MIPI 屏调试 点不亮,请高手指教
MIPI 屏调试 点不亮,我示波器中看到初始化代码发出后MIPI通道就停止运作了。 没有发画面。,请高手指教,谢i谢!
我按WIKI中的指示,修改和编译了KERNEL
在arch/arm/configs/firefly-rk3288_defconfig添加配置:
CONFIG_LCD_MIPI=yCONFIG_MIPI_DSI=yCONFIG_RK32_MIPI_DSI=y/kernel/arch/arm/boot/dts/rk3288.dtsi配置&dsihost0 { status = “okay”;};
./kernel/arch/arm/boot/dts/下新增LCD_XXX_MIPI.DTSI ,/kernel/arch/arm/boot/dts/firefly-rk3288.dts中加上参考
开机记录中显示FB0 CHECK_var fail: 2具体开机记录如下
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Nov 26 2014 - 09:28:44)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 300000000HZ
ddr pll = 200000000HZ
codec pll = 594000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2014-11-26#2.17
sn:1006120000000232
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to load fdt from boot!
kernel @ 0x02000000 (0x005fb6a0)
ramdisk @ 0x04bf0000 (0x00120fad)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 04803000, end 0482741a … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (root@tatkei-VirtualBox) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #12 SMP PREEMPT Mon Mar 9 10:08:44 HKT 2015 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] hdmi init vic is -1 [ 0.000000] rockchip_ion_reserve [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ecd000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768 [ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-26_09:28:44 hdmi.vic=-1 androidboot.serialno=1006120000000232 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 2046956k/2046956k available, 50196k reserved, 1318912K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0a7af40 (10700 kB) [ 0.000000] .init : 0xc0a7b000 - 0xc0cca6c0 (2366 kB) [ 0.000000] .data : 0xc0ccc000 - 0xc0d69048 ( 629 kB) [ 0.000000] .bss : 0xc0d69048 - 0xc0e83e44 (1132 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 32 [ 0.000000] Architected local timer running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:0, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:1, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.529849] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.529901] pid_max: default: 32768 minimum: 301 [ 0.530239] Security Framework initialized [ 0.530280] SELinux: Initializing. [ 0.530508] Mount-cache hash table entries: 512 [ 0.532549] Initializing cgroup subsys debug [ 0.532594] Initializing cgroup subsys freezer [ 0.532684] CPU: Testing write buffer coherency: ok [ 0.533443] /cpus/cpu@0 missing clock-frequency property [ 0.533487] /cpus/cpu@1 missing clock-frequency property [ 0.533522] /cpus/cpu@2 missing clock-frequency property [ 0.533555] /cpus/cpu@3 missing clock-frequency property [ 0.533733] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.533846] Setting up static identity map for 0xc078e0a0 - 0xc078e0f8 [ 0.538210] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x14db (version 3.0) [ 0.616176] CPU1: Booted secondary processor [ 0.616269] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.635903] CPU2: Booted secondary processor [ 0.635986] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.655687] CPU3: Booted secondary processor [ 0.655769] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.656136] Brought up 4 CPUs [ 0.656235] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.656266] CPU: All CPU(s) started in SVC mode. [ 0.658513] devtmpfs: initialized [ 0.676305] pinctrl core: initialized pinctrl subsystem [ 0.677041] regulator-dummy: no parameters [ 0.678705] NET: Registered protocol family 16 [ 0.683964] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.684851] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e5f494 (version 0.1) [ 0.685362] Registered FIQ tty driver [ 0.688773] console [ttyFIQ0] enabled [ 0.689357] Registered fiq debugger ttyFIQ0 [ 0.691214] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.691302] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.691375] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.691445] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.691710] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.691944] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.692171] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.692395] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.692618] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.692841] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.693078] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.693309] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.693546] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.693781] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.693838] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.693890] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.693941] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.695766] rockchip_interrupts_register:bank_num=7 [ 0.702494] of_get_gpio_init_config:gpio[0] = 256, value = 0 [ 0.702579] of_get_gpio_init_config:gpio[1] = 233, value = 0 [ 0.702661] of_get_gpio_init_config:gpio[2] = 136, value = 0 [ 0.702874] rockchip_pinctrl_probe:init ok [ 0.723211] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.723565] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.723621] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.724246] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.724584] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.724637] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.725176] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.725497] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.725550] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.726096] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.726425] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.726478] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.727043] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.727421] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.727475] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.728019] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.728347] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.728400] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.729008] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.729379] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.729432] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.735962] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.736019] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.736641] DDR DEBUG: version 1.00 20140603 [ 0.736723] DDR DEBUG: Channel a: [ 0.736759] DDR DEBUG: DDR3 Device [ 0.736809] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.736851] DDR DEBUG: Channel b: [ 0.736882] DDR DEBUG: DDR3 Device [ 0.736928] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.736972] DDR DEBUG: addr=0xd6f000 [ 0.737012] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.737053] DDR DEBUG: socAddr[0]=0xd6f000, socAddr[1]=0xd6f100 [ 0.737094] DDR DEBUG: chAddr[0]=0xd6f000, chAddr[1]=0xd6f000 [ 0.737141] DDR DEBUG: dtar[0]=0x701ad000, dtar[1]=0x701ad000 [ 0.737302] DDR DEBUG: init success!!! freq=200MHz [ 0.737337] DDR DEBUG: Channel a: [ 0.737386] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.737445] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.737503] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.737562] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.737616] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.737659] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.737699] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.737733] DDR DEBUG: Channel b: [ 0.737780] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.737837] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.737895] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.737953] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738005] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.738048] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.738087] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.814846] bio: create slab at 0 [ 0.816734] Enter firefly_noatx8_init [ 0.817221] firefly_noatx8_probe 51 [ 0.817953] SCSI subsystem initialized [ 0.818454] usbcore: registered new interface driver usbfs [ 0.818611] usbcore: registered new interface driver hub [ 0.818904] usbcore: registered new device driver usb [ 0.821997] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.826483] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.827973] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.829459] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.830282] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.833263] media: Linux media interface: v0.10 [ 0.833411] Linux video capture interface: v2.00 [ 0.833569] pps_core: LinuxPPS API ver. 1 registered [ 0.833612] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.833693] PTP clock support registered [ 0.834146] rockchip_temp_probe,line=362 [ 0.834931] tsadc ff280000.tsadc: initialized [ 0.836200] rockchip_ion_parse_dt: num_heaps = 1 [ 0.836259] 0: 0 3 vmalloc 0x (null) [ 0.837074] Rockchip ion module is successfully loaded (v1.0) [ 0.837622] Advanced Linux Sound Architecture Driver Initialized. [ 0.838865] Bluetooth: Core ver 2.16 [ 0.838992] NET: Registered protocol family 31 [ 0.839033] Bluetooth: HCI device and connection manager initialized [ 0.839094] Bluetooth: HCI socket layer initialized [ 0.839144] Bluetooth: L2CAP socket layer initialized [ 0.839237] Bluetooth: SCO socket layer initialized [ 0.839905] cfg80211: Calling CRDA to update world regulatory domain [ 0.846328] act8846_i2c_probe,line=898 [ 0.847743] act8846_parse_dt,line=746 [ 0.851341] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.851414] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.851472] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1 [ 0.851529] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1 [ 0.854053] act_dcdc1: 1200 mV [ 0.857753] vccio: 3300 mV [ 0.860387] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 0.864122] act_dcdc4: 2000 mV [ 0.866009] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.868932] act_ldo2: 1050 mV [ 0.871803] act_ldo3: 1800 mV [ 0.874713] act_ldo4: 3300 mV [ 0.877580] act_ldo5: 3300 mV [ 0.880470] act_ldo6: 1100 mV [ 0.883358] vcc_18: 1800 mV [ 0.886315] act_ldo8: 1850 mV [ 0.893028] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.899583] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.900551] rk808_i2c_probe,line=1368 [ 0.902221] The device is not rk808 -11 [ 0.902495] rk808: probe of 0-001b failed with error -11 [ 0.906980] Switching to clocksource arch_sys_counter [ 0.912733] usb_battery_charger_detect_synop , battery_charger_detect 1, pass DCD, dcd_state = 1 [ 0.973704] rk-fb rockchip-fb: rk fb ion client create success! [ 0.973777] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.974896] rk-screen rk_screen.9: rockchip screen probe success [ 0.975475] rk32-lvds ff96c000.lvds: screen is not lvds/rgb! [ 0.975548] rk32-lvds: probe of ff96c000.lvds failed with error -22 [ 0.976322] rk32-edp ff970000.edp: screen is not edp! [ 0.976391] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.977276] dsi->host.irq =51 [ 0.977338] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a [ 0.977377] mipi_dsi v1.3 2014-04-17 [ 0.977464] rk32-mipi ff960000.mipi: rk mipi_dsi probe success! [ 0.977516] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17 [ 0.978711] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 0.979427] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.980450] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.980999] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.981536] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.982101] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.983750] rk_iommu ff930300.vopb_mmu: (vopb) Enabled [ 0.984239] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:63 [ 0.984290] dsi->phy.sys_clk =24000000 [ 3.918231] rk3288-lcdc lcdc0: wakeup from standby! [ 4.027966] alloc_buffer:ion_phy_addr=0x10000000 [ 4.073150] fb0:phy:10000000>>vir:f0191000>>len:0x1900000 [ 4.073281] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 4.074454] rockchip_set_mux:warning ignore bank num 15 [ 4.074865] rockchip_set_mux:warning ignore bank num 15 [ 4.075257] rockchip_set_mux:warning ignore bank num 15 [ 4.075738] rockchip_set_mux:warning ignore bank num 15 [ 4.076131] rockchip_set_mux:warning ignore bank num 15 [ 4.076568] rockchip_set_mux:warning ignore bank num 15 [ 4.077465] rockchip_set_mux:warning ignore bank num 15 [ 4.077962] rockchip_set_mux:warning ignore bank num 15 [ 4.078804] rockchip_set_mux:warning ignore bank num 15 [ 4.079313] rockchip_set_mux:warning ignore bank num 15 [ 4.080162] rockchip_set_mux:warning ignore bank num 15 [ 4.080667] rockchip_set_mux:warning ignore bank num 15 [ 4.081506] rockchip_set_mux:warning ignore bank num 15 [ 4.082012] rockchip_set_mux:warning ignore bank num 15 [ 4.086602] NET: Registered protocol family 2 [ 4.088055] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 4.088546] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 4.089044] TCP: Hash tables configured (established 8192 bind 8192) [ 4.089198] TCP: reno registered [ 4.089252] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 4.089382] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 4.090032] NET: Registered protocol family 1 [ 4.090645] Unpacking initramfs... [ 4.313774] Freeing initrd memory: 1152K (c4bf0000 - c4d10000) [ 4.315673] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 4.317211] probe device ff9a0000.vpu_service [ 4.317650] vpu_service: power on [ 4.318801] checking hw id 4831 [ 4.319844] vpu_service set to auto frequency mode [ 4.320032] vcodec vpu_service: vcodec ion client create success! [ 4.321150] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled [ 4.321256] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled [ 4.321309] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26f000 [ 4.321357] vpu_service: power off... [ 4.321442] done [ 4.321474] init success [ 4.321709] probe device ff9c0000.hevc_service [ 4.322303] hevc_service: power on [ 4.323472] checking hw id 6867 [ 4.324296] vcodec hevc_service: vcodec ion client create success! [ 4.325190] rk_iommu ff9c0440.hevc_mmu: (hevc) Enabled [ 4.325296] rk_iommu ff9c0440.hevc_mmu: (hevc) Disabled [ 4.325348] rk_iommu ff9c0440.hevc_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26c000 [ 4.325395] hevc_service: power off... [ 4.325480] done [ 4.325511] init success [ 4.325885] rknandbase v1.0 2014-03-31 [ 4.326523] rknand_probe clk rate = 148500000 [ 4.326919] rknand_driver:ret = 0 [ 4.328049] audit: initializing netlink socket (disabled) [ 4.328178] type=2000 audit(3.850:1): initialized [ 4.330504] bounce pool size: 64 pages [ 4.346266] fuse init (API version 7.22) [ 4.347515] msgmni has been set to 1456 [ 4.353762] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 4.353823] io scheduler noop registered [ 4.353864] io scheduler deadline registered [ 4.354157] io scheduler cfq registered (default) [ 4.356486] rga ff920000.rga: rga ion client create success! [ 4.356908] rga: Driver loaded succesfully [ 4.358341] IEP Power ON [ 4.358457] iep ion client create success! [ 4.359445] rk_iommu ff900800.iep_mmu: (iep) Enabled [ 4.359536] IEP Power OFF [ 4.359582] rk_iommu ff900800.iep_mmu: (iep) Disabled [ 4.359635] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e262000 [ 4.359698] IEP Driver loaded succesfully [ 4.360001] Module initialized. [ 4.362532] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 4.362606] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 4.367016] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 4.367087] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 4.367857] pwm-voltage-regulator pwm_regulator.27: unable to request PWM, trying legacy API [ 4.367920] pwm-voltage-regulator pwm_regulator.27: unable to request legacy PWM [ 4.367963] pwm_regulator_probe:error [ 4.368035] platform pwm_regulator.27: Driver pwm-voltage-regulator requests probe deferral [ 4.369152] rk_serial.c v1.8 2014-03-04 [ 4.369763] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 4.370387] serial ff180000.serial: membase 0xf0174000 [ 4.380218] loop: module loaded [ 4.382117] SCSI Media Changer driver v0.25 [ 4.383145] tun: Universal TUN/TAP device driver, 1.6 [ 4.383194] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 4.384836] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 4.384894] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 4.384943] stmmac_probe_config_dt: clock input or output? (input). [ 4.384988] stmmac_probe_config_dt: TX delay(0x30). [ 4.385029] stmmac_probe_config_dt: RX delay(0x10). [ 4.385151] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 4.385192] stmmc_pltfr_init: [ 4.385227] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 4.385302] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed. [ 4.385341] stmmc_pltfr_init: init for RGMII [ 4.385381] tx delay=0x30 [ 4.385381] rx delay=0x10 [ 4.386796] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 4.386838] Normal descriptors [ 4.386870] Ring mode enabled [ 4.386904] DMA HW capability register supported [ 4.386943] RX Checksum Offload Engine supported (type 2) [ 4.386982] TX Checksum insertion supported [ 4.387015] Wake-Up On Lan supported [ 4.387129] Enable RX Mitigation via HW Watchdog Timer [ 4.388439] PPP generic driver version 2.4.2 [ 4.388910] PPP BSD Compression module registered [ 4.388957] PPP Deflate Compression module registered [ 4.389021] PPP MPPE Compression module registered [ 4.389063] NET: Registered protocol family 24 [ 4.389171] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 4.389221] CSLIP: code copyright 1989 Regents of the University of California. [ 4.389267] Rockchip WiFi SYS interface (V1.00) ... [ 4.389510] usbcore: registered new interface driver catc [ 4.389642] usbcore: registered new interface driver kaweth [ 4.389688] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 4.389836] usbcore: registered new interface driver pegasus [ 4.389967] usbcore: registered new interface driver rtl8150 [ 4.390094] usbcore: registered new interface driver r8152 [ 4.390135] hso: drivers/net/usb/hso.c: Option Wireless [ 4.390342] usbcore: registered new interface driver hso [ 4.390558] usbcore: registered new interface driver asix [ 4.390700] usbcore: registered new interface driver ax88179_178a [ 4.390846] usbcore: registered new interface driver cdc_ether [ 4.390976] usbcore: registered new interface driver cdc_eem [ 4.391103] usbcore: registered new interface driver dm9601 [ 4.391228] usbcore: registered new interface driver dm9620 [ 4.391390] usbcore: registered new interface driver smsc75xx [ 4.391549] usbcore: registered new interface driver smsc95xx [ 4.391691] usbcore: registered new interface driver gl620a [ 4.391824] usbcore: registered new interface driver net1080 [ 4.391954] usbcore: registered new interface driver plusb [ 4.392083] usbcore: registered new interface driver rndis_host [ 4.392213] usbcore: registered new interface driver cdc_subset [ 4.392337] usbcore: registered new interface driver zaurus [ 4.392469] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 4.392651] usbcore: registered new interface driver int51x1 [ 4.392796] usbcore: registered new interface driver kalmia [ 4.392928] usbcore: registered new interface driver ipheth [ 4.393074] usbcore: registered new interface driver sierra_net [ 4.393207] usbcore: registered new interface driver cx82310_eth [ 4.393371] usbcore: registered new interface driver cdc_ncm [ 4.393505] usbcore: registered new interface driver qmi_wwan [ 4.393658] usbcore: registered new interface driver cdc_mbim [ 4.393701] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.396916] ehci_rk_probe f1b00000 f1b00010 [ 4.396973] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller [ 4.397069] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 4.398114] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 4.410270] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00 [ 4.410512] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.410574] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.410627] usb usb1: Product: Rockchip On-Chip EHCI Host Controller [ 4.410677] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 4.410724] usb usb1: SerialNumber: ff500000.usb [ 4.412133] hub 1-0:1.0: USB hub found [ 4.412230] hub 1-0:1.0: 1 port detected [ 4.439786] ehci_rk_probe ok [ 4.440262] usbcore: registered new interface driver cdc_acm [ 4.440309] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 4.440511] usbcore: registered new interface driver usblp [ 4.440662] usbcore: registered new interface driver cdc_wdm [ 4.440895] usbcore: registered new interface driver usb-storage [ 4.441027] usbcore: registered new interface driver ums-alauda [ 4.441155] usbcore: registered new interface driver ums-cypress [ 4.441286] usbcore: registered new interface driver ums-datafab [ 4.441412] usbcore: registered new interface driver ums_eneub6250 [ 4.441548] usbcore: registered new interface driver ums-freecom [ 4.441682] usbcore: registered new interface driver ums-isd200 [ 4.441812] usbcore: registered new interface driver ums-jumpshot [ 4.441938] usbcore: registered new interface driver ums-karma [ 4.442066] usbcore: registered new interface driver ums-onetouch [ 4.442197] usbcore: registered new interface driver ums-sddr09 [ 4.442326] usbcore: registered new interface driver ums-sddr55 [ 4.442453] usbcore: registered new interface driver ums-usbat [ 4.442732] usbcore: registered new interface driver usbserial [ 4.442884] usbcore: registered new interface driver usbserial_generic [ 4.443002] usbserial: USB Serial support registered for generic [ 4.443142] usbcore: registered new interface driver option [ 4.443254] usbserial: USB Serial support registered for GSM modem (1-port) [ 4.443494] usbcore: registered new interface driver trancevibrator [ 4.443537] usb20_otg: version 3.10a 21-DEC-2012 [ 4.444602] f1b80040 [ 4.444647] Core Release: 3.10a [ 4.444685] Setting default values for core params [ 4.445126] Using Buffer DMA mode [ 4.445168] Periodic Transfer Interrupt Enhancement - disabled [ 4.445207] Multiprocessor Interrupt Enhancement - disabled [ 4.445248] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 4.445284] ^^^^^^^^^^^^^^^^^Device Mode [ 4.445330] Dedicated Tx FIFOs mode [ 4.445387] pcd_init otg_dev = ed976a80 [ 4.445868] usb20_otg ff580000.usb: DWC OTG Controller [ 4.445963] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 4.446067] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 4.446251] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.446311] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.446363] usb usb2: Product: DWC OTG Controller [ 4.446409] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 4.446456] usb usb2: SerialNumber: ff580000.usb [ 4.447776] hub 2-0:1.0: USB hub found [ 4.447854] hub 2-0:1.0: 1 port detected [ 4.448811] usb20_host: version 3.10a 21-DEC-2012 [ 4.452439] f1c00040 [ 4.452488] Core Release: 3.10a [ 4.452528] Setting default values for core params [ 4.452940] Using Buffer DMA mode [ 4.452980] Periodic Transfer Interrupt Enhancement - disabled [ 4.453018] Multiprocessor Interrupt Enhancement - disabled [ 4.453059] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 4.453095] ^^^^^^^^^^^^^^^^^^Host Mode [ 4.453175] usb20_host ff540000.usb: DWC OTG Controller [ 4.453262] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 4.453364] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 4.453531] Init: Power Port (0) [ 4.453763] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.453826] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.453880] usb usb3: Product: DWC OTG Controller [ 4.453927] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 4.453974] usb usb3: SerialNumber: ff540000.usb [ 4.455350] hub 3-0:1.0: USB hub found [ 4.455426] hub 3-0:1.0: 1 port detected [ 4.457064] .. rk pwm remotectl v1.0 init [ 4.457320] remotectl probe j=0x0 [ 4.457799] input: ff680000.pwm as /devices/ff680000.pwm/input/input0 [ 4.458379] pwm enable val=0x646205 [ 4.459259] usbcore: registered new interface driver xpad [ 4.459535] usbcore: registered new interface driver usb_acecad [ 4.459696] usbcore: registered new interface driver aiptek [ 4.459847] usbcore: registered new interface driver gtco [ 4.459995] usbcore: registered new interface driver hanwang [ 4.460157] usbcore: registered new interface driver kbtab [ 4.460328] usbcore: registered new interface driver wacom [ 4.461405] sensor_register_slave:mma8452,id=17 [ 4.461456] sensor_register_slave:cm3217,id=44 [ 4.461496] sensor_register_slave:cm3218,id=45 [ 4.468226] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 4.468394] i2c /dev entries driver [ 4.470726] IR NEC protocol handler initialized [ 4.470774] IR RC5(x) protocol handler initialized [ 4.470812] IR RC6 protocol handler initialized [ 4.470849] IR JVC protocol handler initialized [ 4.470883] IR Sony protocol handler initialized [ 4.470919] IR RC5 (streamzap) protocol handler initialized [ 4.470957] IR SANYO protocol handler initialized [ 4.470993] IR MCE Keyboard/mouse protocol handler initialized [ 4.471250] usbcore: registered new interface driver uvcvideo [ 4.471293] USB Video Class driver (1.1.1) [ 4.471339] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0 [ 4.474567] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236 [ 4.474654] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request [ 4.474719] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0 [ 4.474782] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high [ 4.474997] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 4.475460] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf1ab0000 size: 0x4000) [ 4.477549] D1:camsys_platform_probe(1208): ff910000.isp memory: [ 4.477614] D1:camsys_platform_probe(1218): Register memory (phy: 0xff910000 vir: 0xf1ae0000 size: 0x10000) [ 4.477673] D1:camsys_platform_probe(1213): I2c memory (phy: 0x2d918000 vir: 0xed918000 size: 0x1000) [ 4.477726] D1:camsys_platform_probe(1233): Probe ff910000.isp device success [ 4.480801] device-mapper: uevent: version 1.0.3 [ 4.481560] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 4.482497] Bluetooth: HCI UART driver ver 2.2 [ 4.482548] Bluetooth: HCI H4 protocol initialized [ 4.482587] Bluetooth: HCILL protocol initialized [ 5.267824] cpufreq version 1.0, suspend freq 1200 MHz [ 5.268418] cpuidle: using governor ladder [ 5.268464] cpuidle: using governor menu [ 5.268603] Synopsys Designware Multimedia Card Interface Driver [ 5.269391] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 5.270246] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 5.270749] 3230..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 5.270804] Line3235..dw_mci_init_slot: The rk_sdmmc Ver 1.12 2014-07-08 [ 5.271188] 1357..dw_mci_set_ios: no card. [mmc0] [ 5.286063] 1357..dw_mci_set_ios: no card. [mmc0] [ 5.305675] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 5.305690] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 5.305705] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 5.306056] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 5.306894] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 5.307083] 3224..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1] [ 5.307646] 1357..dw_mci_set_ios: no card. [mmc1] [ 5.325324] 1357..dw_mci_set_ios: no card. [mmc1] [ 5.337855] mmc0: BKOPS_EN bit is not set [ 5.339761] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 5.342065] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 5.342094] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 5.345142] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 5.345162] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 5.345517] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 5.345739] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 5.345890] 3230..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 5.346002] 1357..dw_mci_set_ios: no card. [mmc2] [ 5.357131] rk_sdmmc: BOOT [ 5.357131] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID[mmc0] [ 5.357251] mmc0: new HS200 MMC card at address 0001 [ 5.357600] mmcblk0: mmc0:0001 AWMB3R 14.5 GiB [ 5.357995] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 5.358012] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 5.358026] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 5.358039] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 5.358052] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 5.358065] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 5.358077] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 5.358090] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 5.358103] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 5.358115] system: 0x012400000 -- 0x042400000 (768 MB) [ 5.358128] metadata: 0x042400000 -- 0x042800000 (4 MB) [ 5.358141] userdata: 0x042800000 -- 0x082800000 (1024 MB) [ 5.358154] radical_update: 0x082800000 -- 0x086800000 (64 MB) [ 5.358166] user: 0x086800000 -- 0x3a3a00000 (12754 MB) [ 5.358208] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141357..dw_mci_set_ios: no card. [mmc1] [ 5.364672] 1357..dw_mci_set_ios: no card. [mmc2] [ 5.384345] 1357..dw_mci_set_ios: no card. [mmc2] [ 5.384544] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 5.384558] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 5.384834] leds-gpio leds.35: pins are not configured from the driver [ 5.385048] hidraw: raw HID events driver (C) Jiri Kosina [ 5.386363] usbcore: registered new interface driver usbhid [ 5.386373] usbhid: USB HID core driver [ 5.386658] ashmem: initialized [ 5.386771] logger: created 256K log 'log_main' [ 5.386868] logger: created 256K log 'log_events' [ 5.386959] logger: created 256K log 'log_radio' [ 5.387052] logger: created 256K log 'log_system' [ 5.388084] input: rk29-keypad as /devices/ff100000.adc/key.38/input/input1 [ 5.388674] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ; cannot claim for 2-0010 [ 5.388690] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22 [ 5.388702] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl [ 5.388714] ES8323 2-0010: Error applying setting, reverse things back [ 5.388997] es8323 probe i2c recv ok [ 5.389213] i2c-core: driver [ES8323] using legacy suspend method [ 5.389224] i2c-core: driver [ES8323] using legacy resume method [ 5.389600] rockchip-hdmi-spdif rockchip-hdmi-spdif.31: ASoC: CPU DAI (null) not registered [ 5.389633] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 5.389653] platform rockchip-hdmi-spdif.31: Driver rockchip-hdmi-spdif requests probe deferral [ 5.389890] es8323_probe [ 5.389986] es8323_probe:register ISR (irq=194) [ 6.024286] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> NULL --> Left Line Mux [ 6.024302] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> NULL -> Left Line Mux [ 6.024313] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> NULL --> Left Line Mux [ 6.024322] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> NULL -> Left Line Mux [ 6.024334] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> NULL --> Left Line Mux [ 6.024359] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> NULL -> Left Line Mux [ 6.024391] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> NULL --> Right Line Mux [ 6.024411] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> NULL -> Right Line Mux [ 6.024477] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> NULL --> Right Line Mux [ 6.024574] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> NULL -> Right Line Mux [ 6.024683] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> NULL --> Right Line Mux [ 6.024781] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> NULL -> Right Line Mux [ 6.024923] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left PGA Mux [ 6.025018] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left PGA Mux [ 6.025187] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left PGA Mux [ 6.025303] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left PGA Mux [ 6.025417] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> LAMP --> Left PGA Mux [ 6.025565] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> LAMP -> Left PGA Mux [ 6.025701] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right PGA Mux [ 6.025799] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right PGA Mux [ 6.025957] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right PGA Mux [ 6.026070] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right PGA Mux [ 6.026184] ES8323 2-0010: ASoC: no dapm match for Differential Mux --> RAMP --> Right PGA Mux [ 6.026327] ES8323 2-0010: ASoC: Failed to add route Differential Mux -> RAMP -> Right PGA Mux [ 6.026459] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Differential Mux [ 6.026554] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Differential Mux [ 6.026712] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Differential Mux [ 6.026808] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Differential Mux [ 6.026915] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Differential Mux [ 6.027009] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Differential Mux [ 6.027116] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Differential Mux [ 6.027210] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Differential Mux [ 6.027440] ES8323 2-0010: ASoC: no dapm match for LINPUT1 --> LAMP --> Left Line Mux [ 6.027534] ES8323 2-0010: ASoC: Failed to add route LINPUT1 -> LAMP -> Left Line Mux [ 6.027642] ES8323 2-0010: ASoC: no dapm match for LINPUT2 --> LAMP --> Left Line Mux [ 6.027735] ES8323 2-0010: ASoC: Failed to add route LINPUT2 -> LAMP -> Left Line Mux [ 6.027841] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux --> LAMP --> Left Line Mux [ 6.027937] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux -> LAMP -> Left Line Mux [ 6.028048] ES8323 2-0010: ASoC: no dapm match for RINPUT1 --> RAMP --> Right Line Mux [ 6.028142] ES8323 2-0010: ASoC: Failed to add route RINPUT1 -> RAMP -> Right Line Mux [ 6.028252] ES8323 2-0010: ASoC: no dapm match for RINPUT2 --> RAMP --> Right Line Mux [ 6.028344] ES8323 2-0010: ASoC: Failed to add route RINPUT2 -> RAMP -> Right Line Mux [ 6.028453] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux --> RAMP --> Right Line Mux [ 6.028548] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux -> RAMP -> Right Line Mux [ 6.029768] ES8323 2-0010: ASoC: mux Right Line Mux has no paths [ 6.029903] ES8323 2-0010: ASoC: mux Left Line Mux has no paths [ 6.030021] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths [ 6.030137] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths [ 6.030354] ES8323 2-0010: ASoC: mux Differential Mux has no paths [ 6.035680] Enter::rk29_es8323_init----135 [ 6.047859] rockchip-es8323 rockchip-es8323.33: ES8323 HiFi <-> rockchip-i2s.0 mapping ok [ 6.048951] u32 classifier [ 6.048969] Actions configured [ 6.048991] Netfilter messages via NETLINK v0.30. [ 6.049080] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 6.049658] ctnetlink v0.93: registering with nfnetlink. [ 6.049759] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 6.049778] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 6.050233] xt_time: kernel timezone is -0000 [ 6.050599] ip_tables: (C) 2000-2006 Netfilter Core Team [ 6.050837] arp_tables: (C) 2002 David S. Miller [ 6.050907] TCP: cubic registered [ 6.050922] Initializing XFRM netlink socket [ 6.051357] NET: Registered protocol family 10 [ 6.052294] mip6: Mobile IPv6 [ 6.052343] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 6.052553] sit: IPv6 over IPv4 tunneling driver [ 6.053114] NET: Registered protocol family 17 [ 6.053160] NET: Registered protocol family 15 [ 6.053249] Bridge firewalling registered [ 6.053273] Ebtables v2.0 registered [ 6.053539] Bluetooth: RFCOMM TTY layer initialized [ 6.053586] Bluetooth: RFCOMM socket layer initialized [ 6.053602] Bluetooth: RFCOMM ver 1.11 [ 6.053619] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 6.053633] Bluetooth: BNEP filters: protocol multicast [ 6.053656] Bluetooth: BNEP socket layer initialized [ 6.053671] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 6.053693] Bluetooth: HIDP socket layer initialized [ 6.053740] l2tp_core: L2TP core driver, V2.0 [ 6.053768] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 6.053783] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 6.054080] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 6.054100] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 6.054118] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 6.054135] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 6.054154] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 6.054195] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 6.054239] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 6.054257] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 6.054297] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 6.054369] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 6.054447] [BT_RFKILL]: Enter rfkill_rk_init [ 6.054682] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 6.054717] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 6.054747] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 6.054779] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 6.054809] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 6.054901] [BT_RFKILL]: Request irq for bt wakeup host [ 6.055043] [BT_RFKILL]: ** disable irq [ 6.055179] [BT_RFKILL]: ap6335 device registered. [ 6.056287] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess. [ 6.057077] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 6.057111] rk3288_init_suspend [ 6.057126] rk3288_suspend_init enter [ 6.057300] rk3288_suspend_init: pm_ctrbits =40017 [ 6.057354] gpio_get_dts_info suspend:8 [ 6.057369] gpio_get_dts_info resume:8 [ 6.057382] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 6.057448] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 6.057733] clks_gating_suspend_init:clkgt info ok [ 6.057900] Registering SWP/SWPB emulation handler [ 6.058549] ddrfreq: verion 1.2 20140526 [ 6.058576] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz [ 6.058595] ddrfreq: auto-freq=0 [ 6.058609] ddrfreq: auto-freq-table[0] 240MHz [ 6.058623] ddrfreq: auto-freq-table[1] 324MHz [ 6.058636] ddrfreq: auto-freq-table[2] 456MHz [ 6.058650] ddrfreq: auto-freq-table[3] 528MHz [ 6.060863] act_ldo3: operation not allowed [ 6.061147] vga_edid_probe: turn on ldo3 done. [ 6.061209] act_ldo4: operation not allowed [ 6.061487] vga_edid_probe: turn on ldo done. [ 6.061541] act_ldo2: operation not allowed [ 6.061813] vga_edid_probe: turn on ldo2 done. [ 6.061862] act_ldo8: operation not allowed [ 6.062134] vga_edid_probe: turn on ldo done. [ 6.067302] unable to read EDID block. [ 6.101878] unable to read EDID block. [ 6.136453] unable to read EDID block. [ 6.136468] vga-ddc: read and parse edid failed errno:-5. [ 6.136477] vga_edid_probe: success. 10 [ 6.136635] firefly_vga_get_enable 180, 0 [ 6.136647] firefly_vga_get_status 186 [ 6.136664] firefly_vga_set_enable 159 enable:1 [ 6.136692] firefly_vga_enable 130 start [ 6.136702] firefly_switch_fb 55 [ 6.136712] [ 6.136712] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 [ 6.136727] fb0 win id 1 state 1 [ 6.136747] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 6.136752] regulator-dummy: disabling [ 6.136767] dsi->phy.sys_clk =24000000 [ 6.142387] rockchip-hdmi-spdif rockchip-hdmi-spdif.31: ASoC: CPU DAI (null) not registered [ 6.142420] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 6.142440] platform rockchip-hdmi-spdif.31: Driver rockchip-hdmi-spdif requests probe deferral [ 6.142548] pcd_pullup, is_on 0 [ 6.142607] file system registered [ 6.143363] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 6.143376] android_usb gadget: Number of LUNs=2 [ 6.143387] lun0: LUN: removable file: (no medium) [ 6.143396] lun1: LUN: removable file: (no medium) [ 6.143581] android_usb gadget: android_usb ready [ 6.143690] sensor_init: Probe name sensors [ 6.143710] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 6.144249] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:45:39 UTC (1293885939) [ 6.151952] usbcore: registered new interface driver snd-usb-audio [ 6.151967] ALSA device list: [ 6.151975] #0: RK_ES8323 [ 6.153972] Freeing unused kernel memory: 2364K (c0a7b000 - c0cca000) [ 6.154608] rockchip-hdmi-spdif rockchip-hdmi-spdif.31: rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok [ 6.161211] SELinux: Permission attach_queue in class tun_socket not defined in policy. [ 6.161227] SELinux: the above unknown classes and permissions will be denied [ 6.410669] type=1403 audit(1293885939.760:2): policy loaded auid=4294967295 ses=4294967295 [ 6.410766] SELinux: Loaded policy from /sepolicy [ 6.412195] type=1404 audit(1293885939.760:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295 [ 6.427352] dwc_otg_hcd_enable, enable host controller [ 6.560196] Using Buffer DMA mode [ 6.560202] Periodic Transfer Interrupt Enhancement - disabled [ 6.560209] Multiprocessor Interrupt Enhancement - disabled [ 6.560215] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 6.560221] ^^^^^^^^^^^^^^^^^^Host Mode [ 6.604546] Init: Power Port (0) [ 6.880019] Indeed it is in host mode hprt0 = 00021501 [ 7.057148] usb 3-1: new high-speed USB device number 2 using usb20_host [ 7.057215] Indeed it is in host mode hprt0 = 00001101 [ 7.254148] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101 [ 7.254169] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 7.254178] usb 3-1: Product: USB 2.0 Hub [MTT] [ 7.254521] hub 3-1:1.0: USB hub found [ 7.254570] hub 3-1:1.0: 4 ports detected [ 7.255408] init: init.rk30board.bootmode.emmc.rc: 8: invalid command '/devices/ff0f0000.rksdmmc/mmc_host/mmc' [ 7.255423] init: init.rk30board.bootmode.emmc.rc: 9: invalid command '/devices/ff0c0000.rksdmmc/mmc_host/mmc' [ 7.255435] init: init.rk30board.bootmode.emmc.rc: 10: invalid command '/devices/ff580000.usb' [ 7.255445] init: init.rk30board.bootmode.emmc.rc: 11: invalid command '/devices/ff580000.usb' [ 7.255455] init: init.rk30board.bootmode.emmc.rc: 12: invalid command '/devices/ff500000.usb' [ 7.255465] init: init.rk30board.bootmode.emmc.rc: 13: invalid command '/devices/ff500000.usb' [ 7.255474] init: init.rk30board.bootmode.emmc.rc: 14: invalid command '/devices/ff540000.usb' [ 7.255483] init: init.rk30board.bootmode.emmc.rc: 15: invalid command '/devices/ff540000.usb' [ 7.255769] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead. [ 7.306143] init: /dev/hw_random not found [ 7.306201] keychord: using input dev ff680000.pwm for fevent [ 7.306210] keychord: using input dev rk29-keypad for fevent [ 7.311133] fs_mgr: parse_link_device : path = NULL [ 7.311156] fs_mgr: parse_link_device : path = NULL [ 7.311173] fs_mgr: parse_link_device : path = NULL [ 7.311190] fs_mgr: parse_link_device : path = NULL [ 7.311205] fs_mgr: parse_link_device : path = NULL [ 7.311220] fs_mgr: parse_link_device : path = NULL [ 7.311236] fs_mgr: parse_link_device : path = NULL [ 7.311250] fs_mgr: parse_link_device : path = NULL [ 7.311304] fs_mgr: ---------------resize_fs blk_dev /dev/block/platform/ff0f0000.rksdmmc/by-name/system, type ext4fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system [ 7.312124] resize2fs: resize2fs 1.41.14 (22-Dec-2010)resize2fs: The filesystem is already 196608 blocks long. Nothing to do!resize2fs: [ 7.318488] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc [ 7.329205] EXT4-fs (mmcblk0p8): recovery complete [ 7.330349] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 7.333730] EXT4-fs (mmcblk0p11): recovery complete [ 7.333742] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 7.382179] EXT4-fs (mmcblk0p12): recovery complete [ 7.382738] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard [ 7.388101] drmboot: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 7.393202] mali pd enabled [ 7.393216] clk enabled [ 7.393226] MALI_DVFS_STEP=4,div_dvfs=10 [ 7.393233] mali_dvfs_infotbl[0].clock=198000,min_threshold=0,max_threshold=70 [ 7.393241] mali_dvfs_infotbl[1].clock=297000,min_threshold=70,max_threshold=80 [ 7.393248] mali_dvfs_infotbl[2].clock=417000,min_threshold=80,max_threshold=90 [ 7.393255] mali_dvfs_infotbl[3].clock=480000,min_threshold=94,max_threshold=100 [ 7.393351] turn on mali power [ 7.393372] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1 [ 7.393716] mali ffa30000.gpu: Probed as mali0 [ 7.396012] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ' should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' [ 7.404841] init: /dev/hw_random not found [ 7.411488] binder: 135:135 transaction failed 29189, size 0-0 [ 7.411977] init: cannot find '/system/vendor/bin/pvrsrvctl', disabling 'pvrsrvctl' [ 7.414332] init: cannot find '/system/bin/rild3', disabling 'ril-daemon3' [ 7.415893] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery' [ 7.417458] init: cannot find '/system/bin/chrome.sh', disabling 'chrome' [ 7.417787] init: cannot find '/system/bin/bplus_helper', disabling 'bplus_helper' [ 7.436869] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 7.436887] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' [ 7.437041] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead [ 7.538266] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 7.538280] dsi->phy.sys_clk =24000000 [ 7.633381] fs_mgr: parse_link_device : path = NULL [ 7.633409] fs_mgr: parse_link_device : path = NULL [ 7.633427] fs_mgr: parse_link_device : path = NULL [ 7.633444] fs_mgr: parse_link_device : path = NULL [ 7.633460] fs_mgr: parse_link_device : path = NULL [ 7.633476] fs_mgr: parse_link_device : path = NULL [ 7.633509] fs_mgr: parse_link_device : path = NULL [ 7.633527] fs_mgr: parse_link_device : path = NULL [ 7.657665] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}' [ 7.657681] init: powerctl: cannot expand '${sys.powerctl}' [ 7.657693] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}' [ 7.657704] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes' [ 7.658562] android_usb: already disabled [ 7.667904] read descriptors [ 7.667920] read strings [ 7.667949] pcd_pullup, is_on 1 shell@rk3288:/ $ [ 8.297002] iep dpi mode inactivity [ 8.423396] rk3288-lcdc lcdc0: blank mode:0 [ 8.515769] init: sys_prop: permission denied uid:1003 name:sys.gmali.version [ 8.537901] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_hal.ver [ 8.543208] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_trace [ 8.543357] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_camboard.ver [ 8.543492] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_libisp.ver [ 8.543609] init: sys_prop: permission denied uid:1000 name:sys_graphic.cam_isi.ver [ 8.547700] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on [ 8.547728] D1:camsys_mipiphy_clkin_cb(29): camsys_marvin mipi phy clk in turn on [ 8.547739] D1:camsys_open(710): camsys_marvin(ed90ad10) is opened! [ 8.547799] D1:camsys_extdev_register(226): Get RK30_PIN2_PB6(78) gpio(active: 0) for dev_id 0x2000000 success! [ 8.547816] D1:camsys_extdev_register(226): Get RK30_PIN2_PB7(79) gpio(active: 0) for dev_id 0x2000000 success! [ 8.547830] D1:camsys_extdev_register(226): Get RK30_PIN0_PB3(11) gpio(active: 1) for dev_id 0x2000000 success! [ 8.547865] rockchip_gpio_request:GPIO7-13 [ 8.547877] rockchip_gpio_set:GPIO7-13 level = 1 [ 8.547886] rockchip_gpio_direction_output:set GPIO7-13 level 1 [ 8.547898] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x0 [ 8.547909] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x207600,result=0x207600 [ 8.547920] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl [ 8.547947] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000400,result=0x400 [ 8.547958] _rockchip_pinconf_set:GPIO7-13,group=isp_flash_trigger, function=isp_pin, type=3 [ 8.547968] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10 [ 8.547977] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3 [ 8.547987] D1:camsys_extdev_register(248): Extdev(dev_id: 0x2000000) register success [ 8.553060] D1:camsys_mrv_clkin_cb(344): camsys_marvin clock(f: 210000000 Hz) in turn on [ 8.553076] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 1 [ 8.553182] D1:camsys_rk3288_cfg(49): Isp_SoftRst: 0 [ 8.553217] D1:camsys_mrv_clkout_cb(379): camsys_marvin clock out(rate: 24000000Hz) turn on [ 8.554297] D1:camsys_sysctl_extdev(326): Sysctl 11 success, gpio(11) set 1 [ 8.555375] D1:camsys_sysctl_extdev(330): Sysctl 8 success, gpio(79) set 1 [ 8.556452] D1:camsys_sysctl_extdev(330): Sysctl 7 success, gpio(78) set 1 [ 8.559688] E:camsys_i2c_write(77): i2c write dev(addr:0x20) failed! [ 8.560875] E:camsys_i2c_write(77): i2c write dev(addr:0x6c) failed! [ 8.560924] D1:camsys_sysctl_extdev(326): Sysctl 7 success, gpio(78) set 0 [ 8.560938] D1:camsys_sysctl_extdev(326): Sysctl 8 success, gpio(79) set 0 [ 8.560952] D1:camsys_sysctl_extdev(330): Sysctl 11 success, gpio(11) set 0 [ 8.562058] D1:camsys_mrv_clkin_cb(361): camsys_marvin clock in turn off [ 8.562098] D1:camsys_mrv_clkout_cb(391): camsys_marvin clock out turn off [ 8.564163] D1:camsys_extdev_deregister(308): Extdev(dev_id: 0x2000000) is deregister success [ 8.564184] D1:camsys_irq_disconnect(635): All thread disconnect camsys_marvin irq success! [ 8.564198] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off [ 8.564208] D1:camsys_mipiphy_clkin_cb(31): camsys_marvin mipi phy clk in turn off [ 8.564217] D1:camsys_release(734): camsys_marvin(ed90ad10) is closed [ 8.737569] Enter::rk29_hw_params----52 [ 8.738514] Enter:rk29_hw_params, 86, rate=44100 [ 8.738524] Enter:rk29_hw_params, 104, LRCK=64 [ 8.757237] hjc:hp_det_irq_handler>>>> [ 8.848004] hjc:hp_detect_do_switch,irq=194 [ 8.848023] mic_state_switch 0 [ 8.848030] hp_det = 0,insert hp [ 8.848036] hp mic use intern [ 9.050735] Enter::rk29_hw_params----52 [ 9.051730] Enter:rk29_hw_params, 86, rate=44100 [ 9.051744] Enter:rk29_hw_params, 104, LRCK=64 [ 9.103871] fb1 win id 0 state 0 [ 9.103895] fb2 win id 2 state 0 [ 9.103904] fb3 win id 3 state 0 [ 9.103913] fb4 win id 4 state 0 [ 9.103922] [ 9.103922] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done [ 9.103922] [ 9.104025] VGA ENABLE [ 10.482809] firefly_vga_get_enable 180, 1 [ 10.482887] firefly_vga_get_status 186 [ 10.483415] firefly_vga_set_mode 203 [ 10.483474] firefly_vga_set_enable 159 enable:1 [ 11.620427] warning: `zygote' uses 32-bit capabilities (legacy support in use) [ 13.286430] es8323_mic_state_ctrl read: 0 [ 13.286455] mic_state_switch 0 [ 13.286468] hp_det = 0,insert hp [ 13.286475] hp mic use intern [ 13.339505] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj: [ 13.339532] lowmemorykiller: oom_adj 0 => oom_score_adj 0 [ 13.339541] lowmemorykiller: oom_adj 1 => oom_score_adj 58 [ 13.339549] lowmemorykiller: oom_adj 2 => oom_score_adj 117 [ 13.339557] lowmemorykiller: oom_adj 3 => oom_score_adj 176 [ 13.339564] lowmemorykiller: oom_adj 9 => oom_score_adj 529 [ 13.339572] lowmemorykiller: oom_adj 15 => oom_score_adj 1000 [ 13.554556] phy_power_on: enable = 1 [ 13.589085] Read the Ethernet MAC address from IDB:00:00:00:00:00:00 [ 13.589130] eth0: device MAC address 3e:7d:56:3e:4b:d8 [ 13.593286] libphy: stmmac: probed [ 13.593300] eth0: PHY ID 001cc915 at 0 IRQ 0 (stmmac-0:00) active [ 13.593310] eth0: PHY ID 001cc915 at 1 IRQ 0 (stmmac-0:01) active [ 13.738414] wifi_driver_write: wifi driver already rmmod [ 13.917695] acc_open [ 13.917728] acc_release [ 15.258459] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 15.285870] init: no such service 'fuse_internal_sd' [ 15.927579] init: sys_prop: permission denied uid:1001 name:media.cfg.audio.soundeffect [ 16.020520] init: sys_prop: permission denied uid:10007 name:sys.gmali.version [ 16.200659] vpu_service: power on [ 16.200718] rk_iommu ff9a0800.vpu_mmu: (vpu) Enabled [ 16.546946] graphics fb0: fb0 check_var fail 2: [ 16.546946] xoffset:0>>xres:1920>>xres_vir:1080 [ 16.546946] yoffset:0>>yres:1080>>yres_vir:5760 [ 16.609516] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit [ 20.144337] rk_iommu ff9a0800.vpu_mmu: (vpu) Disabled [ 20.144361] rk_iommu ff9a0800.vpu_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e26f000 [ 20.144372] vpu_service: power off... [ 20.144407] done [ 20.213199] *****************vbus detect******************* [ 20.392467] Using Buffer DMA mode [ 20.392484] Periodic Transfer Interrupt Enhancement - disabled [ 20.392493] Multiprocessor Interrupt Enhancement - disabled [ 20.392502] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 20.392510] ^^^^^^^^^^^^^^^^^Device Mode [ 20.392553] *******************soft connect!!!******************* [ 20.507044] USB RESET [ 20.598257] android_work: sent uevent USB_STATE=CONNECTED [ 20.601666] USB RESET [ 20.744155] android_usb gadget: high-speed config #1: android [ 20.752164] android_work: sent uevent USB_STATE=CONFIGURED
可以参考其他人的经验:
http://developer.t-firefly.com/search.php?mod=forum&searchid=12&orderby=lastpost&ascdesc=desc&searchsubmit=yes&kw=MIPI
大概都是上电时序、显示timming、指令的问题
zhansb 发表于 2015-3-9 14:30
可以参考其他人的经验:
感觉MIPI没在送画面。
D0P/N 在发命令的时候有信号。
发完命令之后, D0P/N D1P/N, D2P/N, D3P/N 都不动了。没有在送画面。
我试过用自带的MIPI驱动也是没有在送画面。
注:firefly-rk3288_android4.4_git_20141211.tar 代码 +Firefly-RK3288_Android4.4_201412111722 固件
是不是应该用PAD的文件去改??
要用pad版的代码调试,默认版的不支持屏调试
MIPI 成功有信号。
但是, 单MIPI的CLOCK FREQUENCY 最高时钟是多少? 我把时钟设定于142MHz MIPI信号出错
单MIPI支持1080P@60fps,怎么确定信号出错?有波形图吗?
时钟设定为120MHz MIPI 信号正常
1:D0P 2:CLKP
时钟设定为142MHz MIPI 信号出错了
1:D0P 2:CLKP
OK了,MIPI 速度 从 880Mbps 改为 1Gbps
还有一个问题
怎样设定MIPI VIDEO 模式(以下三种)?
  • Non-Burst Mode with Sync Pulses
  • Non-Burst Mode with Sync Events
  • Burst Mode
1:D0P 2:CLKP
应该是用的示波器支持不到这么高的采样率。
我这边1080P的MIPI屏设置为142MHz,波形正常,也可以显示
我这边1080P的显示屏设置为142MHz,波形正常,也可以显示
我把MIPI 速度 从 880Mbps 改为 1Gbps后MIPI输出信号正常了。
谢谢!
如何设定MIPI VIDEO 模式(以下三种)?
  • Burst Mode
谢谢!
  • Non-Burst Mode with Sync …
参考技术文档:k3288-chapter-37-mipi-controller.pdf
或者查看源码,都有详细的介绍
drivers/video/rockchip/transmitter/rk32_mipi_dsi.c:
 813     rk32_dsi_set_bits(dsi, dsi->host.video_mode, vid_mode_type); /* burst mode */
 814
 815     switch (dsi->host.video_mode) {
 816     case VM_BM:
 817         if (screen->type == SCREEN_DUAL_MIPI)
 818             rk32_dsi_set_bits(dsi, screen->x_res / 2 + 4, vid_pkt_size);
 819         else
 820             rk32_dsi_set_bits(dsi, screen->x_res, vid_pkt_size);
 821         break;
 822     case VM_NBMWSE:
 823     case VM_NBMWSP:
 824         for (i = 8; i < 32; i++) {
 825             temp = i * lane * Tpclk % Ttxbyte_clk;
 826             if (decimals > temp) {
 827                 decimals = temp;
 828                 m = i;
 829             }
 830             if (decimals == 0)
 831                 break;
 832         }
谢谢,找到了。k3288-chapter-37-mipi-controller.pdf可以在哪里找到??
可以在这里下载:
http://developer.t-firefly.com/thread-686-1-1.html
谢谢!
您好,请问您是怎么设置MIPI 速度 从 880Mbps 改为 1Gbps 我现在 跟你的情况差不多。。。
我从官方的开发板到firefly平台就亮不起来了
您好,我想问下mipi能只用dsi1来刷屏吗?我发现会出现
[ 1.544652] dw-mipi-dsi ff968000.dsi: final DSI-Link bandwidth: 496 x 8 Mbps
[ 1.557069] dw-mipi-dsi ff968000.dsi: PHY is not locked
[ 1.584162] dw-mipi-dsi ff968000.dsi: generic write fifo is full
[ 1.584168] panel-simple-dsi ff968000.dsi.0: failed to write dcs cmd: -110
[ 1.604191] dw-mipi-dsi ff968000.dsi: generic write fifo is full
这种问题,能帮我看看是什么原因吗,谢谢
[ 1.544652] dw-mipi-dsi ff968000.dsi: final D …
你好,请问这个问题解决了吗,我现在也有需求用DSI1刷屏,出现和你一样的问题,求指教
