ROC-RK3328-CC运行官方提供的Ubuntu
ROC-RK3328-CC运行官方提供的Ubuntu(ROC-RK3328-CC_Ubuntu16.04_Arch64_20180324)断电重启失败,有人遇到吗
SSH连接复制粘贴指令 终端直接卡死
在串口调试时,输入reboot,启动不起来,显示如下:
Unmounting /boot…
Unmounting /run/user/1000…
[ OK ] Unmounted /boot.
[ OK ] Unmounted /run/user/1000.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped File System Check on /dev/mmcblk0p4.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Removed slice system-systemd\x2dfsck.slice.
[ OK ] Reached target Shutdown.
[ 2996.611167] reboot: Restarting system
INFO: PSCI Power Domain Map:
INFO: Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO: Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO: Domain Node : Level 0, parent_node 0, State ON (0x0)
INFO: CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO: CPU Node : MPID 0x1, parent_node 1, State ON (0x0)
INFO: CPU Node : MPID 0x2, parent_node 1, State ON (0x0)
INFO: CPU Node : MPID 0x3, parent_node 1, State ON (0x0)
