按照此文档http://www.t-firefly.com/doc/product/info/id/360.html
一步一步操作的谢谢!
./build/mk-uboot.sh roc-rk3328-cc
Building U-boot for roc-rk3328-cc board!
Using roc-rk3328-cc_defconfig
input in flex scanner failed
scripts/kconfig/Makefile:121: recipe for target ‘roc-rk3328-cc_defconfig’ failed
make[2]: *** [roc-rk3328-cc_defconfig] Error 2
Makefile:478: recipe for target ‘roc-rk3328-cc_defconfig’ failed
make[1]: *** [roc-rk3328-cc_defconfig] Error 2
Makefile:460: recipe for target ‘__build_one_by_one’ failed
make: *** [__build_one_by_one] Error 2
自己确认一下环境安装是否有问题吧。 我们测试没有问题, 无法重现你的问题。
你好, 我的uboot起不来是怎么回事呢?
log显示 DRAM的大小都读取不到?
DDR version 1.06 20170424
DDR3
786MHz
ddrconfig:6
Boot1 Release Time: 2017-05-18, version: 2.43
ChipType = 0x11, 125
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=14910MB
FwPartOffset=2000 , 2000
SdmmcInit=0 2
StorageInit ok = 20770
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
LoadTrustBL
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xa7fec
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):f947c7e
NOTICE: BL31: Built : 09:28:45, May 31 2017
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: SPSR = 0x3c9
U-Boot 2017.09-gc58a816-dirty (Oct 19 2018 - 00:39:34 +0800)
Model: Firefly ROC-RK3328-CC
DRAM:
kernel 目录 下 编译 内核 如何编译的啊 ? 不是 build 目录下 的 mk-kernel
