WIFI ap6335无法被加载
错误提示: wifi_platform_set_power = 0
[ 4.649365] ======== PULL WL_REG_ON LOW! ========
[ 4.649371] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 4.656497] mmc2: error -110 whilst initialising SDIO card
[ 4.672888] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84)
[ 4.672913] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 600000Hz for init[mmc2]
[ 4.722073] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125)
[ 4.722104] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 400000Hz for init[mmc2]
[ 4.751599] [WLAN_RFKILL]: wifi shut off power.
[ 4.751612] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 4.751618] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 4.751626] wifi_platform_bus_enumerate device present 0
[ 4.751632] ======== Card detection to remove SDIO card! ========
[ 4.751638] mmc2:mmc host rescan start!
[ 4.751652] failed to power up DHD generic adapter, max retry reached**
[ 4.751671] unregister wifi platform drivers
[ 4.751677] wifi_platform_bus_enumerate device present 0
[ 4.751682] ======== Card detection to remove SDIO card! ========
[ 4.751687] mmc2:mmc host rescan start!
[ 4.751694] dhd_module_init: Failed to load the driver, try cnt 0
[ 4.751712] dhd_module_init: Failed to load driver max retry reached**
[ 4.751718] dhd_module_init: Exit err=-19
