求助:RK3128插SD卡时,启动出现问题
[ 0.779221] cpu_det_gpio up
[ 0.779296] power_hold_gpio up
[ 0.779347] rk818_i2c_probe: rk818_pmic_sleep=0
[ 0.783355] vdd_arm: 712 ↔ 1500 mV at 1100 mV
[ 0.787680] vdd_logic: 712 ↔ 1500 mV at 1100 mV
[ 0.791527] rk818_dcdc3: 1200 mV
[ 0.795872] vccio: 1800 ↔ 3300 mV at 3000 mV
[ 0.799766] rk818_ldo1: 3300 mV
[ 0.803586] rk818_ldo2: 3000 mV
[ 0.807421] rk818_ldo3: 1100 mV
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒)▒+▒▒!▒▒▒f▒H▒%r▒@▒▒Ɓz▒▒▒Y▒▒▒▒▒Y9r /▒▒y ▒!
▒▒▒▒▒G▒,FJ6▒X▒h3▒▒*R▒▒▒▒;▒
▒▒▒▒▒r▒~▒▒▒▒▒'@▒ ▒0▒▒p▒▒O▒H▒▒▒!▒▒Y▒D▒U▒▒▒FM▒L�T▒t▒▒!▒▒ ▒▒▒@▒▒
▒▒@▒▒▒▒▒▒@▒0▒▒▒▒▒▒▒?}▒▒▒▒▒▒ ▒▒▒ ▒(▒▒▒▒▒▒▒▒▒▒p▒▒
▒▒▒▒c▒▒▒▒▒▒#▒▒I▒▒▒▒ ▒6}▒▒▒▒▒▒▒▒▒▒▒▒Q"▒▒▒#▒▒▒▒▒▒▒#H▒▒<}▒▒▒Ȁ▒N▒▒`▒▒
  1. fireprime插sd卡时,kernel启动就会卡在”rk818”这里。无论sd卡是空的,是有文件的,还是有rootfs的。
  2. 不插卡启动正常。
  3. 电源用的5v 2A的适配器。
    不清楚是什么原因,求大神解答
完整的反馈信息:
▒▒▒DDR Version 2.04 20150121
1A1A1C1B 3
DDR3
1C1C1C1C F
mach:2
Boot1 Release Time: 2015-05-25, version: 2.25
ChipType = a 1359
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=e90000
FwPart▒▒▒▒eMF▒;_^r▒▒\r\▒0
FwPartOffset=0 , 0
StorageInit ok = 150510
theL
U-Boot 2014.10-RK3128-10 (Dec 28 2015 - 14:53:17)
CPU: rk3128
CPU’s clock information:
arm pll = 300000000HZ
periph pll = 594000000HZ
ddr pll = 600000000HZ
codec pll = 400000000HZ
Uboot as second level loader
DRAM: Found dram banks:1
128 MiB
rk dma▒▒▒▒▒▒▒▒storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_MODEL:rk312x!
Unknow param: MACHINE_ID:007!
power key: bank-3 pin-23
can’t find dts node for act8846
can’t find dts node for rk808
v01: power_hold GPIO pull up
cpu_det GPIO pull up
pmic:rk818
can’t find dts node for ADC
Enter power_led_init
#Boot ver: 2015-06-12#2.25
empty serial no.
checkKey
vbus = 1
use dc chg rk818_charger_setting iset1:0xf9 chgiset:0xf5 current 1
read logo_on switch from dts [1]
failed to find part:logo
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x62000000 (0x006a5320)
ramdisk @ 0x65bf0000 (0x00299428)
bootrk: do_bootm_linux…
Loading Device Tree to 65600000, end 6561663c … OK
Add bank:0000000060000000, 0000000040000000
[ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (william@william-K42JP) (gcc version 4.6.x-google 20120106
(prerelease) (GCC) ) #2 SMP PREEMPT Fri Feb 23 20:54:36 CST 2018
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128
[ 0.000000] rockchip_uboot_logo_setup: mem: 2000000@9dc00000, offset:0
[ 0.000000] rockchip_uboot_mem_reserve: reserve 2000000@9dc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(800000) align(0)
[ 0.000000] cma: CMA: reserved 8 MiB at 9d400000
[ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608
[ 0.000000] cma: CMA: reserved 16 MiB at 7f000000
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c166b000 s14016 r8192 d14656 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120
[ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0,115200
console=tty0 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4
init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000
(misc),0x00008000@0x00006000(resource),0x00010000@0x0000E000(boot),0x00020000@0x0001E000
(backup),-@0x0003E000(linuxroot) storagemedia=emmc uboot_logo=0x02000000@0x9dc00000
loader.timestamp=2015-12-28_14:53:17
[ 0.000000] rockchip jtag enabled
[ 0.000000] allocated 2097152 bytes of page_cgroup
[ 0.000000] Memory: 1024MB = 1024MB total
[ 0.000000] Memory: 962896k/962896k available, 85680k reserved, 483328K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0ba890c (11907 kB)
[ 0.000000] .init : 0xc0ba9000 - 0xc0c036c0 ( 362 kB)
[ 0.000000] .data : 0xc0c04000 - 0xc0d20438 (1138 kB)
[ 0.000000] .bss : 0xc0d20438 - 0xc0e424fc (1161 kB)
[ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_parent = 25
[ 0.000000] rkclk_init_clks: cnt_rate = 17
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:22
[ 0.000000] target-temp:85
[ 0.000000] FirePrime hardware version: V01
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty0] enabled
[ 0.548195] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00
BogoMIPS (lpj=240000)
[ 0.548257] pid_max: default: 32768 minimum: 301
[ 0.548468] Security Framework initialized
[ 0.548514] SELinux: Initializing.
[ 0.548662] Mount-cache hash table entries: 512
[ 0.549891] Initializing cgroup subsys debug
[ 0.549943] Initializing cgroup subsys memory
[ 0.550011] Initializing cgroup subsys freezer
[ 0.550090] CPU: Testing write buffer coherency: ok
[ 0.550636] /cpus/cpu@0 missing clock-frequency property
[ 0.550690] /cpus/cpu@1 missing clock-frequency property
[ 0.550727] /cpus/cpu@2 missing clock-frequency property
[ 0.550763] /cpus/cpu@3 missing clock-frequency property
[ 0.550851] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.550939] Setting up static identity map for 0xc0854a38 - 0xc0854a90
[ 0.553122] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early
0x169b (version 3.0)
[ 0.624623] CPU1: Booted secondary processor
[ 0.624679] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.644320] CPU2: Booted secondary processor
[ 0.644365] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.664067] CPU3: Booted secondary processor
[ 0.664109] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.664293] Brought up 4 CPUs
[ 0.664460] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.664495] CPU: All CPU(s) started in SVC mode.
[ 0.665909] devtmpfs: initialized
[ 0.675577] pinctrl core: initialized pinctrl subsystem
[ 0.676106] regulator-dummy: no parameters
[ 0.677651] NET: Registered protocol family 16
[ 0.680855] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.681562] ion_snapshot: 0x7e998000 map to 0xe0907000 and copy to 0xc0e1da84 (version 0.1)
[ 0.681820] Registered FIQ tty driver
[ 0.684202] console [ttyFIQ0] enabled
[ 0.684644] Registered fiq debugger ttyFIQ0
[ 0.686219] rockchip_get_bank_data:name=/pinctrl@20008000/gpio0@2007c000
start=0x2007c000,end=0x2007c0ff
[ 0.686396] rockchip_get_bank_data:name=/pinctrl@20008000/gpio1@20080000
start=0x20080000,end=0x200800ff
[ 0.686518] rockchip_get_bank_data:name=/pinctrl@20008000/gpio2@20084000
start=0x20084000,end=0x200840ff
[ 0.686635] rockchip_get_bank_data:name=/pinctrl@20008000/gpio3@20088000
start=0x20088000,end=0x200880ff
[ 0.686760] rockchip_get_bank_data:name=/pinctrl@20008000/gpio15@2008A000
start=0x20086000,end=0x200860ff
[ 0.686867] rockchip_pinctrl_probe:name=rk312x-GPIO,type=5
[ 0.686918] rockchip_pinctrl_probe:name=base start=0x20008000,end=0x200080a7
[ 0.686969] rockchip_pinctrl_probe:name=mux start=0x200080a8,end=0x200080f3
[ 0.687019] rockchip_pinctrl_probe:name=pull start=0x20008118,end=0x20008137
[ 0.687070] rockchip_pinctrl_probe:name=drv start=0x20008100,end=0x20008103
[ 0.689840] rockchip_pinctrl_probe:init ok
[ 0.697886] rk_iommu 1010e300.vop_mmu: (vop) Enter
[ 0.697970] rk_iommu 1010e300.vop_mmu: skip request vop mmu irq
[ 0.698081] rk_iommu 1010e300.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.698143] rk_iommu 1010e300.vop_mmu: (vop) Initialized
[ 0.698441] rk_iommu 10104440.hevc_mmu: (hevc) Enter
[ 0.698608] rk_iommu 10104440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.698671] rk_iommu 10104440.hevc_mmu: (hevc) Initialized
[ 0.698967] rk_iommu 10106800.vpu_mmu: (vpu) Enter
[ 0.699123] rk_iommu 10106800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.699190] rk_iommu 10106800.vpu_mmu: (vpu) Initialized
[ 0.699468] rk_iommu 10108800.iep_mmu: (iep) Enter
[ 0.699617] rk_iommu 10108800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 0.699678] rk_iommu 10108800.iep_mmu: (iep) Initialized
[ 0.701303] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.701367] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.701681] DDR DEBUG: version 1.02 20140828
[ 0.701726] DDR DEBUG: DRAM Type:DDR3
[ 0.701765] DDR DEBUG: 1 CS, ROW=15, Bank=8, COL=10, Total Capability=1024MB
[ 0.701832] DDR DEBUG: init success!!! freq=300MHz
[ 0.755912] bio: create slab at 0
[ 0.757006] Rockchip hdmi driver version 2.0
[ 0.758903] SCSI subsystem initialized
[ 0.759269] usbcore: registered new interface driver usbfs
[ 0.759398] usbcore: registered new interface driver hub
[ 0.759630] usbcore: registered new device driver usb
[ 0.761842] rockchip_i2c 20072000.i2c: i2c-0: Rockchip I2C adapter
[ 0.764177] media: Linux media interface: v0.10
[ 0.764298] Linux video capture interface: v2.00
[ 0.764526] pps_core: LinuxPPS API ver. 1 registered
[ 0.764573] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti
<giometti@linux.it>
[ 0.764652] PTP clock support registered
[ 0.764765] i2c-core: driver [bq24296] using legacy suspend method
[ 0.764810] i2c-core: driver [bq24296] using legacy resume method
[ 0.766226] Rockchip ion module is successfully loaded (v1.1)
[ 0.766529] Advanced Linux Sound Architecture Driver Initialized.
[ 0.767315] Bluetooth: Core ver 2.16
[ 0.767412] NET: Registered protocol family 31
[ 0.767451] Bluetooth: HCI device and connection manager initialized
[ 0.767505] Bluetooth: HCI socket layer initialized
[ 0.767552] Bluetooth: L2CAP socket layer initialized
[ 0.767626] Bluetooth: SCO socket layer initialized
[ 0.768093] cfg80211: Calling CRDA to update world regulatory domain
[ 0.769768] act8931_i2c_probe,line=715
[ 0.770616] The device is not act8931
[ 0.771317] rk818_i2c_probe,line=1286
[ 0.771642] rk818_pre_init,line=1201
rockchipzz 发表于 2018-2-23 22:42
完整的反馈信息:
sdmmc与串口debug印脚是复用的
leung先森 发表于 2018-2-24 09:06
sdmmc与串口debug印脚是复用的
谢谢大神,我去改一下
能否贴出修改的地方么?
请问一下插入SD卡之后去哪里进行调试
