RK3288 烧录固件后无法启动
使用的官网的烧录工具,烧录的是ubuntu16.04,板子已经使用了7、8个月了,
烧录之后无法启动,以下是采集的log ,请教各位大神是驱动问题还是硬件问题呢,谢谢!
2018-07-07 14:07:19接收数据(ASCII 长度:1):.
2018-07-07 14:07:20接收数据(ASCII 长度:1295):DDR Version 1.00 20141007..In..Channel a: DDR3 200MHz..Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB..Channel b: DDR3 200MHz..Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB..Memory OK..Memory OK..OUT…U-Boot 2014.10-RK3288-01 (Jan 21 2015 - 16:36:44)…CPU: rk3288..CPU’s clock information:.. arm pll = 600000000HZ.. periph pll = 297000000HZ.. ddr pll = 200000000HZ.. codec pll = 384000000HZ..Board:.Rockchip platform Board..DRAM: Found dram banks:1..Adding bank:0000000000000000(0000000080000000)..128 MiB..storage init OK!..Using default environment…GetParam..check parameter success..Unknow param: MACHINE_MODEL:rk3288!..Unknow param: MACHINE_ID:007!..Unknow param: MANUFACTURER:RK3288!..Unknow param: PWR_HLD: 0,0,A,0,1 !..
no adc node..light power led: bank-8 pin-2..can’t find dts node for ricoh619..can’t find dts node for act8846..can’t find dts node for rk808..can’t find dts node for rk818..Can’t find dts node for fuel guage cw201x..SecureBootEn = 0, SecureBootLock = 0…#Boot ver: 2015-01-21#2.19..empty serial no…checkKey..vbus = 0..no fuel gauge found..no fuel gauge found..read logo_on switch from dts [0]..no fuel gauge found..failed to find part:misc..misc partition not found!..Hit any key to stop autoboot: 1
2018-07-07 14:07:22接收数据(ASCII 长度:256):… 0 ..kernel @ 0x02000000 (0x006f9388)..ramdisk @ 0x04bf0000 (0x00298858)..Secure Boot state: 0..bootrk: do_bootm_linux… Loading Device Tree to 0481d000, end 0482b2b9 … OK..Add bank:0000000000000000, 0000000080000000…Starting kernel …
2018-07-07 14:07:24接收数据(ASCII 长度:10240):[ 0.000000] Booting Linux on physical CPU 0x500..[ 0.000000] Initializing cgroup subsys cpuset..[ 0.000000] Initializing cgroup subsys cpu..[ 0.000000] Initializing cgroup subsys cpuacct..[ 0.000000] Linux version 4.4.52 (whh@esky14) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #25 SMP Tue May 16 16:07:58 HKT 2017..[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d..[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache..[ 0.000000] Machine model: Firefly-RK3288..[ 0.000000] Memory policy: Data cache writealloc..[ 0.000000] PERCPU: Embedded 13 pages/cpu @eef8d000 s24448 r8192 d20608 u53248..[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522752..[ 0.000000] Kernel command line: earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2 root=/dev/block/mtd/by-name/linuxroot linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00010000@0x00002000(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot) storagemedia=emmc loader.timestamp=2015-01-21_16:36:44..[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)..[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)..[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)..[ 0.000000] Memory: 2058968K/2097152K available (11264K kernel code, 849K rwdata, 2924K rodata, 1024K init, 588K bss, 38184K reserved, 0K cma-reserved, 1310720K highmem)..[ 0.000000] Virtual kernel memory layout:..[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)..[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)..[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)..[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)..[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)..[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)..[ 0.000000] .text : 0xc0008000 - 0xc0c00000 (12256 kB)..[ 0.000000] .init : 0xc1000000 - 0xc1100000 (1024 kB)..[ 0.000000] .data : 0xc1100000 - 0xc11d44b0 ( 850 kB)..[ 0.000000] .bss : 0xc11d6000 - 0xc126912c ( 589 kB)..[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1..[ 0.000000] Hierarchical RCU implementation…[ 0.000000] .Build-time adjustment of leaf fanout to 32…[ 0.000000] NR_IRQS:16 nr_irqs:16 16..[ 0.000000] L2C: failed to init: -19..[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys)…[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns..[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns..[ 0.000027] Switching to timer-based delay loop, resolution 41ns..[ 0.002400] Console: colour dummy device 80x30..
[ 0.003581] console [tty0] enabled..
[ 0.003635] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)..
[ 0.003710] pid_max: default: 32768 minimum: 301..
[ 0.003848] Security Framework initialized..
[ 0.003888] Yama: becoming mindful…
[ 0.003983] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)..
[ 0.004032] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)..
[ 0.005000] Initializing cgroup subsys devices..
[ 0.005054] Initializing cgroup subsys freezer..
[ 0.005116] CPU: Testing write buffer coherency: ok..
[ 0.005189] ftrace: allocating 40338 entries in 119 pages..
[ 0.101841] CPU0: update cpu_capacity 430..
[ 0.101886] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500..
[ 0.102268] Setting up static identity map for 0x100000 - 0x100058..
[ 0.105468] CPU1: update cpu_capacity 430..
[ 0.105475] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501..
[ 0.107321] CPU2: update cpu_capacity 430..
[ 0.107329] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502..
[ 0.109151] CPU3: update cpu_capacity 430..
[ 0.109159] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503..
[ 0.109253] Brought up 4 CPUs..
[ 0.109404] SMP: Total of 4 processors activated (192.00 BogoMIPS)…
[ 0.109431] CPU: All CPU(s) started in SVC mode…
[ 0.111050] devtmpfs: initialized..
[ 0.128953] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0..
[ 0.129428] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns..
[ 0.129495] futex hash table entries: 1024 (order: 4, 65536 bytes)..
[ 0.130048] pinctrl core: initialized pinctrl subsystem..
[ 0.131272] NET: Registered protocol family 16..
[ 0.132461] DMA: preallocated 256 KiB pool for atomic coherent allocations..
[ 0.161586] cpuidle: using governor ladder..
[ 0.191612] cpuidle: using governor menu..
[ 0.223336] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers…
[ 0.223387] hw-breakpoint: maximum watchpoint size is 4 bytes…
[ 0.286546] iommu: Adding device ff930000.vop to group 0..
[ 0.286690] iommu: Adding device ff940000.vop to group 1..
[ 0.286814] iommu: Adding device ff9a0000.vpu-service to group 2..
[ 0.286933] iommu: Adding device ff9c0000.hevc-service to group 3..
[ 0.289495] SCSI subsystem initialized..
[ 0.289829] usbcore: registered new interface driver usbfs..
[ 0.289923] usbcore: registered new interface driver hub..
[ 0.290009] usbcore: registered new device driver usb..
[ 0.290191] Linux video capture interface: v2.00..
[ 0.290261] pps_core: LinuxPPS API ver. 1 registered..
[ 0.290289] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>..
[ 0.290355] PTP clock support registered..
[ 0.291841] Advanced Linux Sound Architecture Driver Initialized…
[ 0.292703] Bluetooth: Core ver 2.21..[ 0.292769] NET: Registered protocol family 31..
[ 0.292796] Bluetooth: HCI device and connection manager initialized..
[ 0.292832] Bluetooth: HCI socket layer initialized..
[ 0.292865] Bluetooth: L2CAP socket layer initialized..
[ 0.292921] Bluetooth: SCO socket layer initialized..
[ 0.294623] clocksource: Switched to clocksource arch_sys_counter..
[ 0.359087] NET: Registered protocol family 2..
[ 0.359870] TCP established hash table entries: 8192 (order: 3, 32768 bytes)..
[ 0.359997] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)..
[ 0.360435] TCP: Hash tables configured (established 8192 bind 8192)..
[ 0.360545] UDP hash table entries: 512 (order: 2, 24576 bytes)..
[ 0.360638] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)..
[ 0.360971] NET: Registered protocol family 1..
[ 0.361424] RPC: Registered named UNIX socket transport module…
[ 0.361459] RPC: Registered udp transport module…
[ 0.361484] RPC: Registered tcp transport module…
[ 0.361509] RPC: Registered tcp NFSv4.1 backchannel transport module…
[ 0.361845] Trying to unpack rootfs image as initramfs…
[ 0.561613] Freeing initrd memory: 2660K (c4bf0000 - c4e89000)..
[ 0.562879] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available..
[ 0.565842] Initialise system trusted keyring..
[ 0.577749] squashfs: version 4.0 (2009/01/31) Phillip Lougher..
[ 0.580064] NFS: Registering the id_resolver key type..
[ 0.580123] Key type id_resolver registered..
[ 0.580150] Key type id_legacy registered..
[ 0.580195] Installing knfsd (copyright (C) 1996 okir@monad.swb.de)…
[ 0.581051] fuse init (API version 7.23)..
[ 0.587112] NET: Registered protocol family 38..
[ 0.587175] Key type asymmetric registered..
[ 0.587209] Asymmetric key parser ‘x509’ registered..
[ 0.587334] bounce: pool size: 64 pages..
[ 0.587605] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)..
[ 0.587661] io scheduler noop registered..
[ 0.587695] io scheduler deadline registered..
[ 0.587758] io scheduler cfq registered (default)..
[ 0.588258] rockchip-usb-phy ff770000.syscon:usbphy: vbus_drv is not assigned! ..
[ 0.591260] rk-vcodec ff9a0000.vpu-service: No core reset resource define..
[ 0.591339] rk-vcodec ff9a0000.vpu-service: do not have pd_video..
[ 0.591397] rk-vcodec ff9a0000.vpu-service: probe device..
[ 0.591480] rk-vcodec ff9a0000.vpu-service: vpu mmu dec eeb10a10..
[ 0.591548] rk-vcodec ff9a0000.vpu-service: checking hw id 4831..
[ 0.592228] rk-vcodec ff9a0000.vpu-service: allocator is drm..
[ 0.592586] rk-vcodec ff9a0000.vpu-service: init success..
[ 0.593068] rk-vcodec ff9c0000.hevc-service: No aclk reset resource define..
[ 0.593104] rk-vcodec ff9c0000.hevc-service: No hclk reset resource define..
[ 0.593145] rk-vcodec ff9c0000.hevc-service: failed on clk_get pd_hevc..
[ 0.593261] rk-vcodec ff9c0000.hevc-service: do not have pd_video..
[ 0.593308] rk-vcodec ff9c0000.hevc-service: probe device..
[ 0.593388] rk-vcodec ff9c0000.hevc-service: vpu mmu dec eeb10e10..
[ 0.593446] rk-vcodec ff9c0000.hevc-service: checking hw id 6867..
[ 0.593927] rk-vcodec ff9c0000.hevc-service: allocator is drm..
[ 0.594239] rk-vcodec ff9c0000.hevc-service: init success..
[ 0.597064] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330..
[ 0.597116] dma-pl330 ff250000.dma-controller: .DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16..
[ 0.598098] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330..
[ 0.598147] dma-pl330 ffb20000.dma-controller: .DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10..
[ 0.598910] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled..
[ 0.601135] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud = 1500000) is a 16550A..
[ 0.602052] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud = 1500000) is a 16550A..
[ 0.602954] console [ttyS2] disabled..
[ 0.603028] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 39, base_baud = 1500000) is a 16550A..
[ 1.479122] console [ttyS2] enabled..
[ 1.483541] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 40, base_baud = 1500000) is a 16550A..
[ 1.494030] [drm:drm_core_i
2018-07-07 14:07:25接收数据(ASCII 长度:10240):nit] Initialized drm 1.1.0 20060810..
[ 1.504935] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0c51650)..
[ 1.512519] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0c51650)..
[ 1.520002] rockchip-drm display-subsystem: failed to bind ff980000.hdmi (ops 0xc0c4e334): -517..
[ 1.529177] rockchip-drm display-subsystem: master bind failed: -517..
[ 1.535890] usbcore: registered new interface driver udl..
[ 1.543430] mali ffa30000.gpu: Failed to get regulator..
[ 1.548615] mali ffa30000.gpu: Power control initialization failed..
[ 1.555028] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 389; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-fffa36b’, rk_ko_ver is ‘5’, built at ‘16:06:37’, on ‘May 16 2017’…
[ 1.576275] Mali: Mali device driver loaded..
[ 1.581779] brd: module loaded..
[ 1.592632] loop: module loaded..
[ 1.596706] zram: Added device: zram0..
[ 1.600421] lkdtm: No crash points registered, enable through debugfs..
[ 1.608980] tun: Universal TUN/TAP device driver, 1.6..
[ 1.614055] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>..
[ 1.621931] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing..
[ 1.631659] PPP generic driver version 2.4.2..
[ 1.636326] usbcore: registered new interface driver rndis_wlan..
[ 1.642492] usbcore: registered new interface driver rt2800usb..
[ 1.648460] Rockchip WiFi SYS interface (V1.00) … ..
[ 1.653490] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver..
[ 1.661002] usbcore: registered new interface driver pegasus..
[ 1.666758] usbcore: registered new interface driver rtl8150..
[ 1.672492] usbcore: registered new interface driver r8152.
.[ 1.678091] usbcore: registered new interface driver asix..
[ 1.683567] usbcore: registered new interface driver ax88179_178a..
[ 1.689752] usbcore: registered new interface driver cdc_ether..
[ 1.695683] usbcore: registered new interface driver dm9601..
[ 1.701349] usbcore: registered new interface driver smsc75xx..
[ 1.707206] usbcore: registered new interface driver smsc95xx..
[ 1.713029] usbcore: registered new interface driver net1080..
[ 1.718788] usbcore: registered new interface driver rndis_host..
[ 1.724809] usbcore: registered new interface driver MOSCHIP usb-ethernet driver..
[ 1.732336] usbcore: registered new interface driver cdc_ncm..
[ 1.738094] usbcore: registered new interface driver cdc_mbim..
[ 1.744308] ff540000.usb supply vusb_d not found, using dummy regulator..
[ 1.751031] ff540000.usb supply vusb_a not found, using dummy regulator..
[ 1.874837] dwc2 ff540000.usb: DWC OTG Controller..
[ 1.879592] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1..
[ 1.886732] dwc2 ff540000.usb: irq 44, io mem 0x00000000..
[ 1.892352] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002..
[ 1.899185] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1..
[ 1.906450] usb usb1: Product: DWC OTG Controller..
[ 1.911172] usb usb1: Manufacturer: Linux 4.4.52 dwc2_hsotg..
[ 1.916774] usb usb1: SerialNumber: ff540000.usb..
[ 1.922209] hub 1-0:1.0: USB hub found..
[ 1.926042] hub 1-0:1.0: 1 port detected..
[ 1.930712] ff580000.usb supply vusb_d not found, using dummy regulator..
[ 1.937431] ff580000.usb supply vusb_a not found, using dummy regulator..
[ 2.214671] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM..
[ 2.222391] dwc2 ff580000.usb: DWC OTG Controller..
[ 2.227175] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2..
[ 2.234268] dwc2 ff580000.usb: irq 45, io mem 0x00000000..
[ 2.239810] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002..
[ 2.246640] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1..
[ 2.253887] usb usb2: Product: DWC OTG Controller..
[ 2.258633] usb usb2: Manufacturer: Linux 4.4.52 dwc2_hsotg..
[ 2.264222] usb usb2: SerialNumber: ff580000.usb..
[ 2.269686] hub 2-0:1.0: USB hub found..
[ 2.273492] hub 2-0:1.0: 1 port detected..
[ 2.279173] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver..
[ 2.285758] ehci-platform: EHCI generic platform driver..
[ 2.291465] usbcore: registered new interface driver cdc_acm..
[ 2.297161] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters..
[ 2.305280] usbcore: registered new interface driver cdc_wdm..
[ 2.311077] usbcore: registered new interface driver usb-storage..
[ 2.317246] usbcore: registered new interface driver usbserial..
[ 2.323144] usbcore: registered new interface driver usbserial_generic..
[ 2.329733] usb 1-1: new high-speed USB device number 2 using dwc2..
[ 2.336045] usbserial: USB Serial support registered for generic..
[ 2.342143] usbcore: registered new interface driver cp210x..
[ 2.347799] usbserial: USB Serial support registered for cp210x..
[ 2.353813] usbcore: registered new interface driver ftdi_sio..
[ 2.359636] usbserial: USB Serial support registered for FTDI USB Serial Device..
[ 2.367127] usbcore: registered new interface driver keyspan..
[ 2.372841] usbserial: USB Serial support registered for Keyspan - (without firmware)..
[ 2.380751] usbserial: USB Serial support registered for Keyspan 1 port adapter..
[ 2.388143] usbserial: USB Serial support registered for Keyspan 2 port adapter..
[ 2.395531] usbserial: USB Serial support registered for Keyspan 4 port adapter..
[ 2.402932] usbcore: registered new interface driver option..
[ 2.408583] usbserial: USB Serial support registered for GSM modem (1-port)..
[ 2.415751] usbcore: registered new interface driver oti6858..
[ 2.421465] usbserial: USB Serial support registered for oti6858..
[ 2.427571] usbcore: registered new interface driver pl2303..
[ 2.433197] usbserial: USB Serial support registered for pl2303..
[ 2.439219] usbcore: registered new interface driver qcserial..
[ 2.445041] usbserial: USB Serial support registered for Qualcomm USB modem..
[ 2.452090] usbcore: registered new interface driver sierra..
[ 2.457738] usbserial: USB Serial support registered for Sierra USB modem..
[ 2.465728] usbcore: registered new interface driver iforce..
[ 2.471421] usbcore: registered new interface driver xpad..
[ 2.477073] usbcore: registered new interface driver usbtouchscreen..
[ 2.483732] i2c /dev entries driver..
[ 2.488191] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f08f8000..
[ 2.495749] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f08fa000..
[ 2.503212] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f08fc000..
[ 2.511384] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!..
[ 2.518671] vdd_cpu: No configuration..
[ 2.524006] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!..
[ 2.531277] vdd_gpu: No configuration..
[ 2.538732] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0..
[ 2.545047] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101..
[ 2.545057] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0..
[ 2.545064] usb 1-1: Product: USB 2.0 Hub [MTT]..
[ 2.545808] hub 1-1:1.0: USB hub found..
[ 2.545903] hub 1-1:1.0: 4 ports detected..
[ 2.580423] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f08fe000..
[ 2.588005] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0912000..
[ 2.595743] usbcore: registered new interface driver uvcvideo..
[ 2.601506] USB Video Class driver (1.1.1)..
[ 2.606434] vcc_io: supplied by vcc_sys..
[ 2.610959] vcc28_dvp: supplied by vcc_io..
[ 2.615208] dovdd_1v8: supplied by vcc28_dvp..
[ 2.619637] vcc_flash: supplied by vcc_io..
[ 2.623964] vcc_lan: supplied by vcc_sys..
[ 2.628388] vcc_20: supplied by vcc_sys..
[ 2.632431] vcc_18: supplied by vcc_20..
[ 2.637328] vcca_33: supplied by vcc_sys..
[ 2.641846] vccio_sd: supplied by vcc_sys..
[ 2.647799] rockchip_cpu_avs: cluster0 leakage=15 adjust_volt=0..
[ 2.655011] rockchip-thermal ff280000.tsadc: Missing rockchip,grf property..
[ 2.663173] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com..
[ 2.671884] Bluetooth: Virtual HCI driver ver 1.5..
[ 2.676823] Bluetooth: HCI UART driver ver 2.3..
[ 2.681287] Bluetooth: HCI UART protocol H4 registered..
[ 2.686460] Bluetooth: HCI UART protocol LL registered..
[ 2.691612] Bluetooth: HCI UART protocol ATH3K registered..
[ 2.697146] usbcore: registered new interface driver bfusb..
[ 2.702737] usbcore: registered new interface driver btusb..
[ 2.708568] vdd_cpu: supplied by vcc_sys..
[ 2.716276] cpufreq-dt cpufreq-dt: failed register driver: -17..
[ 2.722145] cpufreq-dt: probe of cpufreq-dt failed with error -17..
[ 2.728380] sdhci: Secure Digital Host Controller Interface driver..
[ 2.734574] sdhci: Copyright(c) Pierre Ossman..
[ 2.738983] Synopsys Designware Multimedia Card Interface Driver..
[ 2.745664] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode…
[ 2.752929] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller…
[ 2.759749] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a..
[ 2.765538] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo..
[ 2.775314] dwmmc_rockchip ff0c0000.dwmmc: ‘clock-freq-min-max’ property was deprecated…
[ 2.783458] vcc_sd: supplied by vcc_io..
[ 2.824635] usb 1-1.3: new full-speed USB device number 3 using dwc2..
[ 2.914882] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)..
[ 2.930446] usb 1-1.3: New USB device found, idVendor=062a, idProduct=4101..
[ 2.936361] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized..
[ 2.938960] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode…
[ 2.939094] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller…
[ 2.939146] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a..
[ 2.939388] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo..
[ 2.939480] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-m
2018-07-07 14:07:27接收数据(ASCII 长度:7170):c: 1 slots initialized..
[ 3.143594] sdhci-pltfm: SDHCI platform and OF driver helper..
[ 3.152696] hidraw: raw HID events driver (C) Jiri Kosina..
[ 3.158117] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)..
[ 3.166811] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:062A:4101.0001/input/input0..
[ 3.168083] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)..
[ 3.207261] mmc2: MAN_BKOPS_EN bit is not set..
[ 3.212586] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)..
[ 3.222503] mmc2: new high speed MMC card at address 0001..
[ 3.228294] mmcblk2: mmc2:0001 AJNB4R 14.6 GiB ..
[ 3.232959] mmcblk2boot0: mmc2:0001 AJNB4R partition 1 4.00 MiB..
[ 3.239017] mmcblk2boot1: mmc2:0001 AJNB4R partition 2 4.00 MiB..
[ 3.245059] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-ff540000.usb-1.3/input0..
[ 3.245111] mmcblk2rpmb: mmc2:0001 AJNB4R partition 3 4.00 MiB..
[ 3.256390] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)..
[ 3.258678] boot: 0x000400000 – 0x002400000 (32 MB)..
[ 3.258683] backup: 0x002400000 – 0x002800000 (4 MB)..
[ 3.258686] linuxroot: 0x002800000 – 0x3a3a00000 (14866 MB)..
[ 3.293227] mmcblk2: p1 p2 p3..
[ 3.293228] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/ff540000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:062A:4101.0002/input/input1..
[ 3.364920] hid-generic 0003:062A:4101.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-ff540000.usb-1.3/input1..
[ 3.378711] usbcore: registered new interface driver usbhid..
[ 3.384279] usbhid: USB HID core driver..
[ 3.388340] ashmem: initialized..
[ 3.392707] usbcore: registered new interface driver snd-usb-audio..
[ 3.400543] u32 classifier..
[ 3.403261] Netfilter messages via NETLINK v0.30…
[ 3.408029] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)..
[ 3.414408] ctnetlink v0.93: registering with nfnetlink…
[ 3.419811] ip_set: protocol 6..
[ 3.422874] IPVS: Registered protocols ()..
[ 3.426917] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)..
[ 3.434291] IPVS: Creating netns size=1104 id=0..
[ 3.438855] IPVS: ipvs loaded…
[ 3.442115] ip_tables: (C) 2000-2006 Netfilter Core Team..
[ 3.447518] Initializing XFRM netlink socket..
[ 3.452225] NET: Registered protocol family 10..
[ 3.457325] ip6_tables: (C) 2000-2006 Netfilter Core Team..
[ 3.462909] sit: IPv6 over IPv4 tunneling driver..
[ 3.467962] NET: Registered protocol family 17..
[ 3.472441] NET: Registered protocol family 15..
[ 3.476950] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this…
[ 3.489590] Bridge firewalling registered..
[ 3.493698] Bluetooth: RFCOMM socket layer initialized..
[ 3.498909] Bluetooth: RFCOMM ver 1.11..
[ 3.502683] Bluetooth: HIDP (Human Interface Emulation) ver 1.2..
[ 3.508637] Bluetooth: HIDP socket layer initialized..
[ 3.513662] 8021q: 802.1Q VLAN Support v1.8..
[ 3.517905] lib80211: common routines for IEEE802.11 drivers..
[ 3.523612] [WLAN_RFKILL]: Enter rfkill_wlan_init..
[ 3.528554] [WLAN_RFKILL]: Enter rfkill_wlan_probe..
[ 3.533395] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6335..
[ 3.540302] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control…
[ 3.547444] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio…
[ 3.554902] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0…[ 3.564137] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio..
[ 3.569401] [WLAN_RFKILL]: Exit rfkill_wlan_probe..
[ 3.574153] [BT_RFKILL]: Enter rfkill_rk_init..
[ 3.578793] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139…
[ 3.587042] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149…
[ 3.595176] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146…
[ 3.603193] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151…
[ 3.611586] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!..
[ 3.618335] [BT_RFKILL]: Request irq for bt wakeup host..
[ 3.623596] [BT_RFKILL]: BT_WAKE_HOST IRQ fired..
[ 3.628160] [BT_RFKILL]: ** disable irq..
[ 3.632125] [BT_RFKILL]: bt_default device registered…
[ 3.637364] Key type dns_resolver registered..
[ 3.642111] ThumbEE CPU extension supported…
[ 3.646431] Registering SWP/SWPB emulation handler..
[ 3.651715] Loading compiled-in X.509 certificates..
[ 3.657328] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0c51650)..
[ 3.664790] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0c51650)..
[ 3.672182] dwhdmi-rockchip ff980000.hdmi: Detected HDMI controller 0x20:0xa:0xa0:0xc1..
[ 3.680499] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0c4e334)..
[ 3.687931] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013)…
[ 3.695941] [drm:drm_vblank_init] No driver support for vblank timestamp query…
[ 3.703266] rockchip-drm display-subsystem: failed to parse display resources..
[ 3.795301] Console: switching to colour frame buffer device 240x67..
[ 3.826756] rockchip-drm display-subsystem: fb0: frame buffer device..
[ 3.831783] random: nonblocking pool is initialized..
[ 3.875356] rockchip-pm-domain ff730000.power-management:power-controller: failed to set idle on domain ‘pd_gpu’, val=1..
[ 3.886496] vdd_gpu: supplied by vcc_sys..
[ 3.891052] W : [File] : drivers/gpu/arm/midgard_for_linux/platform/rk/mali_kbase_config_rk.c; [Line] : 107; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available…
[ 3.907358] Too many coherent groups (keeping only 16 groups)…
[ 3.913433] mali ffa30000.gpu: Unknown GPU ID ffffffff..
[ 3.918683] mali ffa30000.gpu: Device initialization failed (-22)..
[ 3.925350] mali: probe of ffa30000.gpu failed with error -22..
[ 3.931892] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input)…
[ 3.939109] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30)…
[ 3.944887] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10)…
[ 3.950726] rk_gmac-dwmac ff290000.ethernet: clock input from PHY..
[ 3.956926] rk_gmac-dwmac ff290000.ethernet: init for RGMII..
[ 3.964675] dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 106..
[ 3.967785] stmmac - user ID: 0x10, Synopsys ID: 0x35..
[ 3.967786] Ring mode enabled..
[ 3.967791] DMA HW capability register supported..
[ 3.967791] Normal descriptors..
[ 3.967793] RX Checksum Offload Engine supported (type 2)..
[ 3.967793] TX Checksum insertion supported..
[ 3.967794] Wake-Up On Lan supported.
.[ 3.967820] Enable RX Mitigation via HW Watchdog Timer..
[ 4.008684] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)..
[ 4.014273] mmc1: new ultra high speed SDR104 SDIO card at address 0001..
2018-07-07 14:07:28接收数据(ASCII 长度:2048):
[ 4.134617] Unable to handle kernel NULL pointer dereference at virtual address 00000000..
[ 4.142849] pgd = c0004000..
[ 4.145591] [00000000] *pgd=00000000..
[ 4.149249] Internal error: Oops: 5 [#1] SMP ARM..
[ 4.153945] Modules linked in:..
[ 4.157071] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.52 #25..
[ 4.163177] Hardware name: Rockchip (Device Tree)..
[ 4.167963] task: ee944b00 ti: ee972000 task.ti: ee972000..
[ 4.173455] PC is at __queue_work+0x15c/0x360..
[ 4.177878] LR is at __queue_work+0x114/0x360..
[ 4.182306] pc : [] lr : [] psr: 60000193..
[ 4.182306] sp : ee973df0 ip : ee973df0 fp : ee973e24..
[ 4.199537] r10: 00000004 r9 : c1107ea0 r8 : 00000003..
[ 4.250890] r7 : edd93200 r6 : 00000000 r5 : edc02e8c r4 : 00000000..
[ 4.303423] r3 : 0000000e r2 : ee973df0 r1 : 07ffffff r0 : 00000000..
[ 4.355519] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none..
[ 4.408315] Control: 10c5387d Table: 0000406a DAC: 00000051..
[ 4.459289] ..
[ 4.459289] PC: 0xc013398c:..
[ 4.551666] 398c e35a0004 01a0200d 03c23d7f 03c3303f 05938010 e59730c0 e3130002 159740c8..
[ 4.605498] 39ac 1a000002 e7994108 e59730c4 e0834004 e1a00005 ebffff86 e2506000 0a00000f..
[ 4.659661] 39cc e5943000 e1560003 0a00000c eb29924d e1a00006 e1a01005 ebfff933 e3500000..
[ 4.714083] 39ec 0a000004 e5903010 e5932004 e1520007 01a04003 0a000003 e1a00006 eb29921e..
[ 4.768904] 3a0c e5940000 eb29923f e5943010 e3530000 1a000011 e59730c0 e3130002 0a000002..
[ 4.823808] 3a2c e5940000 eb299214 eaffffd4 e59f61b4 e5d6300b e3530001 0a000007 e2873074..
[ 4.878875] 3a4c e59f01a4 e3001581 e59f21a4 e58d8000 ebffa89a e3a03001 e5c6300b e59f2194..
[ 4.934112] 3a6c e5923004 e3530000 da00001d e1a0100d e3c13d7f e3c3303f e59f117c e5933010..
[ 4.989533] ..
[ 4.989533] LR: 0xc0133944:..
[ 5.084892] 3944 e5930004 e0671000 e2710000 e0a00001 e2200001 e31000ff 0a000009 e59f428c..
[ 5.139827] 3964 e5d4300a e3530001 0a00009e e59f0280 e300154d ebffa8b4
2018-07-07 14:07:29接收数据(ASCII 长度:2048):e3a03001 e5c4300a..
[ 5.194614] 3984 ea000098 e59f926c e35a0004 01a0200d 03c23d7f 03c3303f 05938010 e59730c0..
[ 5.249303] 39a4 e3130002 159740c8 1a000002 e7994108 e59730c4 e0834004 e1a00005 ebffff86..
[ 5.303958] 39c4 e2506000 0a00000f e5943000 e1560003 0a00000c eb29924d e1a00006 e1a01005..
[ 5.358360] 39e4 ebfff933 e3500000 0a000004 e5903010 e5932004 e1520007 01a04003 0a000003..
[ 5.412567] 3a04 e1a00006 eb29921e e5940000 eb29923f e5943010 e3530000 1a000011 e59730c0..
[ 5.466731] 3a24 e3130002 0a000002 e5940000 eb299214 eaffffd4 e59f61b4 e5d6300b e3530001..
[ 5.520579] ..
[ 5.520579] SP: 0xee973d70:..
[ 5.612644] 3d70 00000003 ee944b00 eefb4f18 f32fe95a c0133a0c 60000193 ffffffff ee973dd4..
[ 5.665925] 3d90 ee973e24 ee973da0 c010bca0 c01011c0 00000000 07ffffff ee973df0 0000000e..
[ 5.719306] 3db0 00000000 edc02e8c 00000000 edd93200 00000003 c1107ea0 00000004 ee973e24..
[ 5.772610] 3dd0 ee973df0 ee973df0 c01339c4 c0133a0c 60000193 ffffffff 00000051 c01337ec..
[ 5.826029] 3df0 00000001 00000000 dfd14080 00000100 edc02e9c c0133c10 00000001 edc02e8c..
[ 5.878908] 3e10 c0c01a74 edc02e8c ee973e34 ee973e28 c0133c34 c01338bc ee973e64 ee973e38..
[ 5.931461] 3e30 c01803d0 c0133c1c 00000100 c0b982a0 edc02e9c eefb4400 c0133c10 00000001..
[ 5.982904] 3e50 c11d06f4 edc02e8c ee973eb4 ee973e68 c018071c c018032c eefb4d18 c018a668..
[ 6.033430] ..
[ 6.033430] IP: 0xee973d70:..
[ 6.119593] 3d70 00000003 ee944b00 eefb4f18 f32fe95a c0133a0c 60000193 ffffffff ee973dd4..
[ 6.170453] 3d90 ee973e24 ee973da0 c010bca0 c01011c0 00000000 07ffffff ee973df0 0000000e..
[ 6.221328] 3db0 00000000 edc02e8c 00000000 edd93200 00000003 c1107ea0 00000004 ee973e24..
[ 6.272444] 3dd0 ee973df0 ee973df0 c01339c4 c0133a0c 60000193 ffffffff 00000051 c01337ec..
[ 6.324201] 3df0 00000001 00000000 dfd14080 00000100 edc02e9c c0133c10 00000001 edc02e8c..
[ 6.376390] 3e10 c0c01a74 edc02e8c ee973e34 ee973e28 c0133c34 c01338bc ee973e64 ee973e38..
[ 6.428973] 3e30 c01803d0 c0133c1c 00000100 c0b
2018-07-07 14:07:30接收数据(ASCII 长度:2048):982a0 edc02e9c eefb4400 c0133c10 00000001..
[ 6.481758] 3e50 c11d06f4 edc02e8c ee973eb4 ee973e68 c018071c c018032c eefb4d18 c018a668..
[ 6.534532] ..
[ 6.534532] FP: 0xee973da4:..
[ 6.625527] 3da4 07ffffff ee973df0 0000000e 00000000 edc02e8c 00000000 edd93200 00000003..
[ 6.679057] 3dc4 c1107ea0 00000004 ee973e24 ee973df0 ee973df0 c01339c4 c0133a0c 60000193..
[ 6.732806] 3de4 ffffffff 00000051 c01337ec 00000001 00000000 dfd14080 00000100 edc02e9c..
[ 6.786919] 3e04 c0133c10 00000001 edc02e8c c0c01a74 edc02e8c ee973e34 ee973e28 c0133c34..
[ 6.841293] 3e24 c01338bc ee973e64 ee973e38 c01803d0 c0133c1c 00000100 c0b982a0 edc02e9c..
[ 6.896021] 3e44 eefb4400 c0133c10 00000001 c11d06f4 edc02e8c ee973eb4 ee973e68 c018071c..
[ 6.950829] 3e64 c018032c eefb4d18 c018a668 7fffffff eefb492c eefb482c 00200000 f32fe5ef..
[ 7.005881] 3e84 00000000 f32fe5ef 00000082 c1102084 00000100 00000001 c10b5858 c11d69c0..
[ 7.060763] ..
[ 7.060763] R2: 0xee973d70:..
[ 7.155512] 3d70 00000003 ee944b00 eefb4f18 f32fe95a c0133a0c 60000193 ffffffff ee973dd4..
[ 7.210799] 3d90 ee973e24 ee973da0 c010bca0 c01011c0 00000000 07ffffff ee973df0 0000000e..
[ 7.266325] 3db0 00000000 edc02e8c 00000000 edd93200 00000003 c1107ea0 00000004 ee973e24..
[ 7.321947] 3dd0 ee973df0 ee973df0 c01339c4 c0133a0c 60000193 ffffffff 00000051 c01337ec..
[ 7.377735] 3df0 00000001 00000000 dfd14080 00000100 edc02e9c c0133c10 00000001 edc02e8c..
[ 7.433577] 3e10 c0c01a74 edc02e8c ee973e34 ee973e28 c0133c34 c01338bc ee973e64 ee973e38..
[ 7.489752] 3e30 c01803d0 c0133c1c 00000100 c0b982a0 edc02e9c eefb4400 c0133c10 00000001..
[ 7.546479] 3e50 c11d06f4 edc02e8c ee973eb4 ee973e68 c018071c c018032c eefb4d18 c018a668..
[ 7.603346] ..
[ 7.603346] R5: 0xedc02e0c:..
[ 7.702452] 2e0c ffffffff edc02f24 edc02f24 c05389e4 c0538a2c eea73080 eea73090 edc02da4..
[ 7.759838] 2e2c 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000..
[ 7.817452] 2e4c 00000000 edc02e50 edc02e50 edd7e400 00000000 000000
2018-07-07 14:07:32接收数据(ASCII 长度:2048):00 00000000 00000000..
[ 7.874770] 2e6c 00000000 00000000 00000000 00000000 00000000 edc02a00 00000000 edd93200..
[ 7.931673] 2e8c ffffffe1 edc02e90 edc02e90 c04f2688 00000200 00000000 ffff8c66 c0133c10..
[ 7.988804] 2eac edc02e8c 00300003 ffffffff ffffffff 00000000 00000000 00000000 00000000..
[ 8.046260] 2ecc 00000000 edd93200 00000004 000000c8 00000064 00000000 00000000 00000000..
[ 8.103453] 2eec 00000000 00000000 00000000 00000000 00000000 00000000 dead4ead ffffffff..
[ 8.160363] ..
[ 8.160363] R7: 0xedd93180:..
[ 8.258937] 3180 00000000 00000000 00000000 00000000 00000000 dead4ead ffffffff ffffffff..
[ 8.315725] 31a0 edd931a0 edd931a0 ee2e4a74 ee2e4a84 edd7e5ac 00000001 ee2cf3c0 c1161334..
[ 8.372725] 31c0 c0538a68 00000000 00000000 00000000 00000000 00000000 00000000 00000000..
[ 8.429778] 31e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000..
[ 8.486374] 3200 edd93400 edd93200 c1111670 00000200 00000001 00000000 dead4ead ffffffff..
[ 8.542558] 3220 ffffffff edd93224 edd93224 00000000 00000000 00000001 00000001 00000000..
[ 8.599215] 3240 00000000 edd93244 edd93244 edd9324c edd9324c edd93254 edd93254 edc02b00..
[ 8.655620] 3260 00000000 00000001 edc11400 00000000 00000000 5f757067 65776f70 666f5f72..
[ 8.711972] ..
[ 8.711972] R9: 0xc1107e20:..
[ 8.809272] 7e20 00000000 000003e8 00000204 00000000 0007dd4f 00003086 03ffffff 00000000..
[ 8.865481] 7e40 00000000 00000001 00000001 00000001 00000001 00000001 00000064 00000000..
[ 8.921285] 7e60 eefc1200 0000000d eefc11c0 00000001 0000d000 0000000f eefc1140 00000004..
[ 8.976953] 7e80 00000000 00000003 0000003c eefc1280 eefc1240 00000001 00001000 eef8d000..
[ 9.032624] 7ea0 2dedc000 2dee9000 2def6000 2df03000 00050000 00000002 0002fffa 00010000..
[ 9.087959] 7ec0 0007ffff 0000fadd 00002000 00000000 0000fffa 00000000 00000000 00000032..
[ 9.143691] 7ee0 00000008 00000001 ee801d80 eeb93310 00000000 00000000 eea67080 ee801380..
[ 9.199131] 7f00 eef09000 00000011 ee801b80
2018-07-07 14:07:33接收数据(ASCII 长度:2048):0001ffff 00000064 00000010 0000ffff eeec9000..
[ 9.254287] Process swapper/3 (pid: 0, stack limit = 0xee972218)..
[ 9.306598] Stack: (0xee973df0 to 0xee974000)..
[ 9.357059] 3de0: 00000001 00000000 dfd14080 00000100..
[ 9.411891] 3e00: edc02e9c c0133c10 00000001 edc02e8c c0c01a74 edc02e8c ee973e34 ee973e28..
[ 9.466685] 3e20: c0133c34 c01338bc ee973e64 ee973e38 c01803d0 c0133c1c 00000100 c0b982a0..
[ 9.521413] 3e40: edc02e9c eefb4400 c0133c10 00000001 c11d06f4 edc02e8c ee973eb4 ee973e68..
[ 9.576276] 3e60: c018071c c018032c eefb4d18 c018a668 7fffffff eefb492c eefb482c 00200000..
[ 9.631012] 3e80: f32fe5ef 00000000 f32fe5ef 00000082 c1102084 00000100 00000001 c10b5858..
[ 9.686269] 3ea0: c11d69c0 0000000a ee973efc ee973eb8 c0121ec0 c01804dc ee973ed4 ee973ec8..
[ 9.741471] 3ec0: c0898224 00000002 ffff8c6a 00200040 c0173804 00000000 00000000 ee820000..
[ 9.796499] 3ee0: 00000001 c10b5858 00000001 00000000 ee973f14 ee973f00 c012237c c0121d6c..
[ 9.851613] 3f00: c0173668 00000000 ee973f34 ee973f18 c016f424 c01222f0 f0802000 c1154a40..
[ 9.906849] 3f20: ee973f58 c110801c ee973f54 ee973f38 c0101440 c016f398 c0107f78 60000013..
[ 9.961952] 3f40: ffffffff ee973f8c ee973fb4 ee973f58 c010bd14 c01013f0 00000001 00000000..
[ 10.016673] 3f60: ee973fb8 c0118d40 00000000 00000000 c10b13ac c0c01a74 c10b5858 00000001..
[ 10.071336] 3f80: 00000000 ee973fb4 ee973fb8 ee973fa8 c0107f74 c0107f78 60000013 ffffffff..
[ 10.126013] 3fa0: 00000051 c0161334 ee973fc4 ee973fb8 c0161334 c0107f48 ee973fdc ee973fc8..
[ 10.180340] 3fc0: c01615cc c0161308 00000001 c11d6328 ee973ff4 ee973fe0 c010d87c c0161344..
[ 10.235184] 3fe0: c01014f4 2e95406a 00000000 ee973ff8 0010150c c010d744 f2de191d fcfc0180..
[ 10.289918] [] (__queue_work) from [] (delayed_work_timer_fn+0x24/0x28)..
[ 10.345003] [] (delayed_work_timer_fn) from [] (call_timer_fn+0xb0/0x1b0)..
[ 10.400449] [] (call_timer_fn) from [] (run_timer_softirq+0x24c/0x2c
2018-07-07 14:07:34接收数据(ASCII 长度:2048):4)..
[ 10.455599] [] (run_timer_softirq) from [] (__do_softirq+0x160/0x360)..
[ 10.510819] [] (__do_softirq) from [] (irq_exit+0x98/0x108)..
[ 10.564975] [] (irq_exit) from [] (__handle_domain_irq+0x98/0xbc)..
[ 10.619735] [] (__handle_domain_irq) from [] (gic_handle_irq+0x5c/0x9c)..
[ 10.675059] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x70)..
[ 10.729338] Exception stack(0xee973f58 to 0xee973fa0)..[ 10.781607] 3f40: 00000001 00000000..
[ 10.837197] 3f60: ee973fb8 c0118d40 00000000 00000000 c10b13ac c0c01a74 c10b5858 00000001..
[ 10.892762] 3f80: 00000000 ee973fb4 ee973fb8 ee973fa8 c0107f74 c0107f78 60000013 ffffffff..
[ 10.948427] [] (__irq_svc) from [] (arch_cpu_idle+0x3c/0x48)..
[ 11.003470] [] (arch_cpu_idle) from [] (default_idle_call+0x38/0x3c)..
[ 11.059385] [] (default_idle_call) from [] (cpu_startup_entry+0x294/0x3b8)..
[ 11.116006] [] (cpu_startup_entry) from [] (secondary_start_kernel+0x144/0x16c)..
[ 11.173007] [] (secondary_start_kernel) from [<0010150c>] (0x10150c)..
[ 11.228050] Code: 01a04003 0a000003 e1a00006 eb29921e (e5940000) ..
[ 11.281578] —[ end trace fc4bf13d001f8a9d ]—..
[ 11.333986] Kernel panic - not syncing: Fatal exception in interrupt..
[ 11.388311] CPU0: stopping..
[ 11.438348] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.52 #25..
[ 11.493563] Hardware name: Rockchip (Device Tree)..
[ 11.546159] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)..
[ 11.602488] [] (show_stack) from [] (dump_stack+0x80/0xa0)..
[ 11.658327] [] (dump_stack) from [] (handle_IPI+0x184/0x2c8)..
[ 11.714342] [] (handle_IPI) from [] (gic_handle_irq+0x90/0x9c)..
[ 11.770600] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x7
2018-07-07 14:07:36接收数据(ASCII 长度:4374):0)..[ 11.826609] Exception stack(0xc1101f20 to 0xc1101f68)..
[ 11.880470] 1f20: 00000001 00000000 c1101f80 c0118d40 00000000 00000000 c10b13ac c0c01a74..
[ 11.937827] 1f40: c10b5858 00000001 eefc32c0 c1101f7c c1101f80 c1101f70 c0107f74 c0107f78..
[ 11.995103] 1f60: 60000013 ffffffff..
[ 12.047177] [] (__irq_svc) from [] (arch_cpu_idle+0x3c/0x48)..
[ 12.104343] [] (arch_cpu_idle) from [] (default_idle_call+0x38/0x3c)..
[ 12.162647] [] (default_idle_call) from [] (cpu_startup_entry+0x294/0x3b8)..
[ 12.221873] [] (cpu_startup_entry) from [] (rest_init+0x74/0x8c)..
[ 12.280067] [] (rest_init) from [] (start_kernel+0x370/0x3dc)..
[ 12.337977] [] (start_kernel) from [<0000807c>] (0x807c)..
[ 12.394347] CPU1: stopping..[ 12.447243] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.52 #25..
[ 12.504823] Hardware name: Rockchip (Device Tree)..[ 12.559900] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)..
[ 12.618911] [] (show_stack) from [] (dump_stack+0x80/0xa0)..
[ 12.677369] [] (dump_stack) from [] (handle_IPI+0x184/0x2c8)..
[ 12.735842] [] (handle_IPI) from [] (gic_handle_irq+0x90/0x9c)..
[ 12.794635] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x70)..
[ 12.853457] Exception stack(0xee96ff58 to 0xee96ffa0)..[ 12.909822] ff40: 00000001 00000000..
[ 12.969608] ff60: ee96ffb8 c0118d40 00000000 00000000 c10b13ac c0c01a74 c10b5858 00000001..
[ 13.029509] ff80: 00000000 ee96ffb4 ee96ffb8 ee96ffa8 c0107f74 c0107f78 60000013 ffffffff..
[ 13.089427] [] (__irq_svc) from [] (arch_cpu_idle+0x3c/0x48)..
[ 13.148475] [] (arch_cpu_idle) from [] (default_idle_call+0x38/0x3c)..
[ 13.208368] [] (default_idle_call) from [] (cpu_startup_entry+0x294/0x3b8)..
[ 13.268920] [] (cpu_startup_entry) from [] (secondary_start_kernel+0x144/0x16c)..
[ 13.329847] [] (secondary_st[a ry C1P3U.3s3.2.8l9)8 ]f rSoMmP :[ <f0a0i1l0e1d5 0ct>]o (s0txop 1s0e1c5o0ncd)a.r.y CPUs..
[ 13.3[3 2 9 941]3 .r33o2c9k9c4h]i pr-othcekrcmhiapl- tfhfe2r80m0a0l0 .ftfs2a8d0c0:0 0.chtasnandalc: c1: htanemnpaler a1:tu rtee(m3pe3r aCt)u.r.e(33 C)..
[ 13.333004] THERMAL REGS:..
[ 13.333068] 00000000: 00000200 00030061 00000606 00000000 00000000 00000000 00000000 00000000..
[ 13.333120] 00000020: 00000000 00000e4b 00000e4c 00000e4c 00000000 00000df7 00000dde 00000000..
[ 13.333167] 00000040: 00000000 00000db6 00000db6 00000000 00000000 00000000 00000000 00000000..
[ 13.333214] 00000060: 00000004 00000004 000000fa 00000032 00000000 00000000 00000000 00000000..
[ 13.333236] 00000080: 00000000 00000000..
[ 13.395777] CPU2: stopping..
[ 13.398570] CPU: 2 PID: 0 Comm: swapper/2 Tainted: G D 4.4.52 #25..
[ 13.405829] Hardware name: Rockchip (Device Tree)..
[ 13.410648] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)..
[ 13.418482] [] (show_stack) from [] (dump_stack+0x80/0xa0)..
[ 13.425787] [] (dump_stack) from [] (handle_IPI+0x184/0x2c8)..
[ 13.433252] [] (handle_IPI) from [] (gic_handle_irq+0x90/0x9c)..
[ 13.440885] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x70)..
[ 13.448405] Exception stack(0xee971f58 to 0xee971fa0)..
[ 13.453502] 1f40: [ x c ep1ti3.4on5 8i42n 5]int e–rr-[up etn..d 01K e0rn00el00 pa00n0i.c .- not syncing: Fatal exception in interrupt..
[ 13.468940] 1f60: ee971fb8 c0118d40 00000000 00000000 c10b13ac c0c01a74 c10b5858 00000001..
[ 13.477179] 1f80: 00000000 ee971fb4 ee971fb8 ee971fa8 c0107f74 c0107f78 60000013 ffffffff..
[ 13.485430] [] (__irq_svc) from [] (arch_cpu_idle+0x3c/0x48)..
[ 13.492906] [] (arch_cpu_idle) from [] (default_idle_call+0x38/0x3c)..
[ 13.501073] [] (default_idle_call) from [] (cpu_startup_entry+0x294/0x3b8)..
[ 13.509754] [] (cpu_startup_entry) from [] (secondary_start_kernel+0x144/0x16c)..
[ 13.518859] [] (secondary_start_kernel) from [<0010150c>] (0x10150c)..
2018-07-07 14:08:04接收数据(ASCII 长度:2048):[ 40.104623] ------------[ cut here ]------------..
[ 40.161881] WARNING: CPU: 3 PID: 0 at kernel/watchdog.c:352 watchdog_timer_fn+0x11c/0x34c()..
[ 40.223421] Watchdog detected hard LOCKUP on cpu 0..
[ 40.228713] Modules linked in:..
[ 40.337326] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.52 #25..
[ 40.397726] Hardware name: Rockchip (Device Tree)..
[ 40.455537] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)..
[ 40.516949] [] (show_stack) from [] (dump_stack+0x80/0xa0)..
[ 40.577791] [] (dump_stack) from [] (warn_slowpath_common+0x98/0xc0)..
[ 40.639260] [] (warn_slowpath_common) from [] (warn_slowpath_fmt+0x40/0x48)..
[ 40.701489] [] (warn_slowpath_fmt) from [] (watchdog_timer_fn+0x11c/0x34c)..
[ 40.763494] [] (watchdog_timer_fn) from [] (__hrtimer_run_queues+0x1e8/0x32c)..
[ 40.825593] [] (__hrtimer_run_queues) from [] (hrtimer_interrupt+0xe0/0x238)..
[ 40.887735] [] (hrtimer_interrupt) from [] (arch_timer_handler_phys+0x38/0x40)..
[ 40.950125] [] (arch_timer_handler_phys) from [] (handle_percpu_devid_irq+0xfc/0x1b0)..
[ 41.013290] [] (handle_percpu_devid_irq) from [] (generic_handle_irq+0x28/0x38)..
[ 41.075856] [] (generic_handle_irq) from [] (__handle_domain_irq+0x94/0xbc)..
[ 41.138091] [] (__handle_domain_irq) from [] (gic_handle_irq+0x5c/0x9c)..
[ 41.200183] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x70)..
[ 41.261354] Exception stack(0xee973af8 to 0xee973b40)..[ 41.319764] 3ae0: ee973b84 00000000..
[ 41.381590] 3b00: fd640800 c089817c ee973b84 00005dbf 00006784 0000002b c1154710 c0d9c880..
[ 41.443421] 3b20: 00000008 ee973b54 ee973b58 ee973b48 c010ea9c c089818c a0000113 ffffffff..
[ 41.505140] [] (__irq_svc) from [] (arch_co
2018-07-07 14:08:05接收数据(ASCII 长度:2048):unter_get_cntpct+0x10/0x18)..[ 41.566899] [] (arch_counter_get_cntpct) from [] (arch_timer_read_counter_long+0x20/0x28)..
[ 41.630561] [] (arch_timer_read_counter_long) from [] (read_current_timer+0x30/0x48)..
[ 41.693899] [] (read_current_timer) from [] (__timer_delay+0x3c/0x5c)..
[ 41.756174] [] (__timer_delay) from [] (__timer_const_udelay+0x2c/0x34)..
[ 41.818709] [] (__timer_const_udelay) from [] (panic+0x1cc/0x20c)..
[ 41.880799] [] (panic) from [] (die+0x3b8/0x418)..
[ 41.941350] [] (die) from [] (__do_kernel_fault.part.0+0x64/0x1f4)..
[ 42.003882] [] (__do_kernel_fault.part.0) from [] (do_page_fault+0x320/0x33c)..
[ 42.067477] [] (do_page_fault) from [] (do_translation_fault+0x2c/0xc0)..
[ 42.130689] [] (do_translation_fault) from [] (do_DataAbort+0x44/0xc4)..
[ 42.194099] [] (do_DataAbort) from [] (__dabt_svc+0x40/0x60)..
[ 42.256696] Exception stack(0xee973da0 to 0xee973de8)..
[ 42.316782] 3da0: 00000000 07ffffff ee973df0 0000000e 00000000 edc02e8c 00000000 edd93200..
[ 42.380487] 3dc0: 00000003 c1107ea0 00000004 ee973e24 ee973df0 ee973df0 c01339c4 c0133a0c..
[ 42.444001] 3de0: 60000193 ffffffff..
[ 42.502422] [] (__dabt_svc) from [] (__queue_work+0x15c/0x360)..
[ 42.565422] [] (__queue_work) from [] (delayed_work_timer_fn+0x24/0x28)..
[ 42.629236] [] (delayed_work_timer_fn) from [] (call_timer_fn+0xb0/0x1b0)..
[ 42.693244] [] (call_timer_fn) from [] (run_timer_softirq+0x24c/0x2c4)..
[ 42.756927] [] (run_timer_softirq) from [] (__do_softirq+0x160/0x360)..
[ 42.820575] [] (__do_softirq) from [] (irq_exit+0x98/0x108)..
[ 42.883361] [] (irq_exit) from [] (__handle_domain_irq+0x98/0xbc)..
[ 42.946785] [] (__handle_domain
2018-07-07 14:08:06接收数据(ASCII 长度:995):_irq) from [] (gic_handle_irq+0x5c/0x9c)..
[ 43.010967] [] (gic_handle_irq) from [] (__irq_svc+0x54/0x70)..
[ 43.074355] Exception stack(0xee973f58 to 0xee973fa0)..
[ 43.135194] 3f40: 00000001 00000000..
[ 43.199509] 3f60: ee973fb8 c0118d40 00000000 00000000 c10b13ac c0c01a74 c10b5858 00000001..
[ 43.263810] 3f80: 00000000 ee973fb4 ee973fb8 ee973fa8 c0107f74 c0107f78 60000013 ffffffff..
[ 43.328393] [] (__irq_svc) from [] (arch_cpu_idle+0x3c/0x48)..
[ 43.392398] [] (arch_cpu_idle) from [] (default_idle_call+0x38/0x3c)..
[ 43.457300] [] (default_idle_call) from [] (cpu_startup_entry+0x294/0x3b8)..
[ 43.522774] [] (cpu_startup_entry) from [] (secondary_start_kernel+0x144/0x16c)..
[ 43.588726] [] (secondary_start_kernel) from [<0010150c>] (0x10150c)..
[ 43.652795] —[ end trace fc4bf13d001f8a9e ]—..
发现了几个报错的地方
[ 4.459289] ..
已困惑许久,在线等各位大神赐教!
