求助:HDMI播放无声音输出,启动过程有爆音,有LOG,求大神帮忙分析
按照《RK音频简介以及常见问题DEBUG方法.pdf》文档的方法调试,发现:
  1. 声卡注册不知道是否成功?
[ 2.403665] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 2.404145] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 2.404155] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: Failed to add ELD: -16
[ 2.405498] rk-hdmi-dp-sound hdmi-dp-sound: multicodec ↔ ff8a0000.i2s mapping ok
[ 2.407540] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: Failed to create Playback debugfs file
[ 2.407916] rt5640 1-001c: rt5640 have no aux_det_adc_value defined
2.查看当前系统的声卡,声卡存在
root@android:/ # cat /proc/asound/cards
0 [ROCKCHIPSPDIF ]: ROCKCHIP_SPDIF - ROCKCHIP,SPDIF
                  ROCKCHIP,SPDIF
1 [rkhdmidpsound ]: rk-hdmi-dp-soun - rk-hdmi-dp-sound
                  rk-hdmi-dp-sound
root@android:/ #
错误如下:
03-0205:52:52.283 257 257 I mediadrmserver: type=1400audit(0.0:13): avc: denied { execmod } forpath=“/system/lib/libffmpeg.so” dev=“mmcblk1p10” ino=1645scontext=u:r:mediadrmserver:s0 tcontext=u:object_r:system_file:s0 tclass=filepermissive=1
03-0205:52:52.309 251 251 D AudioHardwareTiny: ALSA Audio Version:V1.1.0
03-0205:52:52.309 251 251 D AudioHardwareTiny: card[0] =ROCKCHIPSPDIF
03-0205:52:52.309 251 251 D AudioHardwareTiny: card[1] =RKHDMIDPSOUND
03-0205:52:52.309 251 251 D AudioHardwareTiny: card[2] =
03-0205:52:52.309 251 251 D AudioHardwareTiny: PCM_CARD=2,PCM_CARD_SPDIF=0, PCM_CARD_HDMI=1, PCM_BT=3
3:route报错
03-0205:53:02.939 463 557 W KeyguardServiceDelegate:onScreenTurningOn(): no keyguard service!
03-0205:53:03.087 251 334 V alsa_route: route_pcm_open() route 11
03-0205:53:03.087 251 334 V alsa_route: get_route_config() route11
03-0205:53:03.087 251 334 E alsa_route: get_route_config()route_table is NULL!
03-0205:53:03.087 251 334 E alsa_route:route_pcm_open() Can not get config of route
03-0205:53:03.087 251 334 V alsa_route: route_pcm_open exit
03-0205:53:03.087 251 334 E AudioHardwareTiny:pcm_open(PCM_CARD_HDMI) failed: cannot open device ‘/dev/snd/pcmC1D0p’: Deviceor resource busy
03-0205:53:03.089 653 653 W SystemConfig: No directory/system/etc/sysconfig, skipping
03-0205:53:03.099 251 334 D AudioHardwareTiny: 1212121start_output_stream
03-0205:53:03.099 251 334 E AudioHardwareTiny: vicent r 44100 c 2 ps512 pc 3
03-0205:53:03.099 463 750 I ACodec : callingProcessName:system_server
03-0205:53:03.099 251 334 D AudioHardwareTiny: Device : 0x8040a
03-0205:53:03.100 251 334 D AudioHardwareTiny: SampleRate : 44100
03-0205:53:03.100 251 334 D AudioHardwareTiny: Channels : 2
03-0205:53:03.100 251 334 D AudioHardwareTiny: Formate : 0
03-0205:53:03.100 251 334 D AudioHardwareTiny: PreiodSize : 512
03-0205:53:03.100 251 334 E AudioHardwareTiny:start_output_stream() >>>> PCM_CARD_HDMI:1, PCM_CARD:2,
麻烦大神告知一下,是声卡注册的问题还是,route的错误,
03-02 05:53:03.087 251 334 E AudioHardwareTiny: pcm_open(PCM_CARD_HDMI) failed: cannot open device ‘/dev/snd/pcmC1D0p’: Device or resource busy
非常感谢
楼主解决了吗,我也遇到类似问题
楼主解决了吗,我也遇到类似问题
Monster_Mr 发表于 2018-3-5 14:20
楼主解决了吗,我也遇到类似问题
还没解决,没有大神出现
你用的是firefly的开发板,日志显示codec都有异常了
那这个该如何解决?
hal层的通路有问题,把rkhdmidpsound注册为card0,ROCKCHIPSPDIF注册为card1,通路的配置文件用默认的,应该就可以了
pumpkinZhu 发表于 2018-5-23 10:28
hal层的通路有问题,把rkhdmidpsound注册为card0,ROCKCHIPSPDIF注册为card1,通路的配置文件用默认的,应 …
感谢
