RS9113无线网卡驱动编译报错
在编译RS9113 onebox 驱动时报错。
编译平台 VM虚拟机,linux mint 18.3 64bit
目标平台 RK3399 ubuntu 16.04 内核版本4.4.77
驱动程序的Makefile已经设置了交叉编译工具链的路径和内核源码路径:
CROSS_COMPILE := /home/kavi/firefly-rk3399/prebuilts/gcc/linux-x86/aarch64/aarch64-linux-android-4.9/bin/aarch64-linux-android-
CC=$(CROSS_COMPILE)gcc
#DEF_KERNEL_DIR := /lib/modules/$(shell uname -r)/build
DEF_KERNEL_DIR := /home/kavi/firefly-rk3399/A3_Kubot_Firefly_RK3399_linux_kernel
然后编译时会有以下报错:
kavi-virtual-machine host # make
-e Compiling Onebox Mobile Driver...
make EXTRA_CFLAGS="-DWLAN_ENABLE -DONEBOX_DEBUG_ENABLE -DPROGRAMMING_BBP_TA -DPROGRAMMING_SCAN_TA -DRSI_SDIO_MULTI_BLOCK_SUPPORT -DLINUX -Wimplicit -Wstrict-prototypes -DFLASH_BURNING -DRSI_SDIO_MULTI_BLOCK_SUPPORT -DSDIO_COMMANDS -DDYNAMIC_VARIABLES -DRF_8111 -I/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/common_hal/include/linux/ -I/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/common_hal/include/common/ -DINET6 -Dnet80211_s -DBGSCAN_SUPPORT -DPWR_SAVE_SUPPORT -DACM_NO_TSPEC_CNFM -DBYPASS_TX_DATA_PATH -DBYPASS_RX_DATA_PATH -DIEEE80211_AMPDU_AGE -DSECURITY_SUPPORT -DAMPDU_AGGR_SUPPORT -DENABLE_P2P_SUPPORT -DRSI_CCX -DUSE_WORKQUEUES -DCHANNEL_UTILIZATION -DONEBOX_CONFIG_WOWLAN -I/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/net80211/linux/osd_linux/include/ -I/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/net80211/linux/osi_net80211/net80211/ -I/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/net80211/linux/osi_net80211/ -I/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/wlan_hal/include/linux -DUSE_BLUEZ_BT_STACK -I/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/bt/include/linux -I/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/zigbee/include/linux -g -DUSE_USB_INTF" -C /home/kavi/firefly-rk3399/A3_Kubot_Firefly_RK3399_linux_kernel SUBDIRS=/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host modules
make[1]: Entering directory '/home/kavi/firefly-rk3399/A3_Kubot_Firefly_RK3399_linux_kernel'
  CC [M]  /home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/wlan_hal/osi_wlan/devdep/rsi_9113/onebox_wlan_osi_init.o
In file included from include/linux/pagemap.h:10:0,
                 from include/linux/blkdev.h:14,
                 from include/linux/mmc/host.h:19,
                 from /home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/common_hal/include/common/onebox_sdio_intf.h:50,
                 from /home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/wlan_hal/include/linux/wlan_common.h:1008,
                 from /home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/wlan_hal/osi_wlan/devdep/rsi_9113/onebox_wlan_osi_init.c:34:
include/linux/highmem.h: In function 'kmap_to_page':
include/linux/highmem.h:50:1: error: macro "ALIGN" passed 2 arguments, but takes just 1
  return virt_to_page(addr);
In file included from include/linux/mm.h:66:0,
                 from include/linux/scatterlist.h:7,
                 from include/linux/dmaengine.h:24,
                 from include/linux/netdevice.h:38,
                 from /home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/wlan_hal/include/linux/wlan_common.h:34,
./arch/arm64/include/asm/pgtable.h:43:23: error: 'ALIGN' undeclared (first use in this function)
 #define VMEMMAP_SIZE  ALIGN((1UL << (VA_BITS - PAGE_SHIFT)) * sizeof(struct page), PUD_SIZE)
./arch/arm64/include/asm/pgtable.h:46:48: note: in expansion of macro 'VMEMMAP_SIZE'
 #define VMALLOC_END  (PAGE_OFFSET - PUD_SIZE - VMEMMAP_SIZE - SZ_64K)
./arch/arm64/include/asm/pgtable.h:48:25: note: in expansion of macro 'VMALLOC_END'
 #define VMEMMAP_START  (VMALLOC_END + SZ_64K)
./arch/arm64/include/asm/pgtable.h:49:35: note: in expansion of macro 'VMEMMAP_START'
 #define vmemmap   ((struct page *)VMEMMAP_START - \
include/asm-generic/memory_model.h:53:29: note: in expansion of macro 'vmemmap'
 #define __pfn_to_page(pfn) (vmemmap + (pfn))
include/asm-generic/memory_model.h:81:21: note: in expansion of macro '__pfn_to_page'
 #define pfn_to_page __pfn_to_page
./arch/arm64/include/asm/memory.h:198:29: note: in expansion of macro 'pfn_to_page'
 #define virt_to_page(kaddr) pfn_to_page(__pa(kaddr) >> PAGE_SHIFT)
include/linux/highmem.h:50:9: note: in expansion of macro 'virt_to_page'
./arch/arm64/include/asm/pgtable.h:43:23: note: each undeclared identifier is reported only once for each function it appears in
scripts/Makefile.build:258: recipe for target '/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/wlan_hal/osi_wlan/devdep/rsi_9113/onebox_wlan_osi_init.o' failed
make[2]: *** [/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host/wlan/wlan_hal/osi_wlan/devdep/rsi_9113/onebox_wlan_osi_init.o] Error 1
Makefile:1424: recipe for target '_module_/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host' failed
make[1]: *** [_module_/home/kavi/firefly-rk3399/RS9113.NBZ.NL.GENR.LNX.1.6.0/source/host] Error 2
make[1]: Leaving directory '/home/kavi/firefly-rk3399/A3_Kubot_Firefly_RK3399_linux_kernel'
Makefile:382: recipe for target 'compile_driver' failed
make: *** [compile_driver] Error 2
与RS9113原厂沟通,他们的回复是我们要编译linux系统为什么要用android的工具链,他们觉得这个问题是内核和这套工具链不兼容。
我觉得关键点编译器的出错信息上:
./arch/arm64/include/asm/pgtable.h:43:23: error: ‘ALIGN’ undeclared (first use in this function)
include/linux/highmem.h: In function ‘kmap_to_page’:
include/linux/highmem.h:50:1: error: macro “ALIGN” passed 2 arguments, but takes just 1
错误信息是没找到 ALIGN macro, 而 ALIGN macro 在 include/linux/kernel.h 上定义,确实是需要传入两个参数的,而驱动中有没有包含这个头文件呢?
另外可以试试, ubuntu 16.04 本身的 aarch64-linux-gnu-gcc 去编译(sudo apt install gcc-aarch64-linux-gnu) 。
busybee 发表于 2018-3-15 14:29
我觉得关键点编译器的出错信息上:
./arch/arm64/include/asm/pgtable.h:43:23: error: ‘ALIGN’ undeclare …
onebox_wlan_osi_init,c里面已经include kernel.h了
#include <linux/module.h>
#include <linux/kernel.h>
#include "onebox_datatypes.h"
#include "wlan_common.h"
ONEBOX_STATIC int32 onebox_wlan_nongpl_module_init(VOID)
	ONEBOX_DEBUG(ONEBOX_ZONE_INIT,(TEXT("onebox_wlan_nongpl_module_init called and registering the wlan nongpl driver\n")));
	return 0;
ONEBOX_STATIC VOID onebox_wlan_nongpl_module_exit(VOID)
	ONEBOX_DEBUG(ONEBOX_ZONE_INIT,(TEXT("onebox_wlan_nongpl_module_exit called and unregistering the wlan nongpl driver\n")));
	return;
module_init(onebox_wlan_nongpl_module_init);
module_exit(onebox_wlan_nongpl_module_exit);
交叉编译之前我在linux mint 18.3 64bit系统上直接编译并且可以加载运行,但是使用firefly的linux kernel和交叉编译工具链就会报这个错误。
