RK3328 Android 版本串口无法使用,无 ttyS1 设备节点!!!
最近一个项目要使用 rk3328 接串口外设 ,发现官网的 wifi 有问题,ttySx 节点都没有。
http://www.t-firefly.com/doc/product/info/id/263.html
  1. 接收数据
首先在设备上运行下列命令:
cat /dev/ttyS1复制代码
然后在主机的串口终端输入字符串 “Firefly uart1 test…”,设备端即可见到相同的字符串。
ttyS1设备节点都没有,操作个毛线,也不知道如何打开,请问你们rk3328的 git 代码能不能更新一下,懂 Kernel 应该配置一下,很简单的吧,这么简单的事情都做不好么。
自己尝试改了下 dts,还是没有 ttyS1
diff --git a/arch/arm64/boot/dts/rk3328-roc-cc-port.dtsi b/arch/arm64/boot/dts/rk3328-roc-cc-port.dtsi
index a66214d..10c4af1 100644
— a/arch/arm64/boot/dts/rk3328-roc-cc-port.dtsi
+++ b/arch/arm64/boot/dts/rk3328-roc-cc-port.dtsi
@@ -53,6 +53,60 @@
status = “okay”;
  •    aliases {
  •            serial0 = &uart0;
  •            serial1 = &uart1;
  •            serial2 = &uart_dbg;
  •    uart0: serial@ff110000 {
  •            compatible = "rockchip,serial";
  •            reg = <0x0 0xff110000 0x0 0x100>;
  •            interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
  •            clock-frequency = <24000000>;
  •            clocks = <&clk_uart0>, <&clk_gates16 11>;
  •            clock-names = "sclk_uart", "pclk_uart";
  •            reg-shift = <2>;
  •            reg-io-width = <4>;
  •            dmas = <&pdma 2>, <&pdma 3>;
  •            #dma-cells = <2>;
  •            pinctrl-names = "default";
  •            pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
  •            status = "disabled";
  •    uart1: serial@ff120000 {
  •            reg = <0x0 0xff120000 0x0 0x100>;
  •            interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>;
  •            clocks = <&clk_uart1>, <&clk_gates16 12>;
  •            reg-shift = <2>;
  •            dmas = <&pdma 4>, <&pdma 5>;
  •            #dma-cells = <2>;
  •            pinctrl-0 = <&uart1_xfer &uart1_cts &uart1_rts>;
  •            status = "okey";
  •    uart_dbg: serial@ff130000 {
  •            reg = <0x0 0xff130000 0x0 0x100>;
  •            interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
  •            clocks = <&clk_uart2>, <&clk_gates16 13>;
  •            reg-shift = <2>;
  •            dmas = <&pdma 6>, <&pdma 7>;
  •            #dma-cells = <2>;
  •            pinctrl-0 = <&uart2m1_xfer>;
  • io-domains {
    status = “okay”;
@@ -378,11 +432,20 @@
&uart0 {
  • status = “disabled”;
  • dma-names = “!tx”, “!rx”;
  • pinctrl-0 = <&uart0_xfer &uart0_cts>;
  •   dma-names = "!tx", "!rx";
+&uart1{
  • status = “okey”;
+&uart_dbg{
  • status = “okey”;
diff --git a/arch/arm64/boot/dts/rk3328-roc-cc-port.dtsi b/arc …
改得有问题,不知道是复制错了还是怎样
你应该直接参照uart0改
&uart0 {
最好在a/a/b/d/rk3328-roc-cc.dts上面改,这样可以避免被其他dts覆盖掉。
&uart1 {
        status = "okay";
        pinctrl-0 = <&uart1_xfer &uart1_cts>;
我没有3328,所以如果通信有问题,则要去确认uart1是否有被复用的可能性
希望可以帮到你。
忒感谢了,赶紧去试试!!!!
