Replace Android with ubuntu 16.04
Hi,
I got a RK3399 board with Android. I want to install Ubuntu 16.04 instead. I struggled to get to bootloader. I got this manual http://en.t-firefly.com/index.php/doc/product/info/id/263.html . But still couldn’t make it work so far.
Now I can go to the boot menu. But when I choose the option to reboot to bootloader, the firefly board will boot back to Android again. I downloaded upgrade_tool on my Ubuntu 16.04 host PC, but it couldn’t talk to firefly board via USB-C.
/usr/local/bin$ sudo upgrade_tool ~/Documents/firefly/Firefly-rk3399_xubuntu1604_201707041527.img
No found any rockusb device,please plug device in!
Actually, My host Ubuntu did find a new device at Bus 001 Device 020: ID 2207:0006 .
/usr/local/bin$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 04f2:0833 Chicony Electronics Co., Ltd
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Does firefly board must be in bootloader when running upgrade_tool on a host Ubuntu machine?
thanks a lot for your help!
Steve
up
this command is err.
sudo upgrade_tool uf ~/Documents/firefly/Firefly-rk3399_xubuntu1604_201707041527.img
same issue.
adb devices found the device in the recovery mode, but upgrade_tool didn’t find it.
