各位大神你们好,我最近遇到一个问题解决不了。
硬件平台:rk3288 reload
软件平台:android 5.1
目的:需要hdmi与lvds双屏异显
问题:已实现hdmi与lvds接口屏幕 双屏同显,但是想要hdmi主屏,lvds为副屏时,hdmi正常显示,lvds黑屏(通过修改dts文件,见附件)
想问下改dts中的prop可以实现吗?或者还是要修改其他东西
麻烦百忙之中答疑解惑,谢谢。
#firefly-rk3288-reload.dts
/dts-v1/;
#include "rk3288.dtsi"
//#include "lcd-box.dtsi"
#include <dt-bindings/input/input.h>
#include "lcd-b101ew05.dtsi"
fiq-debugger {
status = "disabled";
hsic-usb-hub{
compatible = "hub_reset";
reset,pin =<&gpio7 GPIO_A6 GPIO_ACTIVE_HIGH>; // hub reset pin
wireless-wlan {
compatible = "wlan-platdata";
/* wifi_chip_type - wifi chip define
* bcmwifi ==> like ap6xxx, rk90x;
* rtkwifi ==> like rtl8188xx, rtl8723xx,rtl8812auv;
* esp8089 ==> esp8089;
* other ==> for other wifi;
wifi_chip_type = "bcmwifi";
sdio_vref = <1800>; //1800mv or 3300mv
//keep_wifi_power_on;
//power_ctrl_by_pmu;
power_pmu_regulator = "act_ldo3";
power_pmu_enable_level = <1>; //1->HIGH, 0->LOW
//vref_ctrl_enable;
//vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
vref_pmu_regulator = "act_ldo3";
vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW
WIFI,poweren_gpio = <&gpio4 GPIO_D4 GPIO_ACTIVE_HIGH>;
WIFI,host_wake_irq = <&gpio4 GPIO_D6 GPIO_ACTIVE_HIGH>;
//WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>;
status = "okay";
wireless-bluetooth {
compatible = "bluetooth-platdata";
//wifi-bt-power-toggle;
uart_rts_gpios = <&gpio4 GPIO_C3 GPIO_ACTIVE_LOW>;
pinctrl-names = "default","rts_gpio";
pinctrl-0 = <&uart0_rts>;
pinctrl-1 = <&uart0_rts_gpio>;
BT,power_gpio = <&gpio8 GPIO_A7 GPIO_ACTIVE_HIGH>;
BT,reset_gpio = <&gpio4 GPIO_D5 GPIO_ACTIVE_HIGH>;
BT,wake_gpio = <&gpio4 GPIO_D2 GPIO_ACTIVE_HIGH>;
BT,wake_host_irq = <&gpio4 GPIO_D7 GPIO_ACTIVE_LOW>;
status = "okay";
pwm_regulator {
compatible = "rockchip_pwm_regulator";
pwms = <&pwm1 0 2000>;
rockchip,pwm_id= <1>;
rockchip,pwm_voltage_map= <925000 950000 975000 1000000 1025000 1050000 1075000 1100000 1125000 1150000 1175000 1200000 1225000 1250000 1275000 1300000 1325000 1350000 1375000 1400000>;
rockchip,pwm_voltage= <1100000>;
rockchip,pwm_min_voltage= <925000>;
rockchip,pwm_max_voltage= <1400000>;
rockchip,pwm_suspend_voltage= <950000>;
rockchip,pwm_coefficient= <475>;
regulators {
#address-cells = <1>;
#size-cells = <0>;
pwm_reg0: regulator@0 {
regulator-compatible = "pwm_dcdc1";
regulator-name= "vdd_logic";
regulator-min-microvolt = <925000>;
regulator-max-microvolt = <1400000>;
regulator-always-on;
regulator-boot-on;
codec_hdmi_i2s: codec-hdmi-i2s {
compatible = "hdmi-i2s";
codec_hdmi_spdif: codec-hdmi-spdif {
compatible = "hdmi-spdif";
rockchip-hdmi-i2s {
compatible = "rockchip-hdmi-i2s";
dais {
dai0 {
audio-codec = <&codec_hdmi_i2s>;
audio-controller = <&i2s>;
format = "i2s";
//continuous-clock;
//bitclock-inversion;
//frame-inversion;
//bitclock-master;
//frame-master;
rockchip-spdif-card {
compatible = "rockchip-spdif-card";
dais {
dai0 {
audio-codec = <&codec_hdmi_spdif>;
audio-controller = <&spdif>;
rockchip-es8323 {
compatible = "rockchip-es8323";
dais {
dai0 {
audio-codec = <&es8323>;
format = "i2s";
//continuous-clock;
//frame-inversion;
//bitclock-master;
//frame-master;
rkxx-remotectl{
compatible = "rockchip,remotectl";
module-gpios = <&gpio7 GPIO_A0 GPIO_ACTIVE_LOW>;
led-power = <&gpio8 GPIO_A1 GPIO_ACTIVE_LOW>;
leds {
compatible = "gpio-leds";
power {
label = "firefly:blue:power";
linux,default-trigger = "ir-power-click";
default-state = "on";
gpios = <&gpio8 GPIO_A1 GPIO_ACTIVE_LOW>;
user {
label = "firefly:yellow:user";
linux,default-trigger = "ir-user-click";
default-state = "off";
gpios = <&gpio8 GPIO_A2 GPIO_ACTIVE_LOW>;
sata {
label = "firefly:blue:sata";
//linux,default-trigger = "ir-user-click";
gpios = <&gpio0 GPIO_C1 GPIO_ACTIVE_HIGH>;
usb_control {
compatible = "rockchip,rk3288-usb-control";
host_drv_gpio = <&gpio0 GPIO_B6 GPIO_ACTIVE_LOW>;
otg_drv_gpio = <&gpio0 GPIO_B4 GPIO_ACTIVE_LOW>;
rockchip,remote_wakeup;
rockchip,usb_irq_wakeup;
test-power{
rgb2hdmi {
compatible = "firefly,rgb2hdmi";
power-gpio = <&gpio7 GPIO_A2 GPIO_ACTIVE_HIGH>;
lcdc-gpio = <&gpio7 GPIO_A3 GPIO_ACTIVE_HIGH>;
hpd-gpio = <&gpio4 GPIO_D3 GPIO_ACTIVE_HIGH>;
rockchip,source = <0>; //0: LCDC0; 1: LCDC1
rockchip,prop = <PRMRY>;//<EXTEND>
&gmac {
// pmu_regulator = "act_ldo5";
// pmu_enable_level = <1>; //1->HIGH, 0->LOW
// power-gpio = <&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
reset-gpio = <&gpio4 GPIO_B0 GPIO_ACTIVE_LOW>;
phy-mode = "rgmii";
clock_in_out = "input";
tx_delay = <0x30>;
rx_delay = <0x20>;
&uart_dbg {
status = "okay";
&pinctrl {
//used for init some gpio
init-gpios = <&gpio4 GPIO_B0 GPIO_ACTIVE_HIGH>;
gpio0_gpio {
gpio0_c2: gpio0-c2 {
rockchip,pins = <GPIO0_C2>;
rockchip,pull = <VALUE_PULL_DOWN>;
//to add
gpio7_gpio {
gpio7_b7: gpio7-b7 {
rockchip,pins = <GPIO7_B7>;
rockchip,pull = <VALUE_PULL_UP>;
//to add
//could add other pinctrl definition such as gpio
// gmac drive strength
gpio4_gmac {
mac_clk: mac-clk {
rockchip,drive = <VALUE_DRV_12MA>;
mac_txpins: mac-txpins {
mac_rxpins: mac-rxpins {
mac_crs: mac-crs {
mac_mdpins: mac-mdpins {
&nandc0 {
status = "okay"; // used nand set "okay" ,used emmc set "disabled"
&nandc1 {
status = "disabled"; // used nand set "okay" ,used emmc set "disabled"
&nandc0reg {
&emmc {
clock-frequency = <100000000>;
clock-freq-min-max = <400000 100000000>;
supports-highspeed;
supports-emmc;
bootpart-no-access;
//supports-tSD;//only tsd-sdcard mode
supports-DDR_MODE;
caps2-mmc-hs200;
ignore-pm-notify;
keep-power-in-suspend;
//poll-hw-reset
status = "okay";
&sdmmc {
clock-frequency = <50000000>;
lock-freq-min-max = <400000 50000000>;
supports-highspeed;
supports-sd;
broken-cd;
card-detect-delay = <200>;
ignore-pm-notify;
vmmc-supply = <&ldo1_reg>;
status = "okay";
&sdio {
clock-freq-min-max = <200000 50000000>;
supports-highspeed;
supports-sdio;
ignore-pm-notify;
//cap-sdio-irq;
status = "okay";
&spi0 {
max-freq = <48000000>;
spi_test@00 {
compatible = "rockchip,spi_test_bus0_cs0";
reg = <0>;
spi-max-frequency = <24000000>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
spi_test@01 {
compatible = "rockchip,spi_test_bus0_cs1";
reg = <1>;
spi-cpha;
spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
&spi1 {
spi_test@10 {
compatible = "rockchip,spi_test_bus1_cs0";
reg = <0>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
//dtv: connect to dtv demodulator for control signal
/*tstv-ctrl@00 {
compatible = "rockchip,dtv_spi_ctrl";
gpio-powerup = <&gpio0 GPIO_D7 GPIO_ACTIVE_HIGH>;
gpio-powerdown = <&gpio2 GPIO_B6 GPIO_ACTIVE_HIGH>;
gpio-reset = <&gpio2 GPIO_B7 GPIO_ACTIVE_HIGH>;
gpio-nreset = <&gpio2 GPIO_B4 GPIO_ACTIVE_HIGH>;
spi-max-frequency = <12000000>;
reg = <0>;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
&spi2 {
spi_test@20 {
compatible = "rockchip,spi_test_bus2_cs0";
reg = <0>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
spi_test@21 {
compatible = "rockchip,spi_test_bus2_cs1";
reg = <1>;
//spi-cpha;
//spi-cpol;
poll_mode = <0>;
type = <0>;
enable_dma = <0>;
&uart_bt {
status = "okay";
dma-names = "!tx", "!rx";
pinctrl-0 = <&uart0_xfer &uart0_cts>;
&uart_bb {
status = "okay";
&uart_gps {
status = "okay";
&i2c0 {
status = "okay";
rk808: rk808@1b {
reg = <0x1b>;
status = "okay";
syr827: syr827@40 {
compatible = "silergy,syr82x";
reg = <0x40>;
status = "okay";
regulators {
#size-cells = <0>;
syr827_dc1: regulator@0 {
reg = <0>;
regulator-compatible = "syr82x_dcdc1";
regulator-name = "vdd_arm";
regulator-min-microvolt = <712500>;
regulator-max-microvolt = <1500000>;
regulator-boot-on;
regulator-initial-mode = <0x2>;
regulator-initial-state = <3>;
regulator-state-mem {
regulator-state-mode = <0x2>;
regulator-state-enabled;
regulator-state-uv = <900000>;
syr828: syr828@41 {
reg = <0x41>;
status = "okay";
regulators {
#size-cells = <0>;
syr828_dc1: regulator@0 {
reg = <0>;
regulator-name = "vdd_gpu";
regulator-boot-on;
regulator-state-disabled;
act8846: act8846@5a {
reg = <0x5a>;
status = "okay";
rtc@51 {
compatible = "rtc,hym8563";
reg = <0x51>;
irq_gpio = <&gpio7 GPIO_A4 IRQ_TYPE_EDGE_FALLING>;
&i2c1 {
status = "okay";
rtc@51 {
compatible = "nxp,pcf8563";
reg = <0x51>;
tc358749@0f {
compatible = "rockchip,tc358749";
reg = <0x0f>;
gpio-power = <&gpio7 GPIO_C5 GPIO_ACTIVE_HIGH>;//264
gpio-stanby = <&gpio7 GPIO_A5 GPIO_ACTIVE_HIGH>;//238
gpio-reset = <&gpio8 GPIO_B0 GPIO_ACTIVE_HIGH>;//262
gpio-int = <&gpio8 GPIO_B1 GPIO_ACTIVE_HIGH>;//239
status = "okay";
&i2c2 {
status = "okay";
es8323: es8323@10 {
compatible = "es8323";
reg = <0x10>;
spk-con-gpio = <&gpio0 GPIO_B2 GPIO_ACTIVE_HIGH>;
hp-det-gpio = <&gpio7 GPIO_B7 GPIO_ACTIVE_HIGH>;
hp-mic-only = <1>;
clocks = <&clk_i2s>, <&clk_i2s_out>;
clock-names = "i2s_clk","i2s_mclk";
pinctrl-names = "default";
pinctrl-0 = <&i2s_mclk>;
&i2c3 {
status = "okay";
&i2c4 {
status = "okay";
vga_ddc@50 {
compatible = "firefly,vga_ddc";
reg = <0x50>;
rockchip,prop = <EXTEND>;//<EXTEND>
mt@40 {
compatible = "firefly,gsl3680";
reg = <0x40>;
touch-gpio = <&gpio7 GPIO_B5 IRQ_TYPE_EDGE_RISING>;
//reset-gpio = <&gpio7 GPIO_B1 GPIO_ACTIVE_LOW>;
max-y = <2048>;
max-x = <1536>;
flip-x = <1>;
flip-y = <1>;
swap-xy = <0>;
mpu6050:mpu@68{
compatible = "mpu6050";
reg = <0x68>;
mpu-int_config = <0x10>;
mpu-level_shifter = <0>;
mpu-orientation = <0 1 0 1 0 0 0 0 1>;
orientation-x= <1>;
orientation-y= <1>;
orientation-z= <1>;
irq-gpio = <&gpio7 GPIO_B1 IRQ_TYPE_LEVEL_LOW>;
mpu-debug = <0>;
&i2c5 {
&fb {
rockchip,disp-mode = <DUAL>;
rockchip,uboot-logo-on = <1>;
rockchip,disp-policy = <DISPLAY_POLICY_SDK>;
&disp_timings {
native-mode = <&timing0>;
&rk_screen {
display-timings = <&disp_timings>;
/*lcdc0 as PRMRY(HDMI)*/
&lcdc0 {
status = "okay";
rockchip,iommu-enabled = <1>;
//rockchip,prop = <PRMRY>;
power_ctr: power_ctr {
rockchip,debug = <1>;
lcd_en:lcd_en {
rockchip,power_type = <GPIO>;
gpios = <&gpio7 GPIO_A3 GPIO_ACTIVE_HIGH>;
rockchip,delay = <10>;
lcd_cs:lcd_cs {
gpios = <&gpio7 GPIO_A4 GPIO_ACTIVE_HIGH>;
lcd_rst:lcd_rst {
gpios = <&gpio0 GPIO_B5 GPIO_ACTIVE_LOW>;
&lcdc1 {
status = "okay";
//rockchip,prop = <EXTEND>;
&hdmi {
status = "okay";
rockchip,cec_enable = <0>;
rockchip,hdcp_enable = <0>;
rockchip,hdmi_audio_source = <0>;
rockchip,hdmi_video_source = <DISPLAY_SOURCE_LCDC1>;
&ion_cma {
reg = <0x00000000 0x1000000>; /* 16MB */
&vpu {
iommu_enabled = <1>;
&hevc {
&iep {
&adc {
status = "okay";
key {
compatible = "rockchip,key";
io-channels = <&adc 1>;
vol-up-key {
linux,code = <115>;
label = "volume up";
rockchip,adc_value = <1>;
vol-down-key {
linux,code = <114>;
label = "volume down";
rockchip,adc_value = <170>;
power-key {
gpios = <&gpio0 GPIO_A5 GPIO_ACTIVE_LOW>;
linux,code = <116>;
label = "power";
gpio-key,wakeup;
recovery-key {
linux,code = <113>;
label = "recovery";
rockchip,adc_value = <4>;
menu-key {
linux,code = <59>;
label = "menu";
rockchip,adc_value = <355>;
home-key {
linux,code = <102>;
label = "home";
rockchip,adc_value = <746>;
back-key {
linux,code = <158>;
label = "back";
rockchip,adc_value = <560>;
camera-key {
linux,code = <212>;
label = "camera";
rockchip,adc_value = <450>;
&pwm0 {
interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
status = "okay";
&pwm1 {
status = "okay";
&clk_core_dvfs_table {
support-pvtm = <0>;
pvtm-operating-points = <
/* KHz uV pvtm margin*/
126000 900000 25000
216000 900000 25000
312000 900000 25000
408000 900000 25000
600000 950000 50000
696000 950000 25000
816000 1000000 25000
1008000 1050000 25000
1200000 1100000 25000
1416000 1200000 25000
1512000 1300000 25000
1608000 1350000 25000
1704000 1350000 25000
1800000 1350000 25000
status="okay";
&clk_gpu_dvfs_table {
/* KHz uV */
// 100000 900000
200000 900000
300000 950000
420000 1100000
500000 1150000
// 600000 1250000
status="okay";
&clk_ddr_dvfs_table {
/* KHz uV */
200000 1075000
300000 1075000
456000 1125000
533000 1150000
freq-table = <
/*status freq(KHz)*/
SYS_STATUS_NORMAL 456000
SYS_STATUS_SUSPEND 200000
//SYS_STATUS_VIDEO_1080P 240000
SYS_STATUS_VIDEO_4K 456000
SYS_STATUS_PERFORMANCE 533000
//SYS_STATUS_BOOST 324000
//SYS_STATUS_ISP 400000
auto-freq-table = <
240000
324000
456000
528000
auto-freq=<0>;
status="okay";
/include/ "act8846.dtsi"
&act8846 {
gpios =<&gpio7 GPIO_B6 GPIO_ACTIVE_LOW>,<&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
cpu_det_gpio =<&gpio7 GPIO_B2 GPIO_ACTIVE_LOW>;
usb_hub_reset_gpio =<&gpio8 GPIO_A3 GPIO_ACTIVE_LOW>;
act8846,system-power-controller;
regulators {
dcdc1_reg: regulator@0{
regulator-name= "act_dcdc1";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
regulator-boot-on;
dcdc2_reg: regulator@1 {
regulator-name= "vccio";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-state-uv = <3300000>;
dcdc3_reg: regulator@2 {
regulator-min-microvolt = <700000>;
regulator-state-uv = <1200000>;
dcdc4_reg: regulator@3 {
regulator-name= "act_dcdc4";
regulator-min-microvolt = <2000000>;
regulator-max-microvolt = <2000000>;
regulator-state-uv = <2000000>;
ldo1_reg: regulator@4 {
regulator-name= "vccio_sd";
regulator-min-microvolt = <1800000>;
ldo2_reg: regulator@5 {
regulator-name= "act_ldo2";
regulator-min-microvolt = <1050000>;
regulator-max-microvolt = <1050000>;
ldo3_reg: regulator@6 {
regulator-name= "act_ldo3";
ldo4_reg:regulator@7 {
regulator-name= "act_ldo4";
ldo5_reg: regulator@8 {
regulator-name= "act_ldo5";
ldo6_reg: regulator@9 {
regulator-name= "act_ldo6";
regulator-min-microvolt = <1100000>;
regulator-max-microvolt = <1100000>;
ldo7_reg: regulator@10 {
regulator-name= "vcc_18";
regulator-max-microvolt = <1800000>;
ldo8_reg: regulator@11 {
regulator-name= "act_ldo8";
regulator-min-microvolt = <1850000>;
regulator-max-microvolt = <1850000>;
/include/ "rk808.dtsi"
&rk808 {
gpios =<&gpio0 GPIO_A4 GPIO_ACTIVE_HIGH>,<&gpio0 GPIO_B3 GPIO_ACTIVE_LOW>;
rk808,system-power-controller;
regulators {
rk808_dcdc1_reg: regulator@0{
regulator-name= "vdd_arm";
regulator-boot-on;
rk808_dcdc2_reg: regulator@1 {
regulator-name= "vdd_gpu";
regulator-boot-on;
rk808_dcdc3_reg: regulator@2 {
regulator-name= "rk_dcdc3";
regulator-boot-on;
rk808_dcdc4_reg: regulator@3 {
regulator-boot-on;
/* NO USED, 3.3V*/
rk808_ldo1_reg: regulator@4 {
regulator-name= "rk_ldo1";
regulator-boot-on;
/* BOX:RK1000s, 3.3V */
rk808_ldo2_reg: regulator@5 {
regulator-name= "rk_ldo2";
regulator-boot-on;
/* RK3288 PLL,USB PHY, 1.0V */
rk808_ldo3_reg: regulator@6 {
regulator-name= "rk_ldo3";
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
regulator-boot-on;
/* BOX:RK1000S CORE, 1.8V */
rk808_ldo4_reg:regulator@7 {
regulator-name= "rk_ldo4";
regulator-boot-on;
/* SDMMC IO, 3.3V*/
rk808_ldo5_reg: regulator@8 {
regulator-name= "rk_ldo5";
regulator-boot-on;
/* CAMERA, 1.8V box modify*/
rk808_ldo6_reg: regulator@9 {
regulator-name= "rk_ldo6";
regulator-boot-on;
/* RK3288 USB PHY, SAR-ADC, WIFI IO, 1.8V */
rk808_ldo7_reg: regulator@10 {
regulator-name= "rk_ldo7";
regulator-boot-on;
/* DTV, 3.3V box modify*/
rk808_ldo8_reg: regulator@11 {
regulator-name= "rk_ldo8";
regulator-boot-on;
rk808_ldo9_reg: regulator@12 {
regulator-name= "rk_ldo9";
regulator-boot-on;
rk808_ldo10_reg: regulator@13 {
regulator-name= "rk_ldo10";
regulator-boot-on;
&lcdc_vdd_domain {
regulator-name = "vcc30_lcd";
&dpio_vdd_domain{
regulator-name = "vcc18_cif";
&flash0_vdd_domain{
regulator-name = "vcc_flash";
&flash1_vdd_domain{
&apio3_vdd_domain{
regulator-name = "vccio_wl";
&apio5_vdd_domain{
regulator-name = "vccio";
&apio4_vdd_domain{
&apio1_vdd_domain{
&apio2_vdd_domain{
&sdmmc0_vdd_domain{
regulator-name = "vcc_sd";
* Due to not have the software of PWM for remotectrl.
* We can _*HACK*_ do that as the following.
&pwm0 {
compatible = "rockchip,remotectl-pwm";
remote_pwm_id = <0>;
handle_cpu_id = <1>;
status = "okay";
ir_key1{
rockchip,usercode = <0xff00>;
rockchip,key_table =
<0xeb KEY_POWER>,
<0xec KEY_MENU>,
<0xfe KEY_BACK>,
<0xb7 KEY_HOME>,
<0xa3 250>,
<0xf4 KEY_VOLUMEUP>,
<0xa7 KEY_VOLUMEDOWN>,
<0xf8 KEY_REPLY>,
<0xfc KEY_UP>,
<0xfd KEY_DOWN>,
<0xf1 KEY_LEFT>,
<0xe5 KEY_RIGHT>;
#rk3288.dtsi
#include <dt-bindings/clock/rk_system_status.h>
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/rkfb/rk_fb.h>
#include <dt-bindings/rkmipi/mipi_dsi.h>
#include <dt-bindings/suspend/rockchip-pm.h>
#include <dt-bindings/sensor-dev.h>
#include "skeleton.dtsi"
#include "rk3288-pinctrl.dtsi"
#include "rk3288-clocks.dtsi"
compatible = "rockchip,rk3288";
rockchip,sram = <&sram>;
interrupt-parent = <&gic>;
aliases {
serial0 = &uart_bt;
serial1 = &uart_bb;
serial2 = &uart_dbg;
serial3 = &uart_gps;
serial4 = &uart_exp;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
lcdc0 = &lcdc0;
lcdc1 = &lcdc1;
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
cpus {
#size-cells = <0>;
cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a15";
reg = <0x500>;
cpu@1 {
reg = <0x501>;
cpu@2 {
reg = <0x502>;
cpu@3 {
reg = <0x503>;
gic: interrupt-controller@ffc01000 {
compatible = "arm,cortex-a15-gic";
interrupt-controller;
#interrupt-cells = <3>;
#address-cells = <0>;
reg = <0xffc01000 0x1000>,
<0xffc02000 0x1000>;
arm-pmu {
compatible = "arm,cortex-a12-pmu";
interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 153 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>;
cpu_axi_bus: cpu_axi_bus {
compatible = "rockchip,cpu_axi_bus";
#size-cells = <1>;
ranges;
qos {
#size-cells = <1>;
ranges;
/* service core */
cpup {
reg = <0xffa80000 0x20>;
cpum_r {
reg = <0xffa80080 0x20>;
cpum_w {
reg = <0xffa80100 0x20>;
/* service dmac */
bus_dmac {
reg = <0xffa90000 0x20>;
host {
reg = <0xffa90080 0x20>;
crypto {
reg = <0xffa90100 0x20>;
ccp {
reg = <0xffa90180 0x20>;
ccs {
reg = <0xffa90200 0x20>;
/* service gpu */
gpu_r {
reg = <0xffaa0000 0x20>;
gpu_w {
reg = <0xffaa0080 0x20>;
/* service peri */
peri {
reg = <0xffab0000 0x20>;
/* service vio */
vio1_vop {
reg = <0xffad0000 0x20>;
rockchip,priority = <2 2>;
vio1_isp_w0 {
reg = <0xffad0100 0x20>;
vio1_isp_w1 {
reg = <0xffad0180 0x20>;
vio0_vop {
reg = <0xffad0400 0x20>;
vio0_vip {
reg = <0xffad0480 0x20>;
vio0_iep {
reg = <0xffad0500 0x20>;
vio2_rga_r {
reg = <0xffad0800 0x20>;
vio2_rga_w {
reg = <0xffad0880 0x20>;
vio1_isp_r {
reg = <0xffad0900 0x20>;
/* service video */
video {
reg = <0xffae0000 0x20>;
/* service hevc */
hevc_r {
reg = <0xffaf0000 0x20>;
hevc_w {
reg = <0xffaf0080 0x20>;
msch {
#size-cells = <1>;
ranges;
msch@0 {
reg = <0xffac0000 0x40>;
rockchip,read-latency = <0x34>;
msch@1 {
reg = <0xffac0080 0x40>;
sram: sram@ff710000 {
compatible = "mmio-sram";
reg = <0xff710000 0x8000>; /* 32k */
map-exec;
timer {
compatible = "arm,armv7-timer";
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
<GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
clock-frequency = <24000000>;
timer@ff810000 {
compatible = "rockchip,timer";
reg = <0xff810000 0x20>;
interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
rockchip,broadcast = <1>;
watchdog: wdt@2004c000 {
compatible = "rockchip,watch dog";
reg = <0xff800000 0x100>;
clocks = <&pclk_pd_alive>;
clock-names = "pclk_wdt";
interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
rockchip,irq = <1>;
rockchip,timeout = <60>;
rockchip,atboot = <1>;
rockchip,debug = <0>;
amba {
#size-cells = <1>;
compatible = "arm,amba-bus";
ranges;
pdma0: pdma@ffb20000 {
compatible = "arm,pl330", "arm,primecell";
reg = <0xffb20000 0x4000>;
clocks = <&clk_gates10 12>;
clock-names = "apb_pclk";
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
#dma-cells = <1>;
pdma1: pdma@ff250000 {
reg = <0xff250000 0x4000>;
clocks = <&clk_gates6 3>;
interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>;
#dma-cells = <1>;
reset: reset@ff7601b8{
compatible = "rockchip,reset";
reg = <0xff7601b8 0x30>;
rockchip,reset-flag = <ROCKCHIP_RESET_HIWORD_MASK>;
#reset-cells = <1>;
nandc0: nandc@0xff400000 {
compatible = "rockchip,rk-nandc";
reg = <0xff400000 0x4000>;
interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
nandc_id = <0>;
clocks = <&clk_nandc0>, <&clk_gates5 5>, <&clk_gates7 14>;
clock-names = "clk_nandc", "g_clk_nandc", "hclk_nandc";
nandc1: nandc@0xff410000 {
reg = <0xff410000 0x4000>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
nandc_id = <1>;
clocks = <&clk_nandc1>, <&clk_gates5 6>, <&clk_gates7 15>;
nandc0reg: nandc0@0xff400000 {
emmc: rksdmmc@ff0f0000 {
compatible = "rockchip,rk_mmc", "rockchip,rk32xx-sdmmc";
reg = <0xff0f0000 0x4000>;
interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
//pinctrl-names = "default",,"suspend";
//pinctrl-0 = <&sd0_clk &sd0_cmd &sd0_cd &sd0_wp &sd0_pwr &sd0_bus1 &sd0_bus4>;
clocks = <&clk_emmc>, <&clk_gates8 6>;
clock-names = "clk_mmc", "hclk_mmc";
num-slots = <1>;
fifo-depth = <0x100>;
bus-width = <8>;
tune_regsbase = <0x218>;
cru_regsbase = <0x1d8>;
cru_reset_offset = <3>;
sdmmc: rksdmmc@ff0c0000 {
reg = <0xff0c0000 0x4000>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-names = "default", "idle";
pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>;
pinctrl-1 = <&sdmmc0_gpio>;
cd-gpios = <&gpio6 GPIO_C6 GPIO_ACTIVE_HIGH>;/*CD GPIO*/
clocks = <&clk_sdmmc>, <&clk_gates8 3>;
num-slots = <1>;
bus-width = <4>;
tune_regsbase = <0x200>;
cru_reset_offset = <0>;
sdio: rksdmmc@ff0d0000 {
reg = <0xff0d0000 0x4000>;
interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-names = "default","idle";
pinctrl-0 = <&sdio0_clk &sdio0_cmd &sdio0_wrprt &sdio0_pwr &sdio0_bkpwr
&sdio0_intn &sdio0_bus4>;
pinctrl-1 = <&sdio0_gpio>;
clocks = <&clk_sdio0>, <&clk_gates8 4>;
num-slots = <1>;
bus-width = <4>;
tune_regsbase = <0x208>;
cru_reset_offset = <1>;
sdio1: rksdmmc@ff0e0000 {
reg = <0xff0e0000 0x4000>;
interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
//pinctrl-names = "default","suspend";
//pinctrl-0 = <&sd1_clk &sd1_cmd &sd1_cd &sd1_wp &sd1_bus1 &sd1_bus4>;
/*gate8_0 --hclk_sdmmc_ahb_arbi_gate_en, gate13_2 --clk_sdio1_src_gate_en*/
clocks = <&clk_sdio1>, <&clk_gates8 5>;
num-slots = <1>;
bus-width = <4>;
cru_reset_offset = <2>;
spi0: spi@ff110000 {
compatible = "rockchip,rockchip-spi";
reg = <0xff110000 0x1000>;
interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-0 = <&spi0_txd &spi0_rxd &spi0_clk &spi0_cs0 &spi0_cs1>;
rockchip,spi-src-clk = <0>;
num-cs = <2>;
clocks =<&clk_spi0>, <&clk_gates6 4>;
clock-names = "spi","pclk_spi0";
dmas = <&pdma1 11>, <&pdma1 12>;
#dma-cells = <2>;
dma-names = "tx", "rx";
spi1: spi@ff120000 {
reg = <0xff120000 0x1000>;
interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-0 = <&spi1_txd &spi1_rxd &spi1_clk &spi1_cs0>;
rockchip,spi-src-clk = <1>;
num-cs = <1>;
clocks = <&clk_spi1>, <&clk_gates6 5>;
clock-names = "spi","pclk_spi1";
dmas = <&pdma1 13>, <&pdma1 14>;
#dma-cells = <2>;
spi2: spi@ff130000 {
reg = <0xff130000 0x1000>;
interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-0 = <&spi2_txd &spi2_rxd &spi2_clk &spi2_cs0 &spi2_cs1>;
rockchip,spi-src-clk = <2>;
num-cs = <2>;
clocks = <&clk_spi2>, <&clk_gates6 6>;
clock-names = "spi","pclk_spi2";
dmas = <&pdma1 15>, <&pdma1 16>;
#dma-cells = <2>;
uart_bt: serial@ff180000 {
compatible = "rockchip,serial";
reg = <0xff180000 0x100>;
interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart0>, <&clk_gates6 8>;
clock-names = "sclk_uart", "pclk_uart";
reg-shift = <2>;
reg-io-width = <4>;
dmas = <&pdma1 1>, <&pdma1 2>;
#dma-cells = <2>;
pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
uart_bb: serial@ff190000 {
reg = <0xff190000 0x100>;
interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart1>, <&clk_gates6 9>;
current-speed = <921600>;
reg-shift = <2>;
reg-io-width = <4>;
dmas = <&pdma1 3>, <&pdma1 4>;
#dma-cells = <2>;
pinctrl-0 = <&uart1_xfer &uart1_cts &uart1_rts>;
uart_dbg: serial@ff690000 {
reg = <0xff690000 0x100>;
interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart2>, <&clk_gates11 9>;
current-speed = <115200>;
reg-shift = <2>;
reg-io-width = <4>;
dmas = <&pdma0 4>, <&pdma0 5>;
#dma-cells = <2>;
pinctrl-0 = <&uart2_xfer>;
uart_gps: serial@ff1b0000 {
reg = <0xff1b0000 0x100>;
interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart3>, <&clk_gates6 11>;
reg-shift = <2>;
reg-io-width = <4>;
dmas = <&pdma1 7>, <&pdma1 8>;
#dma-cells = <2>;
pinctrl-0 = <&uart3_xfer &uart3_cts &uart3_rts>;
uart_exp: serial@ff1c0000 {
reg = <0xff1c0000 0x100>;
interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart4>, <&clk_gates6 12>;
reg-shift = <2>;
reg-io-width = <4>;
dmas = <&pdma1 9>, <&pdma1 10>;
#dma-cells = <2>;
pinctrl-0 = <&uart4_xfer &uart4_cts &uart4_rts>;
fiq-debugger {
compatible = "rockchip,fiq-debugger";
rockchip,serial-id = <2>;
rockchip,signal-irq = <106>;
rockchip,wake-irq = <0>;
rockchip_clocks_init: clocks-init{
compatible = "rockchip,clocks-init";
rockchip,clocks-init-parent =
<&clk_core &clk_apll>, <&aclk_bus_src &clk_gpll>,
<&aclk_peri &clk_gpll>, <&uart_pll_mux &clk_gpll>,
<&clk_i2s_pll &clk_gpll>, <&clk_spdif_pll &clk_gpll>,
<&usbphy_480m &otgphy2_480m>;
rockchip,clocks-init-rate =
<&clk_core 792000000>, <&clk_gpll 594000000>,
/*<&clk_cpll 47000000>,*/ <&clk_npll 1250000000>,
<&aclk_bus_src 300000000>, <&aclk_bus 300000000>,
<&hclk_bus 150000000>, <&pclk_bus 75000000>,
<&clk_crypto 150000000>, <&aclk_peri 300000000>,
<&hclk_peri 150000000>, <&pclk_peri 75000000>,
<&clk_gpu 200000000>, /*<&aclk_vio0 300000000>,
<&aclk_vio1 300000000>, <&hclk_vio 75000000>,*/
<&pclk_pd_alive 100000000>, <&pclk_pd_pmu 100000000>,
<&aclk_hevc 400000000>, <&hclk_hevc 200000000>,
<&clk_hevc_cabac 300000000>, <&clk_hevc_core 300000000>,
<&aclk_rga 300000000>, <&clk_rga 300000000>,
<&clk_vepu 300000000>, <&clk_vdpu 300000000>,
<&clk_edp 200000000>, <&clk_isp 200000000>,
<&clk_isp_jpe 400000000>, <&clk_tsp 80000000>,
<&clk_tspout 80000000>, <&clk_mac 125000000>,
<&aclk_vio0 594000000>;
/* rockchip,clocks-uboot-has-init = <&aclk_vio0>; */
clocks-enable {
compatible = "rockchip,clocks-enable";
clocks =
/*PLL*/
<&clk_dpll>, <&clk_gpll>,
/*PD_CORE*/
<&clk_gates0 2>, <&clk_core0>,
<&clk_core1>, <&clk_core2>,
<&clk_core3>, <&clk_l2ram>,
<&aclk_core_m0>, <&aclk_core_mp>,
<&atclk_core>, <&pclk_dbg_src>,
<&clk_gates12 9>, <&clk_gates12 10>,
<&clk_gates12 11>,
/*PD_BUS*/
<&aclk_bus>, <&clk_gates0 3>,
<&hclk_bus>, <&pclk_bus>,
<&clk_gates13 8>,
<&clk_gates0 7>,
/*TIMER*/
<&clk_gates1 0>, <&clk_gates1 1>,
<&clk_gates1 2>, <&clk_gates1 3>,
<&clk_gates1 4>, <&clk_gates1 5>,
<&pclk_pd_alive>, <&pclk_pd_pmu>,
/*PD_PERI*/
<&aclk_peri>, <&hclk_peri>,
<&pclk_peri>,
/*JTAG*/
/*<&clk_gates4 14>,*/
/*aclk_bus*/
<&clk_gates10 5>,/*aclk_intmem0*/
<&clk_gates10 6>,/*aclk_intmem1*/
<&clk_gates10 7>,/*aclk_intmem2*/
/*<&clk_gates10 12>,*//*aclk_dma1*/
<&clk_gates10 13>,/*aclk_strc_sys*/
<&clk_gates10 4>,/*aclk_intmem*/
/*hclk_bus*/
<&clk_gates10 9>,/*hclk_rom*/
/*pclk_bus*/
<&clk_gates10 1>,/*pclk_timer*/
<&clk_gates10 9>,/*rom*/
<&clk_gates10 13>,/*aclk strc*/
<&clk_gates12 8>,/*aclk strc*/
/*aclk_peri*/
<&clk_gates6 2>,/*aclk_peri_axi_matrix*/
/*<&clk_gates6 3>,*//*aclk_dmac2*/
<&clk_gates7 11>,/*aclk_peri_niu*/
<&clk_gates8 12>,/*aclk_peri_mmu*/
/*hclk_peri*/
<&clk_gates6 0>,/*hclk_peri_matrix*/
<&clk_gates7 10>,/*hclk_peri_ahb_arbi*/
<&clk_gates7 12>,/*hclk_emem_peri*/
<&clk_gates7 13>,/*hclk_mem_peri*/
/*pclk_peri*/
<&clk_gates6 1>,/*pclk_peri_axi_matrix*/
/*pclk_pd_alive*/
<&clk_gates14 11>,/*pclk_grf*/
<&clk_gates14 12>,/*pclk_alive_niu*/
/*pclk_pd_pmu*/
<&clk_gates17 0>,/*pclk_pmu*/
<&clk_gates17 1>,/*pclk_intmem1*/
<&clk_gates17 2>,/*pclk_pmu_niu*/
<&clk_gates17 3>,/*pclk_sgrf*/
/*UART*/
<&clk_gates11 9>,/*pclk_uart2*/
/*480M*/
<&usbphy_480m>;
i2c0: i2c@ff650000 {
compatible = "rockchip,rk30-i2c";
reg = <0xff650000 0x1000>;
interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-names = "default", "gpio";
pinctrl-0 = <&i2c0_sda &i2c0_scl>;
pinctrl-1 = <&i2c0_gpio>;
gpios = <&gpio0 GPIO_B7 GPIO_ACTIVE_LOW>, <&gpio0 GPIO_C0 GPIO_ACTIVE_LOW>;
clocks = <&clk_gates10 2>;
rockchip,check-idle = <1>;
i2c1: i2c@ff140000 {
reg = <0xff140000 0x1000>;
interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-0 = <&i2c1_sda &i2c1_scl>;
pinctrl-1 = <&i2c1_gpio>;
gpios = <&gpio8 GPIO_A4 GPIO_ACTIVE_LOW>, <&gpio8 GPIO_A5 GPIO_ACTIVE_LOW>;
clocks = <&clk_gates6 13>;
i2c2: i2c@ff660000 {
reg = <0xff660000 0x1000>;
interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-0 = <&i2c2_sda &i2c2_scl>;
pinctrl-1 = <&i2c2_gpio>;
gpios = <&gpio6 GPIO_B1 GPIO_ACTIVE_LOW>, <&gpio6 GPIO_B2 GPIO_ACTIVE_LOW>;
clocks = <&clk_gates10 3>;
i2c3: i2c@ff150000 {
reg = <0xff150000 0x1000>;
interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-0 = <&i2c3_sda &i2c3_scl>;
pinctrl-1 = <&i2c3_gpio>;
gpios = <&gpio2 GPIO_C1 GPIO_ACTIVE_LOW>, <&gpio2 GPIO_C0 GPIO_ACTIVE_LOW>;
clocks = <&clk_gates6 14>;
i2c4: i2c@ff160000 {
reg = <0xff160000 0x1000>;
interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-0 = <&i2c4_sda &i2c4_scl>;
pinctrl-1 = <&i2c4_gpio>;
gpios = <&gpio7 GPIO_C1 GPIO_ACTIVE_LOW>, <&gpio7 GPIO_C2 GPIO_ACTIVE_LOW>;
clocks = <&clk_gates6 15>;
i2c5: i2c@ff170000 {
reg = <0xff170000 0x1000>;
interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
pinctrl-0 = <&i2c5_sda &i2c5_scl>;
pinctrl-1 = <&i2c5_gpio>;
gpios = <&gpio7 GPIO_C3 GPIO_ACTIVE_LOW>, <&gpio7 GPIO_C4 GPIO_ACTIVE_LOW>;
clocks = <&clk_gates7 0>;
fb: fb{
compatible = "rockchip,rk-fb";
rk_screen: rk_screen{
compatible = "rockchip,screen";
dsihost0: mipi@ff960000{
compatible = "rockchip,rk32-dsi";
rockchip,prop = <0>;
reg = <0xff960000 0x4000>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates5 15>, <&clk_gates16 4> , <&pd_mipidsi>;
clock-names = "clk_mipi_24m", "pclk_mipi_dsi", "pd_mipi_dsi";
dsihost1: mipi@ff964000{
rockchip,prop = <1>;
reg = <0xff964000 0x4000>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates5 15>, <&clk_gates16 5>, <&pd_mipidsi>;
lvds: lvds@ff96c000 {
compatible = "rockchip,rk32-lvds";
reg = <0xff96c000 0x4000>;
clocks = <&clk_gates16 7>;
clock-names = "pclk_lvds";
edp: edp@ff970000 {
compatible = "rockchip,rk32-edp";
reg = <0xff970000 0x4000>;
interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_edp>, <&clk_edp_24m>, <&clk_gates16 8>;
clock-names = "clk_edp", "clk_edp_24m", "pclk_edp";
hdmi: hdmi@ff980000 {
compatible = "rockchip,rk3288-hdmi";
reg = <0xff980000 0x20000>;
interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default", "sleep";
pinctrl-0 = <&i2c5_sda &i2c5_scl &hdmi_cec>;
clocks = <&clk_gates16 9>, <&clk_gates5 12>, <&clk_gates5 11>;
clock-names = "pclk_hdmi", "hdcp_clk_hdmi", "cec_clk_hdmi";
hdmi_hdcp2: hdmi_hdcp2@ff974000 {
compatible = "rockchip,rk3288-hdmi-hdcp2";
reg = <0xff974000 0x4000>,
<0xff978000 0x4000>;
clocks = <&aclk_hdcp>, <&clk_hdcp>, <&clk_gates15 12>;
clock-names = "aclk_hdcp2", "hdcp2_clk_hdmi", "pclk_hdcp2";
lcdc0: lcdc@ff930000 {
compatible = "rockchip,rk3288-lcdc";
rockchip,pwr18 = <0>;
rockchip,iommu-enabled = <0>;
reg = <0xff930000 0x10000>;
interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&lcdc0_lcdc>;
pinctrl-1 = <&lcdc0_gpio>;
clocks = <&clk_gates15 5>, <&dclk_lcdc0>, <&clk_gates15 6>, <&pd_vop0>;
clock-names = "aclk_lcdc", "dclk_lcdc", "hclk_lcdc", "pd_lcdc";
lcdc1: lcdc@ff940000 {
reg = <0xff940000 0x10000>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates15 7>, <&dclk_lcdc1>, <&clk_gates15 8>, <&pd_vop1>;
adc: adc@ff100000 {
compatible = "rockchip,saradc";
reg = <0xff100000 0x100>;
interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>;
#io-channel-cells = <1>;
io-channel-ranges;
rockchip,adc-vref = <1800>;
clock-frequency = <1000000>;
clocks = <&clk_saradc>, <&clk_gates7 1>;
clock-names = "saradc", "pclk_saradc";
rga@ff920000 {
compatible = "rockchip,rga2";
reg = <0xff920000 0x1000>;
interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates15 1>, <&aclk_rga>, <&clk_rga>;
clock-names = "hclk_rga", "aclk_rga", "clk_rga";
i2s: rockchip-i2s@0xff890000 {
compatible = "rockchip-i2s";
reg = <0xff890000 0x10000>;
i2s-id = <0>;
clocks = <&clk_i2s>, <&clk_i2s_out>, <&clk_gates10 8>;
clock-names = "i2s_clk","i2s_mclk", "i2s_hclk";
interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&pdma0 0>, <&pdma0 1>;
//#dma-cells = <2>;
pinctrl-0 = <&i2s_mclk &i2s_sclk &i2s_lrckrx &i2s_lrcktx &i2s_sdi &i2s_sdo0 &i2s_sdo1 &i2s_sdo2 &i2s_sdo3>;
pinctrl-1 = <&i2s_gpio>;
spdif: rockchip-spdif@0xff8b0000 {
compatible = "rockchip-spdif";
//reg = <0xff8b0000 0x10000>; //8channel
reg = <0xff880000 0x10000>;//2channel
clocks = <&clk_spdif>, <&clk_spdif_8ch>,<&clk_gates10 10>;
clock-names = "spdif_mclk","spdif_8ch_mclk","spdif_hclk";
interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>;
//dmas = <&pdma0 3>;
dmas = <&pdma0 2>; //2channel
//#dma-cells = <1>;
dma-names = "tx";
pinctrl-0 = <&spdif_tx>;
vop1pwm: pwm@ff9401a0 {
compatible = "rockchip,vop-pwm";
reg = <0xff9401a0 0x10>;
#pwm-cells = <2>;
pinctrl-0 = <&vop1_pwm_pin>;
clocks = <&clk_gates13 11>, <&clk_gates15 7>, <&clk_gates15 8>;
clock-names = "pclk_pwm", "aclk_lcdc", "hclk_lcdc";
vop0pwm: pwm@ff9301a0 {
reg = <0xff9301a0 0x10>;
#pwm-cells = <2>;
pinctrl-0 = <&vop0_pwm_pin>;
clocks = <&clk_gates13 10>, <&clk_gates15 5>, <&clk_gates15 6>;
pwm0: pwm@ff680000 {
compatible = "rockchip,rk-pwm";
reg = <0xff680000 0x10>;
/* used by driver on remotectl'pwm */
#pwm-cells = <2>;
pinctrl-0 = <&pwm0_pin>;
clocks = <&clk_gates11 11>;
clock-names = "pclk_pwm";
pwm1: pwm@ff680010 {
reg = <0xff680010 0x10>;
#pwm-cells = <2>;
pinctrl-0 = <&pwm1_pin>;
pwm2: pwm@ff680020 {
reg = <0xff680020 0x10>;
#pwm-cells = <2>;
pinctrl-0 = <&pwm2_pin>;
pwm3: pwm@ff680030 {
reg = <0xff680030 0x10>;
#pwm-cells = <2>;
pinctrl-0 = <&pwm3_pin>;
dvfs {
vd_arm: vd_arm {
regulator_name = "vdd_arm";
suspend_volt = <1000>; //mV
pd_core {
clk_core_dvfs_table: clk_core {
/* KHz uV */
312000 1100000
504000 1100000
816000 1100000
1008000 1100000
channel = <0>;
temp-limit-enable = <1>;
target-temp = <80>;
min_temp_limit = <48>;
normal-temp-limit = <
/*delta-temp delta-freq*/
3 96000
6 144000
9 192000
15 384000
performance-temp-limit = <
/*temp freq*/
100 816000
status = "okay";
regu-mode-table = <
/*freq mode*/
1008000 4
0 3
regu-mode-en = <0>;
vd_logic: vd_logic {
regulator_name = "vdd_logic";
pd_ddr {
clk_ddr_dvfs_table: clk_ddr {
/* KHz uV */
200000 1200000
300000 1200000
400000 1200000
bd-freq-table = <
/* bandwidth freq */
5000 800000
3500 456000
2600 396000
2000 324000
channel = <2>;
pd_vio {
aclk_vio1_dvfs_table: aclk_vio1 {
/* KHz uV */
100000 1100000
500000 1100000
status = "okay";
vd_gpu: vd_gpu {
regulator_name = "vdd_gpu";
pd_gpu {
clk_gpu_dvfs_table: clk_gpu {
/* KHz uV */
200000 1200000
300000 1200000
400000 1200000
channel = <1>;
temp-limit-enable = <0>;
target-temp = <90>;
min_temp_limit = <200>;
3 50000
6 150000
15 250000
status = "okay";
regu-mode-table = <
/*freq mode*/
200000 4
0 3
regu-mode-en = <0>;
ion {
compatible = "rockchip,ion";
#size-cells = <0>;
ion_drm: rockchip,ion-heap@5 {
compatible = "rockchip,ion-heap";
rockchip,ion_heap = <5>;
reg = <0x00000000 0x00000000>;
ion_cma: rockchip,ion-heap@4 { /* CMA HEAP */
rockchip,ion_heap = <4>;
reg = <0x00000000 0x28000000>; /* 640MB */
rockchip,ion-heap@0 { /* VMALLOC HEAP */
rockchip,ion_heap = <0>;
vpu: vpu_service@ff9a0000 {
compatible = "vpu_service";
iommu_enabled = <0>;
reg = <0xff9a0000 0x800>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "irq_enc", "irq_dec";
clocks = <&clk_vdpu>, <&hclk_vdpu>;
clock-names = "aclk_vcodec", "hclk_vcodec";
resets = <&reset RK3288_SOFT_RST_VCODEC_H>, <&reset RK3288_SOFT_RST_VCODEC_A>;
reset-names = "video_h", "video_a";
name = "vpu_service";
dev_mode = <0>;
//status = "disabled";
hevc: hevc_service@ff9c0000 {
compatible = "rockchip,hevc_service";
reg = <0xff9c0000 0x800>;
interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "irq_dec";
clocks = <&aclk_hevc>, <&hclk_hevc>, <&clk_hevc_core>, <&clk_hevc_cabac>;
clock-names = "aclk_vcodec", "hclk_vcodec", "clk_core", "clk_cabac";
resets = <&reset RK3288_SOFT_RST_VCODEC_H>, <&reset RK3288_SOFT_RST_VCODEC_A>,
<&reset RK3288_SOFT_RST_HEVC>;
reset-names = "video_h", "video_a", "video";
dev_mode = <1>;
name = "hevc_service";
iep: iep@ff900000 {
compatible = "rockchip,iep";
reg = <0xff900000 0x800>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates15 2>, <&clk_gates15 3>;
clock-names = "aclk_iep", "hclk_iep";
status = "okay";
dwc_control_usb: dwc-control-usb@ff770284 {
compatible = "rockchip,rk3288-dwc-control-usb";
reg = <0xff770284 0x04>, <0xff770288 0x04>,
<0xff7702cc 0x04>, <0xff7702d4 0x04>,
<0xff770320 0x14>, <0xff770334 0x14>,
<0xff770348 0x10>, <0xff770358 0x08>,
<0xff770360 0x08>;
reg-names = "GRF_SOC_STATUS1" ,"GRF_SOC_STATUS2",
"GRF_SOC_STATUS19", "GRF_SOC_STATUS21",
"GRF_UOC0_BASE", "GRF_UOC1_BASE",
"GRF_UOC2_BASE", "GRF_UOC3_BASE",
"GRF_UOC4_BASE";
interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "otg_id", "otg_bvalid",
"otg_linestate", "host0_linestate",
"host1_linestate";
clocks = <&clk_gates7 9>, <&usbphy_480m>,
<&otgphy1_480m>, <&otgphy2_480m>;
clock-names = "hclk_usb_peri", "usbphy_480m",
"usbphy1_480m", "usbphy2_480m";
usb_bc {
compatible = "synopsys,phy";
/* offset bit mask */
rk_usb,bvalid = <0x288 14 1>;
rk_usb,iddig = <0x288 17 1>;
rk_usb,dcdenb = <0x328 14 1>;
rk_usb,vdatsrcenb = <0x328 7 1>;
rk_usb,vdatdetenb = <0x328 6 1>;
rk_usb,chrgsel = <0x328 5 1>;
rk_usb,chgdet = <0x2cc 23 1>;
rk_usb,fsvminus = <0x2cc 25 1>;
rk_usb,fsvplus = <0x2cc 24 1>;
usb0: usb@ff580000 {
compatible = "rockchip,rk3288_usb20_otg";
reg = <0xff580000 0x40000>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates13 4>, <&clk_gates7 4>;
clock-names = "clk_usbphy0", "hclk_usb0";
resets = <&reset RK3288_SOFT_RST_USBOTG_H>, <&reset RK3288_SOFT_RST_USBOTGPHY>,
<&reset RK3288_SOFT_RST_USBOTGC>;
reset-names = "otg_ahb", "otg_phy", "otg_controller";
/*0 - Normal, 1 - Force Host, 2 - Force Device*/
rockchip,usb-mode = <0>;
usb1: usb@ff540000 {
compatible = "rockchip,rk3288_usb20_host";
reg = <0xff540000 0x40000>;
interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates13 6>, <&clk_gates7 7>,
<&usbphy_480m>;
clock-names = "clk_usbphy1", "hclk_usb1",
"usbphy_480m";
resets = <&reset RK3288_SOFT_RST_USBHOST1_H>, <&reset RK3288_SOFT_RST_USBHOST1PHY>,
<&reset RK3288_SOFT_RST_USBHOST1C>;
reset-names = "host1_ahb", "host1_phy", "host1_controller";
usb2: usb@ff500000 {
compatible = "rockchip,rk3288_rk_ehci_host";
reg = <0xff500000 0x20000>;
interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_gates13 5>, <&clk_gates7 6>;
clock-names = "clk_usbphy2", "hclk_usb2";
resets = <&reset RK3288_SOFT_RST_USBHOST0_H>, <&reset RK3288_SOFT_RST_USBHOST0PHY>,
<&reset RK3288_SOFT_RST_USBHOST0C>, <&reset RK3288_SOFT_RST_USB_HOST0>;
reset-names = "ehci_ahb", "ehci_phy", "ehci_controller", "ehci";
usb3: usb@ff520000 {
compatible = "rockchip,rk3288_rk_ohci_host";
reg = <0xff520000 0x20000>;
interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
clock-names = "clk_usbphy3", "hclk_usb3";
status = "okay";
usb4: usb@ff5c0000 {
compatible = "rockchip,rk3288_rk_ehci1_host";
reg = <0xff5c0000 0x40000>;
interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ehci1phy_480m>, <&clk_gates7 8>,
<&ehci1phy_12m>, <&usbphy_480m>,
clock-names = "ehci1phy_480m", "hclk_ehci1",
"ehci1phy_12m", "usbphy_480m",
"ehci1_usbphy1", "ehci1_usbphy2";
resets = <&reset RK3288_SOFT_RST_EHCI1>, <&reset RK3288_SOFT_RST_EHCI1_AUX>,
<&reset RK3288_SOFT_RST_EHCI1PHY>;
reset-names = "ehci1_ahb", "ehci1_aux", "ehci1_phy";
gmac: eth@ff290000 {
compatible = "rockchip,rk3288-gmac";
reg = <0xff290000 0x10000>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; /*irq=59*/
interrupt-names = "macirq";
clocks = <&clk_mac>, <&clk_gates5 0>,
<&clk_gates5 1>, <&clk_gates5 2>,
<&clk_gates5 3>, <&clk_gates8 0>,
<&clk_gates8 1>;
clock-names = "clk_mac", "mac_clk_rx",
"mac_clk_tx", "clk_mac_ref",
"clk_mac_refout", "aclk_mac",
"pclk_mac";
phy-mode = "rgmii";
pinctrl-0 = <&mac_clk &mac_txpins &mac_rxpins &mac_mdpins>;
gpu {
compatible = "arm,malit764",
"arm,malit76x",
"arm,malit7xx",
"arm,mali-midgard";
reg = <0xffa30000 0x10000>;
interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "JOB", "MMU", "GPU";
iep_mmu {
dbgname = "iep";
compatible = "rockchip,iep_mmu";
reg = <0xff900800 0x100>;
interrupt-names = "iep_mmu";
vip_mmu {
dbgname = "vip";
compatible = "rockchip,vip_mmu";
reg = <0xff950800 0x100>;
interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "vip_mmu";
vopb_mmu {
dbgname = "vopb";
compatible = "rockchip,vopb_mmu";
reg = <0xff930300 0x100>;
interrupt-names = "vopb_mmu";
vopl_mmu {
dbgname = "vopl";
compatible = "rockchip,vopl_mmu";
reg = <0xff940300 0x100>;
interrupt-names = "vopl_mmu";
hevc_mmu {
dbgname = "hevc";
compatible = "rockchip,hevc_mmu";
reg = <0xff9c0440 0x40>,
<0xff9c0480 0x40>;
interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "hevc_mmu";
vpu_mmu {
dbgname = "vpu";
compatible = "rockchip,vpu_mmu";
reg = <0xff9a0800 0x100>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "vpu_mmu";
isp_mmu {
dbgname = "isp_mmu";
compatible = "rockchip,isp_mmu";
reg = <0xff914000 0x100>,
<0xff915000 0x100>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "isp_mmu";
rockchip_suspend {
rockchip,ctrbits = <
(0
|RKPM_CTR_PWR_DMNS
|RKPM_CTR_GTCLKS
|RKPM_CTR_PLLS
// |RKPM_CTR_GPIOS
// |RKPM_CTR_SYSCLK_DIV
// |RKPM_CTR_IDLEAUTO_MD
// |RKPM_CTR_ARMOFF_LPMD
|RKPM_CTR_ARMOFF_LOGDP_LPMD
rockchip,pmic-suspend_gpios = <
RKPM_PINGPIO_BITS_OUTPUT(GPIO7_A1,RKPM_GPIO_OUT_H)
rockchip,pmic-resume_gpios = <
RKPM_PINGPIO_BITS_FUN(PWM1,RKPM_GPIO_PULL_DN)
isp: isp@ff910000{
compatible = "rockchip,isp";
reg = <0xff910000 0x10000>;
clocks = <&clk_gates16 2>, <&clk_gates16 1>, <&clk_isp>, <&clk_isp_jpe>, <&clkin_isp>, <&clk_cif_out>, <&clk_gates5 15>, <&clk_cif_pll>, <&pd_isp>, <&clk_gates16 6>;
clock-names = "aclk_isp", "hclk_isp", "clk_isp", "clk_isp_jpe", "pclkin_isp", "clk_cif_out", "clk_mipi_24m", "clk_cif_pll", "pd_isp", "hclk_mipiphy1";
pinctrl-names = "default", "isp_dvp8bit2", "isp_dvp10bit", "isp_dvp12bit", "isp_dvp8bit0", "isp_mipi_fl", "isp_mipi_fl_prefl","isp_flash_as_gpio","isp_flash_as_trigger_out";
pinctrl-0 = <&isp_mipi>;
pinctrl-1 = <&isp_mipi &isp_dvp_d2d9>;
pinctrl-2 = <&isp_mipi &isp_dvp_d2d9 &isp_dvp_d0d1>;
pinctrl-3 = <&isp_mipi &isp_dvp_d2d9 &isp_dvp_d0d1 &isp_dvp_d10d11>;
pinctrl-4 = <&isp_mipi &isp_dvp_d0d7>;
pinctrl-5 = <&isp_mipi>;
pinctrl-6 = <&isp_mipi &isp_prelight>;
pinctrl-7 = <&isp_flash_trigger_as_gpio>;
pinctrl-8 = <&isp_flash_trigger>;
rockchip,isp,mipiphy = <2>;
rockchip,isp,cifphy = <1>;
rockchip,isp,mipiphy1,reg = <0xff968000 0x4000>;
rockchip,gpios = <&gpio7 GPIO_B5 GPIO_ACTIVE_HIGH>;
//FireFly
gpios-cifpower = <&gpio7 GPIO_B4 GPIO_ACTIVE_HIGH>;
gpios-dvppower = <&gpio0 GPIO_B3 GPIO_ACTIVE_HIGH>;
rockchip,isp,iommu_enable = <1>;
status = "okay";
cif: cif@ff950000 {
compatible = "rockchip,cif";
reg = <0xff950000 0x10000>;
clocks = <&pd_isp>,<&clk_gates15 14>,<&clk_gates15 15>,<&clkin_cif>,<&clk_gates16 0>,<&clk_cif_out>;
clock-names = "pd_cif0", "aclk_cif0","hclk_cif0","cif0_in","g_pclkin_cif","cif0_out";
pinctrl-names = "cif_pin_all";
pinctrl-0 = <&isp_mipi &isp_dvp_d2d9 &isp_dvp_d10d11>;
status = "okay";
tsadc: tsadc@ff280000 {
compatible = "rockchip,tsadc";
reg = <0xff280000 0x100>;
interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
io-channel-ranges;
clock-frequency = <10000>;
clocks = <&clk_tsadc>, <&clk_gates7 2>;
clock-names = "tsadc", "pclk_tsadc";
pinctrl-names = "default", "tsadc_int";
pinctrl-0 = <&tsadc_gpio>;
pinctrl-1 = <&tsadc_int>;
tsadc-ht-temp = <120>;
tsadc-ht-reset-cru = <1>;
tsadc-ht-pull-gpio = <0>;
status = "okay";
lcdc_vdd_domain: lcdc-vdd-domain {
compatible = "rockchip,io_vol_domain";
pinctrl-names = "default", "1.8V", "3.3V";
pinctrl-0 = <&lcdc_vcc>;
pinctrl-1 = <&lcdc_vcc_18>;
pinctrl-2 = <&lcdc_vcc_33>;
dpio_vdd_domain: dpio-vdd-domain {
pinctrl-0 = <&dvp_vcc>;
pinctrl-1 = <&dvp_vcc_18>;
pinctrl-2 = <&dvp_vcc_33>;
flash0_vdd_domain: flash0-vdd-domain {
pinctrl-0 = <&flash0_vcc>;
pinctrl-1 = <&flash0_vcc_18>;
pinctrl-2 = <&flash0_vcc_33>;
flash1_vdd_domain: flash1-vdd-domain {
pinctrl-0 = <&flash1_vcc>;
pinctrl-1 = <&flash1_vcc_18>;
pinctrl-2 = <&flash1_vcc_33>;
apio3_vdd_domain: apio3-vdd-domain {
pinctrl-0 = <&wifi_vcc>;
pinctrl-1 = <&wifi_vcc_18>;
pinctrl-2 = <&wifi_vcc_33>;
apio5_vdd_domain: apio5-vdd-domain {
pinctrl-0 = <&bb_vcc>;
pinctrl-1 = <&bb_vcc_18>;
pinctrl-2 = <&bb_vcc_33>;
apio4_vdd_domain: apio4-vdd-domain {
pinctrl-0 = <&audio_vcc>;
pinctrl-1 = <&audio_vcc_18>;
pinctrl-2 = <&audio_vcc_33>;
apio1_vdd_domain: apio0-vdd-domain {
pinctrl-0 = <&gpio30_vcc>;
pinctrl-1 = <&gpio30_vcc_18>;
pinctrl-2 = <&gpio30_vcc_33>;
apio2_vdd_domain: apio2-vdd-domain {
pinctrl-0 = <&gpio1830_vcc>;
pinctrl-1 = <&gpio1830_vcc_18>;
pinctrl-2 = <&gpio1830_vcc_33>;
sdmmc0_vdd_domain: sdmmc0-vdd-domain {
pinctrl-0 = <&sdcard_vcc>;
pinctrl-1 = <&sdcard_vcc_18>;
pinctrl-2 = <&sdcard_vcc_33>;
chosen {
bootargs = "vmalloc=496M";
