错误信息
FAILED: /bin/bash -c “PATH=out/host/linux-x86/bin/:$PATH MKBOOTIMG=out/host/linux-x86/bin/mkbootimg ./build/tools/releasetools/ota_from_target_files -v --block -p out/host/linux-x86 -k build/target/product/security/testkey out/target/product/rk3288/obj/PACKAGING/target_files_intermediates/rk3288-target_files-eng.zhaoni.zip out/target/product/rk3288/rk3288-ota-eng.zhaoni.zip”
unzipping target target-files…
running: unzip -o -q out/target/product/rk3288/obj/PACKAGING/target_files_intermediates/rk3288-target_files-eng.zhaoni.zip -d /tmp/targetfiles-OpSyD8
— target info —
blockimgdiff_versions = (str) 1,2,3,4
blocksize = (int) 131072
build.prop = (dict) {‘ro.udisk.visible’: ‘true’, ‘ro.product.usbfactory’: ‘rockchip_usb’, ‘debug.nfc.se’: ‘false’, ‘dalvik.vm.isa.arm.variant’: ‘cortex-a15’, ‘ro.product.cpu.abilist’: ‘armeabi-v7a,armeabi’, ‘ro.build.product’: ‘rk3288’, ‘ro.adb.secure’: ‘0’, ‘ro.rk.systembar.voiceicon’: ‘true’, ‘ro.build.id’: ‘NHG47K’, ‘ro.hwui.gradient_cache_size’: ‘1’, ‘dalvik.vm.stack-trace-file’: ‘/data/anr/traces.txt’, ‘ro.product.cpu.abilist32’: ‘armeabi-v7a,armeabi’, ‘dalvik.vm.isa.arm.features’: ‘default’, ‘dalvik.vm.heapmaxfree’: ‘8m’, ‘ro.build.fingerprint’: ‘Android/rk3288/rk3288:7.1.2/NHG47K/zhaoni05311010:userdebug/test-keys’, ‘ro.product.manufacturer’: ‘rockchip’, ‘ro.boot.noril’: ‘false’, ‘ro.hwui.layer_cache_size’: ‘48’, ‘ro.build.description’: ‘rk3288-userdebug 7.1.2 NHG47K eng.zhaoni.20180531.101057 test-keys’, ‘ro.product.ota.host’: ‘www.rockchip.com:2300’, ‘dalvik.vm.heapstartsize’: ‘16m’, ‘persist.tegra.nvmmlite ‘: ’ 1’, ‘ro.product.brand’: ‘Android’, ‘wifi.interface’: ‘wlan0’, ‘wifi.supplicant_scan_interval’: ‘15’, ‘ro.product.model’: ‘rk3288’, ‘ro.sf.fakerotation’: ‘false’, ‘ro.rk.screenoff_time’: ‘60000’, ‘debug.nfc.fw_download’: ‘false’, ‘dalvik.vm.heapsize’: ‘512m’, ‘sf.power.control’: ‘2073600’, ‘dalvik.vm.heaptargetutilization’: ‘0.75’, ‘ro.factory.storage_suppntfs’: ‘true’, ‘ro.build.host’: ‘sykean’, ‘ro.com.android.dataroaming’: ‘true’, ‘ro.build.version.security_patch’: ‘2017-04-05’, ‘ro.product.cpu.abilist64’: ‘’, ‘ro.com.widevine.cachesize’: ‘16777216’, ‘ro.product.locale’: ‘en-US’, ‘persist.sys.strictmode.visual’: ‘false’, ‘dalvik.vm.heapminfree’: ‘512k’, ‘ro.factory.hasUMS’: ‘false’, ‘ro.sf.hwrotation’: ‘0’, ‘ro.board.platform’: ‘rk3288’, ‘sys.hwc.compose_policy’: ‘6’, ‘persist.sys.usb.config’: ‘mtp,adb’, ‘ro.rk.install_non_market_apps’: ‘false’, ‘ro.expect.recovery_id’: ‘0x33d5febaa7fc23609795da9df7aa46e2756292a4000000000000000000000000’, ‘ro.config.enable.remotecontrol’: ‘false’, ‘ro.build.flavor’: ‘rk3288-userdebug’, ‘ro.ril.ecclist’: ‘112,911’, ‘ro.audio.monitorOrientation’: ‘true’, ‘ro.build.version.release’: ‘7.1.2’, ‘ro.build.version.codename’: ‘REL’, ‘net.bt.name’: ‘Android’, ‘ro.build.type’: ‘userdebug’, ‘ro.product.first_api_level’: ‘23’, ‘ro.config.alarm_alert’: ‘Alarm_Classic.ogg’, ‘ro.opengles.version’: ‘196610’, ‘testing.mediascanner.skiplist’: ‘/mnt/shell/emulated/Android/’, ‘ro.rk.systembar.tabletUI’: ‘false’, ‘ro.hwui.text_small_cache_height’: ‘1024’, ‘ro.build.display.id’: ‘rk3288-userdebug 7.1.2 NHG47K eng.zhaoni.20180531.101057 test-keys’, ‘ro.hwui.texture_cache_flushrate’: ‘0.4’, ‘ro.config.ringtone’: ‘Ring_Synth_04.ogg’, ‘ro.rk.displayd.enable’: ‘false’, ‘ro.rk.def_brightness’: ‘200’, ‘ro.carrier’: ‘unknown’, ‘ro.rk.screenshot_enable’: ‘true’, ‘ro.product.board’: ‘rk30sdk’, ‘ro.build.version.preview_sdk’: ‘0’, ‘sys.resolution.changed’: ‘false’, ‘ro.build.date’: ‘2018\xe5\xb9\xb4 05\xe6\x9c\x88 31\xe6\x97\xa5 \xe6\x98\x9f\xe6\x9c\x9f\xe5\x9b\x9b 10:10:57 CST’, ‘ro.factory.without_battery’: ‘false’, ‘ro.factory.hasGPS’: ‘true’, ‘ro.kernel.android.checkjni’: ‘0’, ‘ro.build.date.utc’: ‘1527732657’, ‘keyguard.no_require_sim’: ‘true’, ‘ro.safemode.disabled’: ‘true’, ‘ro.factory.tool’: ‘0’, ‘sys.status.hidebar_enable’: ‘false’, ‘ro.build.version.all_codenames’: ‘REL’, ‘dalvik.vm.lockprof.threshold’: ‘500’, ‘ro.rk.LowBatteryBrightness’: ‘false’, ‘ro.hwui.text_small_cache_width’: ‘1024’, ‘ro.product.cpu.abi’: ‘armeabi-v7a’, ‘camera2.portability.force_api’: ‘1’, ‘ro.target.product’: ‘tablet’, ‘ro.product.name’: ‘rk3288’, ‘ro.hwui.drop_shadow_cache_size’: ‘6’, ‘ro.build.version.base_os’: ‘’, ‘ro.rk.hdmi_enable’: ‘true’, ‘persist.sys.ui.hw’: ‘true’, ‘ro.wifi.channels’: ‘’, ‘ro.hwui.r_buffer_cache_size’: ‘8’, ‘ro.tether.denied’: ‘false’, ‘ro.build.characteristics’: ‘tablet’, ‘ro.rk.bt_enable’: ‘true’, ‘ro.rk.flash_enable’: ‘true’, ‘ril.function.dataonly’: ‘1’, ‘ro.hwui.text_large_cache_width’: ‘2048’, ‘ro.build.version.incremental’: ‘eng.zhaoni.20180531.101057’, ‘ro.hwui.disable_scissor_opt’: ‘true’, ‘ro.hwui.text_large_cache_height’: ‘1024’, ‘ro.product.version’: ‘1.0.0’, ‘ro.build.tags’: ‘test-keys’, ‘ro.build.version.sdk’: ‘25’, ‘ro.rk.MassStorage’: ‘false’, ‘ro.enable.optee’: ‘true’, ‘ro.product.cpu.abi2’: ‘armeabi’, ‘ro.build.user’: ‘zhaoni’, ‘ro.hwui.path_cache_size’: ‘32’, ‘ro.rk.homepage_base’: ‘http://www.google.com/webhp?client={CID}&source=android-home’, ‘ro.product.device’: ‘rk3288’, ‘ro.default.size’: ‘100’, ‘ro.hwui.texture_cache_size’: ‘72’, ‘persist.sys.dalvik.vm.lib.2’: ‘libart.so’, ‘sys.rkadb.root’: ‘0’, ‘sys.wallpaper.rgb565’: ‘0’, ‘ro.rksdk.version’: ‘RK30_ANDROID7.1.2-SDK-v1.00.00’, ‘dalvik.vm.heapgrowthlimit’: ‘192m’, ‘ro.config.notification_sound’: ‘pixiedust.ogg’}
cache_size = (int) 69206016
default_system_dev_certificate = (str) build/target/product/security/testkey
extfs_sparse_flag = (str) -s
fs_type = (str) ext4
fstab = (dict) {’/metadata’: <common.Partition object at 0x7fda65fddad0>, ‘/mnt/external_sd’: <common.Partition object at 0x7fda65e30050>, ‘/uboot’: <common.Partition object at 0x7fda65fddb10>, ‘/cache’: <common.Partition object at 0x7fda65fdd950>, ‘/data’: <common.Partition object at 0x7fda65fdd750>, ‘/system’: <common.Partition object at 0x7fda65e30110>, ‘/trust’: <common.Partition object at 0x7fda65fdd550>, ‘/radical_update’: <common.Partition object at 0x7fda65fdde10>, ‘/baseparamer’: <common.Partition object at 0x7fda65fdd5d0>, ‘/recovery’: <common.Partition object at 0x7fda65fdd450>, ‘/charge’: <common.Partition object at 0x7fda65fddf90>, ‘/custom’: <common.Partition object at 0x7fda65fdd6d0>, ‘/resource’: <common.Partition object at 0x7fda65fddc10>, ‘/parameter’: <common.Partition object at 0x7fda65fdd7d0>, ‘/backup’: <common.Partition object at 0x7fda65fdd3d0>, ‘/cust’: <common.Partition object at 0x7fda65fdddd0>, ‘/mnt/internal_sd’: <common.Partition object at 0x7fda65e301d0>, ‘/boot’: <common.Partition object at 0x7fda65fddd90>, ‘/misc’: <common.Partition object at 0x7fda65fddd50>}
fstab_version = (int) 2
mkbootimg_args = (str)
mkbootimg_version_args = (str) --os_version 7.1.2 --os_patch_level 2017-04-05
multistage_support = (str) 1
recovery_api_version = (int) 2
recovery_as_boot = (str)
recovery_mount_options = (str) ext4=max_batch_time=0,commit=1,data=ordered,barrier=1,errors=panic,nodelalloc
selinux_fc = (str) /tmp/targetfiles-OpSyD8/META/file_contexts.bin
squashfs_sparse_flag = (str) -s
system_size = (int) 704643072
tool_extensions = (str) device/rockchip/common
update_rename_support = (str) 1
use_set_metadata = (str) 1
userdata_fs_type = (str) f2fs
vendor_fs_type = (str) ext4
vendor_size = (int) 52428800
(using device-specific extensions from target_files)
loaded device-specific extensions from /tmp/targetfiles-OpSyD8/META/releasetools.py
using prebuilt recovery.img from IMAGES…
using system.img from target-files
Total of 172032 4096-byte output blocks in 4097 input chunks.
Finding transfers…
Generating digraph…
Finding vertex sequence…
Reversing backward edges…
0/0 dependencies (0.00%) were violated; 0 source blocks stashed.
Improving vertex order…
Revising stash size…
Total 0 blocks (0 bytes) are packed as new blocks due to insufficient cache size.
Reticulating splines…
528494592 528494592 (100.00%) new __DATA 0-547 549-2258 2260-2356 2358-2359 2361 2363-4051 4053 4055 4057 4059-4063 4065 4067-4093 4095 4097-8333 8335 8337 8339 8341-8688 8690 8692-9698 9700 9702-10037 10039 10041-10077 10079 10081-10304 10306 10308-10669 10671 10673 10675 10677-10678 10680 10682 10684 10686-10807 10809 10811-10816 10818 10820 10822 10824-10831 10833 10835-11010 11012 11014 11016 11018-11143 11145 11147-11699 11701 11703 11705-11706 11708 11710-11981 11983 11985-12023 12025 12027-12114 12116 12118-12163 12165 12167-12172 12174 12176-12181 12183 12185-12187 12189 12191-12240 12242 12244-12251 12253 12255-23456 23458-23459 23461-23465 23467 23469-23474 23476-23514 23516 23518 23520-23525 23527-23536 23538-23543 23545-23555 23557-23561 23563-23564 23566 23568-23570 23572-23584 23586-23594 23596 23598-23601 23603 23605-23609 23611-23827 23829-23832 23834-23840 23842-23853 23855-23861 23863 23865-23869 23871-23882 23884-23916 23918-23936 23938-23941 23943-23953 23955-23988 23990 23992-24008 24010-24015 24017-24058 24060-24066 24068-24108 24110-24118 24120-24131 24133-24278 24280 24282-24289 24291-24295 24297 24299-24402 24404-24413 24415-24423 24425 24427 24429 24431-24457 24459-24470 24472-24526 24528-24589 24591-24651 24653 24655-24695 24697-24829 24831-24997 24999-25020 25022-25026 25028-25035 25037-25165 25167-25320 25322-25327 25329-25337 25339-25356 25358-25359 25361-25368 25370-25374 25376-25385 25387-25527 25529 25531-25535 25537-25543 25545-25549 25551-25555 25557-25563 25565-25573 25575-25589 25591-25609 25611 25613-25619 25621-25625 25627-25672 25674-25699 25701-25710 25712-25749 25751-25768 25770-25780 25782-25792 25794 25796-25802 25804-25855 25857-25859 25861-25862 25864-25865 25867 25869 25871 25873 25875-25883 25885-25888 25890-25934 25936-25939 25941-25944 25946 25948-25960 25962-25966 25968-25972 25974-25978 25980-25984 25986-26011 26013-26020 26022-26027 26029-26032 26034-26039 26041-26046 26048 26050-26080 26082-26127 26129 26131-26145 26147-26151 26153-26154 26156-26177 26179-26186 26188 26190-26194 26196-26200 26202-26206 26208-26229 26231-26300 26302-26306 26308-26312 26314-26319 26321-26332 26334-26339 26341-26342 26344-26359 26361-26365 26367-26472 26474-26478 26480 26482 26484-26505 26507-26806 26808-26809 26811 26813-26826 26828-26840 26842-26923 26925-27006 27008-27088 27090-27166 27168-27233 27235-27315 27317-27397 27399-27479 27481-27531 27533-27613 27615-27691 27693-27769 27771-27847 27849-27925 27927-28003 28005-28081 28083-28159 28161-28237 28239-28315 28317-28395 28397-28477 28479-28560 28562-28643 28645-28726 28728-28808 28810-28891 28893-28974 28976-29057 29059-29140 29142-29223 29225-29306 29308-29389 29391-29472 29474-29554 29556-29637 29639-29720 29722-29803 29805-29886 29888-29969 29971-30052 30054 30056-30106 30108-30109 30111 30113 30115 30117 30119 30121 30123 30125-30129 30131 30133-30215 30217-30221 30223 30225-30232 30234-30247 30249-30258 30260-30276 30278-30292 30294-30308 30310 30312 30314 30316 30318-30327 30329-30335 30337-30343 30345-30351 30353-30361 30363-30376 30378-30381 30383-30387 30389-30399 30401-30414 30416-30425 30427-30435 30437-30453 30455-30504 30506-30555 30557-30606 30608-30659 30661-30710 30712-30763 30765-30823 30825-30883 30885-30940 30942-31000 31002-31060 31062-31118 31120-31171 31173-31228 31230-31280 31282-31328 31330-31384 31386-31440 31442-31497 31499-31557 31559-31614 31616-31674 31676-31727 31729-31787 31789-31884 31886-31983 31985-32082 32084-32137 32139-32197 32199-32296 32298-32395 32397-32486 32488-32599 32601-32701 32703-32712 32714 32716 32718 32720 32722 32724 32726 32728 32730 32732 32734 32736 32738 32740 32742 32744 32746 32748 32750 32752 32754 32756 32758 32760 32762 32764 32768-32769 32817-32818 65536-65537 65986-66313 66315-66560 66562-66617 66619-66669 66671-66692 66694-67381 67383-67410 67412-68853 68855-68862 68864-68944 68946-68968 68970-69033 69035-69051 69053-69085 69087-69092 69094-69099 69101-69108 69110-69124 69126-69150 69152-69162 69164-69275 69277-69332 69334-69339 69341-69430 69432-69625 69627-69655 69657-69676 69678-69686 69688-69691 69693-69834 69836-70026 70028-70065 70067-70659 70661-70683 70685-70744 70746-70755 70757-70821 70823-70996 70998-71003 71005-71209 71211-71297 71299-71390 71392-71691 71693-71779 71781-71790 71792-71964 71966-72207 72209-72233 72235-72238 72240-72246 72248-72251 72253-72390 72392-72404 72406-72412 72414-72440 72442-72450 72452-72457 72459-72464 72466-72524 72526-72567 72569-72591 72593-72603 72605-72609 72611-72618 72620-72625 72627-72635 72637-72642 72644-72689 72691-72708 72710-72716 72718-74457 74459-74587 74589-74623 74625-74629 74631-74741 74743-74749 74751-74757 74759-74768 74770-74868 74870-74873 74875-74885 74887-74965 74967-75201 75203-75207 75209-75244 75246-75371 75373-75592 75594-75985 75987-76263 76265-76272 76274-76290 76292-76325 76327-76393 76395-76408 76410-76413 76415-76428 76430-76732 76734-76775 76777-76804 76806-76926 76928-76931 76933-76943 76945-76953 76955-76969 76971-77202 77204-77208 77210-77213 77215-77218 77220-77280 77282-77297 77299-77308 77310-77343 77345-77380 77382-77394 77396-77409 77411-77415 77417-77439 77441-77456 77458-77462 77464-77475 77477-77500 77502-77533 77535-77543 77545-77743 77745-77827 77829-77835 77837-77852 77854-77860 77862-77869 77871-77889 77891-78040 78042-78052 78054-78057 78059-78083 78085-78099 78101-78126 78128-78390 78392-78415 78417-78418 78420-78424 78426-78433 78435-78443 78445-78454 78456-78460 78462-78472 78474-78480 78482-78489 78491-78494 78496-78515 78517-78576 78578-80682 80684-80728 80730-80742 80744-80800 80802-82011 82013-82017 82019-82024 82026-82046 82048-82056 82058-83229 83231-83240 83242-83277 83279-83315 83317-83320 83322-83328 83330-83334 83336-83340 83342-83512 83514-83541 83543-83557 83559-83562 83564-83579 83581-83591 83593-83604 83606-83616 83618-83659 83661-83681 83683-83687 83689-83903 83905-83982 83984-84125 84127-84271 84273-84287 84289-84587 84589-84594 84596-84631 84633-84751 84753-84756 84758-84759 84761-84764 84766-87201 87203-87216 87218-87250 87252-87269 87271-87296 87298-87302 87304-87307 87309-88256 88258-88263 88265-88291 88293-88297 88299-88384 88386-88396 88398-88413 88415-88430 88432-88439 88441-88447 88449-88572 88574-88612 88614-88978 88980-88995 88997-89005 89007-89010 89012-89046 89048-89051 89053-89092 89094-89143 89145-89220 89222-89304 89306-89336 89338-89357 89359-89394 89396-89481 89483-89568 89570-89605 89607-89613 89615-89624 89626-89749 89751-89771 89773-89804 89806-89835 89837-89877 89879-89887 89889-89895 89897-89904 89906-90005 90007-90130 90132-90199 90201-90206 90208-90213 90215-90308 90310-90313 90315-90319 90321-90324 90326-90334 90336-90340 90342-90349 90351-90358 90360-90365 90367-90426 90428-90450 90452-90473 90475-90480 90482-90506 90508-90687 90689-90719 90721-90734 90736-90758 90760-90904 90906-91108 91110-91114 91116-91120 91122-91157 91159-91206 91208-91222 91224-91229 91231-91254 91256 91258 91260-91264 91266-91270 91272-91276 91278 91280-91315 91317-91354 91356 91358-91362 91364-91367 91369-91372 91374-91378 91380-91384 91386-91389 91391-91394 91396 91398-91404 91406-91423 91425-91429 91431-91434 91436-91440 91442-91451 91453-91457 91459 91461-91465 91467-91468 91470-91472 91474 91476 91478 91480 91482-91485 91487-91488 91490-91495 91497-91499 91501-91507 91509-91511 91513-91541 91543-91555 91557-91580 91582-91588 91590-91618 91620-91655 91657-91692 91694-91719 91721-91764 91766-91789 91791-91834 91836-91846 91848-91854 91856-91883 91885-91910 91912-91939 91941-91952 91954 91956-91958 91960-91961 91963-91964 91966-91968 91970-91972 91974-91980 91982-91983 91985-91988 91990-91998 92000-92003 92005-92009 92011-92014 92016-92020 92022-92024 92026-92029 92031-92034 92036-92042 92044-92048 92050-92052 92054-92058 92060-92063 92065-92067 92069-92073 92075-92078 92080-92083 92085-92087 92089-92094 92096-92098 92100-92104 92106-92111 92113-92115 92117-92126 92128-92129 92131-92135 92137-92140 92142-92156 92158-92160 92162-92165 92167-92171 92173-92177 92179-92183 92185-92189 92191-92194 92196-92197 92199-92204 92206-92211 92213-92218 92220-92223 92225-92231 92233-92238 92240-92242 92244-92249 92251-92256 92258-92264 92266-92268 92270-92279 92281-92283 92285-92295 92297-92299 92301-92304 92306-92310 92312-92316 92318-92323 92325-92332 92334-92338 92340-92346 92348-92351 92353-92354 92356-92359 92361-92365 92367-92371 92373-92379 92381-92387 92389-92391 92393-92400 92402 92404-92410 92412-92418 92420-92425 92427-92482 92484-92505 92507-92513 92515-92523 92525-92531 92533-92540 92542-92553 92555-92565 92567-92576 92578-92589 92591-92598 92600-92607 92609-92618 92620-92629 92631-92638 92640-92647 92649-92652 92654-92660 92662-92671 92673-92682 92684-92693 92695-92745 92747-92754 92756-92763 92765-92779 92781-92784 92786-92798 92800-92807 92809-92851 92853-92865 92867-92882 92884-92892 92894-92901 92903-92930 92932-92943 92945-92954 92956-92968 92970-92979 92981-92991 92993-93006 93008-93018 93020-93036 93038-93043 93045-93048 93050-93090 93092-93101 93103-93111 93113-93123 93125-93134 93136-93142 93144-93152 93154-93164 93166-93176 93178-93181 93183-93191 93193-93201 93203-93212 93214-93220 93222-93229 93231-93244 93246-93273 93275-93284 93286-93307 93309-93366 93368-93381 93383-93387 93389-93432 93434-93446 93448-93462 93464-93478 93480-93485 93487-93499 93501-93511 93513-93524 93526-93533 93535-93545 93547-93556 93558-93584 93586-93663 93665-93675 93677-93686 93688-93698 93700-93707 93709-93730 93732-93738 93740-93749 93751-93759 93761-93778 93780-93822 93824-93832 93834-93845 93847-93853 93855-93890 93892-93937 93939-93946 93948-93952 93954-93961 93963-93982 93984-93989 93991 93993-93994 93996-93997 93999-94000 94002-94004 94006-94007 94009-94010 94012-94013 94015-94017 94019-94022 94024-94025 94027-94029 94031-94032 94034-94035 94037-94038 94040-94042 94044-94045 94047-94049 94051 94053 94055-94111 94113 94115-94155 94157 94159-94243 94245 94247-95895 95897 95899-96036 96038 96040-96041 96043 96045-96050 96052 96054 96056 96058-96404 96406 96408-96870 96872 96874-97018 97020 97022-97024 97026 97028-97039 97041 97043-97048 97050 97052-97105 97107 97109-97326 97328 97330-97373 97375 97377-97386 97388 97390-97422 97424 97426 97428 97430-97450 97452 97454-97458 97460 97462 97464-97465 97467 97469-97471 97473 97475 97477-97517 97519 97521-97523 97525 97527-97583 97585 97587-97595 97597 97599 97601 97603 97605 97607 97609 97611 97613-97666 97668 97670-97690 97692 97694-97719 97721-98271 98273 98275 98277 98279 98281 98283 98285 98287 98289 98291 98293 98295 98297-98298 98300 98304-98305 98353-98354 98803-98914 98916-99048 99050-99182 99184-99316 99318-99420 99422-99524 99526-99624 99626-99724 99726-99821 99823-99914 99916-100007 100009-100100 100102-100223 100225-100346 100348-100465 100467-100611 100613-100757 100759-100903 100905-101041 101043-101179 101181-101316 101318 101320 101322 101324 101326-101334 101336-101349 101351 101353-101359 101361 101363-101374 101376 101378-101389 101391 101393-101404 101406 101408 101410-101417 101419 101421-101433 101435 101437-101448 101450 101452-101468 101470 101472-101488 101490-101506 101508-101525 101527-101543 101545 101547-101564 101566 101568-101578 101580 101582-101591 101593 101595-101604 101606 101608-101617 101619 101621-101634 101636 101638-101648 101650-101669 101671 101673 101675 101677 101679 101681-101685 101687 101689 101691-101692 101694 101696 101698 101700 101702 101704 101706 101708 101710 101712 101714 101716 101718 101720 101722 101724 101726 101728 101730 101732 101734 101736 101738 101740 101742 101744 101746 101748 101750 101752-101754 101756-101757 101759 101761-101762 101764 101766-101772 101774 101776 101778 101780 101782 101784 101786 101788 101790 101792 101794 101796 101798 101800-101802 101804-101805 101807 101809 101811 101813 101815-101818 101820 101822-101823 101825-101862 101864 101866-102322 102324 102326 102328 102330 102332 102334-102335 102337-102338 102340-102341 102343-102344 102346 102348-102349 102351-102352 102354-102355 102357 102359-102360 102362-102363 102365-102366 102368-102369 102371-102372 102374-102375 102377-102378 102380-102381 102383-102384 102386-102387 102389-102390 102392-102393 102395-102397 102399-102400 102402-102403 102405-102406 102408-102409 102411-102412 102414 102416 102418-102419 102421-102422 102424-102426 102428-102430 102432-102433 102435-102436 102438-102439 102441-102442 102444-102445 102447-102448 102450-102451 102453-102454 102456-102457 102459-102461 102463-102464 102466-102467 102469-102470 102472-102473 102475-102476 102478-102479 102481-102482 102484-102485 102487-102488 102490-102491 102493-102494 102496-102497 102499 102501-102502 102504-102505 102507-102508 102510-102511 102513-102514 102516 102518-102519 102521-102522 102524-102525 102527-102528 102530-102531 102533-102534 102536-102537 102539 102541-102542 102544-102545 102547-102548 102550-102551 102553-102554 102556-102557 102559-102560 102562-102563 102565-102566 102568-102569 102571-102572 102574-102575 102577-102578 102580-102581 102583-102584 102586 102588-102589 102591-102592 102594-102595 102597-102598 102600 102602-102603 102605-102606 102608-102609 102611-102612 102614-102615 102617-102618 102620-102621 102623-102624 102626-102627 102629-102631 102633-102634 102636-102637 102639-102640 102642-102643 102645-102646 102648 102650-102651 102653-102654 102656-102657 102659-102660 102662-102663 102665 102667-102668 102670-102671 102673-102674 102676-102677 102679-102680 102682 102684-102685 102687-102688 102690-102691 102693-102694 102696-102697 102699 102701-102702 102704-102705 102707-102708 102710-102711 102713-102714 102716 102718-102719 102721-102722 102724-102725 102727-102728 102730 102732-102733 102735-102736 102738-102739 102741-102742 102744-102745 102747-102748 102750-102751 102753-102754 102756-102757 102759-102760 102762 102764-102765 102767-102768 102770-102771 102773-102774 102776-102777 102779-102780 102782-102783 102785-102786 102788-102789 102791 102793 102795-102806 102808-102809 102811 102813 102815 102817 102819 102821 102823 102825 102827 102829 102831 102833 102835 102837 102839 102841 102843 102845 102847 102849 102851 102853 102855 102857 102859 102861 102863 102865 102867 102869 102871 102873 102875 102877 102879 102881 102883 102885 102887 102889 102891 102893 102895 102897 102899 102901 102903 102905 102907 102909 102911 102913 102915 102917 102919 102921 102923 102925 102927 102929 102931 102933 102935 102937 102939 102941 102943 102945 102947 102949 102951 102953 102955 102957 102959 102961 102963 102965 102967 102969 102971 102973 102975 102977 102979 102981 102983 102985 102987 102989 102991 102993 102995 102997 102999 103001 103003 103005 103007 103009 103011 103013 103015 103017 103019 103021 103023 103025 103027 103029 103031 103033 103035 103037 103039 103041 103043 103045 103047 103049 103051 103053 103055 103057 103059 103061 103063 103065 103067 103069 103071 103073 103075 103077 103079 103081 103083 103085 103087 103089 103091 103093 103095 103097 103099 103101 103103 103105 103107 103109 103111 103113 103115 103117 103119 103121 103123 103125 103127 103129 103131 103133 103135 103137 103139 103141 103143 103145 103147 103149 103151 103153 103155 103157 103159 103161 103163 103165 103167 103169 103171 103173 103175 103177 103179 103181 103183 103185 103187 103189 103191 103193 103195 103197 103199 103201 103203 103205 103207 103209 103211 103213 103215 103217 103219 103221 103223 103225 103227 103229 103231 103233 103235 103237 103239 103241 103243 103245 103247 103249 103251 103253 103255 103257 103259 103261 103263 103265 103267 103269 103271 103273 103275 103277 103279 103281 103283 103285 103287 103289 103291 103293 103295 103297 103299 103301 103303 103305 103307 103309 103311 103313 103315 103317 103319 103321 103323 103325 103327 103329 103331 103333 103335 103337 103339 103341 103343 103345 103347 103349 103351 103353 103355 103357 103359 103361 103363 103365 103367 103369 103371 103373 103375 103377 103379 103381 103383 103385 103387 103389 103391 103393 103395 103397 103399 103401 103403 103405 103407-103410 103412-103413 103415-103416 103418-103427 103429-103443 103445-103461 103463-103491 103493-103521 103523-103549 103551-104995 104997-105025 105027-105055 105057-105085 105087-105115 105117-105120 105122-105125 105127-105134 105136-105168 105170-105173 105175-105199 105201-105225 105227-105252 105254-105280 105282-105283 105285-105286 105288-109847 109849-109860 109862-109867 109869-109874 109876-109884 109886-109891 109893-109925 109927-109960 109962-109991 109993-110023 110025-110060 110062-110096 110098-110102 110104-110108 110110-110113 110115-110143 110145-110174 110176-110203 110205-110233 110235-110242 110244-110251 110253-110260 110262-110269 110271-110272 110274-110278 110280-110284 110286-110295 110297-110316 110318-110338 110340-110359 110361-110380 110382-110383 110385-110393 110395-110403 110405-110413 110415-110424 110426-110433 110435-110442 110444-110451 110453-110460 110462-110486 110488-110490 110492-110493 110495-110508 110510-110523 110525-110538 110540-110553 110555-110558 110560-110563 110565-110592 110594-110620 110622-110648 110650-110675 110677-110702 110704-110708 110710-110713 110715-110716 110718-110738 110740-110760 110762-110781 110783-110802 110804-110805 110807-110811 110813-110850 110852-110891 110893-110895 110897-110900 110902-110972 110974-110977 110979-110990 110992-110993 110995-110997 110999-111010 111012-111015 111017-111025 111027-111035 111037-111045 111047-111055 111057-111083 111085-111112 111114-111141 111143-111170 111172-111175 111177-111180 111182-111186 111188-111193 111195-111199 111201-111206 111208-111299 111301-111399 111401-111404 111406-111421 111423-111453 111455-111515 111517-111581 111583-111643 111645-111705 111707-111781 111783-111863 111865-111939 111941-112021 112023-112103 112105-112180 112182-112263 112265-112339 112341-112421 112423-112497 112499-112573 112575-112654 112656-112729 112731-112811 112813-112893 112895-112969 112971-113052 113054-113128 113130 113132-113139 113141-113160 113162-113297 113299 113301-113303 113305-113434 113436 113438 113440-113443 113445-113446 113448 113450 113452-113486 113488-113490 113492-113494 113496-113891 113893-114339 114341 114343-114346 114348-114851 114853-123016 123018-124615 124617-124618 124620 124622-124633 124635-124636 124638-124644 124646-124647 124649-124661 124663-124707 124709-124762 124764-124768 124770-124771 124773-125541 125543-125544 125546 125548-125549 125551 125553-125754 125756-125767 125769-125790 125792-125808 125810-125919 125921-125922 125924-125925 125927 125929 125931 125933-125947 125949 125951 125953 125955-125962 125964-125968 125970-125978 125980-125985 125987-125992 125994-126017 126019-126329 126331-126656 126658-126734 126736-126740 126742-126747 126749-126753 126755-126834 126836-126839 126841-126869 126871-126879 126881-126890 126892-126902 126904-126916 126918-126927 126929-126943 126945-126959 126961-126970 126972-126986 126988-126997 126999-127009 127011-127020 127022-127064 127066-127076 127078-127094 127096-127115 127117-127136 127138-127159 127161-127170 127172-127182 127184-127187 127189-127192 127194-127218 127220-127223 127225-127251 127253-127257 127259-127314 127316-127324 127326-127342 127344-127360 127362-130292 130294-130419 130421-130425 130427-130431 130433-130443 130445-130560 130562-130600 130602-130659 130661-130721 130723-130727 130729-130734 130736-131027 131029-131034 131036-131056 131058-131063 131065-131068 131072-131073 131522-132801 132803-140835 140837-141806 141808-143090 143092-146013 146015-147685 147687-148422 148424-148579 148581-148688 148690-148832 148834-148934 148936-149125 149127-149285 149287-149349 149351-149498 149500-149703 149705-149798 149800-149953 149955-150016 150018-150026 150028-150054 150056 150058-150083 150085 150087-150113 150115 150117-150128 150130 150132-150139 150141 150143-150146 150148 150150-150155 150157 150159 150161 150163-150164 150166 150168-150176 150178 150180 150182 150184 150186 150188 150190 150192-150269 150271 150273 150275 150277 150279 150281 150283 150285-150286 150288 150290 150292 150294-150329 150331 150333-150368 150370 150372 150374 150376 150378 150380 150382-150383 150385-150386 150388 150390 150392 150394 150396 150398 150400 150402 150404 150406 150408-155828 155830 155832 155834 155836 155838 155840-155843 155845-155847 155849-155852 155854-155857 155859-155862 155864 155866 155868-155870 155872 155874 155876 155878 155880 155882 155884 155886 155888 155890 155892 155894 155896 155898 155900 155902 155904 155906 155908 155910 155912 155914 155916 155918 155920 155922 155924 155926 155928 155930 155932 155934 155936 155938 155940 155942 155944 155946-156017 156019-156361 156363 156365 156367-156370 156372-156376 156378 156380-156502 156504 156506 156508-156512 156514 156516-156598 156600 156602-156654 156656-156661 156663-156719 156721-156725 156727-156731 156733-156744 156746-156751 156753-156757 156759-156933 156935 156937-156943 156945-156949 156951-156955 156957-156961 156963-156968 156970-156979 156981-157038 157040-157051 157053 157055 157057-157085 157087-157091 157093-157098 157100-157104 157106-157112 157114-157118 157120-157124 157126-157130 157132-157207 157209-157226 157228-157302 157304-157308 157310 157312-157317 157319-157524 163840-163841 163889-163890 164339-167026 167028-167029 167031 167033 167035 167037-167046 167048 167050-167530 167532 167534 167536 167538-167541 167543 167545-167549 167551 167553-168204 168206 168208-170740 170742 170744 170746 170748-170765 170767 170769-170858 170860 170862-170863 170865 170867-171961 171963 171965-172022 172024 172026 172028 172030
max stashed blocks: 0 (0 bytes), limit: 55364812 bytes (0.00%)
using prebuilt boot.img from IMAGES…
using vendor.img from target-files
Total of 12800 4096-byte output blocks in 50 input chunks.
Finding transfers…
Generating digraph…
5746688 5746688 (100.00%) new __DATA 0-1234 1236-1237 1239 1241 1243-1247 1249 1251 1253 1255 1257-1302 1304-1308 1310-1314 1316-1322 1324-1328 1330-1338 1340-1343 1345-1353 1355-1378 1380-1402 1404-1409 1411 1413-1423
File “./build/tools/releasetools/ota_from_target_files”, line 2206, in
main(sys.argv[1:])
File “./build/tools/releasetools/ota_from_target_files”, line 2162, in main
WriteFullOTAPackage(input_zip, output_zip)
File “./build/tools/releasetools/ota_from_target_files”, line 728, in WriteFullOTAPackage
vendor_diff = common.BlockDifference(“vendor”, vendor_tgt)
File “/home/zhaoni/workspace/rk3288/king_rp_3288_7.1/build/tools/releasetools/common.py”, line 1397, in init
_, self.device = GetTypeAndDevice(“/” + partition, OPTIONS.info_dict)
File “/home/zhaoni/workspace/rk3288/king_rp_3288_7.1/build/tools/releasetools/common.py”, line 1618, in GetTypeAndDevice
return (PARTITION_TYPES[fstab[mount_point].fs_type],
KeyError: ‘/vendor’
ninja: build stopped: subcommand failed.
build/core/ninja.mk:148: recipe for target ‘ninja_wrapper’ failed
make: *** [ninja_wrapper] Error 1
