 0.799385] test_code=0x22,test_data=0x7
[ 0.799396] rk32_dwc_phy_test_wr:00000707
[ 0.799404] test_code=0x22,test_data=0x87
[ 0.799416] rk32_dwc_phy_test_wr:00000787
[ 0.799423] test_code=0x70,test_data=0x8f
[ 0.799435] rk32_dwc_phy_test_wr:00008f8f
[ 0.799442] test_code=0x71,test_data=0xd5
[ 0.799454] rk32_dwc_phy_test_wr:0000d5d5
[ 0.799461] test_code=0x72,test_data=0x4a
[ 0.799472] rk32_dwc_phy_test_wr:00004a4a
[ 0.799486] dsi->phy.Tpclk = 5000
[ 0.799494] screen->left_margin = 90
[ 0.799501] dsi->phy.Ttxbyte_clk = 8547
[ 0.799508] screen->hsync_len = 24
[ 0.799531] rk_mipi_screen branch*********
[ 0.799540] pwr_enable****
[ 0.799563] dcs_cmd.name:rockchip,on-cmds1
[ 0.799572] dcs_cmd.dsi_id == 2 line=201
[ 0.799584] 1217 command sent in LP mode size:1
[ 0.799592] write GEN_HDR:00001105
[ 0.799612] 1217 command sent in LP mode size:1
[ 0.799619] write GEN_HDR:00001105
[ 0.918729] dcs_cmd.name:rockchip,on-cmds2
[ 0.918739] dcs_cmd.dsi_id == 2 line=201
[ 0.918750] 1217 command sent in LP mode size:2
[ 0.918759] write GEN_HDR:00ff5115
[ 0.918779] 1217 command sent in LP mode size:2
[ 0.918787] write GEN_HDR:00ff5115
[ 0.938403] dcs_cmd.name:rockchip,on-cmds3
[ 0.938413] dcs_cmd.dsi_id == 2 line=201
[ 0.938423] 1217 command sent in LP mode size:2
[ 0.938431] write GEN_HDR:00025515
[ 0.938451] 1217 command sent in LP mode size:2
[ 0.938459] write GEN_HDR:00025515
[ 0.958082] dcs_cmd.name:rockchip,on-cmds4
[ 0.958092] dcs_cmd.dsi_id == 2 line=201
[ 0.958102] 1217 command sent in LP mode size:2
[ 0.958110] write GEN_HDR:002c5315
[ 0.958131] 1217 command sent in LP mode size:2
[ 0.958139] write GEN_HDR:002c5315
[ 0.977763] dcs_cmd.name:rockchip,on-cmds5
[ 0.977773] dcs_cmd.dsi_id == 2 line=201
[ 0.977783] 1217 command sent in LP mode size:1
[ 0.977791] write GEN_HDR:00001105
[ 0.977812] 1217 command sent in LP mode size:1
[ 0.977820] write GEN_HDR:00001105
[ 1.184405] dcs_cmd.name:rockchip,on-cmds6
[ 1.184415] dcs_cmd.dsi_id == 2 line=201
[ 1.184426] 1217 command sent in LP mode size:1
[ 1.184434] write GEN_HDR:00002905
[ 1.184454] 1217 command sent in LP mode size:1
[ 1.184462] write GEN_HDR:00002905
[ 1.391046] ++++++++++++++++rk_mipi_screen:315
[ 1.391065] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.437733] alloc_buffer:ion_phy_addr=0x10000000
[ 1.457367] fb0:phy:10000000>>vir:e0991000>>len:0x2500000
[ 1.457397] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa7000
[ 1.457413] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.457629] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.457642] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.457918] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.458264] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.458433] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.458610] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.459418] unknow screen type: 0
[ 1.459491] rk3288-lcdc lcdc1: lcdc1: dclk:200000000>>fps:55
[ 1.459506] rk3288-lcdc lcdc1: wakeup from standby!
[ 1.465228] fb4:phy:10000000>>vir:e0991000>>len:0x2500000
[ 1.465243] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 1.466120] rockchip_set_mux:warning ignore bank num 15
[ 1.466256] rockchip_set_mux:warning ignore bank num 15
[ 1.466376] rockchip_set_mux:warning ignore bank num 15
[ 1.466495] rockchip_set_mux:warning ignore bank num 15
[ 1.466608] rockchip_set_mux:warning ignore bank num 15
[ 1.466726] rockchip_set_mux:warning ignore bank num 15
[ 1.467303] rockchip_set_mux:warning ignore bank num 15
[ 1.467465] rockchip_set_mux:warning ignore bank num 15
[ 1.468001] rockchip_set_mux:warning ignore bank num 15
[ 1.468157] rockchip_set_mux:warning ignore bank num 15
[ 1.468689] rockchip_set_mux:warning ignore bank num 15
[ 1.468835] rockchip_set_mux:warning ignore bank num 15
[ 1.469370] rockchip_set_mux:warning ignore bank num 15
[ 1.469516] rockchip_set_mux:warning ignore bank num 15
[ 1.470645] tc358749_hdmiin_probe!
[ 1.529924] tc358749_hdmiin_probe OK!
[ 1.530379] NET: Registered protocol family 2
[ 1.531050] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.531125] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.531198] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.531250] TCP: reno registered
[ 1.531266] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.531289] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.531475] NET: Registered protocol family 1
[ 1.532105] Unpacking initramfs…
[ 1.602012] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 1.602694] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.603270] vcodec_service: probe device ff9a0000.vpu_service
[ 1.603474] vcodec_service: No reset resource define
[ 1.603653] vcodec_service: ff9a0000.vpu_service: power on
[ 1.603739] vcodec_service: probe device ff9a0000.vpu_service
[ 1.603756] vcodec_service: checking hw id 4831
[ 1.604756] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.604800] vcodec_service: done
[ 1.604809] vcodec_service: init success
[ 1.604876] vcodec_service: probe device ff9c0000.hevc_service
[ 1.605213] vcodec_service: ff9c0000.hevc_service: power on
[ 1.605276] vcodec_service: probe device ff9c0000.hevc_service
[ 1.605290] vcodec_service: checking hw id 6867
[ 1.605827] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.605868] vcodec_service: done
[ 1.605877] vcodec_service: init success
[ 1.606015] rknandbase v1.0 2014-03-31
[ 1.606159] rknand: probe of ff400000.nandc failed with error -1
[ 1.606274] rknand_driver:ret = 0
[ 1.608258] audit: initializing netlink socket (disabled)
[ 1.608303] type=2000 audit(1.120:1): initialized
[ 1.609117] bounce pool size: 64 pages
[ 1.613731] fuse init (API version 7.22)
[ 1.614112] msgmni has been set to 952
[ 1.615939] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.615956] io scheduler noop registered
[ 1.615967] io scheduler deadline registered
[ 1.616056] io scheduler cfq registered (default)
[ 1.617680] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.618398] IEP Power ON
[ 1.618437] iep ion client create success!
[ 1.618873] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa2000
[ 1.618884] IEP Power OFF
[ 1.618903] IEP Driver loaded succesfully
[ 1.619000] Module initialized.
[ 1.619837] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.619855] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.621181] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.621199] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.621544] rk_serial.c v1.8 2014-03-04
[ 1.621786] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.621973] serial ff180000.serial: membase e2eb2000
[ 1.622134] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.622315] serial ff190000.serial: membase e2ec4000
[ 1.622452] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.624790] console [ttyS2] enabled
[ 1.625014] serial ff690000.serial: membase fed60000
[ 1.625208] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.625380] serial ff1b0000.serial: membase e2ec6000
[ 1.627246] --11
[ 1.628242] loop: module loaded
[ 1.628609] zram: Created 1 device(s) …
[ 1.628697] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.628709] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.628727] mpu_init: Probe name mpu6050B1
[ 1.628869] ak8963_mod_init: Probe name ak8963_mod
[ 1.629624] SCSI Media Changer driver v0.25
[ 1.629950] tun: Universal TUN/TAP device driver, 1.6
[ 1.629975] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.630116] vmac_init.
[ 1.630698] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.630714] stmmac_probe_config_dt: clock input/output? (input).
[ 1.630727] stmmac_probe_config_dt: TX delay(0x30).
[ 1.630739] stmmac_probe_config_dt: RX delay(0x20).
[ 1.630787] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.630798] stmmc_pltfr_init:
[ 1.630806] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.630829] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.630840] stmmc_pltfr_init: init for RGMII
[ 1.630851] tx delay=0x30
[ 1.630851] rx delay=0x20
[ 1.630868] tx delay=0x30
[ 1.630868] rx delay=0x20
[ 1.631336] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.631347] Normal descriptors
[ 1.631356] Ring mode enabled
[ 1.631366] DMA HW capability register supported
[ 1.631378] RX Checksum Offload Engine supported (type 2)
[ 1.631388] TX Checksum insertion supported
[ 1.631398] Wake-Up On Lan supported
[ 1.631433] Enable RX Mitigation via HW Watchdog Timer
[ 1.631866] PPP generic driver version 2.4.2
[ 1.632020] PPP BSD Compression module registered
[ 1.632035] PPP Deflate Compression module registered
[ 1.632059] PPP MPPE Compression module registered
[ 1.632073] NET: Registered protocol family 24
[ 1.632109] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.632123] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.632136] Rockchip WiFi SYS interface (V1.00) …
[ 1.632170] esp_mem_init enter date Sep 23 2017 09:52:56
[ 1.632181] esp_mem_init VERSION [V2.5]
[ 1.632222] esp_mem_init complete
[ 1.632308] usbcore: registered new interface driver catc
[ 1.632348] usbcore: registered new interface driver kaweth
[ 1.632362] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.632400] usbcore: registered new interface driver pegasus
[ 1.632445] usbcore: registered new interface driver rtl8150
[ 1.632485] usbcore: registered new interface driver r8152
[ 1.632497] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.632563] usbcore: registered new interface driver hso
[ 1.632607] usbcore: registered new interface driver asix
[ 1.632650] usbcore: registered new interface driver ax88179_178a
[ 1.632691] usbcore: registered new interface driver cdc_ether
[ 1.632735] usbcore: registered new interface driver cdc_eem
[ 1.632775] usbcore: registered new interface driver dm9601
[ 1.632813] usbcore: registered new interface driver dm9620
[ 1.632860] usbcore: registered new interface driver smsc75xx
[ 1.632906] usbcore: registered new interface driver smsc95xx
[ 1.632944] usbcore: registered new interface driver gl620a
[ 1.632987] usbcore: registered new interface driver net1080
[ 1.633028] usbcore: registered new interface driver plusb
[ 1.633069] usbcore: registered new interface driver rndis_host
[ 1.633108] usbcore: registered new interface driver cdc_subset
[ 1.633146] usbcore: registered new interface driver zaurus
[ 1.633187] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.633251] usbcore: registered new interface driver int51x1
[ 1.633290] usbcore: registered new interface driver kalmia
[ 1.633335] usbcore: registered new interface driver ipheth
[ 1.633377] usbcore: registered new interface driver sierra_net
[ 1.633420] usbcore: registered new interface driver cx82310_eth
[ 1.633468] usbcore: registered new interface driver cdc_ncm
[ 1.633508] usbcore: registered new interface driver qmi_wwan
[ 1.633547] usbcore: registered new interface driver cdc_mbim
[ 1.633560] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.636030] EHCI: ehci_rk_probe e2f40000 e2f40010
[ 1.636049] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.636081] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.636469] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.646891] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.646988] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.647007] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.647022] usb usb1: Product: EHCI Host Controller
[ 1.647035] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.647048] usb usb1: SerialNumber: ff500000.usb
[ 1.647490] hub 1-0:1.0: USB hub found
[ 1.647516] hub 1-0:1.0: 1 port detected
[ 1.647686] EHCI: ehci_rk_probe ok
[ 1.647809] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.648135] usbcore: registered new interface driver cdc_acm
[ 1.648149] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.648206] usbcore: registered new interface driver usblp
[ 1.648250] usbcore: registered new interface driver cdc_wdm
[ 1.648317] usbcore: registered new interface driver usb-storage
[ 1.648358] usbcore: registered new interface driver ums-alauda
[ 1.648396] usbcore: registered new interface driver ums-cypress
[ 1.648437] usbcore: registered new interface driver ums-datafab
[ 1.648482] usbcore: registered new interface driver ums_eneub6250
[ 1.648522] usbcore: registered new interface driver ums-freecom
[ 1.648563] usbcore: registered new interface driver ums-isd200
[ 1.648602] usbcore: registered new interface driver ums-jumpshot
[ 1.648641] usbcore: registered new interface driver ums-karma
[ 1.648679] usbcore: registered new interface driver ums-onetouch
[ 1.648719] usbcore: registered new interface driver ums-sddr09
[ 1.648760] usbcore: registered new interface driver ums-sddr55
[ 1.648800] usbcore: registered new interface driver ums-usbat
[ 1.648894] usbcore: registered new interface driver usbserial
[ 1.648943] usbcore: registered new interface driver usbserial_generic
[ 1.648977] usbserial: USB Serial support registered for generic
[ 1.649019] usbcore: registered new interface driver option
[ 1.649050] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.649126] usbcore: registered new interface driver trancevibrator
[ 1.649139] usb20_otg: version 3.10a 21-DEC-2012
[ 1.649570] e2f80040
[ 1.649584] Core Release: 3.10a
[ 1.649600] Setting default values for core params
[ 1.649744] Using Buffer DMA mode
[ 1.649756] Periodic Transfer Interrupt Enhancement - disabled
[ 1.649767] Multiprocessor Interrupt Enhancement - disabled
[ 1.649779] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.649790] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.649808] Dedicated Tx FIFOs mode
[ 1.649828] pcd_init otg_dev = ddeffd00
[ 1.649990] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.650024] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.650060] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.650120] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.650137] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.650152] usb usb2: Product: DWC OTG Controller
[ 1.650165] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.650178] usb usb2: SerialNumber: ff580000.usb
[ 1.650613] hub 2-0:1.0: USB hub found
[ 1.650638] hub 2-0:1.0: 1 port detected
[ 1.650955] usb20_host: version 3.10a 21-DEC-2012
[ 1.653486] e3000040
[ 1.653501] Core Release: 3.10a
[ 1.653517] Setting default values for core params
[ 1.653640] Using Buffer DMA mode
[ 1.653653] Periodic Transfer Interrupt Enhancement - disabled
[ 1.653663] Multiprocessor Interrupt Enhancement - disabled
[ 1.653675] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.653686] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.653713] usb20_host ff540000.usb: DWC OTG Controller
[ 1.653740] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.653774] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.653867] Init: Power Port (0)
[ 1.653926] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.653943] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.653957] usb usb3: Product: DWC OTG Controller
[ 1.653970] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.653983] usb usb3: SerialNumber: ff540000.usb
[ 1.654437] hub 3-0:1.0: USB hub found
[ 1.654461] hub 3-0:1.0: 1 port detected
[ 1.655229] usbcore: registered new interface driver xpad
[ 1.655288] usbcore: registered new interface driver usb_acecad
[ 1.655334] usbcore: registered new interface driver aiptek
[ 1.655397] usbcore: registered new interface driver gtco
[ 1.655446] usbcore: registered new interface driver hanwang
[ 1.655490] usbcore: registered new interface driver kbtab
[ 1.655547] usbcore: registered new interface driver wacom
[ 1.655812] sensor_register_slave:mma8452,id=17
[ 1.655827] sensor_register_slave:gs_mc3230,id=23
[ 1.655837] gsensor_init
[ 1.655847] sensor_register_slave:mpu6880_acc,id=24
[ 1.655859] sensor_register_slave:mpu6500_acc,id=25
[ 1.655870] sensor_register_slave:cm3217,id=48
[ 1.655880] sensor_register_slave:cm3218,id=49
[ 1.660679] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.660729] i2c /dev entries driver
[ 1.661413] IR NEC protocol handler initialized
[ 1.661427] IR RC5(x) protocol handler initialized
[ 1.661438] IR RC6 protocol handler initialized
[ 1.661447] IR JVC protocol handler initialized
[ 1.661457] IR Sony protocol handler initialized
[ 1.661468] IR RC5 (streamzap) protocol handler initialized
[ 1.661478] IR SANYO protocol handler initialized
[ 1.661488] IR MCE Keyboard/mouse protocol handler initialized
[ 1.661643] usbcore: registered new interface driver uvcvideo
[ 1.661654] USB Video Class driver (1.1.1)
[ 1.661667] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.663224] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.663249] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.663270] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.663291] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.663341] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.663341]
[ 1.663416] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.663564] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe2ed8000 size: 0x4000)
[ 1.664219] D1:camsys_platform_probe(1447): ff910000.isp memory:
[ 1.664238] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe2fe0000 size: 0x10000)
[ 1.664255] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1dfa5000 vir: 0xddfa5000 size: 0x1000)
[ 1.664269] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.664282] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
[ 1.664739] test power disabled
[ 1.664794] i2c-core: driver [bq27320] using legacy suspend method
[ 1.664806] i2c-core: driver [bq27320] using legacy resume method
[ 1.665150] rockchip_temp_probe,line=364
[ 1.675411] hdmi->edidread:1[ 1.715777] tsadc ff280000.tsadc: initialized
[ 1.716170] device-mapper: uevent: version 1.0.3
[ 1.716413] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.716721] Bluetooth: HCI UART driver ver 2.2
[ 1.716737] Bluetooth: HCI H4 protocol initialized
[ 1.716749] Bluetooth: HCILL protocol initialized
[ 1.716762] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.716774] rtk_btusb: Register usb char device interface for BT driver
[ 1.716956] usbcore: registered new interface driver rtk_btusb
[ 1.717588] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(600000), use default, just enable dvfs
[ 1.721700] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.721898] cpuidle: using governor ladder
[ 1.721913] cpuidle: using governor menu
[ 1.721951] Synopsys Designware Multimedia Card Interface Driver
[ 1.721964] MHSC version = Ver 2.00 2015-06-10
[ 1.722273] dw cru_regsbase addr 0x1d8.
[ 1.722286] dw cru_reset_offset val 3.
[ 1.722301] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.722346] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.722648] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.722830] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.722959] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.735477] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.755234] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.755254] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.755286] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.755576] dw cru_regsbase addr 0x1d8.
[ 1.755590] dw cru_reset_offset val 0.
[ 1.755605] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.755644] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.756436] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.756595] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.757077] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.757143] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.771454] hdmi output corlor mode is 3
[ 1.771467] hdmi connect to lcdc1
[ 1.771476] switch:en=1,lcdc_id=1,screen type=6,cur type=0
[ 1.774819] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.787273] mmc0: BKOPS_EN bit is not set
[ 1.789154] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.791443] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.791468] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.791489] [mmc0] tuning regsbase addr 0x218.
[ 1.792259] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.792269] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792300] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.792325] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 1.792335] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792365] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.792391] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.792400] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792430] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.792478] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-237 (22 len)
[ 1.792490] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
[ 1.792500] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-237 (22 len)
[ 1.792511] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
[ 1.792555] mmc0: new HS200 MMC card at address 0001
[ 1.792841] mmcblk0: mmc0:0001 AJNB4R 14.5 GiB
[ 1.792960] mmcblk0rpmb: mmc0:0001 AJNB4R partition 3 4.00 MiB
[ 1.793289] rkpart: partition size too small (0)
[ 1.793303] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.793313] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.793322] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.793331] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.793339] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.793347] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.793356] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.793365] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.793373] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.793381] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.793390] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.793399] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.793407] userdata: 0x073800000 – 0x0f3800000 (2048 MB)
[ 1.793415] radical_update: 0x0f3800000 – 0x0f7800000 (64 MB)
[ 1.793424] user: 0x0f7800000 – 0x3a3a00000 (10946 MB)
[ 1.793453] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15[ 1.794536] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.794550] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.794866] dw cru_regsbase addr 0x1d8.
[ 1.794875] dw cru_reset_offset val 1.
[ 1.794885] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.794925] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.795182] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.795300] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.795549] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.814182] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.833867] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.833915] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.833928] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.834224] leds-gpio leds.31: pins are not configured from the driver
[ 1.834495] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.835920] usbcore: registered new interface driver usbhid
[ 1.835932] usbhid: USB HID core driver
[ 1.836051] ashmem: initialized
[ 1.836176] logger: created 256K log ‘log_main’
[ 1.836267] logger: created 256K log ‘log_events’
[ 1.836362] logger: created 256K log ‘log_radio’
[ 1.836455] logger: created 256K log ‘log_system’
[ 1.837573] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input0
[ 1.838452] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.838468] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.838479] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.838490] ES8323 2-0010: Error applying setting, reverse things back
[ 1.838786] es8323 probe i2c recv ok
[ 1.839732] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.840304] es8323_probe
[ 2.020808] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.020864] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 2.020898] pixel clk is 74250000 tmds clk is 74250000
[ 2.020946] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 2.473812] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 2.473823] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 2.473834] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 2.473842] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 2.473851] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 2.473860] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 2.473869] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 2.473877] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 2.473886] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 2.473894] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 2.473903] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 2.473910] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 2.473919] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 2.473927] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 2.473936] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 2.473943] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 2.473951] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 2.473959] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 2.473968] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 2.473975] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 2.473984] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 2.473992] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 2.474001] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 2.474008] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 2.474018] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 2.474025] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 2.474034] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 2.474041] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 2.474050] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 2.474058] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 2.474066] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 2.474074] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 2.474094] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 2.474102] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 2.474110] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 2.474118] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 2.474128] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 2.474135] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 2.474145] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 2.474152] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 2.474161] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 2.474168] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 2.474177] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 2.474184] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 2.474330] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 2.474342] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 2.474352] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 2.474361] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 2.474381] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 2.480719] rockchip-es8323 rockchip-es8323.30: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 2.481130] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.30/sound/card0/input1
[ 2.481554] u32 classifier
[ 2.481561] Actions configured
[ 2.481572] Netfilter messages via NETLINK v0.30.
[ 2.481625] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.481900] ctnetlink v0.93: registering with nfnetlink.
[ 2.481963] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.481970] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.482205] xt_time: kernel timezone is -0000
[ 2.482378] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.482493] arp_tables: (C) 2002 David S. Miller
[ 2.482529] TCP: cubic registered
[ 2.482535] Initializing XFRM netlink socket
[ 2.482698] NET: Registered protocol family 10
[ 2.483143] mip6: Mobile IPv6
[ 2.483168] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.483330] sit: IPv6 over IPv4 tunneling driver
[ 2.483617] NET: Registered protocol family 17
[ 2.483640] NET: Registered protocol family 15
[ 2.483690] Bridge firewalling registered
[ 2.483701] Ebtables v2.0 registered
[ 2.483870] Bluetooth: RFCOMM TTY layer initialized
[ 2.483898] Bluetooth: RFCOMM socket layer initialized
[ 2.483905] Bluetooth: RFCOMM ver 1.11
[ 2.483912] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.483918] Bluetooth: BNEP filters: protocol multicast
[ 2.483927] Bluetooth: BNEP socket layer initialized
[ 2.483934] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.483943] Bluetooth: HIDP socket layer initialized
[ 2.483967] l2tp_core: L2TP core driver, V2.0
[ 2.483979] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.483986] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.484191] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.484201] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.484209] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 2.484216] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.484225] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 2.484233] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.484252] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 2.484270] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 2.484276] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.484303] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 2.484311] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.484344] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.484467] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 2.484483] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 263.
[ 2.484495] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 2.484507] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 2.484519] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 2.484560] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.484658] [BT_RFKILL]: ** disable irq
[ 2.484731] [BT_RFKILL]: ap6335 device registered.
[ 2.485319] rk3288_init_suspend
[ 2.485330] rk3288_suspend_init enter
[ 2.485529] rk3288_suspend_init: pm_ctrbits =200007
[ 2.485558] gpio_get_dts_info suspend:4
[ 2.485564] gpio_get_dts_info resume:4
[ 2.485569] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.485594] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.485717] clks_gating_suspend_init:clkgt info ok
[ 2.485801] Registering SWP/SWPB emulation handler
[ 2.486098] ddrfreq: verion 1.2 20140526
[ 2.486110] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 2.486117] ddrfreq: auto-freq=0
[ 2.486122] ddrfreq: auto-freq-table[0] 240MHz
[ 2.486127] ddrfreq: auto-freq-table[1] 324MHz
[ 2.486132] ddrfreq: auto-freq-table[2] 456MHz
[ 2.486138] ddrfreq: auto-freq-table[3] 528MHz
[ 2.500428] regulator-dummy: disabling
[ 2.500504] =======================================================
[ 2.500511] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.500516] =======================================================
[ 2.500522] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.500568] dhd_module_init: in
[ 2.500576] ======== bcm_wlan_set_plat_data ========
[ 2.500582] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.500600] host_oob_irq: 196
[ 2.500605] host_oob_irq_flags=4
[ 2.500610] dhd_wifi_platform_load: Enter
[ 2.500622] pcd_pullup, is_on 0
[ 2.500625] Power-up adapter ‘DHD generic adapter’
[ 2.500645] wifi_platform_set_power = 1
[ 2.500651] ======== PULL WL_REG_ON HIGH! ========
[ 2.500657] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.500661] file system registered
[ 2.500666] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.500672] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.501165] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.501173] android_usb gadget: Number of LUNs=2
[ 2.501180] lun0: LUN: removable file: (no medium)
[ 2.501186] lun1: LUN: removable file: (no medium)
[ 2.501322] android_usb gadget: android_usb ready
[ 2.501389] sensor_init: Probe name sensors
[ 2.501404] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.501934] rtc_hym8563 0-0051: setting system clock to 2011-01-01 13:42:21 UTC (1293889341)
[ 2.508042] rockchip-spdif-card rockchip-spdif-card.29: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 2.508997] ret 1024
[ 2.509381] usbcore: registered new interface driver snd-usb-audio
[ 2.509389] ALSA device list:
[ 2.509395] #0: RK_ES8323
[ 2.509399] #1: RK-SPDIF-CARD
[ 2.509730] Freeing unused kernel memory: 356K (c0b96000 - c0bef000)
[ 2.601372] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.732626] type=1403 audit(1293889341.730:2): policy loaded auid=4294967295 ses=4294967295
[ 2.759883] init: invalid gid ‘trace’
[ 2.808015] wifi_platform_bus_enumerate device present 1
[ 2.808034] ======== Card detection to detect SDIO card! ========
[ 2.808043] mmc2:mmc host rescan start!
[ 2.858486] init: /dev/hw_random not found
[ 2.858554] keychord: using input dev rk29-keypad for fevent
[ 2.863539] init: /dev/hw_random not found
[ 2.864495] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.865303] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.867767] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.871717] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.871813] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.872639] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.878019] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.878069] e2fsck: system: clean, 1913/94848 files, 129677/393216 blocks
[ 2.881782] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.881858] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.888877] EXT4-fs (mmcblk0p8): recovery complete
[ 2.889284] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.889350] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.889716] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.893213] EXT4-fs (mmcblk0p11): recovery complete
[ 2.893230] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.893282] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.894015] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.898314] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.898352] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.902241] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.902310] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.902353] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.903193] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.903232] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.903476] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.903765] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.969560] EXT4-fs (mmcblk0p13): recovery complete
[ 2.970003] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.970089] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.971737] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.976964] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.977002] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 523/131072 files, 39603/524288 blocks
[ 2.981030] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.981098] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.981120] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.995317] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 2.995404] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.995450] mali pd enabled
[ 2.995463] clk enabled
[ 2.995476] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.995486] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.995497] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.995507] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.995518] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.995605] turn on mali power
[ 2.995617] kbase_platform_rk_init,register_reboot_notifier
[ 2.995659] hrtimer: interrupt took 11666 ns
[ 2.995757] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.996569] mali ffa30000.gpu: Probed as mali0
[ 2.997601] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.998266] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.998855] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.999609] zram0: detected capacity change from 0 to 533413888
[ 3.024503] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 3.046725] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.059322] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.060862] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.062382] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.065119] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.080707] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 3.088047] drmboot: module license ‘unspecified’ taints kernel.
[ 3.088069] Disabling lock debugging due to kernel taint
[ 3.088305] drm init, 20140910
[ 3.088788] drm init ok
[ 3.090381] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 3.090432] bat_cap: oldcap_path no exist
[ 3.090587] binder: 148:148 transaction failed 29189, size 0-0
[ 3.091309] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 3.095666] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.095694] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 3.095932] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 3.096495] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096512] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096528] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096540] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096563] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096574] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096588] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096598] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.101728] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 3.103386] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 3.103840] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 3.104098] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 3.105679] init: Warning! Service daemonsu needs a SELinux domain defined; please fix!
[ 3.105949] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
[ 3.107452] android_usb: already disabled
[ 3.109598] read descriptors
[ 3.109612] read strings
[ 3.109629] mtp_bind_config
[ 3.109654] pcd_pullup, is_on 1
[ 3.124027] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.124054] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 3.124125] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 3.125915] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.125943] mmc2: new high speed SDIO card at address 0001
[ 3.142132] bcmsdh_register: register client driver
[ 3.142235] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.142300] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.142308] bus num (host idx)=2, slot num (rca)=1
[ 3.142315] found adapter info ‘DHD generic adapter’
[ 3.142559] F1 signature read @0x18000000=0x16224335
[ 3.144539] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 3.144826] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.144868] wifi_platform_get_mac_addr
[ 3.144875] ======== bcm_wlan_get_mac_address ========
[ 3.144882] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.144891] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.144898] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.144908] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 3.144949] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.145257] wl_create_event_handler(): thread:wl_event_handler:aa started
[ 3.145262] tsk Enter, tsk = 0xdd74149c
[ 3.145399] dhd_attach(): thread:dhd_watchdog_thread:ab started
[ 3.145452] dhd_attach(): thread:dhd_dpc:ac started
[ 3.145493] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 3.145523] dhd_attach(): thread:dhd_rxf:ad started
[ 3.145535] dhd_deferred_work_init: work queue initialized
[ 3.145680] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 3.151206] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 3.151206] Compiled in drivers/net/wireless/bcmdhd on Sep 23 2017 at 09:53:11
[ 3.151576] Register interface [wlan0] MAC: 94:a1:a2:f7:cc:97
[ 3.151576]
[ 3.151589] dhd_prot_ioctl : bus is down. we have nothing to do
[ 3.151629] bcmsdh_oob_intr_unregister: Enter
[ 3.151636] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.151646] dhd_txglom_enable: enable 0
[ 3.151652] dhd_bus_devreset: WLAN OFF DONE
[ 3.151684] wifi_platform_set_power = 0
[ 3.151690] ======== PULL WL_REG_ON LOW! ========
[ 3.151696] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.250816] [WLAN_RFKILL]: wifi shut off power.
[ 3.250829] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.250835] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.250890] dhd_module_init: Exit err=0
[ 3.344079] RKNAND_GET_SN_SECTOR
[ 3.344091] return ret = 0
[ 3.344807] RKNAND_GET_DRM_KEY
[ 3.344819] return ret = 0
[ 3.624733] dwc_otg_hcd_enable, enable host controller
[ 3.674081] logd.auditd: start
[ 3.787094] Using Buffer DMA mode
[ 3.787107] Periodic Transfer Interrupt Enhancement - disabled
[ 3.787113] Multiprocessor Interrupt Enhancement - disabled
[ 3.787120] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.787125] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.787139] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.831458] Init: Power Port (0)
[ 4.075222] healthd: No charger supplies found
[ 4.075237] healthd: No battery devices found
[ 4.146300] Indeed it is in host mode hprt0 = 00021501
[ 4.323397] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 4.323477] Indeed it is in host mode hprt0 = 00001101
[ 4.405149] rk3288-lcdc lcdc0: blank mode:0
[ 4.432416] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaaa000
[ 4.520436] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 4.520450] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.520457] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 4.521016] hub 3-1:1.0: USB hub found
[ 4.521080] hub 3-1:1.0: 4 ports detected
[ 4.795866] usb 3-1.4: new full-speed USB device number 3 using usb20_host
[ 4.896400] usb 3-1.4: New USB device found, idVendor=2149, idProduct=2122
[ 4.896413] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.896422] usb 3-1.4: Product: CoolTouch™ System
[ 4.896428] usb 3-1.4: Manufacturer: Advanced Silicon S.A.
[ 4.902172] input: Advanced Silicon S.A. CoolTouch™ System as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.0/input/input2
[ 4.902390] gpufreq_input_connect
[ 4.902571] hid-multitouch 0003:2149:2122.0001: input,hidraw0: USB HID v1.10 Device [Advanced Silicon S.A. CoolTouch™ System] on usb-ff540000.usb-1.4/input0
[ 4.983257] hid-generic 0003:2149:2122.0002: hiddev0,hidraw1: USB HID v1.10 Device [Advanced Silicon S.A. CoolTouch™ System] on usb-ff540000.usb-1.4/input1
[ 5.559417] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 5.563231] iep dpi mode inactivity
[ 7.036343] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.036355] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.036363] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.036451] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 7.036463] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 7.036474] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 7.036500] rockchip_gpio_request:GPIO7-13
[ 7.036510] rockchip_gpio_set:GPIO7-13 level = 1
[ 7.036516] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 7.036525] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
[ 7.036533] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207420,result=0x207420
[ 7.036541] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 7.036562] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 7.041608] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.041619] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.041726] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.041757] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 7.042821] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 7.043880] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 7.044935] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 7.048184] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 7.049375] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 7.049484] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 7.049497] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 7.049520] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 7.050600] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.050634] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.052697] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 7.052713] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.052723] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.052730] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.052737] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.061501] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.061513] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.061521] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.061621] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 7.061634] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 7.061644] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 7.061653] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 7.061746] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 7.066781] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.066790] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.066896] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.066922] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 7.067984] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 7.069046] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 7.070103] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 7.073323] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 7.073394] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 7.073406] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 7.073418] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 7.074511] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.074544] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.076609] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 7.076624] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.076635] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.076643] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.076650] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.080932] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.080943] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.080951] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.081033] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 7.081061] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 7.086100] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.086110] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.086215] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.086240] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 7.087299] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 7.088351] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 7.089410] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 7.092759] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 7.092770] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 7.092777] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 7.093861] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.093887] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.095939] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.095950] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.095956] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.095963] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.097943] type=1400 audit(1293889346.160:3): avc: denied { execute } for pid=492 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.098116] type=1400 audit(1293889346.160:4): avc: denied { read open } for pid=492 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.098212] type=1400 audit(1293889346.160:5): avc: denied { execute_no_trans } for pid=492 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.100227] type=1400 audit(1293889346.170:6): avc: denied { getattr } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100321] type=1400 audit(1293889346.170:7): avc: denied { execute } for pid=492 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100393] type=1400 audit(1293889346.170:8): avc: denied { read open } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100464] type=1400 audit(1293889346.170:9): avc: denied { execute_no_trans } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 8.331945] healthd: battery none chg=
[ 8.514394] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 8.514408] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 8.514414] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 8.514420] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 8.514425] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 8.514430] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 8.514436] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 8.875598] acc_open
[ 8.875617] acc_release
[ 9.031537] phy_power_on: enable = 1
[ 9.070933] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 9.070962] eth0: device MAC address 4a:09:e2:8b:32:4f
[ 9.074998] libphy: stmmac: probed
[ 9.075010] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 9.075017] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 9.538600] [otg id chg] last id -1 current id 1
[ 9.538627] PortPower off
[ 9.538637] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 9.664456] Using Buffer DMA mode
[ 9.664474] Periodic Transfer Interrupt Enhancement - disabled
[ 9.664480] Multiprocessor Interrupt Enhancement - disabled
[ 9.664487] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.664493] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.716265] es8323_mic_state_ctrl read: 0
[ 9.716287] mic_state_switch 0
[ 9.716294] hp_det = 0,insert hp
[ 9.716299] hp mic use intern
[ 10.072988] pm policy 0 → 1
[ 10.148682] vbus detect**
[ 10.150877] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 10.347518] Using Buffer DMA mode
[ 10.347544] Periodic Transfer Interrupt Enhancement - disabled
[ 10.347551] Multiprocessor Interrupt Enhancement - disabled
[ 10.347558] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 10.347564] ^^^^^^^^^^^^^^^^^Device Mode
[ 10.347604] soft connect!!!
[ 10.470312] USB RESET
[ 10.527379] android_work: sent uevent USB_STATE=CONNECTED
[ 10.532064] USB RESET
[ 10.620587] android_usb gadget: high-speed config #1: android
[ 10.620769] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.678527] type=1400 audit(1293889350.820:10): avc: denied { write } for pid=497 comm=“Binder_1” name=“rotation_flag” dev=“mmcblk0p13” ino=15 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[ 11.678791] type=1400 audit(1293889350.820:11): avc: denied { open } for pid=497 comm=“Binder_1” path=“/data/rotation_flag” dev=“mmcblk0p13” ino=15 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[ 11.684100] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.684117] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.684125] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 11.684495] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000 Hz) in turn on
[ 11.684508] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.684615] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.684625] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.685325] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.687384] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.688078] type=1400 audit(1293889350.830:12): avc: denied { write } for pid=1057 comm=“Binder_1” name=“/” dev=“mmcblk0p13” ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688450] type=1400 audit(1293889350.830:13): avc: denied { remove_name } for pid=1057 comm=“Binder_1” name=“vpumem_observer” dev=“mmcblk0p13” ino=16 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688543] type=1400 audit(1293889350.830:14): avc: denied { unlink } for pid=1057 comm=“Binder_1” name=“vpumem_observer” dev=“mmcblk0p13” ino=16 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
[ 11.688650] type=1400 audit(1293889350.830:15): avc: denied { add_name } for pid=1057 comm=“Binder_1” name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688920] type=1400 audit(1293889350.830:16): avc: denied { create } for pid=1057 comm=“Binder_1” name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
[ 11.972740] D1:camsys_mrv_iommu_cb(276): map fd 46 ,client fd 34
[ 11.972740]
[ 11.972780] rk_iommu ff914000.isp_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab1000
[ 11.974899] D1:camsys_mrv_iommu_cb(276): map fd 48 ,client fd 34
[ 11.974899]
[ 11.974919] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.977015] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 34
[ 11.977015]
[ 11.977034] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.979134] D1:camsys_mrv_iommu_cb(276): map fd 50 ,client fd 34
[ 11.979134]
[ 11.979151] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.979809] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
[ 11.979822] W:camsys_phy_ops(478): mipiphy->phy_index(-1191300724) != extdev->phy.info.mipi.phy_index(0)!
[ 11.980032] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(0) turn on(lane: 0xf bit_rate: 648Mbps)
[ 12.093366] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
[ 12.093894] D1:camsys_mrv_iommu_cb(276): map fd 50 ,client fd 34
[ 12.09DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (May 27 2017 - 16:08:14)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-05-27#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00697718)
ramdisk @ 0x05bf0000 (0x00146410)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c902 … OK
[ 0.000000] Linux version 3.10.0 (zq@zq-VirtualBox) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Sun Sep 24 21:37:16 CST 2017
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1efe000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00400000@0x0039C000(userdata),0x00020000@0x0079C000(radical_update),-@0x007BC000(user) storagemedia=emmc loader.timestamp=2017-05-27_16:08:14
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 2026552k/2026552k available, 70600k reserved, 1556480K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b9574c (11830 kB)
[ 0.000000] .init : 0xc0b96000 - 0xc0bef440 ( 358 kB)
[ 0.000000] .data : 0xc0bf0000 - 0xc0d813c0 (1605 kB)
[ 0.000000] .bss : 0xc0d813c0 - 0xc0ea277c (1157 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:12
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:10
[ 0.499993] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.500008] pid_max: default: 32768 minimum: 301
[ 0.500124] Security Framework initialized
[ 0.500141] SELinux: Initializing.
[ 0.500214] Mount-cache hash table entries: 512
[ 0.500859] Initializing cgroup subsys debug
[ 0.500873] Initializing cgroup subsys memory
[ 0.500899] Initializing cgroup subsys freezer
[ 0.500928] CPU: Testing write buffer coherency: ok
[ 0.501242] /cpus/cpu@0 missing clock-frequency property
[ 0.501255] /cpus/cpu@1 missing clock-frequency property
[ 0.501265] /cpus/cpu@2 missing clock-frequency property
[ 0.501274] /cpus/cpu@3 missing clock-frequency property
[ 0.501326] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.501378] Setting up static identity map for 0xc0854760 - 0xc08547b8
[ 0.504619] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x170a (version 3.1)
[ 0.578137] CPU1: Booted secondary processor
[ 0.578169] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.597806] CPU2: Booted secondary processor
[ 0.597830] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.617516] CPU3: Booted secondary processor
[ 0.617539] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.617639] Brought up 4 CPUs
[ 0.617667] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.617676] CPU: All CPU(s) started in SVC mode.
[ 0.618408] devtmpfs: initialized
[ 0.622567] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.623655] pinctrl core: initialized pinctrl subsystem
[ 0.623903] regulator-dummy: no parameters
[ 0.637880] NET: Registered protocol family 16
[ 0.639600] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.639922] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e7da4c (version 0.1)
[ 0.640141] Registered FIQ tty driver
[ 0.640524] fiq-debugger is disabled in device tree
[ 0.641119] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.641140] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.641157] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.641174] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.641265] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.641328] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.641391] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.641453] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.641514] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.641576] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.641637] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.641699] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.641765] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.641829] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.641843] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.641854] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.641866] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.642495] rockchip_interrupts_register:bank_num=7
[ 0.644432] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.644489] rockchip_pinctrl_probe:init ok
[ 0.651721] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.651808] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651821] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.651997] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.652064] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652077] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.652237] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.652310] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652322] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.652489] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.652559] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652571] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.652742] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.652815] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652828] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.653000] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.653071] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653083] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.653253] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.653328] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653341] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.655209] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.655222] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.655812] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.655834] DDR DEBUG: version 1.00 20150126
[ 0.655863] DDR DEBUG: Channel a:
[ 0.655872] DDR DEBUG: DDR3 Device
[ 0.655886] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.655894] DDR DEBUG: Channel b:
[ 0.655901] DDR DEBUG: DDR3 Device
[ 0.655914] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.655923] DDR DEBUG: addr=0xd8b000
[ 0.655932] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.655940] DDR DEBUG: socAddr[0]=0xd8b000, socAddr[1]=0xd8b10000
[ 0.655961] DDR DEBUG: dtar[0]=0x301b1000, dtar[1]=0x301b1000
[ 0.656014] DDR DEBUG: init success!!! freq=200MHz
[ 0.656022] DDR DEBUG: Channel a:
[ 0.656034] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656048] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656061] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656074] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656085] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.656094] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.656103] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.656111] DDR DEBUG: Channel b:
[ 0.656122] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656135] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656147] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656159] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656170] [ 0.656179] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.656188] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.679760] bio: create slab at 0
[ 0.680255] Rockchip hdmi driver version 2.0
[ 0.680255] .
[ 0.681442] SCSI subsystem initialized
[ 0.681595] usbcore: registered new interface driver usbfs
[ 0.681648] usbcore: registered new interface driver hub
[ 0.681731] usbcore: registered new device driver usb
[ 0.684401] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.685035] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.685476] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.685728] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.685979] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.686099] media: Linux media interface: v0.10
[ 0.686178] Linux video capture interface: v2.00
[ 0.686240] pps_core: LinuxPPS API ver. 1 registered
[ 0.686250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.686275] PTP clock support registered
[ 0.686332] i2c-core: driver [bq24296] using legacy suspend method
[ 0.686342] i2c-core: driver [bq24296] using legacy resume method
[ 0.687041] ion_drm_heap_create: 0@0
[ 0.687168] Rockchip ion module is successfully loaded (v1.1)
[ 0.687336] Advanced Linux Sound Architecture Driver Initialized.
[ 0.687742] Bluetooth: Core ver 2.16
[ 0.687795] NET: Registered protocol family 31
[ 0.687805] Bluetooth: HCI device and connection manager initialized
[ 0.687822] Bluetooth: HCI socket layer initialized
[ 0.687835] Bluetooth: L2CAP socket layer initialized
[ 0.687861] Bluetooth: SCO socket layer initialized
[ 0.688110] cfg80211: Calling CRDA to update world regulatory domain
[ 0.689030] rk_mipi_screen_init_dt: lcd->screen_init = 1.
[ 0.689043] rk_mipi_screen_init_dt: mipi_lcd->dsi_lane = 4.
[ 0.689054] rk_mipi_screen_init_dt: lcd->screen->hs_tx_clk = 940000000.
[ 0.689064] rk_mipi_screen_init_dt: lcd->screen.mipi_dsi_num = 2.
[ 0.689132] rk_mipi_screen_init_dt: lcd->screen->lcd_rst_delay = 10.
[ 0.689172] lcd->lcd_rst_gpio=113,dsi->lcd_rst_atv_val=1, lcd_rst_value = 0
[ 0.689185] rk_mipi_screen_init_dt: lcd->screen.lcd_en_delay = 10.
[ 0.689215] dsi->lcd_en_gpio=177, dsi->screen.lcd_en_atv_val=1, lcd_en_value = 0
[ 0.689227] rk_mipi_screen_init_dt: lcd->screen.lcd_vsp_delay = 10.
[ 0.689255] dsi->lcd_vsp_gpio=18, dsi->screen.lcd_vsp_atv_val=1, lcd_vsp_value = 0
[ 0.689267] rk_mipi_screen_init_dt: lcd->screen.lcd_vsn_delay = 20.
[ 0.689294] dsi->lcd_vsn_gpio=178, dsi->screen.lcd_vsn_atv_val=1, lcd_vsn_value = 0
[ 0.689362]
[ 0.689362] childnode->name =rockchip,on-cmds1:length=2
[ 0.689377] cmd[1]=05,
[ 0.689384] cmd[2]=11,[ 0.689391] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689404]
[ 0.689404] childnode->name =rockchip,on-cmds2:length=3
[ 0.689417] cmd[1]=15,
[ 0.689424] cmd[2]=51,cmd[3]=ff,
[ 0.689436] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689448]
[ 0.689448] childnode->name =rockchip,on-cmds3:length=3
[ 0.689461] cmd[1]=15,
[ 0.689468] cmd[2]=55,cmd[3]=02,
[ 0.689479] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689491]
[ 0.689491] childnode->name =rockchip,on-cmds4:length=3
[ 0.689504] cmd[1]=15,
[ 0.689510] cmd[2]=53,cmd[3]=2c,
[ 0.689521] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689532]
[ 0.689532] childnode->name =rockchip,on-cmds5:length=2
[ 0.689545] cmd[1]=05,
[ 0.689551] cmd[2]=11,[ 0.689557] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689573]
[ 0.689573] childnode->name =rockchip,on-cmds6:length=2
[ 0.689586] cmd[1]=05,
[ 0.689593] cmd[2]=29,[ 0.689598] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689609] —close cmd debug—
[ 0.689616] —rk_mipi_screen_probe–end
[ 0.689721] act8846_i2c_probe,line=898
[ 0.690698] act8846_parse_dt,line=746
[ 0.691164] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.691184] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.691199] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.691214] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.693269] act_dcdc1: 1200 mV
[ 0.696231] vccio: 3300 mV
[ 0.698080] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.701033] act_dcdc4: 2000 mV
[ 0.702248] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.704550] act_ldo2: 1050 mV
[ 0.706844] act_ldo3: 3300 mV
[ 0.709142] act_ldo4: 3300 mV
[ 0.711446] act_ldo5: 3300 mV
[ 0.713765] act_ldo6: 1100 mV
[ 0.716069] vcc_18: 1800 mV
[ 0.718363] act_ldo8: 1850 mV
[ 0.723101] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.727802] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.728571] rk808_i2c_probe,line=1355
[ 0.729904] The device is not rk808 -11
[ 0.729988] rk808: probe of 0-001b failed with error -11
[ 0.730060] i2c-core: driver [rk818] using legacy suspend method
[ 0.730069] i2c-core: driver [rk818] using legacy resume method
[ 0.731704] Switching to clocksource arch_sys_counter
[ 0.755381] rga: Module initialized.
[ 0.756091] rga2 ff920000.rga: rga ion client create success!
[ 0.756255] rga: Driver loaded succesfully
[ 0.756462] fb disp policy is box
[ 0.756506] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.756517] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.756815] rk-screen rk_screen.8: rockchip screen probe success
[ 0.756978] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.756998] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.757346] rk32-edp ff970000.edp: screen is not edp!
[ 0.757363] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.757532] rk32-dsi
[ 0.757668] dsi->host.irq =51
[ 0.757683] dsi->dsi_id = 0
[ 0.757697] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
[ 0.757705] mipi_dsi v1.3 2014-04-17
[ 0.757731] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 0.757743] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.757789] rk32-dsi
[ 0.757shell@firefly:/ $ 899] dsi->host.irq =52
[ 0.757910] dsi->dsi_id = 1
[ 0.757920] load mipi dsi chip:rk_mipi_dsi.1 id:3133302a
[ 0.757928] mipi_dsi v1.3 2014-04-17
[ 0.757948] rk32-mipi ff964000.mipi: rk mipi_dsi probe success!
[ 0.757959] rk32-mipi ff964000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.758499] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.758722] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.759025] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.759197] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.759366] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.760913] rk3288-lcdc lcdc0: lcdc0: dclk:200000000>>fps:55
[ 0.760926] rk32_dsi_enable-------
[ 0.760935] rk32_init_phy_mode----------lcdc_id=0
[ 0.760946] dsi->phy.sys_clk =24000000
[ 0.760958] prediv:1, fbdiv:39,dsi->phy.ddr_clk:936000000
[ 0.760967] dsi->phy.ddr_clk =936000000
[ 0.760976] UI:1068
[ 0.760983] ref_clk:24000000
[ 0.760991] pclk:200000000, Tpclk:5000
[ 0.760999] sys_clk:24000000, Tsys_clk:41666
[ 0.761008] ddr_clk:936000000, Tddr_clk:1068
[ 0.761016] txbyte_clk:117000000, Ttxbyte_clk:8547
[ 0.761025] txclkesc:19500000, Ttxclkesc:51282
[ 0.770970] test_code=0x10,test_data=0xab
[ 0.770984] rk32_dwc_phy_test_wr:0000abab
[ 0.770992] test_code=0x11,test_data=0x8
[ 0.771004] rk32_dwc_phy_test_wr:00000808
[ 0.771012] test_code=0x12,test_data=0xc0
[ 0.771023] rk32_dwc_phy_test_wr:0000c0c0
[ 0.771032] test_code=0x44,test_data=0x14
[ 0.771043] rk32_dwc_phy_test_wr:00001414
[ 0.771051] test_code=0x17,test_data=0x0
[ 0.771062] rk32_dwc_phy_test_wr:00000100
[ 0.773038] test_code=0x18,test_data=0x6
[ 0.773050] rk32_dwc_phy_test_wr:00000506
[ 0.775026] test_code=0x18,test_data=0x81
[ 0.775037] rk32_dwc_phy_test_wr:00000281
[ 0.777013] test_code=0x19,test_data=0x30
[ 0.777024] rk32_dwc_phy_test_wr:00003030
[ 0.779001] test_code=0x20,test_data=0x4d
[ 0.779013] rk32_dwc_phy_test_wr:0000cd4d
[ 0.779021] test_code=0x21,test_data=0x3d
[ 0.779033] rk32_dwc_phy_test_wr:0000313d
[ 0.779040] test_code=0x21,test_data=0xdf
[ 0.779052] rk32_dwc_phy_test_wr:00009fdf
[ 0.779059] test_code=0x22,test_data=0x7
[ 0.779071] rk32_dwc_phy_test_wr:00000707
[ 0.779079] test_code=0x22,test_data=0x87
[ 0.779090] rk32_dwc_phy_test_wr:00000787
[ 0.779097] test_code=0x70,test_data=0x8f
[ 0.779109] rk32_dwc_phy_test_wr:00008f8f
[ 0.779117] test_code=0x71,test_data=0xd5
[ 0.779128] rk32_dwc_phy_test_wr:0000d5d5
[ 0.779135] test_code=0x72,test_data=0x4a
[ 0.779147] rk32_dwc_phy_test_wr:00004a4a
[ 0.779161] dsi->phy.Tpclk = 5000
[ 0.779169] screen->left_margin = 90
[ 0.779177] dsi->phy.Ttxbyte_clk = 8547
[ 0.779184] screen->hsync_len = 24
[ 0.779208] dsi->phy.sys_clk =24000000
[ 0.779218] prediv:1, fbdiv:39,dsi->phy.ddr_clk:936000000
[ 0.779226] dsi->phy.ddr_clk =936000000
[ 0.779236] UI:1068
[ 0.779242] ref_clk:24000000
[ 0.779250] pclk:200000000, Tpclk:5000
[ 0.779258] sys_clk:24000000, Tsys_clk:41666
[ 0.779267] ddr_clk:936000000, Tddr_clk:1068
[ 0.779275] txbyte_clk:117000000, Ttxbyte_clk:8547
[ 0.779283] txclkesc:19500000, Ttxclkesc:51282
[ 0.783322] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.791300] test_code=0x10,test_data=0xab
[ 0.791313] rk32_dwc_phy_test_wr:0000abab
[ 0.791321] test_code=0x11,test_data=0x8
[ 0.791333] rk32_dwc_phy_test_wr:00000808
[ 0.791341] test_code=0x12,test_data=0xc0
[ 0.791352] rk32_dwc_phy_test_wr:0000c0c0
[ 0.791360] test_code=0x44,test_data=0x14
[ 0.791371] rk32_dwc_phy_test_wr:00001414
[ 0.791379] test_code=0x17,test_data=0x0
[ 0.791390] rk32_dwc_phy_test_wr:00000100
[ 0.793366] test_code=0x18,test_data=0x6
[ 0.793377] rk32_dwc_phy_test_wr:00000506
[ 0.795353] test_code=0x18,test_data=0x81
[ 0.795364] rk32_dwc_phy_test_wr:00000281
[ 0.797340] test_code=0x19,test_data=0x30
[ 0.797352] rk32_dwc_phy_test_wr:00003030
[ 0.799328] test_code=0x20,test_data=0x4d
[ 0.799340] rk32_dwc_phy_test_wr:0000cd4d
[ 0.799347] test_code=0x21,test_data=0x3d
[ 0.799359] rk32_dwc_phy_test_wr:0000313d
[ 0.799366] test_code=0x21,test_data=0xdf
[ 0.799377] rk32_dwc_phy_test_wr:00009fdf
[ 0.799385] test_code=0x22,test_data=0x7
[ 0.799396] rk32_dwc_phy_test_wr:00000707
[ 0.799404] test_code=0x22,test_data=0x87
[ 0.799416] rk32_dwc_phy_test_wr:00000787
[ 0.799423] test_code=0x70,test_data=0x8f
[ 0.799435] rk32_dwc_phy_test_wr:00008f8f
[ 0.799442] test_code=0x71,test_data=0xd5
[ 0.799454] rk32_dwc_phy_test_wr:0000d5d5
[ 0.799461] test_code=0x72,test_data=0x4a
[ 0.799472] rk32_dwc_phy_test_wr:00004a4a
[ 0.799486] dsi->phy.Tpclk = 5000
[ 0.799494] screen->left_margin = 90
[ 0.799501] dsi->phy.Ttxbyte_clk = 8547
[ 0.799508] screen->hsync_len = 24
[ 0.799531] rk_mipi_screen branch*********
[ 0.799540] pwr_enable****
[ 0.799563] dcs_cmd.name:rockchip,on-cmds1
[ 0.799572] dcs_cmd.dsi_id == 2 line=201
[ 0.799584] 1217 command sent in LP mode size:1
[ 0.799592] write GEN_HDR:00001105
[ 0.799612] 1217 command sent in LP mode size:1
[ 0.799619] write GEN_HDR:00001105
[ 0.918729] dcs_cmd.name:rockchip,on-cmds2
[ 0.918739] dcs_cmd.dsi_id == 2 line=201
[ 0.918750] 1217 command sent in LP mode size:2
[ 0.918759] write GEN_HDR:00ff5115
[ 0.918779] 1217 command sent in LP mode size:2
[ 0.918787] write GEN_HDR:00ff5115
[ 0.938403] dcs_cmd.name:rockchip,on-cmds3
[ 0.938413] dcs_cmd.dsi_id == 2 line=201
[ 0.938423] 1217 command sent in LP mode size:2
[ 0.938431] write GEN_HDR:00025515
[ 0.938451] 1217 command sent in LP mode size:2
[ 0.938459] write GEN_HDR:00025515
[ 0.958082] dcs_cmd.name:rockchip,on-cmds4
[ 0.958092] dcs_cmd.dsi_id == 2 line=201
[ 0.958102] 1217 command sent in LP mode size:2
[ 0.958110] write GEN_HDR:002c5315
[ 0.958131] 1217 command sent in LP mode size:2
[ 0.958139] write GEN_HDR:002c5315
[ 0.977763] dcs_cmd.name:rockchip,on-cmds5
[ 0.977773] dcs_cmd.dsi_id == 2 line=201
[ 0.977783] 1217 command sent in LP mode size:1
[ 0.977791] write GEN_HDR:00001105
[ 0.977812] 1217 command sent in LP mode size:1
[ 0.977820] write GEN_HDR:00001105
[ 1.184405] dcs_cmd.name:rockchip,on-cmds6
[ 1.184415] dcs_cmd.dsi_id == 2 line=201
[ 1.184426] 1217 command sent in LP mode size:1
[ 1.184434] write GEN_HDR:00002905
[ 1.184454] 1217 command sent in LP mode size:1
[ 1.184462] write GEN_HDR:00002905
[ 1.391046] ++++++++++++++++rk_mipi_screen:315
[ 1.391065] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.437733] alloc_buffer:ion_phy_addr=0x10000000
[ 1.457367] fb0:phy:10000000>>vir:e0991000>>len:0x2500000
[ 1.457397] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa7000
[ 1.457413] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.457629] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.457642] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.457918] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.458264] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.458433] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.458610] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.459418] unknow screen type: 0
[ 1.459491] rk3288-lcdc lcdc1: lcdc1: dclk:200000000>>fps:55
[ 1.459506] rk3288-lcdc lcdc1: wakeup from standby!
[ 1.465228] fb4:phy:10000000>>vir:e0991000>>len:0x2500000
[ 1.465243] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 1.466120] rockchip_set_mux:warning ignore bank num 15
[ 1.466256] rockchip_set_mux:warning ignore bank num 15
[ 1.466376] rockchip_set_mux:warning ignore bank num 15
[ 1.466495] rockchip_set_mux:warning ignore bank num 15
[ 1.466608] rockchip_set_mux:warning ignore bank num 15
[ 1.466726] rockchip_set_mux:warning ignore bank num 15
[ 1.467303] rockchip_set_mux:warning ignore bank num 15
[ 1.467465] rockchip_set_mux:warning ignore bank num 15
[ 1.468001] rockchip_set_mux:warning ignore bank num 15
[ 1.468157] rockchip_set_mux:warning ignore bank num 15
[ 1.468689] rockchip_set_mux:warning ignore bank num 15
[ 1.468835] rockchip_set_mux:warning ignore bank num 15
[ 1.469370] rockchip_set_mux:warning ignore bank num 15
[ 1.469516] rockchip_set_mux:warning ignore bank num 15
[ 1.470645] tc358749_hdmiin_probe!
[ 1.529924] tc358749_hdmiin_probe OK!
[ 1.530379] NET: Registered protocol family 2
[ 1.531050] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.531125] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.531198] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.531250] TCP: reno registered
[ 1.531266] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.531289] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.531475] NET: Registered protocol family 1
[ 1.532105] Unpacking initramfs…
[ 1.602012] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 1.602694] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.603270] vcodec_service: probe device ff9a0000.vpu_service
[ 1.603474] vcodec_service: No reset resource define
[ 1.603653] vcodec_service: ff9a0000.vpu_service: power on
[ 1.603739] vcodec_service: probe device ff9a0000.vpu_service
[ 1.603756] vcodec_service: checking hw id 4831
[ 1.604756] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.604800] vcodec_service: done
[ 1.604809] vcodec_service: init success
[ 1.604876] vcodec_service: probe device ff9c0000.hevc_service
[ 1.605213] vcodec_service: ff9c0000.hevc_service: power on
[ 1.605276] vcodec_service: probe device ff9c0000.hevc_service
[ 1.605290] vcodec_service: checking hw id 6867
[ 1.605827] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.605868] vcodec_service: done
[ 1.605877] vcodec_service: init success
[ 1.606015] rknandbase v1.0 2014-03-31
[ 1.606159] rknand: probe of ff400000.nandc failed with error -1
[ 1.606274] rknand_driver:ret = 0
[ 1.608258] audit: initializing netlink socket (disabled)
[ 1.608303] type=2000 audit(1.120:1): initialized
[ 1.609117] bounce pool size: 64 pages
[ 1.613731] fuse init (API version 7.22)
[ 1.614112] msgmni has been set to 952
[ 1.615939] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.615956] io scheduler noop registered
[ 1.615967] io scheduler deadline registered
[ 1.616056] io scheduler cfq registered (default)
[ 1.617680] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.618398] IEP Power ON
[ 1.618437] iep ion client create success!
[ 1.618873] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa2000
[ 1.618884] IEP Power OFF
[ 1.618903] IEP Driver loaded succesfully
[ 1.619000] Module initialized.
[ 1.619837] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.619855] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.621181] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.621199] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.621544] rk_serial.c v1.8 2014-03-04
[ 1.621786] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.621973] serial ff180000.serial: membase e2eb2000
[ 1.622134] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.622315] serial ff190000.serial: membase e2ec4000
[ 1.622452] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.624790] console [ttyS2] enabled
[ 1.625014] serial ff690000.serial: membase fed60000
[ 1.625208] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.625380] serial ff1b0000.serial: membase e2ec6000
[ 1.627246] --11
[ 1.628242] loop: module loaded
[ 1.628609] zram: Created 1 device(s) …
[ 1.628697] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.628709] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.628727] mpu_init: Probe name mpu6050B1
[ 1.628869] ak8963_mod_init: Probe name ak8963_mod
[ 1.629624] SCSI Media Changer driver v0.25
[ 1.629950] tun: Universal TUN/TAP device driver, 1.6
[ 1.629975] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.630116] vmac_init.
[ 1.630698] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.630714] stmmac_probe_config_dt: clock input/output? (input).
[ 1.630727] stmmac_probe_config_dt: TX delay(0x30).
[ 1.630739] stmmac_probe_config_dt: RX delay(0x20).
[ 1.630787] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.630798] stmmc_pltfr_init:
[ 1.630806] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.630829] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.630840] stmmc_pltfr_init: init for RGMII
[ 1.630851] tx delay=0x30
[ 1.630851] rx delay=0x20
[ 1.630868] tx delay=0x30
[ 1.630868] rx delay=0x20
[ 1.631336] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.631347] Normal descriptors
[ 1.631356] Ring mode enabled
[ 1.631366] DMA HW capability register supported
[ 1.631378] RX Checksum Offload Engine supported (type 2)
[ 1.631388] TX Checksum insertion supported
[ 1.631398] Wake-Up On Lan supported
[ 1.631433] Enable RX Mitigation via HW Watchdog Timer
[ 1.631866] PPP generic driver version 2.4.2
[ 1.632020] PPP BSD Compression module registered
[ 1.632035] PPP Deflate Compression module registered
[ 1.632059] PPP MPPE Compression module registered
[ 1.632073] NET: Registered protocol family 24
[ 1.632109] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.632123] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.632136] Rockchip WiFi SYS interface (V1.00) …
[ 1.632170] esp_mem_init enter date Sep 23 2017 09:52:56
[ 1.632181] esp_mem_init VERSION [V2.5]
[ 1.632222] esp_mem_init complete
[ 1.632308] usbcore: registered new interface driver catc
[ 1.632348] usbcore: registered new interface driver kaweth
[ 1.632362] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.632400] usbcore: registered new interface driver pegasus
[ 1.632445] usbcore: registered new interface driver rtl8150
[ 1.632485] usbcore: registered new interface driver r8152
[ 1.632497] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.632563] usbcore: registered new interface driver hso
[ 1.632607] usbcore: registered new interface driver asix
[ 1.632650] usbcore: registered new interface driver ax88179_178a
[ 1.632691] usbcore: registered new interface driver cdc_ether
[ 1.632735] usbcore: registered new interface driver cdc_eem
[ 1.632775] usbcore: registered new interface driver dm9601
[ 1.632813] usbcore: registered new interface driver dm9620
[ 1.632860] usbcore: registered new interface driver smsc75xx
[ 1.632906] usbcore: registered new interface driver smsc95xx
[ 1.632944] usbcore: registered new interface driver gl620a
[ 1.632987] usbcore: registered new interface driver net1080
[ 1.633028] usbcore: registered new interface driver plusb
[ 1.633069] usbcore: registered new interface driver rndis_host
[ 1.633108] usbcore: registered new interface driver cdc_subset
[ 1.633146] usbcore: registered new interface driver zaurus
[ 1.633187] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.633251] usbcore: registered new interface driver int51x1
[ 1.633290] usbcore: registered new interface driver kalmia
[ 1.633335] usbcore: registered new interface driver ipheth
[ 1.633377] usbcore: registered new interface driver sierra_net
[ 1.633420] usbcore: registered new interface driver cx82310_eth
[ 1.633468] usbcore: registered new interface driver cdc_ncm
[ 1.633508] usbcore: registered new interface driver qmi_wwan
[ 1.633547] usbcore: registered new interface driver cdc_mbim
[ 1.633560] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.636030] EHCI: ehci_rk_probe e2f40000 e2f40010
[ 1.636049] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.636081] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.636469] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.646891] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.646988] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.647007] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.647022] usb usb1: Product: EHCI Host Controller
[ 1.647035] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.647048] usb usb1: SerialNumber: ff500000.usb
[ 1.647490] hub 1-0:1.0: USB hub found
[ 1.647516] hub 1-0:1.0: 1 port detected
[ 1.647686] EHCI: ehci_rk_probe ok
[ 1.647809] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.648135] usbcore: registered new interface driver cdc_acm
[ 1.648149] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.648206] usbcore: registered new interface driver usblp
[ 1.648250] usbcore: registered new interface driver cdc_wdm
[ 1.648317] usbcore: registered new interface driver usb-storage
[ 1.648358] usbcore: registered new interface driver ums-alauda
[ 1.648396] usbcore: registered new interface driver ums-cypress
[ 1.648437] usbcore: registered new interface driver ums-datafab
[ 1.648482] usbcore: registered new interface driver ums_eneub6250
[ 1.648522] usbcore: registered new interface driver ums-freecom
[ 1.648563] usbcore: registered new interface driver ums-isd200
[ 1.648602] usbcore: registered new interface driver ums-jumpshot
[ 1.648641] usbcore: registered new interface driver ums-karma
[ 1.648679] usbcore: registered new interface driver ums-onetouch
[ 1.648719] usbcore: registered new interface driver ums-sddr09
[ 1.648760] usbcore: registered new interface driver ums-sddr55
[ 1.648800] usbcore: registered new interface driver ums-usbat
[ 1.648894] usbcore: registered new interface driver usbserial
[ 1.648943] usbcore: registered new interface driver usbserial_generic
[ 1.648977] usbserial: USB Serial support registered for generic
[ 1.649019] usbcore: registered new interface driver option
[ 1.649050] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.649126] usbcore: registered new interface driver trancevibrator
[ 1.649139] usb20_otg: version 3.10a 21-DEC-2012
[ 1.649570] e2f80040
[ 1.649584] Core Release: 3.10a
[ 1.649600] Setting default values for core params
[ 1.649744] Using Buffer DMA mode
[ 1.649756] Periodic Transfer Interrupt Enhancement - disabled
[ 1.649767] Multiprocessor Interrupt Enhancement - disabled
[ 1.649779] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.649790] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.649808] Dedicated Tx FIFOs mode
[ 1.649828] pcd_init otg_dev = ddeffd00
[ 1.649990] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.650024] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.650060] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.650120] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.650137] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.650152] usb usb2: Product: DWC OTG Controller
[ 1.650165] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.650178] usb usb2: SerialNumber: ff580000.usb
[ 1.650613] hub 2-0:1.0: USB hub found
[ 1.650638] hub 2-0:1.0: 1 port detected
[ 1.650955] usb20_host: version 3.10a 21-DEC-2012
[ 1.653486] e3000040
[ 1.653501] Core Release: 3.10a
[ 1.653517] Setting default values for core params
[ 1.653640] Using Buffer DMA mode
[ 1.653653] Periodic Transfer Interrupt Enhancement - disabled
[ 1.653663] Multiprocessor Interrupt Enhancement - disabled
[ 1.653675] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.653686] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.653713] usb20_host ff540000.usb: DWC OTG Controller
[ 1.653740] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.653774] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.653867] Init: Power Port (0)
[ 1.653926] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.653943] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.653957] usb usb3: Product: DWC OTG Controller
[ 1.653970] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.653983] usb usb3: SerialNumber: ff540000.usb
[ 1.654437] hub 3-0:1.0: USB hub found
[ 1.654461] hub 3-0:1.0: 1 port detected
[ 1.655229] usbcore: registered new interface driver xpad
[ 1.655288] usbcore: registered new interface driver usb_acecad
[ 1.655334] usbcore: registered new interface driver aiptek
[ 1.655397] usbcore: registered new interface driver gtco
[ 1.655446] usbcore: registered new interface driver hanwang
[ 1.655490] usbcore: registered new interface driver kbtab
[ 1.655547] usbcore: registered new interface driver wacom
[ 1.655812] sensor_register_slave:mma8452,id=17
[ 1.655827] sensor_register_slave:gs_mc3230,id=23
[ 1.655837] gsensor_init
[ 1.655847] sensor_register_slave:mpu6880_acc,id=24
[ 1.655859] sensor_register_slave:mpu6500_acc,id=25
[ 1.655870] sensor_register_slave:cm3217,id=48
[ 1.655880] sensor_register_slave:cm3218,id=49
[ 1.660679] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.660729] i2c /dev entries driver
[ 1.661413] IR NEC protocol handler initialized
[ 1.661427] IR RC5(x) protocol handler initialized
[ 1.661438] IR RC6 protocol handler initialized
[ 1.661447] IR JVC protocol handler initialized
[ 1.661457] IR Sony protocol handler initialized
[ 1.661468] IR RC5 (streamzap) protocol handler initialized
[ 1.661478] IR SANYO protocol handler initialized
[ 1.661488] IR MCE Keyboard/mouse protocol handler initialized
[ 1.661643] usbcore: registered new interface driver uvcvideo
[ 1.661654] USB Video Class driver (1.1.1)
[ 1.661667] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.663224] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.663249] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.663270] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.663291] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.663341] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.663341]
[ 1.663416] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.663564] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe2ed8000 size: 0x4000)
[ 1.664219] D1:camsys_platform_probe(1447): ff910000.isp memory:
[ 1.664238] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe2fe0000 size: 0x10000)
[ 1.664255] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1dfa5000 vir: 0xddfa5000 size: 0x1000)
[ 1.664269] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.664282] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
[ 1.664739] test power disabled
[ 1.664794] i2c-core: driver [bq27320] using legacy suspend method
[ 1.664806] i2c-core: driver [bq27320] using legacy resume method
[ 1.665150] rockchip_temp_probe,line=364
[ 1.675411] hdmi->edidread:1[ 1.715777] tsadc ff280000.tsadc: initialized
[ 1.716170] device-mapper: uevent: version 1.0.3
[ 1.716413] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.716721] Bluetooth: HCI UART driver ver 2.2
[ 1.716737] Bluetooth: HCI H4 protocol initialized
[ 1.716749] Bluetooth: HCILL protocol initialized
[ 1.716762] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.716774] rtk_btusb: Register usb char device interface for BT driver
[ 1.716956] usbcore: registered new interface driver rtk_btusb
[ 1.717588] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(600000), use default, just enable dvfs
[ 1.721700] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.721898] cpuidle: using governor ladder
[ 1.721913] cpuidle: using governor menu
[ 1.721951] Synopsys Designware Multimedia Card Interface Driver
[ 1.721964] MHSC version = Ver 2.00 2015-06-10
[ 1.722273] dw cru_regsbase addr 0x1d8.
[ 1.722286] dw cru_reset_offset val 3.
[ 1.722301] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.722346] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.722648] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.722830] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.722959] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.735477] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.755234] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.755254] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.755286] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.755576] dw cru_regsbase addr 0x1d8.
[ 1.755590] dw cru_reset_offset val 0.
[ 1.755605] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.755644] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.756436] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.756595] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.757077] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.757143] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.771454] hdmi output corlor mode is 3
[ 1.771467] hdmi connect to lcdc1
[ 1.771476] switch:en=1,lcdc_id=1,screen type=6,cur type=0
[ 1.774819] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.787273] mmc0: BKOPS_EN bit is not set
[ 1.789154] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.791443] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.791468] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.791489] [mmc0] tuning regsbase addr 0x218.
[ 1.792259] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.792269] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792300] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.792325] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 1.792335] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792365] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.792391] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.792400] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792430] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.792478] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-237 (22 len)
[ 1.792490] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
[ 1.792500] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-237 (22 len)
[ 1.792511] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
[ 1.792555] mmc0: new HS200 MMC card at address 0001
[ 1.792841] mmcblk0: mmc0:0001 AJNB4R 14.5 GiB
[ 1.792960] mmcblk0rpmb: mmc0:0001 AJNB4R partition 3 4.00 MiB
[ 1.793289] rkpart: partition size too small (0)
[ 1.793303] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.793313] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.793322] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.793331] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.793339] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.793347] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.793356] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.793365] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.793373] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.793381] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.793390] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.793399] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.793407] userdata: 0x073800000 – 0x0f3800000 (2048 MB)
[ 1.793415] radical_update: 0x0f3800000 – 0x0f7800000 (64 MB)
[ 1.793424] user: 0x0f7800000 – 0x3a3a00000 (10946 MB)
[ 1.793453] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15[ 1.794536] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.794550] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.794866] dw cru_regsbase addr 0x1d8.
[ 1.794875] dw cru_reset_offset val 1.
[ 1.794885] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.794925] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.795182] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.795300] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.795549] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.814182] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.833867] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.833915] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.833928] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.834224] leds-gpio leds.31: pins are not configured from the driver
[ 1.834495] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.835920] usbcore: registered new interface driver usbhid
[ 1.835932] usbhid: USB HID core driver
[ 1.836051] ashmem: initialized
[ 1.836176] logger: created 256K log ‘log_main’
[ 1.836267] logger: created 256K log ‘log_events’
[ 1.836362] logger: created 256K log ‘log_radio’
[ 1.836455] logger: created 256K log ‘log_system’
[ 1.837573] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input0
[ 1.838452] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.838468] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.838479] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.838490] ES8323 2-0010: Error applying setting, reverse things back
[ 1.838786] es8323 probe i2c recv ok
[ 1.839732] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.840304] es8323_probe
[ 2.020808] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.020864] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 2.020898] pixel clk is 74250000 tmds clk is 74250000
[ 2.020946] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 2.473812] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 2.473823] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 2.473834] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 2.473842] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 2.473851] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 2.473860] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 2.473869] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 2.473877] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 2.473886] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 2.473894] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 2.473903] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 2.473910] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 2.473919] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 2.473927] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 2.473936] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 2.473943] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 2.473951] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 2.473959] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 2.473968] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 2.473975] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 2.473984] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 2.473992] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 2.474001] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 2.474008] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 2.474018] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 2.474025] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 2.474034] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 2.474041] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 2.474050] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 2.474058] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 2.474066] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 2.474074] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 2.474094] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 2.474102] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 2.474110] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 2.474118] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 2.474128] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 2.474135] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 2.474145] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 2.474152] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 2.474161] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 2.474168] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 2.474177] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 2.474184] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 2.474330] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 2.474342] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 2.474352] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 2.474361] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 2.474381] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 2.480719] rockchip-es8323 rockchip-es8323.30: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 2.481130] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.30/sound/card0/input1
[ 2.481554] u32 classifier
[ 2.481561] Actions configured
[ 2.481572] Netfilter messages via NETLINK v0.30.
[ 2.481625] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.481900] ctnetlink v0.93: registering with nfnetlink.
[ 2.481963] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.481970] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.482205] xt_time: kernel timezone is -0000
[ 2.482378] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.482493] arp_tables: (C) 2002 David S. Miller
[ 2.482529] TCP: cubic registered
[ 2.482535] Initializing XFRM netlink socket
[ 2.482698] NET: Registered protocol family 10
[ 2.483143] mip6: Mobile IPv6
[ 2.483168] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.483330] sit: IPv6 over IPv4 tunneling driver
[ 2.483617] NET: Registered protocol family 17
[ 2.483640] NET: Registered protocol family 15
[ 2.483690] Bridge firewalling registered
[ 2.483701] Ebtables v2.0 registered
[ 2.483870] Bluetooth: RFCOMM TTY layer initialized
[ 2.483898] Bluetooth: RFCOMM socket layer initialized
[ 2.483905] Bluetooth: RFCOMM ver 1.11
[ 2.483912] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.483918] Bluetooth: BNEP filters: protocol multicast
[ 2.483927] Bluetooth: BNEP socket layer initialized
[ 2.483934] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.483943] Bluetooth: HIDP socket layer initialized
[ 2.483967] l2tp_core: L2TP core driver, V2.0
[ 2.483979] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.483986] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.484191] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.484201] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.484209] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 2.484216] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.484225] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 2.484233] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.484252] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 2.484270] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 2.484276] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.484303] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 2.484311] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.484344] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.484467] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 2.484483] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 263.
[ 2.484495] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 2.484507] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 2.484519] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 2.484560] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.484658] [BT_RFKILL]: ** disable irq
[ 2.484731] [BT_RFKILL]: ap6335 device registered.
[ 2.485319] rk3288_init_suspend
[ 2.485330] rk3288_suspend_init enter
[ 2.485529] rk3288_suspend_init: pm_ctrbits =200007
[ 2.485558] gpio_get_dts_info suspend:4
[ 2.485564] gpio_get_dts_info resume:4
[ 2.485569] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.485594] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.485717] clks_gating_suspend_init:clkgt info ok
[ 2.485801] Registering SWP/SWPB emulation handler
[ 2.486098] ddrfreq: verion 1.2 20140526
[ 2.486110] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 2.486117] ddrfreq: auto-freq=0
[ 2.486122] ddrfreq: auto-freq-table[0] 240MHz
[ 2.486127] ddrfreq: auto-freq-table[1] 324MHz
[ 2.486132] ddrfreq: auto-freq-table[2] 456MHz
[ 2.486138] ddrfreq: auto-freq-table[3] 528MHz
[ 2.500428] regulator-dummy: disabling
[ 2.500504] =======================================================
[ 2.500511] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.500516] =======================================================
[ 2.500522] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.500568] dhd_module_init: in
[ 2.500576] ======== bcm_wlan_set_plat_data ========
[ 2.500582] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.500600] host_oob_irq: 196
[ 2.500605] host_oob_irq_flags=4
[ 2.500610] dhd_wifi_platform_load: Enter
[ 2.500622] pcd_pullup, is_on 0
[ 2.500625] Power-up adapter ‘DHD generic adapter’
[ 2.500645] wifi_platform_set_power = 1
[ 2.500651] ======== PULL WL_REG_ON HIGH! ========
[ 2.500657] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.500661] file system registered
[ 2.500666] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.500672] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.501165] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.501173] android_usb gadget: Number of LUNs=2
[ 2.501180] lun0: LUN: removable file: (no medium)
[ 2.501186] lun1: LUN: removable file: (no medium)
[ 2.501322] android_usb gadget: android_usb ready
[ 2.501389] sensor_init: Probe name sensors
[ 2.501404] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.501934] rtc_hym8563 0-0051: setting system clock to 2011-01-01 13:42:21 UTC (1293889341)
[ 2.508042] rockchip-spdif-card rockchip-spdif-card.29: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 2.508997] ret 1024
[ 2.509381] usbcore: registered new interface driver snd-usb-audio
[ 2.509389] ALSA device list:
[ 2.509395] #0: RK_ES8323
[ 2.509399] #1: RK-SPDIF-CARD
[ 2.509730] Freeing unused kernel memory: 356K (c0b96000 - c0bef000)
[ 2.601372] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.732626] type=1403 audit(1293889341.730:2): policy loaded auid=4294967295 ses=4294967295
[ 2.759883] init: invalid gid ‘trace’
[ 2.808015] wifi_platform_bus_enumerate device present 1
[ 2.808034] ======== Card detection to detect SDIO card! ========
[ 2.808043] mmc2:mmc host rescan start!
[ 2.858486] init: /dev/hw_random not found
[ 2.858554] keychord: using input dev rk29-keypad for fevent
[ 2.863539] init: /dev/hw_random not found
[ 2.864495] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.865303] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.867767] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.871717] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.871813] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.872639] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.878019] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.878069] e2fsck: system: clean, 1913/94848 files, 129677/393216 blocks
[ 2.881782] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.881858] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.888877] EXT4-fs (mmcblk0p8): recovery complete
[ 2.889284] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.889350] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.889716] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.893213] EXT4-fs (mmcblk0p11): recovery complete
[ 2.893230] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.893282] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.894015] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.898314] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.898352] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.902241] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.902310] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.902353] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.903193] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.903232] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.903476] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.903765] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.969560] EXT4-fs (mmcblk0p13): recovery complete
[ 2.970003] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.970089] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.971737] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.976964] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.977002] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 523/131072 files, 39603/524288 blocks
[ 2.981030] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.981098] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.981120] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.995317] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 2.995404] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.995450] mali pd enabled
[ 2.995463] clk enabled
[ 2.995476] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.995486] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.995497] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.995507] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.995518] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.995605] turn on mali power
[ 2.995617] kbase_platform_rk_init,register_reboot_notifier
[ 2.995659] hrtimer: interrupt took 11666 ns
[ 2.995757] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.996569] mali ffa30000.gpu: Probed as mali0
[ 2.997601] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.998266] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.998855] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.999609] zram0: detected capacity change from 0 to 533413888
[ 3.024503] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 3.046725] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.059322] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.060862] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.062382] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.065119] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.080707] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 3.088047] drmboot: module license ‘unspecified’ taints kernel.
[ 3.088069] Disabling lock debugging due to kernel taint
[ 3.088305] drm init, 20140910
[ 3.088788] drm init ok
[ 3.090381] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 3.090432] bat_cap: oldcap_path no exist
[ 3.090587] binder: 148:148 transaction failed 29189, size 0-0
[ 3.091309] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 3.095666] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.095694] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 3.095932] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 3.096495] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096512] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096528] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096540] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096563] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096574] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096588] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096598] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.101728] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 3.103386] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 3.103840] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 3.104098] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 3.105679] init: Warning! Service daemonsu needs a SELinux domain defined; please fix!
[ 3.105949] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
[ 3.107452] android_usb: already disabled
[ 3.109598] read descriptors
[ 3.109612] read strings
[ 3.109629] mtp_bind_config
[ 3.109654] pcd_pullup, is_on 1
[ 3.124027] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.124054] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 3.124125] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 3.125915] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.125943] mmc2: new high speed SDIO card at address 0001
[ 3.142132] bcmsdh_register: register client driver
[ 3.142235] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.142300] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.142308] bus num (host idx)=2, slot num (rca)=1
[ 3.142315] found adapter info ‘DHD generic adapter’
[ 3.142559] F1 signature read @0x18000000=0x16224335
[ 3.144539] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 3.144826] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.144868] wifi_platform_get_mac_addr
[ 3.144875] ======== bcm_wlan_get_mac_address ========
[ 3.144882] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.144891] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.144898] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.144908] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 3.144949] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.145257] wl_create_event_handler(): thread:wl_event_handler:aa started
[ 3.145262] tsk Enter, tsk = 0xdd74149c
[ 3.145399] dhd_attach(): thread:dhd_watchdog_thread:ab started
[ 3.145452] dhd_attach(): thread:dhd_dpc:ac started
[ 3.145493] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 3.145523] dhd_attach(): thread:dhd_rxf:ad started
[ 3.145535] dhd_deferred_work_init: work queue initialized
[ 3.145680] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 3.151206] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 3.151206] Compiled in drivers/net/wireless/bcmdhd on Sep 23 2017 at 09:53:11
[ 3.151576] Register interface [wlan0] MAC: 94:a1:a2:f7:cc:97
[ 3.151576]
[ 3.151589] dhd_prot_ioctl : bus is down. we have nothing to do
[ 3.151629] bcmsdh_oob_intr_unregister: Enter
[ 3.151636] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.151646] dhd_txglom_enable: enable 0
[ 3.151652] dhd_bus_devreset: WLAN OFF DONE
[ 3.151684] wifi_platform_set_power = 0
[ 3.151690] ======== PULL WL_REG_ON LOW! ========
[ 3.151696] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.250816] [WLAN_RFKILL]: wifi shut off power.
[ 3.250829] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.250835] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.250890] dhd_module_init: Exit err=0
[ 3.344079] RKNAND_GET_SN_SECTOR
[ 3.344091] return ret = 0
[ 3.344807] RKNAND_GET_DRM_KEY
[ 3.344819] return ret = 0
[ 3.624733] dwc_otg_hcd_enable, enable host controller
[ 3.674081] logd.auditd: start
[ 3.787094] Using Buffer DMA mode
[ 3.787107] Periodic Transfer Interrupt Enhancement - disabled
[ 3.787113] Multiprocessor Interrupt Enhancement - disabled
[ 3.787120] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.787125] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.787139] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.831458] Init: Power Port (0)
[ 4.075222] healthd: No charger supplies found
[ 4.075237] healthd: No battery devices found
[ 4.146300] Indeed it is in host mode hprt0 = 00021501
[ 4.323397] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 4.323477] Indeed it is in host mode hprt0 = 00001101
[ 4.405149] rk3288-lcdc lcdc0: blank mode:0
[ 4.432416] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaaa000
[ 4.520436] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 4.520450] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.520457] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 4.521016] hub 3-1:1.0: USB hub found
[ 4.521080] hub 3-1:1.0: 4 ports detected
[ 4.795866] usb 3-1.4: new full-speed USB device number 3 using usb20_host
[ 4.896400] usb 3-1.4: New USB device found, idVendor=2149, idProduct=2122
[ 4.896413] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.896422] usb 3-1.4: Product: CoolTouch™ System
[ 4.896428] usb 3-1.4: Manufacturer: Advanced Silicon S.A.
[ 4.902172] input: Advanced Silicon S.A. CoolTouch™ System as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.0/input/input2
[ 4.902390] gpufreq_input_connect
[ 4.902571] hid-multitouch 0003:2149:2122.0001: input,hidraw0: USB HID v1.10 Device [Advanced Silicon S.A. CoolTouch™ System] on usb-ff540000.usb-1.4/input0
[ 4.983257] hid-generic 0003:2149:2122.0002: hiddev0,hidraw1: USB HID v1.10 Device [Advanced Silicon S.A. CoolTouch™ System] on usb-ff540000.usb-1.4/input1
[ 5.559417] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 5.563231] iep dpi mode inactivity
[ 7.036343] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.036355] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.036363] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.036451] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 7.036463] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 7.036474] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 7.036500] rockchip_gpio_request:GPIO7-13
[ 7.036510] rockchip_gpio_set:GPIO7-13 level = 1
[ 7.036516] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 7.036525] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
[ 7.036533] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207420,result=0x207420
[ 7.036541] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 7.036562] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 7.041608] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.041619] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.041726] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.041757] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 7.042821] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 7.043880] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 7.044935] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 7.048184] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 7.049375] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 7.049484] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 7.049497] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 7.049520] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 7.050600] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.050634] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.052697] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 7.052713] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.052723] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.052730] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.052737] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.061501] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.061513] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.061521] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.061621] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 7.061634] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 7.061644] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 7.061653] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 7.061746] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 7.066781] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.066790] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.066896] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.066922] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 7.067984] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 7.069046] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 7.070103] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 7.073323] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 7.073394] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 7.073406] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 7.073418] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 7.074511] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.074544] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.076609] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 7.076624] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.076635] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.076643] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.076650] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.080932] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.080943] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.080951] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.081033] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 7.081061] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 7.086100] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.086110] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.086215] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.086240] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 7.087299] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 7.088351] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 7.089410] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 7.092759] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 7.092770] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 7.092777] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 7.093861] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.093887] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.095939] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.095950] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.095956] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.095963] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.097943] type=1400 audit(1293889346.160:3): avc: denied { execute } for pid=492 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.098116] type=1400 audit(1293889346.160:4): avc: denied { read open } for pid=492 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.098212] type=1400 audit(1293889346.160:5): avc: denied { execute_no_trans } for pid=492 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.100227] type=1400 audit(1293889346.170:6): avc: denied { getattr } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100321] type=1400 audit(1293889346.170:7): avc: denied { execute } for pid=492 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100393] type=1400 audit(1293889346.170:8): avc: denied { read open } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100464] type=1400 audit(1293889346.170:9): avc: denied { execute_no_trans } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 8.331945] healthd: battery none chg=
[ 8.514394] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 8.514408] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 8.514414] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 8.514420] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 8.514425] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 8.514430] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 8.514436] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 8.875598] acc_open
[ 8.875617] acc_release
[ 9.031537] phy_power_on: enable = 1
[ 9.070933] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 9.070962] eth0: device MAC address 4a:09:e2:8b:32:4f
[ 9.074998] libphy: stmmac: probed
[ 9.075010] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 9.075017] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 9.538600] [otg id chg] last id -1 current id 1
[ 9.538627] PortPower off
[ 9.538637] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 9.664456] Using Buffer DMA mode
[ 9.664474] Periodic Transfer Interrupt Enhancement - disabled
[ 9.664480] Multiprocessor Interrupt Enhancement - disabled
[ 9.664487] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.664493] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.716265] es8323_mic_state_ctrl read: 0
[ 9.716287] mic_state_switch 0
[ 9.716294] hp_det = 0,insert hp
[ 9.716299] hp mic use intern
[ 10.072988] pm policy 0 → 1
[ 10.148682] vbus detect**
[ 10.150877] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 10.347518] Using Buffer DMA mode
[ 10.347544] Periodic Transfer Interrupt Enhancement - disabled
[ 10.347551] Multiprocessor Interrupt Enhancement - disabled
[ 10.347558] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 10.347564] ^^^^^^^^^^^^^^^^^Device Mode
[ 10.347604] soft connect!!!
[ 10.470312] USB RESET
[ 10.527379] android_work: sent uevent USB_STATE=CONNECTED
[ 10.532064] USB RESET
[ 10.620587] android_usb gadget: high-speed config #1: android
[ 10.620769] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.678527] type=1400 audit(1293889350.820:10): avc: denied { write } for pid=497 comm=“Binder_1” name=“rotation_flag” dev=“mmcblk0p13” ino=15 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[ 11.678791] type=1400 audit(1293889350.820:11): avc: denied { open } for pid=497 comm=“Binder_1” path=“/data/rotation_flag” dev=“mmcblk0p13” ino=15 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[ 11.684100] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.684117] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.684125] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 11.684495] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000 Hz) in turn on
[ 11.684508] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.684615] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.684625] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.685325] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.687384] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.688078] type=1400 audit(1293889350.830:12): avc: denied { write } for pid=1057 comm=“Binder_1” name=“/” dev=“mmcblk0p13” ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688450] type=1400 audit(1293889350.830:13): avc: denied { remove_name } for pid=1057 comm=“Binder_1” name=“vpumem_observer” dev=“mmcblk0p13” ino=16 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688543] type=1400 audit(1293889350.830:14): avc: denied { unlink } for pid=1057 comm=“Binder_1” name=“vpumem_observer” dev=“mmcblk0p13” ino=16 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
[ 11.688650] type=1400 audit(1293889350.830:15): avc: denied { add_name } for pid=1057 comm=“Binder_1” name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688920] type=1400 audit(1293889350.830:16): avc: denied { create } for pid=1057 comm=“Binder_1” name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
[ 11.972740] D1:camsys_mrv_iommu_cb(276): map fd 46 ,client fd 34
[ 11.972740]
[ 11.972780] rk_iommu ff914000.isp_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab1000
[ 11.974899] D1:camsys_mrv_iommu_cb(276): map fd 48 ,client fd 34
[ 11.974899]
[ 11.974919] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.977015] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 34
[ 11.977015]
[ 11.977034] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.979134] D1:camsys_mrv_iommu_cb(276): map fd 50 ,client fd 34
[ 11.979134]
[ 11.979151] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.979809] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
[ 11.979822] W:camsys_phy_ops(478): mipiphy->phy_index(-1191300724) != extdev->phy.info.mipi.phy_index(0)!
[ 11.980032] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(0) turn on(lane: 0xf bit_rate: 648Mbps)
[ 12.093366] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
[ 12.093894] D1:camsys_mrv_iommu_cb(276): map fd 50 ,client fd 34
[ 12.093894]
[ 12.093997] rk_iommu ff914000.isp_mmu: (isp_mmu) 3 times left to be disabled
[ 12.094008] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 1eab1000 delayed
[ 12.094283] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 34
[ 12.094283]
[ 12.094380] rk_iommu ff914000.isp_mmu: (isp_mmu) 2 times left to be disabled
[ 12.094389] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 1eab1000 delayed
[ 12.094635] D1:camsys_mrv_iommu_cb(276): map fd 48 ,client fd 34
[ 12.094635]
[ 12.094732] rk_iommu ff914000.isp_mmu: (isp_mmu) 1 times left to be disabled
[ 12.094741] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 1eab1000 delayed
[ 12.094967] D1:camsys_mrv_iommu_cb(276): map fd 46 ,client fd 34
[ 12.094967]
[ 13.663621] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 13.663670] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 13.663681] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.663689] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.663698] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (May 27 2017 - 16:08:14)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-05-27#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x00697718)
ramdisk @ 0x05bf0000 (0x00146410)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c902 … OK
[ 0.000000] Linux version 3.10.0 (zq@zq-VirtualBox) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Sun Sep 24 21:37:16 CST 2017
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] ion_reserve: cma reserved base 7f000000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1efe000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),0x00400000@0x0039C000(userdata),0x00020000@0x0079C000(radical_update),-@0x007BC000(user) storagemedia=emmc loader.timestamp=2017-05-27_16:08:14
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 2026552k/2026552k available, 70600k reserved, 1556480K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0b9574c (11830 kB)
[ 0.000000] .init : 0xc0b96000 - 0xc0bef440 ( 358 kB)
[ 0.000000] .data : 0xc0bf0000 - 0xc0d813c0 (1605 kB)
[ 0.000000] .bss : 0xc0d813c0 - 0xc0ea277c (1157 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:12
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:10
[ 0.499993] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.500008] pid_max: default: 32768 minimum: 301
[ 0.500124] Security Framework initialized
[ 0.500141] SELinux: Initializing.
[ 0.500214] Mount-cache hash table entries: 512
[ 0.500859] Initializing cgroup subsys debug
[ 0.500873] Initializing cgroup subsys memory
[ 0.500899] Initializing cgroup subsys freezer
[ 0.500928] CPU: Testing write buffer coherency: ok
[ 0.501242] /cpus/cpu@0 missing clock-frequency property
[ 0.501255] /cpus/cpu@1 missing clock-frequency property
[ 0.501265] /cpus/cpu@2 missing clock-frequency property
[ 0.501274] /cpus/cpu@3 missing clock-frequency property
[ 0.501326] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.501378] Setting up static identity map for 0xc0854760 - 0xc08547b8
[ 0.504619] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x170a (version 3.1)
[ 0.578137] CPU1: Booted secondary processor
[ 0.578169] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.597806] CPU2: Booted secondary processor
[ 0.597830] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.617516] CPU3: Booted secondary processor
[ 0.617539] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.617639] Brought up 4 CPUs
[ 0.617667] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.617676] CPU: All CPU(s) started in SVC mode.
[ 0.618408] devtmpfs: initialized
[ 0.622567] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.623655] pinctrl core: initialized pinctrl subsystem
[ 0.623903] regulator-dummy: no parameters
[ 0.637880] NET: Registered protocol family 16
[ 0.639600] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.639922] ion_snapshot: 0x1ea90000 map to 0xe0907000 and copy to 0xc0e7da4c (version 0.1)
[ 0.640141] Registered FIQ tty driver
[ 0.640524] fiq-debugger is disabled in device tree
[ 0.641119] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.641140] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.641157] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.641174] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.641265] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.641328] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.641391] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.641453] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.641514] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.641576] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.641637] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.641699] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.641765] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.641829] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.641843] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.641854] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.641866] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.642495] rockchip_interrupts_register:bank_num=7
[ 0.644432] of_get_gpio_init_config:gpio[0] = 136, value = 0
[ 0.644489] rockchip_pinctrl_probe:init ok
[ 0.651721] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 0.651808] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.651821] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 0.651997] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 0.652064] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652077] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 0.652237] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 0.652310] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652322] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 0.652489] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 0.652559] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652571] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 0.652742] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 0.652815] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.652828] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 0.653000] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 0.653071] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653083] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 0.653253] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 0.653328] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.653341] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 0.655209] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.655222] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.655812] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.655834] DDR DEBUG: version 1.00 20150126
[ 0.655863] DDR DEBUG: Channel a:
[ 0.655872] DDR DEBUG: DDR3 Device
[ 0.655886] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.655894] DDR DEBUG: Channel b:
[ 0.655901] DDR DEBUG: DDR3 Device
[ 0.655914] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.655923] DDR DEBUG: addr=0xd8b000
[ 0.655932] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.655940] DDR DEBUG: socAddr[0]=0xd8b000, socAddr[1]=0xd8b10000
[ 0.655961] DDR DEBUG: dtar[0]=0x301b1000, dtar[1]=0x301b1000
[ 0.656014] DDR DEBUG: init success!!! freq=200MHz
[ 0.656022] DDR DEBUG: Channel a:
[ 0.656034] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656048] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656061] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656074] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656085] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.656094] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.656103] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.656111] DDR DEBUG: Channel b:
[ 0.656122] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656135] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656147] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656159] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90
[ 0.656170] [ 0.656179] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.656188] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.679760] bio: create slab at 0
[ 0.680255] Rockchip hdmi driver version 2.0
[ 0.680255] .
[ 0.681442] SCSI subsystem initialized
[ 0.681595] usbcore: registered new interface driver usbfs
[ 0.681648] usbcore: registered new interface driver hub
[ 0.681731] usbcore: registered new device driver usb
[ 0.684401] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.685035] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.685476] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.685728] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.685979] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.686099] media: Linux media interface: v0.10
[ 0.686178] Linux video capture interface: v2.00
[ 0.686240] pps_core: LinuxPPS API ver. 1 registered
[ 0.686250] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.686275] PTP clock support registered
[ 0.686332] i2c-core: driver [bq24296] using legacy suspend method
[ 0.686342] i2c-core: driver [bq24296] using legacy resume method
[ 0.687041] ion_drm_heap_create: 0@0
[ 0.687168] Rockchip ion module is successfully loaded (v1.1)
[ 0.687336] Advanced Linux Sound Architecture Driver Initialized.
[ 0.687742] Bluetooth: Core ver 2.16
[ 0.687795] NET: Registered protocol family 31
[ 0.687805] Bluetooth: HCI device and connection manager initialized
[ 0.687822] Bluetooth: HCI socket layer initialized
[ 0.687835] Bluetooth: L2CAP socket layer initialized
[ 0.687861] Bluetooth: SCO socket layer initialized
[ 0.688110] cfg80211: Calling CRDA to update world regulatory domain
[ 0.689030] rk_mipi_screen_init_dt: lcd->screen_init = 1.
[ 0.689043] rk_mipi_screen_init_dt: mipi_lcd->dsi_lane = 4.
[ 0.689054] rk_mipi_screen_init_dt: lcd->screen->hs_tx_clk = 940000000.
[ 0.689064] rk_mipi_screen_init_dt: lcd->screen.mipi_dsi_num = 2.
[ 0.689132] rk_mipi_screen_init_dt: lcd->screen->lcd_rst_delay = 10.
[ 0.689172] lcd->lcd_rst_gpio=113,dsi->lcd_rst_atv_val=1, lcd_rst_value = 0
[ 0.689185] rk_mipi_screen_init_dt: lcd->screen.lcd_en_delay = 10.
[ 0.689215] dsi->lcd_en_gpio=177, dsi->screen.lcd_en_atv_val=1, lcd_en_value = 0
[ 0.689227] rk_mipi_screen_init_dt: lcd->screen.lcd_vsp_delay = 10.
[ 0.689255] dsi->lcd_vsp_gpio=18, dsi->screen.lcd_vsp_atv_val=1, lcd_vsp_value = 0
[ 0.689267] rk_mipi_screen_init_dt: lcd->screen.lcd_vsn_delay = 20.
[ 0.689294] dsi->lcd_vsn_gpio=178, dsi->screen.lcd_vsn_atv_val=1, lcd_vsn_value = 0
[ 0.689362]
[ 0.689362] childnode->name =rockchip,on-cmds1:length=2
[ 0.689377] cmd[1]=05,
[ 0.689384] cmd[2]=11,[ 0.689391] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689404]
[ 0.689404] childnode->name =rockchip,on-cmds2:length=3
[ 0.689417] cmd[1]=15,
[ 0.689424] cmd[2]=51,cmd[3]=ff,
[ 0.689436] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689448]
[ 0.689448] childnode->name =rockchip,on-cmds3:length=3
[ 0.689461] cmd[1]=15,
[ 0.689468] cmd[2]=55,cmd[3]=02,
[ 0.689479] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689491]
[ 0.689491] childnode->name =rockchip,on-cmds4:length=3
[ 0.689504] cmd[1]=15,
[ 0.689510] cmd[2]=53,cmd[3]=2c,
[ 0.689521] dcs_cmd->dcs_cmd.cmd_len=3
[ 0.689532]
[ 0.689532] childnode->name =rockchip,on-cmds5:length=2
[ 0.689545] cmd[1]=05,
[ 0.689551] cmd[2]=11,[ 0.689557] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689573]
[ 0.689573] childnode->name =rockchip,on-cmds6:length=2
[ 0.689586] cmd[1]=05,
[ 0.689593] cmd[2]=29,[ 0.689598] dcs_cmd->dcs_cmd.cmd_len=2
[ 0.689609] —close cmd debug—
[ 0.689616] —rk_mipi_screen_probe–end
[ 0.689721] act8846_i2c_probe,line=898
[ 0.690698] act8846_parse_dt,line=746
[ 0.691164] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.691184] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.691199] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.691214] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.693269] act_dcdc1: 1200 mV
[ 0.696231] vccio: 3300 mV
[ 0.698080] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.701033] act_dcdc4: 2000 mV
[ 0.702248] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.704550] act_ldo2: 1050 mV
[ 0.706844] act_ldo3: 3300 mV
[ 0.709142] act_ldo4: 3300 mV
[ 0.711446] act_ldo5: 3300 mV
[ 0.713765] act_ldo6: 1100 mV
[ 0.716069] vcc_18: 1800 mV
[ 0.718363] act_ldo8: 1850 mV
[ 0.723101] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.727802] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.728571] rk808_i2c_probe,line=1355
[ 0.729904] The device is not rk808 -11
[ 0.729988] rk808: probe of 0-001b failed with error -11
[ 0.730060] i2c-core: driver [rk818] using legacy suspend method
[ 0.730069] i2c-core: driver [rk818] using legacy resume method
[ 0.731704] Switching to clocksource arch_sys_counter
[ 0.755381] rga: Module initialized.
[ 0.756091] rga2 ff920000.rga: rga ion client create success!
[ 0.756255] rga: Driver loaded succesfully
[ 0.756462] fb disp policy is box
[ 0.756506] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.756517] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.756815] rk-screen rk_screen.8: rockchip screen probe success
[ 0.756978] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.756998] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.757346] rk32-edp ff970000.edp: screen is not edp!
[ 0.757363] rk32-edp: probe of ff970000.edp failed with error -22
[ 0.757532] rk32-dsi
[ 0.757668] dsi->host.irq =51
[ 0.757683] dsi->dsi_id = 0
[ 0.757697] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
[ 0.757705] mipi_dsi v1.3 2014-04-17
[ 0.757731] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
[ 0.757743] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.757789] rk32-dsi
[ 0.757shell@firefly:/ $ 899] dsi->host.irq =52
[ 0.757910] dsi->dsi_id = 1
[ 0.757920] load mipi dsi chip:rk_mipi_dsi.1 id:3133302a
[ 0.757928] mipi_dsi v1.3 2014-04-17
[ 0.757948] rk32-mipi ff964000.mipi: rk mipi_dsi probe success!
[ 0.757959] rk32-mipi ff964000.mipi: rockchip mipi_dsi v1.1 2014-06-17
[ 0.758499] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 0.758722] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.759025] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.759197] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.759366] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.760913] rk3288-lcdc lcdc0: lcdc0: dclk:200000000>>fps:55
[ 0.760926] rk32_dsi_enable-------
[ 0.760935] rk32_init_phy_mode----------lcdc_id=0
[ 0.760946] dsi->phy.sys_clk =24000000
[ 0.760958] prediv:1, fbdiv:39,dsi->phy.ddr_clk:936000000
[ 0.760967] dsi->phy.ddr_clk =936000000
[ 0.760976] UI:1068
[ 0.760983] ref_clk:24000000
[ 0.760991] pclk:200000000, Tpclk:5000
[ 0.760999] sys_clk:24000000, Tsys_clk:41666
[ 0.761008] ddr_clk:936000000, Tddr_clk:1068
[ 0.761016] txbyte_clk:117000000, Ttxbyte_clk:8547
[ 0.761025] txclkesc:19500000, Ttxclkesc:51282
[ 0.770970] test_code=0x10,test_data=0xab
[ 0.770984] rk32_dwc_phy_test_wr:0000abab
[ 0.770992] test_code=0x11,test_data=0x8
[ 0.771004] rk32_dwc_phy_test_wr:00000808
[ 0.771012] test_code=0x12,test_data=0xc0
[ 0.771023] rk32_dwc_phy_test_wr:0000c0c0
[ 0.771032] test_code=0x44,test_data=0x14
[ 0.771043] rk32_dwc_phy_test_wr:00001414
[ 0.771051] test_code=0x17,test_data=0x0
[ 0.771062] rk32_dwc_phy_test_wr:00000100
[ 0.773038] test_code=0x18,test_data=0x6
[ 0.773050] rk32_dwc_phy_test_wr:00000506
[ 0.775026] test_code=0x18,test_data=0x81
[ 0.775037] rk32_dwc_phy_test_wr:00000281
[ 0.777013] test_code=0x19,test_data=0x30
[ 0.777024] rk32_dwc_phy_test_wr:00003030
[ 0.779001] test_code=0x20,test_data=0x4d
[ 0.779013] rk32_dwc_phy_test_wr:0000cd4d
[ 0.779021] test_code=0x21,test_data=0x3d
[ 0.779033] rk32_dwc_phy_test_wr:0000313d
[ 0.779040] test_code=0x21,test_data=0xdf
[ 0.779052] rk32_dwc_phy_test_wr:00009fdf
[ 0.779059] test_code=0x22,test_data=0x7
[ 0.779071] rk32_dwc_phy_test_wr:00000707
[ 0.779079] test_code=0x22,test_data=0x87
[ 0.779090] rk32_dwc_phy_test_wr:00000787
[ 0.779097] test_code=0x70,test_data=0x8f
[ 0.779109] rk32_dwc_phy_test_wr:00008f8f
[ 0.779117] test_code=0x71,test_data=0xd5
[ 0.779128] rk32_dwc_phy_test_wr:0000d5d5
[ 0.779135] test_code=0x72,test_data=0x4a
[ 0.779147] rk32_dwc_phy_test_wr:00004a4a
[ 0.779161] dsi->phy.Tpclk = 5000
[ 0.779169] screen->left_margin = 90
[ 0.779177] dsi->phy.Ttxbyte_clk = 8547
[ 0.779184] screen->hsync_len = 24
[ 0.779208] dsi->phy.sys_clk =24000000
[ 0.779218] prediv:1, fbdiv:39,dsi->phy.ddr_clk:936000000
[ 0.779226] dsi->phy.ddr_clk =936000000
[ 0.779236] UI:1068
[ 0.779242] ref_clk:24000000
[ 0.779250] pclk:200000000, Tpclk:5000
[ 0.779258] sys_clk:24000000, Tsys_clk:41666
[ 0.779267] ddr_clk:936000000, Tddr_clk:1068
[ 0.779275] txbyte_clk:117000000, Ttxbyte_clk:8547
[ 0.779283] txclkesc:19500000, Ttxclkesc:51282
[ 0.783322] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.791300] test_code=0x10,test_data=0xab
[ 0.791313] rk32_dwc_phy_test_wr:0000abab
[ 0.791321] test_code=0x11,test_data=0x8
[ 0.791333] rk32_dwc_phy_test_wr:00000808
[ 0.791341] test_code=0x12,test_data=0xc0
[ 0.791352] rk32_dwc_phy_test_wr:0000c0c0
[ 0.791360] test_code=0x44,test_data=0x14
[ 0.791371] rk32_dwc_phy_test_wr:00001414
[ 0.791379] test_code=0x17,test_data=0x0
[ 0.791390] rk32_dwc_phy_test_wr:00000100
[ 0.793366] test_code=0x18,test_data=0x6
[ 0.793377] rk32_dwc_phy_test_wr:00000506
[ 0.795353] test_code=0x18,test_data=0x81
[ 0.795364] rk32_dwc_phy_test_wr:00000281
[ 0.797340] test_code=0x19,test_data=0x30
[ 0.797352] rk32_dwc_phy_test_wr:00003030
[ 0.799328] test_code=0x20,test_data=0x4d
[ 0.799340] rk32_dwc_phy_test_wr:0000cd4d
[ 0.799347] test_code=0x21,test_data=0x3d
[ 0.799359] rk32_dwc_phy_test_wr:0000313d
[ 0.799366] test_code=0x21,test_data=0xdf
[ 0.799377] rk32_dwc_phy_test_wr:00009fdf
[ 0.799385] test_code=0x22,test_data=0x7
[ 0.799396] rk32_dwc_phy_test_wr:00000707
[ 0.799404] test_code=0x22,test_data=0x87
[ 0.799416] rk32_dwc_phy_test_wr:00000787
[ 0.799423] test_code=0x70,test_data=0x8f
[ 0.799435] rk32_dwc_phy_test_wr:00008f8f
[ 0.799442] test_code=0x71,test_data=0xd5
[ 0.799454] rk32_dwc_phy_test_wr:0000d5d5
[ 0.799461] test_code=0x72,test_data=0x4a
[ 0.799472] rk32_dwc_phy_test_wr:00004a4a
[ 0.799486] dsi->phy.Tpclk = 5000
[ 0.799494] screen->left_margin = 90
[ 0.799501] dsi->phy.Ttxbyte_clk = 8547
[ 0.799508] screen->hsync_len = 24
[ 0.799531] rk_mipi_screen branch*********
[ 0.799540] pwr_enable****
[ 0.799563] dcs_cmd.name:rockchip,on-cmds1
[ 0.799572] dcs_cmd.dsi_id == 2 line=201
[ 0.799584] 1217 command sent in LP mode size:1
[ 0.799592] write GEN_HDR:00001105
[ 0.799612] 1217 command sent in LP mode size:1
[ 0.799619] write GEN_HDR:00001105
[ 0.918729] dcs_cmd.name:rockchip,on-cmds2
[ 0.918739] dcs_cmd.dsi_id == 2 line=201
[ 0.918750] 1217 command sent in LP mode size:2
[ 0.918759] write GEN_HDR:00ff5115
[ 0.918779] 1217 command sent in LP mode size:2
[ 0.918787] write GEN_HDR:00ff5115
[ 0.938403] dcs_cmd.name:rockchip,on-cmds3
[ 0.938413] dcs_cmd.dsi_id == 2 line=201
[ 0.938423] 1217 command sent in LP mode size:2
[ 0.938431] write GEN_HDR:00025515
[ 0.938451] 1217 command sent in LP mode size:2
[ 0.938459] write GEN_HDR:00025515
[ 0.958082] dcs_cmd.name:rockchip,on-cmds4
[ 0.958092] dcs_cmd.dsi_id == 2 line=201
[ 0.958102] 1217 command sent in LP mode size:2
[ 0.958110] write GEN_HDR:002c5315
[ 0.958131] 1217 command sent in LP mode size:2
[ 0.958139] write GEN_HDR:002c5315
[ 0.977763] dcs_cmd.name:rockchip,on-cmds5
[ 0.977773] dcs_cmd.dsi_id == 2 line=201
[ 0.977783] 1217 command sent in LP mode size:1
[ 0.977791] write GEN_HDR:00001105
[ 0.977812] 1217 command sent in LP mode size:1
[ 0.977820] write GEN_HDR:00001105
[ 1.184405] dcs_cmd.name:rockchip,on-cmds6
[ 1.184415] dcs_cmd.dsi_id == 2 line=201
[ 1.184426] 1217 command sent in LP mode size:1
[ 1.184434] write GEN_HDR:00002905
[ 1.184454] 1217 command sent in LP mode size:1
[ 1.184462] write GEN_HDR:00002905
[ 1.391046] ++++++++++++++++rk_mipi_screen:315
[ 1.391065] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.437733] alloc_buffer:ion_phy_addr=0x10000000
[ 1.457367] fb0:phy:10000000>>vir:e0991000>>len:0x2500000
[ 1.457397] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa7000
[ 1.457413] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.457629] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.457642] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.457918] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.458264] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.458433] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.458610] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.459418] unknow screen type: 0
[ 1.459491] rk3288-lcdc lcdc1: lcdc1: dclk:200000000>>fps:55
[ 1.459506] rk3288-lcdc lcdc1: wakeup from standby!
[ 1.465228] fb4:phy:10000000>>vir:e0991000>>len:0x2500000
[ 1.465243] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 1.466120] rockchip_set_mux:warning ignore bank num 15
[ 1.466256] rockchip_set_mux:warning ignore bank num 15
[ 1.466376] rockchip_set_mux:warning ignore bank num 15
[ 1.466495] rockchip_set_mux:warning ignore bank num 15
[ 1.466608] rockchip_set_mux:warning ignore bank num 15
[ 1.466726] rockchip_set_mux:warning ignore bank num 15
[ 1.467303] rockchip_set_mux:warning ignore bank num 15
[ 1.467465] rockchip_set_mux:warning ignore bank num 15
[ 1.468001] rockchip_set_mux:warning ignore bank num 15
[ 1.468157] rockchip_set_mux:warning ignore bank num 15
[ 1.468689] rockchip_set_mux:warning ignore bank num 15
[ 1.468835] rockchip_set_mux:warning ignore bank num 15
[ 1.469370] rockchip_set_mux:warning ignore bank num 15
[ 1.469516] rockchip_set_mux:warning ignore bank num 15
[ 1.470645] tc358749_hdmiin_probe!
[ 1.529924] tc358749_hdmiin_probe OK!
[ 1.530379] NET: Registered protocol family 2
[ 1.531050] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.531125] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.531198] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.531250] TCP: reno registered
[ 1.531266] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.531289] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.531475] NET: Registered protocol family 1
[ 1.532105] Unpacking initramfs…
[ 1.602012] Freeing initrd memory: 1304K (c5bf0000 - c5d36000)
[ 1.602694] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.603270] vcodec_service: probe device ff9a0000.vpu_service
[ 1.603474] vcodec_service: No reset resource define
[ 1.603653] vcodec_service: ff9a0000.vpu_service: power on
[ 1.603739] vcodec_service: probe device ff9a0000.vpu_service
[ 1.603756] vcodec_service: checking hw id 4831
[ 1.604756] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.604800] vcodec_service: done
[ 1.604809] vcodec_service: init success
[ 1.604876] vcodec_service: probe device ff9c0000.hevc_service
[ 1.605213] vcodec_service: ff9c0000.hevc_service: power on
[ 1.605276] vcodec_service: probe device ff9c0000.hevc_service
[ 1.605290] vcodec_service: checking hw id 6867
[ 1.605827] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.605868] vcodec_service: done
[ 1.605877] vcodec_service: init success
[ 1.606015] rknandbase v1.0 2014-03-31
[ 1.606159] rknand: probe of ff400000.nandc failed with error -1
[ 1.606274] rknand_driver:ret = 0
[ 1.608258] audit: initializing netlink socket (disabled)
[ 1.608303] type=2000 audit(1.120:1): initialized
[ 1.609117] bounce pool size: 64 pages
[ 1.613731] fuse init (API version 7.22)
[ 1.614112] msgmni has been set to 952
[ 1.615939] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.615956] io scheduler noop registered
[ 1.615967] io scheduler deadline registered
[ 1.616056] io scheduler cfq registered (default)
[ 1.617680] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.618398] IEP Power ON
[ 1.618437] iep ion client create success!
[ 1.618873] rk_iommu ff900800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaa2000
[ 1.618884] IEP Power OFF
[ 1.618903] IEP Driver loaded succesfully
[ 1.619000] Module initialized.
[ 1.619837] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.619855] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.621181] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.621199] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.621544] rk_serial.c v1.8 2014-03-04
[ 1.621786] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.621973] serial ff180000.serial: membase e2eb2000
[ 1.622134] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.622315] serial ff190000.serial: membase e2ec4000
[ 1.622452] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.624790] console [ttyS2] enabled
[ 1.625014] serial ff690000.serial: membase fed60000
[ 1.625208] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.625380] serial ff1b0000.serial: membase e2ec6000
[ 1.627246] --11
[ 1.628242] loop: module loaded
[ 1.628609] zram: Created 1 device(s) …
[ 1.628697] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.628709] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.628727] mpu_init: Probe name mpu6050B1
[ 1.628869] ak8963_mod_init: Probe name ak8963_mod
[ 1.629624] SCSI Media Changer driver v0.25
[ 1.629950] tun: Universal TUN/TAP device driver, 1.6
[ 1.629975] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.630116] vmac_init.
[ 1.630698] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.630714] stmmac_probe_config_dt: clock input/output? (input).
[ 1.630727] stmmac_probe_config_dt: TX delay(0x30).
[ 1.630739] stmmac_probe_config_dt: RX delay(0x20).
[ 1.630787] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.630798] stmmc_pltfr_init:
[ 1.630806] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.630829] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.630840] stmmc_pltfr_init: init for RGMII
[ 1.630851] tx delay=0x30
[ 1.630851] rx delay=0x20
[ 1.630868] tx delay=0x30
[ 1.630868] rx delay=0x20
[ 1.631336] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.631347] Normal descriptors
[ 1.631356] Ring mode enabled
[ 1.631366] DMA HW capability register supported
[ 1.631378] RX Checksum Offload Engine supported (type 2)
[ 1.631388] TX Checksum insertion supported
[ 1.631398] Wake-Up On Lan supported
[ 1.631433] Enable RX Mitigation via HW Watchdog Timer
[ 1.631866] PPP generic driver version 2.4.2
[ 1.632020] PPP BSD Compression module registered
[ 1.632035] PPP Deflate Compression module registered
[ 1.632059] PPP MPPE Compression module registered
[ 1.632073] NET: Registered protocol family 24
[ 1.632109] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.632123] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.632136] Rockchip WiFi SYS interface (V1.00) …
[ 1.632170] esp_mem_init enter date Sep 23 2017 09:52:56
[ 1.632181] esp_mem_init VERSION [V2.5]
[ 1.632222] esp_mem_init complete
[ 1.632308] usbcore: registered new interface driver catc
[ 1.632348] usbcore: registered new interface driver kaweth
[ 1.632362] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.632400] usbcore: registered new interface driver pegasus
[ 1.632445] usbcore: registered new interface driver rtl8150
[ 1.632485] usbcore: registered new interface driver r8152
[ 1.632497] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.632563] usbcore: registered new interface driver hso
[ 1.632607] usbcore: registered new interface driver asix
[ 1.632650] usbcore: registered new interface driver ax88179_178a
[ 1.632691] usbcore: registered new interface driver cdc_ether
[ 1.632735] usbcore: registered new interface driver cdc_eem
[ 1.632775] usbcore: registered new interface driver dm9601
[ 1.632813] usbcore: registered new interface driver dm9620
[ 1.632860] usbcore: registered new interface driver smsc75xx
[ 1.632906] usbcore: registered new interface driver smsc95xx
[ 1.632944] usbcore: registered new interface driver gl620a
[ 1.632987] usbcore: registered new interface driver net1080
[ 1.633028] usbcore: registered new interface driver plusb
[ 1.633069] usbcore: registered new interface driver rndis_host
[ 1.633108] usbcore: registered new interface driver cdc_subset
[ 1.633146] usbcore: registered new interface driver zaurus
[ 1.633187] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.633251] usbcore: registered new interface driver int51x1
[ 1.633290] usbcore: registered new interface driver kalmia
[ 1.633335] usbcore: registered new interface driver ipheth
[ 1.633377] usbcore: registered new interface driver sierra_net
[ 1.633420] usbcore: registered new interface driver cx82310_eth
[ 1.633468] usbcore: registered new interface driver cdc_ncm
[ 1.633508] usbcore: registered new interface driver qmi_wwan
[ 1.633547] usbcore: registered new interface driver cdc_mbim
[ 1.633560] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.636030] EHCI: ehci_rk_probe e2f40000 e2f40010
[ 1.636049] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.636081] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.636469] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.646891] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.646988] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.647007] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.647022] usb usb1: Product: EHCI Host Controller
[ 1.647035] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.647048] usb usb1: SerialNumber: ff500000.usb
[ 1.647490] hub 1-0:1.0: USB hub found
[ 1.647516] hub 1-0:1.0: 1 port detected
[ 1.647686] EHCI: ehci_rk_probe ok
[ 1.647809] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.648135] usbcore: registered new interface driver cdc_acm
[ 1.648149] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.648206] usbcore: registered new interface driver usblp
[ 1.648250] usbcore: registered new interface driver cdc_wdm
[ 1.648317] usbcore: registered new interface driver usb-storage
[ 1.648358] usbcore: registered new interface driver ums-alauda
[ 1.648396] usbcore: registered new interface driver ums-cypress
[ 1.648437] usbcore: registered new interface driver ums-datafab
[ 1.648482] usbcore: registered new interface driver ums_eneub6250
[ 1.648522] usbcore: registered new interface driver ums-freecom
[ 1.648563] usbcore: registered new interface driver ums-isd200
[ 1.648602] usbcore: registered new interface driver ums-jumpshot
[ 1.648641] usbcore: registered new interface driver ums-karma
[ 1.648679] usbcore: registered new interface driver ums-onetouch
[ 1.648719] usbcore: registered new interface driver ums-sddr09
[ 1.648760] usbcore: registered new interface driver ums-sddr55
[ 1.648800] usbcore: registered new interface driver ums-usbat
[ 1.648894] usbcore: registered new interface driver usbserial
[ 1.648943] usbcore: registered new interface driver usbserial_generic
[ 1.648977] usbserial: USB Serial support registered for generic
[ 1.649019] usbcore: registered new interface driver option
[ 1.649050] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.649126] usbcore: registered new interface driver trancevibrator
[ 1.649139] usb20_otg: version 3.10a 21-DEC-2012
[ 1.649570] e2f80040
[ 1.649584] Core Release: 3.10a
[ 1.649600] Setting default values for core params
[ 1.649744] Using Buffer DMA mode
[ 1.649756] Periodic Transfer Interrupt Enhancement - disabled
[ 1.649767] Multiprocessor Interrupt Enhancement - disabled
[ 1.649779] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.649790] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.649808] Dedicated Tx FIFOs mode
[ 1.649828] pcd_init otg_dev = ddeffd00
[ 1.649990] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.650024] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 1.650060] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.650120] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.650137] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.650152] usb usb2: Product: DWC OTG Controller
[ 1.650165] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.650178] usb usb2: SerialNumber: ff580000.usb
[ 1.650613] hub 2-0:1.0: USB hub found
[ 1.650638] hub 2-0:1.0: 1 port detected
[ 1.650955] usb20_host: version 3.10a 21-DEC-2012
[ 1.653486] e3000040
[ 1.653501] Core Release: 3.10a
[ 1.653517] Setting default values for core params
[ 1.653640] Using Buffer DMA mode
[ 1.653653] Periodic Transfer Interrupt Enhancement - disabled
[ 1.653663] Multiprocessor Interrupt Enhancement - disabled
[ 1.653675] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.653686] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.653713] usb20_host ff540000.usb: DWC OTG Controller
[ 1.653740] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 1.653774] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.653867] Init: Power Port (0)
[ 1.653926] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.653943] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.653957] usb usb3: Product: DWC OTG Controller
[ 1.653970] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.653983] usb usb3: SerialNumber: ff540000.usb
[ 1.654437] hub 3-0:1.0: USB hub found
[ 1.654461] hub 3-0:1.0: 1 port detected
[ 1.655229] usbcore: registered new interface driver xpad
[ 1.655288] usbcore: registered new interface driver usb_acecad
[ 1.655334] usbcore: registered new interface driver aiptek
[ 1.655397] usbcore: registered new interface driver gtco
[ 1.655446] usbcore: registered new interface driver hanwang
[ 1.655490] usbcore: registered new interface driver kbtab
[ 1.655547] usbcore: registered new interface driver wacom
[ 1.655812] sensor_register_slave:mma8452,id=17
[ 1.655827] sensor_register_slave:gs_mc3230,id=23
[ 1.655837] gsensor_init
[ 1.655847] sensor_register_slave:mpu6880_acc,id=24
[ 1.655859] sensor_register_slave:mpu6500_acc,id=25
[ 1.655870] sensor_register_slave:cm3217,id=48
[ 1.655880] sensor_register_slave:cm3218,id=49
[ 1.660679] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.660729] i2c /dev entries driver
[ 1.661413] IR NEC protocol handler initialized
[ 1.661427] IR RC5(x) protocol handler initialized
[ 1.661438] IR RC6 protocol handler initialized
[ 1.661447] IR JVC protocol handler initialized
[ 1.661457] IR Sony protocol handler initialized
[ 1.661468] IR RC5 (streamzap) protocol handler initialized
[ 1.661478] IR SANYO protocol handler initialized
[ 1.661488] IR MCE Keyboard/mouse protocol handler initialized
[ 1.661643] usbcore: registered new interface driver uvcvideo
[ 1.661654] USB Video Class driver (1.1.1)
[ 1.661667] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.663224] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.663249] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.663270] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.663291] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.663341] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.663341]
[ 1.663416] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.663564] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe2ed8000 size: 0x4000)
[ 1.664219] D1:camsys_platform_probe(1447): ff910000.isp memory:
[ 1.664238] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe2fe0000 size: 0x10000)
[ 1.664255] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1dfa5000 vir: 0xddfa5000 size: 0x1000)
[ 1.664269] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.664282] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
[ 1.664739] test power disabled
[ 1.664794] i2c-core: driver [bq27320] using legacy suspend method
[ 1.664806] i2c-core: driver [bq27320] using legacy resume method
[ 1.665150] rockchip_temp_probe,line=364
[ 1.675411] hdmi->edidread:1[ 1.715777] tsadc ff280000.tsadc: initialized
[ 1.716170] device-mapper: uevent: version 1.0.3
[ 1.716413] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.716721] Bluetooth: HCI UART driver ver 2.2
[ 1.716737] Bluetooth: HCI H4 protocol initialized
[ 1.716749] Bluetooth: HCILL protocol initialized
[ 1.716762] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.716774] rtk_btusb: Register usb char device interface for BT driver
[ 1.716956] usbcore: registered new interface driver rtk_btusb
[ 1.717588] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(600000), use default, just enable dvfs
[ 1.721700] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.721898] cpuidle: using governor ladder
[ 1.721913] cpuidle: using governor menu
[ 1.721951] Synopsys Designware Multimedia Card Interface Driver
[ 1.721964] MHSC version = Ver 2.00 2015-06-10
[ 1.722273] dw cru_regsbase addr 0x1d8.
[ 1.722286] dw cru_reset_offset val 3.
[ 1.722301] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.722346] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.722648] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.722830] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.722959] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.735477] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.755234] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.755254] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.755286] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.755576] dw cru_regsbase addr 0x1d8.
[ 1.755590] dw cru_reset_offset val 0.
[ 1.755605] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.755644] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.756436] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.756595] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.757077] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.757143] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.771454] hdmi output corlor mode is 3
[ 1.771467] hdmi connect to lcdc1
[ 1.771476] switch:en=1,lcdc_id=1,screen type=6,cur type=0
[ 1.774819] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.787273] mmc0: BKOPS_EN bit is not set
[ 1.789154] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.791443] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.791468] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.791489] [mmc0] tuning regsbase addr 0x218.
[ 1.792259] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.792269] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792300] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.792325] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 1.792335] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792365] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.792391] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.792400] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.792430] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.792478] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-237 (22 len)
[ 1.792490] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
[ 1.792500] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-237 (22 len)
[ 1.792511] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
[ 1.792555] mmc0: new HS200 MMC card at address 0001
[ 1.792841] mmcblk0: mmc0:0001 AJNB4R 14.5 GiB
[ 1.792960] mmcblk0rpmb: mmc0:0001 AJNB4R partition 3 4.00 MiB
[ 1.793289] rkpart: partition size too small (0)
[ 1.793303] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.793313] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.793322] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.793331] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.793339] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.793347] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.793356] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.793365] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.793373] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.793381] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.793390] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.793399] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.793407] userdata: 0x073800000 – 0x0f3800000 (2048 MB)
[ 1.793415] radical_update: 0x0f3800000 – 0x0f7800000 (64 MB)
[ 1.793424] user: 0x0f7800000 – 0x3a3a00000 (10946 MB)
[ 1.793453] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15[ 1.794536] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.794550] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.794866] dw cru_regsbase addr 0x1d8.
[ 1.794875] dw cru_reset_offset val 1.
[ 1.794885] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.794925] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.795182] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.795300] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.795549] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.814182] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.833867] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.833915] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.833928] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.834224] leds-gpio leds.31: pins are not configured from the driver
[ 1.834495] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.835920] usbcore: registered new interface driver usbhid
[ 1.835932] usbhid: USB HID core driver
[ 1.836051] ashmem: initialized
[ 1.836176] logger: created 256K log ‘log_main’
[ 1.836267] logger: created 256K log ‘log_events’
[ 1.836362] logger: created 256K log ‘log_radio’
[ 1.836455] logger: created 256K log ‘log_system’
[ 1.837573] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input0
[ 1.838452] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.838468] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.838479] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.838490] ES8323 2-0010: Error applying setting, reverse things back
[ 1.838786] es8323 probe i2c recv ok
[ 1.839732] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.840304] es8323_probe
[ 2.020808] rk_fb_switch_screen: wait update_regs_wait timeout
[ 2.020864] rk3288-lcdc lcdc1: lcdc1: dclk:74250000>>fps:60
[ 2.020898] pixel clk is 74250000 tmds clk is 74250000
[ 2.020946] rockchip-hdmiv2 ff980000.hdmi: [hdmi_dev_config_video] sucess output HDMI.
[ 2.473812] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 2.473823] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 2.473834] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 2.473842] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 2.473851] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 2.473860] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 2.473869] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 2.473877] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 2.473886] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 2.473894] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 2.473903] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 2.473910] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 2.473919] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 2.473927] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 2.473936] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 2.473943] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 2.473951] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 2.473959] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 2.473968] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 2.473975] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 2.473984] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 2.473992] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 2.474001] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 2.474008] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 2.474018] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 2.474025] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 2.474034] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 2.474041] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 2.474050] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 2.474058] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 2.474066] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 2.474074] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 2.474094] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 2.474102] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 2.474110] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 2.474118] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 2.474128] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 2.474135] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 2.474145] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 2.474152] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 2.474161] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 2.474168] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 2.474177] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 2.474184] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 2.474330] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 2.474342] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 2.474352] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 2.474361] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 2.474381] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 2.480719] rockchip-es8323 rockchip-es8323.30: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 2.481130] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.30/sound/card0/input1
[ 2.481554] u32 classifier
[ 2.481561] Actions configured
[ 2.481572] Netfilter messages via NETLINK v0.30.
[ 2.481625] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.481900] ctnetlink v0.93: registering with nfnetlink.
[ 2.481963] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.481970] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.482205] xt_time: kernel timezone is -0000
[ 2.482378] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.482493] arp_tables: (C) 2002 David S. Miller
[ 2.482529] TCP: cubic registered
[ 2.482535] Initializing XFRM netlink socket
[ 2.482698] NET: Registered protocol family 10
[ 2.483143] mip6: Mobile IPv6
[ 2.483168] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.483330] sit: IPv6 over IPv4 tunneling driver
[ 2.483617] NET: Registered protocol family 17
[ 2.483640] NET: Registered protocol family 15
[ 2.483690] Bridge firewalling registered
[ 2.483701] Ebtables v2.0 registered
[ 2.483870] Bluetooth: RFCOMM TTY layer initialized
[ 2.483898] Bluetooth: RFCOMM socket layer initialized
[ 2.483905] Bluetooth: RFCOMM ver 1.11
[ 2.483912] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.483918] Bluetooth: BNEP filters: protocol multicast
[ 2.483927] Bluetooth: BNEP socket layer initialized
[ 2.483934] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.483943] Bluetooth: HIDP socket layer initialized
[ 2.483967] l2tp_core: L2TP core driver, V2.0
[ 2.483979] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.483986] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.484191] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.484201] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.484209] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 2.484216] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.484225] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 2.484233] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.484252] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 2.484270] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 2.484276] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.484303] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 2.484311] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.484344] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.484467] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 2.484483] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 263.
[ 2.484495] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 2.484507] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 2.484519] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 2.484560] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.484658] [BT_RFKILL]: ** disable irq
[ 2.484731] [BT_RFKILL]: ap6335 device registered.
[ 2.485319] rk3288_init_suspend
[ 2.485330] rk3288_suspend_init enter
[ 2.485529] rk3288_suspend_init: pm_ctrbits =200007
[ 2.485558] gpio_get_dts_info suspend:4
[ 2.485564] gpio_get_dts_info resume:4
[ 2.485569] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.485594] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.485717] clks_gating_suspend_init:clkgt info ok
[ 2.485801] Registering SWP/SWPB emulation handler
[ 2.486098] ddrfreq: verion 1.2 20140526
[ 2.486110] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 2.486117] ddrfreq: auto-freq=0
[ 2.486122] ddrfreq: auto-freq-table[0] 240MHz
[ 2.486127] ddrfreq: auto-freq-table[1] 324MHz
[ 2.486132] ddrfreq: auto-freq-table[2] 456MHz
[ 2.486138] ddrfreq: auto-freq-table[3] 528MHz
[ 2.500428] regulator-dummy: disabling
[ 2.500504] =======================================================
[ 2.500511] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.500516] =======================================================
[ 2.500522] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.500568] dhd_module_init: in
[ 2.500576] ======== bcm_wlan_set_plat_data ========
[ 2.500582] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.500600] host_oob_irq: 196
[ 2.500605] host_oob_irq_flags=4
[ 2.500610] dhd_wifi_platform_load: Enter
[ 2.500622] pcd_pullup, is_on 0
[ 2.500625] Power-up adapter ‘DHD generic adapter’
[ 2.500645] wifi_platform_set_power = 1
[ 2.500651] ======== PULL WL_REG_ON HIGH! ========
[ 2.500657] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.500661] file system registered
[ 2.500666] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.500672] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.501165] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.501173] android_usb gadget: Number of LUNs=2
[ 2.501180] lun0: LUN: removable file: (no medium)
[ 2.501186] lun1: LUN: removable file: (no medium)
[ 2.501322] android_usb gadget: android_usb ready
[ 2.501389] sensor_init: Probe name sensors
[ 2.501404] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.501934] rtc_hym8563 0-0051: setting system clock to 2011-01-01 13:42:21 UTC (1293889341)
[ 2.508042] rockchip-spdif-card rockchip-spdif-card.29: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 2.508997] ret 1024
[ 2.509381] usbcore: registered new interface driver snd-usb-audio
[ 2.509389] ALSA device list:
[ 2.509395] #0: RK_ES8323
[ 2.509399] #1: RK-SPDIF-CARD
[ 2.509730] Freeing unused kernel memory: 356K (c0b96000 - c0bef000)
[ 2.601372] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.732626] type=1403 audit(1293889341.730:2): policy loaded auid=4294967295 ses=4294967295
[ 2.759883] init: invalid gid ‘trace’
[ 2.808015] wifi_platform_bus_enumerate device present 1
[ 2.808034] ======== Card detection to detect SDIO card! ========
[ 2.808043] mmc2:mmc host rescan start!
[ 2.858486] init: /dev/hw_random not found
[ 2.858554] keychord: using input dev rk29-keypad for fevent
[ 2.863539] init: /dev/hw_random not found
[ 2.864495] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.865303] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
[ 2.867767] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
[ 2.871717] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.871813] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
[ 2.872639] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
[ 2.878019] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.878069] e2fsck: system: clean, 1913/94848 files, 129677/393216 blocks
[ 2.881782] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 2.881858] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
[ 2.888877] EXT4-fs (mmcblk0p8): recovery complete
[ 2.889284] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.889350] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
[ 2.889716] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 2.893213] EXT4-fs (mmcblk0p11): recovery complete
[ 2.893230] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.893282] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
[ 2.894015] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
[ 2.898314] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.898352] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
[ 2.902241] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 2.902310] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
[ 2.902353] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.903193] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
[ 2.903232] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 2.903476] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
[ 2.903765] EXT4-fs (mmcblk0p13): Ignoring removed nomblk_io_submit option
[ 2.969560] EXT4-fs (mmcblk0p13): recovery complete
[ 2.970003] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
[ 2.970089] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
[ 2.971737] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
[ 2.976964] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 2.977002] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 523/131072 files, 39603/524288 blocks
[ 2.981030] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
[ 2.981098] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
[ 2.981120] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
[ 2.995317] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
[ 2.995404] mali ffa30000.gpu: Continuing without Mali clock control
[ 2.995450] mali pd enabled
[ 2.995463] clk enabled
[ 2.995476] MALI_DVFS_STEP = 4, div_dvfs = 10
[ 2.995486] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70
[ 2.995497] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80
[ 2.995507] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90
[ 2.995518] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100
[ 2.995605] turn on mali power
[ 2.995617] kbase_platform_rk_init,register_reboot_notifier
[ 2.995659] hrtimer: interrupt took 11666 ns
[ 2.995757] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
[ 2.996569] mali ffa30000.gpu: Probed as mali0
[ 2.997601] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.998266] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.998855] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
[ 2.999609] zram0: detected capacity change from 0 to 533413888
[ 3.024503] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 3.046725] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 3.059322] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.060862] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.062382] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.065119] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.080707] EXT4-fs (mmcblk0p13): Unrecognized mount option “background_gc=on” or missing value
[ 3.088047] drmboot: module license ‘unspecified’ taints kernel.
[ 3.088069] Disabling lock debugging due to kernel taint
[ 3.088305] drm init, 20140910
[ 3.088788] drm init ok
[ 3.090381] bat_cap: oldcap path is /sys/devices/ff100000.adc
[ 3.090432] bat_cap: oldcap_path no exist
[ 3.090587] binder: 148:148 transaction failed 29189, size 0-0
[ 3.091309] init: Warning! Service displayd needs a SELinux domain defined; please fix!
[ 3.095666] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 3.095694] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
[ 3.095932] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
[ 3.096495] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096512] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096528] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096540] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096563] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096574] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.096588] rtk_btusb: btchr_open: BT usb char device is opening
[ 3.096598] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
[ 3.101728] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
[ 3.103386] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
[ 3.103840] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
[ 3.104098] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
[ 3.105679] init: Warning! Service daemonsu needs a SELinux domain defined; please fix!
[ 3.105949] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
[ 3.107452] android_usb: already disabled
[ 3.109598] read descriptors
[ 3.109612] read strings
[ 3.109629] mtp_bind_config
[ 3.109654] pcd_pullup, is_on 1
[ 3.124027] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.124054] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 3.124125] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 3.125915] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.125943] mmc2: new high speed SDIO card at address 0001
[ 3.142132] bcmsdh_register: register client driver
[ 3.142235] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.142300] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.142308] bus num (host idx)=2, slot num (rca)=1
[ 3.142315] found adapter info ‘DHD generic adapter’
[ 3.142559] F1 signature read @0x18000000=0x16224335
[ 3.144539] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 3.144826] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.144868] wifi_platform_get_mac_addr
[ 3.144875] ======== bcm_wlan_get_mac_address ========
[ 3.144882] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.144891] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.144898] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.144908] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 3.144949] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.145257] wl_create_event_handler(): thread:wl_event_handler:aa started
[ 3.145262] tsk Enter, tsk = 0xdd74149c
[ 3.145399] dhd_attach(): thread:dhd_watchdog_thread:ab started
[ 3.145452] dhd_attach(): thread:dhd_dpc:ac started
[ 3.145493] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 3.145523] dhd_attach(): thread:dhd_rxf:ad started
[ 3.145535] dhd_deferred_work_init: work queue initialized
[ 3.145680] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 3.151206] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 3.151206] Compiled in drivers/net/wireless/bcmdhd on Sep 23 2017 at 09:53:11
[ 3.151576] Register interface [wlan0] MAC: 94:a1:a2:f7:cc:97
[ 3.151576]
[ 3.151589] dhd_prot_ioctl : bus is down. we have nothing to do
[ 3.151629] bcmsdh_oob_intr_unregister: Enter
[ 3.151636] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.151646] dhd_txglom_enable: enable 0
[ 3.151652] dhd_bus_devreset: WLAN OFF DONE
[ 3.151684] wifi_platform_set_power = 0
[ 3.151690] ======== PULL WL_REG_ON LOW! ========
[ 3.151696] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.250816] [WLAN_RFKILL]: wifi shut off power.
[ 3.250829] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.250835] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.250890] dhd_module_init: Exit err=0
[ 3.344079] RKNAND_GET_SN_SECTOR
[ 3.344091] return ret = 0
[ 3.344807] RKNAND_GET_DRM_KEY
[ 3.344819] return ret = 0
[ 3.624733] dwc_otg_hcd_enable, enable host controller
[ 3.674081] logd.auditd: start
[ 3.787094] Using Buffer DMA mode
[ 3.787107] Periodic Transfer Interrupt Enhancement - disabled
[ 3.787113] Multiprocessor Interrupt Enhancement - disabled
[ 3.787120] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.787125] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.787139] EHCI: rk_ehci_hcd_enable, disable host controller
[ 3.831458] Init: Power Port (0)
[ 4.075222] healthd: No charger supplies found
[ 4.075237] healthd: No battery devices found
[ 4.146300] Indeed it is in host mode hprt0 = 00021501
[ 4.323397] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 4.323477] Indeed it is in host mode hprt0 = 00001101
[ 4.405149] rk3288-lcdc lcdc0: blank mode:0
[ 4.432416] rk_iommu ff940300.vopl_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eaaa000
[ 4.520436] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 4.520450] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.520457] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 4.521016] hub 3-1:1.0: USB hub found
[ 4.521080] hub 3-1:1.0: 4 ports detected
[ 4.795866] usb 3-1.4: new full-speed USB device number 3 using usb20_host
[ 4.896400] usb 3-1.4: New USB device found, idVendor=2149, idProduct=2122
[ 4.896413] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.896422] usb 3-1.4: Product: CoolTouch™ System
[ 4.896428] usb 3-1.4: Manufacturer: Advanced Silicon S.A.
[ 4.902172] input: Advanced Silicon S.A. CoolTouch™ System as /devices/ff540000.usb/usb3/3-1/3-1.4/3-1.4:1.0/input/input2
[ 4.902390] gpufreq_input_connect
[ 4.902571] hid-multitouch 0003:2149:2122.0001: input,hidraw0: USB HID v1.10 Device [Advanced Silicon S.A. CoolTouch™ System] on usb-ff540000.usb-1.4/input0
[ 4.983257] hid-generic 0003:2149:2122.0002: hiddev0,hidraw1: USB HID v1.10 Device [Advanced Silicon S.A. CoolTouch™ System] on usb-ff540000.usb-1.4/input1
[ 5.559417] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
[ 5.563231] iep dpi mode inactivity
[ 7.036343] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.036355] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.036363] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.036451] D1:camsys_extdev_register(243): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success!
[ 7.036463] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success!
[ 7.036474] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success!
[ 7.036500] rockchip_gpio_request:GPIO7-13
[ 7.036510] rockchip_gpio_set:GPIO7-13 level = 1
[ 7.036516] rockchip_gpio_direction_output:set GPIO7-13 level 1
[ 7.036525] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x15
[ 7.036533] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207420,result=0x207420
[ 7.036541] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
[ 7.036562] D1:camsys_extdev_register(268): Extdev(dev_id: 0x2000000 dev_name: OV13850) register success
[ 7.041608] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.041619] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.041726] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.041757] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 7.042821] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 7.043880] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 7.044935] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(78) set 1
[ 7.048184] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
[ 7.049375] E:camsys_i2c_write(78): i2c write dev(addr:0x6c) failed!
[ 7.049484] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(78) set 0
[ 7.049497] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 7.049520] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 7.050600] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.050634] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.052697] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x2000000) is deregister success
[ 7.052713] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.052723] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.052730] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.052737] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.061501] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.061513] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.061521] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.061621] D1:camsys_extdev_register(243): Get RK30_PIN3_PB4(108) gpio(active: 1) for dev_id 0x4000000 success!
[ 7.061634] D1:camsys_extdev_register(243): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x4000000 success!
[ 7.061644] D1:camsys_extdev_register(243): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x4000000 success!
[ 7.061653] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_dvp10bit
[ 7.061746] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV5640) register success
[ 7.066781] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.066790] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.066896] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.066922] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 24000000Hz) turn on
[ 7.067984] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(11) set 1
[ 7.069046] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(79) set 1
[ 7.070103] D1:camsys_sysctl_extdev(364): Sysctl 7 success, gpio(108) set 0
[ 7.073323] E:camsys_i2c_write(78): i2c write dev(addr:0x78) failed!
[ 7.073394] D1:camsys_sysctl_extdev(360): Sysctl 7 success, gpio(108) set 1
[ 7.073406] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(79) set 0
[ 7.073418] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(11) set 0
[ 7.074511] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.074544] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.076609] D1:camsys_extdev_deregister(331): Extdev(dev_id: 0x4000000) is deregister success
[ 7.076624] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.076635] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.076643] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.076650] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.080932] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.080943] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 7.080951] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 7.081033] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: default
[ 7.081061] D1:camsys_extdev_register(268): Extdev(dev_id: 0x1000000 dev_name: TC358749XBG) register success
[ 7.086100] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
[ 7.086110] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 7.086215] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 7.086240] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 27000000Hz) turn on
[ 7.087299] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 7.088351] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 7.089410] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 7.092759] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
[ 7.092770] E:camsys_sysctl_extdev(367): Sysctl 8 failed, because gpio is NULL!
[ 7.092777] E:camsys_sysctl_extdev(367): Sysctl 11 failed, because gpio is NULL!
[ 7.093861] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 7.093887] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
[ 7.095939] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 7.095950] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.095956] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 7.095963] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
[ 7.097943] type=1400 audit(1293889346.160:3): avc: denied { execute } for pid=492 comm=“mediaserver” name=“sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.098116] type=1400 audit(1293889346.160:4): avc: denied { read open } for pid=492 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.098212] type=1400 audit(1293889346.160:5): avc: denied { execute_no_trans } for pid=492 comm=“mediaserver” path=“/system/bin/sh” dev=“mmcblk0p10” ino=321 scontext=u:r:mediaserver:s0 tcontext=u:object_r:shell_exec:s0 tclass=file permissive=1
[ 7.100227] type=1400 audit(1293889346.170:6): avc: denied { getattr } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100321] type=1400 audit(1293889346.170:7): avc: denied { execute } for pid=492 comm=“sh” name=“toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100393] type=1400 audit(1293889346.170:8): avc: denied { read open } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 7.100464] type=1400 audit(1293889346.170:9): avc: denied { execute_no_trans } for pid=492 comm=“sh” path=“/system/bin/toolbox” dev=“mmcblk0p10” ino=336 scontext=u:r:mediaserver:s0 tcontext=u:object_r:toolbox_exec:s0 tclass=file permissive=1
[ 8.331945] healthd: battery none chg=
[ 8.514394] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
[ 8.514408] lowmemorykiller: oom_adj 0 => oom_score_adj 0
[ 8.514414] lowmemorykiller: oom_adj 1 => oom_score_adj 58
[ 8.514420] lowmemorykiller: oom_adj 2 => oom_score_adj 117
[ 8.514425] lowmemorykiller: oom_adj 3 => oom_score_adj 176
[ 8.514430] lowmemorykiller: oom_adj 9 => oom_score_adj 529
[ 8.514436] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
[ 8.875598] acc_open
[ 8.875617] acc_release
[ 9.031537] phy_power_on: enable = 1
[ 9.070933] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
[ 9.070962] eth0: device MAC address 4a:09:e2:8b:32:4f
[ 9.074998] libphy: stmmac: probed
[ 9.075010] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active
[ 9.075017] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active
[ 9.538600] [otg id chg] last id -1 current id 1
[ 9.538627] PortPower off
[ 9.538637] rk_battery_charger_detect_cb , battery_charger_detect 6
[ 9.664456] Using Buffer DMA mode
[ 9.664474] Periodic Transfer Interrupt Enhancement - disabled
[ 9.664480] Multiprocessor Interrupt Enhancement - disabled
[ 9.664487] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 9.664493] ^^^^^^^^^^^^^^^^^Device Mode
[ 9.716265] es8323_mic_state_ctrl read: 0
[ 9.716287] mic_state_switch 0
[ 9.716294] hp_det = 0,insert hp
[ 9.716299] hp mic use intern
[ 10.072988] pm policy 0 → 1
[ 10.148682] vbus detect**
[ 10.150877] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 10.347518] Using Buffer DMA mode
[ 10.347544] Periodic Transfer Interrupt Enhancement - disabled
[ 10.347551] Multiprocessor Interrupt Enhancement - disabled
[ 10.347558] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 10.347564] ^^^^^^^^^^^^^^^^^Device Mode
[ 10.347604] soft connect!!!
[ 10.470312] USB RESET
[ 10.527379] android_work: sent uevent USB_STATE=CONNECTED
[ 10.532064] USB RESET
[ 10.620587] android_usb gadget: high-speed config #1: android
[ 10.620769] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.678527] type=1400 audit(1293889350.820:10): avc: denied { write } for pid=497 comm=“Binder_1” name=“rotation_flag” dev=“mmcblk0p13” ino=15 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[ 11.678791] type=1400 audit(1293889350.820:11): avc: denied { open } for pid=497 comm=“Binder_1” path=“/data/rotation_flag” dev=“mmcblk0p13” ino=15 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=file permissive=1
[ 11.684100] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.684117] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
[ 11.684125] D1:camsys_open(739): camsys_marvin(ddf19410) is opened!
[ 11.684495] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000 Hz) in turn on
[ 11.684508] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.684615] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.684625] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.685325] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
[ 11.687384] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
[ 11.688078] type=1400 audit(1293889350.830:12): avc: denied { write } for pid=1057 comm=“Binder_1” name=“/” dev=“mmcblk0p13” ino=2 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688450] type=1400 audit(1293889350.830:13): avc: denied { remove_name } for pid=1057 comm=“Binder_1” name=“vpumem_observer” dev=“mmcblk0p13” ino=16 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688543] type=1400 audit(1293889350.830:14): avc: denied { unlink } for pid=1057 comm=“Binder_1” name=“vpumem_observer” dev=“mmcblk0p13” ino=16 scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
[ 11.688650] type=1400 audit(1293889350.830:15): avc: denied { add_name } for pid=1057 comm=“Binder_1” name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=dir permissive=1
[ 11.688920] type=1400 audit(1293889350.830:16): avc: denied { create } for pid=1057 comm=“Binder_1” name=“vpumem_observer” scontext=u:r:mediaserver:s0 tcontext=u:object_r:system_data_file:s0 tclass=sock_file permissive=1
[ 11.972740] D1:camsys_mrv_iommu_cb(276): map fd 46 ,client fd 34
[ 11.972740]
[ 11.972780] rk_iommu ff914000.isp_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab1000
[ 11.974899] D1:camsys_mrv_iommu_cb(276): map fd 48 ,client fd 34
[ 11.974899]
[ 11.974919] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.977015] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 34
[ 11.977015]
[ 11.977034] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.979134] D1:camsys_mrv_iommu_cb(276): map fd 50 ,client fd 34
[ 11.979134]
[ 11.979151] rk_iommu ff914000.isp_mmu: (isp_mmu) Already enabled
[ 11.979809] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
[ 11.979822] W:camsys_phy_ops(478): mipiphy->phy_index(-1191300724) != extdev->phy.info.mipi.phy_index(0)!
[ 11.980032] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(0) turn on(lane: 0xf bit_rate: 648Mbps)
[ 12.093366] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
[ 12.093894] D1:camsys_mrv_iommu_cb(276): map fd 50 ,client fd 34
[ 12.093894]
[ 12.093997] rk_iommu ff914000.isp_mmu: (isp_mmu) 3 times left to be disabled
[ 12.094008] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 1eab1000 delayed
[ 12.094283] D1:camsys_mrv_iommu_cb(276): map fd 49 ,client fd 34
[ 12.094283]
[ 12.094380] rk_iommu ff914000.isp_mmu: (isp_mmu) 2 times left to be disabled
[ 12.094389] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 1eab1000 delayed
[ 12.094635] D1:camsys_mrv_iommu_cb(276): map fd 48 ,client fd 34
[ 12.094635]
[ 12.094732] rk_iommu ff914000.isp_mmu: (isp_mmu) 1 times left to be disabled
[ 12.094741] rk_iommu ff914000.isp_mmu: rockchip_iommu_detach_device: Detaching IOMMU with pgtable 1eab1000 delayed
[ 12.094967] D1:camsys_mrv_iommu_cb(276): map fd 46 ,client fd 34
[ 12.094967]
[ 13.663621] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
[ 13.663670] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
[ 13.663681] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.663689] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
[ 13.663698] D1:camsys_release(763): camsys_marvin(ddf19410) is closed
3894]
[ 12.094283]
[ 12.094635]
[ 12.094967]
您好,我也遇到这方面问题,您解决了吗?
