firefly-reload3288 编译内核 烧录更新进不了系统?
根据维基下载编译firefly-rk3288-kernel内核:
cd ~/UbuntuDev
git clone https://github.com/T-Firefly/firefly-3.14-kernel
cd ~/UbuntuDev/firefly-3.14-kernel/
make firefly-rk3288_defconfig
make -j8 firefly-rk3288.img
cd ~/UbuntuDev/
git clone https://github.com/TeeFirefly/initrd.git
make -C initrd
将 kernel 和 initrd 打包成 boot.img:
./mkbootimg --kernel arch/arm/boot/zImage --ramdisk ../initrd.img --second resource.img -o boot.img
git clone -b u-boot-rk3288 https://github.com/linux-rockchip/u-boot-rockchip.git u-boot
cd u-boot
make rk3288_defconfig
make -j4
parameter:CMDLINE:earlyprintk=ttyS2,115200 console=tty0 console=ttyS2,115200 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyS2
通过上面的步骤:然后进行刷机,打印下面的log,感觉emmc有问题,帮忙看一下
root=/dev/mmcblk0p3 linuxroot rw rootfstype=ext4 init=/sbin/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00010000@0x00002000
(boot),0x00002000@0x00012000(backup),-@0x00014000(linuxroot)
4.415935] Freeing unused kernel memory: 504K (c0d00000 - c0d7e000)
Loading, please wait…
[ 4.441624] udevd[120]: starting version 175
Begin: Loading essential drivers … FATAL: Could not load /lib/modules/3.14.0/modules.dep: No such file or directory
done.
Begin: Running /scripts/init-premount … Waiting for eMMC storage…
Timeout!
done.
[ 11.000305] ES8323 2-0010: mic_state_switch 0
[ 11.005354] ES8323 2-0010: hp_det = 1,deinsert hp
[ 11.042503] ES8323 2-0010: hp mic use extern
Gave up waiting for root device. Common problems:
  • Boot args (cat /proc/cmdline)
    • Check rootdelay= (did the system wait long enough?)
    • Check root= (did the system wait for the right device?)
  • Missing modules (cat /proc/modules; ls /dev)
    ALERT! /dev/mmcblk0p3 does not exist. Dropping to a shell!
    /bin/sh: can’t access tty; job control turned off
    (initramfs)
