RK3288经常出现无规律的mipi屏花屏
各位大神,有没有遇到过类似的问题,mipi屏花屏,系统还正常运行,用totalcontrol连接电脑显示正常。出现花屏也没有什么规律。有没有大神帮忙分析一下
内核log如下:
<6>[ 0.000000] Booting Linux on physical CPU 0x500
<6>[ 0.000000] Initializing cgroup subsys cpu
<6>[ 0.000000] Initializing cgroup subsys cpuacct
<5>[ 0.000000] Linux version 3.10.0 (deng@deng-Inspiron-3668) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Mon Nov 6 10:13:37 CST 2017
<4>[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
<4>[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<6>[ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288
<4>[ 0.000000] rockchip_ion_reserve
<6>[ 0.000000] ion heap(drm): base(0) size(0) align(0)
<6>[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
<6>[ 0.000000] ion heap(vmalloc): base(0) size(0) align(0)
<6>[ 0.000000] cma: CMA: reserved 640 MiB at 58000000
<6>[ 0.000000] ion_reserve: cma reserved base 58000000 size 671088640
<6>[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
<4>[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
<4>[ 0.000000] Boot mode: REBOOT (6) flag: NORMAL (0xc3524200)
<7>[ 0.000000] On node 0 totalpages: 524288
<7>[ 0.000000] free_area_init_node: node 0, pgdat c0ccbc00, node_mem_map c0df5000
<7>[ 0.000000] Normal zone: 1024 pages used for memmap
<7>[ 0.000000] Normal zone: 0 pages reserved
<7>[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
<7>[ 0.000000] HighMem zone: 3072 pages used for memmap
<7>[ 0.000000] HighMem zone: 393216 pages, LIFO batch:31
<6>[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1e4a000 s13376 r8192 d15296 u36864
<7>[ 0.000000] pcpu-alloc: s13376 r8192 d15296 u36864 alloc=9*4096
<7>[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
<4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
<5>[ 0.000000] Kernel command line: vmalloc=496M console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00200000@0x0039A000(userdata),0x00020000@0x0059A000(radical_update),-@0x005BA000(user) storagemedia=emmc loader.timestamp=2016-08-04_15:11:35
<6>[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
<6>[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[ 0.000000] allocated 4194304 bytes of page_cgroup
<6>[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
<6>[ 0.000000] Memory: 2048MB = 2048MB total
<5>[ 0.000000] Memory: 1388300k/1388300k available, 708852k reserved, 917504K highmem
<5>[ 0.000000] Virtual kernel memory layout:
<5>[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
<5>[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
<5>[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
<5>[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
<5>[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
<5>[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
<5>[ 0.000000] .text : 0xc0008000 - 0xc0b6bd04 (11664 kB)
<5>[ 0.000000] .init : 0xc0b6c000 - 0xc0bc5440 ( 358 kB)
<5>[ 0.000000] .data : 0xc0bc6000 - 0xc0cd3240 (1077 kB)
<5>[ 0.000000] .bss : 0xc0cd3240 - 0xc0df463c (1157 kB)
<6>[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
<6>[ 0.000000] Preemptible hierarchical RCU implementation.
<6>[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
<6>[ 0.000000] NR_IRQS:16 nr_irqs:16 16
<4>[ 0.000000] rk_clk_tree_init start!
<3>[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
<3>[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
<4>[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0
<4>[ 0.000000] rkclk_init_clks: cnt_parent = 7
<4>[ 0.000000] rkclk_init_clks: cnt_rate = 28
<4>[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
<6>[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
<6>[ 0.000000] Switching to timer-based delay loop
<6>[ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
<6>[ 0.000000] process version: 3
<6>[ 0.000000] channel:0, lkg:12
<6>[ 0.000000] target-temp:80
<6>[ 0.000000] channel:2, lkg:0
<6>[ 0.000000] channel:1, lkg:10
<6>[ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
<6>[ 0.350397] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
<6>[ 0.350413] pid_max: default: 32768 minimum: 301
<6>[ 0.350528] Security Framework initialized
<6>[ 0.350544] SELinux: Initializing.
<7>[ 0.350580] SELinux: Starting in permissive mode
<6>[ 0.350616] Mount-cache hash table entries: 512
<6>[ 0.351257] Initializing cgroup subsys debug
<6>[ 0.351271] Initializing cgroup subsys memory
<6>[ 0.351298] Initializing cgroup subsys freezer
<6>[ 0.351326] CPU: Testing write buffer coherency: ok
<3>[ 0.351640] /cpus/cpu@0 missing clock-frequency property
<3>[ 0.351654] /cpus/cpu@1 missing clock-frequency property
<3>[ 0.351664] /cpus/cpu@2 missing clock-frequency property
<3>[ 0.351673] /cpus/cpu@3 missing clock-frequency property
<6>[ 0.351719] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
<6>[ 0.351769] Setting up static identity map for 0xc083ee40 - 0xc083ee98
<6>[ 0.354079] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1736 (version 3.1)
<4>[ 0.428605] CPU1: Booted secondary processor
<6>[ 0.428637] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
<4>[ 0.448274] CPU2: Booted secondary processor
<6>[ 0.448297] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
<4>[ 0.467991] CPU3: Booted secondary processor
<6>[ 0.468014] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
<6>[ 0.468117] Brought up 4 CPUs
<6>[ 0.468144] SMP: Total of 4 processors activated (192.00 BogoMIPS).
<6>[ 0.468153] CPU: All CPU(s) started in SVC mode.
<6>[ 0.468884] devtmpfs: initialized
<6>[ 0.473030] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
<6>[ 0.474106] pinctrl core: initialized pinctrl subsystem
<6>[ 0.474357] regulator-dummy: no parameters
<6>[ 0.498017] NET: Registered protocol family 16
<6>[ 0.499805] DMA: preallocated 256 KiB pool for atomic coherent allocations
<6>[ 0.500200] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0dcfacc (version 0.1)
<6>[ 0.500461] Registered FIQ tty driver
<6>[ 0.501782] console [ttyFIQ0] enabled
<6>[ 0.501977] Registered fiq debugger ttyFIQ0
<4>[ 0.502541] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
<4>[ 0.502565] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
<4>[ 0.502592] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
<4>[ 0.502612] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
<4>[ 0.502708] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
<4>[ 0.502776] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
<4>[ 0.502840] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
<4>[ 0.502906] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
<4>[ 0.502970] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
<4>[ 0.503035] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
<4>[ 0.503099] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
<4>[ 0.503164] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
<4>[ 0.503236] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
<4>[ 0.503306] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
<4>[ 0.503322] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
<4>[ 0.503336] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
<4>[ 0.503350] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
<7>[ 0.503430] gpiochip_add: registered GPIOs 0 to 31 on device: gpio0
<7>[ 0.503485] gpiochip_add: registered GPIOs 32 to 63 on device: gpio1
<7>[ 0.503537] gpiochip_add: registered GPIOs 64 to 95 on device: gpio2
<7>[ 0.503589] gpiochip_add: registered GPIOs 96 to 127 on device: gpio3
<7>[ 0.503648] gpiochip_add: registered GPIOs 128 to 159 on device: gpio4
<7>[ 0.503700] gpiochip_add: registered GPIOs 160 to 191 on device: gpio5
<7>[ 0.503752] gpiochip_add: registered GPIOs 192 to 223 on device: gpio6
<7>[ 0.503811] gpiochip_add: registered GPIOs 224 to 255 on device: gpio7
<7>[ 0.503864] gpiochip_add: registered GPIOs 256 to 287 on device: gpio8
<7>[ 0.503918] gpiochip_add: registered GPIOs 288 to 319 on device: gpio15
<4>[ 0.503947] rockchip_interrupts_register:bank_num=7
<4>[ 0.505922] rockchip_pinctrl_probe:init ok
<6>[ 0.513041] rk_iommu ff900800.iep_mmu: (iep) Enter
<6>[ 0.513132] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.513150] rk_iommu ff900800.iep_mmu: (iep) Initialized
<6>[ 0.513318] rk_iommu ff950800.vip_mmu: (vip) Enter
<6>[ 0.513390] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.513406] rk_iommu ff950800.vip_mmu: (vip) Initialized
<6>[ 0.513581] rk_iommu ff930300.vopb_mmu: (vopb) Enter
<6>[ 0.513654] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.513670] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
<6>[ 0.513840] rk_iommu ff940300.vopl_mmu: (vopl) Enter
<6>[ 0.513914] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.513931] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
<6>[ 0.514111] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
<6>[ 0.514186] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.514202] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
<6>[ 0.514373] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
<6>[ 0.514446] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.514463] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
<6>[ 0.514644] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
<6>[ 0.514726] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
<6>[ 0.514742] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
<6>[ 0.517065] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[ 0.517082] hw-breakpoint: maximum watchpoint size is 4 bytes.
<3>[ 0.517688] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
<4>[ 0.517725] DDR DEBUG: version 1.00 20150126
<4>[ 0.517756] DDR DEBUG: Channel a:
<4>[ 0.517766] DDR DEBUG: DDR3 Device
<4>[ 0.517781] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.517792] DDR DEBUG: Channel b:
<4>[ 0.517800] DDR DEBUG: DDR3 Device
<4>[ 0.517814] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
<4>[ 0.517826] DDR DEBUG: addr=0xcdd000
<4>[ 0.517837] DDR DEBUG: stride=9, size=256, halfcap=40000000
<4>[ 0.517848] DDR DEBUG: socAddr[0]=0xcdd000, socAddr[1]=0xcdd100
<4>[ 0.517859] DDR DEBUG: chAddr[0]=0xcdd000, chAddr[1]=0xcdd000
<4>[ 0.517872] DDR DEBUG: dtar[0]=0x5019b000, dtar[1]=0x5019b000
<4>[ 0.517929] DDR DEBUG: init success!!! freq=200MHz
<4>[ 0.517939] DDR DEBUG: Channel a:
<4>[ 0.517953] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.517969] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.517985] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.518001] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.518016] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.518028] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.518038] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<4>[ 0.518047] DDR DEBUG: Channel b:
<4>[ 0.518060] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.518076] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.518091] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.518107] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
<4>[ 0.518121] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
<4>[ 0.518132] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
<4>[ 0.518143] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
<6>[ 0.542204] bio: create slab at 0
<6>[ 0.542718] Rockchip hdmi driver version 2.0
<6>[ 0.542718] .
<5>[ 0.544045] SCSI subsystem initialized
<6>[ 0.544209] usbcore: registered new interface driver usbfs
<6>[ 0.544257] usbcore: registered new interface driver hub
<6>[ 0.544349] usbcore: registered new device driver usb
<7>[ 0.544630] of_get_named_gpio_flags exited with status 14
<7>[ 0.544665] of_get_named_gpio_flags exited with status 12
<7>[ 0.545843] of_get_named_gpio_flags exited with status 15
<7>[ 0.545861] of_get_named_gpio_flags exited with status 16
<6>[ 0.546411] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
<7>[ 0.546553] of_get_named_gpio_flags exited with status 260
<7>[ 0.546574] of_get_named_gpio_flags exited with status 261
<6>[ 0.546721] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
<7>[ 0.546818] of_get_named_gpio_flags exited with status 201
<7>[ 0.546836] of_get_named_gpio_flags exited with status 202
<6>[ 0.547193] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
<7>[ 0.547305] of_get_named_gpio_flags exited with status 81
<7>[ 0.547323] of_get_named_gpio_flags exited with status 80
<6>[ 0.547459] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
<7>[ 0.547561] of_get_named_gpio_flags exited with status 241
<7>[ 0.547580] of_get_named_gpio_flags exited with status 242
<6>[ 0.548290] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
<6>[ 0.548435] media: Linux media interface: v0.10
<6>[ 0.548478] Linux video capture interface: v2.00
<6>[ 0.548598] pps_core: LinuxPPS API ver. 1 registered
<6>[ 0.548612] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
<6>[ 0.548636] PTP clock support registered
<4>[ 0.548688] i2c-core: driver [bq24296] using legacy suspend method
<4>[ 0.548701] i2c-core: driver [bq24296] using legacy resume method
<4>[ 0.549465] ion_drm_heap_create: 0@0
<6>[ 0.549607] Rockchip ion module is successfully loaded (v1.1)
<6>[ 0.549785] Advanced Linux Sound Architecture Driver Initialized.
<6>[ 0.550182] Bluetooth: Core ver 2.16
<6>[ 0.550224] NET: Registered protocol family 31
<6>[ 0.550237] Bluetooth: HCI device and connection manager initialized
<6>[ 0.550256] Bluetooth: HCI socket layer initialized
<6>[ 0.550272] Bluetooth: L2CAP socket layer initialized
<6>[ 0.550300] Bluetooth: SCO socket layer initialized
<6>[ 0.550549] cfg80211: Calling CRDA to update world regulatory domain
<7>[ 0.551471] of_get_named_gpio_flags exited with status 228
<4>[ 0.552079] rk808_i2c_probe,line=1360
<4>[ 0.552613] rk808_pre_init,line=1229
<7>[ 0.562487] of_get_named_gpio_flags exited with status 4
<7>[ 0.562500] of_get_named_gpio_flags exited with status 11
<7>[ 0.562514] of_get_named_gpio_flags exited with status 227
<6>[ 0.562539] rk808_i2c_probe: rk808_pmic_sleep=0
<6>[ 0.562559] rk808_i2c_probe: rk808_pmic_usb_hub_reset=1
<6>[ 0.568900] vdd_arm: 712 ↔ 1500 mV at 1100 mV
<6>[ 0.574534] vdd_gpu: 712 ↔ 1500 mV at 850 mV
<6>[ 0.580993] rk_dcdc3: 1200 mV
<6>[ 0.587793] vccio: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.594245] rk_ldo1: 3300 mV
<6>[ 0.600704] rk_ldo2: 3300 mV
<6>[ 0.607173] rk_ldo3: 1000 mV
<6>[ 0.613624] rk_ldo4: 1800 mV
<6>[ 0.618072] vcc_sd: 1800 ↔ 3300 mV at 3300 mV
<6>[ 0.624548] rk_ldo6: 1000 mV
<6>[ 0.631012] rk_ldo7: 1800 mV
<4>[ 0.637466] rk_battery_charger_detect_cb , battery_charger_detect 1
<6>[ 0.637578] rk_ldo8: 3300 mV
<6>[ 0.640877] rk_ldo9: at 3300 mV
<6>[ 0.644160] rk_ldo10: at 3300 mV
<6>[ 0.646924] rk808_irq_init: rk808_pmic_irq=1
<4>[ 0.647260] i2c-core: driver [rk818] using legacy suspend method
<4>[ 0.647274] i2c-core: driver [rk818] using legacy resume method
<4>[ 0.647645] rk808_rtc_probe,line=540
<6>[ 0.664552] rk808-rtc rk808-rtc: rtc core: registered rk808 as rtc0
<4>[ 0.668068] rk808_rtc_probe:ok
<7>[ 0.668935] of_get_named_gpio_flags exited with status 13
<4>[ 0.668950] rockchip_i2s_probe : get fpga reset gpio - 13,active value = 1
<6>[ 0.669804] Switching to clocksource arch_sys_counter
<6>[ 0.693677] rga: Module initialized.
<6>[ 0.694420] rga2 ff920000.rga: rga ion client create success!
<6>[ 0.694583] rga: Driver loaded succesfully
<7>[ 0.694800] uboot-logo-on:0
<6>[ 0.694832] rk-fb rockchip-fb: rk fb ion client create success!
<6>[ 0.694848] rk-fb rockchip-fb: rockchip framebuffer driver probe
<6>[ 0.695153] rk-screen rk_screen.9: rockchip screen probe success
<6>[ 0.695354] rk32-dsi
<4>[ 0.695495] dsi->host.irq =51
<4>[ 0.695516] load mipi dsi chip:rk_mipi_dsi.0 id:3133302a
<4>[ 0.695527] mipi_dsi v1.3 2014-04-17
<6>[ 0.695555] rk32-mipi ff960000.mipi: rk mipi_dsi probe success!
<6>[ 0.695570] rk32-mipi ff960000.mipi: rockchip mipi_dsi v1.1 2014-06-17
<3>[ 0.696016] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
<6>[ 0.696241] graphics fb0: rockchip framebuffer registerd:fb0
<6>[ 0.696547] graphics fb1: rockchip framebuffer registerd:fb1
<6>[ 0.696716] graphics fb2: rockchip framebuffer registerd:fb2
<6>[ 0.696876] graphics fb3: rockchip framebuffer registerd:fb3
<6>[ 0.697600] rk3288-lcdc lcdc0: lcdc0: dclk:76000000>>fps:59
<4>[ 0.697618] dsi->phy.sys_clk =24000000
<6>[ 0.886354] rk3288-lcdc lcdc0: wakeup from standby!
<6>[ 0.902888] alloc_buffer:ion_phy_addr=0x58000000
<6>[ 0.909247] fb0:phy:58000000>>vir:e0991000>>len:0xc00000
<6>[ 0.909266] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
<3>[ 0.909451] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
<4>[ 0.909467] rk_fb_trsm_ops_get:un supported transmitter:0!
<6>[ 0.909715] graphics fb4: rockchip framebuffer registerd:fb4
<6>[ 0.910030] graphics fb5: rockchip framebuffer registerd:fb5
<6>[ 0.910203] graphics fb6: rockchip framebuffer registerd:fb6
<6>[ 0.910373] graphics fb7: rockchip framebuffer registerd:fb7
<6>[ 0.910390] fb4:phy:58000000>>vir:e0991000>>len:0xc00000
<6>[ 0.910406] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
<4>[ 0.910803] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.910946] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.911064] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.911184] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.911312] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.911440] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.912411] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.912578] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.913528] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.913679] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.914603] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.914755] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.915683] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.915831] rockchip_set_mux:warning ignore bank num 15
<4>[ 0.916768] rockchip_set_mux:warning ignore bank num 15
<6>[ 0.918229] NET: Registered protocol family 2
<6>[ 0.918901] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.918982] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
<6>[ 0.919058] TCP: Hash tables configured (established 4096 bind 4096)
<6>[ 0.919119] TCP: reno registered
<6>[ 0.919136] UDP hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.919162] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
<6>[ 0.919361] NET: Registered protocol family 1
<6>[ 0.920061] Unpacking initramfs…
<6>[ 0.990288] Freeing initrd memory: 1308K (c5bf0000 - c5d37000)
<6>[ 0.990970] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
<6>[ 0.991612] vcodec_service: probe device ff9a0000.vpu_service
<4>[ 0.991815] vcodec_service: No reset resource define
<6>[ 0.991992] vcodec_service: ff9a0000.vpu_service: power on
<6>[ 0.992082] vcodec_service: probe device ff9a0000.vpu_service
<6>[ 0.992101] vcodec_service: checking hw id 4831
<6>[ 0.992580] vcodec_service: ff9a0000.vpu_service: power off…
<6>[ 0.992625] vcodec_service: done
<6>[ 0.992636] vcodec_service: init success
<6>[ 0.992700] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.993033] vcodec_service: ff9c0000.hevc_service: power on
<6>[ 0.993093] vcodec_service: probe device ff9c0000.hevc_service
<6>[ 0.993110] vcodec_service: checking hw id 6867
<6>[ 0.993352] vcodec_service: ff9c0000.hevc_service: power off…
<6>[ 0.993394] vcodec_service: done
<6>[ 0.993404] vcodec_service: init success
<4>[ 0.993565] rknandbase v1.0 2014-03-31
<4>[ 0.993700] rknand: probe of ff400000.nandc0 failed with error -1
<4>[ 0.993836] rknand_driver:ret = 0
<6>[ 0.995971] audit: initializing netlink socket (disabled)
<5>[ 0.996022] type=2000 audit(0.650:1): initialized
<4>[ 0.996903] bounce pool size: 64 pages
<6>[ 1.001520] fuse init (API version 7.22)
<6>[ 1.001892] msgmni has been set to 954
<7>[ 1.001945] SELinux: Registering netfilter hooks
<6>[ 1.003679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
<6>[ 1.003698] io scheduler noop registered
<6>[ 1.003710] io scheduler deadline registered
<6>[ 1.003799] io scheduler cfq registered (default)
<6>[ 1.004081] lidar control probe begin.
<7>[ 1.004105] of_get_named_gpio_flags exited with status 177
<6>[ 1.004125] lidar control gpio request ret 0
<6>[ 1.004149] lidar control probe ok!
<7>[ 1.004956] of_get_named_gpio_flags exited with status 226
<6>[ 1.005291] hdmi2mipi probe begin!
<7>[ 1.005433] of_get_named_gpio_flags exited with status 172
<6>[ 1.005449] hdmi2mipi probe ok!
<4>[ 1.005565] hdmi2mipi reset, 172 → 1
<6>[ 1.006273] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
<4>[ 1.006966] IEP Driver loaded succesfully
<4>[ 1.007063] Module initialized.
<6>[ 1.007863] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 1.007884] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
<6>[ 1.009271] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
<6>[ 1.009290] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
<6>[ 1.009660] vdd_logic: 925 ↔ 1400 mV at 1000 mV
<4>[ 1.010008] rk_serial.c v1.8 2014-03-04
<6>[ 1.010250] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
<6>[ 1.010431] serial ff180000.serial: membase e1592000
<6>[ 1.010607] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
<6>[ 1.010786] serial ff190000.serial: membase e159c000
<6>[ 1.010955] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
<6>[ 1.011123] serial ff1b0000.serial: membase e159e000
<6>[ 1.011276] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 91) is a rk29_serial.4
<6>[ 1.011444] serial ff1c0000.serial: membase e15be000
<6>[ 1.014289] loop: module loaded
<6>[ 1.014670] zram: Created 1 device(s) …
<4>[ 1.014743] i2c-core: driver [mpu6050B1] using legacy suspend method
<4>[ 1.014756] i2c-core: driver [mpu6050B1] using legacy resume method
<6>[ 1.014773] mpu_init: Probe name mpu6050B1
<6>[ 1.014924] ak8963_mod_init: Probe name ak8963_mod
<6>[ 1.015253] earled probe begin!
<7>[ 1.015362] of_get_named_gpio_flags exited with status 245
<6>[ 1.015379] earled probe ok!
<4>[ 1.015397] earled reset, 245 → 1
<6>[ 1.015991] SCSI Media Changer driver v0.25
<3>[ 1.016198] rockchip-pinctrl ff770000.pinctrl: pin gpio5-14 already requested by ff1c0000.serial; cannot claim for ff110000.spi
<3>[ 1.016219] rockchip-pinctrl ff770000.pinctrl: pin-174 (ff110000.spi) status -22
<3>[ 1.016236] rockchip-pinctrl ff770000.pinctrl: could not request pin 174 on device rockchip-pinctrl
<3>[ 1.016251] rockchip-spi ff110000.spi: Error applying setting, reverse things back
<6>[ 1.016298] dws->regs: e15e2000
<4>[ 1.017200] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
<4>[ 1.017330] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000800,result=0xaa05
<4>[ 1.017348] _rockchip_pinconf_set:GPIO7-13,group=spi1-cs0, function=gpio7_spi1, type=3
<4>[ 1.017363] rk3288_calc_drv_reg_and_bit:GPIO7-13, drv_reg=0x74, bit=10
<4>[ 1.017377] _rockchip_pinconf_set:GPIO-7 13 data=0xc000000,type=3
<6>[ 1.017416] dws->regs: e15e4000
<4>[ 1.018191] rockchip_spi_probe:num_cs=1,bus_num=1,irq=77,freq=45692308 ok
<6>[ 1.018343] dws->regs: e15e6000
<4>[ 1.019044] rockchip_spi_probe:num_cs=2,bus_num=2,irq=78,freq=45692308 ok
<6>[ 1.019335] tun: Universal TUN/TAP device driver, 1.6
<6>[ 1.019348] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<4>[ 1.019474] vmac_init.
<3>[ 1.020054] stmmac_probe_config_dt: Can not read property: pmu_regulator.
<6>[ 1.020070] stmmac_probe_config_dt: clock input/output? (input).
<6>[ 1.020085] stmmac_probe_config_dt: TX delay(0x30).
<6>[ 1.020096] stmmac_probe_config_dt: RX delay(0x10).
<7>[ 1.020109] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.020123] of_get_named_gpio_flags exited with status 135
<7>[ 1.020132] of_get_named_gpio_flags: can’t parse gpios property
<6>[ 1.020143] stmmac_probe_config_dt: is rockchip,rk3288-gmac
<6>[ 1.020154] stmmc_pltfr_init:
<3>[ 1.020163] stmmc_pltfr_init: ERROR: Get power-gpio failed.
<6>[ 1.020179] stmmc_pltfr_init: init for RGMII
<6>[ 1.020191] tx delay=0x30
<6>[ 1.020191] rx delay=0x10
<6>[ 1.020207] tx delay=0x30
<6>[ 1.020207] rx delay=0x10
<6>[ 1.020654] stmmac - user ID: 0x10, Synopsys ID: 0x35
<6>[ 1.020667] Normal descriptors
<6>[ 1.020676] Ring mode enabled
<6>[ 1.020688] DMA HW capability register supported
<6>[ 1.020699] RX Checksum Offload Engine supported (type 2)
<6>[ 1.020710] TX Checksum insertion supported
<6>[ 1.020719] Wake-Up On Lan supported
<6>[ 1.020760] Enable RX Mitigation via HW Watchdog Timer
<6>[ 1.021238] PPP generic driver version 2.4.2
<6>[ 1.021385] PPP BSD Compression module registered
<6>[ 1.021399] PPP Deflate Compression module registered
<6>[ 1.021424] PPP MPPE Compression module registered
<6>[ 1.021437] NET: Registered protocol family 24
<6>[ 1.021475] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
<6>[ 1.021489] CSLIP: code copyright 1989 Regents of the University of California.
<4>[ 1.021503] Rockchip WiFi SYS interface (V1.00) …
<4>[ 1.021545] RTL871X: module init start
<4>[ 1.021557] RTL871X: rtl8188eu v4.3.0.8_13968.20150417
<4>[ 1.021568] RTL871X: build time: Nov 6 2017 10:10:23
<6>[ 1.021650] usbcore: registered new interface driver rtl8188eu
<4>[ 1.021661] RTL871X: module init ret=0
<4>[ 1.021673] esp_mem_init enter date Nov 6 2017 10:10:08
<4>[ 1.021683] esp_mem_init VERSION [V2.5]
<4>[ 1.021725] esp_mem_init complete
<6>[ 1.021796] usbcore: registered new interface driver catc
<6>[ 1.021836] usbcore: registered new interface driver kaweth
<6>[ 1.021849] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
<6>[ 1.021887] usbcore: registered new interface driver pegasus
<6>[ 1.021926] usbcore: registered new interface driver rtl8150
<6>[ 1.021964] usbcore: registered new interface driver r8152
<6>[ 1.021976] hso: drivers/net/usb/hso.c: Option Wireless
<6>[ 1.022047] usbcore: registered new interface driver hso
<6>[ 1.022091] usbcore: registered new interface driver asix
<6>[ 1.022129] usbcore: registered new interface driver ax88179_178a
<6>[ 1.022166] usbcore: registered new interface driver cdc_ether
<6>[ 1.022204] usbcore: registered new interface driver cdc_eem
<6>[ 1.022241] usbcore: registered new interface driver dm9601
<6>[ 1.022282] usbcore: registered new interface driver dm9620
<6>[ 1.022328] usbcore: registered new interface driver smsc75xx
<6>[ 1.022374] usbcore: registered new interface driver smsc95xx
<6>[ 1.022411] usbcore: registered new interface driver gl620a
<6>[ 1.022449] usbcore: registered new interface driver net1080
<6>[ 1.022487] usbcore: registered new interface driver plusb
<6>[ 1.022531] usbcore: registered new interface driver rndis_host
<6>[ 1.022570] usbcore: registered new interface driver cdc_subset
<6>[ 1.022608] usbcore: registered new interface driver zaurus
<6>[ 1.022647] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
<6>[ 1.022711] usbcore: registered new interface driver int51x1
<6>[ 1.022750] usbcore: registered new interface driver kalmia
<6>[ 1.022788] usbcore: registered new interface driver ipheth
<6>[ 1.022835] usbcore: registered new interface driver sierra_net
<6>[ 1.022875] usbcore: registered new interface driver cx82310_eth
<6>[ 1.022926] usbcore: registered new interface driver cdc_ncm
<6>[ 1.022966] usbcore: registered new interface driver qmi_wwan
<6>[ 1.023004] usbcore: registered new interface driver cdc_mbim
<6>[ 1.023017] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
<6>[ 1.025471] EHCI: ehci_rk_probe e1640000 e1640010
<6>[ 1.025491] rockchip_ehci_host ff500000.usb: EHCI Host Controller
<6>[ 1.025522] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
<6>[ 1.025836] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
<6>[ 1.043801] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
<6>[ 1.043896] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.043913] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.043928] usb usb1: Product: EHCI Host Controller
<6>[ 1.043941] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
<6>[ 1.043955] usb usb1: SerialNumber: ff500000.usb
<6>[ 1.044395] hub 1-0:1.0: USB hub found
<6>[ 1.044423] hub 1-0:1.0: 1 port detected
<6>[ 1.044594] EHCI: ehci_rk_probe ok
<6>[ 1.044723] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
<6>[ 1.044947] usbcore: registered new interface driver cdc_acm
<6>[ 1.044960] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[ 1.045020] usbcore: registered new interface driver usblp
<6>[ 1.045064] usbcore: registered new interface driver cdc_wdm
<6>[ 1.045130] usbcore: registered new interface driver usb-storage
<6>[ 1.045169] usbcore: registered new interface driver ums-alauda
<6>[ 1.045207] usbcore: registered new interface driver ums-cypress
<6>[ 1.045246] usbcore: registered new interface driver ums-datafab
<6>[ 1.045288] usbcore: registered new interface driver ums_eneub6250
<6>[ 1.045327] usbcore: registered new interface driver ums-freecom
<6>[ 1.045372] usbcore: registered new interface driver ums-isd200
<6>[ 1.045412] usbcore: registered new interface driver ums-jumpshot
<6>[ 1.045450] usbcore: registered new interface driver ums-karma
<6>[ 1.045488] usbcore: registered new interface driver ums-onetouch
<6>[ 1.045528] usbcore: registered new interface driver ums-sddr09
<6>[ 1.045568] usbcore: registered new interface driver ums-sddr55
<6>[ 1.045607] usbcore: registered new interface driver ums-usbat
<6>[ 1.045694] usbcore: registered new interface driver usbserial
<6>[ 1.045737] usbcore: registered new interface driver usbserial_generic
<6>[ 1.045775] usbserial: USB Serial support registered for generic
<6>[ 1.045818] usbcore: registered new interface driver option
<6>[ 1.045850] usbserial: USB Serial support registered for GSM modem (1-port)
<6>[ 1.045944] usbcore: registered new interface driver trancevibrator
<6>[ 1.045958] usb20_otg: version 3.10a 21-DEC-2012
<4>[ 1.046404] e1680040
<4>[ 1.046417] Core Release: 3.10a
<4>[ 1.046429] Setting default values for core params
<4>[ 1.046561] Using Buffer DMA mode
<4>[ 1.046574] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.046586] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.046598] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.046609] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 1.046622] Dedicated Tx FIFOs mode
<4>[ 1.046641] pcd_init otg_dev = dde8f900
<6>[ 1.046799] usb20_otg ff580000.usb: DWC OTG Controller
<6>[ 1.046828] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
<6>[ 1.046859] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
<6>[ 1.046918] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.046935] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.046949] usb usb2: Product: DWC OTG Controller
<6>[ 1.046962] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.046975] usb usb2: SerialNumber: ff580000.usb
<6>[ 1.047398] hub 2-0:1.0: USB hub found
<6>[ 1.047422] hub 2-0:1.0: 1 port detected
<6>[ 1.047768] usb20_host: version 3.10a 21-DEC-2012
<4>[ 1.050296] e1700040
<4>[ 1.050309] Core Release: 3.10a
<4>[ 1.050320] Setting default values for core params
<4>[ 1.050427] Using Buffer DMA mode
<4>[ 1.050439] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 1.050450] Multiprocessor Interrupt Enhancement - disabled
<4>[ 1.050461] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 1.050472] ^^^^^^^^^^^^^^^^^^Host Mode
<6>[ 1.050499] usb20_host ff540000.usb: DWC OTG Controller
<6>[ 1.050524] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
<6>[ 1.050553] usb20_host ff540000.usb: irq 57, io mem 0x00000000
<4>[ 1.050647] Init: Power Port (0)
<6>[ 1.050709] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
<6>[ 1.050726] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
<6>[ 1.050740] usb usb3: Product: DWC OTG Controller
<6>[ 1.050754] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
<6>[ 1.050767] usb usb3: SerialNumber: ff540000.usb
<6>[ 1.051167] hub 3-0:1.0: USB hub found
<6>[ 1.051190] hub 3-0:1.0: 1 port detected
<6>[ 1.051919] usbcore: registered new interface driver xpad
<6>[ 1.051982] usbcore: registered new interface driver usb_acecad
<6>[ 1.052032] usbcore: registered new interface driver aiptek
<6>[ 1.052080] usbcore: registered new interface driver gtco
<6>[ 1.052127] usbcore: registered new interface driver hanwang
<6>[ 1.052172] usbcore: registered new interface driver kbtab
<6>[ 1.052226] usbcore: registered new interface driver wacom
<4>[ 1.052238] <<-GTP-INFO->> GTP driver installing…
<4>[ 1.052248] —–
<4>[ 1.052506] ====>HERE WE IN THE GOODIX_TS_PROBE FUNCTION<======
<4>[ 1.052520] <<-GTP-INFO->> GTP Driver Version: V2.4<2014/11/28>
<4>[ 1.052533] <<-GTP-INFO->> GTP Driver Built@10:09:15, Nov 6 2017
<4>[ 1.052544] <<-GTP-INFO->> GTP I2C Address: 0x14
<7>[ 1.052567] of_get_named_gpio_flags exited with status 238
<7>[ 1.052579] of_get_named_gpio_flags exited with status 237
<4>[ 1.052588] <<-GTP-DEBUG->> [2457]Clock ticks for an esd cycle: 200
<4>[ 1.052646] rockchip_gpio_request:GPIO7-13
<4>[ 1.052660] rockchip_gpio_direction_input:GPIO7-13
<4>[ 1.052675] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x8205
<4>[ 1.052691] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to input,data=0x20081c,result=0x20081c
<4>[ 1.052709] rockchip_gpio_set:GPIO7-13 level = 0
<4>[ 1.052721] rockchip_gpio_direction_output:set GPIO7-13 level 0
<4>[ 1.052735] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x8205
<4>[ 1.052751] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x20281c,result=0x20281c
<4>[ 1.093004] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 1.093018] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 1.093034] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x8205
<4>[ 1.093049] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x20681c,result=0x20681c
<4>[ 1.112668] rockchip_gpio_direction_input:GPIO7-13
<4>[ 1.112686] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x8205
<4>[ 1.112701] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to input,data=0x20481c,result=0x20481c
<4>[ 1.142967] dwc_otg_hcd_suspend, usb device mode
<4>[ 1.172466] <<-GTP-INFO->> IC Version: 9271_1020
<4>[ 1.172484] <<-GTP-DEBUG->> [1370]Config Groups’ Lengths: 186, 0, 0, 0, 0, 0
<4>[ 1.173302] <<-GTP-INFO->> Sensor_ID: 2
<4>[ 1.173317] <<-GTP-INFO->> Config group0 used,length: 186
<4>[ 1.173731] <<-GTP-DEBUG->> [1455]Config Version: 71, 0x47; IC Config Version: 71, 0x47
<4>[ 1.173745] config[TRIGGER_LOC]:0x3d GTP_INT_TRIGGER:0
<4>[ 1.173757] <<-GTP-INFO->> Driver send config.
<4>[ 1.181021] <<-GTP-DEBUG->> [1571]X_MAX: 1280, Y_MAX: 800, TRIGGER: 0x00
<4>[ 1.191411] <<-GTP-INFO->> create proc entry gt9xx_config success
<4>[ 1.191425] <<-GTP-INFO->> Esd started
<6>[ 1.191600] input: gt9xx as /devices/virtual/input/input0
<4>[ 1.191798] <<-GTP-DEBUG->> [1770]INT trigger type:0
<4>[ 1.191907] <<-GTP-INFO->> GTP works in interrupt mode.
<4>[ 1.191925] <<-GTP-INFO->> Applied memory size:2562.
<4>[ 1.191937] <<-GTP-INFO->> I2C function: without pre and end cmd!
<4>[ 1.191964] <<-GTP-INFO->> Create proc entry success!
<4>[ 1.192021] THE VALUE OF i2c_add_driver=0
<4>[ 1.192318] sensor_register_slave:mma8452,id=17
<4>[ 1.192333] sensor_register_slave:gs_mc3230,id=23
<4>[ 1.192343] gsensor_init
<4>[ 1.192353] sensor_register_slave:mpu6880_acc,id=24
<4>[ 1.192365] sensor_register_slave:mpu6500_acc,id=25
<4>[ 1.192376] sensor_register_slave:cm3217,id=48
<4>[ 1.192388] sensor_register_slave:cm3218,id=49
<6>[ 1.192555] i2c /dev entries driver
<6>[ 1.193274] IR NEC protocol handler initialized
<6>[ 1.193288] IR RC5(x) protocol handler initialized
<6>[ 1.193298] IR RC6 protocol handler initialized
<6>[ 1.193309] IR JVC protocol handler initialized
<6>[ 1.193318] IR Sony protocol handler initialized
<6>[ 1.193348] IR RC5 (streamzap) protocol handler initialized
<6>[ 1.193361] IR SANYO protocol handler initialized
<6>[ 1.193372] IR MCE Keyboard/mouse protocol handler initialized
<6>[ 1.193530] usbcore: registered new interface driver uvcvideo
<6>[ 1.193542] USB Video Class driver (1.1.1)
<4>[ 1.193556] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
<4>[ 1.193836] <<-GTP-DEBUG->> [749]touch_num:0
<4>[ 1.193836]
<4>[ 1.193856] <<-GTP-DEBUG->> [919]2 touch_num:0 pre_touch:0
<4>[ 1.193856]
<4>[ 1.194628] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
<4>[ 1.194628]
<4>[ 1.194706] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
<4>[ 1.194857] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe15f8000 size: 0x4000)
<4>[ 1.195518] D1:camsys_platform_probe(1394): ff910000.isp memory:
<4>[ 1.195537] D1:camsys_platform_probe(1404): Register memory (phy: 0xff910000 vir: 0xe1620000 size: 0x10000)
<4>[ 1.195555] D1:camsys_platform_probe(1399): I2c memory (phy: 0x1deb5000 vir: 0xddeb5000 size: 0x1000)
<4>[ 1.195570] D1:camsys_init_ext_fsh_module(20): init external flash module
<4>[ 1.195582] D1:camsys_platform_probe(1419): Probe ff910000.isp device success
<6>[ 1.195958] not find test_power_init dev node
<4>[ 1.196009] i2c-core: driver [bq27320] using legacy suspend method
<4>[ 1.196022] i2c-core: driver [bq27320] using legacy resume method
<4>[ 1.196358] rockchip_temp_probe,line=362
<4>[ 1.212081] <<-GTP-DEBUG->> [749]touch_num:0
<4>[ 1.212081]
<4>[ 1.212103] <<-GTP-DEBUG->> [919]2 touch_num:0 pre_touch:0
<4>[ 1.212103]
<4>[ 1.230270] <<-GTP-DEBUG->> [749]touch_num:0
<4>[ 1.230270]
<4>[ 1.230289] <<-GTP-DEBUG->> [919]2 touch_num:0 pre_touch:0
<4>[ 1.230289]
<4>[ 1.248410] <<-GTP-DEBUG->> [749]touch_num:0
<4>[ 1.248410]
<4>[ 1.248428] <<-GTP-DEBUG->> [919]2 touch_num:0 pre_touch:0
<4>[ 1.248428]
<6>[ 1.250431] tsadc ff280000.tsadc: initialized
<6>[ 1.250807] device-mapper: uevent: version 1.0.3
<6>[ 1.251054] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
<6>[ 1.251383] Bluetooth: HCI UART driver ver 2.2
<6>[ 1.251400] Bluetooth: HCI H4 protocol initialized
<6>[ 1.251412] Bluetooth: HCILL protocol initialized
<6>[ 1.251423] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
<6>[ 1.251436] rtk_btusb: Register usb char device interface for BT driver
<6>[ 1.251616] usbcore: registered new interface driver rtk_btusb
<4>[ 1.251745] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(532000), use default, just enable dvfs
<4>[ 1.261146] cpufreq version 1.0, suspend freq 1200 MHz
<6>[ 1.261346] cpuidle: using governor ladder
<6>[ 1.261361] cpuidle: using governor menu
<6>[ 1.261398] Synopsys Designware Multimedia Card Interface Driver
<6>[ 1.261410] MHSC version = Ver 2.00 2015-06-10
<4>[ 1.261724] dw cru_regsbase addr 0x1d8.
<4>[ 1.261738] dw cru_reset_offset val 3.
<6>[ 1.261753] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
<3>[ 1.261796] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.262124] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
<4>[ 1.262313] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
<7>[ 1.262345] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.262447] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.279966] 1358..dw_mci_set_ios: no card. [mmc0]
<4>[ 1.299666] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
<6>[ 1.299705] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
<6>[ 1.299724] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
<4>[ 1.300014] dw cru_regsbase addr 0x1d8.
<4>[ 1.300026] dw cru_reset_offset val 0.
<6>[ 1.300041] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
<3>[ 1.300093] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.300815] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
<4>[ 1.300985] dw_mci_init_slot: fmin=400000, fmax=50000000 [mmc1]
<7>[ 1.301020] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.306573] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
<4>[ 1.306652] 1358..dw_mci_set_ios: no card. [mmc1]
<4>[ 1.319324] 1358..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.339049] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
<6>[ 1.339063] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
<4>[ 1.339343] dw cru_regsbase addr 0x1d8.
<4>[ 1.339353] dw cru_reset_offset val 1.
<6>[ 1.339363] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
<3>[ 1.339388] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
<6>[ 1.339572] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
<4>[ 1.339683] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
<7>[ 1.339702] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.339922] 1358..dw_mci_set_ios: no card. [mmc2]
<4>[ 1.358675] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.371486] mmc0: BKOPS_EN bit is not set
<6>[ 1.374018] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 52000000Hz, actual 50000000HZ div = 1)
<4>[ 1.374040] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
<4>[ 1.374461] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=8bits.[mmc0]
<6>[ 1.375483] mmc0: new high speed MMC card at address 0001
<6>[ 1.375751] mmcblk0: mmc0:0001 HAG4d 14.6 GiB
<6>[ 1.376053] uboot: 0x000400000 – 0x000800000 (4 MB)
<6>[ 1.376064] misc: 0x000800000 – 0x000c00000 (4 MB)
<6>[ 1.376073] resource: 0x000c00000 – 0x001c00000 (16 MB)
<6>[ 1.376082] kernel: 0x001c00000 – 0x002c00000 (16 MB)
<6>[ 1.376090] boot: 0x002c00000 – 0x004c00000 (32 MB)
<6>[ 1.376099] recovery: 0x004c00000 – 0x006c00000 (32 MB)
<6>[ 1.376108] backup: 0x006c00000 – 0x00a000000 (52 MB)
<6>[ 1.376117] cache: 0x00a000000 – 0x012000000 (128 MB)
<6>[ 1.376125] kpanic: 0x012000000 – 0x012400000 (4 MB)
<6>[ 1.376134] system: 0x012400000 – 0x072400000 (1536 MB)
<6>[ 1.376142] metadata: 0x072400000 – 0x073400000 (16 MB)
<6>[ 1.376151] userdata: 0x073400000 – 0x0b3400000 (1024 MB)
<6>[ 1.376159] radical_update: 0x0b3400000 – 0x0b7400000 (64 MB)
<6>[ 1.376168] user: 0x0b7400000 – 0x3ab400000 (12096 MB)
<6>[ 1.376196] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p141358..dw_mci_set_ios: no card. [mmc1]
<6>[ 1.378419] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
<6>[ 1.378433] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
<4>[ 1.378463] 1358..dw_mci_set_ios: no card. [mmc2]
<6>[ 1.378734] hidraw: raw HID events driver (C) Jiri Kosina
<6>[ 1.380187] usbcore: registered new interface driver usbhid
<6>[ 1.380198] usbhid: USB HID core driver
<6>[ 1.380306] ashmem: initialized
<6>[ 1.380419] logger: created 256K log ‘log_main’
<6>[ 1.380526] logger: created 256K log ‘log_events’
<6>[ 1.380627] logger: created 256K log ‘log_radio’
<6>[ 1.380720] logger: created 256K log ‘log_system’
<7>[ 1.381745] of_get_named_gpio_flags exited with status 5
<7>[ 1.381756] of_get_named_gpio_flags exited with status 5
<6>[ 1.381992] input: rk29-keypad as /devices/ff100000.adc/key.43/input/input1
<4>[ 1.383036] xfm_i2s_audio_probe
<6>[ 1.383421] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
<6>[ 1.385781] rockchip-xfm-i2s rockchip-xfm-i2s.33: rk-xfm-i2s-hifi ↔ ff890000.rockchip-i2s mapping ok
<4>[ 1.386452] client->name = cx20810_1
<7>[ 1.386468] of_get_named_gpio_flags exited with status 7
<4>[ 1.386475] i2c_cx20810_platdata_prase_dt : get cx20810 reset gpio - 7,active value = 1
<4>[ 1.386535] client->name = cx20810_0
<7>[ 1.386546] of_get_named_gpio_flags exited with status 7
<4>[ 1.386552] i2c_cx20810_platdata_prase_dt : get cx20810 reset gpio - 7,active value = 1
<7>[ 1.386562] _gpio_request: gpio-7 (i2c_cx20810_reset) status -16
<6>[ 1.387002] i2c_fpga 4-0040: i2c_driver_fpga_probe, probing i2c_fpga driver flags = 0
<7>[ 1.387017] of_get_named_gpio_flags exited with status 13
<4>[ 1.387024] i2c_fpga_platdata_parse_dt : get property: reset_gpio = 13
<7>[ 1.387036] of_get_named_gpio_flags exited with status 235
<4>[ 1.387042] i2c_fpga_platdata_parse_dt : get property: enb_gpio = 235
<4>[ 1.387265] rk_xfm10521_probe
<4>[ 1.387349] xyh disable_rockchip_i2s_mclk() disable mclk
<4>[ 1.388291] Timothy:send to cx20810 error : -11----0
<4>[ 1.388301] Timothy:cx20810[35] init error!
<4>[ 1.389239] Timothy:send to cx20810 error : -11----0
<4>[ 1.389247] Timothy:cx20810[3b] init error!
<4>[ 1.389257] xyh enable_rockchip_i2s_mclk() enable mclk
<4>[ 1.389266] rk_xfm10521_probe: fpga_dev name = fpga, cx0 name = cx20810_0, cx1 name = cx20810_1
<6>[ 1.389369] u32 classifier
<6>[ 1.389376] Actions configured
<6>[ 1.389389] Netfilter messages via NETLINK v0.30.
<6>[ 1.389447] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
<6>[ 1.389794] ctnetlink v0.93: registering with nfnetlink.
<6>[ 1.389868] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[ 1.389877] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[ 1.390144] xt_time: kernel timezone is -0000
<6>[ 1.390352] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.390494] arp_tables: (C) 2002 David S. Miller
<6>[ 1.390534] TCP: cubic registered
<6>[ 1.390542] Initializing XFRM netlink socket
<6>[ 1.390775] NET: Registered protocol family 10
<6>[ 1.391380] mip6: Mobile IPv6
<6>[ 1.391411] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[ 1.391529] sit: IPv6 over IPv4 tunneling driver
<6>[ 1.391886] NET: Registered protocol family 17
<6>[ 1.391915] NET: Registered protocol family 15
<5>[ 1.391970] Bridge firewalling registered
<6>[ 1.391983] Ebtables v2.0 registered
<6>[ 1.392144] Bluetooth: RFCOMM TTY layer initialized
<6>[ 1.392173] Bluetooth: RFCOMM socket layer initialized
<6>[ 1.392182] Bluetooth: RFCOMM ver 1.11
<6>[ 1.392189] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[ 1.392197] Bluetooth: BNEP filters: protocol multicast
<6>[ 1.392209] Bluetooth: BNEP socket layer initialized
<6>[ 1.392217] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[ 1.392230] Bluetooth: HIDP socket layer initialized
<6>[ 1.392257] l2tp_core: L2TP core driver, V2.0
<6>[ 1.392273] l2tp_ppp: PPPoL2TP kernel driver, V2.0
<6>[ 1.392282] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 1.392495] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 1.392506] [WLAN_RFKILL]: can’t find rockchip,grf property
<6>[ 1.392516] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
<6>[ 1.392526] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 1.392536] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 1.392545] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 1.392561] of_get_named_gpio_flags exited with status 156
<6>[ 1.392568] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
<7>[ 1.392577] of_get_named_gpio_flags: can’t parse gpios property
<7>[ 1.392585] of_get_named_gpio_flags exited with status 158
<6>[ 1.392592] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
<6>[ 1.392602] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 1.392628] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 1.392639] [WLAN_RFKILL]: Exit rfkill_wlan_probe
<6>[ 1.392691] [BT_RFKILL]: Enter rfkill_rk_init
<7>[ 1.392835] of_get_named_gpio_flags exited with status 147
<6>[ 1.392842] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
<7>[ 1.392855] of_get_named_gpio_flags exited with status 155
<6>[ 1.392862] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
<7>[ 1.392872] of_get_named_gpio_flags exited with status 157
<6>[ 1.392878] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
<7>[ 1.392889] of_get_named_gpio_flags exited with status 154
<6>[ 1.392895] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
<7>[ 1.392904] of_get_named_gpio_flags exited with status 159
<6>[ 1.392910] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
<6>[ 1.392960] [BT_RFKILL]: Request irq for bt wakeup host
<6>[ 1.393067] [BT_RFKILL]: ** disable irq
<6>[ 1.393151] [BT_RFKILL]: ap6335 device registered.
<4>[ 1.393906] rk3288_init_suspend
<4>[ 1.393921] rk3288_suspend_init enter
<4>[ 1.394104] rk3288_suspend_init: pm_ctrbits =200007
<4>[ 1.394136] gpio_get_dts_info suspend:4
<4>[ 1.394145] gpio_get_dts_info resume:4
<4>[ 1.394151] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.394184] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
<4>[ 1.394345] clks_gating_suspend_init:clkgt info ok
<5>[ 1.394455] Registering SWP/SWPB emulation handler
<6>[ 1.394836] ddrfreq: verion 1.2 20140526
<6>[ 1.394850] ddrfreq: normal 396MHz video_1080p 240MHz video_4k 396MHz dualview 396MHz idle 0MHz suspend 200MHz reboot 396MHz
<6>[ 1.394860] ddrfreq: auto-freq=0
<6>[ 1.394866] ddrfreq: auto-freq-table[0] 324MHz
<6>[ 1.394873] ddrfreq: auto-freq-table[1] 396MHz
<6>[ 1.394880] ddrfreq: auto-freq-table[2] 528MHz
<6>[ 1.408109] regulator-dummy: disabling
<4>[ 1.408197] =======================================================
<4>[ 1.408206] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
<4>[ 1.408212] =======================================================
<4>[ 1.408219] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
<4>[ 1.408268] dhd_module_init: in
<4>[ 1.408277] ======== bcm_wlan_set_plat_data ========
<6>[ 1.408284] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
<4>[ 1.408304] host_oob_irq: 198
<4>[ 1.408310] host_oob_irq_flags=4
<4>[ 1.408315] dhd_wifi_platform_load: Enter
<4>[ 1.408322] pcd_pullup, is_on 0
<4>[ 1.408344] Power-up adapter ‘DHD generic adapter’
<6>[ 1.408362] file system registered
<4>[ 1.408367] wifi_platform_set_power = 1
<4>[ 1.408372] ======== PULL WL_REG_ON HIGH! ========
<6>[ 1.408376] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 1.408380] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 1.408385] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 1.408952] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[ 1.408962] android_usb gadget: Number of LUNs=2
<6>[ 1.408970] lun0: LUN: removable file: (no medium)
<6>[ 1.408978] lun1: LUN: removable file: (no medium)
<6>[ 1.409128] android_usb gadget: android_usb ready
<6>[ 1.409188] sensor_init: Probe name sensors
<4>[ 1.409205] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
<6>[ 1.413289] rk808-rtc rk808-rtc: setting system clock to 2017-10-10 06:26:56 UTC (1507616816)
<7>[ 1.418469] of_get_named_gpio_flags exited with status 259
<3>[ 1.418492] /adc@ff100000/rockchip_headset: arguments longer than property
<7>[ 1.418500] of_get_named_gpio_flags: can’t parse gpios property
<4>[ 1.418510] rockchip_headset_probe() have not set adc chan
<4>[ 1.418517] rockchip_headset_probe() headset have no hook mode
<6>[ 1.418637] input: rockchip_headset.42 as /devices/ff100000.adc/rockchip_headset.42/input/input2
<6>[ 1.420701] rockchip-spdif-card rockchip-spdif-card.32: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
<6>[ 1.421446] usbcore: registered new interface driver snd-usb-audio
<6>[ 1.421455] ALSA device list:
<6>[ 1.421461] #0: RK-XFM-I2S
<6>[ 1.421467] #1: RK-SPDIF-CARD
<6>[ 1.421708] Freeing unused kernel memory: 356K (c0b6c000 - c0bc5000)
<7>[ 1.425445] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 1.427368] SELinux: 2048 avtab hash slots, 5368 rules.
<7>[ 1.427388] SELinux: 1 users, 2 roles, 442 types, 0 bools, 1 sens, 1024 cats
<7>[ 1.427396] SELinux: 86 classes, 5368 rules
<7>[ 1.428347] SELinux: Completing initialization.
<7>[ 1.428355] SELinux: Setting up existing superblocks.
<7>[ 1.428371] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<7>[ 1.428390] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>[ 1.428446] SELinux: initialized (dev bdev, type bdev), not configured for labeling
<7>[ 1.428459] SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>[ 1.428474] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.428490] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
<7>[ 1.428683] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>[ 1.440036] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>[ 1.440052] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>[ 1.440063] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
<7>[ 1.440075] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>[ 1.440094] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>[ 1.440147] SELinux: initialized (dev configfs, type configfs), not configured for labeling
<7>[ 1.440157] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.440178] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<6>[ 1.516120] [WLAN_RFKILL]: wifi turn on power. 156
<5>[ 1.519512] type=1403 audit(1507616816.600:2): policy loaded auid=4294967295 ses=4294967295
<11>[ 1.545288] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’
<11>[ 1.547165] init: invalid gid ‘trace’
<11>[ 1.645746] init: /dev/hw_random not found
<6>[ 1.645807] keychord: using input dev rk29-keypad for fevent
<7>[ 1.646290] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 1.646573] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.646851] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<7>[ 1.648071] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.648224] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>[ 1.649357] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
<11>[ 1.650565] init: /dev/hw_random not found
<14>[ 1.651541] fs_mgr: Running /sbin/resize2fs on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 1.652409] resize2fs: resize2fs 1.42.9 (28-Dec-2013)resize2fs: The filesystem is already 393216 blocks long. Nothing to do!resize2fs:
<4>[ 1.657274] EXT4-fs (mmcblk0p10): Ignoring removed nomblk_io_submit option
<6>[ 1.664679] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.664704] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 1.664769] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/system,/system,ext4)=0
<14>[ 1.666030] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/system
<14>[ 1.673686] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.673729] e2fsck: system: clean, 1871/83328 files, 112936/393216 blocks
<6>[ 1.679688] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
<7>[ 1.679710] SELinux: initialized (dev mmcblk0p10, type ext4), uses xattr
<14>[ 1.679758] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/system,target=/system,type=ext4)=0
<6>[ 1.686616] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 1.686638] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
<14>[ 1.686685] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/cache,target=/cache,type=ext4)=0
<4>[ 1.687101] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
<6>[ 1.693512] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.693529] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 1.693566] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,/metadata,ext4)=0
<14>[ 1.694724] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata
<14>[ 1.701072] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.701105] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/metadata: clean, 11/1024 files, 1102/4096 blocks
<6>[ 1.707966] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
<7>[ 1.707988] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
<14>[ 1.708034] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/metadata,target=/metadata,type=ext4)=0
<14>[ 1.708075] fs_mgr: Running /system/bin/fsck.f2fs -f /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<14>[ 1.709050] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file or directory
<14>[ 1.709089] fsck.f2fs: fsck.f2fs terminated by exit(255)
<14>[ 1.709341] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=f2fs)=-1
<4>[ 1.709742] EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
<6>[ 1.716066] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
<7>[ 1.716087] SELinux: initialized (dev mmcblk0p12, type ext4), uses xattr
<14>[ 1.716128] fs_mgr: check_fs(): mount(/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,/data,ext4)=0
<14>[ 1.717375] fs_mgr: Running /sbin/e2fsck on /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata
<4>[ 1.722753] wifi_platform_bus_enumerate device present 1
<4>[ 1.722763] ======== Card detection to detect SDIO card! ========
<6>[ 1.722771] mmc2:mmc host rescan start!
<14>[ 1.724438] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
<14>[ 1.724469] e2fsck: /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata: clean, 947/65536 files, 67264/262144 blocks
<6>[ 1.731195] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard,errors=panic
<7>[ 1.731217] SELinux: initialized (dev mmcblk0p12, type ext4), uses xattr
<14>[ 1.731257] fs_mgr: __mount(source=/dev/block/platform/ff0f0000.rksdmmc/by-name/userdata,target=/data,type=ext4)=0
<11>[ 1.731274] fs_mgr: mount_with_alternatives(): Mounted /dev/block/platform/ff0f0000.rksdmmc/by-name/userdata on /data with fs_type=ext4 instead of f2fs
<7>[ 1.731921] SELinux: initialized (dev functionfs, type functionfs), uses genfs_contexts
<6>[ 1.752776] arm_release_ver of this mali_ko is ‘r6p0-02rel0’, rk_ko_ver is ‘13’, built at ‘09:15:10’, on ‘Oct 22 2015’.
<6>[ 1.752852] mali ffa30000.gpu: Continuing without Mali clock control
<4>[ 1.752887] mali pd enabled
<4>[ 1.752896] clk enabled
<4>[ 1.755764] MALI_DVFS_STEP = 5, div_dvfs = 7
<6>[ 1.755775] mali_dvfs_infotbl[0].clock=99000,min_threshold=0,max_threshold=70
<6>[ 1.755784] mali_dvfs_infotbl[1].clock=198000,min_threshold=65,max_threshold=77
<6>[ 1.755792] mali_dvfs_infotbl[2].clock=297000,min_threshold=75,max_threshold=84
<6>[ 1.755799] mali_dvfs_infotbl[3].clock=417000,min_threshold=82,max_threshold=91
<6>[ 1.755807] mali_dvfs_infotbl[4].clock=480000,min_threshold=94,max_threshold=100
<6>[ 1.755900] gpufreq_input_connect
<3>[ 1.755909] turn on mali power
<6>[ 1.755917] kbase_platform_rk_init,register_reboot_notifier
<4>[ 1.755959] hrtimer: interrupt took 11375 ns
<6>[ 1.756056] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1
<6>[ 1.756833] mali ffa30000.gpu: Probed as mali0
<3>[ 1.758137] rk29_ipp: version magic '3.0.8+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 1.759170] rk29_ipp: version magic '3.0.36+ SMP preempt mod_unload ARMv7 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<3>[ 1.760124] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ’ should be ‘3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
<6>[ 1.761110] zram0: detected capacity change from 0 to 533413888
<6>[ 1.841600] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
<3>[ 1.906929] EXT4-fs (mmcblk0p12): Unrecognized mount option “background_gc=on” or missing value
<14>[ 1.918971] bat_cap: oldcap path is /sys/devices/ff100000.adc
<11>[ 1.919046] bat_cap: oldcap_path no exist
<6>[ 1.919199] binder: 142:142 transaction failed 29189, size 0-0
<11>[ 1.919718] init: Warning! Service displayd needs a SELinux domain defined; please fix!
<11>[ 1.923569] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
<11>[ 1.923589] init: cannot expand ‘${ro.serialno}’ while writing to ‘/sys/class/android_usb/android0/iSerial’
<11>[ 1.923788] init: using deprecated syntax for specifying property ‘ro.product.usbfactory’, use ${name} instead
<6>[ 1.924245] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.924255] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.924269] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.924275] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.924293] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.924300] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<6>[ 1.924312] rtk_btusb: btchr_open: BT usb char device is opening
<3>[ 1.924318] rtk_btusb: btchr_open: Failed to get hci dev[NULL]
<11>[ 1.931274] init: cannot find ‘/system/bin/debuggerd64’, disabling ‘debuggerd64’
<11>[ 1.932850] init: cannot find ‘/system/bin/install-recovery.sh’, disabling ‘flash_recovery’
<11>[ 1.933290] init: cannot find ‘/system/bin/bplus_helper’, disabling ‘bplus_helper’
<11>[ 1.933482] init: Warning! Service drmservice needs a SELinux domain defined; please fix!
<4>[ 1.939248] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
<4>[ 1.974019] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 1.975543] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 1.977072] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 1.979807] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<11>[ 2.005976] init: Warning! Service daemonsu needs a SELinux domain defined; please fix!
<11>[ 2.006274] init: cannot find ‘/system/bin/akmd’, disabling ‘akmd’
<5>[ 2.006349] type=1400 audit(1507616817.090:3): avc: denied { execute_no_trans } for pid=157 comm=“init” path=“/system/xbin/su” dev=“mmcblk0p10” ino=1870 scontext=u:r:init:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
<3>[ 2.007445] android_usb: already disabled
<6>[ 2.010083] read descriptors
<6>[ 2.010097] read strings
<4>[ 2.010126] pcd_pullup, is_on 1
<6>[ 2.033267] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 2.033294] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 2.033358] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
<4>[ 2.035004] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
<6>[ 2.035028] mmc2: new high speed SDIO card at address 0001
<4>[ 2.051203] bcmsdh_register: register client driver
<4>[ 2.051311] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 2.051392] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
<4>[ 2.051401] bus num (host idx)=2, slot num (rca)=1
<4>[ 2.051407] found adapter info ‘DHD generic adapter’
<4>[ 2.051642] F1 signature read @0x18000000=0x16224335
<4>[ 2.053659] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
<4>[ 2.053949] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
<4>[ 2.053995] wifi_platform_get_mac_addr
<4>[ 2.054003] ======== bcm_wlan_get_mac_address ========
<6>[ 2.054009] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 2.054020] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 2.054026] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 2.054038] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
<4>[ 2.054079] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
<4>[ 2.054388] wl_create_event_handler(): thread:wl_event_handler:a4 started
<4>[ 2.054393] tsk Enter, tsk = 0xdd6e149c
<4>[ 2.054536] dhd_attach(): thread:dhd_watchdog_thread:a5 started
<4>[ 2.054587] dhd_attach(): thread:dhd_dpc:a6 started
<4>[ 2.054599] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
<4>[ 2.054639] dhd_attach(): thread:dhd_rxf:a7 started
<4>[ 2.054652] dhd_deferred_work_init: work queue initialized
<4>[ 2.054768] dhdsdio_probe_init: set use_rxchain 1 from config.txt
<4>[ 2.060023] Dongle Host Driver, version 1.201.59.4 (r506368)
<4>[ 2.060023] Compiled in drivers/net/wireless/bcmdhd on Nov 6 2017 at 10:10:15
<4>[ 2.060371] Register interface [wlan0] MAC: b0:f1:ec:6b:a7:7c
<4>[ 2.060371]
<4>[ 2.060385] dhd_prot_ioctl : bus is down. we have nothing to do
<4>[ 2.060417] bcmsdh_oob_intr_unregister: Enter
<4>[ 2.060424] bcmsdh_oob_intr_unregister: irq is not registered
<4>[ 2.060434] dhd_txglom_enable: enable 0
<4>[ 2.060440] dhd_bus_devreset: WLAN OFF DONE
<4>[ 2.060478] wifi_platform_set_power = 0
<4>[ 2.060485] ======== PULL WL_REG_ON LOW! ========
<6>[ 2.060491] [WLAN_RFKILL]: rockchip_wifi_power: 0
<6>[ 2.165567] [WLAN_RFKILL]: wifi shut off power.
<6>[ 2.165589] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
<6>[ 2.165596] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<4>[ 2.165674] dhd_module_init: Exit err=0
<38>[ 2.485234] logd.auditd: start
<11>[ 2.903894] healthd: No charger supplies found
<12>[ 2.903912] healthd: No battery devices found
<6>[ 3.021643] EHCI: rk_ehci_hcd_enable, disable host controller
<4>[ 3.021660] dwc_otg_hcd_enable, enable host controller
<4>[ 3.125477] Using Buffer DMA mode
<4>[ 3.125492] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 3.125498] Multiprocessor Interrupt Enhancement - disabled
<4>[ 3.125505] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 3.125512] ^^^^^^^^^^^^^^^^^^Host Mode
<4>[ 3.169325] Init: Power Port (0)
<4>[ 3.169365] ff540000.usb resume, HPRT0:0x21401
<4>[ 3.307045] Indeed it is in host mode hprt0 = 00021501
<6>[ 3.484130] usb 3-1: new high-speed USB device number 2 using usb20_host
<4>[ 3.484213] Indeed it is in host mode hprt0 = 00001101
<6>[ 3.681103] usb 3-1: New USB device found, idVendor=0424, idProduct=2514
<6>[ 3.681121] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
<3>[ 3.681563] usb 3-1: can’t set config #1, error -71
<6>[ 3.710245] rk3288-lcdc lcdc0: blank mode:0
<4>[ 3.710259] <<-GTP-DEBUG->> [2717]Resume by fb notifier.
<4>[ 3.710262] <<-GTP-INFO->> System resume.
<4>[ 3.720495] <<-GTP-INFO->> GTP wakeup sleep.
<4>[ 3.759827] <<-GTP-INFO->> Driver send config.
<6>[ 5.471540] warning: `system_server’ uses 32-bit capabilities (legacy support in use)
<4>[ 6.704366] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 6.704390] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 6.704399] D1:camsys_open(739): camsys_marvin(ddeaf210) is opened!
<4>[ 6.704500] D1:camsys_extdev_register(243): Get RK30_PIN8_PA0(256) gpio(active: 0) for dev_id 0x4000000 success!
<4>[ 6.704515] D1:camsys_extdev_register(243): Get RK30_PIN0_PC1(17) gpio(active: 1) for dev_id 0x4000000 success!
<7>[ 6.704535] of_get_named_gpio_flags exited with status 237
<7>[ 6.704541] of_get_named_gpio_flags exited with status 237
<7>[ 6.704547] _gpio_request: gpio-237 (camsys_gpio) status -16
<4>[ 6.704556] rockchip_gpio_set:GPIO7-13 level = 1
<4>[ 6.704563] rockchip_gpio_direction_output:set GPIO7-13 level 1
<4>[ 6.704574] rk32_iomux_bit_op:GPIO7-13,reg=0x70,data=0xc000000,result=0x8205
<4>[ 6.704583] rockchip_pmx_gpio_set_direction:gpio_direction for pin 237 as gpio7-13 to output,data=0x20281c,result=0x20281c
<4>[ 6.704592] D1:camsys_mrv_iomux_cb(90): marvin pinctrl select: isp_mipi_fl
<4>[ 6.704615] D1:camsys_extdev_register(268): Extdev(dev_id: 0x4000000 dev_name: OV13850) register success
<4>[ 6.709679] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 210000000 Hz) in turn on
<4>[ 6.709692] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 6.709798] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 6.709831] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 12000000Hz) turn on
<4>[ 6.710904] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1
<4>[ 6.711974] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(256) set 1
<3>[ 6.713035] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<3>[ 6.716365] E:camsys_i2c_write(78): i2c write dev(addr:0x20) failed!
<3>[ 6.716990] E:camsys_ioctl(1028): iommu status not consistent,check the dts file ! isp:1,vpu:0
<3>[ 6.718185] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 6.718209] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<4>[ 6.718222] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<4>[ 6.719339] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 6.719408] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 6.721531] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 6.721548] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 6.721556] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 6.721564] D1:camsys_release(763): camsys_marvin(ddeaf210) is closed
<6>[ 8.935482] [otg id chg] last id -1 current id 1
<4>[ 8.935515] PortPower off
<4>[ 8.935524] rk_battery_charger_detect_cb , battery_charger_detect 6
<4>[ 9.035511] Using Buffer DMA mode
<4>[ 9.035535] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 9.035559] Multiprocessor Interrupt Enhancement - disabled
<4>[ 9.035567] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 9.035574] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 9.525904] rk_battery_charger_detect_cb , battery_charger_detect 0
<4>[ 10.529655] test : set_clk_later_work
<12>[ 15.127672] healthd: battery none chg=
<6>[ 15.455859] lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
<6>[ 15.455883] lowmemorykiller: oom_adj 0 => oom_score_adj 0
<6>[ 15.455891] lowmemorykiller: oom_adj 1 => oom_score_adj 58
<6>[ 15.455898] lowmemorykiller: oom_adj 2 => oom_score_adj 117
<6>[ 15.455904] lowmemorykiller: oom_adj 3 => oom_score_adj 176
<6>[ 15.455910] lowmemorykiller: oom_adj 9 => oom_score_adj 529
<6>[ 15.455916] lowmemorykiller: oom_adj 15 => oom_score_adj 1000
<6>[ 16.379175] acc_open
<6>[ 16.379204] acc_release
<4>[ 17.613151] phy_power_on: enable = 1
<4>[ 17.652559] Read the Ethernet MAC address from IDB:00:00:00:00:00:00
<4>[ 17.652595] eth0: device MAC address 42:f5:f8:ca:33:9e
<6>[ 17.656220] libphy: stmmac: probed
<4>[ 17.656229] eth0: No PHY found
<4>[ 18.046011] dwc_otg_hcd_resume, usb device mode
<4>[ 18.065006] Current WiFi chip is AP6210.
<4>[ 18.065090] Current WiFi chip is AP6210.
<4>[ 18.088943] Current WiFi chip is AP6210.
<4>[ 18.146182] dwc_otg_hcd_suspend, usb device mode
<4>[ 18.377221] dhd_open: Enter dd428800
<4>[ 18.377249]
<4>[ 18.377249] Dongle Host Driver, version 1.201.59.4 (r506368)
<4>[ 18.377249] Compiled in drivers/net/wireless/bcmdhd on Nov 6 2017 at 10:10:15
<4>[ 18.377264] wl_android_wifi_on in 1
<4>[ 18.377271] wl_android_wifi_on in 2: g_wifi_on=0
<4>[ 18.377278] wifi_platform_set_power = 1
<4>[ 18.377284] ======== PULL WL_REG_ON HIGH! ========
<6>[ 18.377290] [WLAN_RFKILL]: rockchip_wifi_power: 1
<6>[ 18.377296] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
<6>[ 18.377303] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
<6>[ 18.480285] [WLAN_RFKILL]: wifi turn on power. 156
<4>[ 18.686933] sdio_reset_comm():
<6>[ 18.689948] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
<4>[ 18.689975] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
<4>[ 18.709227] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
<4>[ 18.712240] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 18.715242] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
<4>[ 18.720659] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
<6>[ 18.825168] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
<4>[ 18.825214] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
<4>[ 18.825560]
<4>[ 18.825560]
<4>[ 18.825560] dhd_bus_devreset: == WLAN ON ==
<4>[ 18.825678] F1 signature read @0x18000000=0x16224335
<4>[ 18.828061] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
<4>[ 18.828473] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
<4>[ 18.828633] dhdsdio_probe_init: set use_rxchain 1 from config.txt
<4>[ 18.884889] dhd_conf_read_config: Ignore config file /system/etc/firmware/config.txt
<4>[ 18.884916] dhd_conf_set_fw_name_by_chip: firmware_path=/system/etc/firmware/fw_bcm4339a0_ag.bin,nv_path=/system/etc/firmware/nvram_AP6335.txt
<4>[ 18.884927] Final fw_path=/system/etc/firmware/fw_bcm4339a0_ag.bin
<4>[ 18.884934] Final nv_path=/system/etc/firmware/nvram_AP6335.txt
<4>[ 18.884940] Final conf_path=/system/etc/firmware/config.txt
<4>[ 18.970546] NVRAM version: AP6335_NVRAM_V1.7_04102014
<4>[ 18.971221] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
<4>[ 19.100956] FAT-fs (mmcblk0p14): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
<7>[ 19.101023] SELinux: initialized (dev mmcblk0p14, type vfat), uses genfs_contexts
<4>[ 19.143723] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
<4>[ 19.149544] bcmsdh_oob_intr_register: Enter
<4>[ 19.149596] bcmsdh_oob_intr_register: HW_OOB enabled
<4>[ 19.149627] bcmsdh_oob_intr_register OOB irq=198 flags=4
<4>[ 19.149737] bcmsdh_oob_intr_register: enable_irq_wake
<4>[ 19.150619] dhd_conf_set_band: Set band 0
<4>[ 19.150754] wifi_platform_get_mac_addr
<4>[ 19.150763] ======== bcm_wlan_get_mac_address ========
<6>[ 19.150770] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
<6>[ 19.150779] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
<6>[ 19.150785] [WLAN_RFKILL]: This mac address is not valid, ignored…
<4>[ 19.160091] Firmware up: op_mode=0x0005, MAC=b0:f1:ec:6b:a7:7c
<4>[ 19.160107] dhd_conf_set_country: Set country CN, revision 38
<4>[ 19.205199] Country code: CN (CN/38)
<4>[ 19.205381] dhd_conf_set_roam: Set roam_off 1
<4>[ 19.207017] dhd_conf_set_txbf: set txbf 1
<4>[ 19.213871] Firmware version = wl0: Apr 3 2014 12:12:42 version 6.37.32.28.2_ip (r424058)
<4>[ 19.213885] Driver: 1.201.59.4 (r506368)
<4>[ 19.213885] Firmware: wl0: Apr 3 2014 12:12:42 version 6.37.32.28.2_ip (r424058)
<4>[ 19.214055] dhd_txglom_enable: enable 1
<4>[ 19.214062] dhd_conf_set_disable_proptx: set disable_proptx 0
<4>[ 19.215063] dhd_wlfc_hostreorder_init(): successful bdcv2 tlv signaling, 64
<4>[ 19.217831] wl_android_wifi_on: Success
<4>[ 19.272392] dhd_open: Exit ret=0
<11>[ 19.322460] init: no such service ‘fuse_internal_sd’
<4>[ 19.389742] WLC_E_IF: NO_IF set, event Ignored
<6>[ 19.421785] pm policy 0 → 1
<4>[ 19.600025] Current WiFi chip is AP6210.
<4>[ 19.616077] dhd_pktfilter_offload_set: failed to add pktfilter 102 0 0 0 0xFFFFFF 0x01005E, retcode = -2
<6>[ 19.930483] bio: create slab at 1
<4>[ 19.958178] dhd_set_suspend: Remove extra suspend setting
<6>[ 19.959000] EXT4-fs (dm-0): mounted filesystem without journal. Opts: (null)
<7>[ 19.959022] SELinux: initialized (dev dm-0, type ext4), uses xattr
<6>[ 21.248326] EXT4-fs (dm-0): re-mounted. Opts: (null)
<6>[ 21.271407] EXT4-fs (dm-0): re-mounted. Opts: (null)
<4>[ 22.381571] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 22.381593] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 22.381602] D1:camsys_open(739): camsys_marvin(ddeaf210) is opened!
<3>[ 22.381774] E:camsys_ioctl(1028): iommu status not consistent,check the dts file ! isp:1,vpu:0
<4>[ 22.382003] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000 Hz) in turn on
<4>[ 22.382015] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 22.382121] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 22.382133] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 22.382504] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 22.384570] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 22.385254] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<3>[ 22.385340] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 22.385432] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<3>[ 22.386500] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 22.386514] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 22.386630] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<3>[ 22.386712] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 22.386800] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<3>[ 22.387879] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 22.387891] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 22.387934] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 12000000Hz) turn on
<4>[ 22.388029] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1
<3>[ 22.388121] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 22.388266] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(256) set 1
<3>[ 22.389337] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 22.389349] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 22.690183] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
<3>[ 22.690208] W:camsys_phy_ops(478): mipiphy->phy_index(-1198254612) != extdev->phy.info.mipi.phy_index(0)!
<4>[ 22.690419] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(0) turn on(lane: 0x3 bit_rate: 600Mbps)
<4>[ 22.797653] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
<4>[ 22.805935] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 22.806040] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<3>[ 22.806122] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 22.806209] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<3>[ 22.807271] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 22.807284] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 22.810210] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 22.810313] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<3>[ 22.810397] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 22.810485] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<3>[ 22.811548] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 22.811559] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 22.811598] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 22.811610] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 22.811618] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 22.811626] D1:camsys_release(763): camsys_marvin(ddeaf210) is closed
<38>[ 25.443885] type=1400 audit(1507616840.910:4): avc: denied { read } for pid=1011 comm=“obot.uurobot_u5” name=“ttyS3” dev=“tmpfs” ino=8625 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:serial_device:s0 tclass=chr_file permissive=1
<38>[ 25.444117] type=1400 audit(1507616840.910:5): avc: denied { write } for pid=1011 comm=“obot.uurobot_u5” name=“ttyS3” dev=“tmpfs” ino=8625 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:serial_device:s0 tclass=chr_file permissive=1
<38>[ 25.444206] type=1400 audit(1507616840.910:6): avc: denied { open } for pid=1011 comm=“obot.uurobot_u5” path=“/dev/ttyS3” dev=“tmpfs” ino=8625 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:serial_device:s0 tclass=chr_file permissive=1
<38>[ 25.444312] type=1400 audit(1507616840.910:7): avc: denied { ioctl } for pid=1011 comm=“obot.uurobot_u5” path=“/dev/ttyS3” dev=“tmpfs” ino=8625 ioctlcmd=5401 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:serial_device:s0 tclass=chr_file permissive=1
<38>[ 25.451412] type=1400 audit(1507616840.920:8): avc: denied { execute } for pid=1088 comm=“obot.uurobot_u5” name=“su” dev=“mmcblk0p10” ino=1870 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
<38>[ 25.451595] type=1400 audit(1507616840.920:9): avc: denied { read open } for pid=1088 comm=“obot.uurobot_u5” path=“/system/xbin/su” dev=“mmcblk0p10” ino=1870 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
<38>[ 25.451723] type=1400 audit(1507616840.920:10): avc: denied { execute_no_trans } for pid=1088 comm=“obot.uurobot_u5” path=“/system/xbin/su” dev=“mmcblk0p10” ino=1870 scontext=u:r:untrusted_app:s0 tcontext=u:object_r:su_exec:s0 tclass=file permissive=1
<38>[ 25.470893] type=1400 audit(1507616840.940:11): avc: denied { connectto } for pid=1090 comm=“su” path=005355504552555345520000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 scontext=u:r:untrusted_app:s0 tcontext=u:r:init:s0 tclass=unix_stream_socket permissive=1
<38>[ 25.517820] type=1400 audit(1507616840.990:12): avc: denied { sys_ptrace } for pid=1104 comm=“su” capability=19 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=1
<38>[ 25.547645] type=1400 audit(1496989640.000:13): avc: denied { sigchld } for pid=1104 comm=“sh” scontext=u:r:zygote:s0 tcontext=u:r:init_shell:s0 tclass=process permissive=1
<38>[ 25.569498] type=1400 audit(1496989640.020:14): avc: denied { sigchld } for pid=1104 comm=“sh” scontext=u:r:zygote:s0 tcontext=u:r:init_shell:s0 tclass=process permissive=1
<11>[ 25.615466] init: untracked pid 1096 exited with status 127
<38>[ 25.958022] type=1400 audit(1496989640.410:15): avc: denied { call } for pid=1108 comm=“main” scontext=u:r:zygote:s0 tcontext=u:r:servicemanager:s0 tclass=binder permissive=1
<38>[ 25.958784] type=1400 audit(1496989640.410:16): avc: denied { search } for pid=144 comm=“servicemanager” name=“1108” dev=“proc” ino=11519 scontext=u:r:servicemanager:s0 tcontext=u:r:zygote:s0 tclass=dir permissive=1
<38>[ 25.959256] type=1400 audit(1496989640.410:17): avc: denied { read } for pid=144 comm=“servicemanager” name=“current” dev=“proc” ino=10877 scontext=u:r:servicemanager:s0 tcontext=u:r:zygote:s0 tclass=file permissive=1
<38>[ 25.959667] type=1400 audit(1496989640.410:18): avc: denied { open } for pid=144 comm=“servicemanager” path=“/proc/1108/attr/current” dev=“proc” ino=10877 scontext=u:r:servicemanager:s0 tcontext=u:r:zygote:s0 tclass=file permissive=1
<38>[ 25.960057] type=1400 audit(1496989640.410:19): avc: denied { getattr } for pid=144 comm=“servicemanager” scontext=u:r:servicemanager:s0 tcontext=u:r:zygote:s0 tclass=process permissive=1
<38>[ 25.976506] type=1400 audit(1496989640.430:20): avc: denied { call } for pid=1108 comm=“main” scontext=u:r:zygote:s0 tcontext=u:r:system_server:s0 tclass=binder permissive=1
<38>[ 25.977140] type=1400 audit(1496989640.430:21): avc: denied { transfer } for pid=1108 comm=“main” scontext=u:r:zygote:s0 tcontext=u:r:system_server:s0 tclass=binder permissive=1
<4>[ 26.058705] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 26.058720] D1:camsys_mipiphy_clkin_cb(34): camsys_marvin mipi phy clk in turn on
<4>[ 26.058728] D1:camsys_open(739): camsys_marvin(ddeaf210) is opened!
<3>[ 26.058882] E:camsys_ioctl(1028): iommu status not consistent,check the dts file ! isp:1,vpu:0
<4>[ 26.062218] D1:camsys_mrv_clkin_cb(350): camsys_marvin clock(f: 420000000 Hz) in turn on
<4>[ 26.062233] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 26.062340] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 26.062356] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 26.062431] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 1
<4>[ 26.064498] D1:camsys_rk3288_cfg(267): Isp_SoftRst: 0
<4>[ 26.064927] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<3>[ 26.065019] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 26.065121] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<3>[ 26.066188] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 26.066204] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 26.066306] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<3>[ 26.066391] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 26.066481] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<3>[ 26.067549] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 26.067562] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 26.067607] D1:camsys_mrv_clkout_cb(392): camsys_marvin clock out(rate: 12000000Hz) turn on
<4>[ 26.067701] D1:camsys_sysctl_extdev(360): Sysctl 11 success, gpio(17) set 1
<3>[ 26.067784] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 26.067871] D1:camsys_sysctl_extdev(364): Sysctl 8 success, gpio(256) set 1
<3>[ 26.068941] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 26.068955] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 26.384054] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
<3>[ 26.384080] W:camsys_phy_ops(478): mipiphy->phy_index(-1198202036) != extdev->phy.info.mipi.phy_index(0)!
<4>[ 26.384289] D1:camsys_rk3288_mipihpy_cfg(219): mipi phy(0) turn on(lane: 0x3 bit_rate: 600Mbps)
<4>[ 26.505746] D1:camsys_rk3288_mipihpy_cfg(104): mipi phy 0 standby!
<4>[ 26.515312] D1:camsys_mrv_clkout_cb(404): camsys_marvin clock out turn off
<4>[ 26.515427] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<3>[ 26.515515] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 26.515602] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<3>[ 26.517087] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 26.517100] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 26.519322] D1:camsys_mrv_clkin_cb(374): camsys_marvin clock in turn off
<4>[ 26.519429] D1:camsys_sysctl_extdev(364): Sysctl 11 success, gpio(17) set 0
<3>[ 26.520072] E:camsys_sysctl_extdev(367): Sysctl 7 failed, because gpio is NULL!
<4>[ 26.520167] D1:camsys_sysctl_extdev(360): Sysctl 8 success, gpio(256) set 0
<3>[ 26.521719] E:camsys_sysctl_extdev(367): Sysctl 9 failed, because gpio is NULL!
<3>[ 26.521738] E:camsys_sysctl_extdev(367): Sysctl 10 failed, because gpio is NULL!
<4>[ 26.521785] D1:camsys_irq_disconnect(664): All thread disconnect camsys_marvin irq success!
<4>[ 26.521798] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 26.521806] D1:camsys_mipiphy_clkin_cb(36): camsys_marvin mipi phy clk in turn off
<4>[ 26.521814] D1:camsys_release(763): camsys_marvin(ddeaf210) is closed
<38>[ 37.551764] type=1400 audit(1496989652.200:22): avc: denied { call } for pid=469 comm=“ActivityManager” scontext=u:r:system_server:s0 tcontext=u:r:zygote:s0 tclass=binder permissive=1
<4>[ 37.654222] soc_pcm_hw_params : dai_link.codec.name is rk-hdmi-spdif-hifi,rate = 44100
<4>[ 37.654246] -------spdif_hw_params--------
<4>[ 37.654254] ****spdif_dump
<4>[ 37.654260] SPDIF_CHNSR00_ADDR = 0
<4>[ 37.654266] SPDIF_CHNSR01_ADDR = 0
<4>[ 37.654271] SPDIF_CHNSR02_ADDR = 0
<4>[ 37.654276] SPDIF_CHNSR03_ADDR = 0
<4>[ 37.654281] SPDIF_CHNSR04_ADDR = 0
<4>[ 37.654286] SPDIF_CHNSR05_ADDR = 0
<4>[ 37.654292] SPDIF_CHNSR06_ADDR = 0
<4>[ 37.654297] SPDIF_CHNSR07_ADDR = 0
<4>[ 37.654302] SPDIF_CHNSR08_ADDR = 0
<4>[ 37.654307] SPDIF_CHNSR09_ADDR = 0
<4>[ 37.654312] SPDIF_CHNSR10_ADDR = 0
<4>[ 37.654317] SPDIF_CHNSR11_ADDR = 0
<4>[ 37.654323] CFGR = 0
<4>[ 37.654327] SDBLR = 0
<4>[ 37.654332] DMACR = 0
<4>[ 37.654336] INTCR = 0
<4>[ 37.654342] INTSR = 0
<4>[ 37.654346] XFER = 0
<4>[ 37.654351] SMPDR = 0
<4>[ 37.654355] ******************************************
<4>[ 37.654361] before writel the register values = 0
<4>[ 37.654367] after writel the register values = 580
<4>[ 37.654570] spdif_trigger: cmd: 1
<4>[ 37.654579] **spdif_dump
<4>[ 37.654586] SPDIF_CHNSR00_ADDR = 0
<4>[ 37.654591] SPDIF_CHNSR01_ADDR = 0
<4>[ 37.654596] SPDIF_CHNSR02_ADDR = 15859954
<4>[ 37.654601] SPDIF_CHNSR03_ADDR = 0
<4>[ 37.654606] SPDIF_CHNSR04_ADDR = 0
<4>[ 37.654611] SPDIF_CHNSR05_ADDR = 0
<4>[ 37.654616] SPDIF_CHNSR06_ADDR = 0
<4>[ 37.654621] SPDIF_CHNSR07_ADDR = 0
<4>[ 37.654626] SPDIF_CHNSR08_ADDR = 0
<4>[ 37.654631] SPDIF_CHNSR09_ADDR = 0
<4>[ 37.654635] SPDIF_CHNSR10_ADDR = 0
<4>[ 37.654640] SPDIF_CHNSR11_ADDR = 0
<4>[ 37.654645] CFGR = 68
<4>[ 37.654650] SDBLR = 0
<4>[ 37.654654] DMACR = 16
<4>[ 37.654659] INTCR = 0
<4>[ 37.654663] INTSR = 0
<4>[ 37.654668] XFER = 0
<4>[ 37.654672] SMPDR = 0
<4>[ 37.654677] ******************************************
<11>[ 37.768846] init: untracked pid 1108 exited with status 0
<4>[ 763.419751] rk_battery_charger_detect_cb , battery_charger_detect 1
<4>[ 764.263853] vbus detect
<4>[ 764.444875] Using Buffer DMA mode
<4>[ 764.444908] Periodic Transfer Interrupt Enhancement - disabled
<4>[ 764.444920] Multiprocessor Interrupt Enhancement - disabled
<4>[ 764.444936] OTG VER PARAM: 0, OTG VER FLAG: 0
<4>[ 764.444947] ^^^^^^^^^^^^^^^^^Device Mode
<4>[ 764.444995] soft connect!!!
<4>[ 764.574321] USB RESET
<6>[ 764.684785] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 764.688226] USB RESET
<6>[ 764.812634] android_usb gadget: high-speed config #1: android
<4>[ 764.812688] WARN::do_gadget_setup:1320: do_gadget_setup warning: pcd->lock locked without unlock
<4>[ 764.812688]
<6>[ 764.812779] android_work: sent uevent USB_STATE=CONFIGURED
<6>[ 789.317644] rk3288-lcdc lcdc0: win0:new_addr:0x59d00000 cur_addr:0x59500000–1
<6>[ 822.267154] rk3288-lcdc lcdc0: win0:new_addr:0x59d00000 cur_addr:0x59500000–1
会不会是屏线问题?
你是用的哪个屏?哪个版本的系统?
查下花屏时屏的供电对不对
楼主,你好,你的问题解决了吗
