RK3399中的ubuntu系统启动了一半卡住了
自己做了一块RK3399电路板,ubuntu系统可以烧录,但是开机后系统启动到一半就卡住了,是什么原因?附上串口打印log。
DDR Version 1.07 20161103
Channel 0: DDR3, 666MHz
Channel 1: DDR3, 666MHz
256B stride
pmugrf_os_reg[2] = 0x3AA17AA1, stride = 0xD
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1856
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 62443
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 77791
LoaderFlag2: 0x0
NOTICE: BL31: v1.2(debug):e1a1ee4
NOTICE: BL31: Built : 14:38:26, Sep 29 2016
INFO: plat_rockchip_pmu_init(1202): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-ga7c7ca8 (Mar 28 2017 - 11:12:22)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
no key node
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=33
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-03-28#1.05
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x012e4008)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 00000000056148d4 … OK
Add bank:0000000000200000, 00000000f7e00000
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.77 (zouxf@mid-server) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #329 SMP Mon Dec 18 15:44:03 CST 2017 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ee6000 s46336 r8192 d31488 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432 [ 0.000000] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-03-28_11:12:22 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [ffffffc0ef600000-ffffffc0f35fffff] [ 0.000000] Memory: 3902184K/4061184K available (12094K kernel code, 1680K rwdata, 4352K rodata, 1152K init, 765K bss, 159000K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff80090a0000 - 0xffffff80091c0000 ( 1152 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c50000 ( 12096 KB) [ 0.000000] .rodata : 0xffffff8008c50000 - 0xffffff80090a0000 ( 4416 KB) [ 0.000000] .data : 0xffffff80091c0000 - 0xffffff8009364008 ( 1681 KB) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual) [ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @ef080000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000000ef010000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: using LPI pending table @0x00000000ef020000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001225] Console: colour dummy device 80x25 [ 0.001250] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [ 0.001263] pid_max: default: 32768 minimum: 301 [ 0.001356] Security Framework initialized [ 0.001368] Yama: becoming mindful. [ 0.001451] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.001463] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.002290] Initializing cgroup subsys devices [ 0.002308] Initializing cgroup subsys freezer [ 0.002336] ftrace: allocating 43638 entries in 171 pages [ 0.120469] sched-energy: Sched-energy-costs installed from DT [ 0.120488] CPU0: update cpu_capacity 401 [ 0.120548] ASID allocator initialised with 65536 entries [ 0.123758] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.124240] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.125503] Detected VIPT I-cache on CPU1 [ 0.125535] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.125570] CPU1: using LPI pending table @0x00000000ef2a0000 [ 0.125616] CPU1: update cpu_capacity 401 [ 0.125620] CPU1: Booted secondary processor [410fd034] [ 0.126164] Detected VIPT I-cache on CPU2 [ 0.126184] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.126219] CPU2: using LPI pending table @0x00000000ef2e0000 [ 0.126247] CPU2: update cpu_capacity 401 [ 0.126251] CPU2: Booted secondary processor [410fd034] [ 0.126776] Detected VIPT I-cache on CPU3 [ 0.126797] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.126829] CPU3: using LPI pending table @0x00000000ef320000 [ 0.126856] CPU3: update cpu_capacity 401 [ 0.126859] CPU3: Booted secondary processor [410fd034] [ 0.127381] Detected PIPT I-cache on CPU4 [ 0.127411] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.127447] CPU4: using LPI pending table @0x00000000ef360000 [ 0.127490] CPU4: update cpu_capacity 1024 [ 0.127493] CPU4: Booted secondary processor [410fd082] [ 0.128035] Detected PIPT I-cache on CPU5 [ 0.128054] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.128088] CPU5: using LPI pending table @0x00000000ef390000 [ 0.128115] CPU5: update cpu_capacity 1024 [ 0.128118] CPU5: Booted secondary processor [410fd082] [ 0.128207] Brought up 6 CPUs [ 0.128289] SMP: Total of 6 processors activated. [ 0.128298] CPU features: detected feature: GIC system register CPU interface [ 0.128311] CPU: All CPU(s) started at EL2 [ 0.128359] alternatives: patching kernel code [ 0.129791] devtmpfs: initialized [ 0.143984] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.144008] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.144460] pinctrl core: initialized pinctrl subsystem [ 0.145218] NET: Registered protocol family 16 [ 0.149638] cpuidle: using governor ladder [ 0.153647] cpuidle: using governor menu [ 0.153668] Registered FIQ tty driver [ 0.153896] vdso: 2 pages (1 code @ ffffff8008c56000, 1 data @ ffffff80091c4000) [ 0.153924] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.154083] DMA: preallocated 256 KiB pool for atomic allocations [ 0.237835] console [ttyFIQ0] enabled [ 0.238370] Registered fiq debugger ttyFIQ0 [ 0.264753] iommu: Adding device ff650000.vpu_service to group 0 [ 0.265375] iommu: Adding device ff660000.rkvdec to group 1 [ 0.265955] iommu: Adding device ff8f0000.vop to group 2 [ 0.266510] iommu: Adding device ff900000.vop to group 3 [ 0.268288] SCSI subsystem initialized [ 0.268809] usbcore: registered new interface driver usbfs [ 0.269332] usbcore: registered new interface driver hub [ 0.269891] usbcore: registered new device driver usb [ 0.270428] media: Linux media interface: v0.10 [ 0.270871] Linux video capture interface: v2.00 [ 0.271320] pps_core: LinuxPPS API ver. 1 registered [ 0.271760] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.272578] PTP clock support registered [ 0.273912] Advanced Linux Sound Architecture Driver Initialized. [ 0.274967] Bluetooth: Core ver 2.21 [ 0.275309] NET: Registered protocol family 31 [ 0.275712] Bluetooth: HCI device and connection manager initialized [ 0.276276] Bluetooth: HCI socket layer initialized [ 0.276707] Bluetooth: L2CAP socket layer initialized [ 0.277183] Bluetooth: SCO socket layer initialized [ 0.278215] rockchip-cpuinfo cpuinfo: Serial : d0ca684edfe7e963 [ 0.279265] clocksource: Switched to clocksource arch_sys_counter [ 0.328290] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.329196] NET: Registered protocol family 2 [ 0.330026] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 0.330858] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 0.331989] TCP: Hash tables configured (established 32768 bind 32768) [ 0.332683] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 0.333409] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 0.334330] NET: Registered protocol family 1 [ 0.335008] RPC: Registered named UNIX socket transport module. [ 0.335547] RPC: Registered udp transport module. [ 0.335964] RPC: Registered tcp transport module. [ 0.336388] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.337549] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.338370] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.342124] Initialise system trusted keyring [ 0.350549] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.352812] NFS: Registering the id_resolver key type [ 0.353303] Key type id_resolver registered [ 0.353674] Key type id_legacy registered [ 0.354044] Installing knfsd (copyright (C) 1996 [email]okir@monad.swb.de[/email]). [ 0.355343] fuse init (API version 7.23) [ 0.356168] SGI XFS with security attributes, no debug enabled [ 0.361815] NET: Registered protocol family 38 [ 0.362230] Key type asymmetric registered [ 0.362618] Asymmetric key parser 'x509' registered [ 0.363205] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.363876] io scheduler noop registered [ 0.364229] io scheduler deadline registered [ 0.364741] io scheduler cfq registered (default) [ 0.365809] platform ff770000.syscon:usb2-phy@e450: Driver rockchip-usb2phy requests probe deferral [ 0.367357] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned [ 0.370006] platform ff7c0000.phy: Driver rockchip-typec-phy requests probe deferral [ 0.373475] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [ 0.374055] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [ 0.374646] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [ 1.382284] pll lock timeout! [ 1.382569] phy [email]phy-phy@e220.5[/email]: phy poweron failed --> -22 [ 1.383063] rockchip-pcie f8000000.pcie: fail to power on phy, err -22 [ 1.383776] rockchip-pcie: probe of f8000000.pcie failed with error -22 [ 1.385703] rk-vcodec ff650000.vpu_service: probe device [ 1.386229] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0ee9b2c10 [ 1.387132] rk-vcodec ff650000.vpu_service: allocator is drm [ 1.387718] rk-vcodec ff650000.vpu_service: checking hw id 0 [ 1.388803] rk-vcodec ff650000.vpu_service: init success [ 1.390085] rk-vcodec ff660000.rkvdec: probe device [ 1.390596] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0ee9b3410 [ 1.391344] rk-vcodec ff660000.rkvdec: allocator is drm [ 1.391858] rk-vcodec ff660000.rkvdec: checking hw id 6876 [ 1.392682] rk-vcodec ff660000.rkvdec: init success [ 1.394505] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.395175] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 1.397435] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 1.398104] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.399878] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.401945] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A [ 1.403363] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A [ 1.404734] ff370000.serial: ttyS1 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A [ 1.406475] [drm:drm_core_init] Initialized drm 1.1.0 20060810 [ 1.410092] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008cf19a0) [ 1.411027] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008cf19a0) [ 1.412002] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports [ 1.412605] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver [ 1.413347] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 1.414805] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008cec920) [ 1.415564] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.416277] [drm:drm_vblank_init] No driver support for vblank timestamp query. [ 1.417005] rockchip-drm display-subsystem: failed to parse loader memory [ 1.417625] rockchip-drm display-subsystem: No connectors reported connected with modes [ 1.418369] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768 [ 1.430574] Console: switching to colour frame buffer device 128x48 [ 1.438157] rockchip-drm display-subsystem: fb0: frame buffer device [ 1.445837] mali ff9a0000.gpu: Failed to get regulator [ 1.446313] mali ff9a0000.gpu: Power control initialization failed [ 1.446936] platform ff9a0000.gpu: Driver mali requests probe deferral [ 1.447772] Unable to detect cache hierarchy from DT for CPU 0 [ 1.449058] brd: module loaded [ 1.454560] loop: module loaded [ 1.455426] zram: Added device: zram0 [ 1.456012] lkdtm: No crash points registered, enable through debugfs [ 1.457405] register spi return v = :0 [ 1.457763] tun: Universal TUN/TAP device driver, 1.6 [ 1.458214] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.460060] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 1.460695] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 1.461197] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b). [ 1.461881] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 1.462424] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 1.467995] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.468454] Ring mode enabled [ 1.468729] DMA HW capability register supported [ 1.469132] Normal descriptors [ 1.469448] RX Checksum Offload Engine supported (type 2) [ 1.469933] TX Checksum insertion supported [ 1.470318] Wake-Up On Lan supported [ 1.470672] Enable RX Mitigation via HW Watchdog Timer [ 1.534201] libphy: stmmac: probed [ 1.534519] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active [ 1.535089] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01) [ 1.536602] PPP generic driver version 2.4.2 [ 1.537212] usbcore: registered new interface driver rndis_wlan [ 1.538046] Rockchip WiFi SYS interface (V1.00) ... [ 1.538564] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.539326] usbcore: registered new interface driver pegasus [ 1.539879] usbcore: registered new interface driver rtl8150 [ 1.540443] usbcore: registered new interface driver r8152 [ 1.540995] usbcore: registered new interface driver asix [ 1.541541] usbcore: registered new interface driver ax88179_178a [ 1.542130] usbcore: registered new interface driver cdc_ether [ 1.542710] usbcore: registered new interface driver dm9601 [ 1.543328] usbcore: registered new interface driver smsc75xx [ 1.543901] usbcore: registered new interface driver smsc95xx [ 1.544467] usbcore: registered new interface driver net1080 [ 1.545003] usbcore: registered new interface driver rndis_host [ 1.545572] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.546310] usbcore: registered new interface driver cdc_ncm [ 1.546845] usbcore: registered new interface driver qmi_wwan [ 1.547401] usbcore: registered new interface driver cdc_mbim [ 1.549066] platform fe800000.dwc3: Driver dwc3 requests probe deferral [ 1.549715] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3 [ 1.550412] platform usb@fe800000: Driver rockchip-dwc3 requests probe deferral [ 1.556639] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd [ 1.557464] platform usb@fe900000: Driver rockchip-dwc3 requests probe deferral [ 1.558891] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.559498] ehci-pci: EHCI PCI platform driver [ 1.559939] ehci-platform: EHCI generic platform driver [ 1.560660] platform fe380000.usb: Driver ehci-platform requests probe deferral [ 1.564901] ehci-platform fe3c0000.usb: EHCI Host Controller [ 1.565569] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1 [ 1.566368] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000 [ 1.572284] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [ 1.572982] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.573592] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.574234] usb usb1: Product: EHCI Host Controller [ 1.574673] usb usb1: Manufacturer: Linux 4.4.77 ehci_hcd [ 1.575150] usb usb1: SerialNumber: fe3c0000.usb [ 1.576018] hub 1-0:1.0: USB hub found [ 1.576388] hub 1-0:1.0: 1 port detected [ 1.577242] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.577813] ohci-platform: OHCI generic platform driver [ 1.578527] platform fe3a0000.usb: Driver ohci-platform requests probe deferral [ 1.579411] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [ 1.580154] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2 [ 1.580952] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000 [ 1.636420] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.637018] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.637673] usb usb2: Product: Generic Platform OHCI controller [ 1.638196] usb usb2: Manufacturer: Linux 4.4.77 ohci_hcd [ 1.638681] usb usb2: SerialNumber: fe3e0000.usb [ 1.639513] hub 2-0:1.0: USB hub found [ 1.639871] hub 2-0:1.0: 1 port detected [ 1.641031] usbcore: registered new interface driver cdc_acm [ 1.641545] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.642291] usbcore: registered new interface driver cdc_wdm [ 1.642830] usbcore: registered new interface driver uas [ 1.643390] usbcore: registered new interface driver usb-storage [ 1.643994] usbcore: registered new interface driver usbserial [ 1.644544] usbcore: registered new interface driver usbserial_generic [ 1.645147] usbserial: USB Serial support registered for generic [ 1.645725] usbcore: registered new interface driver cp210x [ 1.646246] usbserial: USB Serial support registered for cp210x [ 1.646825] usbcore: registered new interface driver ftdi_sio [ 1.647367] usbserial: USB Serial support registered for FTDI USB Serial Device [ 1.648082] usbcore: registered new interface driver keyspan [ 1.648613] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 1.649332] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 1.649992] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 1.650666] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 1.651351] usbcore: registered new interface driver option [ 1.651869] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.652594] usbcore: registered new interface driver oti6858 [ 1.653116] usbserial: USB Serial support registered for oti6858 [ 1.653693] usbcore: registered new interface driver pl2303 [ 1.654210] usbserial: USB Serial support registered for pl2303 [ 1.654785] usbcore: registered new interface driver qcserial [ 1.655326] usbserial: USB Serial support registered for Qualcomm USB modem [ 1.655983] usbcore: registered new interface driver sierra [ 1.656502] usbserial: USB Serial support registered for Sierra USB modem [ 1.657840] usbcore: registered new interface driver iforce [ 1.658413] usbcore: registered new interface driver xpad [ 1.658949] ==gsl_ts_init== [ 1.659220] ret=0 [ 1.659635] usbcore: registered new interface driver usbtouchscreen [ 1.660518] i2c /dev entries driver [ 1.662121] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 1.662825] fan53555-reg: supplied by vcc5v0_sys [ 1.665521] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 1.666175] fan53555-reg: supplied by vcc5v0_sys [ 1.669016] rk808 0-001b: failed to read the chip id at 0x17 [ 1.674333] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80094fc000 [ 1.675554] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80094fe000 [ 1.676310] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c [ 1.677239] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22 [ 1.677836] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl [ 1.678821] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back [ 1.679820] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80095c2000 [ 1.690663] fusb302 4-0022: port 0 probe success [ 1.691092] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80095c4000 [ 1.692763] IR NEC protocol handler initialized [ 1.693174] IR RC5(x/sz) protocol handler initialized [ 1.693641] IR RC6 protocol handler initialized [ 1.694051] IR JVC protocol handler initialized [ 1.694471] IR Sony protocol handler initialized [ 1.694881] IR SANYO protocol handler initialized [ 1.695309] IR Sharp protocol handler initialized [ 1.695731] IR MCE Keyboard/mouse protocol handler initialized [ 1.696247] IR XMP protocol handler initialized [ 1.697106] rockchip-rga ff680000.rga: HW Version: 0x03.02 [ 1.697877] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0 [ 1.698714] usbcore: registered new interface driver uvcvideo [ 1.699224] USB Video Class driver (1.1.1) [ 1.700112] platform ff320000.syscon:io-domains: Driver rockchip-iodomain requests probe deferral [ 1.701033] platform ff770000.syscon:io-domains: Driver rockchip-iodomain requests probe deferral [ 1.703287] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647 [ 1.705129] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: [email]dm-devel@redhat.com[/email] [ 1.706042] Bluetooth: Virtual HCI driver ver 1.5 [ 1.706585] Bluetooth: HCI UART driver ver 2.3 [ 1.706981] Bluetooth: HCI UART protocol H4 registered [ 1.707443] Bluetooth: HCI UART protocol LL registered [ 1.707895] Bluetooth: HCI UART protocol ATH3K registered [ 1.708438] usbcore: registered new interface driver bfusb [ 1.708974] usbcore: registered new interface driver btusb [ 1.709859] cpu cpu0: leakage=27 [ 1.710344] cpu cpu4: leakage=49 [ 1.710842] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral [ 1.712136] sdhci: Secure Digital Host Controller Interface driver [ 1.712694] sdhci: Copyright(c) Pierre Ossman [ 1.713089] Synopsys Designware Multimedia Card Interface Driver [ 1.714356] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 1.715025] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 1.715638] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 1.716186] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 1.717077] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.717848] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 1.718402] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 1.719232] platform fe310000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 1.720412] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 1.721072] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 1.721684] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 1.722229] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 1.723101] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.723866] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 1.724503] platform fe320000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 1.725384] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.727536] sdhci-arasan fe330000.sdhci: No vmmc regulator found [ 1.728071] sdhci-arasan fe330000.sdhci: No vqmmc regulator found [ 1.754448] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ 1.756160] hidraw: raw HID events driver (C) Jiri Kosina [ 1.757568] usbcore: registered new interface driver usbhid [ 1.758068] usbhid: USB HID core driver [ 1.760521] usbcore: registered new interface driver snd-usb-audio [ 1.778426] platform rt5640-sound: Driver asoc-simple-card requests probe deferral [ 1.779179] platform hdmi-codec: Driver asoc-simple-card requests probe deferral [ 1.779928] platform spdif-sound: Driver asoc-simple-card requests probe deferral [ 1.783435] u32 classifier [ 1.783688] Netfilter messages via NETLINK v0.30. [ 1.784173] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 1.785036] ctnetlink v0.93: registering with nfnetlink. [ 1.785650] ip_set: protocol 6 [ 1.785934] IPVS: Registered protocols () [ 1.786457] IPVS: Connection hash table configured (size=4096, memory=64Kbytes) [ 1.787181] IPVS: Creating netns size=1592 id=0 [ 1.787624] IPVS: ipvs loaded. [ 1.788192] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.788846] Initializing XFRM netlink socket [ 1.789871] NET: Registered protocol family 10 [ 1.791154] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 1.791811] sit: IPv6 over IPv4 tunneling driver [ 1.792709] NET: Registered protocol family 17 [ 1.793121] NET: Registered protocol family 15 [ 1.793559] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 1.794694] Bridge firewalling registered [ 1.795541] Bluetooth: RFCOMM socket layer initialized [ 1.796024] Bluetooth: RFCOMM ver 1.11 [ 1.796407] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 1.796935] Bluetooth: HIDP socket layer initialized [ 1.797437] 8021q: 802.1Q VLAN Support v1.8 [ 1.797835] lib80211: common routines for IEEE802.11 drivers [ 1.798385] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 1.799078] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 1.799565] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354 [ 1.799721] mmc0: MAN_BKOPS_EN bit is not set [ 1.800565] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 1.801195] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 1.801906] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0. [ 1.802707] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 1.803173] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 1.803645] [BT_RFKILL]: Enter rfkill_rk_init [ 1.804384] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83. [ 1.805129] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9. [ 1.805862] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90. [ 1.806594] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4. [ 1.807325] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!. [ 1.807961] [BT_RFKILL]: Request irq for bt wakeup host [ 1.808480] [BT_RFKILL]: ** disable irq [ 1.808957] [BT_RFKILL]: bt_default device registered. [ 1.809477] Key type dns_resolver registered [ 1.810486] Registered cp15_barrier emulation handler [ 1.811048] Registered setend emulation handler [ 1.812096] Loading compiled-in X.509 certificates [ 1.813556] mmc0: new HS400 Enhanced strobe MMC card at address 0001 [ 1.814534] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned [ 1.814768] mmcblk0: mmc0:0001 AJNB4R 14.6 GiB [ 1.815157] mmcblk0boot0: mmc0:0001 AJNB4R partition 1 4.00 MiB [ 1.815682] mmcblk0boot1: mmc0:0001 AJNB4R partition 2 4.00 MiB [ 1.816157] mmcblk0rpmb: mmc0:0001 AJNB4R partition 3 4.00 MiB [ 1.816522] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 1.816526] trust: 0x000800000 -- 0x000c00000 (4 MB) [ 1.816530] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 1.816534] kernel: 0x001c00000 -- 0x003000000 (20 MB) [ 1.816537] backup: 0x003000000 -- 0x003400000 (4 MB) [ 1.816540] boot: 0x003400000 -- 0x3a3a00000 (14854 MB) [ 1.820548] mmcblk0: p1 p2 p3 p4 p5 p6 [ 1.823391] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0 [ 1.824610] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing power_model_simple. [ 1.826435] mali ff9a0000.gpu: Probed as mali0 [ 1.832527] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 1.833280] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3 [ 1.834111] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010 [ 1.834927] xhci-hcd xhci-hcd.6.auto: irq 229, io mem 0xfe800000 [ 1.835604] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.836202] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.836857] usb usb3: Product: xHCI Host Controller [ 1.837295] usb usb3: Manufacturer: Linux 4.4.77 xhci-hcd [ 1.837772] usb usb3: SerialNumber: xhci-hcd.6.auto [ 1.838720] hub 3-0:1.0: USB hub found [ 1.839077] hub 3-0:1.0: 1 port detected [ 1.839709] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 1.840340] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4 [ 1.841078] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.841893] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 1.842499] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.843141] usb usb4: Product: xHCI Host Controller [ 1.843577] usb usb4: Manufacturer: Linux 4.4.77 xhci-hcd [ 1.844053] usb usb4: SerialNumber: xhci-hcd.6.auto [ 1.844931] hub 4-0:1.0: USB hub found [ 1.845312] hub 4-0:1.0: 1 port detected [ 1.846832] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 1.847310] usb usb4: USB disconnect, device number 1 [ 1.871541] xhci-hcd xhci-hcd.6.auto: Host not halted after 16000 microseconds. [ 1.872185] xhci-hcd xhci-hcd.6.auto: Host controller not halted, aborting reset. [ 1.872862] xhci-hcd xhci-hcd.6.auto: USB bus 4 deregistered [ 1.873501] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 1.873961] usb usb3: USB disconnect, device number 1 [ 1.874848] xhci-hcd xhci-hcd.6.auto: USB bus 3 deregistered [ 1.881003] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 1.881665] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3 [ 1.882502] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010 [ 1.883312] xhci-hcd xhci-hcd.7.auto: irq 230, io mem 0xfe900000 [ 1.883979] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.884587] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.885229] usb usb3: Product: xHCI Host Controller [ 1.885667] usb usb3: Manufacturer: Linux 4.4.77 xhci-hcd [ 1.886144] usb usb3: SerialNumber: xhci-hcd.7.auto [ 1.887075] hub 3-0:1.0: USB hub found [ 1.887446] hub 3-0:1.0: 1 port detected [ 1.888056] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 1.888689] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4 [ 1.889431] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 1.890227] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 1.890834] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.891481] usb usb4: Product: xHCI Host Controller [ 1.891911] usb usb4: Manufacturer: Linux 4.4.77 xhci-hcd [ 1.892396] usb usb4: SerialNumber: xhci-hcd.7.auto [ 1.893319] hub 4-0:1.0: USB hub found [ 1.893676] hub 4-0:1.0: 1 port detected [ 1.898246] ehci-platform fe380000.usb: EHCI Host Controller [ 1.899069] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5 [ 1.899895] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000 [ 1.906436] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 1.907177] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.907792] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.908443] usb usb5: Product: EHCI Host Controller [ 1.908875] usb usb5: Manufacturer: Linux 4.4.77 ehci_hcd [ 1.909359] usb usb5: SerialNumber: fe380000.usb [ 1.910444] hub 5-0:1.0: USB hub found [ 1.910807] hub 5-0:1.0: 1 port detected [ 1.911921] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 1.912789] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6 [ 1.913601] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000 [ 1.968597] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.969200] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.969857] usb usb6: Product: Generic Platform OHCI controller [ 1.970389] usb usb6: Manufacturer: Linux 4.4.77 ohci_hcd [ 1.970866] usb usb6: SerialNumber: fe3a0000.usb [ 1.971961] hub 6-0:1.0: USB hub found [ 1.972338] hub 6-0:1.0: 1 port detected [ 1.973241] platform ff320000.syscon:io-domains: Driver rockchip-iodomain requests probe deferral [ 1.974248] platform ff770000.syscon:io-domains: Driver rockchip-iodomain requests probe deferral [ 1.975175] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral [ 1.976487] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 1.977162] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 1.977777] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 1.978320] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 1.979186] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.979958] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 1.980513] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 1.981379] platform fe310000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 1.982785] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 1.983466] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 1.984066] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 1.984601] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 1.985475] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 1.986232] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 1.986867] platform fe320000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 1.999975] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok [ 2.004142] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input0 [ 2.006317] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok [ 2.008052] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0 [ 2.008689] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22 [ 2.009316] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22 [ 2.010065] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22 [ 2.010873] asoc-simple-card: probe of spdif-sound failed with error -22 [ 2.011714] platform ff320000.syscon:io-domains: Driver rockchip-iodomain requests probe deferral [ 2.012704] platform ff770000.syscon:io-domains: Driver rockchip-iodomain requests probe deferral [ 2.013628] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral [ 2.014930] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 2.015606] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 2.016209] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 2.016749] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 2.017622] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 2.018394] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 2.018940] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 2.019790] platform fe310000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 2.021195] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 2.021880] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 2.022490] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 2.023019] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 2.023905] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 2.024673] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 2.025325] platform fe320000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 2.026509] dhd_module_init: in [ 2.026515] [ 2.026518] ======================================================= [ 2.026520] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 2.026522] ======================================================= [ 2.026524] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init. [ 2.026529] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 2.026532] [WLAN_RFKILL]: wifi turn on power. -1 [ 2.026534] RTL871X: module init start [ 2.026537] RTL871X: rtl8188eu v4.3.24_16705.20160509 [ 2.026658] usbcore: registered new interface driver rtl8188eu [ 2.026660] RTL871X: module init ret=0 [ 2.027249] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 2.027908] hctosys: unable to open rtc device (rtc0) [ 2.032863] ======== dhd_wlan_init_plat_data ======== [ 2.033337] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1 [ 2.033777] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1 [ 2.034244] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 2.034744] dhd_wlan_init_gpio: host_oob_irq: 70 [ 2.035151] dhd_wlan_init_gpio: host_oob_irq_flags=0x414 [ 2.035632] dhd_wifi_platform_load: Enter [ 2.036018] Power-up adapter 'DHD generic adapter' [ 2.036515] wifi_platform_set_power = 1 [ 2.036862] ======== PULL WL_REG_ON(-1) HIGH! ======== [ 2.037327] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 2.037586] platform ff320000.syscon:io-domains: Driver rockchip-iodomain requests probe deferral [ 2.037796] platform ff770000.syscon:io-domains: Driver rockchip-iodomain requests probe deferral [ 2.037949] platform cpufreq-dt: Driver cpufreq-dt requests probe deferral [ 2.038665] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 2.038712] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 2.038723] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 2.038751] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 2.038767] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 2.038807] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 2.038811] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 2.044359] [WLAN_RFKILL]: wifi turn on power. -1 [ 2.044771] platform fe310000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 2.045683] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 2.046382] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 2.046990] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 2.047538] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 2.048422] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 2.049185] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 2.049856] platform fe320000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 2.051502] u? [ 2.153332] ALSA device list: [ 2.153604] #0: rockchip,rt5640-codec [ 2.153950] #1: HDMI-CODEC [ 2.154480] Waiting for root device /dev/mmcblk1p6... [ 2.246364] wifi_platform_bus_enumerate device present 1 [ 2.246845] ======== Card detection to detect SDIO card! ======== [ 2.247395] sdio: host isn't initialization successfully.
[ 2.154480] Waiting for root device /dev/mmcblk1p6…
parameter 明显不对 ,去官网下一个解包,升级下parameter 先,再升级其他分区
http://www.t-firefly.com/doc/product/info/id/100.html
[ 1.820548] mmcblk0: p1 p2 p3 p4 p5 …
嗯,后来发现是硬件上的问题,但是修改后系统还是启动不起来。log如下:
256B stride
CPUId = 0x0
ChipType = 10 1842
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
SdmmcInit=0 20
StorageInit ok = 62460
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 77775
LoaderFlag2: 0x0
WARNING: check_cpu_wfie: 1, 0, 69632, error!
WARNING: check_cpu_wfie: 1, 1, 139264, error!
INFO: plat_rockchip_pmu_init(1202): pd status e
INFO: SPSR = 0x3c9
CPU: rk3399
cpu version = 0
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
no key node
pmic:rk808
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Hit any key to stop autoboot: 3  2  1  0
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.77 (zouxf@mid-server) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #329 SMP Mon Dec 18 15:44:03 CST 2017 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ee6000 s46336 r8192 d31488 u86016 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432 [ 0.000000] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-03-28_11:12:22 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [ffffffc0ef600000-ffffffc0f35fffff] [ 0.000000] Memory: 3902184K/4061184K available (12094K kernel code, 1680K rwdata, 4352K rodata, 1152K init, 765K bss, 159000K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff80090a0000 - 0xffffff80091c0000 ( 1152 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008c50000 ( 12096 KB) [ 0.000000] .rodata : 0xffffff8008c50000 - 0xffffff80090a0000 ( 4416 KB) [ 0.000000] .data : 0xffffff80091c0000 - 0xffffff8009364008 ( 1681 KB) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual) [ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) [ 0.000000] m ( 3966 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @ef080000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000000ef010000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: usinion interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001225] Console: colour dummy device 80x25 [ 0.001250] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000) [ 0.001263] pid_max: default: 32768 minimum: 301 [ 0.001357] Security Framework initialized [ 0.001369] Yama: becoming mindful. [ 0.001451] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.001462] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.002292] Initializing cgroup subsys devices [ 0.002311] Initializing cgroup subsys freezer [ 0.002339] ftrace: allocating 43638 entries in 171 pages [ 0.120523] sched-energy: Sched-energy-costs installed from DT [ 0.120541] CPU0: update cpu_capacity 401 [ 0.120600] ASID allocator initialised with 65536 entries [ 0.123829] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.124279] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.125536] Detected VIPT I-cache on CPU1 [ 0.125567] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.125603] CPU1: using LPI pending table @0x00000000ef2a0000 [ 0.125649] CPU1: update cpu_capacity 401 [ 0.125652] CPU1: Booted secondary processor [410fd034] [ 0.126198] Detected VIPT I-cache on CPU2 [ 0.126218] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.126252] CPU2: using LPI pending table @0x00000000ef2e0000 [ 0.126280] CPU2: update cpu_capacity 401 [ 0.126283] CPU2: Booted secondary processor [410fd034] [ 0.126808] Detected VIPT I-cache on CPU3 [ 0.126828] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.126861] CPU3: using LPI pending table @0x00000000ef320000 [ 0.126889] CPU3: update cpu_capacity 401 [ 0.126893] CPU3: Booted secondary processor [410fd034] [ 1.133135] CPU4: failed to come online [ 1.133189] CPU4: failed in unknown state : 0x0 [ 2.139345] CPU5: failed to come online [ 2.139353] CPU5: failed in unknown state : 0x0 [ 2.139377] Brought up 4 CPUs [ 2.139384] SMP: Total of 4 processors activated. [ 2.139393] CPU features: detected feature: GIC system register CPU interface [ 2.139406] CPU: All CPU(s) started at EL2 [ 2.139439] alternatives: patching kernel code [ 2.140598] devtmpfs: initialized [ 2.161938] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 2.161971] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 2.162527] pinctrl core: initialized pinctrl subsystem [ 2.163650] NET: Registered protocol family 16 [ 2.172739] cpuidle: using governor ladder [ 2.184787] cpuidle: using governor menu [ 2.184810] Registered FIQ tty driver [ 2.185204] vdso: 2 pages (1 code @ ffffff8008c56000, 1 data @ ffffff80091c4000) [ 2.185238] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 2.185431] DMA: preallocated 256 KiB pool for atomic allocations [ 2.274901] console [ttyFIQ0] enabled [ 2.275512] Registered fiq debugger ttyFIQ0 [ 2.315726] iommu: Adding device ff650000.vpu_service to group 0 [ 2.316369] iommu: Adding device ff660000.rkvdec to group 1 [ 2.317014] iommu: Adding device ff8f0000.vop to group 2 [ 2.317600] iommu: Adding device ff900000.vop to group 3 [ 2.319930] SCSI subsystem initialized [ 2.320539] usbcore: registered new interface driver usbfs [ 2.321083] usbcore: registered new interface driver hub [ 2.321678] usbcore: registered new device driver usb [ 2.322249] media: Linux media interface: v0.10 [ 2.322714] Linux video capture interface: v2.00 [ 2.323184] pps_core: LinuxPPS API ver. 1 registered [ 2.323626] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 2.324464] PTP clock support registered [ 2.326356] Advanced Linux Sound Architecture Driver Initialized. [ 2.327616] Bluetooth: Core ver 2.21 [ 2.327980] NET: Registered protocol family 31 [ 2.328374] Bluetooth: HCI device and connection manager initialized [ 2.328940] Bluetooth: HCI socket layer initialized [ 2.329385] Bluetooth: L2CAP socket layer initialized [ 2.329864] Bluetooth: SCO socket layer initialized [ 2.331172] rockchip-cpuinfo cpuinfo: Serial : d0ca684edfe7e963 [ 2.332562] clocksource: Switched to clocksource arch_sys_counter [ 2.410064] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 2.411086] NET: Registered protocol family 2 [ 2.412095] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 2.413140] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 2.414967] TCP: Hash tables configured (established 32768 bind 32768) [ 2.415699] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 2.416424] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 2.417520] NET: Registered protocol family 1 [ 2.418379] RPC: Registered named UNIX socket transport module. [ 2.418923] RPC: Registered udp transport module. [ 2.419342] RPC: Registered tcp transport module. [ 2.419770] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.421282] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 2.422105] hw perfevents: failed to probe PMU! [ 2.422511] hw perfevents: failed to register PMU devices! [ 2.426695] Initialise system trusted keyring [ 2.438520] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.441365] NFS: Registering the id_resolver key type [ 2.441871] Key type id_resolver registered [ 2.442243] Key type id_legacy registered [ 2.442628] Installing knfsd (copyright (C) 1996 [email]okir@monad.swb.de[/email]). [ 2.444174] fuse init (API version 7.23) [ 2.445223] SGI XFS with security attributes, no debug enabled [ 2.451313] NET: Registered protocol family 38 [ 2.451754] Key type asymmetric registered [ 2.452133] Asymmetric key parser 'x509' registered [ 2.452837] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 2.453501] io scheduler noop registered [ 2.453869] io scheduler deadline registered [ 2.454427] io scheduler cfq registered (default) [ 2.455942] platform ff770000.syscon:usb2-phy@e450: Driver rockchip-usb2phy requests probe deferral [ 2.457813] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned [ 2.461473] platform ff7c0000.phy: Driver rockchip-typec-phy requests probe deferral [ 2.466443] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [ 2.467051] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [ 2.467652] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [ 3.475586] pll lock timeout! [ 3.475860] phy [email]phy-phy@e220.5[/email]: phy poweron failed --> -22 [ 3.476351] rockchip-pcie f8000000.pcie: fail to power on phy, err -22 [ 3.477022] rockchip-pcie: probe of f8000000.pcie failed with error -22 [ 3.478838] rk-vcodec ff650000.vpu_service: probe device [ 3.479360] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0ee991810 [ 3.480207] rk-vcodec ff650000.vpu_service: allocator is drm [ 3.480791] rk-vcodec ff650000.vpu_service: checking hw id 0 [ 3.481954] rk-vcodec ff650000.vpu_service: init success [ 3.483273] rk-vcodec ff660000.rkvdec: probe device [ 3.483771] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0ee992010 [ 3.484528] rk-vcodec ff660000.rkvdec: allocator is drm [ 3.485069] rk-vcodec ff660000.rkvdec: checking hw id 6876 [ 3.485945] rk-vcodec ff660000.rkvdec: init success [ 3.488454] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 3.489141] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 3.492100] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 3.492786] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 3.495032] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 3.497791] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A [ 3.499476] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 37, base_baud = 1500000) is a 16550A [ 3.501138] ff370000.serial: ttyS1 at MMIO 0xff370000 (irq = 39, base_baud = 1500000) is a 16550A [ 3.503455] [drm:drm_core_init] Initialized drm 1.1.0 20060810 [ 3.508725] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008cf19a0) [ 3.509796] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008cf19a0) [ 3.510880] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports [ 3.511475] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver [ 3.512250] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 3.513915] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008cec920) [ 3.514649] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.515352] [drm:drm_vblank_init] No driver support for vblank timestamp query. [ 3.516173] rockchip-drm display-subsystem: failed to parse loader memory [ 3.516806] rockchip-drm display-subsystem: No connectors reported connected with modes [ 3.517571] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768 [ 3.538575] Console: switching to colour frame buffer device 128x48 [ 3.554229] rockchip-drm display-subsystem: fb0: frame buffer device [ 3.566651] mali ff9a0000.gpu: Failed to get regulator [ 3.567108] mali ff9a0000.gpu: Power control initialization failed [ 3.567801] platform ff9a0000.gpu: Driver mali requests probe deferral [ 3.568654] Unable to detect cache hierarchy from DT for CPU 0 [ 3.570313] brd: module loaded [ 3.577053] loop: module loaded [ 3.578110] zram: Added device: zram0 [ 3.578937] lkdtm: No crash points registered, enable through debugfs [ 3.580760] register spi return v = :0 [ 3.581125] tun: Universal TUN/TAP device driver, 1.6 [ 3.581590] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 3.584165] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 3.584802] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 3.585307] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b). [ 3.586067] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 3.586616] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 3.592227] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 3.592692] Ring mode enabled [ 3.592970] DMA HW capability register supported [ 3.593374] Normal descriptors [ 3.593696] RX Checksum Offload Engine supported (type 2) [ 3.594183] TX Checksum insertion supported [ 3.594571] Wake-Up On Lan supported [ 3.594941] Enable RX Mitigation via HW Watchdog Timer [ 3.658676] libphy: stmmac: probed [ 3.658993] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active [ 3.659576] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01) [ 3.661660] PPP generic driver version 2.4.2 [ 3.662405] usbcore: registered new interface driver rndis_wlan [ 3.663256] Rockchip WiFi SYS interface (V1.00) ... [ 3.663757] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 3.664468] usbcore: registered new interface driver pegasus [ 3.665040] usbcore: registered new interface driver rtl8150 [ 3.665607] usbcore: registered new interface driver r8152 [ 3.666171] usbcore: registered new interface driver asix [ 3.666711] usbcore: registered new interface driver ax88179_178a [ 3.667295] usbcore: registered new interface driver cdc_ether [ 3.667869] usbcore: registered new interface driver dm9601 [ 3.668438] usbcore: registered new interface driver smsc75xx [ 3.669027] usbcore: registered new interface driver smsc95xx [ 3.669601] usbcore: registered new interface driver net1080 [ 3.670151] usbcore: registered new interface driver rndis_host [ 3.670737] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 3.671485] usbcore: registered new interface driver cdc_ncm [ 3.672049] usbcore: registered new interface driver qmi_wwan [ 3.672624] usbcore: registered new interface driver cdc_mbim [ 3.674927] platform fe800000.dwc3: Driver dwc3 requests probe deferral [ 3.675589] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3 [ 3.676351] platform usb@fe800000: Driver rockchip-dwc3 requests probe deferral [ 3.682840] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd [ 3.683753] platform usb@fe900000: Driver rockchip-dwc3 requests probe deferral [ 3.685627] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.686223] ehci-pci: EHCI PCI platform driver [ 3.686713] ehci-platform: EHCI generic platform driver [ 3.687575] platform fe380000.usb: Driver ehci-platform requests probe deferral [ 3.691604] ehci-platform fe3c0000.usb: EHCI Host Controller [ 3.692342] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1 [ 3.693188] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000 [ 3.699589] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [ 3.700366] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.700979] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.701637] usb usb1: Product: EHCI Host Controller [ 3.702069] usb usb1: Manufacturer: Linux 4.4.77 ehci_hcd [ 3.702561] usb usb1: SerialNumber: fe3c0000.usb [ 3.703613] hub 1-0:1.0: USB hub found [ 3.703996] hub 1-0:1.0: 1 port detected [ 3.705153] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.705733] ohci-platform: OHCI generic platform driver [ 3.706588] platform fe3a0000.usb: Driver ohci-platform requests probe deferral [ 3.707547] ohci-platform fe3e0000.usb: Generic Platform OHCI controller [ 3.708420] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2 [ 3.709245] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000 [ 3.764791] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 3.765390] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.766049] usb usb2: Product: Generic Platform OHCI controller [ 3.766587] usb usb2: Manufacturer: Linux 4.4.77 ohci_hcd [ 3.767066] usb usb2: SerialNumber: fe3e0000.usb [ 3.768101] hub 2-0:1.0: USB hub found [ 3.768470] hub 2-0:1.0: 1 port detected [ 3.770143] usbcore: registered new interface driver cdc_acm [ 3.770657] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 3.771414] usbcore: registered new interface driver cdc_wdm [ 3.771978] usbcore: registered new interface driver uas [ 3.772579] usbcore: registered new interface driver usb-storage [ 3.773213] usbcore: registered new interface driver usbserial [ 3.773778] usbcore: registered new interface driver usbserial_generic [ 3.774402] usbserial: USB Serial support registered for generic [ 3.774997] usbcore: registered new interface driver cp210x [ 3.775527] usbserial: USB Serial support registered for cp210x [ 3.776127] usbcore: registered new interface driver ftdi_sio [ 3.776685] usbserial: USB Serial support registered for FTDI USB Serial Device [ 3.777468] usbcore: registered new interface driver keyspan [ 3.778013] usbserial: USB Serial support registered for Keyspan - (without firmware) [ 3.778746] usbserial: USB Serial support registered for Keyspan 1 port adapter [ 3.779422] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 3.780109] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 3.780814] usbcore: registered new interface driver option [ 3.781345] usbserial: USB Serial support registered for GSM modem (1-port) [ 3.782162] usbcore: registered new interface driver oti6858 [ 3.782709] usbserial: USB Serial support registered for oti6858 [ 3.783290] usbcore: registered new interface driver pl2303 [ 3.783837] usbserial: USB Serial support registered for pl2303 [ 3.784413] usbcore: registered new interface driver qcserial [ 3.784971] usbserial: USB Serial support registered for Qualcomm USB modem [ 3.785663] usbcore: registered new interface driver sierra [ 3.786194] usbserial: USB Serial support registered for Sierra USB modem [ 3.787957] usbcore: registered new interface driver iforce [ 3.788520] usbcore: registered new interface driver xpad [ 3.789114] ==gsl_ts_init== [ 3.789396] ret=0 [ 3.789937] usbcore: registered new interface driver usbtouchscreen [ 3.790973] i2c /dev entries driver [ 3.793110] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 3.793906] fan53555-reg: supplied by vcc5v0_sys [ 3.796545] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 3.797257] fan53555-reg: supplied by vcc5v0_sys [ 3.800380] rk808 0-001b: Pmic Chip id: 0x0 [ 3.804385] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 3.805013] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 3.805731] DCDC_REG1: supplied by vcc3v3_sys [ 3.806989] DCDC_REG2: supplied by vcc3v3_sys [ 3.808071] DCDC_REG3: supplied by vcc3v3_sys [ 3.808811] DCDC_REG4: supplied by vcc3v3_sys [ 3.809729] LDO_REG1: supplied by vcc3v3_sys [ 3.811330] LDO_REG2: supplied by vcc3v3_sys [ 3.812780] LDO_REG3: supplied by vcc3v3_sys [ 3.814232] LDO_REG4: supplied by vcc3v3_sys [ 3.815685] LDO_REG5: supplied by vcc3v3_sys [ 3.817107] LDO_REG6: supplied by vcc3v3_sys [ 3.818567] LDO_REG7: supplied by vcc3v3_sys [ 3.820001] LDO_REG8: supplied by vcc3v3_sys [ 3.821421] SWITCH_REG1: supplied by vcc3v3_sys [ 3.822217] SWITCH_REG2: supplied by vcc3v3_sys [ 3.826460] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ 3.827546] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80094fc000 [ 3.829123] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80094fe000 [ 3.829931] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c [ 3.830875] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22 [ 3.831464] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl [ 3.832450] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back [ 3.833607] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80095c2000 [ 3.845066] fusb302 4-0022: port 0 probe success [ 3.845525] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80095c4000 [ 3.847739] IR NEC protocol handler initialized [ 3.848168] IR RC5(x/sz) protocol handler initialized [ 3.848648] IR RC6 protocol handler initialized [ 3.849076] IR JVC protocol handler initialized [ 3.849495] IR Sony protocol handler initialized [ 3.849936] IR SANYO protocol handler initialized [ 3.850368] IR Sharp protocol handler initialized [ 3.850864] IR MCE Keyboard/mouse protocol handler initialized [ 3.851432] IR XMP protocol handler initialized [ 3.852756] rockchip-rga ff680000.rga: HW Version: 0x03.02 [ 3.853662] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0 [ 3.854650] usbcore: registered new interface driver uvcvideo [ 3.855168] USB Video Class driver (1.1.1) [ 3.859054] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647 [ 3.861535] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: [email]dm-devel@redhat.com[/email] [ 3.862506] Bluetooth: Virtual HCI driver ver 1.5 [ 3.863096] Bluetooth: HCI UART driver ver 2.3 [ 3.863495] Bluetooth: HCI UART protocol H4 registered [ 3.863963] Bluetooth: HCI UART protocol LL registered [ 3.864417] Bluetooth: HCI UART protocol ATH3K registered [ 3.865004] usbcore: registered new interface driver bfusb [ 3.865577] usbcore: registered new interface driver btusb [ 3.866724] cpu cpu0: leakage=27 [ 3.867279] cpu cpu4: leakage=49 [ 3.867585] Failed to set cpu8 opp_info [ 3.868926] sdhci: Secure Digital Host Controller Interface driver [ 3.869473] sdhci: Copyright(c) Pierre Ossman [ 3.869883] Synopsys Designware Multimedia Card Interface Driver [ 3.871667] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 3.872343] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 3.872959] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 3.873528] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 3.874466] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 3.875332] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 3.875898] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 3.876980] platform fe310000.dwmmc: Driver dwmmc_rockchip requests probe deferral [ 3.878650] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 3.879359] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 3.879980] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 3.880578] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo [ 3.881489] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 3.882770] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 3.884144] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 3.885090] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 3.896631] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 3.907688] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized [ 3.908817] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.911651] sdhci-arasan fe330000.sdhci: No vmmc regulator found [ 3.912196] sdhci-arasan fe330000.sdhci: No vqmmc regulator found [ 3.918121] fusb302 4-0022: CC connected in 0 as UFP [ 3.938598] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ 3.941453] hidraw: raw HID events driver (C) Jiri Kosina [ 3.943494] usbcore: registered new interface driver usbhid [ 3.944023] usbhid: USB HID core driver [ 3.948277] usbcore: registered new interface driver snd-usb-audio [ 3.962289] platform rt5640-sound: Driver asoc-simple-card requests probe deferral [ 3.963090] platform hdmi-codec: Driver asoc-simple-card requests probe deferral [ 3.963866] platform spdif-sound: Driver asoc-simple-card requests probe deferral [ 3.969059] u32 classifier [ 3.969321] Netfilter messages via NETLINK v0.30. [ 3.969853] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 3.970827] ctnetlink v0.93: registering with nfnetlink. [ 3.971458] ip_set: protocol 6 [ 3.971759] IPVS: Registered protocols () [ 3.972321] IPVS: Connection hash table configured (size=4096, memory=64Kbytes) [ 3.973108] IPVS: Creating netns size=1592 id=0 [ 3.973580] IPVS: ipvs loaded. [ 3.974205] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.974854] Initializing XFRM netlink socket [ 3.976142] NET: Registered protocol family 10 [ 3.977884] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.978613] sit: IPv6 over IPv4 tunneling driver [ 3.979714] NET: Registered protocol family 17 [ 3.980135] NET: Registered protocol family 15 [ 3.980588] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 3.981728] Bridge firewalling registered [ 3.982358] Bluetooth: RFCOMM socket layer initialized [ 3.982516] mmc1: MAN_BKOPS_EN bit is not set [ 3.983248] Bluetooth: RFCOMM ver 1.11 [ 3.983611] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.984143] Bluetooth: HIDP socket layer initialized [ 3.984675] 8021q: 802.1Q VLAN Support v1.8 [ 3.985074] lib80211: common routines for IEEE802.11 drivers [ 3.985637] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 3.986543] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 3.987076] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6354 [ 3.987693] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 3.988324] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 3.989070] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0. [ 3.989873] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 3.990341] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 3.990847] [BT_RFKILL]: Enter rfkill_rk_init [ 3.991871] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83. [ 3.992649] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9. [ 3.993379] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90. [ 3.994121] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4. [ 3.994356] mmc1: new HS400 Enhanced strobe MMC card at address 0001 [ 3.995304] mmcblk1: mmc1:0001 AJNB4R 14.6 GiB [ 3.995640] mmcblk1boot0: mmc1:0001 AJNB4R partition 1 4.00 MiB [ 3.995970] mmcblk1boot1: mmc1:0001 AJNB4R partition 2 4.00 MiB [ 3.996238] mmcblk1rpmb: mmc1:0001 AJNB4R partition 3 4.00 MiB [ 3.996945] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 3.996950] trust: 0x000800000 -- 0x000c00000 (4 MB) [ 3.996955] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 3.996960] kernel: 0x001c00000 -- 0x003000000 (20 MB) [ 3.996965] backup: 0x003000000 -- 0x003400000 (4 MB) [ 3.996970] boot: 0x003400000 -- 0x3a3a00000 (14854 MB) [ 4.001718] mmcblk1: p1 p2 p3 p4 p5 p6 [ 4.001718] [BT_RFKILL]: Request irq for bt wakeup host [ 4.002613] [BT_RFKILL]: ** disable irq [ 4.003124] [BT_RFKILL]: bt_default device registered. [ 4.003740] Key type dns_resolver registered [ 4.004847] Registered cp15_barrier emulation handler [ 4.005338] Registered setend emulation handler [ 4.006986] Loading compiled-in X.509 certificates [ 4.009173] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned [ 4.013772] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0 [ 4.015442] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing power_model_simple. [ 4.017454] mali ff9a0000.gpu: Probed as mali0 [ 4.023872] vendor storage:20160801 ret = 0 [ 4.024063] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 4.024282] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3 [ 4.024472] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010 [ 4.024537] xhci-hcd xhci-hcd.6.auto: irq 229, io mem 0xfe800000 [ 4.024765] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.024772] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.024778] usb usb3: Product: xHCI Host Controller [ 4.024784] usb usb3: Manufacturer: Linux 4.4.77 xhci-hcd [ 4.024790] usb usb3: SerialNumber: xhci-hcd.6.auto [ 4.025443] hub 3-0:1.0: USB hub found [ 4.025480] hub 3-0:1.0: 1 port detected [ 4.025918] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 4.026105] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4 [ 4.026187] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 4.026321] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 4.026329] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.026336] usb usb4: Product: xHCI Host Controller [ 4.026341] usb usb4: Manufacturer: Linux 4.4.77 xhci-hcd [ 4.026347] usb usb4: SerialNumber: xhci-hcd.6.auto [ 4.026977] hub 4-0:1.0: USB hub found [ 4.027008] hub 4-0:1.0: 1 port detected [ 4.028917] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 4.028946] usb usb4: USB disconnect, device number 1 [ 4.052962] xhci-hcd xhci-hcd.6.auto: Host not halted after 16000 microseconds. [ 4.053611] xhci-hcd xhci-hcd.6.auto: Host controller not halted, aborting reset. [ 4.054293] xhci-hcd xhci-hcd.6.auto: USB bus 4 deregistered [ 4.054990] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 4.055462] usb usb3: USB disconnect, device number 1 [ 4.056566] xhci-hcd xhci-hcd.6.auto: USB bus 3 deregistered [ 4.063984] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 4.064783] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3 [ 4.065655] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010 [ 4.066476] xhci-hcd xhci-hcd.7.auto: irq 230, io mem 0xfe900000 [ 4.067230] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.067852] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.068496] usb usb3: Product: xHCI Host Controller [ 4.068939] usb usb3: Manufacturer: Linux 4.4.77 xhci-hcd [ 4.069419] usb usb3: SerialNumber: xhci-hcd.7.auto [ 4.070519] hub 3-0:1.0: USB hub found [ 4.070914] hub 3-0:1.0: 1 port detected [ 4.071671] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 4.072349] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4 [ 4.073120] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 4.074178] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 4.074793] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.075447] usb usb4: Product: xHCI Host Controller [ 4.075892] usb usb4: Manufacturer: Linux 4.4.77 xhci-hcd [ 4.076372] usb usb4: SerialNumber: xhci-hcd.7.auto [ 4.077432] hub 4-0:1.0: USB hub found [ 4.077814] hub 4-0:1.0: 1 port detected [ 4.080761] rockchip-dwc3 usb@fe800000: USB peripheral connected [ 4.082251] ehci-platform fe380000.usb: EHCI Host Controller [ 4.083013] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5 [ 4.083876] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000 [ 4.089602] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 4.090407] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.091021] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.091676] usb usb5: Product: EHCI Host Controller [ 4.092109] usb usb5: Manufacturer: Linux 4.4.77 ehci_hcd [ 4.092597] usb usb5: SerialNumber: fe380000.usb [ 4.093679] hub 5-0:1.0: USB hub found [ 4.094052] hub 5-0:1.0: 1 port detected [ 4.095479] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 4.096352] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6 [ 4.097187] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000 [ 4.142434] random: nonblocking pool is initialized [ 4.152866] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001 [ 4.153468] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.154124] usb usb6: Product: Generic Platform OHCI controller [ 4.154659] usb usb6: Manufacturer: Linux 4.4.77 ohci_hcd [ 4.155139] usb usb6: SerialNumber: fe3a0000.usb [ 4.156333] hub 6-0:1.0: USB hub found [ 4.156719] hub 6-0:1.0: 1 port detected [ 4.158753] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode. [ 4.159438] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller. [ 4.160056] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a [ 4.160615] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 4.161487] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 4.162313] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found [ 4.162874] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found [ 4.163910] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq [ 4.175706] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 4.187753] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized [ 4.200099] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok [ 4.207053] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input0 [ 4.209926] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok [ 4.212697] rockchip-spdif ff870000.spdif: Missing dma channel for stream: 0 [ 4.213322] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22 [ 4.213958] asoc-simple-card spdif-sound: ASoC: can't create pcm ff870000.spdif-dit-hifi :-22 [ 4.214726] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22 [ 4.215614] asoc-simple-card: probe of spdif-sound failed with error -22 [ 4.216716] [ 4.216855] ======================================================= [ 4.217413] ==== Launching Wi-Fi driver! (Powered by Rockchip) ==== [ 4.217999] ======================================================= [ 4.218568] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init. [ 4.219245] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 4.219676] [WLAN_RFKILL]: wifi turn on power. -1 [ 4.220094] RTL871X: module init start [ 4.220429] RTL871X: rtl8188eu v4.3.24_16705.20160509 [ 4.221066] usbcore: registered new interface driver rtl8188eu [ 4.221591] RTL871X: module init ret=0 [ 4.222984] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 4.223767] dhd_module_init: in [ 4.224059] ======== dhd_wlan_init_plat_data ======== [ 4.224512] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1 [ 4.224967] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1 [ 4.225432] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter [ 4.225931] dhd_wlan_init_gpio: host_oob_irq: 70 [ 4.226338] dhd_wlan_init_gpio: host_oob_irq_flags=0x414 [ 4.226830] dhd_wifi_platform_load: Enter [ 4.227465] Power-up adapter 'DHD generic adapter' [ 4.227955] wifi_platform_set_power = 1 [ 4.228303] ======== PULL WL_REG_ON(-1) HIGH! ======== [ 4.228769] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 4.229189] [WLAN_RFKILL]: wifi turn on power. -1 [ 4.429909] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:54:36 UTC (1358499276) [ 4.430609] wifi_platform_bus_enumerate device present 1 [ 4.430612] ======== Card detection to detect SDIO card! ======== [ 4.430616] mmc2:mmc host rescan start! [ 4.458733] u?
DDR Version 1.07 20161103
In …
我与你出现同样的问题,请问你解决了嘛?
已经准备进安卓系统桌面了,把不用的,你板上没有的设备删掉
否则系统报错太多就蹦了
我QQ254327173,欢迎加聊
