[ 0.866230] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.866448] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.866519] [drm:rockchip_dp_bind] ERROR failed to find panel
[ 0.866539] rockchip-drm display-subsystem: failed to bind ff970000.edp (ops rockchip_dp_component_ops): -517
[ 0.866791] rockchip-drm display-subsystem: master bind failed: -517
[ 1.277165] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.277319] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.277434] rockchip-dp ff970000.edp: failed to get vcc regulator: -19
[ 1.277444] rockchip-dp ff970000.edp: failed to get vccio regulator: -19
[ 1.277493] rockchip-dp ff970000.edp: no DP phy configured
[ 1.277809] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops)
[ 1.278129] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.278151] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.278203] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 1.282572] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.282587] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.282597] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 1.282748] rockchip-drm display-subsystem: failed to parse loader memory
跟我遇到的问题一样,坐等大佬
你用的是什么dts, box的吗? 还有你把你的dts修改贴上来看看勒
帮顶,你解决了吗?没人遇到过吗
帮顶
该问题暂时有改善,根本原因是DTS配置没有对,导致屏或者backlight初始化失败,所以在bond的时候找不到屏。
請問dts配置如何?可否提供檔案參考配置edp,謝謝
你就看你硬件的那个需要配置的管脚,映射是否正确。还有是不是有时序要求。我之前遇到的问题是屏的使能管脚,导致backlight注册失败,所以出现这个问题
suntao945firefl 发表于 2018-4-16 16:56
你就看你硬件的那个需要配置的管脚,映射是否正确。还有是不是有时序要求。我之前遇到的问题是屏的使能管 …
謝謝回覆,看過電路圖對應設備樹設定,在LCD_EN腳位似乎有對應錯誤的狀況,修改後,並且將backlight屏蔽後,錯誤依舊,仍然會報出failed to find panel。
屏蔽backlight干嘛?你的backlight 注册有问题吗?你只有多加打印看哪里有问题?
楼主问题解决了吗?我遇到了和你一样的问题!
学习。。。
