rk3128 启动到这块卡住了,应该怎么办
CPU: rk3128
cpu version = 0
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
ÿ*V«k%1¥с= 0 20
SdmmcInit = 2 0
storage init OK!
Writing env to storage…
done
GetParam
Load FDT from resource image.
power key: bank-0 pin-2
dc det not found!
battery: gl=0 dl=0 rl=0, v=4200, m=0
pmic:rk818
DCDC vdd_arm has been used, pwm regulator not init it.
can’t find dts node for ADC
#Boot ver: 2017-12-15#2.31
empty serial no.
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x62000000 (0x0073ebc8)
ramdisk @ 0x65bf0000 (0x002c8f78)
bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 656169b4 … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (chenxiongwei@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #7 SMP PREEMPT Thu Dec 14 13:42:28 CST 2017 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x9dc00000, offset:0x01000000 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x9dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(800000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 8 MiB at 9d400000 [ ꀩon_reserve: cma rese
