开发板RIL支持的3G上网卡的型号
通过查看代码,发现:
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath1=/system/lib/libreference-ril-mt6229.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath2=/system/lib/libreference-ril-mu509.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath4=/system/lib/libreference-ril-mw100.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath6=/system/lib/libreference-ril-sc6610.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath7=/system/lib/libreference-ril-m51.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath8=/system/lib/libreference-ril-mt6250.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath9=/system/lib/libreference-ril-c66a.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath10=/system/lib/libreference-ril-sew290.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath11=/system/lib/libreference-ril-u5501.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath12=/system/lib/libreference-ril-u7501.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath14=/system/lib/libreference-ril-a85xx.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath15=/system/lib/libreference-ril-e1230s.so
ADDITIONAL_DEFAULT_PROPERTIES += rild1.libpath=/system/lib/libreference-ril-sc6610-1.so
ADDITIONAL_DEFAULT_PROPERTIES += rild3.libpath=/system/lib/libril-rk29-dataonly.so
ADDITIONAL_DEFAULT_PROPERTIES += rild.libpath13=/system/lib/libreference-ril-aw706.so
里面原生支持这些型号的上网卡,RIL也支持,有没有相应的型号之类的,
如果自己有ril动态库,直接加一行,copy到/system/lib/吗?
同问,求助
支持列表可以参考附件
RK_3G_Support_List.rar (95.1 KB)
3G的服务部单单增加ril库就可以哦
zhansb 发表于 2015-3-13 15:05
支持列表可以参考附件
3q,自己测试了一番,各种支持,RK芯片牛逼啊
暴走的阿Sai 发表于 2015-3-13 16:15
3G的服务部单单增加ril库就可以哦
我使用华为MU609模块,用的官方提供的RIL动态库,这样行么
支持列表可以参考附件
使用一个mini pci-e的华为MU609的,出现如下提示:
01-01 20:39:06.720: E/KitKat_RIL_RK_V3.1(108): E: Not support modem!!!
01-01 20:39:09.720: D/KitKat_RIL_RK_V3.1(108): Found a device, get id
01-01 20:39:09.720: D/KitKat_RIL_RK_V3.1(108): tty Device id is: 12D1/1573
01-01 20:39:09.720: D/KitKat_RIL_RK_V3.1(108): Searching modem table…
01-01 20:39:09.720: D/KitKat_RIL_RK_V3.1(108): [matchModem]: match model count=0
01-01 20:39:09.720: E/KitKat_RIL_RK_V3.1(108): E: Not support modem!!!
那目前就没办法支持,要支持,需要寻找vendor soc的支持
我果断把ril.so加到这个rk30_phone.mk文件里面去,结果就启动不了了。
楼主,你在3288板子的安卓固件上可以成功使用3G上网卡吗???需要修改源码很多吗?还是只要替换下ril动态库????
perfect1580 发表于 2015-6-2 15:50
楼主,你在3288板子的安卓固件上可以成功使用3G上网卡吗???需要修改源码很多吗?还是只要替换下ril动态 …
支持列表里面的一般直接用就行
开发板本身已集成了很多USB上网卡驱动,你可以买一个华为联通3G的的试一下
3G请问从RK29到RK30上都需要修改哪些地方的代码?有没有移植说明书?可不可以发到我的邮箱1424346565@qq.com @zhansb @暴走的阿Sai
