rk3399开发板可以运行android7.1,无法运行ubuntu
今天刚拿到的rk3399开发板,运行android7.1正常,后来将系统刷成Firefly-rk3399_xubuntu1604_201707041527.img ,系统启动黑屏,
系统通过串口读取的最后的日志如下,请问是什么问题,我用的是4gb/32gb版本,是我刷新的方式
不对,还是其他问题?
DDR Version 1.07 20161103
Channel 0: DDR3, 666MHz
Channel 1: DDR3, 666MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1844
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 62373
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 77987
LoaderFlag2: 0x0
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE: BL31: v1.2(debug):b995f80
NOTICE: BL31: Built : 16:53:56, Nov 7 2016
INFO: boot cpu mask: 0
INFO: Vesion: 2016.0.01
INFO: plat_rockchip_pmu_init(1211): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-ga7c7ca8 (Apr 25 2017 - 15:10:21)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_per iph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_pe riph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
no key node
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-05-16#1.05
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
‘boot’ does not seem to be a partition nor an address
Unable to boot:boot
try to start recovery
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x011b4100)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005614073 … OK
Add bank:0000000000200000, 00000000f7e00000
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.55 (whh@esky14) (gcc version 4.9.x-google 20140 827 (prerelease) (GCC) ) #3 SMP Tue Jul 4 15:15:12 HKT 2017 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@0000 0000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ee8000 s46144 r8192 d316 80 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 999432 [ 0.000000] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootw ait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust ),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x000 18000(backup),-@0x0001A000(rootfs) storagemedia=emmc uboot_logo=0x02000000@0xf5c 00000 loader.timestamp=2017-04-25_15:10:21 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes ) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [fff fffc0ef600000-ffffffc0f35fffff] [ 0.000000] Memory: 3903404K/4061184K available (11518K kernel code, 1360K rw data, 4048K rodata, 1152K init, 767K bss, 157780K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 M B) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 G B) [ 0.000000] .init : 0xffffff8008fc0000 - 0xffffff80090e0000 ( 1152 K B) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bc0000 ( 11520 K B) [ 0.000000] .rodata : 0xffffff8008bc0000 - 0xffffff8008fc0000 ( 4096 K B) [ 0.000000] .data : 0xffffff80090e0000 - 0xffffff8009234100 ( 1361 K B) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 G B maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 M B actual) [ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 K B) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 M B) [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 M B) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @ef000000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000000ef080000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: using LPI pending table @0x00000000ef090000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpu s/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /c pus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 43980 46511097ns [ 0.001180] Console: colour dummy device 80x25 [ 0.001206] Calibrating delay loop (skipped), value calculated using timer fr equency.. 48.00 BogoMIPS (lpj=24000) [ 0.001219] pid_max: default: 32768 minimum: 301 [ 0.001314] Security Framework initialized [ 0.001325] Yama: becoming mindful. [ 0.001410] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.001421] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.002248] Initializing cgroup subsys devices [ 0.002265] Initializing cgroup subsys freezer [ 0.002293] ftrace: allocating 43079 entries in 169 pages [ 0.120091] sched-energy: Sched-energy-costs installed from DT [ 0.120111] CPU0: update cpu_capacity 401 [ 0.120173] ASID allocator initialised with 65536 entries [ 0.121028] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee2 0000 domain created [ 0.121448] Platform MSI: /interrupt-controller@fee00000/interrupt-controller @fee20000 domain created [ 0.122601] Detected VIPT I-cache on CPU1 [ 0.122636] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.122671] CPU1: using LPI pending table @0x00000000ef2a0000 [ 0.122718] CPU1: update cpu_capacity 401 [ 0.122722] CPU1: Booted secondary processor [410fd034] [ 0.123260] Detected VIPT I-cache on CPU2 [ 0.123281] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.123314] CPU2: using LPI pending table @0x00000000ef2d0000 [ 0.123344] CPU2: update cpu_capacity 401 [ 0.123347] CPU2: Booted secondary processor [410fd034] [ 0.123826] Detected VIPT I-cache on CPU3 [ 0.123847] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.123881] CPU3: using LPI pending table @0x00000000ef300000 [ 0.123909] CPU3: update cpu_capacity 401 [ 0.123913] CPU3: Booted secondary processor [410fd034] [ 0.124430] Detected PIPT I-cache on CPU4 [ 0.124457] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.124493] CPU4: using LPI pending table @0x00000000ef350000 [ 0.124537] CPU4: update cpu_capacity 1024 [ 0.124540] CPU4: Booted secondary processor [410fd082] [ 0.125060] Detected PIPT I-cache on CPU5 [ 0.125079] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.125113] CPU5: using LPI pending table @0x00000000ef380000 [ 0.125141] CPU5: update cpu_capacity 1024 [ 0.125144] CPU5: Booted secondary processor [410fd082] [ 0.125230] Brought up 6 CPUs [ 0.125311] SMP: Total of 6 processors activated. [ 0.125320] CPU features: detected feature: GIC system register CPU interface [ 0.125332] CPU: All CPU(s) started at EL2 [ 0.125380] alternatives: patching kernel code [ 0.126761] devtmpfs: initialized [ 0.147492] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 1911260446275000 ns [ 0.147524] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.148063] pinctrl core: initialized pinctrl subsystem [ 0.149154] NET: Registered protocol family 16 [ 0.153415] cpuidle: using governor ladder [ 0.157437] cpuidle: using governor menu [ 0.157463] Registered FIQ tty driver [ 0.157864] vdso: 2 pages (1 code @ ffffff8008bc6000, 1 data @ ffffff80090e40 00) [ 0.157907] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.158106] DMA: preallocated 256 KiB pool for atomic allocations [ 0.248860] console [ttyFIQ0] enabled [ 0.249387] Registered fiq debugger ttyFIQ0 [ 0.273057] ACPI: Interpreter disabled. [ 0.276107] iommu: Adding device ff650000.vpu_service to group 0 [ 0.276698] iommu: Adding device ff660000.rkvdec to group 1 [ 0.277285] iommu: Adding device ff8f0000.vop to group 2 [ 0.277819] iommu: Adding device ff900000.vop to group 3 [ 0.279430] vgaarb: loaded [ 0.279938] SCSI subsystem initialized [ 0.280454] usbcore: registered new interface driver usbfs [ 0.280970] usbcore: registered new interface driver hub [ 0.281526] usbcore: registered new device driver usb [ 0.282062] media: Linux media interface: v0.10 [ 0.282500] Linux video capture interface: v2.00 [ 0.282941] pps_core: LinuxPPS API ver. 1 registered [ 0.283377] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <[email]giometti@linux.it[/email]> [ 0.284197] PTP clock support registered [ 0.285504] Advanced Linux Sound Architecture Driver Initialized. [ 0.286516] Bluetooth: Core ver 2.21 [ 0.286853] NET: Registered protocol family 31 [ 0.287253] Bluetooth: HCI device and connection manager initialized [ 0.287814] Bluetooth: HCI socket layer initialized [ 0.288245] Bluetooth: L2CAP socket layer initialized [ 0.288712] Bluetooth: SCO socket layer initialized [ 0.289998] clocksource: Switched to clocksource arch_sys_counter [ 0.320132] pnp: PnP ACPI: disabled [ 0.328317] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.329227] NET: Registered protocol family 2 [ 0.330054] TCP established hash table entries: 32768 (order: 6, 262144 bytes ) [ 0.330858] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 0.332011] TCP: Hash tables configured (established 32768 bind 32768) [ 0.332675] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 0.333356] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 0.334303] NET: Registered protocol family 1 [ 0.334986] RPC: Registered named UNIX socket transport module. [ 0.335505] RPC: Registered udp transport module. [ 0.335918] RPC: Registered tcp transport module. [ 0.336339] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.337497] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte rs available [ 0.338317] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte rs available [ 0.342069] Initialise system trusted keyring [ 0.349957] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.352297] NFS: Registering the id_resolver key type [ 0.352766] Key type id_resolver registered [ 0.353148] Key type id_legacy registered [ 0.353514] Installing knfsd (copyright (C) 1996 [email]okir@monad.swb.de[/email]). [ 0.354744] fuse init (API version 7.23) [ 0.359067] NET: Registered protocol family 38 [ 0.359480] Key type asymmetric registered [ 0.359847] Asymmetric key parser 'x509' registered [ 0.360445] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 47) [ 0.361119] io scheduler noop registered [ 0.361471] io scheduler deadline registered [ 0.361977] io scheduler cfq registered (default) [ 0.363013] platform ff770000.syscon:usb2-phy@e450: Driver rockchip-usb2phy r equests probe deferral [ 0.364495] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not a ssigned [ 0.366955] platform ff7c0000.phy: Driver rockchip-typec-phy requests probe d eferral [ 0.370373] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [ 0.370948] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [ 0.371540] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [ 0.462166] PCI host bridge /pcie@f8000000 ranges: [ 0.462603] MEM 0xfa000000..0xfa5fffff -> 0xfa000000 [ 0.463071] IO 0xfa600000..0xfa6fffff -> 0xfa600000 [ 0.463745] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 0.464341] pci_bus 0000:00: root bus resource [bus 00-01] [ 0.464824] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfa5fffff] [ 0.465438] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus addr ess [0xfa600000-0xfa6fffff]) [ 0.466653] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), rec onfiguring [ 0.467567] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 0.468216] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid [ 0.468851] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid [ 0.469495] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid [ 0.470139] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid [ 0.473040] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff] [ 0.473639] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref ] [ 0.474286] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa0101ff] [ 0.474887] pci 0000:01:00.0: BAR 4: no space for [io size 0x0010] [ 0.475446] pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0010] [ 0.476035] pci 0000:01:00.0: BAR 0: no space for [io size 0x0008] [ 0.476584] pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0008] [ 0.477172] pci 0000:01:00.0: BAR 2: no space for [io size 0x0008] [ 0.477721] pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0008] [ 0.478310] pci 0000:01:00.0: BAR 1: no space for [io size 0x0004] [ 0.478858] pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0004] [ 0.479447] pci 0000:01:00.0: BAR 3: no space for [io size 0x0004] [ 0.480004] pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0004] [ 0.480584] pci 0000:00:00.0: PCI bridge to [bus 01] [ 0.481036] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff] [ 0.481674] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [ 0.482432] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [ 0.483055] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt [ 0.484525] rk-vcodec ff650000.vpu_service: No core reset resource define [ 0.485178] rk-vcodec ff650000.vpu_service: do not have pd_video [ 0.485718] rk-vcodec ff650000.vpu_service: probe device [ 0.486229] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0ee9a3c10 [ 0.486981] rk-vcodec ff650000.vpu_service: allocator is drm [ 0.487527] rk-vcodec ff650000.vpu_service: checking hw id 0 [ 0.488472] rk-vcodec ff650000.vpu_service: init success [ 0.489286] rk-vcodec ff660000.rkvdec: No core reset resource define [ 0.489942] rk-vcodec ff660000.rkvdec: do not have pd_video [ 0.490461] rk-vcodec ff660000.rkvdec: probe device [ 0.490925] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0ee9a8410 [ 0.491620] rk-vcodec ff660000.rkvdec: allocator is drm [ 0.492141] rk-vcodec ff660000.rkvdec: checking hw id 6876 [ 0.492938] rk-vcodec ff660000.rkvdec: init success [ 0.494767] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-2 41330 [ 0.495450] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chan s-6 Num_Peri-12 Num_Events-12 [ 0.497629] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-2 41330 [ 0.498307] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Cha ns-8 Num_Peri-20 Num_Events-16 [ 0.500106] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.502227] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A [ 0.503617] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A [ 0.505392] [drm:drm_core_init] Initialized drm 1.1.0 20060810 [ 0.506880] platform fec00000.dp: Driver cdn-dp requests probe deferral [ 0.509342] usbcore: registered new interface driver udl [ 0.511031] mali ff9a0000.gpu: Failed to get regulator [ 0.511482] mali ff9a0000.gpu: Power control initialization failed [ 0.512096] platform ff9a0000.gpu: Driver mali requests probe deferral [ 0.512887] Unable to detect cache hierarchy from DT for CPU 0 [ 0.514171] brd: module loaded [ 0.519352] loop: module loaded [ 0.520183] zram: Added device: zram0 [ 0.520789] lkdtm: No crash points registered, enable through debugfs [ 0.522144] tun: Universal TUN/TAP device driver, 1.6 [ 0.522588] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 0.524408] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 0.525040] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 0.525538] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b). [ 0.526226] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 0.526760] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 0.532328] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 0.532771] Ring mode enabled [ 0.533050] DMA HW capability register supported [ 0.533447] Normal descriptors [ 0.533740] RX Checksum Offload Engine supported (type 2) [ 0.534226] TX Checksum insertion supported [ 0.534599] Wake-Up On Lan supported [ 0.534954] Enable RX Mitigation via HW Watchdog Timer [ 0.597930] libphy: stmmac: probed [ 0.598251] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active [ 0.598815] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01) [ 0.600288] PPP generic driver version 2.4.2 [ 0.600882] usbcore: registered new interface driver rndis_wlan [ 0.601593] Rockchip WiFi SYS interface (V1.00) ... [ 0.602074] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet dri ver [ 0.602757] usbcore: registered new interface driver pegasus [ 0.603299] usbcore: registered new interface driver rtl8150 [ 0.603828] usbcore: registered new interface driver r8152 [ 0.604362] usbcore: registered new interface driver asix [ 0.604866] usbcore: registered new interface driver ax88179_178a [ 0.605446] usbcore: registered new interface driver cdc_ether [ 0.606000] usbcore: registered new interface driver dm9601 [ 0.606529] usbcore: registered new interface driver smsc75xx [ 0.607085] usbcore: registered new interface driver smsc95xx [ 0.607617] usbcore: registered new interface driver net1080 [ 0.608159] usbcore: registered new interface driver rndis_host [ 0.608709] usbcore: registered new interface driver MOSCHIP usb-ethernet dri ver [ 0.609422] usbcore: registered new interface driver cdc_ncm [ 0.609948] usbcore: registered new interface driver qmi_wwan [ 0.610493] usbcore: registered new interface driver cdc_mbim [ 0.612175] platform fe800000.dwc3: Driver dwc3 requests probe deferral [ 0.612800] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3 [ 0.613491] platform usb@fe800000: Driver rockchip-dwc3 requests probe deferr al [ 0.617224] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd [ 0.618032] platform usb@fe900000: Driver rockchip-dwc3 requests probe deferr al [ 0.619447] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.620037] ehci-pci: EHCI PCI platform driver [ 0.620483] ehci-platform: EHCI generic platform driver [ 0.621197] platform fe380000.usb: Driver ehci-platform requests probe deferr al [ 0.623395] ehci-platform fe3c0000.usb: EHCI Host Controller [ 0.624047] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1 [ 0.624819] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000 [ 0.630992] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [ 0.631655] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.632265] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 0.632898] usb usb1: Product: EHCI Host Controller [ 0.633336] usb usb1: Manufacturer: Linux 4.4.55 ehci_hcd [ 0.633810] usb usb1: SerialNumber: fe3c0000.usb [ 0.634659] hub 1-0:1.0: USB hub found [ 0.635025] hub 1-0:1.0: 1 port detected [ 0.635874] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.636442] ohci-pci: OHCI PCI platform driver [ 0.636880] ohci-platform: OHCI generic platform driver [ 0.637596] platform fe3a0000.usb: Driver ohci-platform requests probe deferr al [ 0.638474] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [ 0.639225] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2 [ 0.640004] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000 [ 0.695120] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.695717] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 0.696361] usb usb2: Product: Generic Platform OHCI controller [ 0.696880] usb usb2: Manufacturer: Linux 4.4.55 ohci_hcd [ 0.697362] usb usb2: SerialNumber: fe3e0000.usb [ 0.698192] hub 2-0:1.0: USB hub found [ 0.698545] hub 2-0:1.0: 1 port detected [ 0.699706] usbcore: registered new interface driver cdc_acm [ 0.700216] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters [ 0.700953] usbcore: registered new interface driver cdc_wdm [ 0.701498] usbcore: registered new interface driver uas [ 0.702051] usbcore: registered new interface driver usb-storage [ 0.702647] usbcore: registered new interface driver usbserial [ 0.703196] usbcore: registered new interface driver usbserial_generic [ 0.703785] usbserial: USB Serial support registered for generic [ 0.704358] usbcore: registered new interface driver ch341 [ 0.704857] usbserial: USB Serial support registered for ch341-uart [ 0.705455] usbcore: registered new interface driver cp210x [ 0.705972] usbserial: USB Serial support registered for cp210x [ 0.706536] usbcore: registered new interface driver ftdi_sio [ 0.707068] usbserial: USB Serial support registered for FTDI USB Serial Devi ce [ 0.707782] usbcore: registered new interface driver keyspan [ 0.708308] usbserial: USB Serial support registered for Keyspan - (without f irmware) [ 0.709019] usbserial: USB Serial support registered for Keyspan 1 port adapt er [ 0.709679] usbserial: USB Serial support registered for Keyspan 2 port adapt er [ 0.710347] usbserial: USB Serial support registered for Keyspan 4 port adapt er [ 0.711028] usbcore: registered new interface driver option [ 0.711534] usbserial: USB Serial support registered for GSM modem (1-port) [ 0.712251] usbcore: registered new interface driver oti6858 [ 0.712766] usbserial: USB Serial support registered for oti6858 [ 0.713335] usbcore: registered new interface driver pl2303 [ 0.713841] usbserial: USB Serial support registered for pl2303 [ 0.714411] usbcore: registered new interface driver qcserial [ 0.714934] usbserial: USB Serial support registered for Qualcomm USB modem [ 0.715594] usbcore: registered new interface driver sierra [ 0.716111] usbserial: USB Serial support registered for Sierra USB modem [ 0.717470] usbcore: registered new interface driver iforce [ 0.718039] usbcore: registered new interface driver xpad [ 0.718786] usbcore: registered new interface driver usbtouchscreen [ 0.719672] i2c /dev entries driver [ 0.721156] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 0.721833] fan53555-reg: supplied by vcc5v0_sys [ 0.724507] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 0.725168] fan53555-reg: supplied by vcc5v0_sys [ 0.728165] rk808 0-001b: Pmic Chip id: 0x0 [ 0.731732] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 0.732336] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 0.732974] DCDC_REG1: supplied by vcc3v3_sys [ 0.734082] DCDC_REG2: supplied by vcc3v3_sys [ 0.734994] DCDC_REG3: supplied by vcc3v3_sys [ 0.735602] DCDC_REG4: supplied by vcc3v3_sys [ 0.736412] LDO_REG1: supplied by vcc3v3_sys [ 0.737856] LDO_REG2: supplied by vcc3v3_sys [ 0.739179] LDO_REG3: supplied by vcc3v3_sys [ 0.740484] LDO_REG4: supplied by vcc3v3_sys [ 0.741780] LDO_REG5: supplied by vcc3v3_sys [ 0.743121] LDO_REG6: supplied by vcc3v3_sys [ 0.744421] LDO_REG7: supplied by vcc3v3_sys [ 0.745720] LDO_REG8: supplied by vcc3v3_sys [ 0.747061] SWITCH_REG1: supplied by vcc3v3_sys [ 0.747692] SWITCH_REG2: supplied by vcc3v3_sys [ 0.751465] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ 0.752479] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800947 2000 [ 0.753724] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800947 4000 [ 0.754465] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940 000.hdmi; cannot claim for ff130000.i2c [ 0.755395] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22 [ 0.755984] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) fr om group i2c3-xfer on device rockchip-pinctrl [ 0.756954] rk3x-i2c ff130000.i2c: Error applying setting, reverse things bac k [ 0.757928] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff800947 6000 [ 0.768548] fusb302 4-0022: port 0 probe success [ 0.768992] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800947 8000 [ 0.770804] IR NEC protocol handler initialized [ 0.771218] IR RC5(x/sz) protocol handler initialized [ 0.771664] IR RC6 protocol handler initialized [ 0.772073] IR JVC protocol handler initialized [ 0.772473] IR Sony protocol handler initialized [ 0.772880] IR SANYO protocol handler initialized [ 0.773305] IR Sharp protocol handler initialized [ 0.773720] IR MCE Keyboard/mouse protocol handler initialized [ 0.774242] IR XMP protocol handler initialized [ 0.774714] usbcore: registered new interface driver uvcvideo [ 0.775227] USB Video Class driver (1.1.1) [ 0.776821] rockchip_cpu_avs: cluster0 leakage=20 adjust_volt=0 [ 0.777385] rockchip_cpu_avs: cluster1 leakage=32 adjust_volt=0 [ 0.779194] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, tem perature=2147483647 [ 0.780686] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-d [email]evel@redhat.com[/email] [ 0.781591] Bluetooth: Virtual HCI driver ver 1.5 [ 0.782123] Bluetooth: HCI UART driver ver 2.3 [ 0.782516] Bluetooth: HCI UART protocol H4 registered [ 0.782977] Bluetooth: HCI UART protocol LL registered [ 0.783426] Bluetooth: HCI UART protocol ATH3K registered [ 0.783959] usbcore: registered new interface driver bfusb [ 0.784502] usbcore: registered new interface driver btusb [ 0.789394] sdhci: Secure Digital Host Controller Interface driver [ 0.789937] sdhci: Copyright(c) Pierre Ossman [ 0.790341] Synopsys Designware Multimedia Card Interface Driver [ 0.791704] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode . [ 0.792379] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 0.792990] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 0.793531] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 0.794407] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 0.795188] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 0.795729] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 0.796551] platform fe310000.dwmmc: Driver dwmmc_rockchip requests probe def erral [ 0.797724] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode . [ 0.798384] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 0.798995] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 0.799537] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 0.800406] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 0.801221] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 0.802007] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 0.802793] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 0.814031] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 0.825047] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized [ 0.825857] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.828095] sdhci-arasan fe330000.sdhci: No vmmc regulator found [ 0.828621] sdhci-arasan fe330000.sdhci: No vqmmc regulator found [ 0.855155] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using A DMA [ 0.857816] hidraw: raw HID events driver (C) Jiri Kosina [ 0.859233] usbcore: registered new interface driver usbhid [ 0.859723] usbhid: USB HID core driver [ 0.861462] ashmem: initialized [ 0.864698] usbcore: registered new interface driver snd-usb-audio [ 0.879276] platform rt5640-sound: Driver asoc-simple-card requests probe def erral [ 0.880072] platform hdmi-codec: Driver asoc-simple-card requests probe defer ral [ 0.880824] platform spdif-sound: Driver asoc-simple-card requests probe defe rral [ 0.885835] u32 classifier [ 0.886116] Netfilter messages via NETLINK v0.30. [ 0.886627] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 0.887625] ctnetlink v0.93: registering with nfnetlink. [ 0.888295] ip_set: protocol 6 [ 0.888586] IPVS: Registered protocols () [ 0.889153] IPVS: Connection hash table configured (size=4096, memory=64Kbyte s) [ 0.889921] IPVS: Creating netns size=1592 id=0 [ 0.890381] IPVS: ipvs loaded. [ 0.891036] ip_tables: (C) 2000-2006 Netfilter Core Team [ 0.891669] Initializing XFRM netlink socket [ 0.893087] NET: Registered protocol family 10 [ 0.894817] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 0.895548] sit: IPv6 over IPv4 tunneling driver [ 0.896716] NET: Registered protocol family 17 [ 0.897151] NET: Registered protocol family 15 [ 0.897586] bridge: automatic filtering via arp/ip/ip6tables has been depreca ted. Update your scripts to load br_netfilter if you need this. [ 0.898728] Bridge firewalling registered [ 0.899321] mmc1: MAN_BKOPS_EN bit is not set [ 0.899556] Bluetooth: RFCOMM socket layer initialized [ 0.899590] Bluetooth: RFCOMM ver 1.11 [ 0.899609] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 0.899620] Bluetooth: HIDP socket layer initialized [ 0.899704] 8021q: 802.1Q VLAN Support v1.8 [ 0.899733] lib80211: common routines for IEEE802.11 drivers [ 0.899777] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 0.900312] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 0.900407] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354 [ 0.900410] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 0.900414] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gp io. [ 0.900480] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wa ke_irq = 3, flags = 0. [ 0.900484] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 0.900489] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 0.900566] [BT_RFKILL]: Enter rfkill_rk_init [ 0.901160] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_ gpios = 83. [ 0.901197] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_ gpio = 9. [ 0.901224] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_g pio = 90. [ 0.901251] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_h ost_irq = 4. [ 0.901704] [BT_RFKILL]: Request irq for bt wakeup host [ 0.901741] [BT_RFKILL]: BT_WAKE_HOST IRQ fired [ 0.901791] [BT_RFKILL]: ** disable irq [ 0.902003] [BT_RFKILL]: bt_default device registered. [ 0.902103] Key type dns_resolver registered [ 0.902907] Registered cp15_barrier emulation handler [ 0.903232] Registered setend emulation handler [ 0.904567] Loading compiled-in X.509 certificates [ 0.906356] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not a ssigned [ 0.909440] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8 008c41de0) [ 0.909659] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8 008c41de0) [ 0.910368] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports [ 0.910400] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver [ 0.910478] dwhdmi-rockchip ff940000.hdmi: Detected HDMI controller 0x21:0x1a :0xa0:0xc1 [ 0.911709] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff 8008c3d828) [ 0.912328] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffffff80 08c3e038) [ 0.912430] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin fa iled with error -2 [ 0.912451] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21 .10.2013). [ 0.912456] [drm:drm_vblank_init] No driver support for vblank timestamp quer y. [ 0.912620] rockchip-drm display-subsystem: failed to parse loader memory [ 0.933867] mmc1: new HS400 Enhanced strobe MMC card at address 0001 [ 0.935253] mmcblk1: mmc1:0001 BJNB4R 29.1 GiB [ 0.936212] mmcblk1boot0: mmc1:0001 BJNB4R partition 1 4.00 MiB [ 0.937298] mmcblk1boot1: mmc1:0001 BJNB4R partition 2 4.00 MiB [ 0.938031] usb 1-1: new high-speed USB device number 2 using ehci-platform [ 0.938815] mmcblk1rpmb: mmc1:0001 BJNB4R partition 3 4.00 MiB [ 0.939950] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 0.940452] trust: 0x000800000 -- 0x000c00000 (4 MB) [ 0.940930] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 0.941426] kernel: 0x001c00000 -- 0x003000000 (20 MB) [ 0.941909] backup: 0x003000000 -- 0x003400000 (4 MB) [ 0.942395] rootfs: 0x003400000 -- 0x747800000 (29764 MB) [ 0.942923] mmcblk1: p1 p2 p3 p4 p5 p6 [ 1.054836] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201 [ 1.055495] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.056148] usb 1-1: Product: USB 2.0 Hub [MTT] [ 1.057877] hub 1-1:1.0: USB hub found [ 1.058054] hub 1-1:1.0: 7 ports detected [ 1.133638] Console: switching to colour frame buffer device 240x67 [ 1.164751] rockchip-drm display-subsystem: fb0: frame buffer device [ 1.174272] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0 [ 1.175606] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_k base_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing pow er_model_simple. [ 1.177541] mali ff9a0000.gpu: Probed as mali0 [ 1.181848] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 1.182637] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus nu mber 3 [ 1.183460] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010 [ 1.184280] xhci-hcd xhci-hcd.6.auto: irq 229, io mem 0xfe800000 [ 1.184949] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.185558] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.186198] usb usb3: Product: xHCI Host Controller [ 1.186626] usb usb3: Manufacturer: Linux 4.4.55 xhci-hcd [ 1.187107] usb usb3: SerialNumber: xhci-hcd.6.auto [ 1.188052] hub 3-0:1.0: USB hub found [ 1.188404] hub 3-0:1.0: 1 port detected [ 1.189035] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 1.189639] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus nu mber 4 [ 1.190369] usb usb4: We don't know the algorithms for LPM for this host, dis abling LPM. [ 1.191164] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 1.191758] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.192399] usb usb4: Product: xHCI Host Controller [ 1.192827] usb usb4: Manufacturer: Linux 4.4.55 xhci-hcd [ 1.193309] usb usb4: SerialNumber: xhci-hcd.6.auto [ 1.194146] hub 4-0:1.0: USB hub found [ 1.194537] hub 4-0:1.0: 1 port detected [ 1.197419] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 1.197884] usb usb4: USB disconnect, device number 1 [ 1.222197] xhci-hcd xhci-hcd.6.auto: Host not halted after 16000 microsecond s. [ 1.222839] xhci-hcd xhci-hcd.6.auto: Host controller not halted, aborting re set. [ 1.223527] xhci-hcd xhci-hcd.6.auto: USB bus 4 deregistered [ 1.224177] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 1.224630] usb usb3: USB disconnect, device number 1 [ 1.225510] xhci-hcd xhci-hcd.6.auto: USB bus 3 deregistered [ 1.229790] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 1.230466] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus nu mber 3 [ 1.231286] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010 [ 1.232102] xhci-hcd xhci-hcd.7.auto: irq 230, io mem 0xfe900000 [ 1.232768] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.233373] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.234013] usb usb3: Product: xHCI Host Controller [ 1.234441] usb usb3: Manufacturer: Linux 4.4.55 xhci-hcd [ 1.234915] usb usb3: SerialNumber: xhci-hcd.7.auto [ 1.235777] hub 3-0:1.0: USB hub found [ 1.236141] hub 3-0:1.0: 1 port detected [ 1.236751] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 1.237364] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus nu mber 4 [ 1.238092] usb usb4: We don't know the algorithms for LPM for this host, dis abling LPM. [ 1.238878] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 1.239483] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.240120] usb usb4: Product: xHCI Host Controller [ 1.240549] usb usb4: Manufacturer: Linux 4.4.55 xhci-hcd [ 1.241030] usb usb4: SerialNumber: xhci-hcd.7.auto [ 1.241845] hub 4-0:1.0: USB hub found [ 1.242211] hub 4-0:1.0: 1 port detected [ 1.244859] ehci-platform fe380000.usb: EHCI Host Controller [ 1.245529] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5 [ 1.246338] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000 [ 1.251990] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 1.252655] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.253262] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.253893] usb usb5: Product: EHCI Host Controller [ 1.254330] usb usb5: Manufacturer: Linux 4.4.55 ehci_hcd [ 1.254803] usb usb5: SerialNumber: fe380000.usb [ 1.255703] hub 5-0:1.0: USB hub found [ 1.256070] hub 5-0:1.0: 1 port detected [ 1.257159] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 1.257986] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6 [ 1.258773] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000 [ 1.314686] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.315341] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 1.316012] usb usb6: Product: Generic Platform OHCI controller [ 1.316545] usb usb6: Manufacturer: Linux 4.4.55 ohci_hcd [ 1.317054] usb usb6: SerialNumber: fe3a0000.usb [ 1.319016] hub 6-0:1.0: USB hub found [ 1.319424] hub 6-0:1.0: 1 port detected [ 1.322669] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode . [ 1.323399] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 1.324044] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 1.324607] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 1.325525] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.326442] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 1.327022] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 1.328283] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq [ 1.340362] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 1.352560] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized [ 1.367520] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mappi ng ok [ 1.376524] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/ rt5640-sound/sound/card0/input0 [ 1.380568] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok [ 1.384770] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0 [ 1.385434] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22 [ 1.386092] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spd if-dit-hifi :-22 [ 1.386851] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -2 2 [ 1.387911] asoc-simple-card: probe of spdif-sound failed with error -22 [ 1.389423] [ 1.389492] dhd_module_init: in [ 1.389500] ======== bcm_wlan_set_plat_data ======== [ 1.389507] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 1.389516] host_oob_irq: 68 [ 1.389520] host_oob_irq_flags=0x4 [ 1.389523] dhd_wifi_platform_load: Enter [ 1.389555] Power-up adapter 'DHD generic adapter' [ 1.389643] wifi_platform_set_power = 1 [ 1.389647] ======== PULL WL_REG_ON HIGH! ======== [ 1.389652] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 1.389658] [WLAN_RFKILL]: wifi turn on power. -1 [ 1.393798] ======================================================= [ 1.394363] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 1.394916] ======================================================= [ 1.395483] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init. [ 1.396172] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 1.396591] [WLAN_RFKILL]: wifi turn on power. -1 [ 1.397022] RTL871X: module init start [ 1.397358] RTL871X: rtl8188eu v4.3.24_16705.20160509 [ 1.398035] usbcore: registered new interface driver rtl8188eu [ 1.398552] RTL871X: module init ret=0 [ 1.399707] mmc2: queuing unknown CIS tuple 0x80 (2 bytes) [ 1.400018] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 1.402487] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.403155] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:02 UTC (1358499002) [ 1.404723] mmc2: queuing unknown CIS tuple 0x80 (3 bytes) [ 1.408361] mmc2: queuing unknown CIS tuple 0x80 (7 bytes) [ 1.427179] vendor storage:20160801 ret = 0 MÏ 1.428092] [ 1.469710] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000 Hz, actual 50000000HZ div = 0)
如果是要点屏,就要下载对应的屏固件
接的hdmi啊
xxj 发表于 2017-10-24 09:53
接的hdmi啊
HDMI默认都是可以的吧。
