哪位好心朋友帮我看一个问题,十分感谢
Connecting to COM3…
Connected.
DDR Version 1.05 20170712
SRX
Channel a: DDR3 400MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=8 Size=2048MB
Channel b: DDR3 400MHz
Boot1 Release Time: 2017-06-15, version: 2.33
ChipType = 0x8, 178
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=29820MB
FwPartOffset=2000 , 2000
SdmmcInit=0 400
StorageInit ok = 29353
Code check OK! theLoader 0x0, 48145
Code check OK! theLoader 0x8400000, 77828
Enter Trust OS
INF [0x0] TEE-CORE:init_primary_helper:366: Initializing (1.1.0-211-g897ad0f-dev #67 Tue Aug 8 07:55:21 UTC 2017 arm)
INF [0x0] TEE-CORE:init_primary_helper:367: Release version: 1.2
U-Boot 2014.10-RK3288-06-g71a1f41-dirty (Sep 28 2017 - 15:01:10)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 816000000HZ
periph pll = 297000000HZ
ddr pll = 396000000HZ
codec pll = 384000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x00e00000
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059bbdcc
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059bbfcc
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059cbbcc
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059cbdcc
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm0
#Boot ver: 2017-09-28#2.33
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find phy node
no fuel gauge found
ERROR: v7_dcache_inval_range - start address is not aligned - 0x05738160
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x05738360
Using display timing dts
Detailed mode clock 65000 kHz, flags[a]
H: 1024 1105 1115 1195
V: 0600 0621 0624 0645
bus_format: 100e
pll_src = 0, dclk_hz = 65000000, dclk_div = 6
rockchip_phy_power_on: failed to find phy power on funcs
failed to wait for phy clk lane stop state
ERROR: v7_dcache_inval_range - start address is not aligned - 0x05738a68
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x05738c68
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x02000000 (0x007f36a0)
ramdisk @ 0x05bf0000 (0x0016e424)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 05611b93 … OK
Add bank:0000000000000000, 0000000008400000
Add bank:0000000009200000, 00000000f4e00000
[ 0.000000] Linux version 4.4.77 (zw_ye@zwqx-mobile-pc) (gcc version 4.9 20150123 (prerelease) (GCC) ) #65 SMP PREEMPT Wed Oct 11 20:17:06 CST 2017
[ 0.000000] Machine model: rockchip,rk3288-evb-android-rk818
[ 0.000000] earlycon: Early serial console at MMIO32 0xff690000 (options ‘’)
[ 0.000000] cma: Reserved 16 MiB at 0xfd000000
[ 0.000000] psci: PSCIv65535.65535 detected in firmware.
[ 0.000000] PERCPU: Embedded 13 pages/cpu @de7c7000 s24192 r8192 d20864 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1035760
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff690000 vmalloc=496M console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00400000@0x000B4000(system),0x00008000@0x004B4000(metadata),0x00019000@0x004BC000(vendor0),0x00019000@0x004D5000(vendor1),-@0x004EE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xfbc00000 loader.timestamp=2017-09-28_15:01:10 SecureBootCheckOk=0
[ 0.000000] Memory: 4075136K/4147200K available (11264K kernel code, 908K rwdata, 3956K rodata, 1024K init, 896K bss, 55680K reserved, 16384K cma-reserved, 3612008K highmem)
[ 0.000000] vmalloc : 0xe1000000 - 0xff800000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0800000 ( 520 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0c00000 (12256 kB)
[ 0.000000] .init : 0xc1100000 - 0xc1200000 (1024 kB)
[ 0.000000] .data : 0xc1200000 - 0xc12e335c ( 909 kB)
[ 0.000000] .bss : 0xc12e5000 - 0xc13c52fc ( 897 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] L2C: failed to init: -19
[ 0.008535] Switching to timer-based delay loop, resolution 41ns
[ 0.016009] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.027013] pid_max: default: 32768 minimum: 301
[ 0.032014] Security Framework initialized
[ 0.036356] SELinux: Initializing.
[ 0.040134] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.047165] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.055196] Initializing cgroup subsys freezer
[ 0.059935] Initializing cgroup subsys debug
[ 0.064489] CPU: Testing write buffer coherency: ok
[ 0.069963] CPU0: update cpu_capacity 430
[ 0.074284] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.080397] Setting up static identity map for 0x100000 - 0x100058
[ 0.117419] CPU1: update cpu_capacity 430
[ 0.117424] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.127448] CPU2: update cpu_capacity 430
[ 0.127453] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.137487] CPU3: update cpu_capacity 430
[ 0.137492] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.137558] Brought up 4 CPUs
[ 0.171880] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.178575] CPU: All CPU(s) started in SVC mode.
[ 0.184620] devtmpfs: initialized
[ 0.201185] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.209669] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.220116] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.227328] pinctrl core: initialized pinctrl subsystem
[ 0.233650] NET: Registered protocol family 16
[ 0.239880] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.260684] cpuidle: using governor ladder
[ 0.278403] cpuidle: using governor menu
[ 0.282620] Registered FIQ tty driver
[ 0.308968] console [pstore-1] enabled
[ 0.313186] pstore: Registered ramoops as persistent store backend
[ 0.319837] ramoops: attached 0xf0000@0x8000000, ecc: 0/0
[ 0.326787] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.335233] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.341868] fiq debugger fiq mode enabled
[ 0.346451] console [ttyFIQ0] enabled
[[ 0.346451] console [ttyFIQ0] enabled
[ 0.353659] bootconsole [uart0] disabled
[ 0.365560] Registered fiq debugger ttyFIQ0
[ 0.415391] iommu: Adding device ff900000.iep to group 0
[ 0.415481] iommu: Adding device ff910000.isp to group 1
[ 0.415586] iommu: Adding device ff930000.vop to group 2
[ 0.415662] iommu: Adding device ff940000.vop to group 3
[ 0.415738] iommu: Adding device ff9a0000.vpu-service to group 4
[ 0.415814] iommu: Adding device ff9c0000.hevc-service to group 5
[ 0.416128] rk_iommu ff900800.iommu: can’t get aclk
[ 0.416145] rk_iommu ff900800.iommu: can’t get hclk
[ 0.417386] SCSI subsystem initialized
[ 0.417596] usbcore: registered new interface driver usbfs
[ 0.417653] usbcore: registered new interface driver hub
[ 0.417720] usbcore: registered new device driver usb
[ 0.418053] rk3288-dwc-control-usb ff770284.dwc-control-usb: host_drv_gpio is not specified or invalid
[ 0.419016] media: Linux media interface: v0.10
[ 0.419070] Linux video capture interface: v2.00
[ 0.419216] pps_core: LinuxPPS API ver. 1 registered
[ 0.419227] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.419255] PTP clock support registered
[ 0.420419] Advanced Linux Sound Architecture Driver Initialized.
[ 0.420928] Bluetooth: Core ver 2.21
[ 0.420977] NET: Registered protocol family 31
[ 0.420988] Bluetooth: HCI device and connection manager initialized
[ 0.421004] Bluetooth: HCI socket layer initialized
[ 0.421017] Bluetooth: L2CAP socket layer initialized
[ 0.421047] Bluetooth: SCO socket layer initialized
[ 0.421991] rockchip-cpuinfo cpuinfo: Serial : 73fd8c97869e178f
[ 0.422853] clocksource: Switched to clocksource arch_sys_counter
[ 0.464059] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.464303] NET: Registered protocol family 2
[ 0.464794] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.464838] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.464910] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.464959] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.464984] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.465126] NET: Registered protocol family 1
[ 0.465562] Trying to unpack rootfs image as initramfs…
[ 0.515244] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.547102] Freeing initrd memory: 1468K (c5bf0000 - c5d5f000)
[ 0.547976] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[ 0.550555] audit: initializing netlink subsys (disabled)
[ 0.550610] audit: type=2000 audit(0.423:1): initialized
[ 0.555487] VFS: Disk quotas dquot_6.6.0
[ 0.555612] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.556601] Registering sdcardfs 0.1
[ 0.556853] fuse init (API version 7.23)
[ 0.558053]
[ 0.558053] TEE Core Framework initialization (ver 1:0.1)
[ 0.558085] TEE armv7 Driver initialization
[ 0.558379] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.558394] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.558572] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.562120] bounce: pool size: 64 pages
[ 0.562255] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.562276] io scheduler noop registered
[ 0.562291] io scheduler deadline registered
[ 0.562328] io scheduler cfq registered (default)
[ 0.562621] rockchip-usb-phy ff770000.syscon:usbphy: vbus_drv is not assigned!
[ 0.564911] backlight supply power not found, using dummy regulator
[ 0.565231] iep: failed to find iep power down clock source.
[ 0.565573] IEP Power ON
[ 0.565728] IEP Power OFF
[ 0.565788] IEP Driver loaded succesfully
[ 0.565899] Module initialized.
[ 0.566344] rk-vcodec ff9a0000.vpu-service: probe device
[ 0.566400] rk-vcodec ff9a0000.vpu-service: vpu mmu dec de2b6610
[ 0.566537] rk-vcodec ff9a0000.vpu-service: allocator is drm
[ 0.566589] rk-vcodec ff9a0000.vpu-service: checking hw id 4831
[ 0.567013] rk-vcodec ff9a0000.vpu-service: init success
[ 0.567444] rk-vcodec ff9c0000.hevc-service: probe device
[ 0.567498] rk-vcodec ff9c0000.hevc-service: vpu mmu dec de2b6a10
[ 0.567640] rk-vcodec ff9c0000.hevc-service: allocator is drm
[ 0.567697] rk-vcodec ff9c0000.hevc-service: checking hw id 6867
[ 0.568005] rk-vcodec ff9c0000.hevc-service: init success
[ 0.569548] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.569568] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.570126] dma-pl330 ff600000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.570145] dma-pl330 ff600000.dma-controller: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.571029] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.572385] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A
[ 0.572802] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.573808] dw-mipi-dsi ff960000.dsi: no reset control specified
[ 0.575681] rockchip-vop ff930000.vop: invalid resource
[ 0.575698] rockchip-vop ff930000.vop: failed to get vop cabc lut registers
[ 0.576368] rockchip-drm display-subsystem: bound ff930000.vop (ops vop_component_ops)
[ 0.576420] rockchip-vop ff940000.vop: invalid resource
[ 0.576433] rockchip-vop ff940000.vop: failed to get vop cabc lut registers
[ 0.577042] rockchip-drm display-subsystem: bound ff940000.vop (ops vop_component_ops)
[ 0.577245] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[ 0.577265] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.577331] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.00a with HDCP (DWC MHL PHY)
[ 0.577913] rockchip-drm display-subsystem: bound ff980000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.577941] rockchip-drm display-subsystem: failed to bind ff960000.dsi (ops dw_mipi_dsi_ops): -517
[ 0.578560] rockchip-drm display-subsystem: master bind failed: -517
[ 0.580392] mali ffa30000.gpu: Failed to get regulator
[ 0.580407] mali ffa30000.gpu: Power control initialization failed
[ 0.603232] brd: module loaded
[ 0.607957] loop: module loaded
[ 0.608496] zram: Added device: zram0
[ 0.608999] SCSI Media Changer driver v0.25
[ 0.609445] tun: Universal TUN/TAP device driver, 1.6
[ 0.609457] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.610338] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[ 0.610357] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[ 0.610370] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[ 0.610493] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[ 0.610506] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[ 0.615575] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.615585] Ring mode enabled
[ 0.615593] DMA HW capability register supported
[ 0.615601] Normal descriptors
[ 0.615610] RX Checksum Offload Engine supported (type 2)
[ 0.615618] TX Checksum insertion supported
[ 0.615626] Wake-Up On Lan supported
[ 0.615672] Enable RX Mitigation via HW Watchdog Timer
[ 0.683629] libphy: stmmac: probed
[ 0.683646] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 0.683659] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 0.684375] PPP generic driver version 2.4.2
[ 0.684570] PPP BSD Compression module registered
[ 0.684587] PPP Deflate Compression module registered
[ 0.684616] PPP MPPE Compression module registered
[ 0.684636] NET: Registered protocol family 24
[ 0.684681] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.684692] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.684711] Rockchip WiFi SYS interface (V1.00) …
[ 0.684807] usbcore: registered new interface driver catc
[ 0.684861] usbcore: registered new interface driver kaweth
[ 0.684878] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.684924] usbcore: registered new interface driver pegasus
[ 0.684975] usbcore: registered new interface driver rtl8150
[ 0.685033] usbcore: registered new interface driver r8152
[ 0.685049] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.685120] usbcore: registered new interface driver hso
[ 0.685179] usbcore: registered new interface driver asix
[ 0.685232] usbcore: registered new interface driver ax88179_178a
[ 0.685283] usbcore: registered new interface driver cdc_ether
[ 0.685334] usbcore: registered new interface driver cdc_eem
[ 0.685384] usbcore: registered new interface driver dm9601
[ 0.685452] usbcore: registered new interface driver smsc75xx
[ 0.685517] usbcore: registered new interface driver smsc95xx
[ 0.685570] usbcore: registered new interface driver gl620a
[ 0.685623] usbcore: registered new interface driver net1080
[ 0.685673] usbcore: registered new interface driver plusb
[ 0.685722] usbcore: registered new interface driver rndis_host
[ 0.685776] usbcore: registered new interface driver cdc_subset
[ 0.685827] usbcore: registered new interface driver zaurus
[ 0.685881] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.685953] usbcore: registered new interface driver int51x1
[ 0.686005] usbcore: registered new interface driver kalmia
[ 0.686055] usbcore: registered new interface driver ipheth
[ 0.686108] usbcore: registered new interface driver sierra_net
[ 0.686159] usbcore: registered new interface driver cx82310_eth
[ 0.686248] usbcore: registered new interface driver cdc_ncm
[ 0.686303] usbcore: registered new interface driver qmi_wwan
[ 0.686359] usbcore: registered new interface driver cdc_mbim
[ 0.686567] ff540000.usb supply vusb_d not found, using dummy regulator
[ 0.686641] ff540000.usb supply vusb_a not found, using dummy regulator
[ 0.793062] dwc2 ff540000.usb: DWC OTG Controller
[ 0.793095] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[ 0.793126] dwc2 ff540000.usb: irq 43, io mem 0x00000000
[ 0.793347] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.793364] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.793377] usb usb1: Product: DWC OTG Controller
[ 0.793388] usb usb1: Manufacturer: Linux 4.4.77 dwc2_hsotg
[ 0.793400] usb usb1: SerialNumber: ff540000.usb
[ 0.793888] hub 1-0:1.0: USB hub found
[ 0.793929] hub 1-0:1.0: 1 port detected
[ 0.794518] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.794539] ehci-platform: EHCI generic platform driver
[ 0.794736] ehci-platform ff500000.usb: EHCI Host Controller
[ 0.794765] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 2
[ 0.794912] ehci-platform ff500000.usb: irq 41, io mem 0xff500000
[ 0.802887] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[ 0.803030] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.803045] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.803058] usb usb2: Product: EHCI Host Controller
[ 0.803069] usb usb2: Manufacturer: Linux 4.4.77 ehci_hcd
[ 0.803080] usb usb2: SerialNumber: ff500000.usb
[ 0.803522] hub 2-0:1.0: USB hub found
[ 0.803566] hub 2-0:1.0: 1 port detected
[ 0.804012] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.804043] ohci-platform: OHCI generic platform driver
[ 0.804317] usbcore: registered new interface driver cdc_acm
[ 0.804329] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.804400] usbcore: registered new interface driver usblp
[ 0.804456] usbcore: registered new interface driver cdc_wdm
[ 0.804547] usbcore: registered new interface driver usb-storage
[ 0.804600] usbcore: registered new interface driver ums-alauda
[ 0.804651] usbcore: registered new interface driver ums-cypress
[ 0.804701] usbcore: registered new interface driver ums-datafab
[ 0.804750] usbcore: registered new interface driver ums-freecom
[ 0.804801] usbcore: registered new interface driver ums-isd200
[ 0.804850] usbcore: registered new interface driver ums-jumpshot
[ 0.804899] usbcore: registered new interface driver ums-karma
[ 0.804949] usbcore: registered new interface driver ums-onetouch
[ 0.805000] usbcore: registered new interface driver ums-sddr09
[ 0.805055] usbcore: registered new interface driver ums-sddr55
[ 0.805110] usbcore: registered new interface driver ums-usbat
[ 0.805206] usbcore: registered new interface driver usbserial
[ 0.805250] usbcore: registered new interface driver usbserial_generic
[ 0.805285] usbserial: USB Serial support registered for generic
[ 0.805340] usbcore: registered new interface driver option
[ 0.805374] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.805491] usbcore: registered new interface driver trancevibrator
[ 0.805509] usb20_otg: version 3.10a 21-DEC-2012
[ 0.805793] e1400040
[ 0.805804] Core Release: 3.10a
[ 0.805817] Setting default values for core params
[ 0.806002] Using Buffer DMA mode
[ 0.806012] Periodic Transfer Interrupt Enhancement - disabled
[ 0.806021] Multiprocessor Interrupt Enhancement - disabled
[ 0.806031] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.806040] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.806051] Dedicated Tx FIFOs mode
[ 0.806068] pcd_init otg_dev = ddb4e500
[ 0.806343] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.806373] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 3
[ 0.806402] usb20_otg ff580000.usb: irq 44, io mem 0x00000000
[ 0.806545] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.806561] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.806574] usb usb3: Product: DWC OTG Controller
[ 0.806585] usb usb3: Manufacturer: Linux 4.4.77 dwc_otg_hcd
[ 0.806596] usb usb3: SerialNumber: ff580000.usb
[ 0.807062] hub 3-0:1.0: USB hub found
[ 0.807100] hub 3-0:1.0: 1 port detected
[ 0.807611] usb20_host: version 3.10a 21-DEC-2012
[ 0.808173] usbcore: registered new interface driver xpad
[ 0.808227] Initial gslx680 Touch Driver
[ 0.808300] zwqx goodix_ts_init–
[ 0.808593] .. rk pwm remotectl v1.1 init
[ 0.808653] remotectl: remote pwm id=0x0
[ 0.808663] remotectl: handle cpu id=0x1
[ 0.808674] remotectl probe j = 0x0
[ 0.808849] input: ff680000.pwm as /devices/platform/ff680000.pwm/input/input0
[ 0.809176] sensor_register_slave:mma8452,id=17
[ 0.809196] sensor_register_slave:lis3dh,id=7
[ 0.809212] sensor_register_slave:mma7660,id=18
[ 0.809227] sensor_register_slave:lsm303d,id=22
[ 0.809241] sensor_register_slave:mpu6880_acc,id=24
[ 0.809255] sensor_register_slave:mpu6500_acc,id=25
[ 0.809270] sensor_register_slave:lsm330_acc,id=26
[ 0.809285] sensor_register_slave:akm8975,id=28
[ 0.809300] sensor_register_slave:akm8963,id=29
[ 0.809315] sensor_register_slave:l3g4200d,id=43
[ 0.809329] sensor_register_slave:l3g20d,id=44
[ 0.809343] sensor_register_slave:ewtsa,id=45
[ 0.809357] sensor_register_slave:lsm330_gyro,id=48
[ 0.809371] sensor_register_slave:cm3217,id=50
[ 0.809386] sensor_register_slave:cm3218,id=51
[ 0.810112] i2c /dev entries driver
[ 0.811136] rk808 0-001b: Pmic Chip id: 0x0
[ 0.813978] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.814039] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.814120] DCDC_REG1: supplied by vcc_sys
[ 0.814676] DCDC_REG2: supplied by vcc_sys
[ 0.815168] DCDC_REG3: supplied by vcc_sys
[ 0.815397] DCDC_REG4: supplied by vcc_sys
[ 0.815733] vcc_lcd: supplied by vcc_io
[ 0.815842] LDO_REG1: supplied by vcc_sys
[ 0.816877] LDO_REG2: supplied by vcc_sys
[ 0.817786] LDO_REG3: supplied by vcc_sys
[ 0.818670] LDO_REG4: supplied by vcc_io
[ 0.819578] LDO_REG5: supplied by vcc_io
[ 0.820465] LDO_REG6: supplied by vcc_io
[ 0.821361] LDO_REG7: supplied by vcc_sys
[ 0.822281] LDO_REG8: supplied by vcc_sys
[ 0.823150] SWITCH_REG1: supplied by vcc_18
[ 0.823344] SWITCH_REG2: supplied by vcc_io
[ 0.826359] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 0.826831] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at e12d6000
[ 0.827393] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at e12d8000
[ 0.827807] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at e12da000
[ 0.828692] input: gsl3673 as /devices/platform/ff160000.i2c/i2c-4/4-0040/input/input1
[ 0.886255] gsl3673 4-0040: GSL3673 test_i2c error!
[ 0.886271] gsl3673 4-0040: gsl_probe: init_chip failed
[ 0.899641] gsl3673: probe of 4-0040 failed with error -1
[ 0.899780] goodix_ts_probe() start
[ 0.899809] 4-005d supply tp not found, using dummy regulator
[ 0.906255] dwc_otg_hcd_suspend, usb device mode
[ 1.036367] input: goodix-ts as /devices/platform/ff160000.i2c/i2c-4/4-005d/input/input2
[ 1.036782] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at e12dc000
[ 1.037379] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at e12de000
[ 1.038174] IR NEC protocol handler initialized
[ 1.038191] IR RC5(x/sz) protocol handler initialized
[ 1.038204] IR RC6 protocol handler initialized
[ 1.038217] IR JVC protocol handler initialized
[ 1.038229] IR Sony protocol handler initialized
[ 1.038242] IR SANYO protocol handler initialized
[ 1.038254] IR Sharp protocol handler initialized
[ 1.038267] IR MCE Keyboard/mouse protocol handler initialized
[ 1.038280] IR XMP protocol handler initialized
[ 1.038373] usbcore: registered new interface driver uvcvideo
[ 1.038384] USB Video Class driver (1.1.1)
[ 1.038403] CamSys driver version: v0.34.2, CamSys head file version: v0.13.0
[ 1.040810] test_power_init: could not find dev node
[ 1.040881] come in 10.7。。。。我在设备树中添加了&pwm0 对应驱动probe进去了,但打印信息里面显示can’t find dts node for pwm0
