rk3288 用了一个月不能启动了,是什么原因,请版主看看。
3288板子用了一个月,现在不启动了。可以刷固件,但是一直重启。串口信息如下
pmic:act8846
#Boot ver: 2014-11-27#2.19
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
got recovery cmd from misc.
failed to load fdt from recovery!
kernel @ 0x02000000 (0x00659f60)
ramdisk @ 0x04bf0000 (0x003d1840)
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480d000, end 0482aaf9 … OK
DDR Version 1.00 20141007
Channel a: DDR3 200MHz
Channel b: DDR3 200MHz
Memory OK
Memory OK
U-Boot 2014.10-RK3288-01 (Nov 27 2014 - 16:44:27)
CPU: rk3288
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks:1
128 MiB
storage init OK!
GetParam
check parameter success
Unknow param: MACHINE_ID:007!
power key: bank-0 pin-5
pmic:act8846
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
如果按了reset就是如下显示,然#Boot ver: 2014-11-27#2.19
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
Memory OK
Memory OK
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (firefly@midserver) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #3 SMP PREEMPT Tue Dec 30 15:45:08 CST 2014 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(40000000) size(28000000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 640 MiB at 40000000 [ 0.000000] ion_reserve: cma reserved base 40000000 size 671088640 [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1dea000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768 [ 0.000000] Kernel command line: console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00180000@0x00092000(system),0x00002000@0x00212000(metadata),0x00200000@0x00214000(userdata),0x00020000@0x00414000(radical_update),-@0x00434000(user) storagemedia=emmc loader.timestamp=2014-11-27_16:44:27 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 4194304 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 1385680k/1385680k available, 711472k reserved, 663552K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0af04ac (11170 kB) [ 0.000000] .init : 0xc0af1000 - 0xc0b856c0 ( 594 kB) [ 0.000000] .data : 0xc0b86000 - 0xc0c8e9b8 (1059 kB) [ 0.000000] .bss : 0xc0c8e9b8 - 0xc0daca04 (1145 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 31 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 1 [ 0.000000] channel:0, lkg:44 [ 0.000000] target-temp:80 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:80 [ 0.000000] channel:0, lkg:44 [ 0.000000] target-temp:80 [ 0.000000] channel:1, lkg:33 [ 0.000000] target-temp:80 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.306417] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.306433] pid_max: default: 32768 minimum: 301 [ 0.306537] Security Framework initialized [ 0.306554] SELinux: Initializing. [ 0.306623] Mount-cache hash table entries: 512 [ 0.307258] Initializing cgroup subsys debug [ 0.307272] Initializing cgroup subsys memory [ 0.307299] Initializing cgroup subsys freezer [ 0.307328] CPU: Testing write buffer coherency: ok [ 0.307631] /cpus/cpu@0 missing clock-frequency property [ 0.307643] /cpus/cpu@1 missing clock-frequency property [ 0.307652] /cpus/cpu@2 missing clock-frequency property [ 0.307661] /cpus/cpu@3 missing clock-frequency property [ 0.307724] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.307775] Setting up static identity map for 0xc07df1a8 - 0xc07df200 [ 0.310982] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x16bb (version 3.0) [ 0.384527] CPU1: Booted secondary processor [ 0.384559] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.404213] CPU2: Booted secondary processor [ 0.404237] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.423926] CPU3: Booted secondary processor [ 0.423949] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.424050] Brought up 4 CPUs [ 0.424079] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.424088] CPU: All CPU(s) started in SVC mode. [ 0.424813] devtmpfs: initialized [ 0.429676] pinctrl core: initialized pinctrl subsystem [ 0.429928] regulator-dummy: no parameters [ 0.441305] NET: Registered protocol family 16 [ 0.443051] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.443382] ion_snapshot: 0x2e1b0000 map to 0xf0107000 and copy to 0xc0d88004 (version 0.1) [ 0.443691] Registered FIQ tty driver [ 0.445018] console [ttyFIQ0] enabled [ 0.445238] Registered fiq debugger ttyFIQ0 [ 0.445757] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.445782] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.445802] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.445822] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.445914] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.445983] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.446047] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.446110] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.446174] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.446239] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.446305] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.446374] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.446447] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.446515] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.446531] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.446545] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.446560] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.447066] rockchip_interrupts_register:bank_num=7 [ 0.448997] rockchip_pinctrl_probe:init ok [ 0.454967] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.455059] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.455076] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.455239] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.455318] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.455334] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.455489] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.455561] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.455576] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.455735] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.455814] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.455829] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.455993] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.456070] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.456085] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.456242] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.456313] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.456329] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.456520] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.456594] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.456609] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.458281] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.458298] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.458510] DDR DEBUG: version 1.00 20140603 [ 0.458541] DDR DEBUG: Channel a: [ 0.458552] DDR DEBUG: DDR3 Device [ 0.458568] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.458580] DDR DEBUG: Channel b: [ 0.458588] DDR DEBUG: DDR3 Device [ 0.458602] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Total Capability=1024MB [ 0.458614] DDR DEBUG: addr=0xc96000 [ 0.458626] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.458637] DDR DEBUG: socAddr[0]=0xc96000, socAddr[1]=0xc96100 [ 0.458649] DDR DEBUG: chAddr[0]=0xc96000, chAddr[1]=0xc96000 [ 0.458662] DDR DEBUG: dtar[0]=0x60192000, dtar[1]=0x60192000 [ 0.458908] DDR DEBUG: init success!!! freq=300MHz [ 0.458918] DDR DEBUG: Channel a: [ 0.458932] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.458949] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.458965] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.458982] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.458997] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.459010] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.459021] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.459030] DDR DEBUG: Channel b: [ 0.459043] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459059] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459076] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459092] DDR DEBUG: DTONE=0x1, DTERR=0x0, DTIERR=0x0, DTPASS=4,0, DGSL=1,1 extra clock, DGPS=270,270 [ 0.459107] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.459118] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.459129] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.480811] bio: create slab at 0 [ 0.481656] SCSI subsystem initialized [ 0.481805] usbcore: registered new interface driver usbfs [ 0.481852] usbcore: registered new interface driver hub [ 0.481935] usbcore: registered new device driver usb [ 0.483304] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.485490] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.486988] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.487953] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.488199] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.488688] media: Linux media interface: v0.10 [ 0.488729] Linux video capture interface: v2.00 [ 0.488775] pps_core: LinuxPPS API ver. 1 registered [ 0.488787] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.488810] PTP clock support registered [ 0.489288] Rockchip ion module is successfully loaded (v1.0) [ 0.489443] Advanced Linux Sound Architecture Driver Initialized. [ 0.489813] Bluetooth: Core ver 2.16 [ 0.489850] NET: Registered protocol family 31 [ 0.489862] Bluetooth: HCI device and connection manager initialized [ 0.489879] Bluetooth: HCI socket layer initialized [ 0.489894] Bluetooth: L2CAP socket layer initialized [ 0.489920] Bluetooth: SCO socket layer initialized [ 0.490155] cfg80211: Calling CRDA to update world regulatory domain [ 0.490792] act8846_i2c_probe,line=898 [ 0.491753] act8846_parse_dt,line=746 [ 0.492441] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.492463] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.492481] act8846_i2c_probe: act8846_pmic_cpu_det_gpio=1 [ 0.492498] act8846_i2c_probe: act8846_pmic_usb_hub_reset_gpio=1 [ 0.494349] act_dcdc1: 1200 mV [ 0.497078] vccio: 3300 mV [ 0.498940] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 0.501654] act_dcdc4: 2000 mV [ 0.502903] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.504984] act_ldo2: 1000 mV [ 0.507062] act_ldo3: 3300 mV [ 0.509136] act_ldo4: 3300 mV [ 0.511216] act_ldo5: 3300 mV [ 0.513290] act_ldo6: 1000 mV [ 0.515366] vcc_18: 1800 mV [ 0.517435] act_ldo8: 1800 mV [ 0.522206] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.526908] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.527658] Switching to clocksource arch_sys_counter [ 0.547787] rk-fb rockchip-fb: rk fb ion client create success! [ 0.547805] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.548188] rk-screen rk_screen.9: rockchip screen probe success [ 0.548443] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.548775] rk32-edp ff970000.edp: screen is not edp! [ 0.548799] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.549522] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.549869] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.550036] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.550188] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.570543] rk3288-lcdc lcdc0: lcdc0: dclk:78000000>>fps:68 [ 0.570568] rk3288-lcdc lcdc0: wakeup from standby! [ 0.586386] alloc_buffer:ion_phy_addr=0x40000000 [ 0.592326] fb0:phy:40000000>>vir:f0171000>>len:0xc00000 [ 0.595835] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu disabled [ 0.595993] rk3288-lcdc lcdc1: can't find power_ctr node for lcdc1 [ 0.596009] rk_fb_trsm_ops_get:un supported transmitter:0! [ 0.596213] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.596515] graphics fb5: rockchip framebuffer registerd:fb5 [ 0.596690] graphics fb6: rockchip framebuffer registerd:fb6 [ 0.596869] graphics fb7: rockchip framebuffer registerd:fb7 [ 0.596887] fb0:phy:40000000>>vir:f0171000>>len:0xc00000 [ 0.596902] rk3288-lcdc lcdc1: lcdc1 probe ok, iommu disabled [ 0.597493] rockchip_set_mux:warning ignore bank num 15 [ 0.597615] rockchip_set_mux:warning ignore bank num 15 [ 0.597722] rockchip_set_mux:warning ignore bank num 15 [ 0.597836] rockchip_set_mux:warning ignore bank num 15 [ 0.597939] rockchip_set_mux:warning ignore bank num 15 [ 0.598051] rockchip_set_mux:warning ignore bank num 15 [ 0.598617] rockchip_set_mux:warning ignore bank num 15 [ 0.598758] rockchip_set_mux:warning ignore bank num 15 [ 0.599304] rockchip_set_mux:warning ignore bank num 15 [ 0.599440] rockchip_set_mux:warning ignore bank num 15 [ 0.599976] rockchip_set_mux:warning ignore bank num 15 [ 0.600117] rockchip_set_mux:warning ignore bank num 15 [ 0.600668] rockchip_set_mux:warning ignore bank num 15 [ 0.600810] rockchip_set_mux:warning ignore bank num 15 [ 0.602123] NET: Registered protocol family 2 [ 0.602580] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 0.602719] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.602856] TCP: Hash tables configured (established 8192 bind 8192) [ 0.602908] TCP: reno registered [ 0.602924] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.602961] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.603157] NET: Registered protocol family 1 [ 0.603337] Unpacking initramfs... [ 0.764619] Freeing initrd memory: 3908K (c4bf0000 - c4fc1000) [ 0.765180] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 0.765652] probe device ff9a0000.vpu_service [ 0.765825] vpu_service: power on [ 0.766882] checking hw id 4831 [ 0.767252] vpu_service set to auto frequency mode [ 0.767289] vpu_service: power off... [ 0.767326] done [ 0.767335] init success [ 0.767386] probe device ff9c0000.hevc_service [ 0.767590] hevc_service: power on [ 0.768627] checking hw id 6867 [ 0.768852] hevc_service: power off... [ 0.768891] done [ 0.768901] init success [ 0.769010] rknandbase v1.0 2014-03-31 [ 0.769105] rknand ff400000.nandc0: no irq resource? [ 0.769228] rknand_driver:ret = 0 [ 0.770690] audit: initializing netlink socket (disabled) [ 0.770730] type=2000 audit(0.460:1): initialized [ 0.771478] bounce pool size: 64 pages [ 0.775905] fuse init (API version 7.22) [ 0.776259] msgmni has been set to 1450 [ 0.778042] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 0.778062] io scheduler noop registered [ 0.778073] io scheduler deadline registered [ 0.778159] io scheduler cfq registered (default) [ 0.781647] rga2 ff920000.rga: rga ion client create success! [ 0.781799] rga: Driver loaded succesfully [ 0.782416] IEP Driver loaded succesfully [ 0.782505] Module initialized. [ 0.783367] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 0.783388] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 0.784709] dma-pl330 ff250000.pdma: Loaded driver for PL330 DM?DDR Version 1.00 20141007 In Channel a: DDR3 200MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB Channel b: DDR3 200MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB Memory OK Memory OK OUT
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
后一直循环,一直重启:
检查一下电源适配器是否正常。
装了linux版的固件还是有问题:
#Boot ver: 2015-01-21#2.17
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
failed to load fdt from boot!
kernel @ 0x02000000 (0x00609068)
ramdisk @ 0x04bf0000 (0x00275b8f)
Loading Device Tree to 0480c000, end 04827184 … OK
Memory OK
Memory OK
U-Boot 2014.10-RK3288-02 (Jan 21 2015 - 17:07:53)
CPU: rk3288
periph pll = 300000000HZ
codec pll = 594000000HZ
128 MiB
storage init OK!
GetParam
light power led: bank-8 pin-1
pmic:act8846
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
Memory OK
Memory OK
CPU: rk3288
128 MiB
storage init OK!
GetParam
pmic:act8846
empty serial no.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
Memory OK
Memory OK
先检查一下电源适配器
zhansb 发表于 2015-3-30 11:06
先检查一下电源适配器
怎么检查?再买一个?
pqy 发表于 2015-3-30 15:59
怎么检查?再买一个?
可以用万用表查一下,电压、电流看看是不是电流过高的时候才会出现
电源适配器是什么规格?
电源适配器刚买了原装的,问题依旧。
chenxin90 发表于 2015-4-2 09:58
电源适配器刚买了原装的,问题依旧。
擦除flash后,刷写固件Firefly-RK3288_Android4.4_201501271047.7z
如果还是会的话,请联系一下售后
初步测试了下,电源电压被拉的很低3点几伏,用的是原厂的2.5a电源,芯片没发现发热的。所以暂时找不到哪里短路了。
chenxin90 发表于 2015-4-2 11:28
初步测试了下,电源电压被拉的很低3点几伏,用的是原厂的2.5a电源,芯片没发现发热的。所以暂时找不到哪里 …
你直接量DC输出的电压是多少?我的意思是没有插到板子上的时候
那个事5v没问题的,试过很多电源了,直接接可编程电源,都是如此的。
你好,你这个最后问题解决了吗?我现在遇到和你一样的串口输出信息了。跟硬件没关系的,我把自己编译的kernel烧进去就这样,用的固件里的kernel就没事。
可能已经注册 发表于 2016-3-21 18:59
你好,你这个最后问题解决了吗?我现在遇到和你一样的串口输出信息了。跟硬件没关系的,我把自己编译的kern …
你好。请问您的问题解决了吗?怎么解决的?
解决了,就是kernel源码下载git里3.14版本就可以,不要修改太多,我在dts里删除了一些配置,发现就是启动不了。但是时间原因我没有仔细看过,但是CPU的配置那一块尽量不要修改。
