U-Boot使用DTS共享配置应用实例
设备树(DTS)的引入减少了内核为支持新硬件而需要的改变,提高代码重用,使得单个内核镜像能支持多个系统。
DTS作为U-Boot 和Linux 内核之间的动态接口,能够有效减少重复配置,共享于U-Boot 和Linux之间。本文将简单介绍U-Boot使用DTS控制LED的例子:
1.在kernel/arch/arm/boot/dts/rk3288-box.dts中添加LED配置:
------------------- kernel/arch/arm/boot/dts/rk3288-box.dts -------------------
index e102714..80928ba 100755
@@ -137,6 +136,16 @@
                 rockchip,remote_wakeup;
                 rockchip,usb_irq_wakeup;
+        leds {
+                compatible = "gpio-leds";
+                power {
+                        label = "tchip:blue:power";
+                        default-state = "on";
+                        gpios = <&gpio8 GPIO_A3 GPIO_ACTIVE_LOW>;
 &gmac {
以上是linux标准的GPIO-LED配置,直接配置上内核就可使用LED。
2.修改U-Boot,以支持读取DTS配置并操作LED灯,修改u-boot/board/rockchip/rk32xx/rk32xx.c:
-------------------- u-boot/board/rockchip/rk32xx/rk32xx.c --------------------
index bfdcf0e..29fff0f 100755
@@ -61,12 +61,34 @@ void board_lmb_reserve(struct lmb *lmb) {
         //reserve 48M for kernel & 8M for nand api.
         lmb_reserve(lmb, gd->bd->bi_dram[0].start, CONFIG_LMB_RESERVE_SIZE);
+static struct fdt_gpio_state power_led_gpio;
+int power_led_parse_dt(const void *blob)
+        int led_node = 0;
+        int node = 0;
+        node = fdt_node_offset_by_compatible(blob,
+                                        0, "gpio-leds");
+        if (node < 0) {
+                printf("can't find dts node for led\n");
+                return -ENODEV;
+        led_node = fdt_subnode_offset(blob, node, "power");
+        fdtdec_decode_gpio(blob, led_node, "gpios", &power_led_gpio);
+        power_led_gpio.gpio = rk_gpio_base_to_bank(power_led_gpio.gpio & RK_GPIO_BANK_MASK) | (power_led_gpio.gpio & RK_GPIO_PIN_MASK);
+        power_led_gpio.flags = !(power_led_gpio.flags  & OF_GPIO_ACTIVE_LOW);
+        debug("power_led_gpio: %s,%d-%d\n", power_led_gpio.name, power_led_gpio.gpio, power_led_gpio.flags);
+        return 0;
 #endif /* CONFIG_OF_LIBFDT */
 #ifdef CONFIG_RK_FB
 #ifdef CONFIG_OF_LIBFDT
 static struct fdt_gpio_state lcd_en_gpio, lcd_cs_gpio;
 static int lcd_en_delay, lcd_cs_delay;
 static int lcd_node = 0;
@@ -114,7 +136,6 @@ void rk_backlight_ctrl(int brightness)
 void rk_fb_init(unsigned int onoff)
         if (lcd_node == 0) rk_lcd_parse_dt(gd->fdt_blob);
@@ -178,6 +199,17 @@ void init_panel_info(vidinfo_t *vid)
         vid->logo_rgb_mode = RGB565;
+void power_led_init(void)
+        printf("Enter power_led_init\n");
+#ifdef CONFIG_OF_LIBFDT
+        power_led_parse_dt(gd->fdt_blob);
+        if (power_led_gpio.name!=NULL)
+                gpio_direction_output(power_led_gpio.gpio, power_led_gpio.flags);
+#endif
 #ifdef CONFIG_RK616
 int rk616_power_on(void)
@@ -259,6 +291,9 @@ int board_late_init(void)
         load_disk_partitions();
         prepare_fdt();
         key_init();
+        power_led_init();
 #ifdef CONFIG_POWER_RK
         pmic_init(0);
         fg_init(0); /*fuel gauge init*/
3.编译内核,参考Wiki<http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_kernel>中的编译内核映像部分
4.编译U-Boot,参考SDK下的“RKDocs/common/uboot/RockChip_Uboot开发文档V1.0.pdf”文档,编译生成RK3288Loader_uboot_V2.15.bin
5.烧写resource.img和RK3288Loader_uboot_V2.15.bin,开机。有没有发现LED灯比原来的快差不多两秒点亮呢{:3_48:}
查了一下kernel/arch/arm/boot/dts/Makefile文件,发现:
dtb-$(CONFIG_ARCH_ROCKCHIP) += rk3188-tb.dtb
也就是选择ROCKCHIP平台,编译的是 rk3188-tb.dtb,并没有编译rk3288-box.dts文件啊
请问UBOOT代码在那个目录下面,没有找到。
在SDK下的u-boot/目录下
没有这个目录.
看看这个链接:
https://bitbucket.org/T-Firefly/firefly-rk3288/src/e509c77e5e414d270f419a3bf275e6984cda977a/u-boot/?at=master
U-BOOT用的DTS文件和kernel用的是一样的吗?路径是kernel/arch/arm/boot/dts/rk3288-box.dts。为什么找不到UBOOT的DTS
是一样的
支持一个
rk_gpio_base_to_bank函数运行出错,提示的是rk_gpio_base_to_id error …?
这个该怎么解决啊?版主可否教一下。
对了,忘了说一个信息了,我的uboot编译生成的是RK3288Loader_uboot_V2.17.02.bin不是V2.15的。
可以的,大佬
