各位好!
我尝试在rk3128上点一款 800x480 的 rgb 屏,做了以下改动:
(主要是屏蔽网卡相关的, 使能lcd rgb相关的)
rk3128-fireprime.dts 文件:
#include “lcd-md070nl.dtsi”
&fb {
//rockchip,disp-mode = <NO_DUAL>;
//rockchip,disp-policy = <DISPLAY_POLICY_BOX>;
//rockchip,disp-policy = <DISPLAY_POLICY_SDK>;
rockchip,disp-mode = ;
//rockchip,disp-mode = <ONE_DUAL>;
rockchip,uboot-logo-on = <0>;//1
&disp_timings {
native-mode = <&timing0>;
&rk_screen {
display-timings = <&disp_timings>;
&lvds {
status = “okay”;
pinctrl-names = "lcdc";
pinctrl-0 = <&lcdc0_lcdc_d>;
&lcdc {
status = “okay”;
backlight = <&backlight>;
pinctrl-names = "default", "gpio";
pinctrl-0 = <&lcdc0_lcdc>;
pinctrl-1 = <&lcdc0_gpio>;
rockchip,fb-win-map = <FB_DEFAULT_ORDER>;
power_ctr: power_ctr {
rockchip,debug = <0>;
lcd_en: lcd_en {
rockchip,power_type = <GPIO>;
gpios = <&gpio3 GPIO_B3 GPIO_ACTIVE_HIGH>;
rockchip,delay = <10>;
&hdmi {
status = “disabled”;
//rockchip,hdmi_audio_source = <1>;
//&gmac_clkin {
// clock-frequency = <125000000>;
//&gmac {
//pmu_regulator = “act_ldo5”;
//pmu_enable_level = <1>; //1->HIGH, 0->LOW
//power-gpio = <&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
//reset-gpio = <&gpio2 GPIO_D0 GPIO_ACTIVE_LOW>;
//phyirq-gpio = <&gpio0 GPIO_D0 GPIO_ACTIVE_LOW>;
//phy-mode = “rgmii”;
//clock_in_out = “input”;
//tx_delay = <0x30>;
//rx_delay = <0x10>;
rk312x.dtsi 文件:
//gmac: eth@2008c000 {
// compatible = “rockchip,rk312x-gmac”;
// reg = <0x2008c000 0x4000>;
// interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; /irq=88/
// interrupt-names = “macirq”;
// clocks = <&clk_mac_ref>, <&clk_gates2 6>,
// <&clk_gates2 7>, <&clk_gates2 4>,
// <&clk_gates2 5>, <&clk_gates10 10>,
// <&clk_gates10 11>;
// clock-names = “clk_mac”, “mac_clk_rx”,
// “mac_clk_tx”, “clk_mac_ref”,
// “clk_mac_refout”, “aclk_mac”,
// “pclk_mac”;
// phy-mode = “rgmii”;
// pinctrl-names = “default”;
// pinctrl-0 = <&gmac_rxdv &gmac_txclk &gmac_crs &gmac_rxclk &gmac_mdio &gmac_txen &gmac_clk &gmac_rxer &gmac_rxd1 &gmac_rxd0 &gmac_txd1 &gmac_txd0 &gmac_rxd3 &gmac_rxd2 &gmac_txd2 &gmac_txd3 &gmac_col_gpio &gmac_mdc>;
lcdc: lcdc@1010e000 {
compatible = “rockchip,rk312x-lcdc”;
rockchip,prop = ;
reg = <0x1010e000 0x1000>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates6 0>, <&dclk_lcdc0>, <&clk_gates6 1>, <&sclk_lcdc0>, <&pd_vop>, <&clk_cpll>;
clock-names = “aclk_lcdc”, “dclk_lcdc”, “hclk_lcdc”, “sclk_lcdc”, “pd_lcdc”, “sclk_pll”;
rockchip,iommu-enabled = <1>;
rk312x-pinctrl.dtsi文件:
//gpio2_gmac {
// gmac_rxdv:gmac-rxdv {
// rockchip,pins = <GMAC_RXDV>;
// rockchip,pull = <VALUE_PULL_DEFAULT>;
// gmac_txclk:gmac-txclk {
// rockchip,pins = <GMAC_TXCLK>;
// gmac_crs:gmac-crs {
// rockchip,pins = <GMAC_CRS>;
// gmac_rxclk:gmac-rxclk {
// rockchip,pins = <GMAC_RXCLK>;
// gmac_mdio:gmac-mdio {
// rockchip,pins = <GMAC_MDIO>;
// gmac_txen:gmac-txen {
// rockchip,pins = <GMAC_TXEN>;
// gmac_clk:gmac-clk {
// rockchip,pins = <GMAC_CLK>;
// gmac_rxer:gmac-rxer {
// rockchip,pins = <GMAC_RXER>;
// gmac_rxd1:gmac-rxd1 {
// rockchip,pins = <GMAC_RXD1>;
// gmac_rxd0:gmac-rxd0 {
// rockchip,pins = <GMAC_RXD0>;
// gmac_txd1:gmac-txd1 {
// rockchip,pins = <GMAC_TXD1>;
// gmac_txd0:gmac-txd0 {
// rockchip,pins = <GMAC_TXD0>;
// gmac_rxd3:gmac-rxd3 {
// rockchip,pins = <GMAC_RXD3>;
// gmac_rxd2:gmac-rxd2 {
// rockchip,pins = <GMAC_RXD2>;
// gmac_txd2:gmac-txd2 {
// rockchip,pins = <GMAC_TXD2>;
// gmac_txd3:gmac-txd3 {
// rockchip,pins = <GMAC_TXD3>;
// gmac_col:gmac-col {
// rockchip,pins = <GMAC_COL>;
// gmac_col_gpio:gmac-col-gpio {
// rockchip,pins = <GPIO2_D0>;
// gmac_mdc:gmac-mdc {
// rockchip,pins = <GMAC_MDC>;
gpio2_lcdc0 {
lcdc0_lcdc:lcdc0-lcdc {
rockchip,pins =
<LCDC0_DCLK>,
<LCDC0_DEN>,
<LCDC0_HSYNC>,
<LCDC0_VSYNC>;
rockchip,pull = <VALUE_PULL_DISABLE>;
lcdc0_gpio:lcdc0-gpio {
rockchip,pins =
<FUNC_TO_GPIO(LCDC0_DCLK)>,
<FUNC_TO_GPIO(LCDC0_DEN)>,
<FUNC_TO_GPIO(LCDC0_HSYNC)>,
<FUNC_TO_GPIO(LCDC0_VSYNC)>;
gpio2_lcdc0_d {
lcdc0_lcdc_d: lcdc0-lcdc_d {
rockchip,pins =
<LCDC0_D10>,
<LCDC0_D11>,
<LCDC0_D12>,
<LCDC0_D13>,
<LCDC0_D14>,
<LCDC0_D15>,
<LCDC0_D16>,
<LCDC0_D17>,
<LCDC0_D18>,
<LCDC0_D19>,
<LCDC0_D20>,
<LCDC0_D21>,
<LCDC0_D22>,
<LCDC0_D23>;
lcdc0_lcdc_gpio: lcdc0-lcdc_gpio {
rockchip,pins =
<FUNC_TO_GPIO(LCDC0_D10)>,
<FUNC_TO_GPIO(LCDC0_D11)>,
<FUNC_TO_GPIO(LCDC0_D12)>,
<FUNC_TO_GPIO(LCDC0_D13)>,
<FUNC_TO_GPIO(LCDC0_D14)>,
<FUNC_TO_GPIO(LCDC0_D15)>,
<FUNC_TO_GPIO(LCDC0_D16)>,
<FUNC_TO_GPIO(LCDC0_D17)>,
<FUNC_TO_GPIO(LCDC0_D18)>,
<FUNC_TO_GPIO(LCDC0_D19)>,
<FUNC_TO_GPIO(LCDC0_D20)>,
<FUNC_TO_GPIO(LCDC0_D21)>,
<FUNC_TO_GPIO(LCDC0_D22)>,
<FUNC_TO_GPIO(LCDC0_D23)>;
rockchip,pull = <VALUE_PULL_DOWN>;
lcd-md070nl.dtsi 文件:
- RockChip. LCD_MD070NL22-50N
timing0: timing0 {
screen-type = <SCREEN_RGB>;
out-face = <OUT_P888>;
clock-frequency = <33000000>;//13000000//33000000//27000000//32000000
hactive = <800>;
vactive = <480>;
hback-porch = <46>;
hfront-porch = <210>;
vback-porch = <23>;
vfront-porch = <22>;
hsync-len = <40>;
vsync-len = <20>;
hsync-active = <1>;
vsync-active = <1>;
de-active = <0>;
pixelclk-active = <1>;
swap-rb = <0>;
swap-rg = <0>;
swap-gb = <0>;
通过以上的改动后,接上屏,有显示,但是显示有问题,一个是屏幕的上半部分和下半部分重复显示了; 另一个是屏的右面有一部分无显示;(如图1,图2,图3)
对于上面的问题,我尝试去调整hback-porch ,hfront-porch ,vback-porch ,vfront-porch ,hsync-len ,vsync-len ,hsync-active ,vsync-active ,de-active ,
pixelclk-active; 但是基本没有任何改变,还是如图的情况;
请问有遇到过类似情况的朋友吗? 是否是哪些地方改动没完成吗? 遇到过类似情况的朋友,请指导下,被这个问题一直困扰着;
(我用的代码是天启的fireprime 的Android5.1的代码)
