升级ubuntu固件
按照流程升级ubuntu固件,板卡无法启动,HDMI显示屏是黑屏,使用串口打印信息如下,之后一直卡住,使用了好几个版本固件都一样
DDR Version 1.07 20161103
Channel 0: LPDDR3, 666MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB
Channel 1: LPDDR3, 666MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x3
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1842
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=7456MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 63027
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 79162
LoaderFlag2: 0x0
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE: BL31: v1.2(debug):b995f80
NOTICE: BL31: Built : 16:53:56, Nov 7 2016
INFO: boot cpu mask: 0
INFO: Vesion: 2016.0.01
INFO: plat_rockchip_pmu_init(1211): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-ga7c7ca8 (Apr 25 2017 - 15:10:21)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
no key node
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=33
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-04-25#1.05
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x012e3808)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 000000000561480c … OK
Add bank:0000000000200000, 00000000f7e00000
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.77 (huangzq@esky14) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #493 SMP Fri Nov 3 13:01:26 HKT 2017 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ee6000 s45504 r8192 d32320 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432 [ 0.000000] Kernel command line: splash console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait fbcon=rotate:1 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-04-25_15:10:21 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [ffffffc0ef600000-ffffffc0f35fffff] [ 0.000000] Memory: 3902188K/4061184K available (12094K kernel code, 1678K rwdata, 4348K rodata, 1152K init, 763K bss, 158996K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff80090a0000 - 0xffffff80091c0000 ( 1152 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c50000 ( 12096 KB) [ 0.000000] .rodata : 0xffffff8008c50000 - 0xffffff80090a0000 ( 4416 KB) [ 0.000000] .data : 0xffffff80091c0000 - 0xffffff8009363808 ( 1679 KB) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual) [ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @ef080000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000000ef010000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: using LPI pending table @0x00000000ef020000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001212] Console: colour dummy device 80x25 [ 0.001239] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [ 0.001253] pid_max: default: 32768 minimum: 301 [ 0.001349] Security Framework initialized [ 0.001360] Yama: becoming mindful. [ 0.001445] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.001457] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.002288] Initializing cgroup subsys devices [ 0.002307] Initializing cgroup subsys freezer [ 0.002334] ftrace: allocating 43569 entries in 171 pages [ 0.120803] sched-energy: Sched-energy-costs installed from DT [ 0.120823] CPU0: update cpu_capacity 401 [ 0.120881] ASID allocator initialised with 65536 entries [ 0.124120] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.124610] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.125888] Detected VIPT I-cache on CPU1 [ 0.125921] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.125957] CPU1: using LPI pending table @0x00000000ef2a0000 [ 0.126003] CPU1: update cpu_capacity 401 [ 0.126007] CPU1: Booted secondary processor [410fd034] [ 0.126552] Detected VIPT I-cache on CPU2 [ 0.126573] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.126607] CPU2: using LPI pending table @0x00000000ef2e0000 [ 0.126636] CPU2: update cpu_capacity 401 [ 0.126640] CPU2: Booted secondary processor [410fd034] [ 0.127168] Detected VIPT I-cache on CPU3 [ 0.127188] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.127221] CPU3: using LPI pending table @0x00000000ef320000 [ 0.127248] CPU3: update cpu_capacity 401 [ 0.127251] CPU3: Booted secondary processor [410fd034] [ 0.127777] Detected PIPT I-cache on CPU4 [ 0.127805] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.127841] CPU4: using LPI pending table @0x00000000ef360000 [ 0.127884] CPU4: update cpu_capacity 1024 [ 0.127887] CPU4: Booted secondary processor [410fd082] [ 0.128434] Detected PIPT I-cache on CPU5 [ 0.128454] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.128487] CPU5: using LPI pending table @0x00000000ef390000 [ 0.128515] CPU5: update cpu_capacity 1024 [ 0.128518] CPU5: Booted secondary processor [410fd082] [ 0.128606] Brought up 6 CPUs [ 0.128688] SMP: Total of 6 processors activated. [ 0.128697] CPU features: detected feature: GIC system register CPU interface [ 0.128710] CPU: All CPU(s) started at EL2 [ 0.128757] alternatives: patching kernel code [ 0.130181] devtmpfs: initialized [ 0.144205] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.144229] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.144671] pinctrl core: initialized pinctrl subsystem [ 0.145420] NET: Registered protocol family 16 [ 0.146282] Registered FIQ tty driver [ 0.146554] vdso: 2 pages (1 code @ ffffff8008c56000, 1 data @ ffffff80091c4000) [ 0.146580] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.146740] DMA: preallocated 256 KiB pool for atomic allocations [ 0.229882] console [ttyFIQ0] enabled [ 0.230417] Registered fiq debugger ttyFIQ0 [ 0.257263] iommu: Adding device ff650000.vpu_service to group 0 [ 0.257879] iommu: Adding device ff660000.rkvdec to group 1 [ 0.258461] iommu: Adding device ff8f0000.vop to group 2 [ 0.259020] iommu: Adding device ff900000.vop to group 3 [ 0.260800] SCSI subsystem initialized [ 0.261319] usbcore: registered new interface driver usbfs [ 0.261843] usbcore: registered new interface driver hub [ 0.262403] usbcore: registered new device driver usb [ 0.262949] media: Linux media interface: v0.10 [ 0.263392] Linux video capture interface: v2.00 [ 0.263837] pps_core: LinuxPPS API ver. 1 registered [ 0.264277] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.265094] PTP clock support registered [ 0.266399] Advanced Linux Sound Architecture Driver Initialized. [ 0.267442] Bluetooth: Core ver 2.21 [ 0.267785] NET: Registered protocol family 31 [ 0.268188] Bluetooth: HCI device and connection manager initialized [ 0.268752] Bluetooth: HCI socket layer initialized [ 0.269184] Bluetooth: L2CAP socket layer initialized [ 0.269660] Bluetooth: SCO socket layer initialized [ 0.270689] rockchip-cpuinfo cpuinfo: Serial : 0000000000000000 [ 0.271787] clocksource: Switched to clocksource arch_sys_counter [ 0.321556] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.322484] NET: Registered protocol family 2 [ 0.323327] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 0.324160] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 0.325296] TCP: Hash tables configured (established 32768 bind 32768) [ 0.325986] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 0.326667] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 0.327613] NET: Registered protocol family 1 [ 0.328304] RPC: Registered named UNIX socket transport module. [ 0.328842] RPC: Registered udp transport module. [ 0.329259] RPC: Registered tcp transport module. [ 0.329675] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.330917] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.331709] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.335475] Initialise system trusted keyring [ 0.343858] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.346118] NFS: Registering the id_resolver key type [ 0.346592] Key type id_resolver registered [ 0.346976] Key type id_legacy registered [ 0.347350] Installing knfsd (copyright (C) 1996 [email]okir@monad.swb.de[/email]). [ 0.348640] fuse init (API version 7.23) [ 0.349474] SGI XFS with security attributes, no debug enabled [ 0.355131] NET: Registered protocol family 38 [ 0.355543] Key type asymmetric registered [ 0.355929] Asymmetric key parser 'x509' registered [ 0.356516] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.357188] io scheduler noop registered [ 0.357539] io scheduler deadline registered [ 0.358053] io scheduler cfq registered (default) [ 0.359117] platform ff770000.syscon:usb2-phy@e450: Driver rockchip-usb2phy requests probe deferral [ 0.360645] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned [ 0.363286] platform ff7c0000.phy: Driver rockchip-typec-phy requests probe deferral [ 0.366754] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [ 0.367359] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [ 0.367948] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [ 0.909822] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout! [ 0.910469] rockchip-pcie: probe of f8000000.pcie failed with error -110 [ 0.912088] rk-vcodec ff650000.vpu_service: probe device [ 0.912665] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0ee9b2c10 [ 0.913588] rk-vcodec ff650000.vpu_service: allocator is drm [ 0.914175] rk-vcodec ff650000.vpu_service: checking hw id 0 [ 0.915277] rk-vcodec ff650000.vpu_service: init success [ 0.916617] rk-vcodec ff660000.rkvdec: probe device [ 0.917142] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0ee9b3410 [ 0.917934] rk-vcodec ff660000.rkvdec: allocator is drm [ 0.918458] rk-vcodec ff660000.rkvdec: checking hw id 6876 [ 0.919344] rk-vcodec ff660000.rkvdec: init success [ 0.921965] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.922638] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 0.925611] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.926298] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.928555] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.931308] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A [ 0.932881] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A [ 0.934301] ff370000.serial: ttyS1 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A [ 0.936082] [drm:drm_core_init] Initialized drm 1.1.0 20060810 [ 0.939291] rockchip-vop ff900000.vop: failed to get vop register byname [ 0.939919] rockchip-vop ff900000.vop: invalid resource [ 0.940385] rockchip-vop ff900000.vop: failed to get vop lut registers [ 0.940983] rockchip-vop ff900000.vop: invalid resource [ 0.941448] rockchip-vop ff900000.vop: failed to get vop cabc lut registers [ 0.942294] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008cf19a0) [ 0.943027] rockchip-vop ff8f0000.vop: failed to get vop register byname [ 0.943634] rockchip-vop ff8f0000.vop: invalid resource [ 0.944110] rockchip-vop ff8f0000.vop: failed to get vop lut registers [ 0.944692] rockchip-vop ff8f0000.vop: invalid resource [ 0.945171] rockchip-vop ff8f0000.vop: failed to get vop cabc lut registers [ 0.945949] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008cf19a0) [ 0.946905] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports [ 0.947495] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver [ 0.948247] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 0.949736] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008cec920) [ 0.950469] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 0.951180] [drm:drm_vblank_init] No driver support for vblank timestamp query. [ 0.951908] rockchip-drm display-subsystem: failed to parse loader memory [ 0.952520] rockchip-drm display-subsystem: No connectors reported connected with modes [ 0.953261] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768 [ 0.965612] Console: switching to colour frame buffer device 128x48 [ 0.973202] rockchip-drm display-subsystem: fb0: frame buffer device [ 0.980245] mali ff9a0000.gpu: Failed to get regulator [ 0.980699] mali ff9a0000.gpu: Power control initialization failed [ 0.981337] platform ff9a0000.gpu: Driver mali requests probe deferral [ 0.982163] Unable to detect cache hierarchy from DT for CPU 0 [ 0.983390] brd: module loaded [ 0.988875] loop: module loaded [ 0.989717] zram: Added device: zram0 [ 0.990320] lkdtm: No crash points registered, enable through debugfs [ 0.991650] register spi return v = :0 [ 0.992027] tun: Universal TUN/TAP device driver, 1.6 [ 0.992479] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 0.994298] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 0.994932] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 0.995434] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b). [ 0.996124] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 0.996660] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 1.002235] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.002686] Ring mode enabled [ 1.002970] DMA HW capability register supported [ 1.003373] Normal descriptors [ 1.003683] RX Checksum Offload Engine supported (type 2) [ 1.004174] TX Checksum insertion supported [ 1.004554] Wake-Up On Lan supported [ 1.004913] Enable RX Mitigation via HW Watchdog Timer [ 1.067735] libphy: stmmac: probed [ 1.068053] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active [ 1.068623] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01) [ 1.070113] PPP generic driver version 2.4.2 [ 1.070714] usbcore: registered new interface driver rndis_wlan [ 1.071544] Rockchip WiFi SYS interface (V1.00) ... [ 1.072062] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.072810] usbcore: registered new interface driver pegasus [ 1.073361] usbcore: registered new interface driver rtl8150 [ 1.073925] usbcore: registered new interface driver r8152 [ 1.074478] usbcore: registered new interface driver asix [ 1.075024] usbcore: registered new interface driver ax88179_178a [ 1.075618] usbcore: registered new interface driver cdc_ether [ 1.076196] usbcore: registered new interface driver dm9601 [ 1.076761] usbcore: registered new interface driver smsc75xx [ 1.077351] usbcore: registered new interface driver smsc95xx [ 1.077934] usbcore: registered new interface driver net1080 [ 1.078483] usbcore: registered new interface driver rndis_host [ 1.079083] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.079840] usbcore: registered new interface driver cdc_ncm [ 1.080390] usbcore: registered new interface driver qmi_wwan [ 1.080970] usbcore: registered new interface driver cdc_mbim [ 1.083336] platform fe800000.dwc3: Driver dwc3 requests probe deferral [ 1.084011] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3 [ 1.084773] platform usb@fe800000: Driver rockchip-dwc3 requests probe deferral [ 1.092352] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd [ 1.093263] platform usb@fe900000: Driver rockchip-dwc3 requests probe deferral [ 1.095033] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.095632] ehci-pci: EHCI PCI platform driver [ 1.096129] ehci-platform: EHCI generic platform driver [ 1.096974] platform fe380000.usb: Driver ehci-platform requests probe deferral [ 1.101306] ehci-platform fe3c0000.usb: EHCI Host Controller [ 1.101999] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1 [ 1.102805] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000 [ 1.108804] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [ 1.109511] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.110122] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.110764] usb usb1: Product: EHCI Host Controller [ 1.111203] usb usb1: Manufacturer: Linux 4.4.77 ehci_hcd [ 1.111680] usb usb1: SerialNumber: fe3c0000.usb [ 1.112536] hub 1-0:1.0: USB hub found [ 1.112908] hub 1-0:1.0: 1 port detected [ 1.113761] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.114335] ohci-platform: OHCI generic platform driver [ 1.115057] platform fe3a0000.usb: Driver ohci-platform requests probe deferral [ 1.115949] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [ 1.116697] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2 [ 1.117479] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000 [ 1.172945] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.173542] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.174197] usb usb2: Product: Generic Platform OHCI controller [ 1.174720] usb usb2: Manufacturer: Linux 4.4.77 ohci_hcd [ 1.175206] usb usb2: SerialNumber: fe3e0000.usb [ 1.176034] hub 2-0:1.0: USB hub found [ 1.176392] hub 2-0:1.0: 1 port detected [ 1.177537] usbcore: registered new interface driver cdc_acm [ 1.178050] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.178803] usbcore: registered new interface driver cdc_wdm [ 1.179343] usbcore: registered new interface driver uas [ 1.179899] usbcore: registered new interface driver usb-storage [ 1.180508] usbcore: registered new interface driver usbserial [ 1.181055] usbcore: registered new interface driver usbserial_generic [ 1.181650] usbserial: USB Serial support registered for generic [ 1.182229] usbcore: registered new interface driver cp210x [ 1.182747] usbserial: USB Serial support registered for cp210x [ 1.183323] usbcore: registered new interface driver ftdi_sio [ 1.183864] usbserial: USB Serial support registered for FTDI USB Serial Device [ 1.184583] usbcore: registered new interface driver keyspan [ 1.185111] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 1.185831] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 1.186492] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 1.187161] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 1.187849] usbcore: registered new interface driver option [ 1.188367] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.189092] usbcore: registered new interface driver oti6858 [ 1.189613] usbserial: USB Serial support registered for oti6858 [ 1.190191] usbcore: registered new interface driver pl2303 [ 1.190701] usbserial: USB Serial support registered for pl2303 [ 1.191274] usbcore: registered new interface driver qcserial [ 1.191814] usbserial: USB Serial support registered for Qualcomm USB modem [ 1.192478] usbcore: registered new interface driver sierra [ 1.193005] usbserial: USB Serial support registered for Sierra USB modem [ 1.194386] usbcore: registered new interface driver iforce [ 1.194955] usbcore: registered new interface driver xpad [ 1.195499] ==gsl_ts_init== [ 1.195769] ret=0 [ 1.196230] usbcore: registered new interface driver usbtouchscreen [ 1.197128] i2c /dev entries driver [ 1.198734] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 1.199441] fan53555-reg: supplied by vcc5v0_sys
Android固件试过正常吗
