12-22 02:14:52.894 3448-3478/com.siwill.sw_ac_adfe D/mali_winsys: EGLint new_window_surface(egl_winsys_display*, void*, EGLSurface, EGLConfig, egl_winsys_surface**, egl_color_buffer_format*, EGLBoolean) returns 0x3000
12-22 02:14:52.905 261-671/? I/CameraService: CameraService::connect call (PID -1 "com.siwill.sw_ac_adfe", camera ID 1) for HAL version default and Camera API version 1
12-22 02:14:52.908 261-671/? D/CameraHal: camera_get_number_of_cameras(1224): camera_get_number_of_cameras(1224): Current board have 2 cameras attached.
12-22 02:14:52.908 261-671/? D/CameraHal: camera_get_number_of_cameras(1227): meida_profiles_xml_control time (159)us
12-22 02:14:52.908 261-671/? I/CameraService: onTorchStatusChangedLocked: Torch status changed for cameraId=0, newStatus=0
12-22 02:14:52.908 261-671/? I/CameraService: onTorchStatusChangedLocked: Torch status changed for cameraId=1, newStatus=0
12-22 02:14:52.908 261-671/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_1 facing(0), orientation(180)
12-22 02:14:52.919 259-3916/? D/NuPlayerDriver: notifyListener_l(0xf01aab40), (1, 0, 0), loop setting(0, 0)
12-22 02:14:52.930 259-3918/? D/NuPlayerDriver: notifyListener_l(0xee98d3c0), (1, 0, 0), loop setting(0, 0)
12-22 02:14:52.941 259-3920/? D/NuPlayerDriver: notifyListener_l(0xf01ab200), (1, 0, 0), loop setting(0, 0)
12-22 02:14:52.944 261-671/? I/CameraFlashlight: Opening camera 1
12-22 02:14:52.945 261-671/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_1 facing(0), orientation(180)
12-22 02:14:52.945 261-671/? I/CameraHal: camera_device_open(567): camera_device open
12-22 02:14:52.945 261-671/? D/CameraHal: gCameraHalLogLevel: 0
12-22 02:14:52.946 261-671/? D/CameraHal: CameraHal(136): it is a isp camera
12-22 02:14:52.946 261-671/? D/mfdenoise: ---------- MutliFrameDenoise-4.5 ----------
12-22 02:14:52.946 261-671/? D/CameraHal: Calling process is: com.siwill.sw_ac_adfe
12-22 02:14:52.947 261-671/? D/CameraHal: Calling process is: com.siwill.sw_ac_adfe
12-22 02:14:52.951 261-671/? E/CameraHal: disconnectCamera(1891): getFocusLimits failed!
12-22 02:14:53.064 261-671/? E/CameraHal_Marvin: OV13850: OV13850_IsiCheckSensorConnectionIss read chip revision ok, revison:0xb2
12-22 02:14:53.064 261-671/? D/CameraHal_Marvin: CameraHal Version Check:
12-22 02:14:53.065 261-671/? D/CameraHal_Marvin: CamSys_Head.h version:
kernel: (0x) v0.d.0
libisp_siliconimage_isp.so: (0x) v0.d.0
12-22 02:14:53.065 261-671/? D/CameraHal_Marvin: LibIsp version:
local: (0x) v1.47.0
camera.rk30board.so: (0x) v1.47.0
12-22 02:14:53.065 261-671/? D/CameraHal_Marvin: Sensor ISI version:
libisp_isi_drv_XXX: (0x) v0.d.0
12-22 02:14:53.065 261-671/? D/CameraHal_Marvin: Tunning XML version:
libisp_isi_drv_XXX: (22-May-2014_OUYANG_OV13850_FX288_v1.0)
Calibdb: (06-Aug-2014_ZYL-OYYF_OV13850_CMK-CT0116-FV1_v0.1.2)
12-22 02:14:53.065 261-671/? D/CameraHal_Marvin: sensor name OV13850:
sensor drv version: (0x) v0.c.0
12-22 02:14:53.065 261-671/? D/CameraHal: setupPreview(325): isp out put format is YUV420SP.
12-22 02:14:53.065 261-671/? D/CameraHal: setupPreview(337): Sensor output: 2112x1568 --(0,0,2112,1568)--> User request: 640x480
12-22 02:14:53.068 261-671/? E/CameraHal_Marvin: OV13850: OV13850_IsiCheckSensorConnectionIss read chip revision ok, revison:0xb2
12-22 02:14:53.276 261-671/? D/CameraHal: cam_mem_gralloc_ops_alloc(388): alloc graphic buffer sucess,mem 0xf1fde120, vir_addr 0xf0910000,fd 31
12-22 02:14:53.276 261-671/? D/CameraHal: cam_mem_gralloc_ops_iommu_map(428): mem 0xf1fde120, fd 31
12-22 02:14:53.312 261-671/? D/CameraHal: cam_mem_gralloc_ops_alloc(388): alloc graphic buffer sucess,mem 0xf1fde160, vir_addr 0xef61d000,fd 33
12-22 02:14:53.312 261-671/? D/CameraHal: cam_mem_gralloc_ops_iommu_map(428): mem 0xf1fde160, fd 33
12-22 02:14:53.349 261-671/? D/CameraHal: cam_mem_gralloc_ops_alloc(388): alloc graphic buffer sucess,mem 0xf1fde1a0, vir_addr 0xee32a000,fd 35
12-22 02:14:53.350 261-671/? D/CameraHal: cam_mem_gralloc_ops_iommu_map(428): mem 0xf1fde1a0, fd 35
12-22 02:14:53.384 261-671/? D/CameraHal: cam_mem_gralloc_ops_alloc(388): alloc graphic buffer sucess,mem 0xf1fde1e0, vir_addr 0xed037000,fd 37
12-22 02:14:53.384 261-671/? D/CameraHal: cam_mem_gralloc_ops_iommu_map(428): mem 0xf1fde1e0, fd 37
12-22 02:14:53.416 261-671/? D/CameraHal: cam_mem_gralloc_ops_alloc(388): alloc graphic buffer sucess,mem 0xf1fde220, vir_addr 0xebd44000,fd 39
12-22 02:14:53.416 261-671/? D/CameraHal: cam_mem_gralloc_ops_iommu_map(428): mem 0xf1fde220, fd 39
12-22 02:14:53.450 261-671/? D/CameraHal: cam_mem_gralloc_ops_alloc(388): alloc graphic buffer sucess,mem 0xf1fde260, vir_addr 0xeaa51000,fd 41
12-22 02:14:53.450 261-671/? D/CameraHal: cam_mem_gralloc_ops_iommu_map(428): mem 0xf1fde260, fd 41
12-22 02:14:53.484 261-671/? D/CameraHal: cam_mem_gralloc_ops_alloc(388): alloc graphic buffer sucess,mem 0xf1fde2a0, vir_addr 0xe975e000,fd 43
12-22 02:14:53.484 261-671/? D/CameraHal: cam_mem_gralloc_ops_iommu_map(428): mem 0xf1fde2a0, fd 43
12-22 02:14:53.519 261-671/? D/CameraHal: cam_mem_gralloc_ops_alloc(388): alloc graphic buffer sucess,mem 0xf1fde2e0, vir_addr 0xe846b000,fd 45
12-22 02:14:53.519 261-671/? D/CameraHal: cam_mem_gralloc_ops_iommu_map(428): mem 0xf1fde2e0, fd 45
12-22 02:14:53.598 261-671/? E/CameraHal_Marvin: CAM_ENGINE_API: CamEngineStart (IsiGetColorIss failed -> RESULT=2)
12-22 02:14:53.600 261-671/? E/CameraHal_Marvin: OV13850: OV13850_IsiCheckSensorConnectionIss read chip revision ok, revison:0xb2
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1090): ------mHardInfo.mVcmInfo.mVcmDrvName is DW9714-----
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1352): Support Preview format: yuv420sp,yuv420p yuv420sp(default)
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1354): Support Preview sizes: 176x144,320x240,352x288,640x480,720x480,800x600,1280x720,1920x1080,2112x1568,2064x1548 1920x1080(default) 1920x1080(force)
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1355): Support Preview FPS range: (3000,30000),(30000,30000)
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1356): Support Preview framerate: 10,15,20,30
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1357): Support Picture sizes: 4224x3136,4096x3096,4096x3072,3264x2448,2592x1944,1600x1200,640x480,352x288,320x240,176x144,1280x720,1920x1080 4224x3136(default)
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1358): Support Focus: fixed,auto,continuous-picture Focus zone: 1
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1360): Support Flash: off,on,auto,torch Flash: off
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1361): Support AWB: auto,incandescent,fluorescent,daylight
12-22 02:14:53.602 261-671/? D/CameraHal: initDefaultParameters(1362): Support FOV test h(60.000000) v(60.000000)
12-22 02:14:53.603 261-671/? D/CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (1920x1080)
12-22 02:14:53.603 261-671/? D/CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
12-22 02:14:53.603 261-671/? D/CameraHal: isNeedToRestartPreview(146): video width (1920x1080)
12-22 02:14:53.605 261-671/? D/CameraHal: enableSensor(214): orientation = 0xf575c040 (MPL Accelerometer)
12-22 02:14:53.605 448-479/system_process D/Sensors: int sensors_poll_context_t::activate(int, int)
12-22 02:14:53.605 448-479/system_process V/Sensors: HAL:enable - sensor Accelerometer (handle 2) dis -> en
12-22 02:14:53.605 448-479/system_process V/Sensors: HAL:Accelerometer sensor state change what=2
12-22 02:14:53.606 448-479/system_process E/Sensors: HAL: int self_test_auto_load_state_read(): Open of /sys/bus/iio/devices/iio:device0/cal_data_auto_load failed with 'No such file or directory' (2)
12-22 02:14:53.606 448-479/system_process V/Sensors: HAL:handle = 2
12-22 02:14:53.606 448-479/system_process V/Sensors: HAL:flags = 1
12-22 02:14:53.606 448-479/system_process V/Sensors: HAL:enable : mEnabled = 4
12-22 02:14:53.606 448-479/system_process V/Sensors: HAL:sen_mask= 0x70
12-22 02:14:53.606 448-479/system_process V/Sensors: HAL:changed = 4
12-22 02:14:53.606 448-479/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/power_state (5615712728138)
12-22 02:14:53.606 448-479/system_process V/Sensors: HAL:sysfs:echo 0 > /sys/bus/iio/devices/iio:device0/buffer/enable (5615713036722)
12-22 02:14:53.606 448-479/system_process V/Sensors: HAL:enableSensors - sensors: 0x70
12-22 02:14:53.607 448-479/system_process V/Sensors: HAL:enableSensors - accel enable
12-22 02:14:53.607 448-479/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/accl_enable (5615713364555)
12-22 02:14:53.607 448-479/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_accel_x_en (5615713543930)
12-22 02:14:53.607 448-479/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_accel_y_en (5615713731764)
12-22 02:14:53.607 448-479/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/scan_elements/in_accel_z_en (5615713950222)
12-22 02:14:53.607 448-479/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/buffer/enable (5615714133680)
12-22 02:14:53.630 448-479/system_process D/Sensors: set sensor(2) delay 200000000 ns
12-22 02:14:53.630 448-479/system_process D/Sensors: int sensors_poll_context_t::setDelay(int, int64_t)
12-22 02:14:53.630 448-479/system_process V/Sensors: setDelay : 200000000 ns, (5.00 Hz)
12-22 02:14:53.630 448-479/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/power_state (5615736606016)
12-22 02:14:53.630 448-479/system_process V/Sensors: HAL:sysfs:echo 0 > /sys/bus/iio/devices/iio:device0/buffer/enable (5615736886891)
12-22 02:14:53.635 448-479/system_process V/Sensors: HAL:wanted rate for all sensors : 200000000 ns, mpl rate: 200000 us, (5.00 Hz)
12-22 02:14:53.635 448-479/system_process V/Sensors: HAL:MPL gyro sample rate: 200000
12-22 02:14:53.635 448-479/system_process V/Sensors: HAL:MPL accel sample rate: 200000
12-22 02:14:53.635 448-479/system_process V/Sensors: HAL:MPL compass sample rate: 200000
12-22 02:14:53.635 448-479/system_process V/Sensors: HAL:sysfs:echo 5 > /sys/bus/iio/devices/iio:device0/sampling_frequency (5615741919891)
12-22 02:14:53.635 448-479/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/buffer/enable (5615742205725)
12-22 02:14:53.662 448-982/system_process D/Sensors: set sensor(2) delay 100000000 ns
12-22 02:14:53.662 448-982/system_process D/Sensors: int sensors_poll_context_t::setDelay(int, int64_t)
12-22 02:14:53.662 448-982/system_process V/Sensors: setDelay : 100000000 ns, (10.00 Hz)
12-22 02:14:53.662 448-982/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/power_state (5615768609644)
12-22 02:14:53.662 448-982/system_process V/Sensors: HAL:sysfs:echo 0 > /sys/bus/iio/devices/iio:device0/buffer/enable (5615768856102)
12-22 02:14:53.666 448-982/system_process V/Sensors: HAL:wanted rate for all sensors : 100000000 ns, mpl rate: 100000 us, (10.00 Hz)
12-22 02:14:53.667 448-982/system_process V/Sensors: HAL:MPL gyro sample rate: 100000
12-22 02:14:53.667 448-982/system_process V/Sensors: HAL:MPL accel sample rate: 100000
12-22 02:14:53.667 448-982/system_process V/Sensors: HAL:MPL compass sample rate: 100000
12-22 02:14:53.667 448-982/system_process V/Sensors: HAL:sysfs:echo 10 > /sys/bus/iio/devices/iio:device0/sampling_frequency (5615773438186)
12-22 02:14:53.667 448-982/system_process V/Sensors: HAL:sysfs:echo 1 > /sys/bus/iio/devices/iio:device0/buffer/enable (5615773710895)
12-22 02:14:53.691 261-3697/? D/CameraHal: camera_get_camera_info(1437): camera_get_camera_info(1437): camera_1 facing(0), orientation(180)
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:176x144
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:320x240
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:352x288
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:640x480
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:720x480
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:800x600
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:1280x720
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:1920x1080
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:2112x1568
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: SIZE:2064x1548
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: FORMAT:17
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: FORMAT:842094169
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: T:
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: V=3000
12-22 02:14:53.694 3448-3448/com.siwill.sw_ac_adfe D/DetecterActivity: V=30000
12-22 02:14:53.695 261-3934/? D/CameraHal: isNeedToRestartPreview(144): mPreviewFrame2AppW (176x144)
12-22 02:14:53.695 261-3934/? D/CameraHal: isNeedToRestartPreview(145): mCamPreviewW (640x480)
12-22 02:14:53.695 261-3934/? D/CameraHal: isNeedToRestartPreview(146): video width (176x144)
12-22 02:14:53.701 3448-3448/com.siwill.sw_ac_adfe D/CameraSurfaceView: preview size = 176,144
12-22 02:14:53.701 261-3934/? D/CameraHal: commandThread(1009): commandThread(1009):receive CMD_SET_PREVIEW_WINDOW
12-22 02:14:53.702 261-3934/? D/CameraHal: commandThread(1025): commandThread(1025): CMD_SET_PREVIEW_WINDOW out
12-22 02:14:53.702 261-3934/? D/CameraHal: commandThread(904): commandThread(904):receive CMD_PREVIEW_START
12-22 02:14:53.728 3448-3448/com.siwill.sw_ac_adfe I/Choreographer: Skipped 48 frames! The application may be doing too much work on its main thread.
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/mali_winsys: EGLint new_window_surface(egl_winsys_display*, void*, EGLSurface, EGLConfig, egl_winsys_surface**, egl_color_buffer_format*, EGLBoolean) returns 0x3000
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glesInit() <--- format = 2050
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGetShaderiv called shader = 1 GL_INVALID_ENUM = 1280 GL_INVALID_OPERATION = 1282
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGetShaderiv called compiled = 1, shader = 1
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGetShaderiv called shader = 2 GL_INVALID_ENUM = 1280 GL_INVALID_OPERATION = 1282
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGetShaderiv called compiled = 1, shader = 2
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glAttachShader
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glBindAttribLocation
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glLinkProgram
12-22 02:14:53.731 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGenTextures
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: VBO
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: set mirror is true
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glesInit() --->
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glesInit() <--- format = 2050
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGetShaderiv called shader = 4 GL_INVALID_ENUM = 1280 GL_INVALID_OPERATION = 1282
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGetShaderiv called compiled = 1, shader = 4
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGetShaderiv called shader = 5 GL_INVALID_ENUM = 1280 GL_INVALID_OPERATION = 1282
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glGetShaderiv called compiled = 1, shader = 5
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glLinkProgram
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glesChanged(768, 976) <---
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glesChanged() --->
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: GLChangedAngle(1, 270) <---
12-22 02:14:53.732 3448-3902/com.siwill.sw_ac_adfe D/ATC.: GLChangedAngle() --->
12-22 02:14:53.764 3448-3902/com.siwill.sw_ac_adfe D/mali_winsys: EGLint new_window_surface(egl_winsys_display*, void*, EGLSurface, EGLConfig, egl_winsys_surface**, egl_color_buffer_format*, EGLBoolean) returns 0x3000
12-22 02:14:53.764 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glesChanged(768, 939) <---
12-22 02:14:53.764 3448-3902/com.siwill.sw_ac_adfe D/ATC.: glesChanged() --->
12-22 02:14:53.764 3448-3902/com.siwill.sw_ac_adfe D/ATC.: GLChangedAngle(1, 270) <---
12-22 02:14:53.764 3448-3902/com.siwill.sw_ac_adfe D/ATC.: set mirror is true
12-22 02:14:53.764 3448-3902/com.siwill.sw_ac_adfe D/ATC.: GLChangedAngle() --->
12-22 02:14:53.767 261-3934/? D/CameraHal: stop(1966): m_camDevice->stopPreview success!
12-22 02:14:53.767 261-3934/? D/CameraHal: setupPreview(325): isp out put format is YUV420SP.
12-22 02:14:53.767 261-3934/? D/CameraHal: setupPreview(337): Sensor output: 2112x1568 --(106,7,1900,1554)--> User request: 176x144
12-22 02:14:53.768 261-3930/? E/CameraHal_Marvin: CAM-ENGINE: CamEngineReStartEventCbCamerIcDrv: >>>>>1.000000,1.000000<<<<<<
12-22 02:14:53.771 261-3934/? D/CameraHal: start(1921): m_camDevice->startPreview success
12-22 02:14:53.771 261-3924/? D/CameraHal: displayThread(600): displayThread(600): receive CMD_DISPLAY_START
12-22 02:14:53.771 261-3924/? D/CameraHal: cameraDisplayBufferDestory(403): cameraDisplayBufferDestory(403): mANativeWindow is NULL, destory is ignore
12-22 02:14:53.779 261-3934/? D/CameraHal: commandThread(977): commandThread(977): CMD_PREVIEW_START out
12-22 02:14:53.803 448-553/system_process I/ActivityManager: Displayed com.siwill.sw_ac_adfe/com.arcsoft.sdk_demo.DetecterActivity: +1s166ms
有人知道是什么原因吗?
