RK3399system分区起不来
在自己的板子上移植RK3399SDK时发现,system分区起不来,利用串口查看打印信息发现一直重复打印binder: 188:188 transaction failed 29189/0, size 0-0 line 2868,现在没有一点思路,贴上部分打印信息,希望各位大神能够指教.
rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.374534] headset_interrupt:get pin level again,pin=1156,i=0
[ 1.470313] ueventd: Coldboot took 0.18s.
[ 1.483986] init: write_file: Unable to open ‘/proc/self/coredump_filter’: Ny
[ 1.484035] init: write_file: Unable to open '/proc/sys/kernel/panic_on_stacy
[ 1.484065] init: Waiting for /dev/.coldboot_done…
[ 1.484119] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 1.484147] init: /dev/hw_random not found
[ 1.484657] keychord: using input dev rk29-keypad for fevent
[ 1.490302] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such y
[ 1.497157] Registered swp emulation handler
[ 1.497318] init: write_file: Unable to open '/sys/module/rockchip_pm/paramey
[ 1.497896] fs_mgr: Warning: unknown flag resize
[ 1.499725] fec: <1> error: get_squashfs_size: failed to parse superblock: It
[ 1.499744] fs_mgr: Failed to get verity metadata '/dev/block/platform/fe330)
[ 1.499998] init: /dev/hw_random not found
[ 1.500073] init: write_file: Unable to open '/sys/block/mmcblk0/bdi/read_ahy
[ 1.501055] fs_mgr: Warning: unknown flag resize
[ 1.503333] fec: <177> error: get_squashfs_size: failed to parse superblock:t
[ 1.503413] fs_mgr: Failed to get verity metadata ‘/dev/block/platform/fe330)
[ 1.503592] fs_mgr: Could not set up verified partition, skipping!
[ 1.504624] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-y
[ 1.504717] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/fe)
[ 1.518310] EXT4-fs (mmcblk1p9): recovery complete
[ 1.518872] EXT4-fs (mmcblk1p9): mounted filesystem with ordered data mode. d
[ 1.519134] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-nam0
[ 1.520658] EXT4-fs (mmcblk1p11): Ignoring removed nomblk_io_submit option
[ 1.524657] EXT4-fs (mmcblk1p11): warning: maximal mount count reached, runnd
[ 1.525318] EXT4-fs (mmcblk1p11): recovery complete
[ 1.525329] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode.t
[ 1.525406] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-s
[ 1.540119] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 1.540321] fs_mgr: Not running /system/bin/e2fsck on /dev/block/platform/fe)
[ 1.545645] EXT4-fs (mmcblk1p11): warning: maximal mount count reached, runnd
[ 1.546496] EXT4-fs (mmcblk1p11): mounted filesystem with ordered data mode.d
[ 1.546684] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-nam0
[ 1.546894] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe3a
[ 1.550323] fsck.f2fs: executing /system/bin/fsck.f2fs failed: No such file y
[ 1.550323]
[ 1.550448] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 1.550448]
[ 1.571450] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-nam0
[ 1.595110] init: do_start: Service logd not found
[ 1.603478] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No suche
[ 1.607699] zram0: detected capacity change from 0 to 533413888
[ 1.610829] Unable to find swap-space signature
[ 1.610977] fs_mgr: swapon failed for /dev/block/zram0
[ 1.611487] init: (Loading properties from /system/build.prop took 0.00s.)
[ 1.611587] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 1.611670] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 1.611897] fs_mgr: Warning: unknown flag resize
[ 1.612152] init: /recovery not specified in fstab
[ 1.612607] init: SELinux: Could not set context for /data: Read-only file m
[ 1.612672] init: do_start: Service debuggerd not found
[ 1.612723] init: do_start: Service debuggerd64 not found
[ 1.612771] init: do_start: Service vold not found
[ 1.613302] init: Not bootcharting.
[ 1.650821] init: SELinux: Could not set context for /data: Read-only file m
[ 1.650966] init: cannot find ‘/system/bin/tzdatacheck’ (No such file or dir’
[ 1.655332] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’y
[ 1.655550] init: (Loading properties from /data/local.prop took 0.00s.)
[ 1.655592] init: Unable to open persistent property directory "/data/propery
[ 1.655624] init: do_start: Service logd not found
[ 1.655649] init: do_start: Service logd-reinit not found
[ 1.656350] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shy
[ 1.658452] init: Starting service ‘healthd’…
[ 1.658942] init: cannot find ‘/system/bin/displayd’ (No such file or direct’
[ 1.659012] init: cannot find ‘/system/vendor/bin/elogs.sh’ (No such file or’
[ 1.659386] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/i.
[ 1.661197] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_fly
[ 1.664347] audit: type=1400 audit(1358499003.110:4): avc: denied { relabe1
[ 1.665162] audit: type=1400 audit(1358499003.110:5): avc: denied { relabe1
[ 1.665884] init: SELinux: Could not get canonical path for /system/bin/tee-.
[ 1.665964] init: SELinux: Could not get canonical path for /system/bin/rk_s.
[ 1.667288] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro’
[ 1.667317] init: write: cannot expand ‘${ro.serialno}’
[ 1.667352] init: property ‘ro.product.manufacturer’ doesn’t exist while exp’
[ 1.667375] init: write: cannot expand ‘${ro.product.manufacturer}’
[ 1.667407] init: property ‘ro.product.model’ doesn’t exist while expanding ’
[ 1.667429] init: write: cannot expand ‘${ro.product.model}’
[ 1.669268] file system registered
[ 1.670374] binder: 188:188 transaction failed 29189/0, size 0-0 line 2868
[ 1.671006] using random self ethernet address
[ 1.671025] using random host ethernet address
[ 1.671111] init: write_file: Unable to open '/config/usb_gadget/g1/functiond
[ 1.678683] init: cannot find ‘/system/bin/sh’ (No such file or directory), ’
[ 1.678824] init: Starting service ‘adbd’…
[ 2.670787] binder: 188:188 transaction failed 29189/0, size 0-0 line 2868
[ 3.671258] binder: 188:188 transaction failed 29189/0, size 0-0 line 2868
[ 4.671726] binder: 188:188 transaction failed 29189/0, size 0-0 line 2868
[ 5.672194] binder: 188:188 transaction failed 29189/0, size 0-0 line 2868
[ 6.672661] binder: 188:188 transaction failed 29189/0, size 0-0 line 2868
不要沉,大家有遇到过这样的问题吗
不要沉呀,同问,求大神指点
