edp驱动调试,uboot阶段logo图可以显示,进入ubuntu系统就无图像
如题,edp驱动调试,uboot阶段logo图可以显示,进入ubuntu系统就无图像
使用自己的13.3寸edp屏和17.3寸edp屏,两个屏幕timing参数完全一样,
13.3寸uboot阶段和进入ubuntu系统都可以正常显示,换了17.3寸屏后就只能显示logo图像,
进入ubuntu系统就黑屏了。
有人能解吗?
log,贴下~
luvings 发表于 2017-12-20 11:37
log,贴下~
log信息如下
DDR Version 1.00 20160530
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
rk serial
initcall: 0002d958
U-Boot 2014.10-RK3288-10 (Dec 20 2017 - 11:34:51)
initcall: 00010914
U-Boot code: 00000000 → 00051AC4 BSS: → 000B0370
IRQ Stack: 0badc0de
FIQ Stack: 0badc0de
initcall: 00000a20
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ, mp_cpu = 150000000HZ, m0_cpu = 300000000HZ, l2ram_cpu = 300000000HZ
periph pll = 297000000HZ, aclk_periph = 297000000HZ, hclk_periph = 148500000HZ, pclk_periph = 74250000HZ
aclk_bus = 297000000HZ, hclk_bus = 148500000HZ, pclk_bus = 74250000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
initcall: 00010ccc
initcall: 00010970
DRAM: initcall: 000022a8
DDR End Address: 0x80000000
initcall: 00010abc
Monitor len: 000B0370
Ram size: 08000000
Ram top: 08000000
initcall: 00010614
initcall: 000108bc
TLB table from 07ff0000 to 07ff4000
initcall: 00010890
LCD base at ddr end, fb base = 7dc00000, size = 01000000
initcall: 000107f8
Reserving 4096k for rk global buffer at 07bf0000
Reserving 32768k for rk boot buffer at 05bf0000
Using rk boot buffer as Fastboot transfer buffer.
Reserving 2048k for fastboot log buffer at 059f0000
initcall: 0001062c
initcall: 000107ac
Reserving 704k for U-Boot at: 0593f000
initcall: 0001077c
Reserving 2049k for malloc() at: 0573ec00
initcall: 000109c8
Reserving 224 Bytes for Board Info at: 0573eb20
initcall: 00010634
initcall: 00010748
Reserving 232 Bytes for Global Data at: 0573ea38
initcall: 000106e4
initcall: 00010b2c
Reserving 69632 Bytes for IRQ stack at: 0572da20
initcall: 00010aa4
Found dram banks: 1
initcall: 00010a20
RAM Configuration:
Bank #0: 00000000 128 MiB
DRAM: 128 MiB
initcall: 000106c8
New Stack Pointer is: 0572da10
initcall: 0001064c
initcall: 0001067c
Relocation Offset is: 0593f000
Relocating to 0593f000, new gd at 0573ea38, sp at 0572da10
initcall: 0594fb78
initcall: 0594fc84
initcall: 00010c74 (relocated to 0594fc74)
dram_bank_mmu_setup: bank: 0
initcall: 00010b80 (relocated to 0594fb80)
initcall: 00010ba8 (relocated to 0594fba8)
initcall: 00010c50 (relocated to 0594fc50)
using memory 0x573ec00-0x593f000 for malloc()
initcall: 00010b70 (relocated to 0594fb70)
initcall: 0000dafc (relocated to 0594cafc)
initcall: 0001c274 (relocated to 0595b274)
initcall: 00010c40 (relocated to 0594fc40)
initcall: 00010c24 (relocated to 0594fc24)
Now running in RAM - U-Boot at: 0593f000
initcall: 0000db34 (relocated to 0594cb34)
arch_early_init_r
rk irq version: 1.1, initialized.
gic_irq_init.
GIC CPU mask = 0x01010101
GIC CPU mask = 0x00000001
gpio_irq_init, default enable gpio group interrupt.
initcall: 00010bb0 (relocated to 0594fbb0)
initcall: 00010c14 (relocated to 0594fc14)
rk save sdcard iomux config.
grf gpio6c iomux = 0x00005555
Force select jtag from sdcard io.
GetMmcCLK: sd 0, clk = 148500
SCUSelSDClk: sd id = 0, div = 3
SCUSelSDClk: sd id = 0, div = 62
DATA_BUSY:cmd=0x8, pReg->SDMMC_CMD=0x20008100
SdmmcInit = 0 400
rk restore sdcard iomux config.
GetMmcCLK: sd 2, clk = 148500
SCUSelSDClk: sd id = 2, div = 3
SCUSelSDClk: sd id = 2, div = 62
EMMC BUS mode: 0x2
SdmmcInit = 2 0
storage init OK!
initcall: 00010be4 (relocated to 0594fbe4)
Destroy Hash Table: 0598f90c table = 00000000
Create Hash Table: N=75
INSERT: table 0598f90c, filled 1/79 rv 0573eca8 ==> name=“bootcmd” value=“bootrk”
INSERT: table 0598f90c, filled 2/79 rv 0573ee38 ==> name=“bootdelay” value=“0”
INSERT: table 0598f90c, filled 3/79 rv 0573ecf8 ==> name=“baudrate” value=“115200”
DELETE CANDIDATE: “preboot”
hdelete: DELETE key “preboot”
DELETE ERROR ##############################
INSERT: table 0598f90c, filled 4/79 rv 0573ede8 ==> name=“verify” value=“n”
INSERT: table 0598f90c, filled 5/79 rv 0573ecbc ==> name=“initrd_high” value=“0xffffffff=n”
INSERT: free(data = 0573ec08)
INSERT: done
INSERT: table 0598f90c, filled 5/79 rv 0573ecf8 ==> name=“baudrate” value=“115200”
INSERT: table 0598f90c, filled 5/79 rv 0573eca8 ==> name=“bootcmd” value=“bootrk”
INSERT: table 0598f90c, filled 5/79 rv 0573ee38 ==> name=“bootdelay” value=“0”
INSERT: table 0598f90c, filled 6/79 rv 0573ef14 ==> name=“fastboot_unlocked” value=“0”
INSERT: table 0598f90c, filled 6/79 rv 0573ecbc ==> name=“initrd_high” value=“0xffffffff=n”
INSERT: table 0598f90c, filled 6/79 rv 0573ede8 ==> name=“verify” value=“n”
INSERT: free(data = 0573f358)
INSERT: done
initcall: 00010ca8 (relocated to 0594fca8)
initcall: 0001c290 (relocated to 0595b290)
initcall: 00010bd4 (relocated to 0594fbd4)
initcall: 00019a90 (relocated to 05958a90)
initcall: 00002ef4 (relocated to 05941ef4)
rk irq has been initialized.
initcall: 00010bc4 (relocated to 0594fbc4)
initcall: 0000db54 (relocated to 0594cb54)
board_late_init
getenv: bootdelay = 0
getenv: bootcmd = bootrk
getenv: initrd_high = 0xffffffff=n
GetParam
rk crc32 check: crc_check = 0x10a79664, crc_calc = 0x10a79664
check parameter success
Unknow param: MACHINE_MODEL:rk3288!
Unknow param: MACHINE_ID:007!
Unknow param: MANUFACTURER:RK3288!
partition(resource): offset=0x00002000, size=0x00008000
partition(boot): offset=0x0000A000, size=0x00008000
partition(misc): offset=0x00012000, size=0x00002000
partition(backup): offset=0x00014000, size=0x0001A000
partition(linuxroot): offset=0x0002E000, size=0xFFFFFFFF
rkimage_prepare_fdt
get_content: base_offset = 0xee00
get_entry: base_offset = 0xee00
load_content: load_addr = 0x0573fc80
Load FDT from boot image.
key_init
fdtdec_decode_gpio: gpios
fdtdec_decode_gpios: gpios
power key: bank-0 pin-5
pmic_init
fdtdec_get_addr_size: reg: 0000005a
fdtdec_get_addr_size: reg: ff650000
i2c_reg_read: addr=0x5a, reg=0x22
fdtdec_get_int: regulator-min-microvolt: 0x124f80 (1200000)
fdtdec_get_int: regulator-max-microvolt: 0x124f80 (1200000)
act_dcdc1–act_dcdc1
min_uV:1200000
max_uV:1200000
boot_on:1
fdtdec_get_int: regulator-min-microvolt: 0x325aa0 (3300000)
fdtdec_get_int: regulator-max-microvolt: 0x325aa0 (3300000)
act_dcdc2–vccio
min_uV:3300000
max_uV:3300000
boot_on:1
fdtdec_get_int: regulator-min-microvolt: 0xaae60 (700000)
fdtdec_get_int: regulator-max-microvolt: 0x16e360 (1500000)
act_dcdc3–vdd_logic
min_uV:700000
max_uV:1500000
boot_on:1
fdtdec_get_int: regulator-min-microvolt: 0x1e8480 (2000000)
fdtdec_get_int: regulator-max-microvolt: 0x1e8480 (2000000)
act_dcdc4–act_dcdc4
min_uV:2000000
max_uV:2000000
boot_on:1
fdtdec_get_int: regulator-min-microvolt: 0x1b7740 (1800000)
act_ldo1–vccio_sd
min_uV:1800000
max_uV:3300000
boot_on:1
fdtdec_get_int: regulator-min-microvolt: 0x100590 (1050000)
fdtdec_get_int: regulator-max-microvolt: 0x100590 (1050000)
act_ldo2–act_ldo2
min_uV:1050000
max_uV:1050000
boot_on:1
fdtdec_get_int: regulator-min-microvolt: 0x2ab980 (2800000)
fdtdec_get_int: regulator-max-microvolt: 0x2ab980 (2800000)
act_ldo3–act_ldo3
min_uV:2800000
max_uV:2800000
boot_on:1
act_ldo4–act_ldo4
min_uV:3300000
max_uV:3300000
boot_on:1
act_ldo5–act_ldo5
min_uV:3300000
max_uV:3300000
boot_on:1
fdtdec_get_int: regulator-min-microvolt: 0x10c8e0 (1100000)
fdtdec_get_int: regulator-max-microvolt: 0x10c8e0 (1100000)
act_ldo6–act_ldo6
min_uV:1100000
max_uV:1100000
boot_on:1
fdtdec_get_int: regulator-max-microvolt: 0x1b7740 (1800000)
act_ldo7–vcc_18
min_uV:1800000
max_uV:1800000
boot_on:1
fdtdec_get_int: regulator-min-microvolt: 0x1c3a90 (1850000)
fdtdec_get_int: regulator-max-microvolt: 0x1c3a90 (1850000)
act_ldo8–act_ldo8
min_uV:1850000
max_uV:1850000
boot_on:1
pmic_alloc: new pmic struct: 0x05759688
set act_dcdc1–act_dcdc1 volt:1200000
set act_dcdc2–vccio volt:3300000
set act_dcdc4–act_dcdc4 volt:2000000
set act_ldo2–act_ldo2 volt:1050000
set act_ldo3–act_ldo3 volt:2800000
set act_ldo4–act_ldo4 volt:3300000
set act_ldo5–act_ldo5 volt:3300000
set act_ldo6–act_ldo6 volt:1100000
set act_ldo7–vcc_18 volt:1800000
set act_ldo8–act_ldo8 volt:1850000
pmic:act8846
pwm_regulator_init
can’t find dts node for pwm1
fdtdec_get_int_array: pwms
get_prop_check_min_len: pwms
fdtdec_get_int_array: rockchip,pwm_voltage_map
get_prop_check_min_len: rockchip,pwm_voltage_map
fdtdec_get_int: rockchip,pwm_id: 0x1 (1)
fdtdec_get_int: rockchip,pwm_voltage: 0x10c8e0 (1100000)
fdtdec_get_int: rockchip,pwm_coefficient: 0x1db (475)
fdtdec_get_int: rockchip,pwm_max_voltage: 0x155cc0 (1400000)
fdtdec_get_int: regulator-min-microvolt: 0xe1d48 (925000)
fdtdec_get_int: regulator-max-microvolt: 0x155cc0 (1400000)
pwm_dcdc1–vdd_logic
min_uV:925000
max_uV:1400000
boot_on:1
fg_init
idb init
#Boot ver: 2017-12-20#2.30
My log 1
empty serial no.
fbt preboot
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
fdtdec_get_int: rockchip,uboot-logo-on: 0x1 (1)
drv_lcd_init My log 2
[LCD] Initializing LCD frambuffer at 7dc00000
rk fb parse dt start.
fdtdec_get_int: screen-type: 0x9 (9)
fdtdec_get_int: color-mode: (not found)
fdtdec_get_int: out-face: 0x0 (0)
fdtdec_get_int: hactive: 0x780 (1920)
fdtdec_get_int: vactive: 0x438 (1080)
fdtdec_get_int: clock-frequency: 0x84464e0 (138700000)
fdtdec_get_int: de-active: 0x0 (0)
fdtdec_get_int: hsync-active: 0x0 (0)
fdtdec_get_int: vsync-active: 0x0 (0)
fdtdec_get_int: lvds-format: (not found)
fdtdec_get_int: swap-rb: 0x0 (0)
fdtdec_get_int: hsync-len: 0x20 (32)
fdtdec_get_int: hfront-porch: 0x30 (48)
fdtdec_get_int: hback-porch: 0x50 (80)
fdtdec_get_int: vsync-len: 0x5 (5)
fdtdec_get_int: vfront-porch: 0x3 (3)
fdtdec_get_int: vback-porch: 0x17 (23)
fdtdec_get_int: rockchip,prop: 0x1 (1)
rockchip fb use lcdc0
fdtdec_get_int: rockchip,power_type: 0x0 (0)
fdtdec_get_int: rockchip,delay: 0xa (10)
pwr_ctr_name:lcd_en
pwr_type:gpio
gpio:0x0000000d
atv_val:1
delay:10
lcd timing:
screen_type:9
lcd_face=0x0
vl_col=1920
vl_row=1080
vl_freq = 138700000
lvds_format=-1
lcdc_id=0
rk fb parse dt end.
My log 14-1: vio_limit_freq = 277400000
My log 15-1: pll_hz = 277400000,div = 2
rkclk_cal_pll_set fin_khz = 24000, fout_khz = 277400
gcd_val = 200
YFfenzi = 1387, YFfenmu = 120
fref = 400, PLL_FREF_MAX_KHZ = 2200000
fvco = 554800, PLL_FVCO_MAX_KHZ = 2200000
fout = 277400, PLL_FOUT_MAX_KHZ = 2200000
rate = 277400KHZ, nr = 60, nf = 1387, no = 2
fref = 800, PLL_FREF_MAX_KHZ = 2200000
fvco = 1109600, PLL_FVCO_MAX_KHZ = 2200000
rate = 277400KHZ, nr = 30, nf = 1387, no = 4
fref = 1200, PLL_FREF_MAX_KHZ = 2200000
fvco = 1664400, PLL_FVCO_MAX_KHZ = 2200000
rate = 277400KHZ, nr = 20, nf = 1387, no = 6
fref = 1600, PLL_FREF_MAX_KHZ = 2200000
fvco = 2219200, PLL_FVCO_MAX_KHZ = 2200000
fref = 2000, PLL_FREF_MAX_KHZ = 2200000
fvco = 2774000, PLL_FVCO_MAX_KHZ = 2200000
fref = 2400, PLL_FREF_MAX_KHZ = 2200000
fvco = 3328800, PLL_FVCO_MAX_KHZ = 2200000
rate = 277400KHZ, nr = 60, nf = 2774, no = 4
fref = 600, PLL_FREF_MAX_KHZ = 2200000
rate = 277400KHZ, nr = 40, nf = 2774, no = 6
fref = 1000, PLL_FREF_MAX_KHZ = 2200000
fvco = 4438400, PLL_FVCO_MAX_KHZ = 2200000
nr_out = 20, nf_out = 1387, no_out = 6
pll_hz = 277400000, nr = 20, nf = 1387, no = 6
My log 15-2: pll_hz = 277000000,div = 2
Mylog in rkclk_lcdc_dclk_config: lcdc_id= 0
Mylog in rkclk_lcdc_dclk_config:write CRU_CLKSELS_CON27: 0xff030100
Mylog in rkclk_lcdc_dclk_config:read CRU_CLKSELS_CON27: 0x00000100
Mylog in rkclk_lcdc_aclk_config: lcdc_id= 0
Mylog in rkclk_lcdc_aclk_config:write CRU_CLKSELS_CON31: 0x00df0000
Mylog in rkclk_lcdc_aclk_config:read CRU_CLKSELS_CON31: 0x00000000
Mylog in rkclk_lcdc_aclk_config: lcdc_id= 1
Mylog in rkclk_lcdc_aclk_config:write CRU_CLKSELS_CON31: 0xdf000000
Mylog in rkclk_vio_hclk_set: lcdc_id= 0
Mylog in rkclk_vio_hclk_set:write CRU_CLKSELS_CON28: 0x1f000200
Mylog in rkclk_vio_hclk_set:read CRU_CLKSELS_CON28: 0x00000203
pll_src = 0, dclk_hz = 138700000, dclk_div = 2
fdtdec_get_addr_size: reg: ff930000
fdtdec_get_int: rockchip,fb-win-map: (not found)
edp pll locked
max link rate:2.70Gps max number of lanes:2
link training success.
Timeout of video streamclk ok
unable to config video
[LCD] Using LCD frambuffer at 7dc00000
[LCD] 2 Drawing the logo…
My log-2:def CONFIG_ROCKCHIP in lcd_log()
My log-3:v1_col =1920,v1_row=1080, logow=200,logoh=50
Logo: width 200 height 50 colors 240 cmap 240
Mylog:def CONFIG_RK_FB
My log:in rk_bitmap_from_resource
Failed to find part: ‘logo’
get_content: base_offset = 0x0
get_entry: base_offset = 0x2000
show_resource_image:show logo from resource or boot partition
My log:bitmap_center1
Try to show:logo.bmp
My log:bitmap_center2
My bmp1:width = 1920 ,height = 1080
My panel:pcol = 1920 ,prow = 1080
My hw1:width = 1920,height = 1080My hw2:width = 1920,height = 1080My xy1:x = 0,y = 0
Display-bmp1: 1920 x 1080 with 256 colors
My hw3:width = 1920,height = 1080
My bpix2:bpix = 8
My xy2:x = 0,y = 0
My test1:pwidth = 1920,pheight = 1080
Mylog1: not define CONFIG_PRODUCT_BOX
My hw4:width = 1920,height = 1080
My bpix3:bpix = 8
My log2:not def CONFIG_DIRECT_LOGO,lcd_base = 2109734912
My hw5:width = 1920,height = 1080
My bpix4:bpix = 8
Mylog5: def CONFIG_LCD_BMP_RLE8,lcd_base
Mylog9: def CONFIG_LCD_BMP_RLE8,lcd_base
Mylog11: in for (i = 0; i < height; ++i)Mylog10: break
Mylog7: display
Mylog8: display 3
Test format=2,xact=1920,yact=1080,xsize=1920,vsize=1080,xpos=0,ypos=0
win->win_lb_mode = 4;
yrgb:hsd=0,vsd=0,vsu=1;cbcr:hsd=0,vsd=0,vsu=1
yrgb:h_fac=4096, v_fac=4096,gt4=0, gt2=0
cbcr:h_fac=4096,v_fac=4096,gt4=0,gt2=0
no fuel gauge found
rk pwm parse dt start.
fdtdec_decode_gpio: enable-gpios
fdtdec_decode_gpios: enable-gpios
fdtdec_decode_gpios: property ‘enable-gpios’ missing
fdtdec_get_addr_size: reg: ff680010
bl base = 0xff680010
fdtdec_get_int_array: brightness-levels
get_prop_check_min_len: brightness-levels
fdtdec_get_int: default-brightness-level: 0xb4 (180)
rk pwm parse dt end.
gpio = 0xffffffff is not valid!
rk_pwm_bl_config: brightness: 180
initcall: 00010bb8 (relocated to 0594fbb8)
### main_loop entered: bootdelay=0
### main_loop: bootcmd=“bootrk”
## Current stack ends at 0x0572d650
Try to load fdt from boot.
load_content: load_addr = 0x0575ad80
loader kernel logo from resource.
Initial value for argc=3
Final value for argc=3
Secure Boot state: 0
Image magic: ANDROID!
kernel_size: 0x70a198
kernel_addr: 0x2000000
rdisk_size: 0x2afa86
rdisk_addr: 0x5bf0000
second_size: 0x214a00
second_addr: 0x60f00000
tags_addr: 0x60088000
page_size: 0x4000
name:
cmdline:
id[0]: 0x767bfb25
id[1]: 0x37b53aed
id[2]: 0x42a4d150
id[3]: 0x360993d2
id[4]: 0x77e38948
id[5]: 0x0
id[6]: 0x0
id[7]: 0x0
kernel @ 0x02000000 (0x0070a198)
ramdisk @ 0x05bf0000 (0x002afa86)
bootrk: do_bootm_linux…
using: FDT
## initrd_high = 0xffffffff, copy_to_ram = 0
in-place initrd
ramdisk load start = 0x05bf0000, ramdisk load end = 0x05e9fa86
## device tree at 0575ad80 … 05774630 (len=116913 [0x1C8B1])
Loading Device Tree to 05600000, end 0561c8b0 … OK
No ethernet MAC Address defined
## Transferring control to Linux (at address 02000000)…
[ 0.000000] Linux version 3.10.0 (root@sxl-virtual-machine) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #27 SMP PREEMPT Wed Dec 20 14:28:18 CST 2017
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x7dc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x7dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(28000000) align(0)
[ 0.000000] cma: CMA: reserved 640 MiB at 55c00000
[ 0.000000] ion_reserve: cma reserved base 55c00000 size 671088640
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1fe0000 s13312 r8192 d15360 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523264
[ 0.000000] Kernel command line: vmalloc=496M console=tty0 console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/mmcblk0p5 linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-12-20_11:34:51
[ 0.000000] allocated 4194304 bytes of page_cgroup
[ 0.000000] Memory: 1352460k/1352460k available, 744692k reserved, 884736K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0c65908 (12663 kB)
[ 0.000000] .init : 0xc0c66000 - 0xc0cc0400 ( 361 kB)
[ 0.000000] .data : 0xc0cc2000 - 0xc0e5e200 (1649 kB)
[ 0.000000] .bss : 0xc0e5e200 - 0xc0f848dc (1178 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 3
[ 0.000000] channel:0, lkg:13
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:11
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.347592] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.347623] pid_max: default: 32768 minimum: 301
[ 0.347745] Security Framework initialized
[ 0.347771] SELinux: Initializing.
[ 0.347849] Mount-cache hash table entries: 512
[ 0.348511] Initializing cgroup subsys debug
[ 0.348537] Initializing cgroup subsys memory
[ 0.348571] Initializing cgroup subsys freezer
[ 0.348608] CPU: Testing write buffer coherency: ok
[ 0.348951] /cpus/cpu@0 missing clock-frequency property
[ 0.348975] /cpus/cpu@1 missing clock-frequency property
[ 0.348994] /cpus/cpu@2 missing clock-frequency property
[ 0.349011] /cpus/cpu@3 missing clock-frequency property
[ 0.349073] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 0.349132] Setting up static identity map for 0xc08ef548 - 0xc08ef5a0
[ 0.351639] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x1756 (version 3.1)
[ 0.425012] CPU1: Booted secondary processor
[ 0.425045] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 0.444687] CPU2: Booted secondary processor
[ 0.444713] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 0.464385] CPU3: Booted secondary processor
[ 0.464410] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 0.464512] Brought up 4 CPUs
[ 0.464594] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.464612] CPU: All CPU(s) started in SVC mode.
[ 0.465368] devtmpfs: initialized
[ 0.470001] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 0.471133] pinctrl core: initialized pinctrl subsystem
[ 0.471399] regulator-dummy: no parameters
[ 0.496882] NET: Registered protocol family 16
[ 0.498934] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.499364] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0f5d0cc (version 0.1)
[ 0.499626] Registered FIQ tty driver
[ 0.500049] fiq-debugger is disabled in device tree
[ 0.500901] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 0.500935] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 0.500965] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 0.500993] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 0.501102] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 0.501184] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 0.501262] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 0.501343] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 0.501423] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 0.501500] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 0.501579] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 0.501657] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 0.501742] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 0.501824] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 0.501846] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 0.501868] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 0.501888] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 0.502535] rockchip_interrupts_register:bank_num=7
[ 0.504507] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 0.504539] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 0.504615] rockchip_pinctrl_probe:init ok
[ 0.513957] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.513989] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.514575] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 0.514601] DDR DEBUG: version 1.00 20150126
[ 0.514634] DDR DEBUG: Channel a:
[ 0.514649] DDR DEBUG: DDR3 Device
[ 0.514669] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.514691] DDR DEBUG: Channel b:
[ 0.514703] DDR DEBUG: DDR3 Device
[ 0.514721] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB
[ 0.514743] DDR DEBUG: addr=0xe68000
[ 0.514758] DDR DEBUG: stride=9, size=256, halfcap=40000000
[ 0.514775] DDR DEBUG: socAddr[0]=0xe68000, socAddr[1]=0xe68100
[ 0.514793] DDR DEBUG: chAddr[0]=0xe68000, chAddr[1]=0xe68000
[ 0.514812] DDR DEBUG: dtar[0]=0x1cd000, dtar[1]=0x1cd000
[ 0.514874] DDR DEBUG: init success!!! freq=200MHz
[ 0.514889] DDR DEBUG: Channel a:
[ 0.514908] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.514934] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.514961] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.514987] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.515013] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.515031] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.515047] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.515062] DDR DEBUG: Channel b:
[ 0.515079] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.515105] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.515132] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.515158] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,0 extra clock, DGPS=180,270
[ 0.515183] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 0.515201] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 0.515218] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 0.539938] bio: create slab at 0
[ 0.540444] Rockchip hdmi driver version 2.0
[ 0.540444] .
[ 0.541630] SCSI subsystem initialized
[ 0.541806] usbcore: registered new interface driver usbfs
[ 0.541862] usbcore: registered new interface driver hub
[ 0.541963] usbcore: registered new device driver usb
[ 0.544708] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 0.545558] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 0.546013] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 0.546279] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 0.547074] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 0.547203] media: Linux media interface: v0.10
[ 0.547259] Linux video capture interface: v2.00
[ 0.547323] pps_core: LinuxPPS API ver. 1 registered
[ 0.547342] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.547377] PTP clock support registered
[ 0.547443] i2c-core: driver [bq24296] using legacy suspend method
[ 0.547462] i2c-core: driver [bq24296] using legacy resume method
[ 0.548186] ion_drm_heap_create: 0@0
[ 0.548323] Rockchip ion module is successfully loaded (v1.1)
[ 0.548488] Advanced Linux Sound Architecture Driver Initialized.
[ 0.548901] Bluetooth: Core ver 2.16
[ 0.548966] NET: Registered protocol family 31
[ 0.548984] Bluetooth: HCI device and connection manager initialized
[ 0.549008] Bluetooth: HCI socket layer initialized
[ 0.549030] Bluetooth: L2CAP socket layer initialized
[ 0.549064] Bluetooth: SCO socket layer initialized
[ 0.549307] cfg80211: Calling CRDA to update world regulatory domain
[ 0.550017] act8846_i2c_probe,line=898
[ 0.550998] act8846_parse_dt,line=746
[ 0.551490] act8846_i2c_probe: act8846_pmic_hold=1
[ 0.551518] act8846_i2c_probe: act8846_pmic_sleep=1
[ 0.551541] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 0.551563] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 0.553640] act_dcdc1: 1200 mV
[ 0.556591] vccio: 3300 mV
[ 0.558441] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 0.561397] act_dcdc4: 2000 mV
[ 0.562618] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 0.564946] act_ldo2: 1050 mV
[ 0.567243] act_ldo3: 2800 mV
[ 0.569540] act_ldo4: 3300 mV
[ 0.571846] act_ldo5: 3300 mV
[ 0.574164] act_ldo6: 1100 mV
[ 0.576468] vcc_18: 1800 mV
[ 0.578764] act_ldo8: 1850 mV
[ 0.583509] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 0.588204] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 0.588965] rk808_i2c_probe,line=1355
[ 0.590307] The device is not rk808 -11
[ 0.590398] rk808: probe of 0-001b failed with error -11
[ 0.590495] i2c-core: driver [rk818] using legacy suspend method
[ 0.590515] i2c-core: driver [rk818] using legacy resume method
[ 0.592643] Switching to clocksource arch_sys_counter
[ 0.616901] rga: Module initialized.
[ 0.617643] rga2 ff920000.rga: rga ion client create success!
[ 0.617825] rga: Driver loaded succesfully
[ 0.618026] fb disp policy is box
[ 0.618074] rk-fb rockchip-fb: rk fb ion client create success!
[ 0.618096] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 0.618400] rk-screen rk_screen.8: rockchip screen probe success
[ 0.618569] rk32-lvds ff96c000.lvds: screen is not lvds/rgb!
[ 0.618598] rk32-lvds: probe of ff96c000.lvds failed with error -22
[ 0.619107] rk32-edp rk32-edp: failed to get reset
[ 0.619131] rk32-edp rk32-edp: failed to get reset
[ 0.619251] rk32-edp rk32-edp: rk32 edp driver probe success
[ 0.619804] pwr_ctr_name:lcd_en
[ 0.619804] pwr_type:gpio
[ 0.619804] gpio:13
[ 0.619804] atv_val:1
[ 0.619804] delay:10
[ 0.619804]
[ 0.620081] graphics fb0: rockchip framebuffer registerd:fb0
[ 0.620405] graphics fb1: rockchip framebuffer registerd:fb1
[ 0.620589] graphics fb2: rockchip framebuffer registerd:fb2
[ 0.620768] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.621004] rk3288-lcdc lcdc0: lcdc0: dclk:138700000>>fps:60
[ 0.621028] rk3288-lcdc lcdc0: wakeup from standby!
[ 0.634450] rk_battery_charger_detect_cb , battery_charger_detect 1
[ 0.641176] alloc_buffer:ion_phy_addr=0x55c00000
[ 0.650283] My log fb0:phy:55c00000>>vir:e0971000>>len:0x1000000
[ 0.697466] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled
[ 0.697664] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 0.697687] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 0.697949] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.698280] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.698465] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.698649] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.698908] unknow screen type: 0
[ 0.698980] rk3288-lcdc lcdc1: lcdc1: dclk:138700000>>fps:1066
[ 0.699002] rk3288-lcdc lcdc1: wakeup from standby!
[ 0.699022] My log fb4:phy:55c00000>>vir:e0971000>>len:0x1000000
[ 0.699043] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled
[ 0.699920] rockchip_set_mux:warning ignore bank num 15
[ 0.700063] rockchip_set_mux:warning ignore bank num 15
[ 0.700185] rockchip_set_mux:warning ignore bank num 15
[ 0.700321] rockchip_set_mux:warning ignore bank num 15
[ 0.700461] rockchip_set_mux:warning ignore bank num 15
[ 0.700587] rockchip_set_mux:warning ignore bank num 15
[ 0.701182] rockchip_set_mux:warning ignore bank num 15
[ 0.701360] rockchip_set_mux:warning ignore bank num 15
[ 0.701908] rockchip_set_mux:warning ignore bank num 15
[ 0.702055] rockchip_set_mux:warning ignore bank num 15
[ 0.702611] rockchip_set_mux:warning ignore bank num 15
[ 0.702761] rockchip_set_mux:warning ignore bank num 15
[ 0.703303] rockchip_set_mux:warning ignore bank num 15
[ 0.703457] rockchip_set_mux:warning ignore bank num 15
[ 0.710625] NET: Registered protocol family 2
[ 0.711330] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.711421] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.711504] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.711579] TCP: reno registered
[ 0.711602] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.711636] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.711834] NET: Registered protocol family 1
[ 0.712162] RPC: Registered named UNIX socket transport module.
[ 0.712188] RPC: Registered udp transport module.
[ 0.712206] RPC: Registered tcp transport module.
[ 0.712222] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.712919] Unpacking initramfs…
[ 0.870485] Freeing initrd memory: 2748K (c5bf0000 - c5e9f000)
[ 0.871431] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 0.872008] vcodec_service: probe device ff9a0000.vpu_service
[ 0.872231] vcodec_service: No reset resource define
[ 0.872376] vcodec_service: ff9a0000.vpu_service: power on
[ 0.872471] vcodec_service: probe device ff9a0000.vpu_service
[ 0.872495] vcodec_service: checking hw id 4831
[ 0.872985] vcodec_service: ff9a0000.vpu_service: power off…
[ 0.873033] vcodec_service: done
[ 0.873053] vcodec_service: init success
[ 0.873119] vcodec_service: probe device ff9c0000.hevc_service
[ 0.873442] vcodec_service: ff9c0000.hevc_service: power on
[ 0.873508] vcodec_service: probe device ff9c0000.hevc_service
[ 0.873531] vcodec_service: checking hw id 6867
[ 0.873781] vcodec_service: ff9c0000.hevc_service: power off…
[ 0.873826] vcodec_service: done
[ 0.873844] vcodec_service: init success
[ 0.873987] rknandbase v1.0 2014-03-31
[ 0.874140] rknand: probe of ff400000.nandc failed with error -1
[ 0.874274] rknand_driver:ret = 0
[ 0.876135] audit: initializing netlink socket (disabled)
[ 0.876214] type=2000 audit(0.530:1): initialized
[ 0.877072] bounce pool size: 64 pages
[ 0.881727] NFS: Registering the id_d
[ 0.881810] Key type id_legacy registered
[ 0.881836] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.882390] fuse init (API version 7.22)
[ 0.882784] msgmni has been set to 950
[ 0.884566] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.884600] io scheduler noop registered
[ 0.884616] io scheduler deadline registered
[ 0.884716] io scheduler cfq registered (default)
[ 0.886326] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 0.887036] IEP Driver loaded suLoading, please wait…
Begin: Loading essential drivers … FAccesfully
[ 0.887140] Module initialized.
[ 0.887994] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.888025] dTAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
FATAL: Could not load /lib/modma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 0.889356] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 0.889385] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 0.889694] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API
[ 0.889723] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM
[ 0.889745] pwm_regulator_probe:error
[ 0.889774] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral
[ 0.889991] rk_serial.c v1.8 2014-03-04
[ 0.890223] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 0.890431] serial ff180000.serial: membase e3992000
[ 0.890599] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 0.890784] serial ff190000.serial: membase e39ae000
[ 0.890923] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 0.891029] 2, baud is:115200
[ 0.892539] console [ttyS2] enabled
[ 0.892725] serial ff690000.serial: membase fed60000
[ 0.892918] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 0.893100] serial ff1b0000.serial: membase e39b6000
[ 0.895902] loop: module loaded
[ 0.896289] zram: Created 1 device(s) …
[ 0.896388] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 0.896411] i2c-core: driver [mpu6050B1] using legacy resume method
[ 0.896438] mpu_init: Probe name mpu6050B1
[ 0.896594] ak8963_mod_init: Probe name ak8963_mod
[ 0.897319] SCSI Media Changer driver v0.25
[ 0.897598] dws->regs: e39b8000
[ 0.902758] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 0.903104] tun: Universal TUN/TAP device driver, 1.6
[ 0.903129] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.903259] vmac_init.
[ 0.903900] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 0.903928] stmmac_probe_config_dt: clock input/output? (input).
[ 0.903951] stmmac_probe_config_dt: TX delay(0x30).
[ 0.903970] stmmac_probe_config_dt: RX delay(0x20).
[ 0.904027] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 0.904047] stmmc_pltfr_init:
[ 0.904061] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 0.904094] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 0.904114] stmmc_pltfr_init: init for RGMII
[ 0.904132] tx delay=0x30
[ 0.904132] rx delay=0x20
[ 0.904158] tx delay=0x30
[ 0.904158] rx delay=0x20
[ 0.904680] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 0.904701] Normal descriptors
[ 0.904717] Ring mode enabled
[ 0.904733] DMA HW capability register supported
[ 0.904750] RX Checksum Offload Engine supported (type 2)
[ 0.904770] TX Checksum insertion supported
[ 0.904787] Wake-Up On Lan supported
[ 0.904828] Enable RX Mitigation via HW Watchdog Timer
[ 0.905309] PPP generic driver version 2.4.2
[ 0.905469] PPP BSD Compression module registered
[ 0.905492] PPP Deflate Compression module registered
[ 0.905525] PPP MPPE Compression module registered
[ 0.905546] NET: Registered protocol family 24
[ 0.905592] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.905620] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.905645] Rockchip WiFi SYS interface (V1.00) …
[ 0.905688] esp_mem_init enter date Nov 17 2017 15:55:19
[ 0.905707] esp_mem_init VERSION [V2.5]
[ 0.905758] esp_mem_init complete
[ 0.905854] usbcore: registered new interface driver catc
[ 0.905906] usbcore: registered new interface driver kaweth
[ 0.905928] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.905980] usbcore: registered new interface driver pegasus
[ 0.906035] usbcore: registered new interface driver rtl8150
[ules/3.10.0/modules.dep: No such file or directory
FATAL: Could 0.906085] usbcore: registered new interface driver r8152
[ 0.906105] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.906200] usbcore: registered new interface driver hso
[ 0.906255] usbcore: registered new interface driver asix
[ 0.906304] usbcore: registered new interface driver ax88179_178a
[ 0.906352] usbcore: registered new interface driver cdc_ether
[ 0.906406] usbcore: registered new interface driver cdc_eem
[ 0.906455] usbcore: registered new interface driver dm9601
[ 0.906502] usbcore: registered new interface driver dm9620
[ 0.906582] usbcore: registered new interface driver smsc75xx
[ 0.906642] usbcore: registered new interface driver smsc95xx
[ 0.906691] usbcore: registered new interface driver gl620a
[ 0.906746] usbcore: registered new interface driver net1080
[ 0.906796] usbcore: registered new interface driver plusb
[ 0.906845] usbcore: registered new interface driver rndis_host
[ 0.906895] usbcore: registered new interface driver cdc_subset
[ 0.906942] usbcore: registered new interface driver zaurus
[ 0.906991] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.907080] usbcore: registered new interface driver int51x1
[ 0.907135] usbcore: registered new interface driver kalmia
[ 0.907189] usbcore: registered new interface driver ipheth
[ 0.907242] usbcore: registered new interface driver sierra_net
[ 0.907291] usbcore: registered new interface driver cx82310_eth
[ 0.907348] usbcore: registered new interface driver cdc_ncm
[ 0.907398] usbcore: registered new interface driver qmi_wwan
[ 0.907447] usbcore: registered new interface driver cdc_mbim
[ 0.907469] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.910008] EHCI: ehci_rk_probe e3a40000 e3a40010
[ 0.910038] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 0.910079] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 0.910467] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 0.927282] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 0.927393] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.927424] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.927452] usb usb1: Product: EHCI Host Controller
[ 0.927473] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 0.927494] usb usb1: SerialNumber: ff500000.usb
[ 0.927953] hub 1-0:1.0: USB hub found
[ 0.927991] hub 1-0:1.0: 1 port detected
[ 0.928172] EHCI: ehci_rk_probe ok
[ 0.928314] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.928640] usbcore: registered new interface driver cdc_acm
[ 0.928663] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.928733] usbcore: registered new interface driver usblp
[ 0.928787] usbcore: registered new interface driver cdc_wdm
[ 0.928862] usbcore: registered new interface driver usb-storage
[ 0.928913] usbcore: registered new interface driver ums-alauda
[ 0.928963] usbcore: registered new interface driver ums-cypress
[ 0.929021] usbcore: registered new interface driver ums-datafab
[ 0.929072] usbcore: registered new interface driver ums_eneub6250
[ 0.929122] usbcore: registered new interface driver ums-freecom
[ 0.929172] usbcore: registered new interface driver ums-isd200
[ 0.929239] usbcore: registered new interface driver ums-jumpshot
[ 0.929291] usbcore: registered new interface driver ums-karma
[ 0.929341] usbcore: registered new interface driver ums-onetouch
[ 0.929392] usbcore: registered new interface driver ums-sddr09
[ 0.929442] usbcore: registered new interface driver ums-sddr55
[ 0.929493] usbcore: registered new interface driver ums-usbat
[ 0.929603] usbcore: registered new interface driver usbserial
[ 0.929659] usbcore: registered new interface driver usbserial_generic
[ 0.929702] usbserial: USB Serial support registered for generic
[ 0.929753] usbcore: registered new interface driver option
[ 0.929794] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.929881] usbcore: registered new interface driver trancevibrator
[ 0.929903] usb20_otg: version 3.10a 21-DEC-2012
[ 0.930368] e3a80040
[ 0.930391] Core Release: 3.10a
[ 0.930410] Setting default values for core params
[ 0.930559] Using Buffer DMA mode
[ 0.930579] Periodic Transfer Interrupt Enhancement - disabled
[ 0.930598] Multiprocessor Interrupt Enhancement - disabled
[ 0.930619] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.930637] ^^^^^^^^^^^^^^^^^Device Mode
[ 0.930659] Dedicated Tx FIFOs mode
[ 0.930686] pcd_init otg_dev = ddf31dc0
[ 0.930853] usb20_otg ff580000.usb: DWC OTG Controller
[ 0.930891] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2
[ 0.930937] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 0.931009] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.931036] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.931063] usb usb2: Product: DWC OTG Controller
[ 0.931084] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.931104] usb usb2: SerialNumber: ff580000.usb
[ 0.931541] hub 2-0:1.0: USB hub found
[ 0.931573] hub 2-0:1.0: 1 port detected
[ 0.931892] usb20_host: version 3.10a 21-DEC-2012
[ 0.934427] e3b00040
[ 0.934448] Core Release: 3.10a
[ 0.934469] Setting default values for core params
[ 0.934602] Using Buffer DMA mode
[ 0.934622] Periodic Transfer Interrupt Enhancement - disabled
[ 0.934641] Multiprocessor Interrupt Enhancement - disabled
[ 0.934660] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.934677] ^^^^^^^^^^^^^^^^^^Host Mode
[ 0.934714] usb20_host ff540000.usb: DWC OTG Controller
[ 0.934749] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3
[ 0.934792] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 0.934895] Init: Power Port (0)
[ 0.934957] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.934983] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.935010] usb usb3: Product: DWC OTG Controller
[ 0.935030] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 0.935052] usb usb3: SerialNumber: ff540000.usb
[ 0.935498] hub 3-0:1.0: USB hub found
[ 0.935529] hub 3-0:1.0: 1 port detected
[ 0.936258] usbcore: registered new interface driver xpad
[ 0.936331] usbcore: registered new interface driver usb_acecad
[ 0.936389] usbcore: registered new interface driver aiptek
[ 0.936450] usbcore: registered new interface driver gtco
[ 0.936509] usbcore: registered new interface driver hanwang
[ 0.936582] usbcore: registered new interface driver kbtab
[ 0.936654] usbcore: registered new interface driver wacom
[ 0.936754] ILITEK INFO line = 195 ilitek_touch_driver_probe : *** ilitek_touch_driver_probe ***
[ 0.936786] ILITEK INFO line = 2040 ilitek_main_probe :
[ 0.936807] ILITEK INFO line = 1635 ilitek_power_on : POWER ON
[ 0.936861] ILITEK INFO line = 1580 ilitek_get_gpio_num : reset_gpio = 233 irq_gpio = 168
[ 0.936916] ILITEK INFO line = 598 ilitek_reset : delay = 200
[ 1.153512] ILITEK INFO line = 1786 ilitek_read_tp_info : driver version 5.0.0.0.0.0.0
[ 1.153830] ILITEK ERR line = 472 ilitek_i2c_transfer : ilitek_i2c_transfer err
[ 1.173797] ILITEK ERR line = 472 ilitek_i2c_transfer : ilitek_i2c_transfer err
[ 1.193763] ILITEK ERR line = 472 ilitek_i2c_transfer : ilitek_i2c_transfer err
[ 1.213727] ILITEK ERR line = 472 ilitek_i2c_transfer : ilitek_i2c_transfer err
[ 1.233440] ILITEK ERR line = 552 ilitek_i2c_write_and_read : ilitek_i2c_write_and_read, i2c write error, ret = -11
[ 1.238913] ILITEK ERR line = 472 ilitek_i2c_transfer : ilitek_i2c_transfer err
[ 1.259158] ILITEK ERR line = 472 ilitek_i2c_transfer : ilitek_i2c_transfer err
[ 1.279392] ILITEK ERR line = 472 ilitek_i2c_transfer : ilitek_i2c_transfer err
[ 1.299627] ILITEK ERR line = 472 ilitek_i2c_transfer : ilitek_i2c_transfer err
[ 1.319340] ILITEK ERR line = 561 ilitek_i2c_write_and_read : ilitek_i2c_write_and_read, i2c read error, ret = -11
[ 1.319373] ILITEK ERR line = 2047 ilitek_main_probe : init read tp info error so exit
[ 1.319400] ILITEK INFO line = 636 ilitek_free_gpio : reset_gpio is valid so free
[ 1.319430] ILITEK INFO line = 640 ilitek_free_gpio : irq_gpio is valid so free
[ 1.319508] ILITEK INFO line = 384 ilitek_touch_driver_init : add touch device driver i2c driver.
[ 1.319536] ==gsl_ts_init==
[ 1.319620] GSLX680 Enter gsl_ts_probe
[ 1.635757] gsl_ts_probe–1291, i2c_master_recv fail
[ 1.635786] gslX680: probe of 1-0040 failed with error -11
[ 1.635836] ret=0
[ 1.636139] sensor_register_slave:mma8452,id=17
[ 1.636163] sensor_register_slave:gs_mc3230,id=23
[ 1.636182] gsensor_init
[ 1.636197] sensor_register_slave:mpu6880_acc,id=24
[ 1.636216] sensor_register_slave:mpu6500_acc,id=25
[ 1.636235] sensor_register_slave:cm3217,id=48
[ 1.636253] sensor_register_slave:cm3218,id=49
[ 1.636482] .. rk pwm remotectl v1.1 init
[ 1.636740] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.639285] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.642276] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.642344] i2c /dev entries driver
[ 1.643052] IR NEC protocol handler initialized
[ 1.643075] IR RC5(x) protocol handler initialized
[ 1.643093] IR RC6 protocol handler initialized
[ 1.643110] IR JVC protocol handler initialized
[ 1.643127] IR Sony protocol handler initialized
[ 1.643145] IR RC5 (streamzap) protocol handler initialized
[ 1.643164] IR SANYO protocol handler initialized
[ 1.643181] IR MCE Keyboard/mouse protocol handler initialized
[ 1.643346] usbcore: registered new interface driver uvcvideo
[ 1.643369] USB Video Class driver (1.1.1)
[ 1.643389] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.644956] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.644993] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.645022] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.645052] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.645100] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.645100]
[ 1.645190] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.645379] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe39e8000 size: 0x4000)
[ 1.646092] D1:camsys_platform_probe(1447): ff910000.isp memory:
[ 1.646122] D1:camsys_platform_probe(1457): Register memory (phy: 0xff910000 vir: 0xe3a20000 size: 0x10000)
[ 1.646153] D1:camsys_platform_probe(1452): I2c memory (phy: 0x1df42000 vir: 0xddf42000 size: 0x1000)
[ 1.646183] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.646205] D1:camsys_platform_probe(1472): Probe ff910000.isp device success
[ 1.646708] not find test_power_init dev node
[ 1.646778] i2c-core: driver [bq27320] using legacy suspend method
[ 1.646800] i2c-core: driver [bq27320] using legacy resume method
[ 1.647149] rockchip_temp_probe,line=364
[ 1.704650] tsadc ff280000.tsadc: initialized
[ 1.705042] device-mapper: uevent: version 1.0.3
[ 1.705298] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.705593] Bluetooth: HCI UART driver ver 2.2
[ 1.705617] Bluetooth: HCI H4 protocol initialized
[ 1.705636] Bluetooth: HCILL protocol initialized
[ 1.705655] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.705677] rtk_btusb: Register usb char device interface for BT driver
[ 1.705870] usbcore: registered new interface driver rtk_btusb
[ 1.709252] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.709472] cpuidle: using governor ladder
[ 1.709494] cpuidle: using governor menu
[ 1.709539] Synopsys Designware Multimedia Card Interface Driver
[ 1.709560] MHSC version = Ver 2.00 2015-06-10
[ 1.709850] dw cru_regsbase addr 0x1d8.
[ 1.709878] dw cru_reset_offset val 3.
[ 1.709929] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.709985] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.710306] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.710487] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.710624] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.724333] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.744035] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.744053] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.744079] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.744389] dw cru_regsbase addr 0x1d8.
[ 1.744412] dw cru_reset_offset val 0.
[ 1.744433] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.744476] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.745266] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.745449] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.745982] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.746060] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.763689] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.776136] mmc0: BKOPS_EN bit is not set
[ 1.778012] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.780297] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.780331] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.780362] [mmc0] tuning regsbase addr 0x218.
[ 1.781070] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[ 1.781087] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.781116] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 1.781153] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.781188] [mmc0] Data transmission error !!! MINTSTS: [0x00000080]
[ 1.781203] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.781239] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.781273] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.781289] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.781325] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-84
[ 1.781379] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-237 (22 len)
[ 1.781398] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 282-282 (1 len)
[ 1.781415] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-237 (22 len)
[ 1.781432] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 124
[ 1.781482] mmc0: new HS200 MMC card at address 0001
[ 1.781786] mmcblk0: mmc0:0001 AJNB4R 14.5 GiB
[ 1.782114] resource: 0x000400000 – 0x001400000 (16 MB)
[ 1.782132] boot: 0x001400000 – 0x002400000 (16 MB)
[ 1.782147] misc: 0x002400000 – 0x002800000 (4 MB)
[ 1.782161] backup: 0x002800000 – 0x005c00000 (52 MB)
[ 1.782175] linuxroot: 0x005c00000 – 0x3a3a00000 (14814 MB)
[ 1.782202] mmcblk0: p1 p2 p3 p4 p51358..dw_mci_set_ios: no card. [mmc1]
[ 1.783396] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.783405] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.783699] dw cru_regsbase addr 0x1d8.
[ 1.783713] dw cru_reset_offset val 1.
[ 1.783728] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.783779] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.784004] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.784128] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.784384] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.803040] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.822755] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.822779] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.823057] leds-gpio leds.30: pins are not configured from the driver
[ 1.823289] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.823357] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.824805] usbcore: registered new interface driver usbhid
[ 1.824821] usbhid: USB HID core driver
[ 1.824933] ashmem: initialized
[ 1.825053] logger: created 256K log ‘log_main’
[ 1.825148] logger: created 256K log ‘log_events’
[ 1.825246] logger: created 256K log ‘log_radio’
[ 1.825354] logger: created 256K log ‘log_system’
[ 1.826446] input: rk29-keypad as /devices/ff100000.adc/key.33/input/input1
[ 1.827321] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.827352] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.827370] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.827392] ES8323 2-0010: Error applying setting, reverse things back
[ 1.827690] es8323 probe i2c recv ok
[ 1.828627] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.829209] es8323_probe
[ 2.462675] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 2.462697] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 2.462712] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 2.462725] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 2.462739] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 2.462752] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 2.462767] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 2.462780] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 2.462794] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 2.462807] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 2.462821] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 2.462834] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 2.462849] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 2.462861] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 2.462875] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 2.462888] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 2.462902] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 2.462915] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 2.462930] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 2.462943] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 2.462964] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 2.462978] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 2.462993] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 2.463006] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 2.463021] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 2.463034] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 2.463049] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 2.463062] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 2.463076] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 2.463089] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 2.463103] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 2.463117] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 2.463141] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 2.463154] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 2.463168] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 2.463180] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 2.463194] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 2.463207] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 2.463222] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 2.463235] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 2.463249] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 2.463262] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 2.463275] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 2.463289] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 2.463426] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 2.463443] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 2.463456] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 2.463470] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 2.463491] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 2.469802] rockchip-es8323 rockchip-es8323.28: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 2.470171] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.28/sound/card0/input2
[ 2.470570] u32 classifier
[ 2.470582] Actions configured
[ 2.470594] Netfilter messages via NETLINK v0.30.
[ 2.470648] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.470919] ctnetlink v0.93: registering with nfnetlink.
[ 2.470985] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.470997] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.471226] xt_time: kernel timezone is -0000
[ 2.471399] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.471512] arp_tables: (C) 2002 David S. Miller
[ 2.471546] TCP: cubic registered
[ 2.471555] Initializing XFRM netlink socket
[ 2.471725] NET: Registered protocol family 10
[ 2.472208] mip6: Mobile IPv6
[ 2.472236] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.472342] sit: IPv6 over IPv4 tunneling driver
[ 2.472618] NET: Registered protocol family 17
[ 2.472643] NET: Registered protocol family 15
[ 2.472697] Bridge firewalling registered
[ 2.472711] Ebtables v2.0 registered
[ 2.472870] Bluetooth: RFCOMM TTY layer initialized
[ 2.472910] Bluetooth: RFCOMM socket layer initialized
[ 2.472920] Bluetooth: RFCOMM ver 1.11
[ 2.472930] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.472938] Bluetooth: BNEP filters: protocol multicast
[ 2.472951] Bluetooth: BNEP socket layer initialized
[ 2.472961] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.472973] Bluetooth: HIDP socket layer initialized
[ 2.473028] l2tp_core: L2TP core driver, V2.0
[ 2.473043] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.473053] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.473256] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.473271] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.473282] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 2.473294] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.473305] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 2.473317] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.473341] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 2.473364] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 2.473377] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.473404] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 2.473417] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.473458] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.473574] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 2.473594] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 2.473611] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 2.473628] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 2.473645] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 2.473690] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.473785] [BT_RFKILL]: ** disable irq
[ 2.473862] [BT_RFKILL]: ap6335 device registered.
[ 2.473918] Key type dns_resolver registered
[ 2.474601] rk3288_init_suspend
[ 2.474616] rk3288_suspend_init enter
[ 2.474822] rk3288_suspend_init: pm_ctrbits =200005
[ 2.474859] gpio_get_dts_info suspend:4
[ 2.474869] gpio_get_dts_info resume:4
[ 2.474876] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.474909] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.475037] clks_gating_suspend_init:clkgt info ok
[ 2.475111] Registering SWP/SWPB emulation handler
[ 2.475126] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x7dc00000
[ 2.477410] ddrfreq: verion 1.2 20140526
[ 2.477432] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz
[ 2.477446] ddrfreq: auto-freq=0
[ 2.477454] ddrfreq: auto-freq-table[0] 240MHz
[ 2.477462] ddrfreq: auto-freq-table[1] 324MHz
[ 2.477469] ddrfreq: auto-freq-table[2] 456MHz
[ 2.477477] ddrfreq: auto-freq-table[3] 528MHz
[ 2.480861] regulator-dummy: disabling
[ 2.481072] =======================================================
[ 2.481086] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.481096] =======================================================
[ 2.481105] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.481163] dhd_module_init: in
[ 2.481173] ======== bcm_wlan_set_plat_data ========
[ 2.481182] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.481205] host_oob_irq: 196
[ 2.481212] host_oob_irq_flags=4
[ 2.481214] pcd_pullup, is_on 0
[ 2.481226] dhd_wifi_platform_load: Enter
[ 2.481243] file system registered
[ 2.481255] Power-up adapter ‘DHD generic adapter’
[ 2.481276] wifi_platform_set_power = 1
[ 2.481284] ======== PULL WL_REG_ON HIGH! ========
[ 2.481292] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.481301] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.481310] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.481728] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.481742] android_usb gadget: Number of LUNs=2
[ 2.481751] lun0: LUN: removable file: (no medium)
[ 2.481760] lun1: LUN: removable file: (no medium)
[ 2.481885] android_usb gadget: android_usb ready
[ 2.481961] sensor_init: Probe name sensors
[ 2.482010] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.482536] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:01 UTC (1293883201)
[ 2.488322] rockchip-spdif-card rockchip-spdif-card.26: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
[ 2.488974] usbcore: registered new interface driver snd-usb-audio
[ 2.488986] ALSA device list:
[ 2.488994] #0: RK_ES8323
[ 2.489000] #1: RK-SPDIF-CARD
[ 2.489238] 2, baud is:115200
[ 2.489393] Freeing unused kernel memory: 360K (c0c66000 - c0cc0000)
[ 2.508256] udevd[156]: starting version 175
[ 2.580414] [WLAN_RFKILL]: wifi turn on power. 156
[ 2.787212] wifi_platform_bus_enumerate device present 1
[ 2.787234] ======== Card detection to detect SDIO card! ========
[ 2.787245] mmc2:mmc host rescan start!
[ 2.803325] EXT4-fs (mmcblk0p5): 2 orphan inodes deleted
[ 2.803339] EXT4-fs (mmcblk0p5): recovery complete
[ 2.810891] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.905111] EHCI: rk_ehci_hcd_enable, disable host controller
[ 2.905132] dwc_otg_hcd_enable, enable host controller
[ 3.003519] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[ 3.018276] Using Buffer DMA mode
[ 3.018285] Periodic Transfer Interrupt Enhancement - disabled
[ 3.018294] Multiprocessor Interrupt Enhancement - disabled
[ 3.018304] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.018311] ^^^^^^^^^^^^^^^^^^Host Mode
[ 3.038114] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.039610] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.041109] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.043801] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.062629] Init: Power Port (0)
[ 3.096147] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[ 3.096176] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[ 3.096225] rk_sdmmc: BOOT Bus speed=50000000Hz,Bus width=4bits.[mmc2]
[ 3.097758] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.097782] mmc2: new high speed SDIO card at address 0001
[ 3.113828] bcmsdh_register: register client driver
[ 3.113886] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.113943] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 3.113953] bus num (host idx)=2, slot num (rca)=1
[ 3.113962] found adapter info ‘DHD generic adapter’
[ 3.114163] F1 signature read @0x18000000=0x16224335
[ 3.115848] F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x2
[ 3.116096] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 3.116141] wifi_platform_get_mac_addr
[ 3.116150] ======== bcm_wlan_get_mac_address ========
[ 3.116159] [WLAN_RFKILL]: rockchip_wifi_mac_addr: enter.
[ 3.116171] [WLAN_RFKILL]: falsh wifi_custom_mac_addr=[00:00:00:00:00:00]
[ 3.116180] [WLAN_RFKILL]: This mac address is not valid, ignored…
[ 3.116192] dhd_conf_set_chiprev: chip=0x4339, chiprev=1
[ 3.116229] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[ 3.116475] wl_create_event_handler(): thread:wl_event_handler:12c started
[ 3.116480] tsk Enter, tsk = 0xdd58147c
[ 3.116584] dhd_attach(): thread:dhd_watchdog_thread:12d started
[ 3.116625] dhd_attach(): thread:dhd_dpc:12e started
[ 3.116633] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 3.116673] dhd_attach(): thread:dhd_rxf:12f started
[ 3.116687] dhd_deferred_work_init: work queue initialized
[ 3.116785] dhdsdio_probe_init: set use_rxchain 1 from config.txt
[ 3.121358] Dongle Host Driver, version 1.201.59.5 (r506368)
[ 3.121358] Compiled in drivers/net/wireless/bcmdhd on Nov 17 2017 at 15:55:44
[ 3.121649] Register interface [wlan0] MAC: b0:f1:ec:6b:ff:7e
[ 3.121649]
[ 3.121666] dhd_prot_ioctl : bus is down. we have nothing to do
[ 3.121701] bcmsdh_oob_intr_unregister: Enter
[ 3.121710] bcmsdh_oob_intr_unregister: irq is not registered
[ 3.121722] dhd_txglom_enable: enable 0
[ 3.121730] dhd_bus_devreset: WLAN OFF DONE
[ 3.121761] wifi_platform_set_power = 0
[ 3.121769] ======== PULL WL_REG_ON LOW! ========
[ 3.121777] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 3.229823] [WLAN_RFKILL]: wifi shut off power.
[ 3.229836] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[ 3.229851] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 3.229884] dhd_module_init: Exit err=0
[ 3.249527] Indeed it is in host mode hprt0 = 00021501
[ 3.426638] usb 3-1: new high-speed USB device number 2 using usb20_host
[ 3.426701] Indeed it is in host mode hprt0 = 00001101
[ 3.623639] usb 3-1: New USB device found, idVendor=1a40, idProduct=0101
[ 3.623655] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.623666] usb 3-1: Product: USB 2.0 Hub [MTT]
[ 3.623949] hub 3-1:1.0: USB hub found
[ 3.624009] hub 3-1:1.0: 4 ports detected
done.
Begin: Running /scripts/init-premount … ls: /sys/block/mmcblk0/mmcblk0p*/volname: No such file or directory
done.
ext4
Begin: Running /scripts/local-premount … FATAL: Could not load /lib/modules/3.10.0/modules.dep: No such file or directory
done.
Begin: Running /scripts/local-bottom … done.
done.
Begin: Running /scripts/init-bottom … done.
SELinux: Could not open policy file <= /etc/selinux/targeted/policy/policy.30: No such file or directory
[ 6.036512] 2, baud is:115200
[ 6.141341] init: plymouth-upstart-bridge main process (306) terminated with status 1
[ 6.141526] init: plymouth-upstart-bridge main process ended, respawning
[ 6.149901] 2, baud is:115200
[ 6.179081] init: plymouth-upstart-bridge main process (316) terminated with status 1
[ 6.179212] init: plymouth-upstart-bridge main process ended, respawning
[ 6.180774] init: ureadahead main process (309) terminated with status 5
[ 6.187766] 2, baud is:115200
[ 6.251023] init: plymouth-upstart-bridge main process (319) terminated with status 1
[ 6.251103] init: plymouth-upstart-bridge main process ended, respawning
[ 6.252607] 2, baud is:115200
[ 6.346673] init: mounted-proc main process (333) terminated with status 1
  • Starting Mount filesystems on boot [ OK ]
  • Starting Signal sysvinit that the rootfs is mounted [ OK ]
  • Starting Clean /tmp directory [ OK ]
  • Stopping Track if upstart is running in a container [ OK ]
  • Stopping Clean /tmp directory [ OK ]
  • Starting Initialize or finalize resolvconf [ OK ]
  • Starting Signal sysvinit that virtual filesystems are mounted [ OK ]
  • Starting Signal sysvinit that local filesystems are mounted [ OK ]
  • Starting restore software rfkill state [ OK ]
  • Starting Bridge udev events into upstart [ OK ]
  • Starting Signal sysvinit that remote filesystems are mounted [ OK ]
  • Starting device node and kernel event manager [ OK ]
  • Stopping Mount filesystems on boot [ OK ]
  • Starting NFSv4 id ↔ name mapper [ OK ]
  • Stopping restore software rfkill state [ OK ]
  • Starting flush early job output to logs [ OK ]
  • Starting load modules from /etc/modules [ OK ]
  • Starting log initial device creation [ OK ]
  • Starting D-Bus system message bus [ OK ]
  • Stopping flush early job output to logs [ OK ]
  • Stopping load modules from /etc/modules [ OK ]
  • Starting SystemD login management service [ OK ]
  • Stopping rpcsec_gss daemon [ OK ]
  • Starting configure network device security [ OK ]
  • Starting configure network device [ OK ]
  • Starting system logging daemon [ OK ]
  • Starting userspace bootsplash [ OK ]
  • Starting mDNS/DNS-SD daemon [ OK ]
  • Starting bluetooth initialization [ OK ]
  • Stopping userspace bootsplash [ OK ]
  • Starting Send an event to indicate plymouth is up [ OK ]
  • Starting bluetooth initialization [fail]
  • Starting Reload cups, upon starting avahi-daemon to make sure remote queues are populated [ OK ]
  • Stopping Send an event to indicate plymouth is up [ OK ]
  • Starting bluetooth daemon [ OK ]
  • Stopping Reload cups, upon starting avahi-daemon to make sure remote queues are populated [ OK ]
  • Starting Turn on/off the ap6335 bluetooth [ OK ]
  • Starting Mount network filesystems [ OK ]
  • Starting Upstart job to start rpcbind on boot only [ OK ]
  • Starting Failsafe Boot Delay [ OK ]
  • Stopping Upstart job to start rpcbind on boot only [ OK ]
  • Starting CUPS printing spooler/server [ OK ]
  • Stopping Failsafe Boot Delay [ OK ]
  • Stopping Mount network filesystems [ OK ]
  • Starting System V initialisation compatibility [ OK ]
  • Starting modem connection manager [ OK ]
  • Setting sensors limits [ OK ]
  • Stopping cold plug devices [ OK ]
  • Starting RPC portmapper replacement [ OK ]
  • Stopping log initial device creation [ OK ]
  • Setting up X socket directories… [ OK ]
  • Starting NSM status monitor [ OK ]
  • Stopping System V initialisation compatibility [ OK ]
  • Starting cups-browsed - Bonjour remote printer browsing daemon [ OK ]
  • Not starting NFS kernel daemon: no exports.
  • Starting System V runlevel compatibility [ OK ]
  • Starting regular background program processing daemon [ OK ]
  • Starting anac(h)ronistic cron [ OK ]
  • Starting save kernel messages [ OK ]
  • Starting OpenSSH server [ OK ]
  • Stopping save kernel messages [ OK ]
  • Starting configure virtual network devices [ OK ]
  • Starting crash report submission daemon [ OK ]
  • Starting NTP server ntpd [ OK ]
  • Stopping Restore Sound Card State [ OK ]
  • Starting automatic crash report generation [fail]
  • Stopping automatic crash report generation [ OK ]
    [ 8.947021] mali_kbase: version magic '3.10.0+ SMP preempt mod_unload ARMv7 p2v8 ’ should be '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ’
    insmod: ERROR: could not insert module /system/lib/modules/mali_kbase.ko: Invalid module format
  • Stopping System V runlevel
    Ubuntu 14.04.1 LTS firefly ttyS2
firefly login: root (automatic login)
Last login: Sat Jan 1 12:00:31 UTC 2011 on ttyS2
Welcome to Ubuntu 14.04.1 LTS (GNU/Linux 3.10.0 armv7l)
244 packages can be updated.
159 updates are security updates.
[ 9.323972] (null): test111:0
[ 9.323981] (null): -527204352
[ 9.323989] (null): hw lt test:0
[ 9.323994] rk32-edp rk32-edp: hw lt err:0
root@firefly:~#
使能脚和reset脚等是不一致
luvings 发表于 2017-12-22 14:55
使能脚和reset脚等是不一致
edp屏只接了只有bl enable脚接在了gpio0_B5上,也没有reset脚
