求助 RK3288 Linux 编译dts 想让LVDS工作, 但是启动失败
你好!
我编译的dts 附件中想让LVDS工作, 但是RK3288不能正常启动,请问是什么原因造成的?
U-Boot 2014.10-RK3288-10 (Nov 20 2017 - 17:19:35)
CPU: rk3288
cpu version = 0
CPU’s clock information:
arm pll = 600000000HZ
periph pll = 297000000HZ
ddr pll = 200000000HZ
codec pll = 384000000HZ
DRAM: Found dram banks: 1
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
Load FDT from boot image.
power key: bank-0 pin-5
pmic:act8846
can’t find dts node for pwm1
#Boot ver: 2017-11-20#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
boot or recovery image sha mismatch!
Unable to boot:boot
try to start recovery
‘recovery’ does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
ERROR: [rk_load_image_from_storage]: bootrk: bad boot or kernel image
Unable to boot:backup
try to start rockusb
下面是dts 文件: firefly-rk3288-linux
/dts-v1/;
#include "rk3288.dtsi"
// #include "lcd-box.dtsi"  // default
#include "lvds-lcd-box.dtsi"  // Custom LVDS
#include <dt-bindings/input/input.h>
	fiq-debugger {
		status = "disabled";
	hsic-usb-hub{
		compatible = "hub_reset";
		reset,pin =<&gpio7 GPIO_A6 GPIO_ACTIVE_HIGH>;	// hub reset pin
    wireless-wlan {
        compatible = "wlan-platdata";
	/* wifi_chip_type - wifi chip define
	* bcmwifi ==> like ap6xxx, rk90x;
	* rtkwifi ==> like rtl8188xx, rtl8723xx,rtl8812auv;
	* esp8089 ==> esp8089;
	* other   ==> for other wifi;
	wifi_chip_type = "bcmwifi";
        sdio_vref = <1800>; //1800mv or 3300mv
	//keep_wifi_power_on;
        //power_ctrl_by_pmu;
        power_pmu_regulator = "act_ldo3";
        power_pmu_enable_level = <1>; //1->HIGH, 0->LOW
        //vref_ctrl_enable;
        //vref_ctrl_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
        vref_pmu_regulator = "act_ldo3";
        vref_pmu_enable_level = <1>; //1->HIGH, 0->LOW
        WIFI,poweren_gpio = <&gpio4 GPIO_D4 GPIO_ACTIVE_HIGH>;
        WIFI,host_wake_irq = <&gpio4 GPIO_D6 GPIO_ACTIVE_HIGH>;
        //WIFI,reset_gpio = <&gpio0 GPIO_A2 GPIO_ACTIVE_LOW>;
        status = "okay";
    wireless-bluetooth {
        compatible = "bluetooth-platdata";
        //wifi-bt-power-toggle;
        uart_rts_gpios = <&gpio4 GPIO_C3 GPIO_ACTIVE_LOW>;
        pinctrl-names = "default","rts_gpio";
        pinctrl-0 = <&uart0_rts>;
        pinctrl-1 = <&uart0_rts_gpio>;
        BT,power_gpio = <&gpio4 GPIO_D3 GPIO_ACTIVE_HIGH>;
        BT,reset_gpio = <&gpio4 GPIO_D5 GPIO_ACTIVE_HIGH>;
        BT,wake_gpio = <&gpio4 GPIO_D2 GPIO_ACTIVE_HIGH>;
        BT,wake_host_irq = <&gpio4 GPIO_D7 GPIO_ACTIVE_LOW>;
        status = "okay";
	pwm_regulator {
		compatible = "rockchip_pwm_regulator";
		pwms = <&pwm1 0 2000>;
		rockchip,pwm_id= <1>;
		rockchip,pwm_voltage_map= <925000 950000 975000 1000000 1025000 1050000 1075000 1100000 1125000 1150000 1175000 1200000 1225000 1250000 1275000 1300000 1325000 1350000 1375000 1400000>;
		rockchip,pwm_voltage= <1100000>;
		rockchip,pwm_min_voltage= <925000>;
		rockchip,pwm_max_voltage= <1400000>;
		rockchip,pwm_suspend_voltage= <950000>;
		rockchip,pwm_coefficient= <475>;
		regulators {
			#address-cells = <1>;
			#size-cells = <0>;
			pwm_reg0: regulator@0 {
				regulator-compatible = "pwm_dcdc1";
				regulator-name= "vdd_logic";
				regulator-min-microvolt = <925000>;
				regulator-max-microvolt = <1400000>;
				regulator-always-on;
				regulator-boot-on;
	codec_hdmi_i2s: codec-hdmi-i2s {
		compatible = "hdmi-i2s";
	codec_hdmi_spdif: codec-hdmi-spdif {
		compatible = "hdmi-spdif";
	rockchip-hdmi-i2s {
		compatible = "rockchip-hdmi-i2s";
		dais {
			dai0 {
				audio-codec = <&codec_hdmi_i2s>;
				audio-controller = <&i2s>;
				format = "i2s";
				//continuous-clock;
				//bitclock-inversion;
				//frame-inversion;
				//bitclock-master;
				//frame-master;
	rockchip-spdif-card {
		compatible = "rockchip-spdif-card";
		dais {
			dai0 {
				audio-codec = <&codec_hdmi_spdif>;
				audio-controller = <&spdif>;
	rockchip-rk1000 {
		compatible = "rockchip-rk1000";
		dais {
			dai0 {
				audio-codec = <&rk1000_codec>;
				format = "i2s";
	rockchip-es8323 {
		compatible = "rockchip-es8323";
		dais {
			dai0 {
				audio-codec = <&es8323>;
				format = "i2s";
				//continuous-clock;
				//frame-inversion;
				//bitclock-master;
				//frame-master;
	rkxx-remotectl{
		compatible = "rockchip,remotectl";
                module-gpios = <&gpio7 GPIO_A0 GPIO_ACTIVE_LOW>;
        led-power = <&gpio8 GPIO_A1 GPIO_ACTIVE_LOW>;
	firefly-led{
		compatible = "firefly,led";
		led-work = <&gpio8 GPIO_A2 GPIO_ACTIVE_LOW>;
		status = "okay";
 	leds {
       compatible = "gpio-leds";
       power {
           label = "firefly:blue:power";
           linux,default-trigger = "ir-power-click";
           default-state = "on";
           gpios = <&gpio8 GPIO_A1 GPIO_ACTIVE_LOW>;
        user {
           label = "firefly:yellow:user";
           linux,default-trigger = "ir-user-click";
           default-state = "off";
           gpios = <&gpio8 GPIO_A2 GPIO_ACTIVE_LOW>;
	atx8_unsetup{
		compatible = "firefly,noatx8";
		atx8-rst = <&gpio7 GPIO_C5 GPIO_ACTIVE_HIGH>;
		status = "okay";
	usb_control {
		compatible = "rockchip,rk3288-usb-control";
		host_drv_gpio = <&gpio0 GPIO_B6 GPIO_ACTIVE_LOW>;
		otg_drv_gpio = <&gpio0 GPIO_B4 GPIO_ACTIVE_LOW>;
		rockchip,remote_wakeup;
		rockchip,usb_irq_wakeup;
&gmac {
//	pmu_regulator = "act_ldo5";
//	pmu_enable_level = <1>; //1->HIGH, 0->LOW
//	power-gpio = <&gpio0 GPIO_A6 GPIO_ACTIVE_HIGH>;
	reset-gpio = <&gpio4 GPIO_B0 GPIO_ACTIVE_LOW>;
	phy-mode = "rgmii";
	clock_in_out = "input";
	tx_delay = <0x30>;
	rx_delay = <0x20>;
&uart_dbg {
	 status = "okay";
&pinctrl {
	//used for init some gpio
	init-gpios = <&gpio8 GPIO_A0 GPIO_ACTIVE_HIGH
//		&gpio7 GPIO_B1 GPIO_ACTIVE_HIGH
		&gpio4 GPIO_B0 GPIO_ACTIVE_HIGH>;
	gpio0_gpio {
			gpio0_c2: gpio0-c2 {
				rockchip,pins = <GPIO0_C2>;
				rockchip,pull = <VALUE_PULL_DOWN>;
			//to add
	gpio7_gpio {
			gpio7_b7: gpio7-b7 {
				rockchip,pins = <GPIO7_B7>;
				rockchip,pull = <VALUE_PULL_UP>;
			//to add
	//could add other pinctrl definition such as gpio
	// gmac drive strength
	gpio4_gmac {
		mac_clk: mac-clk {
			rockchip,drive = <VALUE_DRV_12MA>;
		mac_txpins: mac-txpins {
		mac_rxpins: mac-rxpins {
		mac_crs: mac-crs {
		mac_mdpins: mac-mdpins {
&nandc0 {
	status = "okay"; // used nand set "okay" ,used emmc set "disabled"
&nandc1 {
	status = "disabled"; // used nand set "okay" ,used emmc set "disabled"
&nandc0reg {
&emmc {
	clock-frequency = <100000000>;
	clock-freq-min-max = <400000 100000000>;
        supports-highspeed;
	supports-emmc;
        bootpart-no-access;
	//supports-tSD;//only tsd-sdcard mode
	supports-DDR_MODE;
	caps2-mmc-hs200;
        ignore-pm-notify;
		keep-power-in-suspend;
		//poll-hw-reset
		status = "okay";
&sdmmc {
		clock-frequency = <50000000>;
		lock-freq-min-max = <400000 50000000>;
		supports-highspeed;
		supports-sd;
		broken-cd;
		card-detect-delay = <200>;
		ignore-pm-notify;
        	vmmc-supply = <&ldo1_reg>;
		status = "okay";
&sdio {
		clock-freq-min-max = <200000 50000000>;
		supports-highspeed;
		supports-sdio;
		ignore-pm-notify;
		//cap-sdio-irq;
		status = "okay";
&spi0 {
	status = "okay";
	max-freq = <48000000>;
    spidev@00 {
        compatible = "linux,spidev";
        reg = <0x00>;
        spi-max-frequency = <48000000>;
	spi_test@00 {
     		compatible = "rockchip,spi_test_bus0_cs0";
                reg = <0>;
                spi-max-frequency = <24000000>;
                //spi-cpha;
		//spi-cpol;
                poll_mode = <0>;
	        type = <0>;
		enable_dma = <0>;
	spi_test@01 {
	        compatible = "rockchip,spi_test_bus0_cs1";
	        reg = <1>;
	        spi-cpha;
		spi-cpol;
	        poll_mode = <0>;
	        type = <0>;
		enable_dma = <0>;
&spi1 {
	spi_test@10 {
	        compatible = "rockchip,spi_test_bus1_cs0";
	        reg = <0>;
	        //spi-cpha;
		//spi-cpol;
	        poll_mode = <0>;
	        type = <0>;
		enable_dma = <0>;
	//dtv: connect to dtv demodulator for control signal
	tstv-ctrl@00 {
		compatible = "rockchip,dtv_spi_ctrl";
		gpio-powerup = <&gpio0 GPIO_D7 GPIO_ACTIVE_HIGH>;
		gpio-powerdown = <&gpio2 GPIO_B6 GPIO_ACTIVE_HIGH>;
		gpio-reset = <&gpio2 GPIO_B7 GPIO_ACTIVE_HIGH>;
	        gpio-nreset = <&gpio2 GPIO_B4 GPIO_ACTIVE_HIGH>;
		spi-max-frequency = <12000000>;
		reg = <0>;
                poll_mode = <0>;
	        type = <0>;
		enable_dma = <0>;
&spi2 {
	spi_test@20 {
	        compatible = "rockchip,spi_test_bus2_cs0";
	        reg = <0>;
	        //spi-cpha;
		//spi-cpol;
	        poll_mode = <0>;
	        type = <0>;
		enable_dma = <0>;
	spi_test@21 {
	        compatible = "rockchip,spi_test_bus2_cs1";
	        reg = <1>;
	        //spi-cpha;
		//spi-cpol;
	        poll_mode = <0>;
	        type = <0>;
		enable_dma = <0>;
&uart_bt {
        status = "okay";
        dma-names = "!tx", "!rx";
        pinctrl-0 = <&uart0_xfer &uart0_cts>;
&uart_dbg {
	status = "okay";
&uart_bb {
    status = "okay";
&uart_gps {
    status = "okay";
&i2c0 {
	status = "okay";
	rk808: rk808@1b {
		reg = <0x1b>;
		status = "okay";
		syr827: syr827@40 {
		compatible = "silergy,syr82x";
  	reg = <0x40>;
		status = "okay";
		regulators {
			#size-cells = <0>;
			syr827_dc1: regulator@0 {
			reg = <0>;
			regulator-compatible = "syr82x_dcdc1";
			regulator-name = "vdd_arm";
			regulator-min-microvolt = <712500>;
			regulator-max-microvolt = <1500000>;
			regulator-boot-on;
			regulator-initial-mode = <0x2>;
			regulator-initial-state = <3>;
			regulator-state-mem {
				regulator-state-mode = <0x2>;
				regulator-state-enabled;
				regulator-state-uv = <900000>;
	syr828: syr828@41 {
		reg = <0x41>;
		status = "okay";
		regulators {
			#size-cells = <0>;
			syr828_dc1: regulator@0 {
			reg = <0>;
			regulator-name = "vdd_gpu";
  		regulator-boot-on;
				regulator-state-disabled;
	act8846: act8846@5a {
		reg = <0x5a>;
		status = "okay";
	rtc@51 {
		compatible = "rtc,hym8563";
		reg = <0x51>;
		irq_gpio = <&gpio7 GPIO_A4 IRQ_TYPE_EDGE_FALLING>;
&i2c1 {
	status = "okay";
	rtc@51 {
		compatible = "nxp,pcf8563";
		reg = <0x51>;
        synaptics_ts@20 {
                compatible = "synaptics,synaptics_dsx";
                reg = <0x20>;
        	touch-gpio = <&gpio8 GPIO_A7 IRQ_TYPE_EDGE_FALLING>;
                reset-gpio = <&gpio5 GPIO_B1 GPIO_ACTIVE_LOW>;
                //power-gpio = <&gpio0 GPIO_C5 GPIO_ACTIVE_LOW>;
                max-x = <1080>;
                max-y = <1920>;
                flip-x = <0>;
                flip-y = <0>;
     	mt@40 {
               	compatible = "firefly,gsl3680";
              	reg = <0x40>;
               	touch-gpio = <&gpio5 GPIO_B0 IRQ_TYPE_EDGE_RISING>;
               	reset-gpio = <&gpio7 GPIO_B1 GPIO_ACTIVE_LOW>;
               	max-y = <2048>;
               	max-x = <1536>;
		flip-x = <1>;
		flip-y = <1>;
		swap-xy = <0>;
        ts@41 {
      		reg = <0x41>;
         	touch-gpio = <&gpio8 GPIO_A7 IRQ_TYPE_EDGE_RISING>;
         	//reset-gpio = <&gpio8 GPIO_A6 GPIO_ACTIVE_LOW>;
         	max-x = <1280>;
         	max-y = <800>;
		flip-x = <0>;
		flip-y = <0>;
		swap-xy = <1>;
        mpu6050:mpu@68{
            compatible = "mpu6050";
            reg = <0x68>;
            mpu-int_config = <0x10>;
            mpu-level_shifter = <0>;
            mpu-orientation = <0 1 0 1 0 0 0 0 1>;
            orientation-x= <1>;
            orientation-y= <1>;
            orientation-z= <1>;
            irq-gpio = <&gpio5 GPIO_B4 IRQ_TYPE_LEVEL_LOW>;
            mpu-debug = <0>;
&i2c2 {
	status = "okay";
	es8323: es8323@10 {
	    compatible = "es8323";
		reg = <0x10>;
		spk-con-gpio = <&gpio0 GPIO_B2 GPIO_ACTIVE_HIGH>;
		hp-det-gpio = <&gpio7 GPIO_B7 GPIO_ACTIVE_HIGH>;
		hp-mic-only = <1>;
		clocks = <&clk_i2s>, <&clk_i2s_out>;
		clock-names = "i2s_clk","i2s_mclk";
		pinctrl-names = "default";
		pinctrl-0 = <&i2s_mclk>;
&i2c3 {
	status = "okay";
&i2c4 {
	status = "okay";
	rk1000_control@40 {
		compatible = "rockchip,rk1000_control";
		reg = <0x40>;
		gpio-reset = <&gpio7 GPIO_C5 GPIO_ACTIVE_LOW>;
		//pinctrl-names = "default";
		//pinctrl-0 = <&i2s_mclk>;
	rk1000_tve@42 {
		compatible = "rockchip,rk1000_tve";
		reg = <0x42>;
//		gpio-switch = <&gpio3 GPIO_D4 GPIO_ACTIVE_LOW>;
		rockchip,source = <0>; //0: LCDC0; 1: LCDC1
		rockchip,prop = <PRMRY>;//<EXTEND>
	rk1000_codec: rk1000_codec@60 {
		compatible = "rockchip,rk1000_codec";
		reg = <0x60>;
		spk_ctl_io = <&gpio7 GPIO_A5 GPIO_ACTIVE_LOW>;
		boot_depop = <1>;
		pa_enable_time = <5000>;
	vga_ddc@50 {
		compatible = "firefly,vga_ddc";
		reg = <0x50>;
		gpio-pwn = <&gpio0 GPIO_C1 GPIO_ACTIVE_HIGH>;
		status = "okay";
&i2c5 {
/*$_rbox_$_modify_$_begin_huangzhibao for rk1000*/
//&i2s{
//    pinctrl-names = "default", "sleep";
//		pinctrl-0 = <&i2s_sclk &i2s_lrckrx &i2s_lrcktx &i2s_sdi &i2s_sdo0 &i2s_sdo1 &i2s_sdo2 &i2s_sdo3>;
//		pinctrl-1 = <&i2s_gpio>;
/*$_rbox_$_modify_$_end*/
&fb {
	rockchip,disp-mode = <DUAL>;
	rockchip,uboot-logo-on = <0>;
	rockchip,disp-policy = <DISPLAY_POLICY_BOX_TEMP>;
// kou default
//&disp_timings {
//	native-mode = <&timing1>;
// kou custom
&disp_timings {
	native-mode = <&timing0>;
&rk_screen {
	 display-timings = <&disp_timings>;
/*lcdc0 as PRMRY(HDMI),lcdc1 as EXTEND(RK1000)*/
&lcdc0 {
	status = "okay";
	rockchip,iommu-enabled = <1>;
&lcdc1 {
	status = "okay";
	rockchip,prop = <EXTEND>;
&hdmi {
	status = "okay";
	rockchips,hdmi_audio_source = <0>;
	hdmi_cec = <0>;
&adc {
	status = "okay";
	key {
		compatible = "rockchip,key";
		io-channels = <&adc 1>;
		vol-up-key {
			linux,code = <115>;
			label = "volume up";
			rockchip,adc_value = <1>;
		vol-down-key {
			linux,code = <114>;
			label = "volume down";
			rockchip,adc_value = <170>;
		power-key {
			gpios = <&gpio0 GPIO_A5 GPIO_ACTIVE_LOW>;
			linux,code = <116>;
			label = "power";
			gpio-key,wakeup;
		recovery-key {
			linux,code = <113>;
			label = "recovery";
			rockchip,adc_value = <4>;
		menu-key {
			linux,code = <59>;
			label = "menu";
			rockchip,adc_value = <355>;
		home-key {
			linux,code = <102>;
			label = "home";
			rockchip,adc_value = <746>;
		back-key {
			linux,code = <158>;
			label = "back";
			rockchip,adc_value = <560>;
		camera-key {
			linux,code = <212>;
			label = "camera";
			rockchip,adc_value = <450>;
/*&pwm0 {
        interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
        status = "okay";
&pwm1 {
&clk_core_dvfs_table {
	support-pvtm = <0>;
	pvtm-operating-points = <
		/* KHz    uV 	pvtm margin*/
		126000 900000	25000
		216000 900000	25000
		312000 900000	25000
		408000 900000	25000
		600000 950000	50000
		696000 950000	25000
		816000 1000000	25000
		1008000 1050000	25000
		1200000 1100000	25000
		1416000 1200000	25000
		1512000 1300000	25000
		1608000 1350000	25000
		1704000 1350000	25000
		1800000 1350000	25000
	status="okay";
&clk_gpu_dvfs_table {
		/* KHz    uV */
//		100000 900000
		200000 900000
		300000 950000
		420000 1100000
		500000 1150000
	//	600000 1250000
	status="okay";
&clk_ddr_dvfs_table {
		/* KHz    uV */
		200000 1075000
		300000 1075000
		456000 1125000
		533000 1150000
	freq-table = <
		/*status		freq(KHz)*/
		SYS_STATUS_NORMAL	456000
		SYS_STATUS_SUSPEND	200000
		//SYS_STATUS_VIDEO_1080P  240000
		SYS_STATUS_VIDEO_4K     456000
		SYS_STATUS_PERFORMANCE  533000
		//SYS_STATUS_BOOST	324000
		//SYS_STATUS_ISP		400000
	auto-freq-table = <
		240000
		324000
		456000
		528000
	auto-freq=<0>;
	status="okay";
/include/ "act8846.dtsi"
&act8846 {
	gpios =<&gpio7 GPIO_B6 GPIO_ACTIVE_LOW>,<&gpio0 GPIO_A1 GPIO_ACTIVE_HIGH>;
	cpu_det_gpio =<&gpio7 GPIO_B2 GPIO_ACTIVE_LOW>;
	usb_hub_reset_gpio =<&gpio8 GPIO_A3 GPIO_ACTIVE_LOW>;
	act8846,system-power-controller;
	regulators {
		dcdc1_reg: regulator@0{
			regulator-name= "act_dcdc1";
			regulator-min-microvolt = <1200000>;
			regulator-max-microvolt = <1200000>;
			regulator-boot-on;
		dcdc2_reg: regulator@1 {
			regulator-name= "vccio";
			regulator-min-microvolt = <3300000>;
			regulator-max-microvolt = <3300000>;
				regulator-state-uv = <3300000>;
		dcdc3_reg: regulator@2 {
			regulator-min-microvolt = <700000>;
				regulator-state-uv = <1200000>;
		dcdc4_reg: regulator@3 {
			regulator-name= "act_dcdc4";
			regulator-min-microvolt = <2000000>;
			regulator-max-microvolt = <2000000>;
				regulator-state-uv = <2000000>;
		ldo1_reg: regulator@4 {
			regulator-name= "vccio_sd";
			regulator-min-microvolt = <1800000>;
		ldo2_reg: regulator@5 {
			regulator-name= "act_ldo2";
			regulator-min-microvolt = <1050000>;
			regulator-max-microvolt = <1050000>;
		ldo3_reg: regulator@6 {
			regulator-name= "act_ldo3";
			regulator-min-microvolt = <2800000>;
			regulator-max-microvolt = <2800000>;
		ldo4_reg:regulator@7 {
			regulator-name= "act_ldo4";
		ldo5_reg: regulator@8 {
			regulator-name= "act_ldo5";
		ldo6_reg: regulator@9 {
			regulator-name= "act_ldo6";
			regulator-min-microvolt = <1100000>;
			regulator-max-microvolt = <1100000>;
		ldo7_reg: regulator@10 {
			regulator-name= "vcc_18";
			regulator-max-microvolt = <1800000>;
		ldo8_reg: regulator@11 {
			regulator-name= "act_ldo8";
			regulator-min-microvolt = <1850000>;
			regulator-max-microvolt = <1850000>;
/include/ "rk808.dtsi"
&rk808 {
	gpios =<&gpio0 GPIO_A4 GPIO_ACTIVE_HIGH>,<&gpio0 GPIO_B3 GPIO_ACTIVE_LOW>;
	rk808,system-power-controller;
	regulators {
		rk808_dcdc1_reg: regulator@0{
			regulator-name= "vdd_arm";
			regulator-boot-on;
		rk808_dcdc2_reg: regulator@1 {
			regulator-name= "vdd_gpu";
			regulator-boot-on;
		rk808_dcdc3_reg: regulator@2 {
			regulator-name= "rk_dcdc3";
			regulator-boot-on;
		rk808_dcdc4_reg: regulator@3 {
			regulator-boot-on;
    /* NO USED, 3.3V*/
		rk808_ldo1_reg: regulator@4 {
			regulator-name= "rk_ldo1";
			regulator-boot-on;
    /* BOX:RK1000s, 3.3V  */
		rk808_ldo2_reg: regulator@5 {
			regulator-name= "rk_ldo2";
			regulator-boot-on;
    /* RK3288 PLL,USB PHY, 1.0V */
		rk808_ldo3_reg: regulator@6 {
			regulator-name= "rk_ldo3";
			regulator-min-microvolt = <1000000>;
			regulator-max-microvolt = <1000000>;
			regulator-boot-on;
    /* BOX:RK1000S CORE, 1.8V  */
		rk808_ldo4_reg:regulator@7 {
			regulator-name= "rk_ldo4";
			regulator-boot-on;
    /* SDMMC IO, 3.3V*/
		rk808_ldo5_reg: regulator@8 {
			regulator-name= "rk_ldo5";
			regulator-boot-on;
    /* CAMERA, 1.8V  box modify*/
		rk808_ldo6_reg: regulator@9 {
			regulator-name= "rk_ldo6";
			regulator-boot-on;
    /* RK3288 USB PHY, SAR-ADC, WIFI IO, 1.8V */
		rk808_ldo7_reg: regulator@10 {
			regulator-name= "rk_ldo7";
			regulator-boot-on;
    /* DTV, 3.3V  box modify*/
		rk808_ldo8_reg: regulator@11 {
			regulator-name= "rk_ldo8";
			regulator-boot-on;
		rk808_ldo9_reg: regulator@12 {
			regulator-name= "rk_ldo9";
			regulator-boot-on;
		rk808_ldo10_reg: regulator@13 {
			regulator-name= "rk_ldo10";
			regulator-boot-on;
&vpu {
	iommu_enabled = <1>;
&lcdc_vdd_domain {
	regulator-name = "vcc30_lcd";
&dpio_vdd_domain{
	regulator-name = "vcc18_cif";
&flash0_vdd_domain{
	regulator-name = "vcc_flash";
&flash1_vdd_domain{
&apio3_vdd_domain{
	regulator-name = "vccio_wl";
&apio5_vdd_domain{
	regulator-name = "vccio";
&apio4_vdd_domain{
&apio1_vdd_domain{
&apio2_vdd_domain{
&sdmmc0_vdd_domain{
	regulator-name = "vcc_sd";
&remotectl {
	handle_cpu_id = <1>;
	status = "okay";
	ir_key1{
		rockchip,usercode = <0xff00>;
		rockchip,key_table =
			<0xeb   KEY_POWER>,
			<0xec   KEY_MENU>,
			<0xfe   KEY_BACK>,
			<0xb7   KEY_HOME>,
			<0xa3   250>,
			<0xf4   KEY_VOLUMEUP>,
			<0xa7   KEY_VOLUMEDOWN>,
			<0xf8   KEY_REPLY>,
			<0xfc   KEY_UP>,
			<0xfd   KEY_DOWN>,
			<0xf1   KEY_LEFT>,
			<0xe5   KEY_RIGHT>;
 * Due to not have the software of PWM for remotectrl.
 * We can _*HACK*_ do that as the following.
&pwm0 {
	compatible = "rockchip,remotectl-pwm";
	remote_pwm_id = <0>;
	status = "okay";
	ir_key1{
			<0xeb   KEY_POWER>,
			<0xec   KEY_MENU>,
			<0xfe   KEY_BACK>,
			<0xb7   KEY_HOME>,
			<0xa3   250>,
			<0xf8   KEY_REPLY>,
			<0xfc   KEY_UP>,
			<0xfd   KEY_DOWN>,
			<0xf1   KEY_LEFT>,
			<0xe5   KEY_RIGHT>;
下面是dtsi 文件: lvds-lcd-box.dtsi
 * RockChip. LCD_BOX
	 	disp_power_ctr: power_ctr {
                     /*                        rockchip,debug = <0>;
                        lcd_en:lcd_en {
                                rockchip,power_type = <GPIO>;
                                gpios = <&gpio0 GPIO_B0 GPIO_ACTIVE_HIGH>;
                                rockchip,delay = <10>;
                        bl_en:bl_en {
                                gpios = <&gpio0 GPIO_A2 GPIO_ACTIVE_HIGH>;
                        bl_ctr:bl_ctr {
                                gpios = <&gpio3 GPIO_D6 GPIO_ACTIVE_HIGH>;
                        lcd_rst:lcd_rst {
                                rockchip,power_type = <REGULATOR>;
                                rockchip,delay = <5>;
                     	timing0: timing0 {
				screen-type = <SCREEN_LVDS>; // kou
				lvds-format = <LVDS_6BIT>;
				out-face    = <OUT_P666>;
				color-mode = <COLOR_RGB>;
				clock-frequency = <75440000>;
				hactive = <1366>;
				vactive = <768>;
				hback-porch = <80>;
				hfront-porch = <80>;
				vback-porch = <19>;
				vfront-porch = <19>;
				hsync-len = <44>;
				vsync-len = <8>;
				hsync-active = <0>;
				vsync-active = <0>;
				de-active = <0>;
				pixelclk-active = <1>;
				swap-rb = <0>;
				swap-rg = <0>;
				swap-gb = <0>;
你的kernel都还走到,你尝试重新下载一下uboot固件或者下载整个android镜像,最后再替换resource.img
