将FireFly 的Android6.0SDK移植到自己做的板子上上去,板子硬件和FireFly3399硬件差异很小,现在uboot 和 内核都能够起来,但就是内核起到一般就停止了,现在是没有一点思路,问题滞留了很久,希望各位大神帮帮忙,附上部分串口打印信息
[ 0.300945] graphics fb3: rockchip framebuffer registerd:fb3
[ 0.301141] graphics fb4: rockchip framebuffer registerd:fb4
[ 0.301227] rk322x-lcdc vop0: failed to get clk source
[ 0.301241] rk322x-lcdc vop0: failed to get clk source
[ 0.303049] rk322x-lcdc vop0: lcdc0: dclk:148500000>>fps:60
[ 0.303062] rk322x-lcdc vop0: dsp lut table is null
[ 0.303073] rk322x-lcdc vop0: cabc lut table is null
[ 0.325182] alloc_buffer:ion_phy_addr=0x10000000
[ 0.330522] fb0:phy:10000000>>vir:ffffff8009681000>>len:0x1800000
[ 0.336458] rk_iommu ff903f00.vopb-mmu: rockchip_iommu_attach_device: Attach0
[ 0.336493] rk322x-lcdc vop0: lcdc0 probe ok, iommu enabled
[ 0.336760] rk322x-lcdc ff8f0000.vop-rk-fb: vop_dev->regs=0xffffff80093e0000
[ 0.336851] rk322x-lcdc vop1: can’t find power_ctr node for lcdc1
[ 0.336882] rk_fb_trsm_ops_get: unsupported transmitter: 0!
[ 0.337164] graphics fb5: rockchip framebuffer registerd:fb5
[ 0.337533] graphics fb6: rockchip framebuffer registerd:fb6
[ 0.337726] graphics fb7: rockchip framebuffer registerd:fb7
[ 0.337920] graphics fb8: rockchip framebuffer registerd:fb8
[ 0.338108] graphics fb9: rockchip framebuffer registerd:fb9
[ 0.338123] rk322x-lcdc vop1: lcdc1 probe ok, iommu enabled
[ 0.339778] thermal thermal_zone1: power_allocator: sustainable_power will bd
[ 0.339994] NET: Registered protocol family 2
[ 0.340437] TCP established hash table entries: 16384 (order: 5, 131072 byte)
[ 0.340538] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.340658] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.340729] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.340759] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.340896] NET: Registered protocol family 1
[ 0.341353] Trying to unpack rootfs image as initramfs…
[ 0.544864] Freeing initrd memory: 4464K (ffffffc005bf0000 - ffffffc00604c00)
[ 0.545389] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte
[ 0.545476] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte
[ 0.548025] audit: initializing netlink subsys (disabled)
[ 0.548095] audit: type=2000 audit(0.543:1): initialized
[ 0.556582] VFS: Disk quotas dquot_6.6.0
[ 0.556712] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.558126] fuse init (API version 7.23)
[ 0.562765] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[ 0.562794] io scheduler noop registered
[ 0.562957] io scheduler cfq registered (default)
[ 0.564226] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not d
[ 0.568396] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.568426] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.568444] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.570207] pll lock timeout!
[ 1.570227] phy phy-phy@e220.5: phy poweron failed → -22
[ 1.570242] rockchip-pcie f8000000.pcie: fail to power on phy, err -22
[ 1.570301] rockchip-pcie: probe of f8000000.pcie failed with error -22
[ 1.570973] rga2 ff680000.rga: rga ion client create success!
[ 1.571119] rga: Driver loaded successfully ver:3.02
[ 1.571824] hdmi phy_table not exist
[ 1.575679] hdmi_get_prop_dts:No edid-prop-value, 1
[ 1.575699] reset hdmi
[ 1.575837] rockchip-hdmiv2 ff940000.hdmi-rk-fb: rockchip hdmiv2 probe succe.
[ 1.576274] iep: failed to find iep power down clock source.
[ 1.576569] IEP Power ON
[ 1.576632] iep ion client create success!
[ 1.576896] rk_iommu ff670800.iep-mmu: rockchip_iommu_attach_device: Attache0
[ 1.576911] IEP Power OFF
[ 1.576934] IEP Driver loaded succesfully
[ 1.577018] Module initialized.
[ 1.577319] rk-vcodec ff650000.vpu_service: No core reset resource define
[ 1.577368] rk-vcodec ff650000.vpu_service: do not have pd_video
[ 1.577393] rk-vcodec ff650000.vpu_service: probe device
[ 1.577492] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07470e410
[ 1.577527] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.577879] rk-vcodec ff650000.vpu_service: allocator is null
[ 1.578066] rk-vcodec ff650000.vpu_service: init success
[ 1.578289] rk-vcodec ff660000.rkvdec: No core reset resource define
[ 1.578391] rk-vcodec ff660000.rkvdec: do not have pd_video
[ 1.578414] rk-vcodec ff660000.�j#+�{+F+�Kk
[ 1.578515] rk-vcodec ff660
[ 1.578551] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.578726] rk-vcodec ff660000.rkvdec: allocator is null
[ 1.578888] rk-vcodec ff660000.rkvdec: init success
[ 1.580500] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-0
[ 1.580520] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Cha2
[ 1.581841] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-0
[ 1.581859] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Ch6
[ 1.582997] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.584483] console [ttyS0] disabled
[ 1.584527] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud =A
[ 1.585052] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud =A
[ 1.585591] ff370000.serial: ttyS4 at MMIO 0xff370000 (irq = 39, base_baud =A
[ 1.585939] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.588630] mali ff9a0000.gpu: Failed to get regulator
[ 1.588645] mali ff9a0000.gpu: Power control initialization failed
[ 1.588931] Unable to detect cache hierarchy from DT for CPU 0
[ 1.603025] brd: module loaded
[ 1.617649] loop: module loaded
[ 1.618204] zram: Added device: zram0
[ 1.618747] SCSI Media Changer driver v0.25
[ 1.619332] rockchip-pinctrl pinctrl: pin gpio1-8 already requested by ff370i
[ 1.619359] rockchip-pinctrl pinctrl: pin-40 (ff1d0000.spi) status -22
[ 1.619376] rockchip-pinctrl pinctrl: could not request pin 40 (gpio1-8) frol
[ 1.619395] rockchip-spi ff1d0000.spi: Error applying setting, reverse thingk
[ 1.619538] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[ 1.619553] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[ 1.620472] tun: Universal TUN/TAP device driver, 1.6
[ 1.620485] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.621422] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.621440] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.621454] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.621630] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.621643] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.626716] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.626728] Ring mode enabled
[ 1.626737] DMA HW capability register supported
[ 1.626746] Normal descriptors
[ 1.626756] RX Checksum Offload Engine supported (type 2)
[ 1.626766] TX Checksum insertion supported
[ 1.626774] Wake-Up On Lan supported
[ 1.626822] Enable RX Mitigation via HW Watchdog Timer
[ 1.700233] libphy: stmmac: probed
[ 1.700259] eth%d: PHY ID 0000ffff at 0 IRQ POLL (stmmac-0:00) active
[ 1.700274] eth%d: PHY ID 0000ffff at 1 IRQ POLL (stmmac-0:01)
[ 1.700288] eth%d: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02)
[ 1.700300] eth%d: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03)
[ 1.700313] eth%d: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04)
[ 1.700325] eth%d: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05)
[ 1.700336] eth%d: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06)
[ 1.700348] eth%d: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07)
[ 1.700359] eth%d: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08)
[ 1.700371] eth%d: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09)
[ 1.700382] eth%d: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a)
[ 1.700394] eth%d: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b)
[ 1.700405] eth%d: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c)
[ 1.700416] eth%d: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d)
[ 1.700427] eth%d: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e)
[ 1.700439] eth%d: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f)
[ 1.700450] eth%d: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10)
[ 1.700462] eth%d: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11)
[ 1.700474] eth%d: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12)
[ 1.700486] eth%d: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13)
[ 1.700498] eth%d: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14)
[ 1.700509] eth%d: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15)
[ 1.700521] eth%d: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16)
[ 1.700532] eth%d: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17)
[ 1.700544] eth%d: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18)
[ 1.700555] eth%d: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19)
[ 1.700566] eth%d: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a)
[ 1.700578] eth%d: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b)
[ 1.700589] eth%d: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c)
[ 1.700600] eth%d: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d)
[ 1.700611] eth%d: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e)
[ 1.700622] eth%d: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f)
[ 1.701411] PPP generic driver version 2.4.2
[ 1.701583] PPP BSD Compression module registered
[ 1.701598] PPP Deflate Compression module registered
[ 1.701627] PPP MPPE Compression module registered
[ 1.701646] NET: Registered protocol family 24
[ 1.701686] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) .
[ 1.701700] CSLIP: code copyright 1989 Regents of the University of Californ.
[ 1.701723] Rockchip WiFi SYS interface (V1.00) …
[ 1.701810] usbcore: registered new interface driver catc
[ 1.701855] usbcore: registered new interface driver kaweth
[ 1.701873] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet drr
[ 1.701911] usbcore: registered new interface driver pegasus
[ 1.701954] usbcore: registered new interface driver rtl8150
[ 1.701995] usbcore: registered new interface driver r8152
[ 1.702009] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.702070] usbcore: registered new interface driver hso
[ 1.702121] usbcore: registered new interface driver asix
[ 1.702162] usbcore: registered new interface driver ax88179_178a
[ 1.702205] usbcore: registered new interface driver cdc_ether
[ 1.702245] usbcore: registered new interface driver cdc_eem
[ 1.702286] usbcore: registered new interface driver dm9601
[ 1.702339] usbcore: registered new interface driver smsc75xx
[ 1.702390] usbcore: registered new interface driver smsc95xx
[ 1.702431] usbcore: registered new interface driver gl620a
[ 1.702472] usbcore: registered new interface driver net1080
[ 1.702515] usbcore: registered new interface driver plusb
[ 1.702559] usbcore: registered new interface driver rndis_host
[ 1.702603] usbcore: registered new interface driver cdc_subset
[ 1.702645] usbcore: registered new interface driver zaurus
[ 1.702686] usbcore: registered new interface driver MOSCHIP usb-ethernet drr
[ 1.702745] usbcore: registered new interface driver int51x1
[ 1.702785] usbcore: registered new interface driver kalmia
[ 1.702830] usbcore: registered new interface driver ipheth
[ 1.702876] usbcore: registered new interface driver sierra_net
[ 1.702917] usbcore: registered new interface driver cx82310_eth
[ 1.702968] usbcore: registered new interface driver cdc_ncm
[ 1.703009] usbcore: registered new interface driver qmi_wwan
[ 1.703055] usbcore: registered new interface driver cdc_mbim
[ 1.704201] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.707562] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.707584] ehci-pci: EHCI PCI platform driver
[ 1.707640] ehci-platform: EHCI generic platform driver
[ 1.708106] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.708135] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus1
[ 1.708281] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.716879] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.717020] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.717037] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 1.717051] usb usb1: Product: EHCI Host Controller
[ 1.717063] usb usb1: Manufacturer: Linux 4.4.52 ehci_hcd
[ 1.717075] usb usb1: SerialNumber: fe3c0000.usb
[ 1.717539] hub 1-0:1.0: USB hub found
[ 1.717573] hub 1-0:1.0: 1 port detected
[ 1.718064] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.718094] ohci-platform: OHCI generic platform driver
[ 1.718552] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.718578] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus2
[ 1.718705] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.774346] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.774369] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 1.774384] usb usb2: Product: Generic Platform OHCI controller
[ 1.774397] usb usb2: Manufacturer: Linux 4.4.52 ohci_hcd
[ 1.774409] usb usb2: SerialNumber: fe3e0000.usb
[ 1.774835] hub 2-0:1.0: USB hub found
[ 1.774868] hub 2-0:1.0: 1 port detected
[ 1.775625] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.775650] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n3
[ 1.775876] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110
[ 1.775925] xhci-hcd xhci-hcd.0.auto: irq 234, io mem 0xfe900000
[ 1.776047] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.776062] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 1.776076] usb usb3: Product: xHCI Host Controller
[ 1.776088] usb usb3: Manufacturer: Linux 4.4.52 xhci-hcd
[ 1.776099] usb usb3: SerialNumber: xhci-hcd.0.auto
[ 1.776519] hub 3-0:1.0: USB hub found
[ 1.776553] hub 3-0:1.0: 1 port detected
[ 1.776804] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.776824] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus n4
[ 1.776920] usb usb4: We don’t know the algorithms for LPM for this host, di.
[ 1.777014] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.777030] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber1
[ 1.777043] usb usb4: Product: xHCI Host Controller
[ 1.777055] usb usb4: Manufacturer: Linux 4.4.52 xhci-hcd
[ 1.777067] usb usb4: SerialNumber: xhci-hcd.0.auto
[ 1.777478] hub 4-0:1.0: USB hub found
[ 1.777508] hub 4-0:1.0: 1 port detected
[ 1.777852] usbcore: registered new interface driver cdc_acm
[ 1.777864] cdc_acm: USB Abstract Control Model driver for USB modems and ISs
[ 1.777930] usbcore: registered new interface driver usblp
[ 1.777979] usbcore: registered new interface driver cdc_wdm
[ 1.778072] usbcore: registered new interface driver usb-storage
[ 1.778119] usbcore: registered new interface driver ums-alauda
[ 1.778163] usbcore: registered new interface driver ums-cypress
[ 1.778207] usbcore: registered new interface driver ums-datafab
[ 1.778250] usbcore: registered new interface driver ums_eneub6250
[ 1.778294] usbcore: registered new interface driver ums-freecom
[ 1.778338] usbcore: registered new interface driver ums-isd200
[ 1.778380] usbcore: registered new interface driver ums-jumpshot
[ 1.778424] usbcore: registered new interface driver ums-karma
[ 1.778467] usbcore: registered new interface driver ums-onetouch
[ 1.778515] usbcore: registered new interface driver ums-sddr09
[ 1.778559] usbcore: registered new interface driver ums-sddr55
[ 1.778602] usbcore: registered new interface driver ums-usbat
[ 1.778683] usbcore: registered new interface driver usbserial
[ 1.778723] usbcore: registered new interface driver usbserial_generic
[ 1.778755] usbserial: USB Serial support registered for generic
[ 1.778804] usbcore: registered new interface driver option
[ 1.778838] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.778995] usbcore: registered new interface driver trancevibrator
[ 1.779012] usb20_otg: version 3.10a 21-DEC-2012
[ 1.779217] usb20_host: version 3.10a 21-DEC-2012
[ 1.779686] usbcore: registered new interface driver xpad
[ 1.779739] usbcore: registered new interface driver usb_acecad
[ 1.779788] usbcore: registered new interface driver aiptek
[ 1.779838] usbcore: registered new interface driver gtco
[ 1.779886] usbcore: registered new interface driver hanwang
[ 1.779933] usbcore: registered new interface driver kbtab
[ 1.779949] ==gsl_ts_init==
[ 1.779981] ret=0
[ 1.780397] .. rk pwm remotectl v1.1 init
[ 1.780630] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/inpu0
[ 1.781028] sensor_register_slave:mma8452,id=17
[ 1.781046] sensor_register_slave:lis3dh,id=7
[ 1.781061] sensor_register_slave:mma7660,id=18
[ 1.781076] sensor_register_slave:lsm303d,id=22
[ 1.781092] sensor_register_slave:mpu6880_acc,id=24
[ 1.781107] sensor_register_slave:mpu6500_acc,id=25
[ 1.781122] sensor_register_slave:lsm330_acc,id=26
[ 1.781138] sensor_register_slave:akm8975,id=28
[ 1.781152] sensor_register_slave:akm8963,id=29
[ 1.781168] sensor_register_slave:l3g4200d,id=43
[ 1.781183] sensor_register_slave:l3g20d,id=44
[ 1.781199] sensor_register_slave:ewtsa,id=45
[ 1.781213] sensor_register_slave:lsm330_gyro,id=48
[ 1.781228] sensor_register_slave:cm3217,id=50
[ 1.781243] sensor_register_slave:cm3218,id=51
[ 1.781844] i2c /dev entries driver
[ 1.782818] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.782900] fan53555-reg: supplied by vcc5v0_sys
[ 1.784533] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.784584] fan53555-reg: supplied by vcc5v0_sys
[ 1.786372] rk808 0-001b: Pmic Chip id: 0x0
[ 1.789194] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.789247] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.789326] DCDC_REG1: supplied by vcc3v3_sys
[ 1.789970] DCDC_REG2: supplied by vcc3v3_sys
[ 1.790446] DCDC_REG3: supplied by vcc3v3_sys
[ 1.790663] DCDC_REG4: supplied by vcc3v3_sys
[ 1.791022] LDO_REG1: supplied by vcc3v3_sys
[ 1.792036] LDO_REG2: supplied by vcc3v3_sys
[ 1.792927] LDO_REG3: supplied by vcc3v3_sys
[ 1.793737] LDO_REG4: supplied by vcc3v3_sys
[ 1.794620] LDO_REG5: supplied by vcc3v3_sys
[ 1.795519] LDO_REG6: supplied by vcc3v3_sys
[ 1.796403] LDO_REG7: supplied by vcc3v3_sys
[ 1.797293] LDO_REG8: supplied by vcc3v3_sys
[ 1.798189] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.798400] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.801807] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.802314] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800af0
[ 1.802862] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800af0
[ 1.803327] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800af0
[ 1.804117] IR NEC protocol handler initialized
[ 1.804133] IR RC5(x/sz) protocol handler initialized
[ 1.804147] IR RC6 protocol handler initialized
[ 1.804160] IR JVC protocol handler initialized
[ 1.804173] IR Sony protocol handler initialized
[ 1.804187] IR SANYO protocol handler initialized
[ 1.804200] IR Sharp protocol handler initialized
[ 1.804213] IR MCE Keyboard/mouse protocol handler initialized
[ 1.804227] IR XMP protocol handler initialized
[ 1.804328] usbcore: registered new interface driver uvcvideo
[ 1.804339] USB Video Class driver (1.1.1)
[ 1.804356] CamSys driver version: v0.33.9, CamSys head file version: v0.13.0
[ 1.805344] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.805344]
[ 1.805364] E:camsys_soc_init(51): camsys_soc_init exit!
[ 1.805430] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy0 probe su)
[ 1.805430]
[ 1.805456] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy1 probe su)
[ 1.805456]
[ 1.805517] D1:camsys_mipiphy_probe_cb(273): rk_cru_base=0xffffff800af72000
[ 1.805548] D1:camsys_mipiphy_probe_cb(277): rk_grf_base=0xffffff800b280000
[ 1.806141] D1:camsys_platform_probe(1527): ff910000.isp memory:
[ 1.806157] D1:camsys_platform_probe(1543): Register memory (phy: 0xff91000)
[ 1.806173] D1:camsys_platform_probe(1535): I2c memory (phy: 0x5e10000 vir:)
[ 1.806188] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.806200] D1:camsys_platform_probe(1557): Probe ff910000.isp device succes
[ 1.807365] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.807365]
[ 1.807384] E:camsys_soc_init(51): camsys_soc_init exit!
[ 1.807441] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy0 probe su)
[ 1.807441]
[ 1.807467] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy1 probe su)
[ 1.807467]
[ 1.807517] D1:camsys_mipiphy_probe_cb(273): rk_cru_base=0xffffff800af74000
[ 1.807548] D1:camsys_mipiphy_probe_cb(277): rk_grf_base=0xffffff800b2c0000
[ 1.808128] D1:camsys_platform_probe(1527): ff920000.isp memory:
[ 1.808144] D1:camsys_platform_probe(1543): Register memory (phy: 0xff92000)
[ 1.808160] D1:camsys_platform_probe(1535): I2c memory (phy: 0x5e12000 vir:)
[ 1.808175] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.808187] D1:camsys_platform_probe(1557): Probe ff920000.isp device succes
[ 1.808506] __power_supply_register: Expected proper parent device for ‘test’
[ 1.808637] __power_supply_register: Expected proper parent device for ‘test’
[ 1.808879] thermal thermal_zone2: power_allocator: sustainable_power will bd
[ 1.808977] power_supply_register: Expected proper parent device for ‘test’
[ 1.810165] rockchip_cpu_avs: cluster0 leakage=20 adjust_volt=0
[ 1.810225] rockchip_cpu_avs: cluster1 leakage=34 adjust_volt=0
[ 1.811320] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, te7
[ 1.811864] device-mapper: uevent: version 1.0.3
[ 1.812145] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-m
[ 1.812281] Bluetooth: HCI UART driver ver 2.3
[ 1.812294] Bluetooth: HCI UART protocol H4 registered
[ 1.812305] Bluetooth: HCI UART protocol LL registered
[ 1.816808] sdhci: Secure Digital Host Controller Interface driver
[ 1.816827] sdhci: Copyright(c) Pierre Ossman
[ 1.816842] Synopsys Designware Multimedia Card Interface Driver
[ 1.818183] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mod.
[ 1.818266] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.818288] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.818339] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bio
[ 1.818377] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was.
[ 1.818424] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.818437] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.819185] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mod.
[ 1.819237] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.819256] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.819298] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bio
[ 1.819321] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was.
[ 1.819419] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.819643] vcc_sd: voltage operation not allowed
[ 1.830377] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,)
[ 1.844685] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.844955] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.846644] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.846658] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.875656] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using A
[ 1.877661] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.881273] usbcore: registered new interface driver usbhid
[ 1.881297] usbhid: USB HID core driver
[ 1.881461] inv_mpu_iio: inv_mpu_init:745
[ 1.882443] ashmem: initialized
[ 1.884410] ff100000.saradc supply vref not found, using dummy regulator
[ 1.886754] rknandbase v1.1 2016-01-08
[ 1.887687] usbcore: registered new interface driver snd-usb-audio
[ 1.894479] u32 classifier
[ 1.894516] Actions configured
[ 1.894583] Netfilter messages via NETLINK v0.30.
[ 1.894671] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.895165] ctnetlink v0.93: registering with nfnetlink.
[ 1.896225] xt_time: kernel timezone is -0000
[ 1.897088] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.897307] arp_tables: (C) 2002 David S. Miller
[ 1.897857] Initializing XFRM netlink socket
[ 1.898462] NET: Registered protocol family 10
[ 1.899767] mip6: Mobile IPv6
[ 1.899819] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.901486] sit: IPv6 over IPv4 tunneling driver
[ 1.902142] NET: Registered protocol family 17
[ 1.902185] NET: Registered protocol family 15
[ 1.902241] bridge: automatic filtering via arp/ip/ip6tables has been deprec.
[ 1.903661] Bridge firewalling registered
[ 1.903693] Ebtables v2.0 registered
[ 1.903925] Bluetooth: RFCOMM TTY layer initialized
[ 1.903948] Bluetooth: RFCOMM socket layer initialized
[ 1.903978] Bluetooth: RFCOMM ver 1.11
[ 1.903998] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.904007] Bluetooth: BNEP filters: protocol multicast
[ 1.904021] Bluetooth: BNEP socket layer initialized
[ 1.904040] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.904053] Bluetooth: HIDP socket layer initialized
[ 1.904088] l2tp_core: L2TP core driver, V2.0
[ 1.904107] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.904121] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.904378] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.904433] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.904443] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.904454] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by g.
[ 1.904504] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_w.
[ 1.904515] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.904526] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.904578] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.904842] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts.
[ 1.904877] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset.
[ 1.904902] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake.
[ 1.904928] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake.
[ 1.905254] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.905302] [BT_RFKILL]: ** disable irq
[ 1.905416] [BT_RFKILL]: bt_default device registered.
[ 1.905607] sensor_register_slave:mpu6880_gyro,id=47
[ 1.906040] Registered cp15_barrier emulation handler
[ 1.906146] Registered setend emulation handler
[ 1.907096] registered taskstats version 1
[ 1.910337] Freeing logo memory: 16384K (ffffffc07dc00000 - ffffffc07ec00000)
[ 1.910368] pvtm list NULL
[ 1.915737] mmc1: MAN_BKOPS_EN bit is not set
[ 1.918289] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 1.918969] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devf.
[ 1.919628] mali ff9a0000.gpu: Probed as mali0
[ 1.920655] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.921957] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mod.
[ 1.922158] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.922181] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.922219] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bio
[ 1.922245] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was.
[ 1.922293] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.922306] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.922672] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 1.929458] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.930004] mmcblk1: mmc1:0001 8GME4R 7.28 GiB
[ 1.930399] mmcblk1boot0: mmc1:0001 8GME4R partition 1 4.00 MiB
[ 1.931557] mmcblk1boot1: mmc1:0001 8GME4R partition 2 4.00 MiB
[ 1.932353] mmcblk1rpmb: mmc1:0001 8GME4R partition 3 512 KiB
[ 1.932763] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.932778] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.932790] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 1.932802] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 1.932814] resource: 0x001000000 – 0x002000000 (16 MB)
[ 1.932826] kernel: 0x002000000 – 0x003400000 (20 MB)
[ 1.932837] boot: 0x003400000 – 0x005400000 (32 MB)
[ 1.932848] recovery: 0x005400000 – 0x007400000 (32 MB)
[ 1.932859] backup: 0x007400000 – 0x00e400000 (112 MB)
[ 1.932871] cache: 0x00e400000 – 0x016400000 (128 MB)
[ 1.932882] system: 0x016400000 – 0x056400000 (1024 MB)
[ 1.932894] metadata: 0x056400000 – 0x057400000 (16 MB)
[ 1.932905] baseparamer: 0x057400000 – 0x057800000 (4 MB)
[ 1.932917] userdata: 0x057800000 – 0x1d1c00000 (6052 MB)
[ 1.932964] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.933682] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,)
[ 1.946918] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 1.948778] asoc-simple-card hdmi-sound: dw-hdmi-hifi ↔ ff8a0000.i2s mappik
[ 1.950606] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mappink
[ 1.952976] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.955028]
[ 1.955047] =======================================================
[ 1.955059] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 1.955070] =======================================================
[ 1.955084] dhd_module_init: in
[ 1.955091] ======== bcm_wlan_set_plat_data ========
[ 1.955097] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 1.955104] host_oob_irq: 67
[ 1.955107] host_oob_irq_flags=0x4
[ 1.955109] dhd_wifi_platform_load: Enter
[ 1.955130] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD.
[ 1.955137] Power-up adapter ‘DHD generic adapter’
[ 1.955152] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.955163] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.955173] RTL871X: module init start
[ 1.955183] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 1.955197] wifi_platform_set_power = 1
[ 1.955217] ======== PULL WL_REG_ON HIGH! ========
[ 1.955228] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 1.955240] [WLAN_RFKILL]: wifi turn on power. -1
[ 1.955307] usbcore: registered new interface driver rtl8188eu
[ 1.955325] RTL871X: module init ret=0
[ 1.955345] otg_wakelock_init: No USB transceiver found
[ 1.955422] sensor_init: Probe name sensors
[ 1.955437] sensor-dev.c v1.4 add angle calculation support between two gsen1
[ 1.956149] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:43)
u�
[ 1.991658] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.993253] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.994842] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.997853] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.056454] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 5000000)
