RK3288 Android5.1 点LVDS的问题
Hi,因为官网的10寸屏幕没有购买的了,所以从淘宝购买了一块型号为lr10fhd01的屏。使用的是android 5.1,rk3288的板子。
在dts中添加文件lcd-lr10fhd01.dtsi如下:
  • RockChip. LCD_LR10FHD01
backlight {
	compatible = "pwm-backlight";
	pwms = <&pwm1 0 20000>;
	rockchip,pwm_id= <1>;
	brightness-levels = </*255 254 253 252 251 250 249 248 247 246 245 244 243 242 241 240 239 238 237 236 235 234 233 232 231 230 229 228 227 226 225 224 223 222 221 */220 219 218 217 216 215 214 213 212 211 210 209 208 207 206 205 204 203 202 201 200 199 198 197 196 195 194 193 192 191 190 189 188 187 186 185 184 183 182 181 180 179 178 177 176 175 174 173 172 171 170 169 168 167 166 165 164 163 162 161 160 159 158 157 156 155 154 153 152 151 150 149 148 147 146 145 144 143 142 141 140 139 138 137 136 135 134 133 132 131 130 129 128 127 126 125 124 123 122 121 120 119 118 117 116 115 114 113 112 111 110 109 108 107 106 105 104 103 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0>;
	default-brightness-level = <128>;
	enable-gpios = <&gpio8 GPIO_A6 GPIO_ACTIVE_HIGH>;
	native-mode = <&timing0>;
	timing0: timing0 {
		screen-type = <SCREEN_DUAL_LVDS>;
		lvds-format = <LVDS_8BIT_1>;
		out-face    = <OUT_P888>;
		color-mode = <COLOR_RGB>;
		clock-frequency = <148›4›4000000>;
		hactive = <1920>;
		vactive = <1080>;
		hback-porch = <7>;
		hfront-porch = <3>;
		vback-porch = <90>;
		vfront-porch = <50>;
		hsync-len = <1>;
		vsync-len = <20>;
		hsync-active = <0>;
		vsync-active = <0>;
		de-active = <0>;
		pixelclk-active = <0>;
		swap-rb = <0>;
		swap-rg = <0>;
		swap-gb = <0>;
同时我修改了firefly-rk3288.dts
修改之后的部分如下:
&fb {
rockchip,disp-mode = ;
rockchip,uboot-logo-on = <0>;
rockchip,disp-policy = <DISPLAY_POLICY_SDK>;
&disp_timings {
&rk_screen {
display-timings = <&disp_timings>;
/lcdc0 as PRMRY(HDMI),lcdc1 as EXTEND(RK1000)/
&lcdc0 {
status = “okay”;
rockchip,iommu-enabled = <0>;
rockchip,prop = ;
power_ctr: power_ctr {
rockchip,debug = <1>;
&lcdc1 {
status = “okay”;
rockchip,prop = ;
&pwm1 {
status = “okay”;
编译之后刷入kernel和resource,开机,hdmi有输出,lvds背光点亮,屏幕无显示。
串口输出提示
lcdc1 conntect to hdmi
lcdc0 blank mode
adb连接android,ls /sys/class/drm/card0-LVDS-1 会提示找不到文件
万用表测试屏幕3.3v供电正常,两组数据脚电压也正常,请问大佬们是哪里可能存在问题……
o,对了 dts中已经引入了#include “lcd-lr10fhd01.dtsi”
你好! 请问这个问题你是怎么解决的??
你好! 请问这个问题你是怎么解决的??
abcxyztt 发表于 2018-1-12 16:26
没配置好
请问能不能贴出来具体的正确的配置呢?? 我也遇到同样的问题。
楼主问题解决了吗??
同问,怎么解决的?
楼主问题解决了吗?
解决了吗,楼主
备注一下
