rk3288开发板使用RK的SDK无法进入loader模式
使用RK的firefly版本的linux SDK,地址见http://opensource.rock-chips.com/wiki_Uboot
For firefly-rk3288 board. Use below command to build the U-Boot:
./make.sh firefly-rk3288
加载后可正常启动,但是怎么都进入不了loader烧录模式,串口log如下:
U-Boot 2017.09-01495-g3a06149 (May 16 2018 - 15:55:01 +0800)
Model: Firefly-RK3288
DRAM: 2 GiB
Relocation Offset is: 7ef6a000
MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0
In: serial
Out: serial
Err: serial
fastboot key pressed!
Setting reboot to fastboot flag …
switch to partitions #0, OK
download key pressed, entering download mode…
RKUSB: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x1d1f000
跟踪代码是udc_enable的时候hang()了,原因不明,应该是uboot有bug,请问如何解决?多谢!
