最近买了个3288的板子,参照http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_android这个网址编译了系统,用瑞芯微开发工具烧写了如下程序
然后在串口中,读取了如下数据后就停止了,不能写入数据,是因为系统默认关闭了串口的写操作,还是程序有问题?哪位大哥能帮忙解答下?
U-Boot 2014.10-RK3288-06-gb1ceed8-dirty (Mar 26 2015 - 10:37:10)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
power key: bank-0 pin-5
pmic:act8846
#Boot ver: 2015-03-26#2.19
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
failed to load fdt from recovery!
Secure Boot state: 0
kernel @ 0x02000000 (0x006004d0)
ramdisk @ 0x05bf0000 (0x00410fdc)
bootrk: do_bootm_linux…
Loading Device Tree to 0570f000, end 0572aa08 … OK
[ 0.000000] Booting Linux o dhbsg>a CPUugx e[u > 0 00bug> Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (root@10-8-49-201) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Sat Nov 25 13:13:43 CST 2017 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_ion_reserve [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ec7000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768 [ 0.000000] Kernel command line: console=ttyS2 earlyprintk androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00200000@0x0039A000(userdata),0x00020000@0x0059A000(radical_update),-@0x005BA000(user) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2015-03-26_10:37:10 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 2044008k/2044008k available, 53144k reserved, 1318912K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0a841c4 (10737 kB) [ 0.000000] .init : 0xc0a85000 - 0xc0cd46c0 (2366 kB) [ 0.000000] .data : 0xc0cd6000 - 0xc0d731c8 ( 629 kB) [ 0.000000] .bss : 0xc0d731c8 - 0xc0e8e004 (1132 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rkclk: rk_clk_tree_init: unknown [ 0.000000] rkclk: rkclk_cache_parents: hdmi_dclk0 clk_get error [ 0.000000] rkclk: rkclk_cache_parents: hdmi_dclk1 clk_get error [ 0.000000] rkclk: rkclk_cache_parents: hdmi_dclk clk_get error [ 0.000000] rkclk: rkclk_cache_parents: aclk_hdcp clk_get error [ 0.000000] rkclk: rkclk_cache_parents: clk_hdcp clk_get error [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 33 [ 0.000000] Architected local timer running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:21 [ 0.000000] target-temp:95 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:0, lkg:21 [ 0.000000] target-temp:95 [ 0.000000] channel:1, lkg:13 [ 0.000000] target-temp:95 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.525850] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.525902] pid_max: default: 32768 minimum: 301 [ 0.526243] Security Framework initialized [ 0.526285] SELinux: Initializing. [ 0.526530] Mount-cache hash table entries: 512 [ 0.528559] Initializing cgroup subsys debug [ 0.528602] Initializing cgroup subsys freezer [ 0.528693] CPU: Testing write buffer coherency: ok [ 0.529458] /cpus/cpu@0 missing clock-frequency property [ 0.529502] /cpus/cpu@1 missing clock-frequency property [ 0.529536] /cpus/cpu@2 missing clock-frequency property [ 0.529568] /cpus/cpu@3 missing clock-frequency property [ 0.529692] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.529804] Setting up static identity map for 0xc07955e8 - 0xc0795640 [ 0.534454] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x16ac (version 3.0) [ 0.613719] CPU1: Booted secondary processor [ 0.613809] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.633447] CPU2: Booted secondary processor [ 0.633531] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.653218] CPU3: Booted secondary processor [ 0.653300] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.653672] Brought up 4 CPUs [ 0.653771] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.653802] CPU: All CPU(s) started in SVC mode. [ 0.656034] devtmpfs: initialized [ 0.673961] pinctrl core: initialized pinctrl subsystem [ 0.674693] regulator-dummy: no parameters [ 0.676326] NET: Registered protocol family 16 [ 0.681568] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.682443] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0e69654 (version 0.1) [ 0.682941] Registered FIQ tty driver [ 0.689497] console [ttyFIQ0] enabled [ 0.690068] Registered fiq debugger ttyFIQ0 [ 0.691985] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.692074] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.692163] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.692237] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.692508] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.692747] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.692976] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.693204] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.693429] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.693654] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.693881] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.694107] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.694348] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.694587] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.694645] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.694700] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.694753] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.696499] rockchip_interrupts_register:bank_num=7 [ 0.703219] of_get_gpio_init_config:gpio[0] = 256, value = 0 [ 0.703306] of_get_gpio_init_config:gpio[1] = 233, value = 0 [ 0.703388] of_get_gpio_init_config:gpio[2] = 136, value = 0 [ 0.703600] rockchip_pinctrl_probe:init ok [ 0.724790] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.725142] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.725197] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.725755] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.726080] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.726134] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.726698] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.727020] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.727074] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.727634] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.727957] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.728011] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.728600] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.728984] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.729039] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.729599] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.729921] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.729974] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.730605] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.731001] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.731057] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.736808] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.736866] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.737484] DDR DEBUG: version 1.00 20140603 [ 0.737568] DDR DEBUG: Channel a: [ 0.737606] DDR DEBUG: DDR3 Device [ 0.737655] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.737697] DDR DEBUG: Channel b: [ 0.737728] DDR DEBUG: DDR3 Device [ 0.737773] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.737816] DDR DEBUG: addr=0xd79000 [ 0.737855] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.737895] DDR DEBUG: socAddr[0]=0xd79000, socAddr[1]=0xd79100 [ 0.737936] DDR DEBUG: chAddr[0]=0xd79000, chAddr[1]=0xd79000 [ 0.737981] DDR DEBUG: dtar[0]=0x101af000, dtar[1]=0x101af000 [ 0.738142] DDR DEBUG: init success!!! freq=200MHz [ 0.738177] DDR DEBUG: Channel a: [ 0.738226] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738286] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738344] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738402] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738455] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.738498] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.738537] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.738571] DDR DEBUG: Channel b: [ 0.738618] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738676] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738734] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738791] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=180,90 [ 0.738843] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.738886] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.738924] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.815144] bio: create slab at 0 [ 0.817016] Enter firefly_noatx8_init [ 0.817497] firefly_noatx8_probe 51 [ 0.818223] SCSI subsystem initialized [ 0.818723] usbcore: registered new interface driver usbfs [ 0.818878] usbcore: registered new interface driver hub [ 0.819177] usbcore: registered new device driver usb [ 0.823689] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.828094] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.829568] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.831114] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.831952] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.834908] media: Linux media interface: v0.10 [ 0.835069] Linux video capture interface: v2.00 [ 0.835228] pps_core: LinuxPPS API ver. 1 registered [ 0.835271] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.835354] PTP clock support registered [ 0.835781] rockchip_temp_probe,line=362 [ 0.836563] tsadc ff280000.tsadc: initialized [ 0.837810] rockchip_ion_parse_dt: num_heaps = 1 [ 0.837871] 0: 0 3 vmalloc 0x (null) [ 0.838679] Rockchip ion module is successfully loaded (v1.0) [ 0.839211] Advanced Linux Sound Architecture Driver Initialized. [ 0.840549] Bluetooth: Core ver 2.16 [ 0.840682] NET: Registered protocol family 31 [ 0.840726] Bluetooth: HCI device and connection manager initialized [ 0.840789] Bluetooth: HCI socket layer initialized [ 0.840843] Bluetooth: L2CAP socket layer initialized [ 0.840938] Bluetooth: SCO socket layer initialized [ 0.841610] cfg80211: Calling CRDA to update world regulatory domain [ 0.843899] act8846_i2c_probe,line=898 [ 0.845309] act8846_parse_dt,line=746 [ 0.846848] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.846918] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.846976] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1 [ 0.847036] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1 [ 0.849538] act_dcdc1: 1200 mV [ 0.853525] vccio: 3300 mV [ 0.856191] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 0.859894] act_dcdc4: 2000 mV [ 0.861762] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.864649] act_ldo2: 1050 mV [ 0.867617] act_ldo3: 2800 mV [ 0.870512] act_ldo4: 3300 mV [ 0.873421] act_ldo5: 3300 mV [ 0.876321] act_ldo6: 1100 mV [ 0.879209] vcc_18: 1800 mV [ 0.882129] act_ldo8: 1850 mV [ 0.888710] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.895202] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.896167] rk808_i2c_probe,line=1368 [ 0.897815] The device is not rk808 -11 [ 0.898081] rk808: probe of 0-001b failed with error -11 [ 0.900589] i2s: maxburst: 1 [ 0.902625] Switching to clocksource arch_sys_counter [ 0.925149] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 0.969033] rk-fb rockchip-fb: rk fb ion client create success! [ 0.969104] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.970201] rk-screen rk_screen.9: rockchip screen probe success [ 0.970979] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.971768] rk32-edp ff970000.edp: screen is not edp! [ 0.971843] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.973052] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 0.973773] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.974813] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.975360] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.975892] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.976447] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.978136] rk_iommu ff930300.vopb_mmu: (vopb) Enabled [ 0.978531] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 0.978608] rk3288-lcdc lcdc0: wakeup from standby! [ 1.113246] alloc_buffer:ion_phy_addr=0x10000000 [ 1.156578] fb0:phy:10000000>>vir:f0191000>>len:0x1800000 [ 1.320138] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 1.321293] rockchip_set_mux:warning ignore bank num 15 [ 1.321712] rockchip_set_mux:warning ignore bank num 15 [ 1.322104] rockchip_set_mux:warning ignore bank num 15 [ 1.322521] rockchip_set_mux:warning ignore bank num 15 [ 1.322886] rockchip_set_mux:warning ignore bank num 15 [ 1.323282] rockchip_set_mux:warning ignore bank num 15 [ 1.324185] rockchip_set_mux:warning ignore bank num 15 [ 1.324692] rockchip_set_mux:warning ignore bank num 15 [ 1.325536] rockchip_set_mux:warning ignore bank num 15 [ 1.326105] rockchip_set_mux:warning ignore bank num 15 [ 1.326940] rockchip_set_mux:warning ignore bank num 15 [ 1.327438] rockchip_set_mux:warning ignore bank num 15 [ 1.328246] rockchip_set_mux:warning ignore bank num 15 [ 1.328746] rockchip_set_mux:warning ignore bank num 15 [ 1.333082] NET: Registered protocol family 2 [ 1.334569] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 1.335059] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 1.335555] TCP: Hash tables configured (established 8192 bind 8192) [ 1.335810] TCP: reno registered [ 1.335871] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.336005] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.336658] NET: Registered protocol family 1 [ 1.337217] Unpacking initramfs... [ 1.982729] Freeing initrd memory: 4160K (c5bf0000 - c6000000) [ 1.984594] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 1.986130] probe device ff9a0000.vpu_service [ 1.986570] vpu_service: power on [ 1.987728] checking hw id 4831 [ 1.988753] vpu_service set to auto frequency mode [ 1.988924] vcodec vpu_service: vcodec ion client create success! [ 1.990033] vpu_service: power off... [ 1.990127] done [ 1.990160] init success [ 1.990319] probe device ff9c0000.hevc_service [ 1.990959] hevc_service: power on [ 1.992084] checking hw id 6867 [ 1.992889] vcodec hevc_service: vcodec ion client create success! [ 1.993778] hevc_service: power off... [ 1.993872] done [ 1.993905] init success [ 1.994250] rknandbase v1.0 2014-03-31 [ 1.994873] rknand_probe clk rate = 148500000 [ 1.995378] rknand_driver:ret = 0 [ 1.996512] audit: initializing netlink socket (disabled) [ 1.996630] type=2000 audit(1.490:1): initialized [ 1.998944] bounce pool size: 64 pages [ 2.014647] fuse init (API version 7.22) [ 2.015944] msgmni has been set to 1456 [ 2.021981] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 2.022042] io scheduler noop registered [ 2.022083] io scheduler deadline registered [ 2.022373] io scheduler cfq registered (default) [ 2.024708] rga ff920000.rga: rga ion client create success! [ 2.025149] rga: Driver loaded succesfully [ 2.026603] IEP Power ON [ 2.026723] iep ion client create success! [ 2.027722] rk_iommu ff900800.iep_mmu: (iep) Enabled [ 2.027815] IEP Power OFF [ 2.027865] rk_iommu ff900800.iep_mmu: (iep) Disabled [ 2.027918] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e263000 [ 2.027981] IEP Driver loaded succesfully [ 2.028266] Module initialized. [ 2.030650] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 2.030722] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 2.035195] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 2.035266] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 2.036025] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API [ 2.036091] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM [ 2.036134] pwm_regulator_probe:error [ 2.036205] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral [ 2.037280] rk_serial.c v1.8 2014-03-04 [ 2.037916] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 2.038539] serial ff180000.serial: membase f0172000 [ 2.039051] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1 [ 2.039653] serial ff190000.serial: membase f0174000 [ 2.040175] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3 [ 2.040787] serial ff1b0000.serial: membase f0176000 [ 2.050408] loop: module loaded [ 2.052197] SCSI Media Changer driver v0.25 [ 2.053204] tun: Universal TUN/TAP device driver, 1.6 [ 2.053251] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 2.054944] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 2.055001] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 2.055050] stmmac_probe_config_dt: clock input or output? (input). [ 2.055095] stmmac_probe_config_dt: TX delay(0x30). [ 2.055136] stmmac_probe_config_dt: RX delay(0x20). [ 2.055257] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 2.055296] stmmc_pltfr_init: [ 2.055331] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 2.055406] stmmc_pltfr_init: ERROR: Request gmac phy reset pin failed. [ 2.055444] stmmc_pltfr_init: init for RGMII [ 2.055483] tx delay=0x30 [ 2.055483] rx delay=0x20 [ 2.056893] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 2.056935] Normal descriptors [ 2.056967] Ring mode enabled [ 2.057000] DMA HW capability register supported [ 2.057039] RX Checksum Offload Engine supported (type 2) [ 2.057077] TX Checksum insertion supported [ 2.057109] Wake-Up On Lan supported [ 2.057229] Enable RX Mitigation via HW Watchdog Timer [ 2.058550] PPP generic driver version 2.4.2 [ 2.059042] PPP BSD Compression module registered [ 2.059093] PPP Deflate Compression module registered [ 2.059157] PPP MPPE Compression module registered [ 2.059200] NET: Registered protocol family 24 [ 2.059299] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 2.059349] CSLIP: code copyright 1989 Regents of the University of California. [ 2.059397] Rockchip WiFi SYS interface (V1.00) ... [ 2.059642] usbcore: registered new interface driver catc [ 2.059776] usbcore: registered new interface driver kaweth [ 2.059821] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 2.059952] usbcore: registered new interface driver pegasus [ 2.060082] usbcore: registered new interface driver rtl8150 [ 2.060215] usbcore: registered new interface driver r8152 [ 2.060255] hso: drivers/net/usb/hso.c: Option Wireless [ 2.060505] usbcore: registered new interface driver hso [ 2.060662] usbcore: registered new interface driver asix [ 2.060796] usbcore: registered new interface driver ax88179_178a [ 2.060926] usbcore: registered new interface driver cdc_ether [ 2.061055] usbcore: registered new interface driver cdc_eem [ 2.061182] usbcore: registered new interface driver dm9601 [ 2.061312] usbcore: registered new interface driver dm9620 [ 2.061486] usbcore: registered new interface driver smsc75xx [ 2.061649] usbcore: registered new interface driver smsc95xx [ 2.061783] usbcore: registered new interface driver gl620a [ 2.061914] usbcore: registered new interface driver net1080 [ 2.062044] usbcore: registered new interface driver plusb [ 2.062175] usbcore: registered new interface driver rndis_host [ 2.062321] usbcore: registered new interface driver cdc_subset [ 2.062449] usbcore: registered new interface driver zaurus [ 2.062586] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 2.062772] usbcore: registered new interface driver int51x1 [ 2.062907] usbcore: registered new interface driver kalmia [ 2.063040] usbcore: registered new interface driver ipheth [ 2.063187] usbcore: registered new interface driver sierra_net [ 2.063334] usbcore: registered new interface driver cx82310_eth [ 2.063503] usbcore: registered new interface driver cdc_ncm [ 2.063641] usbcore: registered new interface driver qmi_wwan [ 2.063776] usbcore: registered new interface driver cdc_mbim [ 2.063821] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.067166] EHCI: ehci_rk_probe f1a00000 f1a00010 [ 2.067228] rockchip_ehci_host ff500000.usb: EHCI Host Controller [ 2.067339] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 2.068373] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 2.083682] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00 [ 2.083921] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.083983] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.084037] usb usb1: Product: EHCI Host Controller [ 2.084085] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 2.084132] usb usb1: SerialNumber: ff500000.usb [ 2.085581] hub 1-0:1.0: USB hub found [ 2.085662] hub 1-0:1.0: 1 port detected [ 2.086236] EHCI: ehci_rk_probe ok [ 2.086674] usbcore: registered new interface driver cdc_acm [ 2.086720] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 2.086909] usbcore: registered new interface driver usblp [ 2.087055] usbcore: registered new interface driver cdc_wdm [ 2.087264] usbcore: registered new interface driver usb-storage [ 2.087398] usbcore: registered new interface driver ums-alauda [ 2.087527] usbcore: registered new interface driver ums-cypress [ 2.087657] usbcore: registered new interface driver ums-datafab [ 2.087809] usbcore: registered new interface driver ums_eneub6250 [ 2.087944] usbcore: registered new interface driver ums-freecom [ 2.088078] usbcore: registered new interface driver ums-isd200 [ 2.088208] usbcore: registered new interface driver ums-jumpshot [ 2.088336] usbcore: registered new interface driver ums-karma [ 2.088466] usbcore: registered new interface driver ums-onetouch [ 2.088599] usbcore: registered new interface driver ums-sddr09 [ 2.088728] usbcore: registered new interface driver ums-sddr55 [ 2.088858] usbcore: registered new interface driver ums-usbat [ 2.089156] usbcore: registered new interface driver usbserial [ 2.089301] usbcore: registered new interface driver usbserial_generic [ 2.089417] usbserial: USB Serial support registered for generic [ 2.089556] usbcore: registered new interface driver option [ 2.089667] usbserial: USB Serial support registered for GSM modem (1-port) [ 2.089912] usbcore: registered new interface driver trancevibrator [ 2.089956] usb20_otg: version 3.10a 21-DEC-2012 [ 2.091111] f1a80040 [ 2.091157] Core Release: 3.10a [ 2.091195] Setting default values for core params [ 2.091584] Using Buffer DMA mode [ 2.091627] Periodic Transfer Interrupt Enhancement - disabled [ 2.091667] Multiprocessor Interrupt Enhancement - disabled [ 2.091707] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 2.091744] ^^^^^^^^^^^^^^^^^Device Mode [ 2.091788] Dedicated Tx FIFOs mode [ 2.091846] pcd_init otg_dev = ed9fbc80 [ 2.092350] usb20_otg ff580000.usb: DWC OTG Controller [ 2.092450] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 2.092553] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 2.092752] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.092815] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.092868] usb usb2: Product: DWC OTG Controller [ 2.092915] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 2.092961] usb usb2: SerialNumber: ff580000.usb [ 2.094404] hub 2-0:1.0: USB hub found [ 2.094497] hub 2-0:1.0: 1 port detected [ 2.095535] usb20_host: version 3.10a 21-DEC-2012 [ 2.099110] f1b00040 [ 2.099157] Core Release: 3.10a [ 2.099195] Setting default values for core params [ 2.099566] Using Buffer DMA mode [ 2.099609] Periodic Transfer Interrupt Enhancement - disabled [ 2.099649] Multiprocessor Interrupt Enhancement - disabled [ 2.099690] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 2.099726] ^^^^^^^^^^^^^^^^^^Host Mode [ 2.099813] usb20_host ff540000.usb: DWC OTG Controller [ 2.099906] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 2.100009] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 2.100175] Init: Power Port (0) [ 2.100356] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.100417] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.100469] usb usb3: Product: DWC OTG Controller [ 2.100516] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 2.100563] usb usb3: SerialNumber: ff540000.usb [ 2.101872] hub 3-0:1.0: USB hub found [ 2.101951] hub 3-0:1.0: 1 port detected [ 2.104013] .. rk pwm remotectl v1.0 init [ 2.104269] remotectl probe j=0x0 [ 2.104738] input: ff680000.pwm as /devices/ff680000.pwm/input/input0 [ 2.105345] pwm enable val=0x646205 [ 2.106180] usbcore: registered new interface driver xpad [ 2.106344] usbcore: registered new interface driver usb_acecad [ 2.106497] usbcore: registered new interface driver aiptek [ 2.106663] usbcore: registered new interface driver gtco [ 2.106815] usbcore: registered new interface driver hanwang [ 2.106963] usbcore: registered new interface driver kbtab [ 2.107140] usbcore: registered new interface driver wacom [ 2.108214] sensor_register_slave:mma8452,id=17 [ 2.108265] sensor_register_slave:cm3217,id=44 [ 2.108306] sensor_register_slave:cm3218,id=45 [ 2.108341] tchip_rm_init is here! [ 2.109844] input: tchip_remote_key as /devices/virtual/input/input1 [ 2.110242] tchiprm_register_device is here! [ 2.110670] input: tchip_remote_touch as /devices/virtual/input/input2 [ 2.111052] tchip_remote_abs_register_device is here! [ 2.111451] input: tchip_remote_gsensor as /devices/virtual/input/input3 [ 2.111831] tchip_remote_gsensor_register_device is here! [ 2.118925] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 2.119093] i2c /dev entries driver [ 2.121338] IR NEC protocol handler initialized [ 2.121385] IR RC5(x) protocol handler initialized [ 2.121423] IR RC6 protocol handler initialized [ 2.121460] IR JVC protocol handler initialized [ 2.121496] IR Sony protocol handler initialized [ 2.121532] IR RC5 (streamzap) protocol handler initialized [ 2.121570] IR SANYO protocol handler initialized [ 2.121606] IR MCE Keyboard/mouse protocol handler initialized [ 2.121876] usbcore: registered new interface driver uvcvideo [ 2.121920] USB Video Class driver (1.1.1) [ 2.121966] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0 [ 2.122016] E:camsys_soc_init(87): camsys isn't support soc: 0x32880001! [ 2.125311] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236 [ 2.125398] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request [ 2.125462] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0 [ 2.125525] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high [ 2.125730] RockChip-CamSys: probe of ff910000.isp failed with error -1 [ 2.128737] device-mapper: uevent: version 1.0.3 [ 2.129559] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 2.130517] Bluetooth: HCI UART driver ver 2.2 [ 2.130569] Bluetooth: HCI H4 protocol initialized [ 2.130608] Bluetooth: HCILL protocol initialized [ 2.136645] cpufreq version 1.0, suspend freq 1200 MHz [ 2.137245] cpuidle: using governor ladder [ 2.137292] cpuidle: using governor menu [ 2.137427] Synopsys Designware Multimedia Card Interface Driver [ 2.138179] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 2.139037] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 2.139535] 3291..dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0] [ 2.139587] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 2.139969] 1381..dw_mci_set_ios: no card. [mmc0] [ 2.152570] 1381..dw_mci_set_ios: no card. [mmc0] [ 2.172191] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 2.172220] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 2.172246] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 2.172593] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 2.173371] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 2.173555] 3285..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1] [ 2.173573] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 2.174135] 1381..dw_mci_set_ios: no card. [mmc1] [ 2.191845] 1381..dw_mci_set_ios: no card. [mmc1] [ 2.204429] mmc0: BKOPS_EN bit is not set [ 2.206354] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 2.208666] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 2.208695] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 2.211668] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 2.211688] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 2.212042] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 2.212265] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 2.212419] 3291..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 2.212433] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 2.212579] 1381..dw_mci_set_ios: no card. [mmc2] [ 2.223744] rk_sdmmc: BOOT [ 2.223744] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_0 SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID[mmc0] [ 2.223864] mmc0: new HS200 MMC card at address 0001 [ 2.224219] mmcblk0: mmc0:0001 AWPD3R 14.5 GiB [ 2.224614] parameter: 0x000000000 -- 0x000400000 (4 MB) [ 2.224632] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 2.224645] misc: 0x000800000 -- 0x000c00000 (4 MB) [ 2.224658] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 2.224671] kernel: 0x001c00000 -- 0x002c00000 (16 MB) [ 2.224684] boot: 0x002c00000 -- 0x004c00000 (32 MB) [ 2.224697] recovery: 0x004c00000 -- 0x006c00000 (32 MB) [ 2.224709] backup: 0x006c00000 -- 0x00a000000 (52 MB) [ 2.224721] cache: 0x00a000000 -- 0x012000000 (128 MB) [ 2.224734] kpanic: 0x012000000 -- 0x012400000 (4 MB) [ 2.224746] system: 0x012400000 -- 0x072400000 (1536 MB) [ 2.224759] metadata: 0x072400000 -- 0x073400000 (16 MB) [ 2.224771] userdata: 0x073400000 -- 0x0b3400000 (1024 MB) [ 2.224784] radical_update: 0x0b3400000 -- 0x0b7400000 (64 MB) [ 2.224797] user: 0x0b7400000 -- 0x3a3a00000 (11974 MB) [ 2.224842] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p151381..dw_mci_set_ios: no card. [mmc1] [ 2.231187] 1381..dw_mci_set_ios: no card. [mmc2] [ 2.250861] 1381..dw_mci_set_ios: no card. [mmc2] [ 2.251042] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 2.251054] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 2.251302] leds-gpio leds.31: pins are not configured from the driver [ 2.251527] hidraw: raw HID events driver (C) Jiri Kosina [ 2.252834] usbcore: registered new interface driver usbhid [ 2.252844] usbhid: USB HID core driver [ 2.253138] ashmem: initialized [ 2.253244] logger: created 256K log 'log_main' [ 2.253337] logger: created 256K log 'log_events' [ 2.253434] logger: created 256K log 'log_radio' [ 2.253527] logger: created 256K log 'log_system' [ 2.254537] input: rk29-keypad as /devices/ff100000.adc/key.34/input/input4 [ 2.255105] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ; cannot claim for 2-0010 [ 2.255122] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22 [ 2.255134] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl [ 2.255146] ES8323 2-0010: Error applying setting, reverse things back [ 2.255844] es8323 probe error [ 2.255864] ES8323: probe of 2-0010 failed with error -11 [ 2.255891] i2c-core: driver [ES8323] using legacy suspend method [ 2.255900] i2c-core: driver [ES8323] using legacy resume method [ 2.256189] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered [ 2.256221] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 2.256238] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral [ 2.256414] rockchip-es8323 rockchip-es8323.29: ASoC: CODEC (null) not registered [ 2.256435] rockchip_es8323_audio_probe() register card failed:-517 [ 2.256449] platform rockchip-es8323.29: Driver rockchip-es8323 requests probe deferral [ 2.256548] u32 classifier [ 2.256556] Actions configured [ 2.256569] Netfilter messages via NETLINK v0.30. [ 2.256632] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 2.256970] ctnetlink v0.93: registering with nfnetlink. [ 2.257046] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 2.257056] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 2.257358] xt_time: kernel timezone is -0000 [ 2.257568] ip_tables: (C) 2000-2006 Netfilter Core Team [ 2.257704] arp_tables: (C) 2002 David S. Miller [ 2.257750] TCP: cubic registered [ 2.257759] Initializing XFRM netlink socket [ 2.257971] NET: Registered protocol family 10 [ 2.258513] mip6: Mobile IPv6 [ 2.258541] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 2.258657] sit: IPv6 over IPv4 tunneling driver [ 2.258987] NET: Registered protocol family 17 [ 2.259015] NET: Registered protocol family 15 [ 2.259067] Bridge firewalling registered [ 2.259080] Ebtables v2.0 registered [ 2.259243] Bluetooth: RFCOMM TTY layer initialized [ 2.259270] Bluetooth: RFCOMM socket layer initialized [ 2.259279] Bluetooth: RFCOMM ver 1.11 [ 2.259288] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.259295] Bluetooth: BNEP filters: protocol multicast [ 2.259308] Bluetooth: BNEP socket layer initialized [ 2.259316] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.259328] Bluetooth: HIDP socket layer initialized [ 2.259357] l2tp_core: L2TP core driver, V2.0 [ 2.259373] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 2.259381] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 2.259563] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 2.259574] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 2.259583] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 2.259594] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 2.259603] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 2.259627] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 2.259650] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 2.259661] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 2.259690] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 2.259737] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 2.259784] [BT_RFKILL]: Enter rfkill_rk_init [ 2.259918] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 2.259939] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 2.259955] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 2.259971] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 2.259987] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 2.260035] [BT_RFKILL]: Request irq for bt wakeup host [ 2.260129] [BT_RFKILL]: ** disable irq [ 2.260207] [BT_RFKILL]: ap6335 device registered. [ 2.260890] rk3288-hdmi ff980000.hdmi: rk3288 hdmi probe sucess. [ 2.261300] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 2.261321] rk3288_init_suspend [ 2.261330] rk3288_suspend_init enter [ 2.261460] rk3288_suspend_init: pm_ctrbits =40017 [ 2.261491] gpio_get_dts_info suspend:8 [ 2.261500] gpio_get_dts_info resume:8 [ 2.261507] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 2.261540] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 2.261690] clks_gating_suspend_init:clkgt info ok [ 2.261787] Registering SWP/SWPB emulation handler [ 2.262142] ddrfreq: verion 1.2 20140526 [ 2.262157] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz [ 2.262169] ddrfreq: auto-freq=0 [ 2.262176] ddrfreq: auto-freq-table[0] 240MHz [ 2.262183] ddrfreq: auto-freq-table[1] 324MHz [ 2.262190] ddrfreq: auto-freq-table[2] 456MHz [ 2.262197] ddrfreq: auto-freq-table[3] 528MHz [ 2.263926] act_ldo3: operation not allowed [ 2.264173] vga_edid_probe: turn on ldo3 done. [ 2.264206] act_ldo4: operation not allowed [ 2.264446] vga_edid_probe: turn on ldo done. [ 2.264488] act_ldo2: operation not allowed [ 2.264728] vga_edid_probe: turn on ldo2 done. [ 2.264764] act_ldo8: operation not allowed [ 2.265003] vga_edid_probe: turn on ldo done. [ 2.270121] unable to read EDID block. [ 2.304742] unable to read EDID block. [ 2.339366] unable to read EDID block. [ 2.339392] vga-ddc: read and parse edid failed errno:-5. [ 2.339401] vga_edid_probe: success. 10 [ 2.339566] firefly_vga_get_enable 180, 0 [ 2.339575] firefly_vga_get_status 186 [ 2.339599] firefly_vga_set_enable 159 enable:1 [ 2.339626] firefly_vga_enable 130 start [ 2.339635] firefly_switch_fb 55 [ 2.339639] regulator-dummy: disabling [ 2.339651] [ 2.339651] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 [ 2.339664] fb0 win id 1 state 1 [ 2.339682] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 2.339710] fb1 win id 0 state 0 [ 2.339718] fb2 win id 2 state 0 [ 2.339724] fb3 win id 3 state 0 [ 2.339731] fb4 win id 4 state 0 [ 2.339738] [ 2.339738] rk_fb_switch_screen lcdc_id 0 type 1 enable 1 done [ 2.339738] [ 2.339772] VGA ENABLE [ 2.340095] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered [ 2.340123] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 2.340140] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral [ 2.340274] rockchip-es8323 rockchip-es8323.29: ASoC: CODEC (null) not registered [ 2.340294] rockchip_es8323_audio_probe() register card failed:-517 [ 2.340308] platform rockchip-es8323.29: Driver rockchip-es8323 requests probe deferral [ 2.340402] pcd_pullup, is_on 0 [ 2.340451] file system registered [ 2.341120] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 2.341132] android_usb gadget: Number of LUNs=2 [ 2.341142] lun0: LUN: removable file: (no medium) [ 2.341150] lun1: LUN: removable file: (no medium) [ 2.341325] android_usb gadget: android_usb ready [ 2.341418] sensor_init: Probe name sensors [ 2.341436] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01 [ 2.341979] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:44:37 UTC (1293885877) [ 2.348625] usbcore: registered new interface driver snd-usb-audio [ 2.348663] ALSA device list: [ 2.348670] No soundcards found. [ 2.350463] Freeing unused kernel memory: 2364K (c0a85000 - c0cd4000) [ 2.350864] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok [ 2.351510] rockchip-es8323 rockchip-es8323.29: ASoC: CODEC (null) not registered [ 2.351534] rockchip_es8323_audio_probe() register card failed:-517 [ 2.351548] platform rockchip-es8323.29: Driver rockchip-es8323 requests probe deferral [ 2.355412] SELinux: Permission attach_queue in class tun_socket not defined in policy. [ 2.355426] SELinux: the above unknown classes and permissions will be denied [ 2.972278] type=1403 audit(1293885878.130:2): policy loaded auid=4294967295 ses=4294967295 [ 2.972372] SELinux: Loaded policy from /sepolicy [ 3.702209] init: /dev/hw_random not found [ 3.702800] android_usb: already disabled [ 3.702877] android_usb: Cannot enable 'adb' (-22)init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}' [ 3.702945] init: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial' [ 4.061392] EHCI: rk_ehci_hcd_enable, disable host controller [ 4.071233] dwc_otg_hcd_enable, enable host controller [ 4.194236] Using Buffer DMA mode [ 4.194243] Periodic Transfer Interrupt Enhancement - disabled [ 4.194249] Multiprocessor Interrupt Enhancement - disabled [ 4.194255] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 4.194261] ^^^^^^^^^^^^^^^^^^Host Mode [ 4.238597] Init: Power Port (0) [ 4.415654] Indeed it is in host mode hprt0 = 00021501 [ 4.602601] usb 3-1: new high-speed USB device number 2 using usb20_host [ 4.602873] Indeed it is in host mode hprt0 = 00001101 [ 4.800493] usb 3-1: New USB device found, idVendor=05e3, idProduct=0608 [ 4.800512] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.800523] usb 3-1: Product: USB2.0 Hub [ 4.801071] hub 3-1:1.0: USB hub found [ 4.801327] hub 3-1:1.0: 4 ports detected [ 4.803009] rockchip-es8323 rockchip-es8323.29: ASoC: CODEC (null) not registered [ 4.803036] rockchip_es8323_audio_probe() register card failed:-517 [ 4.803051] platform rockchip-es8323.29: Driver rockchip-es8323 requests probe deferral [ 5.970358] iep dpi mode inactivity [ 8.402760] init: /sbin/e2fsck terminated by exit(8) [ 8.402785] init: Operational error while checking volume '/dev/block/platform/emmc/by-name/cache' [ 8.402869] init: Failed to mount /dev/block/platform/emmc/by-name/cache, format it to ext4 now [ 8.404761] init: /dev/hw_random not found [ 8.404815] init: Unable to open persistent property directory /data/property errno: 2 [ 8.405636] init: service 'recovery' requires console [ 8.405651] init: service 'console' requires console [ 8.405712] android_usb: already disabled [ 8.405811] android_usb: Cannot enable 'adb' (-22)pcd_pullup, is_on 1 [ 8.405862] init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead [ 8.405908] init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead [ 8.405950] init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead [ 8.405964] init: property 'ro.serialno' doesn't exist while expanding '$ro.serialno' [ 8.405975] init: cannot expand '$ro.serialno' while writing to '/sys/class/android_usb/android0/iSerial' [ 9.975244] [otg id chg] last id -1 current id 1 [ 9.975267] PortPower off [ 9.975282] rk_battery_charger_detect_cb , battery_charger_detect 6 [ 10.074704] Using Buffer DMA mode [ 10.074719] Periodic Transfer Interrupt Enhancement - disabled [ 10.074727] Multiprocessor Interrupt Enhancement - disabled [ 10.074735] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 10.074743] ^^^^^^^^^^^^^^^^^Device Mode [ 10.565644] ***************vbus detect***************** [ 10.567832] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 10.744897] Using Buffer DMA mode [ 10.744912] Periodic Transfer Interrupt Enhancement - disabled [ 10.744920] Multiprocessor Interrupt Enhancement - disabled [ 10.744929] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 10.744936] ^^^^^^^^^^^^^^^^^Device Mode [ 10.744982] *******************soft connect!!!******************* [ 10.844244] USB RESET [ 10.930721] android_work: sent uevent USB_STATE=CONNECTED [ 10.942576] WARN::ep0_do_stall:1298: req 80.06 protocol STALL; err -22 [ 10.942576] [ 11.438381] USB RESET [ 11.591652] USB RESET [ 11.753804] WARN::ep0_do_stall:1298: req 80.06 protocol STALL; err -22 [ 11.753804] [ 12.249765] USB RESET [ 12.402945] USB RESET [ 12.565029] WARN::ep0_do_stall:1298: req 80.06 protocol STALL; err -22 [ 12.565029] [ 13.061521] USB RESET [ 13.214675] USB RESET [ 13.376972] WARN::ep0_do_stall:1298: req 80.06 protocol STALL; err -22 [ 13.376972]!(file:///C:\Users\souleo\AppData\Roaming\Tencent\Users\2107663580\QQ\WinTemp\RichOle\OMQ~IK(SWZ]~PHRDSIIXQ[2.png)
