求助OV13850模组Linux系统下的驱动,
唉………… 同求 我这里的结果也有点悲催
root@linaro-alip:~# dmesg | grep camer
[ 1.376331] of_get_named_gpiod_flags: can't parse 'rockchip,pd-gpio' property of node '/i2c@ff110000/camera-module@60[0]'
[ 1.376388] of_get_named_gpiod_flags: parsed 'rockchip,pwr-gpio' property of node '/i2c@ff110000/camera-module@60[0]' - status (0)
[ 1.376410] of_get_named_gpiod_flags: can't parse 'rockchip,flash-gpio' property of node '/i2c@ff110000/camera-module@60[0]'
[ 1.376429] of_get_named_gpiod_flags: can't parse 'rockchip,torch-gpio' property of node '/i2c@ff110000/camera-module@60[0]'
[ 1.376446] of_get_named_gpiod_flags: can't parse 'rockchip,rst-gpio' property of node '/i2c@ff110000/camera-module@60[0]'
[ 1.402019] ov13850.ov_camera_module_write_config(182) ERR: no active sensor configuration
[ 1.402751] ov13850.ov_camera_module_write_config(233) ERR: failed with error -14
[ 1.404450] ov13850.pltfrm_camera_module_read_reg(996) ERR: i2c read from offset 0x0000300a failed with error -6
[ 1.405638] ov13850.pltfrm_camera_module_read_reg(996) ERR: i2c read from offset 0x0000300b failed with error -6
[ 1.406555] ov13850.ov13850_check_camera_id(1820) ERR: register read failed, camera module powered off?
[ 1.407384] ov13850.ov13850_check_camera_id(1838) ERR: failed with error (-6)
[ 1.408038] ov13850.ov_camera_module_attach(256) ERR: failed with error -6
root@linaro-alip:~# dmesg | grep mipi
root@linaro-alip:~# dmesg | grep mis
[ 0.931179] rockchip-vop ff900000.vop: missing rockchip,grf property
[ 0.932748] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[ 1.741128] gpio-5 (GPIO Key Power): gpiod_set_debounce: missing set() or set_debounce() operations
[ 5.895884] dhd_get_memdump_info: File [/data/misc/wifi/.memdump.info] doesn't exist
[ 9.108288] dwhdmi-rockchip ff940000.hdmi: Rate 0 missing; compute N dynamically
[ 9.140054] dwhdmi-rockchip ff940000.hdmi: Rate 0 missing; compute N dynamically
root@linaro-alip:~# dmesg | grep misc
root@linaro-alip:~#
