刷miniroot后,系统不断重启
在RK3288 先刷了Firefly-RK3288_Ubuntu14.04_201708151701.img镜像, 然后根据wiki:
刷了0930版本的miniroot固件,http://www.t-firefly.com/downloa … x-boot-miniroot.img
结果看到系统不断重启,会是什么问题呢?
DDR Version 1.00 20160530
SRX
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
U-Boot 2014.10-RK3288-10 (May 27 2017 - 16:08:14)
CPU: rk3288
cpu version = 0
CPU's clock information:
    arm pll = 600000000HZ
    periph pll = 297000000HZ
    ddr pll = 200000000HZ
    codec pll = 384000000HZ
Board:  Rockchip platform Board
DRAM:  Found dram banks: 1
128 MiB                                                             +-----------------------------+
GIC CPU mask = 0x00000001                                           |                             |
SdmmcInit = 0 400                                                   |  Cannot open /dev/ttyUSB0!  |
SdmmcInit = 2 0                                                     |                             |
storage init OK!                                                    +-----------------------------+
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can't find dts node for pwm1
#Boot ver: 2017-05-27#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Hit any key to stop autoboot:  0
load fdt from resouce.
Secure Boot state: 0
kernel   @ 0x02000000 (0x0060b2a0)
ramdisk  @ 0x05bf0000 (0x00199964)
bootrk: do_bootm_linux...
   Loading Device Tree to 05600000, end 0561c522 ... OK
Starting kernel ...
