Firefly-RK3399 7.85寸mipi屏公版固件烧录后屏无显示
在Firefly-RK3399上烧录官方Firefly-RK3399 7.85寸mipi屏公版固件,屏幕无任何显示,串口打印消息中看到有如下提示:
#Boot ver: 2017-12-11#1.06
empty serial no.
reboot normal.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
failed to find phy node
rockchip_dsi_panel_parse_cmds: dcs_cmd=5 len=8, cmd_cnt=2
no fuel gauge found
Using display timing dts
Detailed mode clock 80000 kHz, flags[a]
H: 0768 0918 0938 1068
V: 1024 1160 1200 1330
bus_format: 1009
rk lcdc - 0 dclk set: dclk = 80000000HZ, pll select = 1, div = 1
rockchip_phy_power_on: failed to find phy power on funcs
failed to wait for phy clk lane stop state
failed to display kernel logo
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x011f7ea0)
ramdisk @ 0x05bf0000 (0x006eea00)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 000000000561557c … OK
Add bank:0000000009400000, 00000000eec00000
[ 1.840865] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.841115] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.841241] mmcblk1rpmb: mmc1:0001 BJNB4R partition 3 4.00 MiB
[ 1.841256] dw-mipi-dsi ff960000.mipi: no reset control specified
[ 1.841336] rockchip-drm display-subsystem: bound ff960000.mipi (ops dw_mipi_dsi_ops)
实际测试硬件板子,发现mipi clk通道也未输出信号,请问大家有遇到这样的情况吗?
没这类情况,建议你仔细检查硬件接线
leung先森 发表于 2018-4-12 09:15
没这类情况,建议你仔细检查硬件接线
请问你烧录过这个mipi官方固件吗?可以正常点屏吗?
试过没问题,可以点亮
leung先森 发表于 2018-4-13 09:43
试过没问题,可以点亮
请问下你测量过mipi接口输出clk的频率吗?是320MHz吗?
新固件不支持 edp785屏 楼主 知道怎么处理吗?
新固件不支持 edp785屏 ???
cyberwiz 发表于 2019-3-6 10:15
新固件不支持 edp785屏 ???
好像是的
