关于新发布20180416固件版本上安装支持gstreamer的opencv
使用新发布的sdk,版本:Firefly-RK3399-ubuntu16.04-20180416112819.img;
该img自带gstreamer,测试可以硬解码,非常给力。
现在想源码编译安装opencv,让opencv打开gstreamer的支持,这样opencv就能直接使用gstreamer硬解码。
但是源码编译opencv的时候,出现错误。
编译命令如下:
sudo cmake -D CMAKE_BUILD_TYPE=Release -D CMAKE_INSTALL_PREFIX=/usr/local
-D WITH_GSTREAMER=ON -DCMAKE_C_COMPILER=aarch64-linux-gnu-gcc
-DCMAKE_CXX_COMPILER=aarch64-linux-gnu-g++ -DFIND_LIBRARY=/usr/lib/aarch64-linux-gnu/
-DWITH_GTK=ON -DWITH_GTHREAD=ON ..
出现以下错误:
– Checking for module ‘gtk±3.0’
– No package ‘gtk±3.0’ found
– Checking for module ‘gtk±2.0’
– No package ‘gtk±2.0’ found
– Checking for module ‘gthread-2.0’
– No package ‘gthread-2.0’ found
– Checking for module ‘gstreamer-base-1.0’
– No package ‘gstreamer-base-1.0’ found
– Checking for module ‘gstreamer-video-1.0’
– No package ‘gstreamer-video-1.0’ found
– Checking for module ‘gstreamer-app-1.0’
– No package ‘gstreamer-app-1.0’ found
– Checking for module ‘gstreamer-riff-1.0’
– No package ‘gstreamer-riff-1.0’ found
– Checking for module ‘gstreamer-pbutils-1.0’
– No package ‘gstreamer-pbutils-1.0’ found
– Checking for module ‘gstreamer-base-0.10’
– No package ‘gstreamer-base-0.10’ found
– Checking for module ‘gstreamer-video-0.10’
– No package ‘gstreamer-video-0.10’ found
– Checking for module ‘gstreamer-app-0.10’
– No package ‘gstreamer-app-0.10’ found
– Checking for module ‘gstreamer-riff-0.10’
– No package ‘gstreamer-riff-0.10’ found
但是我能在/usr/lib/aarch64-linux-gnu/目录下,找到这些so。为什么找不到?
向各位大神请教一下,怎么在这个img版本上安装支持自带gstreamer的opencv?
安装缺少的一些库后,opencv编译如下:
Looking for ccache - not found
Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found suitable version “1.2.8”, minimum required is “1.2.3”)
Could NOT find JPEG (missing: JPEG_LIBRARY JPEG_INCLUDE_DIR)
Could NOT find Jasper (missing: JASPER_LIBRARIES JASPER_INCLUDE_DIR)
Found ZLIB: /usr/lib/aarch64-linux-gnu/libz.so (found version “1.2.8”)
Looking for linux/videodev.h
Looking for linux/videodev.h - not found
Looking for linux/videodev2.h
Looking for linux/videodev2.h - found
Looking for sys/videoio.h
Looking for sys/videoio.h - not found
Checking for module ‘libgphoto2’
Found libgphoto2, version 2.5.9
Could not find OpenBLAS include. Turning OpenBLAS_FOUND off
Could not find OpenBLAS lib. Turning OpenBLAS_FOUND off
Could NOT find Atlas (missing: Atlas_CBLAS_INCLUDE_DIR Atlas_CLAPACK_INCLUDE_DIR Atlas_CBLAS_LIBRARY Atlas_BLAS_LIBRARY Atlas_LAPACK_LIBRARY)
A library with BLAS API not found. Please specify library location.
LAPACK requires BLAS
A library with LAPACK API not found. Please specify library location.
Could NOT find Pylint (missing: PYLINT_EXECUTABLE)
Could NOT find Matlab (missing: MATLAB_MEX_SCRIPT MATLAB_INCLUDE_DIRS MATLAB_ROOT_DIR MATLAB_LIBRARIES MATLAB_LIBRARY_DIRS MATLAB_MEXEXT MATLAB_ARCH MATLAB_BIN)
VTK is not found. Please set -DVTK_DIR in CMake to VTK build directory, or to VTK install subdirectory with VTKConfig.cmake file
Module opencv_videostab disabled because opencv_features2d dependency can’t be resolved!
Processing WORLD modules…
module opencv_core…
module opencv_imgproc…
module opencv_photo…
module opencv_video…
module opencv_imgcodecs…
module opencv_videoio…
module opencv_highgui…
Processing WORLD modules… DONE
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/core/src/convert.sse4_1.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/core/src/convert.avx2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/build/modules/world/mathfuncs_core.sse2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/build/modules/world/mathfuncs_core.avx.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/build/modules/world/mathfuncs_core.avx2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/build/modules/world/stat.sse4_2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/build/modules/world/stat.avx2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/imgproc/src/corner.avx.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/imgproc/src/resize.avx2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/imgproc/src/resize.sse4_1.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/imgproc/src/imgwarp.avx2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/imgproc/src/imgwarp.sse4_1.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/imgproc/src/undistort.avx2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/modules/imgproc/src/filter.avx2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/build/modules/world/accum.sse2.cpp
Excluding from source files list: /home/firefly/Workspace/opencv-3.4.0/build/modules/world/accum.avx.cpp
General configuration for OpenCV 3.4.0 =====================================
Version control: unknown
Platform:
Timestamp: 2018-04-17T03:05:12Z
Host: Linux 4.4.77 aarch64
CMake: 3.5.1
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: Release
CPU/HW features:
Baseline: NEON FP16
required: NEON
disabled: VFPV3
C/C++:
Built as dynamic libs?: YES
C++ Compiler: /usr/bin/c++ (ver 5.4.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Winit-self -Wno-narrowing -Wno-delete-non-virtual-dtor -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Winit-self -Wno-narrowing -Wno-comment -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release):
Linker flags (Debug):
ccache: NO
Precompiled headers: NO
Extra dependencies: dl m pthread rt
3rdparty dependencies:
OpenCV modules:
To be built: core highgui imgcodecs imgproc photo video videoio world
Disabled: calib3d features2d flann js ml objdetect python_bindings_generator shape stitching superres
Disabled by dependency: videostab
Unavailable: cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev java python2 python3 ts viz
Applications: -
Documentation: NO
Non-free algorithms: NO
GUI:
GTK+: YES (ver 2.24.30)
GThread : YES (ver 2.52.3)
GtkGlExt: NO
VTK support: NO
Media I/O:
ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.8)
JPEG: libjpeg (ver 90)
WEBP: build (ver encoder: 0x020e)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.2.54)
JPEG 2000: build (ver 1.900.1)
OpenEXR: build (ver 1.7.1)
Video I/O:
GStreamer:
base: YES (ver 1.12.2)
video: YES (ver 1.12.2)
app: YES (ver 1.12.2)
riff: YES (ver 1.12.2)
pbutils: YES (ver 1.12.2)
libv4l/libv4l2: NO
v4l/v4l2: linux/videodev2.h
gPhoto2: YES
Parallel framework: pthreads
Trace: YES (built-in)
Other third-party libraries:
Lapack: NO
Eigen: NO
Custom HAL: YES (carotene (ver 0.0.1))
OpenCL: YES (no extra features)
Include path: /home/firefly/Workspace/opencv-3.4.0/3rdparty/include/opencl/1.2
Link libraries: Dynamic load
Python (for build): /usr/bin/python2.7
Matlab: NO
Install to: /usr/local
Configuring done
这样编译可以成功,但是运行如下代码的时候,提示错误,具体如下:
代码:
#include
#include <opencv2/opencv.hpp>
cv::Mat frame;
cv::VideoCapture capture;
long g_count = 0;
int main()
std::cout<<"open cam "<<std::endl;
if(!capture.open(“test.mp4”))
std::cout<<“open cam failed”<<std::endl;
//return -1;
while(1)
	std::cout<<"capture frame "<<std::endl;
	capture>>frame;
	if(frame.cols > 0 && frame.rows > 0)
		std::cout<<"imshow frame "<<std::endl;
		cv::imshow("0",frame);
	if(cv::waitKey(30)==27) break;
return 0;
报错:
mpi: mpp version: 5849089 author: Herman Chen [mpp]: Add temporally patch for blocking issue
hal_h264d_api: hal_h264d_init mpp_buffer_group_get_internal used ion In
mpp_rt: NOT found ion allocator
mpp_rt: found drm allocator
OpenCV Error: Unspecified error (GStreamer: your gstreamer installation is missing a required plugin
) in handlemessage, file /home/firefly/Workspace/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp, line 1869
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
/home/firefly/Workspace/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp:1869: error: (-2) GStreamer: your gstreamer installation is missing a required plugin
in function handlemessage
这是错在哪里?gstreamer没装好?
lz您好
我也在试新版里面内建的gstreamer,但硬解是有问题的
能帮忙看下吗?
指令如下
gst-launch-1.0 rtspsrc location=‘rtspt://rtsplink:554/user=&password=&channel=&stream=.sdp’ ! rtph264depay ! mppvideodec ! rkximagesink
但都没有出现串流画面, 卡在 mpp_rt: found drm allocator
用ctrl C 中断后,跳出 “gst_mpp_allocator_start: assertion ‘size != 0’ failed”
我之前安装过opencv 3.4.1,配上FFMpeg与Gstreamer,当时gstreamer是用源码compile过来的 ,
包含各个插件(plugins) ,源码直接 ./autogen.sh → make -j6 → make install 即可
FFmpeg是用Longchair的版本,(https://github.com/LongChair/FFmpeg)
configure时要enable rkmpp选项 就有硬解
您可以试下
power1077 发表于 2018-4-20 09:17
lz您好
能帮忙看下吗?
我用的这个,可以播放:gst-launch-1.0 playbin uri=rtsp://admin:a1234567@192.168.1.201:554/h264/ch1/main/av_stream
包含各个插件 …
opencv调ffmpeg实现硬解,这就很好了。那硬件编码呢?您当时试了吗?
硬件編碼會卡在drm allocator
具體我這篇有log : http://dev.t-firefly.com/thread-13573-1-1.html
FFmpeg調用硬解也是類似的錯誤信息
zouxf 发表于 2018-4-27 17:41
去掉这个试试看 -DFIND_LIBRARY=/usr/lib/aarch64-linux-gnu/ \
重新刷了一次20180426的一体化固件,安装libgtk2.0-dev和gstreamer-base1.0,编译可以支持gstreamer,但是测试demo的时候,还是报错,跟之前差不多,如下:
Unable to stop the stream: Inappropriate ioctl for device
) in handlemessage, file /home/firefly/Documents/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp, line 1869
/home/firefly/Documents/opencv-3.4.0/modules/videoio/src/cap_gstreamer.cpp:1869: error: (-2) GStreamer: your gstreamer installation is missing a required plugin
感觉还是gstreamer本身有问题,希望能在帮忙看看,多谢哈
@一只大犀牛,大哥,搞定了么?分享一下吧
