按照教程编译Linux内核到Firefly RK3399出现下面错误,大神来帮帮忙
resetting …
DDR Version 1.07 20161103
soft reset
SRX
Channel 0: DDR3, 666MHz
Channel 1: DDR3, 666MHz
256B stride
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1907
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 62812
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 79367
LoaderFlag2: 0xc3524200
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE: BL31: v1.2(debug):b995f80
NOTICE: BL31: Built : 16:53:56, Nov 7 2016
INFO: boot cpu mask: 0
INFO: Vesion: 2016.0.01
INFO: plat_rockchip_pmu_init(1211): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-gf0c33010c6 (Aug 23 2017 - 12:28:34)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from boot image.
no key node
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-03-28#1.05
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find phy node
delay prepare[0] unprepare[0] enable[0] disable[0]
no fuel gauge found
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 4
rk lcdc - 1 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
“Synchronous Abort” handler, esr 0x96000004
ELR: 594480c
LR: 5925b04
x0 : 0000000005717930 x1 : ffffffffffffffff
x2 : 0000000000000670 x3 : 0000000000000000
x4 : 0000000005717930 x5 : 00000000000003e8
x6 : 00015752a0000001 x7 : 0000000000000020
x8 : 0000000005969cb0 x9 : 0000000000000008
x10: 0000000000000000 x11: 00000000000000d0
x12: 000000000000002d x13: 0000000000000005
x14: 0000000000000004 x15: 0000000008d9ee20
x16: 0000000000000118 x17: 0000000000000000
x18: 0000000005702928 x19: 0000000000000019
x20: 0000000000000104 x21: 0000000005715f50
x22: 0000000005715fd0 x23: 0000000005716050
x24: 000000000595b238 x25: 0000000005716018
x26: 0000000005716530 x27: 00000000000002d5
x28: 000000000000056e x29: 0000000005702660
Resetting CPU …
教程是参照http://developer.t-firefly.com/thread-12613-1-1.html
Firefly RK3399开发板入门笔记 四、开发环境搭建及内核编译
soft reset
SRX
256B stride
CPUId = 0x0
ChipType = 10 1907
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
SdmmcInit=0 20
StorageInit ok = 62852
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 79287
INFO: SPSR = 0x3c9
CPU: rk3399
cpu version = 0
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
No pmic detect.
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
‘boot’ does not seem to be a partition nor an address
Unable to boot:boot
try to start recovery
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
‘backup’ does not seem to be a partition nor an address
Unable to boot:backup
try to start rockusb
重新编译了boot,还是有问题,大神能告诉是什么问题吗
我这边新的板子u-boot都启动不了,ddr信息完了后没log了
好东西,感谢楼主
你确定是按照教程来的吗?我的板子是rk3399,按照教程重新编译所有的镜像,都没有问题
