Firefly-RK3288 编译最新源码,烧录无法正常开机
1.遵循官网推荐方式下载更新源码commit fc02ede46ab9375b38ac66a152ac02963ad8d48a
Author: cjp <service@t-firefly.com>
Date: Tue Feb 27 17:35:37 2018 +0800
Android->device:gps default false
按照官网推荐方式编译
./FFTools/make.sh -d firefly-rk3288 -j8 -l rk3288_box-userdebug ./FFTools/mkupdate/mkupdate.sh -l rk3288_box-userdebug
生成img文件烧录至Firefly-RK3288主板上,开不了机,一直停留在Firefly界面不动
2.随后下载烧录官网中的固件Firefly-RK3288_Android5.1_201803081517.img,现象一样一直停留在Firefly界面
3.尝试下载烧录U盘里双系统固件Firefly-RK3288_DualBoot_201611211031.img,能正常开机。
现将不能开机的log信息贴出,无论是烧录官网Firefly-RK3288_Android5.1_201803081517.img还是烧录最新源码编译出来的img,log信息都是一样的。
DDR Version 1.00 20160530
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-10 (Nov 20 2017 - 17:19:35)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-11-20#2.30
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
Secure Boot state: 0
kernel @ 0x02000000 (0x006a77b0)
ramdisk @ 0x05bf0000 (0x002ad18c)
bootrk: do_bootm_linux…
Loading Device Tree to 05600000, end 0561c4d8 … OK
Add bank:0000000000000000, 00000000fe000000
[ 0.000000] Linux version 3.10.0 (firefly@tchip-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #160 SMP PREEMPT Thu Mar 8 15:09:53 CST 2018
[ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0xfbc00000, offset:0x00000000
[ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0xfbc00000 for uboot logo
[ 0.000000] ion heap(cma): base(0) size(1000000) align(0)
[ 0.000000] cma: CMA: reserved 16 MiB at fac00000
[ 0.000000] ion_reserve: cma reserved base fac00000 size 16777216
[ 0.000000] cma: CMA: reserved 16 MiB at 1f000000
[ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c2ee5000 s13376 r8192 d15296 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1039360
[ 0.000000] Kernel command line: vmalloc=496M console=ttyS2 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00300000@0x00092000(system),0x00008000@0x00392000(metadata),0x00002000@0x0039A000(baseparamer),-@0x003BC000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xfbc00000 loader.timestamp=2017-11-20_17:19:35
[ 0.000000] allocated 8323072 bytes of page_cgroup
[ 0.000000] Memory: 4064MB = 4064MB total
[ 0.000000] Memory: 4036416k/4036416k available, 125120k reserved, 3588096K highmem
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0bb4b2c (11955 kB)
[ 0.000000] .init : 0xc0bb5000 - 0xc0c0e440 ( 358 kB)
[ 0.000000] .data : 0xc0c10000 - 0xc0da2d40 (1612 kB)
[ 0.000000] .bss : 0xc0da2d40 - 0xc0ec3bbc (1156 kB)
[ 0.000000] rk_clk_tree_init start!
[ 0.000000] rkclk: _rkclk_add_provider: fail to get ehci1phy_12m_div
[ 0.000000] rkclk: rkclk_cache_parents: ehci1phy_12m_div clk_get error
[ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[ 0.000000] rkclk_init_clks: cnt_rate = 29
[ 0.000000] rk3288 set GPLL BW 20 for HDMI!
[ 0.000000] process version: 0
[ 0.000000] channel:0, lkg:12
[ 0.000000] target-temp:80
[ 0.000000] channel:2, lkg:0
[ 0.000000] channel:1, lkg:7
[ 1.004202] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 1.004217] pid_max: default: 32768 minimum: 301
[ 1.004333] Security Framework initialized
[ 1.004349] SELinux: Initializing.
[ 1.004422] Mount-cache hash table entries: 512
[ 1.005066] Initializing cgroup subsys debug
[ 1.005081] Initializing cgroup subsys memory
[ 1.005107] Initializing cgroup subsys freezer
[ 1.005137] CPU: Testing write buffer coherency: ok
[ 1.005455] /cpus/cpu@0 missing clock-frequency property
[ 1.005468] /cpus/cpu@1 missing clock-frequency property
[ 1.005478] /cpus/cpu@2 missing clock-frequency property
[ 1.005487] /cpus/cpu@3 missing clock-frequency property
[ 1.005536] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[ 1.005584] Setting up static identity map for 0xc085d580 - 0xc085d5d8
[ 1.008680] last_log: 0x1e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x184a (version 3.1)
[ 1.082320] CPU1: Booted secondary processor
[ 1.082352] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[ 1.102003] CPU2: Booted secondary processor
[ 1.102026] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[ 1.121707] CPU3: Booted secondary processor
[ 1.121730] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[ 1.121831] Brought up 4 CPUs
[ 1.121860] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 1.121868] CPU: All CPU(s) started in SVC mode.
[ 1.122599] devtmpfs: initialized
[ 1.126998] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 1.128094] pinctrl core: initialized pinctrl subsystem
[ 1.128338] regulator-dummy: no parameters
[ 1.142576] NET: Registered protocol family 16
[ 1.144428] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 1.144796] ion_snapshot: 0x1ea98000 map to 0xe0907000 and copy to 0xc0e9ee4c (version 0.1)
[ 1.145035] Registered FIQ tty driver
[ 1.145437] fiq-debugger is disabled in device tree
[ 1.146175] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff
[ 1.146197] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f
[ 1.146214] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f
[ 1.146230] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b
[ 1.146326] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff
[ 1.146391] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff
[ 1.146453] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff
[ 1.146514] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff
[ 1.146577] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff
[ 1.146639] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff
[ 1.146701] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff
[ 1.146761] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff
[ 1.146831] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff
[ 1.146895] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3
[ 1.146909] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f
[ 1.146920] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf
[ 1.146931] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f
[ 1.147555] rockchip_interrupts_register:bank_num=7
[ 1.149496] of_get_gpio_init_config:gpio[0] = 256, value = 0
[ 1.149517] of_get_gpio_init_config:gpio[1] = 136, value = 0
[ 1.149570] rockchip_pinctrl_probe:init ok
[ 1.156687] rk_iommu ff900800.iep_mmu: (iep) Enter
[ 1.156775] rk_iommu ff900800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.156789] rk_iommu ff900800.iep_mmu: (iep) Initialized
[ 1.156958] rk_iommu ff950800.vip_mmu: (vip) Enter
[ 1.157033] rk_iommu ff950800.vip_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.157045] rk_iommu ff950800.vip_mmu: (vip) Initialized
[ 1.157207] rk_iommu ff930300.vopb_mmu: (vopb) Enter
[ 1.157282] rk_iommu ff930300.vopb_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.157294] rk_iommu ff930300.vopb_mmu: (vopb) Initialized
[ 1.157455] rk_iommu ff940300.vopl_mmu: (vopl) Enter
[ 1.157536] rk_iommu ff940300.vopl_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.157548] rk_iommu ff940300.vopl_mmu: (vopl) Initialized
[ 1.157718] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter
[ 1.157791] rk_iommu ff9c0440.hevc_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.157803] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized
[ 1.157971] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter
[ 1.158049] rk_iommu ff9a0800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.158061] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized
[ 1.158233] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter
[ 1.158317] rk_iommu ff914000.isp_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[ 1.158329] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized
[ 1.160124] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 1.160138] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 1.160721] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[ 1.160743] DDR DEBUG: version 1.00 20150126
[ 1.160774] DDR DEBUG: Channel a:
[ 1.160782] DDR DEBUG: DDR3 Device
[ 1.160796] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Total Capability=2048MB
[ 1.160804] DDR DEBUG: Channel b:
[ 1.160812] DDR DEBUG: DDR3 Device
[ 1.160824] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=2 Total Capability=2048MB
[ 1.160833] DDR DEBUG: addr=0xdac000
[ 1.160843] DDR DEBUG: stride=13, size=256, halfcap=80000000
[ 1.160851] DDR DEBUG: socAddr[0]=0xdac000, socAddr[1]=0xdac100
[ 1.160860] DDR DEBUG: chAddr[0]=0xdac000, chAddr[1]=0xdac000
[ 1.160871] DDR DEBUG: dtar[0]=0x401b5000, dtar[1]=0x401b5000
[ 1.160925] DDR DEBUG: init success!!! freq=200MHz
[ 1.160933] DDR DEBUG: Channel a:
[ 1.160945] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.160957] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.160970] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.160982] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.160993] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 1.161002] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 1.161011] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 1.161018] DDR DEBUG: Channel b:
[ 1.161030] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.161042] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.161054] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.161066] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180
[ 1.161077] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0
[ 1.161086] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19
[ 1.161094] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2
[ 1.185349] bio: create slab at 0
[ 1.185876] Rockchip hdmi driver version 2.0
[ 1.185876] .
[ 1.187079] SCSI subsystem initialized
[ 1.187236] usbcore: registered new interface driver usbfs
[ 1.187281] usbcore: registered new interface driver hub
[ 1.187369] usbcore: registered new device driver usb
[ 1.192055] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter
[ 1.192530] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter
[ 1.192978] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter
[ 1.193227] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter
[ 1.194196] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter
[ 1.194311] media: Linux media interface: v0.10
[ 1.194356] Linux video capture interface: v2.00
[ 1.194412] pps_core: LinuxPPS API ver. 1 registered
[ 1.194422] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.194441] PTP clock support registered
[ 1.194500] i2c-core: driver [bq24296] using legacy suspend method
[ 1.194510] i2c-core: driver [bq24296] using legacy resume method
[ 1.194839] RK29 Watchdog Timer, (c) 2011 Rockchip Electronics
[ 1.195529] ion_drm_heap_create: 0@0
[ 1.195656] Rockchip ion module is successfully loaded (v1.1)
[ 1.195819] Advanced Linux Sound Architecture Driver Initialized.
[ 1.196249] Bluetooth: Core ver 2.16
[ 1.196286] NET: Registered protocol family 31
[ 1.196295] Bluetooth: HCI device and connection manager initialized
[ 1.196311] Bluetooth: HCI socket layer initialized
[ 1.196324] Bluetooth: L2CAP socket layer initialized
[ 1.196350] Bluetooth: SCO socket layer initialized
[ 1.196583] cfg80211: Calling CRDA to update world regulatory domain
[ 1.197285] act8846_i2c_probe,line=898
[ 1.198289] act8846_parse_dt,line=746
[ 1.198771] act8846_i2c_probe: act8846_pmic_hold=1
[ 1.198793] act8846_i2c_probe: act8846_pmic_sleep=1
[ 1.198808] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1
[ 1.198823] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1
[ 1.200927] act_dcdc1: 1200 mV
[ 1.203885] vccio: 3300 mV
[ 1.205739] vdd_logic: 700 ↔ 1500 mV at 1100 mV
[ 1.208694] act_dcdc4: 2000 mV
[ 1.209932] vccio_sd: 1800 ↔ 3300 mV at 3300 mV
[ 1.212231] act_ldo2: 1050 mV
[ 1.214525] act_ldo3: 2800 mV
[ 1.216830] act_ldo4: 3300 mV
[ 1.219120] act_ldo5: 3300 mV
[ 1.221521] act_ldo6: 1100 mV
[ 1.223826] vcc_18: 1800 mV
[ 1.226126] act_ldo8: 1850 mV
[ 1.230891] vdd_arm: 712 ↔ 1500 mV at 1000 mV
[ 1.235584] vdd_gpu: 712 ↔ 1500 mV at 1000 mV
[ 1.236358] rk808_i2c_probe,line=1355
[ 1.237690] The device is not rk808 -11
[ 1.237772] rk808: probe of 0-001b failed with error -11
[ 1.237852] i2c-core: driver [rk818] using legacy suspend method
[ 1.237862] i2c-core: driver [rk818] using legacy resume method
[ 1.239812] Switching to clocksource arch_sys_counter
[ 1.263540] rga: Module initialized.
[ 1.264264] rga2 ff920000.rga: rga ion client create success!
[ 1.264441] rga: Driver loaded succesfully
[ 1.264645] fb disp policy is box
[ 1.264687] rk-fb rockchip-fb: rk fb ion client create success!
[ 1.264698] rk-fb rockchip-fb: rockchip framebuffer driver probe
[ 1.265033] rk-screen rk_screen.8: rockchip screen probe success
[ 1.265294] rk32-lvds rk32-lvds: rk32 lvds driver probe success
[ 1.265667] rk32-edp ff970000.edp: screen is not edp!
[ 1.265687] rk32-edp: probe of ff970000.edp failed with error -22
[ 1.266166] rk3288-lcdc lcdc0: can’t find power_ctr node for lcdc0
[ 1.266389] graphics fb0: rockchip framebuffer registerd:fb0
[ 1.266695] graphics fb1: rockchip framebuffer registerd:fb1
[ 1.266873] graphics fb2: rockchip framebuffer registerd:fb2
[ 1.267034] graphics fb3: rockchip framebuffer registerd:fb3
[ 1.267761] rk3288-lcdc lcdc0: lcdc0: dclk:297000000>>fps:120
[ 1.267776] rk3288-lcdc lcdc0: wakeup from standby!
[ 1.298414] alloc_buffer:ion_phy_addr=0x10000000
[ 1.311339] fb0:phy:10000000>>vir:e0991000>>len:0x1800000
[ 1.318786] rk_iommu ff930300.vopb_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x1eab6000
[ 1.318835] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled
[ 1.319049] rk3288-lcdc lcdc1: can’t find power_ctr node for lcdc1
[ 1.319062] rk_fb_trsm_ops_get:un supported transmitter:0!
[ 1.319335] graphics fb4: rockchip framebuffer registerd:fb4
[ 1.319670] graphics fb5: rockchip framebuffer registerd:fb5
[ 1.319843] graphics fb6: rockchip framebuffer registerd:fb6
[ 1.320016] graphics fb7: rockchip framebuffer registerd:fb7
[ 1.320820] unknow screen type: 0
[ 1.320837] vop ver:a050a01,unsupport output color:1
[ 1.320901] rk3288-lcdc lcdc1: lcdc1: dclk:148500000>>fps:868
[ 1.320914] rk3288-lcdc lcdc1: wakeup from standby!
[ 1.324707] fb4:phy:10000000>>vir:e0991000>>len:0x1800000
[ 1.324722] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu enabled
[ 1.325600] rockchip_set_mux:warning ignore bank num 15
[ 1.325736] rockchip_set_mux:warning ignore bank num 15
[ 1.325852] rockchip_set_mux:warning ignore bank num 15
[ 1.325981] rockchip_set_mux:warning ignore bank num 15
[ 1.326117] rockchip_set_mux:warning ignore bank num 15
[ 1.326238] rockchip_set_mux:warning ignore bank num 15
[ 1.326813] rockchip_set_mux:warning ignore bank num 15
[ 1.326976] rockchip_set_mux:warning ignore bank num 15
[ 1.327528] rockchip_set_mux:warning ignore bank num 15
[ 1.327674] rockchip_set_mux:warning ignore bank num 15
[ 1.328209] rockchip_set_mux:warning ignore bank num 15
[ 1.328378] rockchip_set_mux:warning ignore bank num 15
[ 1.328943] rockchip_set_mux:warning ignore bank num 15
[ 1.329094] rockchip_set_mux:warning ignore bank num 15
[ 1.330647] NET: Registered protocol family 2
[ 1.331304] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.331378] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.331451] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.331507] TCP: reno registered
[ 1.331521] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.331544] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.331770] NET: Registered protocol family 1
[ 1.332382] Unpacking initramfs…
[ 1.466001] Freeing initrd memory: 2740K (c5bf0000 - c5e9d000)
[ 1.466871] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available
[ 1.467438] vcodec_service: probe device ff9a0000.vpu_service
[ 1.467646] vcodec_service: No reset resource define
[ 1.467846] vcodec_service: ff9a0000.vpu_service: power on
[ 1.467933] vcodec_service: probe device ff9a0000.vpu_service
[ 1.467949] vcodec_service: checking hw id 4831
[ 1.468925] vcodec_service: ff9a0000.vpu_service: power off…
[ 1.468968] vcodec_service: done
[ 1.468977] vcodec_service: init success
[ 1.469045] vcodec_service: probe device ff9c0000.hevc_service
[ 1.469394] vcodec_service: ff9c0000.hevc_service: power on
[ 1.469458] vcodec_service: probe device ff9c0000.hevc_service
[ 1.469473] vcodec_service: checking hw id 6867
[ 1.470056] vcodec_service: ff9c0000.hevc_service: power off…
[ 1.470098] vcodec_service: done
[ 1.470107] vcodec_service: init success
[ 1.470241] rknandbase v1.0 2014-03-31
[ 1.470378] rknand: probe of ff400000.nandc failed with error -1
[ 1.470491] rknand_driver:ret = 0
[ 1.472358] audit: initializing netlink socket (disabled)
[ 1.472403] type=2000 audit(0.470:1): initialized
[ 1.473392] bounce pool size: 64 pages
[ 1.478135] fuse init (API version 7.22)
[ 1.478527] msgmni has been set to 912
[ 1.480366] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.480381] io scheduler noop registered
[ 1.480391] io scheduler deadline registered
[ 1.480481] io scheduler cfq registered (default)
[ 1.481716] rockchip-hdmiv2 ff980000.hdmi: rockchip hdmiv2 probe sucess.
[ 1.482463] IEP Driver loaded succesfully
[ 1.482551] Module initialized.
[ 1.483401] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.483418] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[ 1.484787] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208
[ 1.484804] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.485108] pwm-voltage-regulator pwm_regulator.22: unable to request PWM, trying legacy API
[ 1.485123] pwm-voltage-regulator pwm_regulator.22: unable to request legacy PWM
[ 1.485132] pwm_regulator_probe:error
[ 1.485153] platform pwm_regulator.22: Driver pwm-voltage-regulator requests probe deferral
[ 1.485367] rk_serial.c v1.8 2014-03-04
[ 1.485603] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0
[ 1.485790] serial ff180000.serial: membase e0972000
[ 1.486015] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 88) is a rk29_serial.1
[ 1.486189] serial ff190000.serial: membase e097e000
[ 1.486332] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 89) is a rk29_serial.2
[ 1.487976] console [ttyS2] enabled
[ 1.488170] serial ff690000.serial: membase fed60000
[ 1.488347] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 90) is a rk29_serial.3
[ 1.488512] serial ff1b0000.serial: membase e41be000
[ 1.491431] loop: module loaded
[ 1.491820] zram: Created 1 device(s) …
[ 1.491902] i2c-core: driver [mpu6050B1] using legacy suspend method
[ 1.491915] i2c-core: driver [mpu6050B1] using legacy resume method
[ 1.491934] mpu_init: Probe name mpu6050B1
[ 1.492080] ak8963_mod_init: Probe name ak8963_mod
[ 1.492834] SCSI Media Changer driver v0.25
[ 1.493080] dws->regs: e41e2000
[ 1.494301] rockchip_spi_probe:num_cs=2,bus_num=0,irq=76,freq=45692308 ok
[ 1.494595] tun: Universal TUN/TAP device driver, 1.6
[ 1.494608] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.494743] vmac_init.
[ 1.495313] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[ 1.495329] stmmac_probe_config_dt: clock input/output? (input).
[ 1.495342] stmmac_probe_config_dt: TX delay(0x1d).
[ 1.495355] stmmac_probe_config_dt: RX delay(0x16).
[ 1.495404] stmmac_probe_config_dt: is rockchip,rk3288-gmac
[ 1.495414] stmmc_pltfr_init:
[ 1.495423] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[ 1.495447] gmac_phy_reset: ERROR: Request pin stmmc_pltfr_init failed.
[ 1.495458] stmmc_pltfr_init: init for RGMII
[ 1.495469] tx delay=0x1d
[ 1.495469] rx delay=0x16
[ 1.495486] tx delay=0x1d
[ 1.495486] rx delay=0x16
[ 1.495983] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.495995] Normal descriptors
[ 1.496004] Ring mode enabled
[ 1.496015] DMA HW capability register supported
[ 1.496028] RX Checksum Offload Engine supported (type 2)
[ 1.496038] TX Checksum insertion supported
[ 1.496048] Wake-Up On Lan supported
[ 1.496090] Enable RX Mitigation via HW Watchdog Timer
[ 1.496519] PPP generic driver version 2.4.2
[ 1.496671] PPP BSD Compression module registered
[ 1.496684] PPP Deflate Compression module registered
[ 1.496708] PPP MPPE Compression module registered
[ 1.496721] NET: Registered protocol family 24
[ 1.496764] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.496777] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.496791] Rockchip WiFi SYS interface (V1.00) …
[ 1.496831] esp_mem_init enter date Oct 9 2017 16:20:34
[ 1.496842] esp_mem_init VERSION [V2.5]
[ 1.496880] esp_mem_init complete
[ 1.496964] usbcore: registered new interface driver catc
[ 1.497004] usbcore: registered new interface driver kaweth
[ 1.497018] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.497057] usbcore: registered new interface driver pegasus
[ 1.497095] usbcore: registered new interface driver rtl8150
[ 1.497134] usbcore: registered new interface driver r8152
[ 1.497145] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.497215] usbcore: registered new interface driver hso
[ 1.497265] usbcore: registered new interface driver asix
[ 1.497304] usbcore: registered new interface driver ax88179_178a
[ 1.497343] usbcore: registered new interface driver cdc_ether
[ 1.497381] usbcore: registered new interface driver cdc_eem
[ 1.497418] usbcore: registered new interface driver dm9601
[ 1.497455] usbcore: registered new interface driver dm9620
[ 1.497509] usbcore: registered new interface driver smsc75xx
[ 1.497557] usbcore: registered new interface driver smsc95xx
[ 1.497597] usbcore: registered new interface driver gl620a
[ 1.497635] usbcore: registered new interface driver net1080
[ 1.497674] usbcore: registered new interface driver plusb
[ 1.497713] usbcore: registered new interface driver rndis_host
[ 1.497750] usbcore: registered new interface driver cdc_subset
[ 1.497793] usbcore: registered new interface driver zaurus
[ 1.497835] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.497895] usbcore: registered new interface driver int51x1
[ 1.497935] usbcore: registered new interface driver kalmia
[ 1.497973] usbcore: registered new interface driver ipheth
[ 1.498015] usbcore: registered new interface driver sierra_net
[ 1.498055] usbcore: registered new interface driver cx82310_eth
[ 1.498109] usbcore: registered new interface driver cdc_ncm
[ 1.498150] usbcore: registered new interface driver qmi_wwan
[ 1.498193] usbcore: registered new interface driver cdc_mbim
[ 1.498206] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.500662] EHCI: ehci_rk_probe e4240000 e4240010
[ 1.500679] rockchip_ehci_host ff500000.usb: EHCI Host Controller
[ 1.500708] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1
[ 1.501045] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000
[ 1.515409] rockchip_ehci_host ff500000.usb: USB 2.0 started, EHCI 1.00
[ 1.515506] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.515523] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.515539] usb usb1: Product: EHCI Host Controller
[ 1.515552] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd
[ 1.515565] usb usb1: SerialNumber: ff500000.usb
[ 1.516035] hub 1-0:1.0: USB hub found
[ 1.516060] hub 1-0:1.0: 1 port detected
[ 1.516230] EHCI: ehci_rk_probe ok
[ 1.516339] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.516604] ohci-rockchip ff520000.usb: RK OHCI Host Controller
[ 1.516633] ohci-rockchip ff520000.usb: new USB bus registered, assigned bus number 2
[ 1.516677] ohci-rockchip ff520000.usb: irq 73, io mem 0xff520000
[ 1.578437] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.578456] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.578471] usb usb2: Product: RK OHCI Host Controller
[ 1.578485] usb usb2: Manufacturer: Linux 3.10.0 ohci_hcd
[ 1.578498] usb usb2: SerialNumber: ff520000.usb
[ 1.578925] hub 2-0:1.0: USB hub found
[ 1.578950] hub 2-0:1.0: 1 port detected
[ 1.579283] usbcore: registered new interface driver cdc_acm
[ 1.579296] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.579354] usbcore: registered new interface driver usblp
[ 1.579399] usbcore: registered new interface driver cdc_wdm
[ 1.579476] usbcore: registered new interface driver usb-storage
[ 1.579518] usbcore: registered new interface driver ums-alauda
[ 1.579558] usbcore: registered new interface driver ums-cypress
[ 1.579598] usbcore: registered new interface driver ums-datafab
[ 1.579637] usbcore: registered new interface driver ums_eneub6250
[ 1.579677] usbcore: registered new interface driver ums-freecom
[ 1.579717] usbcore: registered new interface driver ums-isd200
[ 1.579756] usbcore: registered new interface driver ums-jumpshot
[ 1.579801] usbcore: registered new interface driver ums-karma
[ 1.579851] usbcore: registered new interface driver ums-onetouch
[ 1.579910] usbcore: registered new interface driver ums-sddr09
[ 1.579953] usbcore: registered new interface driver ums-sddr55
[ 1.579993] usbcore: registered new interface driver ums-usbat
[ 1.580094] usbcore: registered new interface driver usbserial
[ 1.580139] usbcore: registered new interface driver usbserial_generic
[ 1.580174] usbserial: USB Serial support registered for generic
[ 1.580217] usbcore: registered new interface driver ch341
[ 1.580253] usbserial: USB Serial support registered for ch341-uart
[ 1.580297] usbcore: registered new interface driver cp210x
[ 1.580328] usbserial: USB Serial support registered for cp210x
[ 1.580377] usbcore: registered new interface driver option
[ 1.580409] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.580500] usbcore: registered new interface driver pl2303
[ 1.580533] usbserial: USB Serial support registered for pl2303
[ 1.580583] usbcore: registered new interface driver trancevibrator
[ 1.580596] usb20_otg: version 3.10a 21-DEC-2012
[ 1.581040] e4300040
[ 1.581054] Core Release: 3.10a
[ 1.581066] Setting default values for core params
[ 1.581214] Using Buffer DMA mode
[ 1.581227] Periodic Transfer Interrupt Enhancement - disabled
[ 1.581238] Multiprocessor Interrupt Enhancement - disabled
[ 1.581250] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.581261] ^^^^^^^^^^^^^^^^^Device Mode
[ 1.581275] Dedicated Tx FIFOs mode
[ 1.581295] pcd_init otg_dev = de024f80
[ 1.581623] usb20_otg ff580000.usb: DWC OTG Controller
[ 1.581653] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 3
[ 1.581686] usb20_otg ff580000.usb: irq 55, io mem 0x00000000
[ 1.581748] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.581765] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.581779] usb usb3: Product: DWC OTG Controller
[ 1.581791] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.581805] usb usb3: SerialNumber: ff580000.usb
[ 1.582255] hub 3-0:1.0: USB hub found
[ 1.582278] hub 3-0:1.0: 1 port detected
[ 1.582590] usb20_host: version 3.10a 21-DEC-2012
[ 1.585090] e4380040
[ 1.585103] Core Release: 3.10a
[ 1.585115] Setting default values for core params
[ 1.585230] Using Buffer DMA mode
[ 1.585242] Periodic Transfer Interrupt Enhancement - disabled
[ 1.585252] Multiprocessor Interrupt Enhancement - disabled
[ 1.585264] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.585274] ^^^^^^^^^^^^^^^^^^Host Mode
[ 1.585301] usb20_host ff540000.usb: DWC OTG Controller
[ 1.585327] usb20_host ff540000.usb: new USB bus registered, assigned bus number 4
[ 1.585356] usb20_host ff540000.usb: irq 57, io mem 0x00000000
[ 1.585450] Init: Power Port (0)
[ 1.585505] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.585522] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.585536] usb usb4: Product: DWC OTG Controller
[ 1.585550] usb usb4: Manufacturer: Linux 3.10.0 dwc_otg_hcd
[ 1.585563] usb usb4: SerialNumber: ff540000.usb
[ 1.585956] hub 4-0:1.0: USB hub found
[ 1.585982] hub 4-0:1.0: 1 port detected
[ 1.586702] usbcore: registered new interface driver xpad
[ 1.586764] usbcore: registered new interface driver usb_acecad
[ 1.586812] usbcore: registered new interface driver aiptek
[ 1.586858] usbcore: registered new interface driver gtco
[ 1.586905] usbcore: registered new interface driver hanwang
[ 1.586954] usbcore: registered new interface driver kbtab
[ 1.587012] usbcore: registered new interface driver wacom
[ 1.587138] ==gsl_ts_init==
[ 1.587183] ret=0
[ 1.587449] sensor_register_slave:mma8452,id=17
[ 1.587464] sensor_register_slave:gs_mc3230,id=23
[ 1.587474] gsensor_init
[ 1.587485] sensor_register_slave:mpu6880_acc,id=24
[ 1.587496] sensor_register_slave:mpu6500_acc,id=25
[ 1.587508] sensor_register_slave:cm3217,id=48
[ 1.587519] sensor_register_slave:cm3218,id=49
[ 1.587747] .. rk pwm remotectl v1.1 init
[ 1.587992] input: ff680000.pwm as /devices/ff680000.pwm/input/input0
[ 1.590500] rtc_hym8563 0-0051: clock/calendar information is no longer guaranteed
[ 1.593506] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[ 1.594138] i2c /dev entries driver
[ 1.594842] IR NEC protocol handler initialized
[ 1.594855] IR RC5(x) protocol handler initialized
[ 1.594867] IR RC6 protocol handler initialized
[ 1.594877] IR JVC protocol handler initialized
[ 1.594886] IR Sony protocol handler initialized
[ 1.594897] IR RC5 (streamzap) protocol handler initialized
[ 1.594907] IR SANYO protocol handler initialized
[ 1.594917] IR MCE Keyboard/mouse protocol handler initialized
[ 1.595085] usbcore: registered new interface driver uvcvideo
[ 1.595097] USB Video Class driver (1.1.1)
[ 1.595110] CamSys driver version: v0.32.0, CamSys head file version: v0.11.0
[ 1.596551] D1:camsys_platform_probe(1300): 1-gpios-cifpower: gpio=236
[ 1.596576] D1:camsys_platform_probe(1303): gpios-cifpower: gpio_request
[ 1.596597] D1:camsys_platform_probe(1305): 1-gpios-cifpower: gpio_request=0
[ 1.596619] D1:camsys_platform_probe(1314): gpios-cifpower: 236 high
[ 1.596659] D1:camsys_mipiphy_probe_cb(115): compatible is rockchip,rk3288
[ 1.596659]
[ 1.596732] D1:camsys_mipiphy_probe_cb(186): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.596906] D1:camsys_mipiphy_probe_cb(183): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xe41f8000 size: 0x4000)
[ 1.597545] D1:camsys_platform_probe(1446): ff910000.isp memory:
[ 1.597563] D1:camsys_platform_probe(1456): Register memory (phy: 0xff910000 vir: 0xe4220000 size: 0x10000)
[ 1.597586] D1:camsys_platform_probe(1451): I2c memory (phy: 0x1df07000 vir: 0xddf07000 size: 0x1000)
[ 1.597617] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.597630] D1:camsys_platform_probe(1471): Probe ff910000.isp device success
[ 1.598045] not find test_power_init dev node
[ 1.598102] i2c-core: driver [bq27320] using legacy suspend method
[ 1.598115] i2c-core: driver [bq27320] using legacy resume method
[ 1.598449] rockchip_temp_probe,line=364
[ 1.653154] tsadc ff280000.tsadc: initialized
[ 1.653566] device-mapper: uevent: version 1.0.3
[ 1.653819] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[ 1.654105] Bluetooth: HCI UART driver ver 2.2
[ 1.654121] Bluetooth: HCI H4 protocol initialized
[ 1.654133] Bluetooth: HCILL protocol initialized
[ 1.654145] rtk_btusb: Realtek Bluetooth USB driver module init, version 2.21
[ 1.654157] rtk_btusb: Register usb char device interface for BT driver
[ 1.654347] usbcore: registered new interface driver rtk_btusb
[ 1.654978] DVFS WARNING: clk_enable_dvfs: clk(aclk_vio1) freq table all value are smaller than default(594000), use default, just enable dvfs
[ 1.659094] cpufreq version 1.0, suspend freq 1200 MHz
[ 1.659315] cpuidle: using governor ladder
[ 1.659328] cpuidle: using governor menu
[ 1.659366] Synopsys Designware Multimedia Card Interface Driver
[ 1.659377] MHSC version = Ver 2.00 2015-06-10
[ 1.659677] dw cru_regsbase addr 0x1d8.
[ 1.659690] dw cru_reset_offset val 3.
[ 1.659706] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a
[ 1.659749] dwmmc_rockchip ff0f0000.rksdmmc: failed to get hpclk_mmc
[ 1.660070] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller.
[ 1.660233] dw_mci_init_slot: fmin=400000, fmax=100000000 [mmc0]
[ 1.660397] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.672861] 1358..dw_mci_set_ios: no card. [mmc0]
[ 1.692559] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[ 1.692575] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo
[ 1.692586] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized
[ 1.692883] dw cru_regsbase addr 0x1d8.
[ 1.692896] dw cru_reset_offset val 0.
[ 1.692912] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a
[ 1.692950] dwmmc_rockchip ff0c0000.rksdmmc: failed to get hpclk_mmc
[ 1.693742] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller.
[ 1.693904] dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1]
[ 1.694587] dwmmc_rockchip ff0c0000.rksdmmc: mmc1: No udbg pinctrl found!
[ 1.694663] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.712208] 1358..dw_mci_set_ios: no card. [mmc1]
[ 1.724649] mmc0: BKOPS_EN bit is not set
[ 1.726521] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0]
[ 1.728808] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0)
[ 1.728832] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0]
[ 1.728854] [mmc0] tuning regsbase addr 0x218.
[ 1.729545] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[ 1.729556] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.729575] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 1.729601] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.729627] [mmc0] Data transmission error !!! MINTSTS: [0x00000088]
[ 1.729636] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.729664] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:-84, data.error:-115
[ 1.729688] [mmc0] Data transmission error !!! MINTSTS: [0x00002000]
[ 1.729697] [mmc0] host was already tuning, Don’t need to retry tune again ignore 0.
[ 1.729716] dwmmc_rockchip ff0f0000.rksdmmc: data FIFO error (status=00002000)
[ 1.729737] dwmmc_rockchip ff0f0000.rksdmmc: Tuning error: cmd.error:0, data.error:-5
[ 1.729813] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 0-225 (21 len)
[ 1.729825] dwmmc_rockchip ff0f0000.rksdmmc: Good phase range 270-282 (2 len)
[ 1.729836] dwmmc_rockchip ff0f0000.rksdmmc: Best phase range 0-225 (21 len)
[ 1.729846] dwmmc_rockchip ff0f0000.rksdmmc: Successfully tuned phase to 113
[ 1.729891] mmc0: new HS200 MMC card at address 0001
[ 1.730163] mmcblk0: mmc0:0001 BJNB4R 29.1 GiB
[ 1.730272] mmcblk0rpmb: mmc0:0001 BJNB4R partition 3 4.00 MiB
[ 1.730612] parameter: 0x000000000 – 0x000400000 (4 MB)
[ 1.730624] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 1.730633] misc: 0x000800000 – 0x000c00000 (4 MB)
[ 1.730643] resource: 0x000c00000 – 0x001c00000 (16 MB)
[ 1.730652] kernel: 0x001c00000 – 0x002c00000 (16 MB)
[ 1.730661] boot: 0x002c00000 – 0x004c00000 (32 MB)
[ 1.730670] recovery: 0x004c00000 – 0x006c00000 (32 MB)
[ 1.730678] backup: 0x006c00000 – 0x00a000000 (52 MB)
[ 1.730687] cache: 0x00a000000 – 0x012000000 (128 MB)
[ 1.730695] kpanic: 0x012000000 – 0x012400000 (4 MB)
[ 1.730703] system: 0x012400000 – 0x072400000 (1536 MB)
[ 1.730712] metadata: 0x072400000 – 0x073400000 (16 MB)
[ 1.730720] baseparamer: 0x073400000 – 0x073800000 (4 MB)
[ 1.730729] userdata: 0x077800000 – 0x747800000 (27904 MB)
[ 1.730754] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14[ 1.731954] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo
[ 1.731970] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized
[ 1.732293] dw cru_regsbase addr 0x1d8.
[ 1.732303] dw cru_reset_offset val 1.
[ 1.732313] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a
[ 1.732363] dwmmc_rockchip ff0d0000.rksdmmc: failed to get hpclk_mmc
[ 1.732597] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller.
[ 1.732726] dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2]
[ 1.732982] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.751557] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.771248] 1358..dw_mci_set_ios: no card. [mmc2]
[ 1.771285] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo
[ 1.771297] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized
[ 1.771587] leds-gpio leds.29: pins are not configured from the driver
[ 1.771799] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.773239] usbcore: registered new interface driver usbhid
[ 1.773250] usbhid: USB HID core driver
[ 1.773367] ashmem: initialized
[ 1.773485] logger: created 256K log ‘log_main’
[ 1.773587] logger: created 256K log ‘log_events’
[ 1.773679] logger: created 256K log ‘log_radio’
[ 1.773771] logger: created 256K log ‘log_system’
[ 1.774911] input: rk29-keypad as /devices/ff100000.adc/key.32/input/input1
[ 1.775746] rockchip-pinctrl ff770000.pinctrl: pin gpio6-8 already requested by ff890000.rockchip-i2s; cannot claim for 2-0010
[ 1.775763] rockchip-pinctrl ff770000.pinctrl: pin-200 (2-0010) status -22
[ 1.775775] rockchip-pinctrl ff770000.pinctrl: could not request pin 200 on device rockchip-pinctrl
[ 1.775786] ES8323 2-0010: Error applying setting, reverse things back
[ 1.775839] jp es8323_line_det_gpio:-1
[ 1.776089] es8323 probe i2c recv ok
[ 1.777045] rockchip-spdif ff880000.rockchip-spdif: spdif ready.
[ 1.777663] es8323_probe
[ 2.411202] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → NULL → Left Line Mux
[ 2.411217] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → NULL → Left Line Mux
[ 2.411227] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → NULL → Left Line Mux
[ 2.411235] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → NULL → Left Line Mux
[ 2.411245] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → NULL → Left Line Mux
[ 2.411253] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → NULL → Left Line Mux
[ 2.411263] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → NULL → Right Line Mux
[ 2.411270] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → NULL → Right Line Mux
[ 2.411279] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → NULL → Right Line Mux
[ 2.411287] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → NULL → Right Line Mux
[ 2.411295] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → NULL → Right Line Mux
[ 2.411303] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → NULL → Right Line Mux
[ 2.411312] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left PGA Mux
[ 2.411319] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left PGA Mux
[ 2.411328] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left PGA Mux
[ 2.411336] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left PGA Mux
[ 2.411345] ES8323 2-0010: ASoC: no dapm match for Differential Mux → LAMP → Left PGA Mux
[ 2.411352] ES8323 2-0010: ASoC: Failed to add route Differential Mux → LAMP → Left PGA Mux
[ 2.411361] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right PGA Mux
[ 2.411369] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right PGA Mux
[ 2.411378] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right PGA Mux
[ 2.411385] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right PGA Mux
[ 2.411394] ES8323 2-0010: ASoC: no dapm match for Differential Mux → RAMP → Right PGA Mux
[ 2.411401] ES8323 2-0010: ASoC: Failed to add route Differential Mux → RAMP → Right PGA Mux
[ 2.411411] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Differential Mux
[ 2.411419] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Differential Mux
[ 2.411428] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Differential Mux
[ 2.411436] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Differential Mux
[ 2.411445] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Differential Mux
[ 2.411452] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Differential Mux
[ 2.411461] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Differential Mux
[ 2.411469] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Differential Mux
[ 2.411489] ES8323 2-0010: ASoC: no dapm match for LINPUT1 → LAMP → Left Line Mux
[ 2.411496] ES8323 2-0010: ASoC: Failed to add route LINPUT1 → LAMP → Left Line Mux
[ 2.411505] ES8323 2-0010: ASoC: no dapm match for LINPUT2 → LAMP → Left Line Mux
[ 2.411513] ES8323 2-0010: ASoC: Failed to add route LINPUT2 → LAMP → Left Line Mux
[ 2.411522] ES8323 2-0010: ASoC: no dapm match for Left PGA Mux → LAMP → Left Line Mux
[ 2.411529] ES8323 2-0010: ASoC: Failed to add route Left PGA Mux → LAMP → Left Line Mux
[ 2.411542] ES8323 2-0010: ASoC: no dapm match for RINPUT1 → RAMP → Right Line Mux
[ 2.411558] ES8323 2-0010: ASoC: Failed to add route RINPUT1 → RAMP → Right Line Mux
[ 2.411568] ES8323 2-0010: ASoC: no dapm match for RINPUT2 → RAMP → Right Line Mux
[ 2.411575] ES8323 2-0010: ASoC: Failed to add route RINPUT2 → RAMP → Right Line Mux
[ 2.411584] ES8323 2-0010: ASoC: no dapm match for Right PGA Mux → RAMP → Right Line Mux
[ 2.411591] ES8323 2-0010: ASoC: Failed to add route Right PGA Mux → RAMP → Right Line Mux
[ 2.411735] ES8323 2-0010: ASoC: mux Right Line Mux has no paths
[ 2.411747] ES8323 2-0010: ASoC: mux Left Line Mux has no paths
[ 2.411757] ES8323 2-0010: ASoC: mux Right PGA Mux has no paths
[ 2.411767] ES8323 2-0010: ASoC: mux Left PGA Mux has no paths
[ 2.411787] ES8323 2-0010: ASoC: mux Differential Mux has no paths
[ 2.418088] rockchip-es8323 rockchip-es8323.27: ES8323 HiFi ↔ ff890000.rockchip-i2s mapping ok
[ 2.418461] input: RK_ES8323 Headphone Jack as /devices/rockchip-es8323.27/sound/card0/input2
[ 2.418889] u32 classifier
[ 2.418897] Actions configured
[ 2.418908] Netfilter messages via NETLINK v0.30.
[ 2.418962] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 2.419241] ctnetlink v0.93: registering with nfnetlink.
[ 2.419305] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.419313] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.419545] xt_time: kernel timezone is -0000
[ 2.419715] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.419832] arp_tables: (C) 2002 David S. Miller
[ 2.419866] TCP: cubic registered
[ 2.419872] Initializing XFRM netlink socket
[ 2.420043] NET: Registered protocol family 10
[ 2.420494] mip6: Mobile IPv6
[ 2.420519] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.420626] sit: IPv6 over IPv4 tunneling driver
[ 2.420965] NET: Registered protocol family 17
[ 2.420989] NET: Registered protocol family 15
[ 2.421036] Bridge firewalling registered
[ 2.421047] Ebtables v2.0 registered
[ 2.421217] Bluetooth: RFCOMM TTY layer initialized
[ 2.421240] Bluetooth: RFCOMM socket layer initialized
[ 2.421246] Bluetooth: RFCOMM ver 1.11
[ 2.421253] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.421259] Bluetooth: BNEP filters: protocol multicast
[ 2.421268] Bluetooth: BNEP socket layer initialized
[ 2.421275] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.421287] Bluetooth: HIDP socket layer initialized
[ 2.421312] l2tp_core: L2TP core driver, V2.0
[ 2.421324] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 2.421330] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.421538] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.421547] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 2.421555] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = bcmwifi
[ 2.421563] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.421571] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[ 2.421579] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.421599] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0.
[ 2.421618] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0.
[ 2.421626] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.421651] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
[ 2.421658] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.421700] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.421816] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147.
[ 2.421831] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155.
[ 2.421844] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157.
[ 2.421856] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154.
[ 2.421867] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159.
[ 2.421915] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.422005] [BT_RFKILL]: ** disable irq
[ 2.422070] [BT_RFKILL]: ap6335 device registered.
[ 2.422759] rk3288_init_suspend
[ 2.422771] rk3288_suspend_init enter
[ 2.422970] rk3288_suspend_init: pm_ctrbits =200007
[ 2.422999] gpio_get_dts_info suspend:4
[ 2.423005] gpio_get_dts_info resume:4
[ 2.423011] rockchip,pmic-suspend_gpios:14007a10 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.423035] rockchip,pmic-resume_gpios:2007a11 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
[ 2.423159] clks_gating_suspend_init:clkgt info ok
[ 2.423244] Registering SWP/SWPB emulation handler
[ 2.423256] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0xfbc00000
[ 2.425757] ddrfreq: verion 1.2 20140526
[ 2.425769] ddrfreq: normal 528MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 528MHz
[ 2.425777] ddrfreq: auto-freq=0
[ 2.425782] ddrfreq: auto-freq-table[0] 240MHz
[ 2.425788] ddrfreq: auto-freq-table[1] 324MHz
[ 2.425794] ddrfreq: auto-freq-table[2] 456MHz
[ 2.425799] ddrfreq: auto-freq-table[3] 528MHz
[ 2.434756] act_ldo3: operation not allowed
[ 2.434764] vga_edid_probe: turn on ldo3 done.
[ 2.435019] act_ldo4: operation not allowed
[ 2.435025] vga_edid_probe: turn on ldo done.
[ 2.435285] act_ldo2: operation not allowed
[ 2.435292] vga_edid_probe: turn on ldo2 done.
[ 2.435537] act_ldo8: operation not allowed
[ 2.435543] vga_edid_probe: turn on ldo done.
[ 2.460670] vga-ddc: read and parse vga edid success.
[ 2.460678] vga-ddc: max mode 1440x900@59[pixclock-106507 KHZ]
[ 2.460693] vga-ddc: max mode 1440x900@59[pixclock-106507 KHZ]
[ 2.460699] vga-ddc: best mode 1440x900@59[pixclock-106507 KHZ]
[ 2.460705] vga_edid_probe: success. 10
[ 2.460818] firefly_vga_get_enable 180, 0
[ 2.460825] firefly_vga_get_status 186
[ 2.460830] firefly_vga_set_enable 159 enable:1
[ 2.460849] firefly_vga_enable 130 start
[ 2.460856] firefly_switch_fb 55
[ 2.460864] switch:en=1,lcdc_id=0,screen type=1,cur type=1
[ 2.460886] regulator-dummy: disabling
[ 2.460909] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60
[ 2.460946] VGA ENABLE
[ 2.461148] =======================================================
[ 2.461155] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.461161] =======================================================
[ 2.461167] WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[ 2.461215] dhd_module_init: in
[ 2.461221] ======== bcm_wlan_set_plat_data ========
[ 2.461228] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.461247] host_oob_irq: 196
[ 2.461252] host_oob_irq_flags=4
[ 2.461257] dhd_wifi_platform_load: Enter
[ 2.461271] pcd_pullup, is_on 0
[ 2.461274] Power-up adapter ‘DHD generic adapter’
[ 2.461291] wifi_platform_set_power = 1
[ 2.461296] ======== PULL WL_REG_ON HIGH! ========
[ 2.461302] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.461308] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[ 2.461310] file system registered
[ 2.461318] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[ 2.461832] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 2.461840] android_usb gadget: Number of LUNs=2
[ 2.461847] lun0: LUN: removable file: (no medium)
[ 2.461853] lun1: LUN: removable file: (no medium)
[ 2.461995] android_usb gadget: android_usb ready
[ 2.462072] sensor_init: Probe name sensors
[ 2.462088] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.462612] rtc_hym8563 0-0051: setting system clock to 2011-01-01 12:00:01 UTC (1293883201)
[ 2.468648] rockchip-spdif-card rockchip-spdif-card.25: rk-hdmi-spdif-hifi ↔ ff880000.rockchip-spdif mapping ok
log信息停止,Firefly画面定格一直不动。
您好,您的问题解决了吗,我也遇到了和您一样的问题,可以分享下经验吗,谢谢您了
你解决了吗?
Asia003 发表于 2020-2-28 16:59
你解决了吗?
你解决了吗?
