Firefly-RK3399 Mini PCIe 转接板不识别硬盘
接上去了,没看到硬盘,没有显示器,用串口命令看的
root@firefly:~# fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/mmcblk1: 14.6 GiB, 15634268160 bytes, 30535680 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors
root@firefly:~#
https://pastebin.ubuntu.com/25973619/
dmesg在这里
dmesg在这里
ls /dev/block/nv* 看是否有节点, 有的话证明驱动是ok的,可以自己手动挂载
root@firefly:~# ls /dev/block/
179:0 179:2 179:32 179:5 179:64 1:0 7:0 7:2 7:4 7:6
179:1 179:3 179:4 179:6 179:96 254:0 7:1 7:3 7:5 7:7
root@firefly:~#
没有
17 …
linux的话看上一层目录/dev/nv*
root@firefly:~# ls /dev/nv*
ls: cannot access ‘/dev/nv*’: No such file or directory
root@firefly:~#
没人用过这个转接板吗?
到底要怎么样才能解决???
QQ645116977 发表于 2017-12-3 15:10
到底要怎么样才能解决???
有log吗
