[Firefly-RK3288]长时间打开相机预览的时候,出现CAMERIC-MI-IRQ异常
设备打开相机,长时间处于预览状态时,会发生CameraHal_Marvin模块会发生IRQ异常。
不知各位大佬是否也遇到过类似情况,如果有解决方法,请指点一二。
问题困扰已久,跪求解决方法。
整份log不方便上传,需要其它部分log,我可以再次截取上传,还望体谅,谢谢!
部分异常log:
05-05 21:38:26.229 D/CameraHal( 155): debugShowFPS(1907): Camera 400864 Frames, 25.247 FPS
05-05 21:38:27.213 D/CameraHal( 155): debugShowFPS(613): Camera 400768 Frames, 25.246 FPS
05-05 21:38:27.496 D/CameraHal( 155): debugShowFPS(1907): Camera 400896 Frames, 25.246 FPS
05-05 21:38:28.480 D/CameraHal( 155): debugShowFPS(613): Camera 400800 Frames, 25.247 FPS
05-05 21:38:28.764 D/CameraHal( 155): debugShowFPS(1907): Camera 400928 Frames, 25.246 FPS
05-05 21:38:29.748 D/CameraHal( 155): debugShowFPS(613): Camera 400832 Frames, 25.246 FPS
05-05 21:38:30.031 D/CameraHal( 155): debugShowFPS(1907): Camera 400960 Frames, 25.246 FPS
05-05 21:38:31.015 D/CameraHal( 155): debugShowFPS(613): Camera 400864 Frames, 25.246 FPS
05-05 21:38:31.299 D/CameraHal( 155): debugShowFPS(1907): Camera 400992 Frames, 25.247 FPS
05-05 21:38:33.554 W/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: pBuf: 0xb8ccdd30(base:0x100e6000) not filled , so reused!!
05-05 21:38:33.554 E/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 258315;numFramesToSkip == 0
05-05 21:38:33.554 W/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: pBuf: 0xb8ccdd58(base:0x10159000) not filled , so reused!!
05-05 21:38:33.554 E/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 258316;numFramesToSkip == 0
05-05 21:38:33.554 E/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 258317;numFramesToSkip == 0
05-05 21:38:33.554 E/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 258318;numFramesToSkip == 0
05-05 21:38:33.554 E/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 258319;numFramesToSkip == 0
05-05 21:38:33.554 E/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 258320;numFramesToSkip == 0
05-05 21:38:33.554 E/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 258321;numFramesToSkip == 0
05-05 21:38:33.555 E/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: CamerIcMiIrq: MP buffer skipped (reused),pDrvCtx->invalFrame === 0,g_miFrameNum == 258322;numFramesToSkip == 0
05-05 21:38:33.555 W/CameraHal_Marvin( 155): CAMERIC-MI-IRQ: pBuf: 0xb8ccdd30(base:0x100e6000) not filled , so reused!!
{:4_126:}
你好,麻烦问下解决了么,怎么解决的?
请问这个问题解决了吗?
