我用的是android4.4最新的SDK编译出来的固件,wifi模块用的是AP6212
一开始android4.4新编译的固件wifi打不开,蓝牙也打不开
然后我更新了bcmdhd驱动,把android5.1系统中的bcmdhd驱动拷贝到4.4系统中编译
发现wifi可以正常使用了,但是蓝牙一直在重启
<6>[ 19.131599] [BT_RFKILL]: bt shut off power
<6>[ 19.741712] [BT_RFKILL]: ENABLE UART_RTS
<6>[ 19.850212] [BT_RFKILL]: DISABLE UART_RTS
<6>[ 19.850402] [BT_RFKILL]: bt turn on power
<4>[ 20.542349] 0,baud is:1500000
<4>[ 20.549114] 0,baud is:115200
<4>[ 20.557798] 0,baud is:1500000
<6>[ 22.083929] [BT_RFKILL]: bt shut off power
<6>[ 26.226284] [BT_RFKILL]: bt shut off power
<6>[ 26.838174] [BT_RFKILL]: ENABLE UART_RTS
<6>[ 26.944579] [BT_RFKILL]: DISABLE UART_RTS
<6>[ 26.944638] [BT_RFKILL]: bt turn on power
<4>[ 27.635389] 0,baud is:1500000
<4>[ 27.635772] 0,baud is:115200
<4>[ 27.644937] 0,baud is:1500000
<6>[ 29.188270] [BT_RFKILL]: bt shut off power
<6>[ 33.360244] [BT_RFKILL]: bt shut off power
<6>[ 33.970402] [BT_RFKILL]: ENABLE UART_RTS
<6>[ 34.078585] [BT_RFKILL]: DISABLE UART_RTS
<6>[ 34.080388] [BT_RFKILL]: bt turn on power
<4>[ 34.770943] 0,baud is:1500000
<4>[ 34.771346] 0,baud is:115200
<4>[ 34.781200] 0,baud is:1500000
<6>[ 36.312472] [BT_RFKILL]: bt shut off power
<6>[ 40.454917] [BT_RFKILL]: bt shut off power
<6>[ 41.065211] [BT_RFKILL]: ENABLE UART_RTS
<6>[ 41.173421] [BT_RFKILL]: DISABLE UART_RTS
<6>[ 41.173594] [BT_RFKILL]: bt turn on power
<4>[ 41.865124] 0,baud is:1500000
<4>[ 41.865503] 0,baud is:115200
<4>[ 41.874448] 0,baud is:1500000
底层没有打印关于蓝牙的出错信息,初始化看起来也是正常的,请问这是什么问题呢?
我们板子硬件是没有问题的,烧5.1的系统wifi蓝牙都可以正常使用。
wifi固件文件也替换了下面两个文件
fw_bcm43438a1.bin
nvram_ap6212.txt
