下载使用的是Firefly-rk3399_xubuntu16.04_EC20_20180614.img
烧录后发现起不来,然后在解包得到分区文件,烧录自己的内核,发现也是一样的现象,起不来,还请帮忙看看是哪里出了问题
DDR Version 1.07 20161103
Channel 0: DDR3, 666MHz
Channel 1: DDR3, 666MHz
256B stride
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1838
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 62317
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 77884
LoaderFlag2: 0x0
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE: BL31: v1.2(debug):b995f80
NOTICE: BL31: Built : 16:53:56, Nov 7 2016
INFO: boot cpu mask: 0
INFO: Vesion: 2016.0.01
INFO: plat_rockchip_pmu_init(1211): pd status 3e
INFO: SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-ga7c7ca8 (Apr 25 2017 - 15:10:21)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
no key node
pmic:rk808
can’t find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=58
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 594000000HZ
cpll = 800000000HZ
dpll = 660000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2017-04-25#1.05
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
misc partition not found!
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01103008)
ramdisk @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 0000000005613645 … OK
Add bank:0000000000200000, 000000007fe00000
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.77 (harris@harris-System-Product-Name) (gcc version 7.3.0 (Ubuntu/Linaro 7.3.0-16ubuntu3) ) #3 SMP Fri Jun 15 18:38:1agemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2017-04-25_15:10:21 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000] software IO TLB [mem 0x79a00000-0x7da00000] (64MB) vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff8008ee0000 - 0xffffff8009000000 ( 1152 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008ae0000 ( 10624 KB) [ 0.000000] .rodata : 0xffffff8008ae0000 - 0xffffff8008ee0000 ( 4096 KB) [ 0.000000] .data : 0xffffff8009000000 - 0xffffff80091830nout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @794g01[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_count.ng 41201 entries in 161 pages [ 0.113983] sched-energy: Sched-energy-costs installed from DT [ 0.114001] CPU0: update cpu_capacity 401 [ 0.114064] ASID allocator initialised with 65536 entries [ 0.117283] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.117714] Platform MSI: /interrupt-controller@fee00000/interrupt-contro7[ 0.120224] Detected VIPT I-cache on CPU3 [ 0.120245] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.120278] CPU3: using LPI pending table @0x0000000079710000 [ 0.120306] CPU3: update cpu_capacity 401 [ 0.120309] CPU3: Booted secondary processor [410fd034] [ 0.120838] Detected PIPT I-cache on CPU4 [ 0.120866] CPU4: found redistributor 100 recacity 1024 [ 0.121581] CPU5: Booted secondary processor [410fd082] [ 0.121671] Brought up 6 CPUs [ 0.121754] SMP: Total of 6 processors activated. [ 0.121764] CPU features: detected feature: GIC system register CPU interface [ 0.121776] CPU: All CPU(s) started at EL2 [ 0.121824] alternatives: patching kernel code [ 0.123278] devtmpfs: initialized [ fg governor ladder [ 0.146134] cpuidle: using governor menu [ 0.146157] Registered FIQ tty driver [ 0.146359] vdso: 2 pages (1 code @ ffffff8008ae6000, 1 data @ ffffff8009004000) [ 0.146389] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.146551] DMA: preallocated 256 KiB pool for atomic allocations [ 0.228562] console [ttyFIQ0] enabled [ [ 0.244290] iommu: Adding device ff650000.vpu_service to group 0 [ 0.244909] iommu: Adding device ff660000.rkvdec to group 1 [ 0.245488] iommu: Adding device ff8f0000.vop to group 2 [ 0.246044] iommu: Adding device ff900000.vop to group 3 [ 0.247752] SCSI subsystem initialized [ 0.248423] usbcore: registered new interface driver usbfs [ 0.248947] usbcore: registered new interface driver hub [ 0.249500] usbcore: registered new device driver usb [ 0.250049] media: Linux media interface: v0.10 [ 0.250494] Linux video capture interface: v2.00 [ 0.250938] pps_core: LinuxPPS API ver. 1 registered [ 0.251378] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.252198] PTP clock support registered [ 0.253439] Advanced Linux Sound Architecture Driver Initialized. [ 0.254469] Bluetooth: Core ver 2.21 [ 0.254812] NET: Registered protocol family 31 [ 0.255214] Bluetooth: HCI device and connection manager initialized [ 0.255777] Bluetooth: HCI socket layer initialized [ 0.256210] Bluetooth: L2CAP socket layer initialized [ 0.256685] Bluetooth: SCO socket layer initialized [ 0.257725] rockchip-cpuinfo cpuinfo: Serial : 5dfb38448dc2d689 [ 0.258707] clocksource: Switched to clocksource arch_sys_counter [ 0.306798] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 0.307721] NET: Registered protocol family 2 [ 0.308540] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 0.309307] TCP bind hash table entries: 16384 (order: 7, 524288 bytes) [ 0.310272] TCP: Hash tables configured (established 16384 bind 16384) [ 0.310929] UDP hash table entries: 1024 (order: 4, 98304 bytes) [ 0.311517] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes) [ 0.312335] NET: Registered protocol family 1 [ 0.313024] RPC: Registered named UNIX socket transport module. [ 0.313548] RPC: Registered udp transport module. [ 0.313980] RPC: Registered tcp transport module. [ 0.314396] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.315525] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 0.316355] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.320151] Initialise system trusted keyring [ 0.328728] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.330995] NFS: Registering the id_resolver key type [ 0.331466] Key type id_resolver registered [ 0.331846] Key type id_legacy registered [ 0.332218] Installing knfsd (copyright (C) 1996 [email]okir@monad.swb.de[/email]). [ 0.333514] fuse init (API version 7.23) [ 0.334361] SGI XFS with security attributes, no debug enabled [ 0.340261] NET: Registered protocol family 38 [ 0.340671] Key type asymmetric registered [ 0.341056] Asymmetric key parser 'x509' registered [ 0.341643] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 0.342319] io scheduler noop registered [ 0.342670] io scheduler deadline registered [ 0.343187] io scheduler cfq registered (default) [ 0.344875] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned [ 0.346779] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned [ 0.351718] backlight supply power not found, using dummy regulator [ 0.352883] rk-vcodec ff650000.vpu_service: probe device [ 0.353394] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc078d9a010 [ 0.354161] rk-vcodec ff650000.vpu_service: allocator is drm [ 0.354726] rk-vcodec ff650000.vpu_service: checking hw id 0 [ 0.355670] rk-vcodec ff650000.vpu_service: init success [ 0.356752] rk-vcodec ff660000.rkvdec: probe device [ 0.357218] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc078d9a810 [ 0.357914] rk-vcodec ff660000.rkvdec: allocator is drm [ 0.358425] rk-vcodec ff660000.rkvdec: checking hw id 6876 [ 0.359220] rk-vcodec ff660000.rkvdec: init success [ 0.360954] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.361624] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 0.363878] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 0.364546] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 0.366310] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.368346] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A [ 0.369750] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A [ 0.371126] ff370000.serial: ttyS1 at MMIO 0xff370000 (irq = 38, base_baud = 1500000) is a 16550A [ 0.372775] [drm:drm_core_init] Initialized drm 1.1.0 20060810 [ 0.376185] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008b81308) [ 0.377117] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008b81308) [ 0.378069] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports [ 0.378659] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver [ 0.379405] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 0.380835] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008b7c3a8) [ 0.381551] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 0.382275] [drm:drm_vblank_init] No driver support for vblank timestamp query. [ 0.383029] rockchip-drm display-subsystem: failed to parse loader memory [ 0.383640] rockchip-drm display-subsystem: No connectors reported connected with modes [ 0.384382] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768 [ 0.396720] Console: switching to colour frame buffer device 128x48 [ 0.404459] rockchip-drm display-subsystem: fb0: frame buffer device [ 0.412072] mali ff9a0000.gpu: Failed to get regulator [ 0.412527] mali ff9a0000.gpu: Power control initialization failed [ 0.413165] platform ff9a0000.gpu: Driver mali requests probe deferral [ 0.413986] Unable to detect cache hierarchy from DT for CPU 0 [ 0.415224] brd: module loaded [ 0.420514] loop: module loaded [ 0.421341] zram: Added device: zram0 [ 0.421936] lkdtm: No crash points registered, enable through debugfs [ 0.423261] register spi return v = :0 [ 0.423615] tun: Universal TUN/TAP device driver, 1.6 [ 0.424083] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 0.425901] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 0.426523] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 0.427037] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b). [ 0.427723] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 0.428260] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 0.433878] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 0.434329] Ring mode enabled [ 0.434605] DMA HW capability register supported [ 0.435016] Normal descriptors [ 0.435326] RX Checksum Offload Engine supported (type 2) [ 0.435817] TX Checksum insertion supported [ 0.436197] Wake-Up On Lan supported [ 0.436560] Enable RX Mitigation via HW Watchdog Timer [ 0.501407] libphy: stmmac: probed [ 0.501729] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active [ 0.502300] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01) [ 0.503735] PPP generic driver version 2.4.2 [ 0.504348] usbcore: registered new interface driver rndis_wlan [ 0.505248] Rockchip WiFi SYS interface (V1.00) ... [ 0.505772] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 0.506498] usbcore: registered new interface driver pegasus [ 0.507108] usbcore: registered new interface driver rtl8150 [ 0.507647] usbcore: registered new interface driver r8152 [ 0.508195] usbcore: registered new interface driver asix [ 0.508720] usbcore: registered new interface driver ax88179_178a [ 0.509289] usbcore: registered new interface driver cdc_ether [ 0.509873] usbcore: registered new interface driver dm9601 [ 0.510417] usbcore: registered new interface driver smsc75xx [ 0.510987] usbcore: registered new interface driver smsc95x[ 0.511531] usbcore: registered new interface driver net1080 [ 0.512079] usbcore: registered new interface driver rndis_host [ 0.512635] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 0.513379] usbcore: registered new interface driver cdc_ncm [ 0.513929] usbcore: registered new interface driver qmi_wwan [ 0.514472] usbcore: registered [ 0.521447] rockchip-dwc3 usb@fe800000: fail to get drvdata hcd [ 0.523052] platform usb@fe800000: Driver rockchip-dwc3 requests probe deferral [ 0.529066] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd [ 0.529891] platform usb@fe900000: Driver rockchip-dwc3 requests probe deferral [ 0.531268] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.531863] ehci-pci: EHCI PCI platform driver [ 0.532309] ehci-platform: EHCI generic platform driver [ 0.536450] ehci-platform fe380000.usb: EHCI Host Controller [ 0.537100] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1 [ 0.537912] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000 [ 0.543731] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 0.544430] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.545040] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.545682] usb usb1: Product: EHCI Host Controller [ 0.546122] usb usb1: Manufacturer: Linux 4.4.77 ehci_hcd [ 0.546599] usb usb1: SerialNumber: fe380000.usb [ 0.547452] hub 1-0:1.0: USB hub found [ 0.547839] hub 1-0:1.0: 1 port detected [ 0.551733] ehci-platform fe3c0000.usb: EHCI Host Controller [ 0.552374] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2 [ 0.553163] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000 [ 0.559728] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00 [ 0.560410] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.561020] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.561662] usb usb2: Product: EHCI Host Controller [ 0.562100] usb usb2: Manufacturer: Linux 4.4.77 ehci_hcd [ 0.562577] usb usb2: SerialNumber: fe3c0000.u[ 0.564615] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.565190] ohci-platform: OHCI generic platform driver [ 0.565961] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 0.566717] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3 [ 0.567501] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000 [ 0.622860] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.623458] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.624111] usb usb3: Product: Generic Platform OHCI controller [ 0.624635] usb usb3: Manufacturer: Linux 4.4.77 ohci_hcd [ 0.625118] usb usb3: SerialNumber: fe3a0000.usb [ 0.625942] hub 3-0:1.0: USB hub found [[ 0.628713] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000 [ 0.683861] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.684458] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.685110] usb usb4: Product: Generic Platform OHCI controller [ 0.685634] usb usb4: Manufacturer: Linux 4.4.77 ohci_hcd [ 0.686118] usb usb4: SerialNumber: fe3e0000.usb [ 0.686943] hub 4-0:1.0: USB hub found [ 0.688469] usbcore: registered new interface driver cdc_acm [ 0.688984] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 0.689737] usbcore: registered new interface driver cdc_wdm [ 0.690280] usbcore: registered new interface driver uas [ 0.690890] usbcore: registered new interface driver usb-storage [ 0.691497] usbcore: registereistered for Keyspan 1 port adapter [ 0.697587] usbserial: USB Serial support registered for Keyspan 2 port adapter [ 0.698261] usbserial: USB Serial support registered for Keyspan 4 port adapter [ 0.698953] usbcore: registered new interface driver option [ 0.699461] usbserial: USB Serial support registered for GSM modem (1-port) [ 0.700262] usbcore: registered nert registered for pl2303 [ 0.702459] usbcore: registered new interface driver qcserial [ 0.703004] usbserial: USB Serial support registered for Qualcomm USB modem [ 0.703673] usbcore: registered new interface driver sierra [ 0.704202] usbserial: USB Serial support registered for Sierra USB modem [ 0.705557] usbcore: registered new interface driver iforce [ 0.hscreen [ 0.708421] i2c /dev entries driver [ 0.709958] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 0.710642] fan53555-reg: supplied by vcc5v0_sys [ 0.712825] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 0.713474] fan53555-reg: supplied by vcc5v0_sys [ 0.715762] rk808 0-001b: Pmic Chip id: 0x0 [ 0.719576] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 0.720192] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 0.720824] DCDC_REG1: supplied by vcc3v3_sys [ 0.721933] DCDC_REG2: supplied by vcc3v3_sys [ 0.722870] DCDC_REG3: supplied by vcc3v3_sys [ 0.723504] DCDC_REG4: supplied by vcc3v3_sys [ 0.724319] LDO_REG1: supplied by vcc3v3_sys [ 0.725819] LDO_REG2: supplied by vcc3v3_sys [ 0.727130] LDO_REG3: supplied by vcc3v3_sys [ 0.728451] LDO_REG4: supplied by vcc3v3_sys [ 0.729802] LDO_REG5: supplied by vcc3v3_sys [ 0.731117] LDO_REG6: supplied by vcc3v3_sys [ 0.732427] LDO_REG7: supplied by vcc3v3_sys [ 0.733778] LDO_REG8: supplied by vcc3v3_sys [ 0.735089] SWITCH_REG1: supplied by vcc3v3_sys [ 0.735755] SWITCH_REG2: supplied by vcc3v3_sys [ 0.739610] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ 0.740633] rk808 0-001b: Can not read property pmic,hold-gpio [ 0.741168] rk808 0-001b: Can not read property pmic,stby-gpio [ 0.741713] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80093fc000 [ 0.742985] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80093fe000 [ 0.743727] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c [ 0.744656] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22 [ 0.745251] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl [ 0.746234] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back [ 0.747228] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff8009442000 [ 0.748382] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009444000 [ 0.749951] IR NEC protocol handler initialized [ 0.750360] IR RC5(x/sz) protocol handler initialized [ 0.750824] IR RC6 protocol handler initialized [ 0.751231] IR JVC protocol handler initialized [ 0.751639] IR Sony protocol handler initialized [ 0.752055] IR SANYO protocol handler initialized [ 0.752475] IR Sharp protocol handler initialized [ 0.752903] IR MCE Keyboard/mouse protocol handler initialized [ 0.753417] IR XMP protocol handler initialized [ 0.754244terface driver uvcvideo [ 0.756340] USB Video Class driver (1.1.1) [ 0.758928] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647 [ 0.760768] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: [email]dm-devel@redhat.com[/email] [ 0.761686] Bluetooth: Virtual HCI driver ver 1.5 [ 0.762241] Bluetooth: HCI UART driver ver 2.3 [ 0.762636] Bluetooth: HCI UART protocol H4 registered [ 0.763100] Bluetooth: HCI UART protocol LL registered [ 0.763552] Bluetooth: HCI UART protocol ATH3K registered [ 0.764101] usbcore: registered new interface driver bfusb [ 0.764642] usbcore: registered new interface driver btusb [ 0.765518] cpu cpu0: leakage=22 [ 0.765993] cpu cpu4: leakage=39 [ 0.769900] sdhci: Secure Digital Host Controller Interface driver [ 0.770447] sdhci: Copyright(c) Pierre Ossman [ 0.770857] Synopsys Designware Multimedia Card Interface Driver [ 0.772232] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode. [ 0.772922] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller. [ 0.773524] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a [ 0.774083] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo [ 0.774958] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated. [ 0.775786] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found [ 0.776582] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 0.777382] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done [ 0.788778] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 0.799787] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized [ 0.800562] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.802786] sdhci-arasan fe330000.sdhci: No vmmc regulator found [ 0.803321] sdhci-arasan fe330000.sdhci: No vqmmc regulator found [ 0.829727] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ 0.830864] hidraw: raw HID events driver (C) Jiri Kosina [ 0.832113] usbcore: registered new interface driver usbhid [ 0.832612] usbhid: USB HID core driver [ 0.834827] usbcore: registered new interface driver snd-usb-audio [ 0.837222] platform es8316-sound: Driver asoc-simple-card requests probe deferral [ 0.838014] platform hdmi-codec: Driver asoc-simple-card requests probe deferral [ 0.840486] u32 classifier [ 0.840775] Netfilter messages via NETLINK v0.30. [ 0.841255] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 0.842114] ctnetlink v0.93: registering with nfnetlink. [ 0.842753] ip_set: protocol 6 [ 0.843037] IPVS: Registered protocols () [ 0.843553] IPVS: Connection hash table configured (size=4096, memory=64Kbytes) [ 0.844324] IPVS: Creating netns size=1592 id=0 [ 0.844783] IPVS: ipvs loaded. [ 0.845393] ip_tables: (C) 2000-2006 Netfilter Core Team [ 0.846064] Initializing XFRM netlink socket [ 0.847140] NET: Registered protocol family 10 [ 0.848434] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 0.849110] sit: IPv6 over IPv4 tunneling driver [ 0.850058] NET: Registered protocol family 17 [ 0.850470] NET: Registered protocol family 15 [ 0.850906] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 0.852046] Bridge foth: RFCOMM ver 1.11 [ 0.853358] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 0.853896] Bluetooth: HIDP socket layer initialized [ 0.854385] 8021q: 802.1Q VLAN Support v1.8 [ 0.854786] lib80211: common routines for IEEE802.11 drivers [ 0.855328] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 0.856009] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 0.856487] [: enable wifi power control. [ 0.857780] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 0.858468] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 149, flags = 0. [ 0.859289] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 0.859779] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 0.860229] [BT_RFKILL]: Enter rfkill_rk_init [mulation handler [ 0.861984] Registered setend emulation handler [ 0.862909] Loading compiled-in X.509 certificates [ 0.864617] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0 [ 0.865773] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing power_model_simple. [ 0.867262] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 0.868353] mali ff9a0000.gpu: Probed as mali0 [ 0.874989] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 0.875072] mmc1: MAN_BKOPS_EN bit is not set [ 0.876404] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 5 [ 0.877372] xhci-hcd xhci-hcd.6.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010 [ 0.878258] xhci-hcd xhci-hcd.6.auto: irq 226, io mem 0xfe800000 [ 0.879186] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.879831] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.880480] usb usb5: Product: xHCI Host Controller [ 0.880950] usb usb5: Manufacturer: Linux 4.4.77 xhci-hcd [ 0.881443] usb usb5: SerialNumber: xhci-hcd.6.auto [ 0.883028] hub 5-0:1.0: USB hub found [ 0.883437] hub 5-0:1.0: 1 port detected [ 0.884662] xhci-hcd xhci-hcd.6.auto: xHCI Host Controller [ 0.885522] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 6 [ 0.886264] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 0.886656] mmc1: new HS400 Enhanced strobe MMC card at address 0001 [ 0.887019] mmcblk1: mmc1:0001 AJNB4R 14.6 GiB [ 0.887208] mmcblk1boot0: mmc1:0001 AJNB4R partition 1 4.00 MiB [ 0.887404] mmcblk1boot1: mmc1:0001 AJNB4R partition 2 4.00 MiB [ 0.887580] mmcblk1rpmb: mmc1:0001 AJNB4R partition 3 4.00 MiB [ 0.887893] uboot: 0x000400000 -- 0x000800000 (4 MB) [ 0.887897] trust: 0x000800000 -- 0x000c00000 (4 MB) [ 0.887900] resource: 0x000c00000 -- 0x001c00000 (16 MB) [ 0.887903] kernel: 0x001c00000 -- 0x003000000 (20 MB) [ 0.887906] backup: 0x003000000 -- 0x003400000 (4 MB) [ 0.887909] boot: 0x003400000 -- 0x3a3a00000 (14854 MB) [ 0.892474] mmcblk1: p1 p2 p3 p4 p5 p6 [ 0.892474] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003 [ 0.893427] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.894072] usb usb6: Product: xHCI Host Controller [ 0.894509] usb usb6: Manufacturer: Linux 4.4.77 xhci-hcd [ 0.894988] usb usb6: SerialNumber: xhci-hcd.6.auto [ 0.895839] hub 6-0:1.0: USB hub found [ 0.896190] hub 6-0:1.0: 1 port detected [ 0.897566] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 0.898042] usb usb6: USB disconnect, device number 1 [ 0.922201] xhci-hcd xhci-hcd.6.auto: Host not halted after 16000 microseconds. [ 0.922849] xhci-hcd xhci-hcd.6.auto: Host controller not halted, aborting reset. [ 0.923533] xhci-hcd xhci-hcd.6.auto: USB bus 6 deregistered [ 0.924430] xhci-hcd xhci-hcd.6.auto: remove, state 1 [ 0.924931] usb usb5: USB disconnect, device number 1 [ 0.925919] xhci-hcd xhci-hcd.6.auto: USB bus 5 deregistered [ 0.931811] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 0.932417] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 5 [ 0.933222] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010 [ 0.934025] xhci-hcd xhci-hcd.7.auto: irq 227, io mem 0xfe900000 [ 0.934646] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.935255] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.935896] usb usb5: Product: xHCI Host Controller [ 0.936332] usb usb5: Manufacturer: Linux 4.4.77 xhci-hcd [ 0.936809] usb usb5: SerialNumber: xhci-hcd.7.auto [ 0.937549] hub 5-0:1.0: USB hub found [ 0.937906] hub 5-0:1.0: 1 port detected [ 0.938457] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller [ 0.939041] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 6 [ 0.939755] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 0.940518] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003 [ 0.941125] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.941764] usb usb6: Product: xHCI Host Controller [ 0.942200] usb usb6: Manufacturer: Linux 4.4.77 xhci-hcd [ 0.942671] usb usb6: SerialNumber: xhci-hcd.7.auto [ 0.943404] hub 6-0:1.0: USB hub found [ 0.943765] hub 6-0:1.0: 1 port detected [ 0.987380] usb 2-1: New USB device found, idVendor=1a40, idProduct=0101 [ 0.987984] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 0.988608] usb 2-1: Product: USB 2.0 Hub [MTT] [ 0.989466] hub 2-1:1.0: USB hub found [ 0.990005] hub 2-1:1.0: 4 ports detected [ 1.066165] asoc-simple-card es8316-sound: ES8316 HiFi <-> ff880000.i2s mapping ok [ 1.066890] asoc-simple-card es8316-sound: ASoC: no source widget found for MICBIAS1 [ 1.067580] asoc-simple-card es8316-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack [ 1.068409] asoc-simple-card es8316-sound: ASoC: no sink widget found for IN1P [ 1.069075] asoc-sim[ 1.076680] asoc-simple-card hdmi-codec: i2s-hifi <-> ff8a0000.i2s mapping ok [ 1.079614] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 1.081613] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:02 UTC (1358499002) u 1.106853]
