android移植
是这样的 我想把RK发布的SDK移植到萤火虫的AIO3399j板子上让它跑起来 现在内核以及跑起来了 但是安卓系统没起来 系统服务不断的重启和被杀死 如下是开机log 麻烦版主和各位大佬看看?
DDR Version 1.08 20170320
Channel 0: DDR3, 800MHz
Channel 1: DDR3, 800MHz
256B stride
Boot1: 2017-06-09, version: 1.09
CPUId = 0x0
ChipType = 0x10, 1825
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 65986
LoadTrustBL
No find bl30.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0x725b4
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):9f93abc
NOTICE: BL31: Built : 10:18:20, Jul 27 2017
INFO: plat_rockchip_pmu_init(1089): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-96-g3fbe315-dev #4 Fri Jun 30 00:35:17 UTC 2017 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.1
INFO: SPSR = 0x3c9
U-Boot 2014.10-RK3399-06-02507-g99e11be-dirty (Jun 26 2018 - 10:20:23)
CPU: rk3399
cpu version = 0
CPU’s clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Uboot as second level loader
DRAM: Found dram banks: 1
Reserve memory for trust os.
dram reserve bank: base = 0x08400000, size = 0x01000000
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
can’t find dts node for fixed
pmic:rk808
can’t find dts node for pwm1
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 800000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
#Boot ver: 2018-06-26#1.09
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
Warn: route-edp: connector node is not available
no fuel gauge found
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x01303808)
ramdisk @ 0x05bf0000 (0x001e6594)
bootrk: do_bootm_linux…
Loading Device Tree to 0000000005600000, end 000000000561514d … OK
Add bank:0000000009400000, 0000000076c00000
[ 0.000000] Linux version 4.4.83 (jiawenchen@sbote.com) (gcc version 4.9 20150123 (prerelease) (GCC) ) #4 SMP PREEMPT Fri Jul 13 17:12:06 CST 2018
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07ef00000 s45696 r8192 d32128 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 511496
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00020000@0x0002C000(recovery),0x00038000@0x0004C000(backup),0x00040000@0x00084000(cache),0x00300000@0x000C4000(system),0x00008000@0x003C4000(metadata),0x00000040@0x003CC000(verity_mode),0x00002000@0x003CC040(baseparamer),0x00000400@0x003CE040(frp),-@0x003CE440(userdata) storagemedia=emmc uboot_logo=0x02000000@0x7dc00000 loader.timestamp=2018-06-26_10:20:23 SecureBootCheckOk=0
[ 0.000000] software IO TLB [mem 0x7edb4000-0x7edf4000] (0MB) mapped at [ffffffc07edb4000-ffffffc07edf3fff]
[ 0.000000] Memory: 2002508K/2078720K available (11710K kernel code, 1422K rwdata, 5444K rodata, 832K init, 1112K bss, 59828K reserved, 16384K cma-reserved)
[ 0.000000] .init : 0xffffff8009150000 - 0xffffff8009220000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bf0000 ( 11712 KB)
[ 0.000000] .rodata : 0xffffff8008bf0000 - 0xffffff8009150000 ( 5504 KB)
[ 0.000000] .data : 0xffffff8009220000 - 0xffffff8009383808 ( 1423 KB)
[ 0.000000] ITS: allocated 65536 Devices @7c400000 (psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x000000007c480000
[ 0.000000] CPU0: using LPI pending table @0x000000007c490000
[ 0.001818] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002806] pid_max: default: 32768 minimum: 301
[ 0.003312] Security Framework initialized
[ 0.003711] SELinux: Initializing.
[ 0.004153] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004799] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006254] Initializing cgroup subsys freezer
[ 0.006694] Initializing cgroup subsys debug
[ 0.007987] sched-energy: Sched-energy-costs installed from DT
[ 0.008551] CPU0: update cpu_capacity 401
[ 0.009013] ASID allocator initialised with 65536 entries
[ 0.025845] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027084] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039238] Detected VIPT I-cache on CPU1
[ 0.039268] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039302] CPU1: using LPI pending table @0x000000007c5f0000
[ 0.039346] CPU1: update cpu_capacity 401
[ 0.039350] CPU1: Booted secondary processor [410fd034]
[ 0.049224] Detected VIPT I-cache on CPU2
[ 0.049243] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049275] CPU2: using LPI pending table @0x000000007c620000
[ 0.049303] CPU2: update cpu_capacity 401
[ 0.049306] CPU2: Booted secondary processor [410fd034]
[ 0.059261] Detected VIPT I-cache on CPU3
[ 0.059280] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059312] CPU3: using LPI pending table @0x000000007c660000
[ 0.059340] CPU3: update cpu_capacity 401
[ 0.059343] CPU3: Booted secondary processor [410fd034]
[ 0.069304] Detected PIPT I-cache on CPU4
[ 0.069333] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069373] CPU4: using LPI pending table @0x000000007c6a0000
[ 0.069413] CPU4: update cpu_capacity 1024
[ 0.069416] CPU4: Booted secondary processor [410fd082]
[ 0.079329] Detected PIPT I-cache on CPU5
[ 0.079348] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079384] CPU5: using LPI pending table @0x000000007c6d0000
[ 0.079411] CPU5: update cpu_capacity 1024
[ 0.079414] CPU5: Booted secondary processor [410fd082]
[ 0.079496] Brought up 6 CPUs
[ 0.091915] SMP: Total of 6 processors activated.
[ 0.092369] CPU features: detected feature: GIC system register CPU interface
[ 0.093057] CPU: All CPU(s) started at EL2
[ 0.093489] alternatives: patching kernel code
[ 0.095605] devtmpfs: initialized
[ 0.115066] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.116025] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117722] pinctrl core: initialized pinctrl subsystem
[ 0.120723] Failed to find legacy iommu devices
[ 0.121710] NET: Registered protocol family 16
[ 0.122772] schedtune: init normalization constants…
[ 0.123272] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.123899] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.124541] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.125169] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.125795] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.126423] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.127049] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.127676] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.128313] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.128940] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.129671] schedtune: verify normalization constants…
[ 0.130182] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.130716] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.131251] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.131796] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.132330] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.132865] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.133400] schedtune: configured to support 5 boost groups
[ 0.141832] cpuidle: using governor ladder
[ 0.151857] cpuidle: using governor menu
[ 0.152254] Registered FIQ tty driver
[ 0.153184] vdso: 2 pages (1 code @ ffffff8008bf6000, 1 data @ ffffff8009224000)
[ 0.153917] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.155408] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.178144] console [pstore0] enabled
[ 0.178808] pstore: Registered ramoops as persistent store backend
[ 0.179407] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.183215] sip_fiq_debugger_uart_irq_tf_init error: -2
[ 0.183724] fiq debugger bind fiq to trustzone failed: -2
[ 0.184634] console [ttyFIQ0] enabled
[[ 0.184634] console [ttyFIQ0] enabled
[ 0.185153] bootconsole [uart0] disabled
[ 0.186444] Registered fiq debugger ttyFIQ0
[ 0.236919] Rockchip hdmi driver version 2.0
[ 0.239013] iommu: Adding device ff650000.vpu_service to group 0
[ 0.239093] iommu: Adding device ff660000.rkvdec to group 1
[ 0.239156] iommu: Adding device ff670000.iep to group 2
[ 0.239240] iommu: Adding device ff8f0000.vop to group 3
[ 0.239309] iommu: Adding device ff900000.vop to group 4
[ 0.239398] iommu: Adding device ff910000.isp to group 5
[ 0.239473] iommu: Adding device ff920000.isp to group 6
[ 0.240091] rk_iommu ff670800.iommu: can’t get aclk
[ 0.240129] rk_iommu ff670800.iommu: can’t get hclk
[ 0.240994] SCSI subsystem initialized
[ 0.241183] usbcore: registered new interface driver usbfs
[ 0.241231] usbcore: registered new interface driver hub
[ 0.241322] usbcore: registered new device driver usb
[ 0.241627] media: Linux media interface: v0.10
[ 0.241666] Linux video capture interface: v2.00
[ 0.241796] pps_core: LinuxPPS API ver. 1 registered
[ 0.241807] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.241834] PTP clock support registered
[ 0.243107] Advanced Linux Sound Architecture Driver Initialized.
[ 0.243594] Bluetooth: Core ver 2.21
[ 0.243626] NET: Registered protocol family 31
[ 0.243636] Bluetooth: HCI device and connection manager initialized
[ 0.243653] Bluetooth: HCI socket layer initialized
[ 0.243666] Bluetooth: L2CAP socket layer initialized
[ 0.243694] Bluetooth: SCO socket layer initialized
[ 0.244646] rockchip-cpuinfo cpuinfo: Serial : 6213564bb0e3f7b3
[ 0.245110] clocksource: Switched to clocksource arch_sys_counter
[ 0.283993] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.284852] NET: Registered protocol family 2
[ 0.285298] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.285406] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.285527] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.285603] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.285635] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.285787] NET: Registered protocol family 1
[ 0.286228] Trying to unpack rootfs image as initramfs…
[ 0.384424] Freeing initrd memory: 1944K
[ 0.384933] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.385026] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.388544] audit: initializing netlink subsys (disabled)
[ 0.388608] audit: type=2000 audit(0.383:1): initialized
[ 0.394149] VFS: Disk quotas dquot_6.6.0
[ 0.394272] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.395649] fuse init (API version 7.23)
[ 0.396657]
[ 0.396657] TEE Core Framework initialization (ver 1:0.1)
[ 0.396690] TEE armv7 Driver initialization
[ 0.397009] tz_tee_probe: name=“armv7sec”, id=0, pdev_name=“armv7sec.0”
[ 0.397025] TEE core: Alloc the misc device “opteearmtz00” (id=0)
[ 0.397198] TEE Core: Register the misc device “opteearmtz00” (id=0,minor=62)
[ 0.401042] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.401074] io scheduler noop registered
[ 0.401243] io scheduler cfq registered (default)
[ 0.404837] iep: failed to find iep power down clock source.
[ 0.405622] IEP Power ON
[ 0.405788] IEP Power OFF
[ 0.405817] IEP Driver loaded succesfully
[ 0.405907] Module initialized.
[ 0.409692] rk-vcodec ff650000.vpu_service: probe device
[ 0.409739] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07bcccc10
[ 0.409873] rk-vcodec ff650000.vpu_service: allocator is drm
[ 0.409927] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 0.410355] rk-vcodec ff650000.vpu_service: init success
[ 0.410881] rk-vcodec ff660000.rkvdec: probe device
[ 0.410921] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07bccd410
[ 0.411048] rk-vcodec ff660000.rkvdec: allocator is drm
[ 0.411104] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 0.411402] rk-vcodec ff660000.rkvdec: init success
[ 0.412727] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.412746] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 0.414039] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 0.414057] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_?ak0.415375] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 0.416903] console [ttyS0] disabled
[ 0.416947] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 34, base_baud = 1500000) is a 16550A
[ 0.417518] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 35, base_baud = 1500000) is a 16550A
[ 0.417905] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 0.420818] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 0.421039] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 0.421274] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 0.421294] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.421357] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.425344] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 0.425370] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.425384] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 0.425573] rockchip-drm display-subsystem: failed to parse loader memory
[ 0.425604] rockchip-drm display-subsystem: No connectors reported connected with modes
[ 0.425646] [drm:drm_fb_helper_single_fb_probe] Cannot find any crtc or sizes - going 1024x768
[ 0.429970] rockchip-drm display-subsystem: fb0: frame buffer device
[ 0.447571] mali ff9a0000.gpu: Failed to get regulator
[ 0.447597] mali ff9a0000.gpu: Power control initialization failed
[ 0.447893] Unable to detect cache hierarchy from DT for CPU 0
[ 0.462817] brd: module loaded
[ 0.467744] loop: module loaded
[ 0.468556] zram: Added device: zram0
[ 0.469446] SCSI Media Changer driver v0.25
[ 0.470369] tun: Universal TUN/TAP device driver, 1.6
[ 0.470829] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.471858] PPP generic driver version 2.4.2
[ 0.472408] PPP BSD Compression module registered
[ 0.472851] PPP Deflate Compression module registered
[ 0.473332] PPP MPPE Compression module registered
[ 0.473790] NET: Registered protocol family 24
[ 0.474241] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 0.475132] CSLIP: code copyright 1989 Regents of the University of California.
[ 0.475802] Rockchip WiFi SYS interface (V1.00) …
[ 0.476330] usbcore: registered new interface driver catc
[ 0.476865] usbcore: registered new interface driver kaweth
[ 0.477379] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 0.478077] usbcore: registered new interface driver pegasus
[ 0.478630] usbcore: registered new interface driver rtl8150
[ 0.478682] usbcore: registered new interface driver r8152
[ 0.478700] hso: drivers/net/usb/hso.c: Option Wireless
[ 0.478759] usbcore: registered new interface driver hso
[ 0.478814] usbcore: registered new interface driver asix
[ 0.478859] usbcore: registered new interface driver ax88179_178a
[ 0.478903] usbcore: registered new interface driver cdc_ether
[ 0.478946] usbcore: registered new interface driver cdc_eem
[ 0.478991] usbcore: registered new interface driver dm9601
[ 0.479047] usbcore: registered new interface driver smsc75xx
[ 0.479099] usbcore: registered new interface driver smsc95xx
[ 0.479143] usbcore: registered new interface driver gl620a
[ 0.479187] usbcore: registered new interface driver net1080
[ 0.479230] usbcore: registered new interface driver plusb
[ 0.479276] usbcore: registered new interface driver rndis_host
[ 0.479322] usbcore: registered new interface driver cdc_subset
[ 0.479365] usbcore: registered new interface driver zaurus
[ 0.479410] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 0.479465] usbcore: registered new interface driver int51x1
[ 0.479507] usbcore: registered new interface driver kalmia
[ 0.479549] usbcore: registered new interface driver ipheth
[ 0.479592] usbcore: registered new interface driver sierra_net
[ 0.479633] usbcore: registered new interface driver cx82310_eth
[ 0.479682] usbcore: registered new interface driver cdc_ncm
[ 0.479722] usbcore: registered new interface driver qmi_wwan
[ 0.479765] usbcore: registered new interface driver cdc_mbim
[ 0.480829] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 0.482069] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.482087] ehci-pci: EHCI PCI platform driver
[ 0.482139] ehci-platform: EHCI generic platform driver
[ 0.482509] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.482543] ohci-platform: OHCI generic platform driver
[ 0.483130] usbcore: registered new interface driver cdc_acm
[ 0.483143] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 0.483200] usbcore: registered new interface driver usblp
[ 0.483245] usbcore: registered new interface driver cdc_wdm
[ 0.483288] usbcore: registered new interface driver uas
[ 0.483345] usbcore: registered new interface driver usb-storage
[ 0.483384] usbcore: registered new interface driver ums-alauda
[ 0.483423] usbcore: registered new interface driver ums-cypress
[ 0.483462] usbcore: registered new interface driver ums-datafab
[ 0.483500] usbcore: registered new interface driver ums_eneub6250
[ 0.483539] usbcore: registered new interface driver ums-freecom
[ 0.483578] usbcore: registered new interface driver ums-isd200
[ 0.483617] usbcore: registered new interface driver ums-jumpshot
[ 0.483661] usbcore: registered new interface driver ums-karma
[ 0.483698] usbcore: registered new interface driver ums-onetouch
[ 0.483736] usbcore: registered new interface driver ums-sddr09
[ 0.483774] usbcore: registered new interface driver ums-sddr55
[ 0.483812] usbcore: registered new interface driver ums-usbat
[ 0.483892] usbcore: registered new interface driver usbserial
[ 0.483928] usbcore: registered new interface driver usbserial_generic
[ 0.483962] usbserial: USB Serial support registered for generic
[ 0.484004] usbcore: registered new interface driver ch341
[ 0.484034] usbserial: USB Serial support registered for ch341-uart
[ 0.484073] usbcore: registered new interface driver cp210x
[ 0.484103] usbserial: USB Serial support registered for cp210x
[ 0.484141] usbcore: registered new interface driver option
[ 0.484172] usbserial: USB Serial support registered for GSM modem (1-port)
[ 0.484219] usbcore: registered new interface driver trancevibrator
[ 0.484235] usb20_otg: version 3.10a 21-DEC-2012
[ 0.484377] usb20_host: version 3.10a 21-DEC-2012
[ 0.484775] usbcore: registered new interface driver xpad
[ 0.484823] usbcore: registered new interface driver usb_acecad
[ 0.484871] usbcore: registered new interface driver aiptek
[ 0.484916] usbcore: registered new interface driver gtco
[ 0.484959] usbcore: registered new interface driver hanwang
[ 0.485002] usbcore: registered new interface driver kbtab
[ 0.488708] sensor_register_slave:mma8452,id=17
[ 0.488726] sensor_register_slave:lis3dh,id=7
[ 0.488740] sensor_register_slave:mma7660,id=18
[ 0.488754] sensor_register_slave:lsm303d,id=22
[ 0.488768] sensor_register_slave:gs_mc3230,id=23
[ 0.488778] [Gsensor] gsensor_init
[ 0.488791] sensor_register_slave:mpu6880_acc,id=24
[ 0.488805] sensor_register_slave:mpu6500_acc,id=25
[ 0.488819] sensor_register_slave:lsm330_acc,id=26
[ 0.488833] sensor_register_slave:akm8975,id=28
[ 0.488848] sensor_register_slave:akm8963,id=29
[ 0.488862] sensor_register_slave:l3g4200d,id=43
[ 0.488875] sensor_register_slave:l3g20d,id=44
[ 0.488889] sensor_register_slave:ewtsa,id=45
[ 0.488902] sensor_register_slave:lsm330_gyro,id=48
[ 0.488916] sensor_register_slave:cm3217,id=50
[ 0.488930] sensor_register_slave:cm3218,id=51
[ 0.489552] i2c /dev entries driver
[ 0.490869] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 0.490934] fan53555-reg: supplied by vcc5v0_sys
[ 0.493153] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 0.493200] fan53555-reg: supplied by vcc5v0_sys
[ 0.495523] rk808 0-001b: Pmic Chip id: 0x0
[ 0.498706] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 0.498761] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 0.498844] DCDC_REG1: supplied by vcc3v3_sys
[ 0.499521] DCDC_REG2: supplied by vcc3v3_sys
[ 0.500011] DCDC_REG3: supplied by vcc3v3_sys
[ 0.500225] DCDC_REG4: supplied by vcc3v3_sys
[ 0.500601] LDO_REG1: supplied by vcc3v3_sys
[ 0.501633] LDO_REG2: supplied by vcc3v3_sys
[ 0.502539] LDO_REG3: supplied by vcc3v3_sys
[ 0.503435] LDO_REG4: supplied by vcc3v3_sys
[ 0.504324] LDO_REG5: supplied by vcc3v3_sys
[ 0.505229] LDO_REG6: supplied by vcc3v3_sys
[ 0.506135] LDO_REG7: supplied by vcc3v3_sys
[ 0.507028] LDO_REG8: supplied by vcc3v3_sys
[ 0.507918] SWITCH_REG1: supplied by vcc3v3_sys
[ 0.508143] SWITCH_REG2: supplied by vcc3v3_sys
[ 0.511475] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 0.511900] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80096dc000
[ 0.512376] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff80096de000
[ 0.512454] rockchip-pinctrl pinctrl: pin gpio4-17 already requested by ff940000.hdmi; cannot claim for ff130000.i2c
[ 0.512472] rockchip-pinctrl pinctrl: pin-145 (ff130000.i2c) status -22
[ 0.512487] rockchip-pinctrl pinctrl: could not request pin 145 (gpio4-17) from group i2c3-xfer on device rockchip-pinctrl
[ 0.512503] rk3x-i2c ff130000.i2c: Error applying setting, reverse things back
[ 0.512841] rk3x-i2c ff130000.i2c: Initialized RK3xxx I2C bus at ffffff80096fa000
[ 0.513245] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at ffffff80096fc000
[ 0.514404] fusb302 4-0022: fusb302 send extcon to disable vbus 5v
[ 0.517949] fusb302 4-0022: port 0 probe success
[ 0.517979] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80096fe000
[ 0.518897] IR NEC protocol handler initialized
[ 0.518915] IR RC5(x/sz) protocol handler initialized
[ 0.518932] IR RC6 protocol handler initialized
[ 0.518949] IR JVC protocol handler initialized
[ 0.518965] IR Sony protocol handler initialized
[ 0.518981] IR SANYO protocol handler initialized
[ 0.518998] IR Sharp protocol handler initialized
[ 0.519014] IR MCE Keyboard/mouse protocol handler initialized
[ 0.519031] IR XMP protocol handler initialized
[ 0.519113] usbcore: registered new interface driver uvcvideo
[ 0.519123] USB Video Class driver (1.1.1)
[ 0.519143] CamSys driver version: v0.34.5, CamSys head file version: v0.13.0
[ 0.522918] __power_supply_register: Expected proper parent device for ‘test_ac’
[ 0.523046] __power_supply_register: Expected proper parent device for ‘test_battery’
[ 0.523279] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 0.523377] __power_supply_register: Expected proper parent device for ‘test_usb’
[ 0.525327] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 0.525831] device-mapper: uevent: version 1.0.3
[ 0.526091] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 0.526219] Bluetooth: HCI UART driver ver 2.3
[ 0.526233] Bluetooth: HCI UART protocol H4 registered
[ 0.526244] Bluetooth: HCI UART protocol LL registered
[ 0.526258] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 0.526269] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 0.526279] rtk_btusb: Register usb char device interface for BT driver
[ 0.526470] usbcore: registered new interface driver rtk_btusb
[ 0.526818] cpu cpu0: leakage=23
[ 0.543197] cpu cpu0: temp=46875, pvtm=147639 (147309 + 330)
[ 0.543429] cpu cpu0: pvtm-sel=1
[ 0.543708] cpu cpu4: leakage=42
[ 0.555597] cpu cpu4: temp=46875, pvtm=153351 (153176 + 175)
[ 0.555752] cpu cpu4: pvtm-sel=1
[ 0.559622] sdhci: Secure Digital Host Controller Interface driver
[ 0.559648] sdhci: Copyright(c) Pierre Ossman
[ 0.559663] Synopsys Designware Multimedia Card Interface Driver
[ 0.560396] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.560600] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 0.560623] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 0.560670] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 0.560696] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 0.560741] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 0.560753] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 0.561442] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.561496] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 0.561516] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 0.561561] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.561585] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 0.561679] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 0.562227] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.563814] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 0.563828] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 0.591882] mmc0: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 0.592651] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.595231] usbcore: registered new interface driver usbhid
[ 0.595253] usbhid: USB HID core driver
[ 0.595381] inv_mpu_iio: inv_mpu_init:746
[ 0.596860] ashmem: initialized
[ 0.600504] ff100000.saradc supply vref not found, using dummy regulator
[ 0.602562] rknandbase v1.1 2016-11-08
[ 0.603212] usbcore: registered new interface driver snd-usb-audio
[ 0.606756] u32 classifier
[ 0.606777] Actions configured
[ 0.606828] Netfilter messages via NETLINK v0.30.
[ 0.606893] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 0.607259] ctnetlink v0.93: registering with nfnetlink.
[ 0.608058] xt_time: kernel timezone is -0000
[ 0.608800] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.608959] arp_tables: (C) 2002 David S. Miller
[ 0.609285] Initializing XFRM netlink socket
[ 0.609732] NET: Registered protocol family 10
[ 0.613952] mip6: Mobile IPv6
[ 0.613995] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 0.615039] sit: IPv6 over IPv4 tunneling driver
[ 0.615527] NET: Registered protocol family 17
[ 0.615569] NET: Registered protocol family 15
[ 0.615609] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.616292] Bridge firewalling registered
[ 0.616308] Ebtables v2.0 registered
[ 0.616465] Bluetooth: RFCOMM TTY layer initialized
[ 0.616482] Bluetooth: RFCOMM socket layer initialized
[ 0.616508] Bluetooth: RFCOMM ver 1.11
[ 0.616530] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 0.616540] Bluetooth: BNEP filters: protocol multicast
[ 0.616555] Bluetooth: BNEP socket layer initialized
[ 0.616570] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 0.616585] Bluetooth: HIDP socket layer initialized
[ 0.616616] l2tp_core: L2TP core driver, V2.0
[ 0.616635] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 0.616652] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 0.616888] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 0.616950] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 0.616963] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 0.616975] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 0.617036] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 1003, flags = 0.
[ 0.617049] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 0.617061] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 0.617119] [BT_RFKILL]: Enter rfkill_rk_init
[ 0.617421] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 1083.
[ 0.617464] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 1009.
[ 0.617496] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 1090.
[ 0.617528] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 1004.
[ 0.617869] [BT_RFKILL]: Request irq for bt wakeup host
[ 0.617911] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[ 0.617923] [BT_RFKILL]: ** disable irq
[ 0.618067] [BT_RFKILL]: bt_default device registered.
[ 0.618216] sensor_register_slave:mpu6880_gyro,id=47
[ 0.618662] Registered cp15_barrier emulation handler
[ 0.618763] Registered setend emulation handler
[ 0.619877] registered taskstats version 1
[ 0.620540] rockchip ion idev is NULL
[ 0.620557] rga2 ff680000.rga: rga ion client create success!
[ 0.620710] rga: Driver loaded successfully ver:3.02
[ 0.622246] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 0.624749] mali ff9a0000.gpu: leakage=29
[ 0.635859] mmc0: MAN_BKOPS_EN bit is not set
[ 0.636981] mali ff9a0000.gpu: temp=45000, pvtm=125098 (125050 + 48)
[ 0.637752] mali ff9a0000.gpu: pvtm-sel=1
[ 0.638900] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 0.639970] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 0.640760] mali ff9a0000.gpu: Probed as mali0
[ 0.647121] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 0.647161] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 1
[ 0.647399] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[ 0.647451] xhci-hcd xhci-hcd.9.auto: irq 222, io mem 0xfe800000
[ 0.647583] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.647600] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.647614] usb usb1: Product: xHCI Host Controller
[ 0.647627] usb usb1: Manufacturer: Linux 4.4.83 xhci-hcd
[ 0.647638] usb usb1: SerialNumber: xhci-hcd.9.auto
[ 0.648359] hub 1-0:1.0: USB hub found
[ 0.648375] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 0.648682] hub 1-0:1.0: 1 port detected
[ 0.649030] mmcblk0: mmc0:0001 AJNB4R 14.6 GiB
[ 0.649278] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 0.649303] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 2
[ 0.649342] mmcblk0boot0: mmc0:0001 AJNB4R partition 1 4.00 MiB
[ 0.649571] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 0.649646] mmcblk0boot1: mmc0:0001 AJNB4R partition 2 4.00 MiB
[ 0.649880] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.649898] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.649912] usb usb2: Product: xHCI Host Controller
[ 0.649946] mmcblk0rpmb: mmc0:0001 AJNB4R partition 3 4.00 MiB
[ 0.650150] usb usb2: Manufacturer: Linux 4.4.83 xhci-hcd
[ 0.650164] usb usb2: SerialNumber: xhci-hcd.9.auto
[ 0.650301] uboot: 0x000400000 – 0x000800000 (4 MB)
[ 0.650314] trust: 0x000800000 – 0x000c00000 (4 MB)
[ 0.650326] misc: 0x000c00000 – 0x001000000 (4 MB)
[ 0.650338] resource: 0x001000000 – 0x002000000 (16 MB)
[ 0.650350] kernel: 0x002000000 – 0x003800000 (24 MB)
[ 0.650361] boot: 0x003800000 – 0x005800000 (32 MB)
[ 0.650372] recovery: 0x005800000 – 0x009800000 (64 MB)
[ 0.650383] backup: 0x009800000 – 0x010800000 (112 MB)
[ 0.650394] cache: 0x010800000 – 0x018800000 (128 MB)
[ 0.650405] system: 0x018800000 – 0x078800000 (1536 MB)
[ 0.650416] metadata: 0x078800000 – 0x079800000 (16 MB)
[ 0.650427] verity_mode: 0x079800000 – 0x079808000 (0 MB)
[ 0.650438] baseparamer: 0x079808000 – 0x079c08000 (4 MB)
[ 0.650449] frp: 0x079c08000 – 0x079c88000 (0 MB)
[ 0.650460] userdata: 0x079c88000 – 0x3a3a00000 (12957 MB)
[ 0.650510] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 0.652371] hub 2-0:1.0: USB hub found
[ 0.652843] hub 2-0:1.0: 1 port detected
[ 0.654909] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 0.654937] usb usb2: USB disconnect, device number 1
[ 0.678776] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds.
[ 0.678799] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting reset.
[ 0.678842] xhci-hcd xhci-hcd.9.auto: USB bus 2 deregistered
[ 0.678860] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 0.678883] usb usb1: USB disconnect, device number 1
[ 0.679363] xhci-hcd xhci-hcd.9.auto: USB bus 1 deregistered
[ 0.683303] ehci-platform fe380000.usb: EHCI Host Controller
[ 0.683337] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[ 0.683493] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000
[ 0.691919] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 0.692065] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.692083] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.692098] usb usb1: Product: EHCI Host Controller
[ 0.692110] usb usb1: Manufacturer: Linux 4.4.83 ehci_hcd
[ 0.692122] usb usb1: SerialNumber: fe380000.usb
[ 0.692664] hub 1-0:1.0: USB hub found
[ 0.692706] hub 1-0:1.0: 1 port detected
[ 0.693325] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 0.693352] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 2
[ 0.693480] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000
[ 0.749762] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.749855] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.749897] usb usb2: Product: Generic Platform OHCI controller
[ 0.749935] usb usb2: Manufacturer: Linux 4.4.83 ohci_hcd
[ 0.749961] usb usb2: SerialNumber: fe3a0000.usb
[ 0.752843] hub 2-0:1.0: USB hub found
[ 0.752929] hub 2-0:1.0: 1 port detected
[ 0.754636] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.754774] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 0.754797] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 0.754837] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 24,32 bit host data width,256 deep fifo
[ 0.754892] dwmmc_rockchip fe310000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 0.754955] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 0.754969] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 0.755456] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 0.768505] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.781934] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 0.783174] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 0.783305] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 0.783326] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 0.783365] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 0.783408] dwmmc_rockchip fe320000.dwmmc: ‘clock-freq-min-max’ property was deprecated.
[ 0.783519] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 0.783941] dwmmc_rockchip fe320000.dwmmc: allocated mmc-pwrseq
[ 0.784117] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 0.784271] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 0.795170] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 0.809702] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 0.812241] asoc-simple-card spdif-sound: dit-hifi ↔ ff870000.spdif mapping ok
[ 0.814587]
[ 0.814625] =======================================================
[ 0.814648] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 0.814670] =======================================================
[ 0.814694] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 0.814725] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 0.814747] [WLAN_RFKILL]: wifi turn on power. -1
[ 0.814765] RTL871X: module init start
[ 0.814783] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 0.815002] usbcore: registered new interface driver rtl8188eu
[ 0.815023] RTL871X: module init ret=0
[ 0.815054] otg_wakelock_init: No USB transceiver found
[ 0.815273] sensor_init: Probe name sensors
[ 0.815302] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 0.815438] dhd_module_init: in Dongle Host Driver, version 1.363.59.144.10 (r)
[ 0.815464] ======== dhd_wlan_init_plat_data ========
[ 0.815484] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[ 0.815553] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[ 0.815573] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 0.815596] dhd_wlan_init_gpio: host_oob_irq: 64
[ 0.815615] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[ 0.815674] dhd_wifi_platform_load: Enter
[ 0.815721] Power-up adapter ‘DHD generic adapter’
[ 0.815790] wifi_platform_set_power = 1
[ 0.815810] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 0.815829] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 0.815848] [WLAN_RFKILL]: wifi turn on power. -1
[ 0.816284] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:50:05 UTC (1358499005)
[ 0.817482] It doesn’t contain Rogue gpu
[ 0.826316] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.827981] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.829638] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.832610] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.841502] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘-dec6767’, rk_ko_ver is ‘5’, built at ‘19:57:39’, on ‘Jul 10 2018’.
[ 0.841754] Mali: Mali device driver loaded
[ 0.842200] input: rk29-keypad as /devices/platform/rockchip-key/input/input0
[ 0.843080] ALSA device list:
[ 0.843093] #0: rockchip,spdif
[ 0.843617] Freeing unused kernel memory: 832K
[ 0.849876] init: init first stage started!
[ 0.891028] mmc_host mmc1: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[ 0.898714] audit: type=1403 audit(1358499005.580:2): policy loaded auid=4294967295 ses=4294967295
[ 0.899204] init: (Initializing SELinux non-enforcing took 0.05s.)
[ 0.902451] init: init second stage started!
[ 0.907315] init: Setting ro.rk.soc=rk3399
[ 0.907431] init: OK,EMMC DRIVERS INIT OK
[ 0.907466] init: property_set(“ro.boot.mode”, “emmc”) failed
[ 0.907544] init: property_set(“ro.hardware”, “rk30board”) failed
[ 0.907966] random: nonblocking pool is initialized
[ 0.909795] init: Running restorecon…
[ 0.973420] init: waitpid failed: No child processes
[ 0.973753] init: (Loading properties from /default.prop took 0.00s.)
[ 0.975526] init: (Parsing /init.environ.rc took 0.00s.)
[ 0.975856] init: (Parsing /init.usb.rc took 0.00s.)
[ 0.976518] init: (Parsing init.rk30board.bootmode.emmc.rc took 0.00s.)
[ 0.977104] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[ 0.977155] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[ 0.977225] init: could not import file ‘/init.stt_trace.rc’ from ‘/init.debug.rc’: No such file or directory
[ 0.977377] init: (Parsing /init.logs.rc took 0.00s.)
[ 0.977449] init: (Parsing /init.crashlogd.rc took 0.00s.)
[ 0.977523] init: (Parsing /init.coredump.rc took 0.00s.)
[ 0.977574] init: (Parsing /init.log-watch.rc took 0.00s.)
[ 0.977644] init: (Parsing /init.kernel.rc took 0.00s.)
[ 0.977738] init: (Parsing /init.debug-charging.rc took 0.00s.)
[ 0.977756] init: (Parsing /init.debug.rc took 0.00s.)
[ 0.977772] init: (Parsing init.rockchip.rc took 0.00s.)
[ 0.978087] init: (Parsing init.connectivity.rc took 0.00s.)
[ 0.978122] init: could not import file ‘init.box.samba.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 0.978205] init: (Parsing init.rk3399.rc took 0.00s.)
[ 0.978298] init: (Parsing init.tablet.rc took 0.00s.)
[ 0.978330] init: could not import file ‘init.car.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 0.978361] init: could not import file ‘init.optee.rc’ from ‘/init.rk30board.rc’: No such file or directory
[ 0.978380] init: (Parsing /init.rk30board.rc took 0.00s.)
[ 0.978925] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[ 0.979012] init: (Parsing /init.zygote64_32.rc took 0.00s.)
[ 0.979029] init: (Parsing /init.rc took 0.00s.)
[ 0.979444] init: Starting service ‘ueventd’…
[ 0.983063] audit: type=1400 audit(1358499005.663:3): avc: denied { getattr } for pid=1 comm=“init” path=“/sys/kernel/debug/tracing/trace_marker” dev=“tracefs” ino=2100 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[ 0.993268] ueventd: ueventd started!
[ 0.993817] ueventd: invalid gid ‘trace’
[ 1.018559] wifi_platform_bus_enumerate device present 1
[ 1.018584] ======== Card detection to detect SDIO card! ========
[ 1.018593] mmc1:mmc host rescan start!
[ 1.095329] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 72
[ 1.102374] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 1.102512] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 1.120050] bcmsdh_register: register client driver
[ 1.120243] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 1.120396] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 1.120420] bus num (host idx)=1, slot num (rca)=1
[ 1.120440] found adapter info ‘DHD generic adapter’
[ 1.120516] sdioh_attach: set sd_f2_blocksize 256
[ 1.121120] F1 signature read @0x18000000=0x17224356
[ 1.128989] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x2 pkg:0x2
[ 1.130240] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 1.130529] dhd_conf_set_chiprev: chip=0x4354, chiprev=2
[ 1.133047] wl_create_event_handler(): thread:wl_event_handler:ad started
[ 1.133135] tsk Enter, tsk = 0xffffffc07ae81a90
[ 1.133653] dhd_attach(): thread:dhd_watchdog_thread:ae started
[ 1.133871] dhd_attach(): thread:dhd_dpc:af started
[ 1.134116] dhd_attach(): thread:dhd_rxf:b0 started
[ 1.134215] dhd_deferred_work_init: work queue initialized
[ 1.155615] Dongle Host Driver, version 1.363.59.144.10 (r)
[ 1.155857] vendor storage:20160801 ret = 0
[ 1.156402] Register interface [wlan0] MAC: ac:83:f3:9f:d5:b6
[ 1.156402]
[ 1.156444] wl_event_handler: was terminated
[ 1.156468] wl_destroy_event_handler(): thread:wl_event_handler:ad terminated OK
[ 1.156484] dhd_wl_ioctl: returning as busstate=0
[ 1.156551] bcmsdh_oob_intr_unregister: Enter
[ 1.156560] bcmsdh_oob_intr_unregister: irq is not registered
[ 1.156583] dhd_txglom_enable: enable 0
[ 1.156593] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0, txglom_bucket_size=0
[ 1.156603] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[ 1.156613] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=128, dhd_txminmax=-1
[ 1.156623] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=0
[ 1.156633] sdioh_set_mode: set txglom_mode to copy
[ 1.156640] dhd_bus_devreset: WLAN OFF DONE
[ 1.156706] wifi_platform_set_power = 0
[ 1.156716] ======== PULL WL_REG_ON(-1) LOW! ========
[ 1.156725] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 1.156750] [WLAN_RFKILL]: wifi shut off power.
[ 1.156824] dhd_module_init: Exit err=0
[ 1.160246] ueventd: Coldboot took 0.16s.
[ 1.199332] init: write_file: Unable to open ‘/proc/self/coredump_filter’: No such file or directory
[ 1.199379] init: write_file: Unable to open ‘/proc/sys/kernel/panic_on_stackoverflow’: No such file or directory
[ 1.199411] init: Waiting for /dev/.coldboot_done…
[ 1.199466] init: Waiting for /dev/.coldboot_done took 0.00s.
[ 1.199495] init: /dev/hw_random not found
[ 1.199951] keychord: using input dev rk29-keypad for fevent
[ 1.205629] init: write_file: Unable to open ‘/proc/cpu/alignment’: No such file or directory
[ 1.211450] Registered swp emulation handler
[ 1.211605] init: write_file: Unable to open ‘/sys/module/rockchip_pm/parameters/policy’: No such file or directory
[ 1.212175] fs_mgr: Warning: unknown flag resize
[ 1.515730] init: /dev/hw_random not found
[ 1.516434] init: Starting service ‘exec 1 (/sbin/slideshow)’…
[ 3.167044] fusb302 4-0022: connection has disconnected
[ 3.167385] fusb302 4-0022: fusb302 send extcon to disable vbus 5v
[ 6.670188] init: Service ‘exec 1 (/sbin/slideshow)’ (pid 180) exited with status 0
[ 6.671009] fs_mgr: Warning: unknown flag resize
[ 7.234831] fs_mgr: Enabling dm-verity for system (mode 1)
[ 7.235064] fs_mgr: loading verity table: ‘1 /dev/block/platform/fe330000.sdhci/by-name/system /dev/block/platform/fe330000.sdhci/by-name/system 4096 4096 387072 387072 sha256 5441f9542cc0c4abec0158663520185bb8383908acf04dc3d0f151cd68d54001 aee087a5be3b982978c923f566a94613496b417f2af592639bc80d141e34dfe7 10 ignore_corruption use_fec_from_device /dev/block/platform/fe330000.sdhci/by-name/system fec_start 390129 fec_blocks 390129 fec_roots 2 ignore_zero_blocks’
[ 7.247436] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
[ 7.248280] fs_mgr: __mount(source=/dev/block/dm-0,target=/system,type=ext4)=0
[ 7.249695] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/cache,/cache,ext4)=-1: No such file or directory
[ 7.253825] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/cache
[ 7.295393] phy phy-ff770000.syscon:usb2-phy@e450.1: charger = USB_FLOATING_CHARGER
[ 7.368101] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 7.368101]
[ 7.368195] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: recovering journal
[ 7.368195]
[ 7.368218] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/cache: clean, 20/8192 files, 1572/32768 blocks
[ 7.368218]
[ 7.375075] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.375333] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/cache,target=/cache,type=ext4)=0
[ 7.378878] EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
[ 7.384777] EXT4-fs (mmcblk0p11): recovery complete
[ 7.385260] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[ 7.385437] fs_mgr: check_fs(): mount(/dev/block/platform/fe330000.sdhci/by-name/metadata,/metadata,ext4)=0: Success
[ 7.405042] fs_mgr: check_fs(): unmount(/metadata) succeeded
[ 7.405277] fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/fe330000.sdhci/by-name/metadata
[ 7.434189] e2fsck: e2fsck 1.42.9 (28-Dec-2013)
[ 7.434189]
[ 7.434326] e2fsck: /dev/block/platform/fe330000.sdhci/by-name/metadata: clean, 12/1024 files, 1105/4096 blocks
[ 7.434326]
[ 7.445304] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[ 7.445517] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/metadata,target=/metadata,type=ext4)=0
[ 7.445689] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/platform/fe330000.sdhci/by-name/userdata
[ 7.535621] fsck.f2fs: Info: Fix the reported corruption.
[ 7.535621]
[ 7.535746] fsck.f2fs: Info: Segments per section = 1
[ 7.535746]
[ 7.535780] fsck.f2fs: Info: Sections per zone = 1
[ 7.535780]
[ 7.535831] fsck.f2fs: Info: sector size = 512
[ 7.535831]
[ 7.535863] fsck.f2fs: Info: total sectors = 26536896 (12957 MB)
[ 7.535863]
[ 7.535895] fsck.f2fs: Can’t find a valid F2FS superblock at 0x0
[ 7.535895]
[ 7.535926] fsck.f2fs: Can’t find a valid F2FS superblock at 0x1
[ 7.535926]
[ 7.535968] fsck.f2fs: fsck.f2fs terminated by exit(255)
[ 7.535968]
[ 7.537318] F2FS-fs (mmcblk0p15): Magic Mismatch, valid(0xf2f52010) - read(0xe1b79f65)
[ 7.537341] F2FS-fs (mmcblk0p15): Can’t find valid F2FS filesystem in 1th superblock
[ 7.537554] F2FS-fs (mmcblk0p15): Magic Mismatch, valid(0xf2f52010) - read(0x9d790df)
[ 7.537573] F2FS-fs (mmcblk0p15): Can’t find valid F2FS filesystem in 2th superblock
[ 7.537598] F2FS-fs (mmcblk0p15): Magic Mismatch, valid(0xf2f52010) - read(0xe1b79f65)
[ 7.537615] F2FS-fs (mmcblk0p15): Can’t find valid F2FS filesystem in 1th superblock
[ 7.537632] F2FS-fs (mmcblk0p15): Magic Mismatch, valid(0xf2f52010) - read(0x9d790df)
[ 7.537649] F2FS-fs (mmcblk0p15): Can’t find valid F2FS filesystem in 2th superblock
[ 7.537757] fs_mgr: __mount(source=/dev/block/platform/fe330000.sdhci/by-name/userdata,target=/data,type=f2fs)=-1
[ 7.538204] fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/platform/fe330000.sdhci/by-name/userdata for mount /data type f2fs )
[ 7.544686] init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[ 7.545666] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[ 7.546426] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[ 7.547107] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[ 7.547693] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[ 7.548225] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[ 7.548806] init: (Parsing /system/etc/init/debuggerd64.rc took 0.00s.)
[ 7.549458] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[ 7.550250] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[ 7.550798] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[ 7.551393] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[ 7.552030] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[ 7.552757] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[ 7.553448] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[ 7.554506] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[ 7.555194] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[ 7.555833] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[ 7.556452] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[ 7.556902] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[ 7.557325] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[ 7.557799] init: ignored duplicate definition of service 'media’init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[ 7.558279] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[ 7.558758] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[ 7.559195] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[ 7.559617] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[ 7.560052] init: ignored duplicate definition of service ‘ril-daemon’init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[ 7.560553] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[ 7.560979] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[ 7.561458] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[ 7.561967] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[ 7.562464] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[ 7.565240] init: Starting service ‘logd’…
[ 7.579551] init: insmod: open(“/system/lib/modules/ump.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/mali_kbase.ko”) failed: No such file or directoryinit: insmod: open(“/system/lib/modules/rk30_mirroring.ko”) failed: No such file or directoryinit: finit_module for “/system/lib/modules/rk29-ipp.ko” failed: Exec format errorinit: insmod: open(“/system/lib/modules/pvrsrvkm.ko”) failed: No such file or directoryinit: finit_module for “/drmboot.ko” failed: Exec format errorfs_mgr: Warning: unknown flag resize
[ 7.585006] zram0: detected capacity change from 0 to 533413888
[ 7.608867] logd.auditd: start
[ 7.608944] logd.klogd: 7603835112
[ 7.616568] Adding 520908k swap on /dev/block/zram0. Priority:-1 extents:1 across:520908k SS
[ 7.619677] init: property_set(“ro.board.platform”, “rk3399”) failed
[ 7.620336] init: property_set(“ro.rk.screenshot_enable”, “true”) failed
[ 7.620482] init: (Loading properties from /system/build.prop took 0.00s.)
[ 7.620549] init: (Loading properties from /vendor/build.prop took 0.00s.)
[ 7.620596] init: (Loading properties from /factory/factory.prop took 0.00s.)
[ 7.620717] fs_mgr: Warning: unknown flag resize
[ 7.620834] init: /recovery not specified in fstab
[ 7.621446] init: Starting service ‘debuggerd’…
[ 7.622517] init: Starting service ‘debuggerd64’…
[ 7.623429] init: Starting service ‘vold’…
[ 7.624561] init: Not bootcharting.
[ 7.770037] fs_mgr: Warning: unknown flag resize
[ 7.816978] init: Starting service ‘exec 2 (/system/bin/tzdatacheck)’…
[ 7.831554] init: Service ‘exec 2 (/system/bin/tzdatacheck)’ (pid 223) exited with status 0
[ 7.835265] type=1400 audit(1358499012.513:4): avc: denied { create } for pid=1 comm=“init” name=“cifsmanager” scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 7.835404] type=1400 audit(1358499012.513:5): avc: denied { setattr } for pid=1 comm=“init” name=“cifsmanager” dev=“tmpfs” ino=8928 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[ 7.836598] tmpfs: Bad mount option background_gc
[ 7.838622] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 7.839097] init: (Loading properties from /data/local.prop took 0.00s.)
[ 7.839375] init: Starting service ‘logd-reinit’…
[ 7.840831] init: write_file: Unable to open ‘/proc/sys/vm/min_free_order_shift’: No such file or directory
[ 7.842833] init: Starting service ‘healthd’…
[ 7.843481] init: cannot find ‘/system/bin/displayd’ (No such file or directory), disabling ‘displayd’
[ 7.845203] init: Starting service ‘earlylogs’…
[ 7.846430] init: Starting service ‘lmkd’…
[ 7.847021] binder: 225:225 transaction failed 29189/0, size 0-0 line 2868
[ 7.848673] init: Starting service ‘servicemanager’…
[ 7.849851] init: Starting service ‘surfaceflinger’…
[ 7.855962] init: SELinux: Could not stat /sys/devices/system/cpu/cpufreq/interactive: No such file or directory.
[ 7.856066] logd.daemon: reinit
[ 7.858387] init: write_file: Unable to open ‘/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold’: No such file or directory
[ 7.863585] init: Service ‘earlylogs’ (pid 226) exited with status 0
[ 7.865839] init: property ‘ro.serialno’ doesn’t exist while expanding ‘${ro.serialno}’
[ 7.865882] init: write: cannot expand ‘${ro.serialno}’
[ 7.867135] file system registered
[ 7.867955] type=1400 audit(1358499012.543:6): avc: denied { relabelto } for pid=1 comm=“init” name=“recovery” dev=“tmpfs” ino=13517 scontext=u:r:init:s0 tcontext=u:object_r:recovery_block_device:s0 tclass=lnk_file permissive=1
[ 7.871842] using random self ethernet address
[ 7.871874] using random host ethernet address
[ 7.871965] init: write_file: Unable to open ‘/config/usb_gadget/g1/functions/rndis.gs4/wceis’: Permission denied
[ 7.882918] init: Starting service ‘console’…
[ 7.884566] init: Starting service ‘adbd’…
[ 7.885523] type=1400 audit(1358499012.543:7): avc: denied { relabelto } for pid=1 comm=“init” name=“boot” dev=“tmpfs” ino=13513 scontext=u:r:init:s0 tcontext=u:object_r:boot_block_device:s0 tclass=lnk_file permissive=1
[ 7.886536] init: Starting service ‘exec 3 (/system/bin/vdc)’…
[ 7.888307] init: Service ‘logd-reinit’ (pid 224) exited with status 0
[ 7.900476] init: Service ‘exec 3 (/system/bin/vdc)’ (pid 234) exited with status 0
rk3399_mid:/ $ [ 8.263092] init: Service ‘surfaceflinger’ (pid 229) killed by signal 6
[ 8.263137] init: Service ‘surfaceflinger’ (pid 229) killing any children in process group
[ 8.263646] init: Starting service ‘zygote’…
[ 8.854076] healthd: BatteryCurrentNowPath not found
[ 8.854155] healthd: BatteryCycleCountPath not found
[ 8.856115] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 8.857920] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 8.859707] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 8.861443] healthd: battery l=50 v=3 t=2.6 h=2 st=3 fc=100 chg=au
[ 8.906357] init: avc: denied { set } for property=ctl.bootanim pid=214 uid=0 gid=0 scontext=u:r:vold:s0 tcontext=u:object_r:ctl_bootanim_prop:s0 tclass=property_service permissive=1
[ 8.906554] init: Starting service ‘bootanim’…
[ 8.925826] fs_mgr: Running /system/bin/fsck.f2fs -a /dev/block/dm-1
[ 8.979931] fsck.f2fs: Info: Fix the reported corruption.
[ 8.979931]
[ 8.980032] fsck.f2fs: Info: Segments per section = 1
[ 8.980032]
[ 8.980057] fsck.f2fs: Info: Sections per zone = 1
[ 8.980057]
[ 8.980082] fsck.f2fs: Info: sector size = 512
[ 8.980082]
[ 8.980104] fsck.f2fs: Info: total sectors = 26536896 (12957 MB)
[ 8.980104]
[ 8.980125] fsck.f2fs: Info: MKFS version
[ 8.980125]
[ 8.980147] fsck.f2fs: “Linux version 4.4.83 (jiawenchen@sbote.com) (gcc version 4.9 20150123 (prerelease) (GCC) ) #4 SMP PREEMPT Fri Jul 13 17:12:06 CST 2018”
[ 8.980147]
[ 8.980170] fsck.f2fs: Info: FSCK version
[ 8.980170]
[ 8.980192] fsck.f2fs: from “Linux version 4.4.83 (jiawenchen@sbote.com) (gcc version 4.9 20150123 (prerelease) (GCC) ) #4 SMP PREEMPT Fri Jul 13 17:12:06 CST 2018”
[ 8.980192]
[ 8.980216] fsck.f2fs: to “Linux version 4.4.83 (jiawenchen@sbote.com) (gcc version 4.9 20150123 (prerelease) (GCC) ) #4 SMP PREEMPT Fri Jul 13 17:12:06 CST 2018”
[ 8.980216]
[ 8.980240] fsck.f2fs: Info: superblock features = 0 :
[ 8.980240]
[ 8.980262] fsck.f2fs: Info: superblock encrypt level = 0, salt = 00000000000000000000000000000000
[ 8.980262]
[ 8.980284] fsck.f2fs: Info: total FS sectors = 26536896 (12957 MB)
[ 8.980284]
[ 8.980305] fsck.f2fs: Info: CKPT version = d
[ 8.980305]
[ 8.980324] fsck.f2fs: Info: No error was reported
[ 8.980324]
[ 9.119985] F2FS-fs (dm-1): recover_inode: ino = 209, name = system@framework@boot.art
[ 9.120665] F2FS-fs (dm-1): recover_dentry: ino = 209, name = system@framework@boot.art, dir = 92, err = 0
[ 9.122906] F2FS-fs (dm-1): recover_data: ino = 209, recovered = 676 blocks, err = 0
[ 9.123065] F2FS-fs (dm-1): recover_inode: ino = 20a, name = system@framework@boot-core-libart.art
[ 9.123137] F2FS-fs (dm-1): recover_dentry: ino = 20a, name = system@framework@boot-core-libart.art, dir = 92, err = 0
[ 9.124792] F2FS-fs (dm-1): recover_data: ino = 20a, recovered = 382 blocks, err = 0
[ 9.124839] F2FS-fs (dm-1): recover_inode: ino = 20b, name = system@framework@boot-conscrypt.art
[ 9.124891] F2FS-fs (dm-1): recover_dentry: ino = 20b, name = system@framework@boot-conscrypt.art, dir = 92, err = 0
[ 9.125205] F2FS-fs (dm-1): recover_data: ino = 20b, recovered = 54 blocks, err = 0
[ 9.125244] F2FS-fs (dm-1): recover_inode: ino = 20c, name = system@framework@boot-okhttp.art
[ 9.125299] F2FS-fs (dm-1): recover_dentry: ino = 20c, name = system@framework@boot-okhttp.art, dir = 92, err = 0
[ 9.125580] F2FS-fs (dm-1): recover_data: ino = 20c, recovered = 58 blocks, err = 0
[ 9.125616] F2FS-fs (dm-1): recover_inode: ino = 20d, name = system@framework@boot-core-junit.art
[ 9.125662] F2FS-fs (dm-1): recover_dentry: ino = 20d, name = system@framework@boot-core-junit.art, dir = 92, err = 0
[ 9.125863] F2FS-fs (dm-1): recover_data: ino = 20d, recovered = 4 blocks, err = 0
[ 9.125903] F2FS-fs (dm-1): recover_inode: ino = 20e, name = system@framework@boot-bouncycastle.art
[ 9.125950] F2FS-fs (dm-1): recover_dentry: ino = 20e, name = system@framework@boot-bouncycastle.art, dir = 92, err = 0
[ 9.126447] F2FS-fs (dm-1): recover_data: ino = 20e, recovered = 71 blocks, err = 0
[ 9.126514] F2FS-fs (dm-1): recover_inode: ino = 20f, name = system@framework@boot-ext.art
[ 9.126564] F2FS-fs (dm-1): recover_dentry: ino = 20f, name = system@framework@boot-ext.art, dir = 92, err = 0
[ 9.126927] F2FS-fs (dm-1): recover_data: ino = 20f, recovered = 67 blocks, err = 0
[ 9.126997] F2FS-fs (dm-1): recover_inode: ino = 210, name = system@framework@boot-framework.art
[ 9.127047] F2FS-fs (dm-1): recover_dentry: ino = 210, name = system@framework@boot-framework.art, dir = 92, err = 0
[ 9.133047] F2FS-fs (dm-1): recover_data: ino = 210, recovered = 873 blocks, err = 0
[ 9.139517] F2FS-fs (dm-1): recover_data: ino = 210, recovered = 1018 blocks, err = 0
[ 9.140239] F2FS-fs (dm-1): recover_data: ino = 210, recovered = 109 blocks, err = 0
[ 9.140332] F2FS-fs (dm-1): recover_inode: ino = 213, name = system@framework@boot-telephony-common.art
[ 9.140397] F2FS-fs (dm-1): recover_dentry: ino = 213, name = system@framework@boot-telephony-common.art, dir = 92, err = 0
[ 9.142051] F2FS-fs (dm-1): recover_data: ino = 213, recovered = 148 blocks, err = 0
[ 9.142133] F2FS-fs (dm-1): recover_inode: ino = 214, name = system@framework@boot-voip-common.art
[ 9.142190] F2FS-fs (dm-1): recover_dentry: ino = 214, name = system@framework@boot-voip-common.art, dir = 92, err = 0
[ 9.142429] F2FS-fs (dm-1): recover_data: ino = 214, recovered = 9 blocks, err = 0
[ 9.142471] F2FS-fs (dm-1): recover_inode: ino = 215, name = system@framework@boot-ims-common.art
[ 9.142549] F2FS-fs (dm-1): recover_dentry: ino = 215, name = system@framework@boot-ims-common.art, dir = 92, err = 0
[ 9.142711] F2FS-fs (dm-1): recover_data: ino = 215, recovered = 13 blocks, err = 0
[ 9.142748] F2FS-fs (dm-1): recover_inode: ino = 216, name = system@framework@boot-apache-xml.art
[ 9.142829] F2FS-fs (dm-1): recover_dentry: ino = 216, name = system@framework@boot-apache-xml.art, dir = 92, err = 0
[ 9.143204] F2FS-fs (dm-1): recover_data: ino = 216, recovered = 36 blocks, err = 0
[ 9.143245] F2FS-fs (dm-1): recover_inode: ino = 217, name = system@framework@boot-org.apache.http.legacy.boot.art
[ 9.143297] F2FS-fs (dm-1): recover_dentry: ino = 217, name = system@framework@boot-org.apache.http.legacy.boot.art, dir = 92, err = 0
[ 9.143650] F2FS-fs (dm-1): recover_data: ino = 217, recovered = 40 blocks, err = 0
[ 9.143689] F2FS-fs (dm-1): recover_inode: ino = 218, name = .temp.ewPswH
[ 9.144882] F2FS-fs (dm-1): recover_dentry: ino = 218, name = .temp.ewPswH, dir = 2e, err = 0
[ 9.144968] F2FS-fs (dm-1): recover_data: ino = 218, recovered = 0 blocks, err = 0
[ 9.145013] F2FS-fs (dm-1): recover_inode: ino = 219, name = batterystats.bin.tmp
[ 9.145861] F2FS-fs (dm-1): recover_dentry: ino = 219, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.146000] F2FS-fs (dm-1): recover_data: ino = 219, recovered = 0 blocks, err = 0
[ 9.146084] F2FS-fs (dm-1): recover_dentry: ino = 21b, name = .booting, dir = 92, err = 0
[ 9.146169] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.146196] F2FS-fs (dm-1): recover_inode: ino = 21c, name = .temp.5ze3RV
[ 9.146239] F2FS-fs (dm-1): recover_dentry: ino = 21c, name = .temp.5ze3RV, dir = 2e, err = 0
[ 9.146313] F2FS-fs (dm-1): recover_data: ino = 21c, recovered = 0 blocks, err = 0
[ 9.146353] F2FS-fs (dm-1): recover_inode: ino = 21d, name = batterystats.bin.tmp
[ 9.146588] F2FS-fs (dm-1): recover_dentry: ino = 21d, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.146669] F2FS-fs (dm-1): recover_data: ino = 21d, recovered = 0 blocks, err = 0
[ 9.146714] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.146736] F2FS-fs (dm-1): recover_inode: ino = 21f, name = .temp.zSclv6
[ 9.146864] F2FS-fs (dm-1): recover_dentry: ino = 21f, name = .temp.zSclv6, dir = 2e, err = 0
[ 9.146911] F2FS-fs (dm-1): recover_data: ino = 21f, recovered = 0 blocks, err = 0
[ 9.146977] F2FS-fs (dm-1): recover_inode: ino = 220, name = batterystats.bin.tmp
[ 9.147073] F2FS-fs (dm-1): recover_dentry: ino = 220, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.147235] F2FS-fs (dm-1): recover_data: ino = 220, recovered = 0 blocks, err = 0
[ 9.147282] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.147305] F2FS-fs (dm-1): recover_inode: ino = 222, name = .temp.eetxFh
[ 9.147377] F2FS-fs (dm-1): recover_dentry: ino = 222, name = .temp.eetxFh, dir = 2e, err = 0
[ 9.147424] F2FS-fs (dm-1): recover_data: ino = 222, recovered = 0 blocks, err = 0
[ 9.147552] F2FS-fs (dm-1): recover_inode: ino = 223, name = batterystats.bin.tmp
[ 9.147645] F2FS-fs (dm-1): recover_dentry: ino = 223, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.147723] F2FS-fs (dm-1): recover_data: ino = 223, recovered = 0 blocks, err = 0
[ 9.147768] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.147790] F2FS-fs (dm-1): recover_inode: ino = 226, name = .temp.8sScvV
[ 9.147868] F2FS-fs (dm-1): recover_dentry: ino = 226, name = .temp.8sScvV, dir = 2e, err = 0
[ 9.148029] F2FS-fs (dm-1): recover_data: ino = 226, recovered = 0 blocks, err = 0
[ 9.148067] F2FS-fs (dm-1): recover_inode: ino = 227, name = batterystats.bin.tmp
[ 9.148212] F2FS-fs (dm-1): recover_dentry: ino = 227, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.148260] F2FS-fs (dm-1): recover_data: ino = 227, recovered = 0 blocks, err = 0
[ 9.148378] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.148401] F2FS-fs (dm-1): recover_inode: ino = 229, name = .temp.t9CA33
[ 9.148660] F2FS-fs (dm-1): recover_dentry: ino = 229, name = .temp.t9CA33, dir = 2e, err = 0
[ 9.148715] F2FS-fs (dm-1): recover_data: ino = 229, recovered = 0 blocks, err = 0
[ 9.148763] F2FS-fs (dm-1): recover_inode: ino = 22a, name = batterystats.bin.tmp
[ 9.148888] F2FS-fs (dm-1): recover_dentry: ino = 22a, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.149038] F2FS-fs (dm-1): recover_data: ino = 22a, recovered = 0 blocks, err = 0
[ 9.149086] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.149140] F2FS-fs (dm-1): recover_inode: ino = 22c, name = .temp.zlc0sl
[ 9.149184] F2FS-fs (dm-1): recover_dentry: ino = 22c, name = .temp.zlc0sl, dir = 2e, err = 0
[ 9.149229] F2FS-fs (dm-1): recover_data: ino = 22c, recovered = 0 blocks, err = 0
[ 9.149301] F2FS-fs (dm-1): recover_inode: ino = 22d, name = batterystats.bin.tmp
[ 9.149394] F2FS-fs (dm-1): recover_dentry: ino = 22d, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.149472] F2FS-fs (dm-1): recover_data: ino = 22d, recovered = 0 blocks, err = 0
[ 9.149652] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.149674] F2FS-fs (dm-1): recover_inode: ino = 22f, name = .temp.k2WmK2
[ 9.149715] F2FS-fs (dm-1): recover_dentry: ino = 22f, name = .temp.k2WmK2, dir = 2e, err = 0
[ 9.149792] F2FS-fs (dm-1): recover_data: ino = 22f, recovered = 0 blocks, err = 0
[ 9.149829] F2FS-fs (dm-1): recover_inode: ino = 230, name = batterystats.bin.tmp
[ 9.149952] F2FS-fs (dm-1): recover_dentry: ino = 230, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.149999] F2FS-fs (dm-1): recover_data: ino = 230, recovered = 0 blocks, err = 0
[ 9.150043] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.150095] F2FS-fs (dm-1): recover_inode: ino = 232, name = .temp.PVRtVA
[ 9.150137] F2FS-fs (dm-1): recover_dentry: ino = 232, name = .temp.PVRtVA, dir = 2e, err = 0
[ 9.150181] F2FS-fs (dm-1): recover_data: ino = 232, recovered = 0 blocks, err = 0
[ 9.150216] F2FS-fs (dm-1): recover_inode: ino = 233, name = batterystats.bin.tmp
[ 9.150332] F2FS-fs (dm-1): recover_dentry: ino = 233, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.150379] F2FS-fs (dm-1): recover_data: ino = 233, recovered = 0 blocks, err = 0
[ 9.150455] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.150477] F2FS-fs (dm-1): recover_inode: ino = 235, name = .temp.DLbUbf
[ 9.150517] F2FS-fs (dm-1): recover_dentry: ino = 235, name = .temp.DLbUbf, dir = 2e, err = 0
[ 9.150601] F2FS-fs (dm-1): recover_data: ino = 235, recovered = 0 blocks, err = 0
[ 9.150638] F2FS-fs (dm-1): recover_inode: ino = 236, name = batterystats.bin.tmp
[ 9.150761] F2FS-fs (dm-1): recover_dentry: ino = 236, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.150936] F2FS-fs (dm-1): recover_data: ino = 236, recovered = 0 blocks, err = 0
[ 9.150971] F2FS-fs (dm-1): recover_inode: ino = 21b, name = .booting
[ 9.150998] F2FS-fs (dm-1): recover_data: ino = 21b, recovered = 0 blocks, err = 0
[ 9.151031] F2FS-fs (dm-1): recover_inode: ino = 238, name = .temp.3YXnYE
[ 9.151105] F2FS-fs (dm-1): recover_dentry: ino = 238, name = .temp.3YXnYE, dir = 2e, err = 0
[ 9.151151] F2FS-fs (dm-1): recover_data: ino = 238, recovered = 0 blocks, err = 0
[ 9.151185] F2FS-fs (dm-1): recover_inode: ino = 239, name = batterystats.bin.tmp
[ 9.151306] F2FS-fs (dm-1): recover_dentry: ino = 239, name = batterystats.bin.tmp, dir = 3b, err = 0
[ 9.151351] F2FS-fs (dm-1): recover_data: ino = 239, recovered = 0 blocks, err = 0
[ 9.163990] F2FS-fs (dm-1): checkpoint: version = e
[ 9.165172] fs_mgr: __mount(source=/dev/block/dm-1,target=/data,type=f2fs)=0
[ 9.167347] init: (Loading properties from /data/local.prop took 0.00s.)
[ 9.175922] init: Starting service ‘logd-reinit’…
[ 9.178164] init: Starting service ‘ap_log_srv’…
[ 9.181028] init: Not bootcharting.
[ 9.208509] logd.daemon: reinit
[ 9.210180] init: Service ‘logd-reinit’ (pid 284) exited with status 0
[ 9.256952] init: Starting service ‘apk_logfs’…
[ 9.260489] init: Service ‘ap_log_srv’ (pid 285) exited with status 0
[ 9.260810] init: Starting service ‘exec 4 (/system/bin/tzdatacheck)’…
[ 9.273778] init: Service ‘exec 4 (/system/bin/tzdatacheck)’ (pid 294) exited with status 0
[ 9.296714] F2FS-fs (dm-1): acl options not supported
[ 9.296759] F2FS-fs (dm-1): Unrecognized mount option “errors=panic” or missing value
[ 9.305164] init: write_file: Unable to open ‘/proc/sys/kernel/core_pattern’: No such file or directory
[ 9.307021] init: Starting service ‘exec 5 (/system/bin/bootstat)’…
[ 9.325383] init: Service ‘exec 5 (/system/bin/bootstat)’ (pid 299) exited with status 0
[ 9.328170] init: cannot find ‘/system/bin/update_verifier’ (No such file or directory), disabling ‘exec 6 (/system/bin/update_verifier)’
[ 9.328230] init: cannot find ‘/system/bin/install-recovery.sh’ (No such file or directory), disabling ‘flash_recovery’
[ 9.328514] init: Starting service ‘drmservice’…
[ 9.329647] init: cannot find ‘/system/bin/bplus_helper’ (No such file or directory), disabling ‘bplus_helper’
[ 9.329907] init: Service up_eth0 does not have a SELinux domain defined.
[ 9.329926] init: cannot find ‘/system/bin/rk_store_keybox’ (No such file or directory), disabling ‘rk_store_keybox’
[ 9.330043] init: Starting service ‘akmd’…
[ 9.331119] init: Starting service ‘media’…
[ 9.332047] init: Starting service ‘zygote_secondary’…
[ 9.335620] init: Starting service ‘audioserver’…
[ 9.337429] init: Starting service ‘cameraserver’…
[ 9.338761] init: couldn’t write 307 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 9.339299] init: Starting service ‘drm’…
[ 9.341085] init: Starting service ‘installd’…
[ 9.343129] init: Starting service ‘keystore’…
[ 9.345033] init: Starting service ‘mediacodec’…
[ 9.346845] init: Starting service ‘mediadrm’…
[ 9.348620] init: Starting service ‘mediaextractor’…
[ 9.350276] init: Starting service ‘netd’…
[ 9.351908] init: Starting service ‘crashlogd’…
[ 9.353149] init: Starting service ‘log-watch’…
[ 9.354690] init: Starting service ‘gatekeeperd’…
[ 9.381476] init: Starting service ‘perfprofd’…
[ 9.391365] init: property ‘sys.serialno’ doesn’t exist while expanding ‘${sys.serialno}’
[ 9.391394] init: setprop: cannot expand ‘${sys.serialno}’
[ 9.392629] init: Service ‘drmservice’ (pid 302) exited with status 0
[ 9.431141] akmd[303]: unhandled level 1 translation fault (11) at 0x00000000, esr 0x92000005
[ 9.431176] pgd = ffffffc072aed000
[ 9.431184] [00000000] *pgd=0000000000000000, *pud=0000000000000000
[ 9.431197]
[ 9.431207] CPU: 3 PID: 303 Comm: akmd Not tainted 4.4.83 #4
[ 9.431214] Hardware name: AIO Board BOX (Android) (DT)
[ 9.431222] task: ffffffc0796bc100 task.stack: ffffffc072be4000
[ 9.431232] PC is at 0x7b21eba7d8
[ 9.431238] LR is at 0xd021fd720
[ 9.431245] pc : [<0000007b21eba7d8>] lr : [<0000000d021fd720>] pstate: 60000000
[ 9.431251] sp : 0000007ffc968050
[ 9.431256] x29: 0000007ffc968060 x28: 0000000000000000
[ 9.431267] x27: 0000007ffc9680c8 x26: 6bdd926f0748cd7f
[ 9.431278] x25: 0000000000000000 x24: 0000000000000000
[ 9.431288] x23: 0000000000000000 x22: 0000007ffc9689f8
[ 9.431298] x21: 0000000d021fce84 x20: 0000000d0220a000
[ 9.431308] x19: 0000000000000000 x18: 0000000000000000
[ 9.431318] x17: 0000007b21eba7c8 x16: 0000000d02209fe0
[ 9.431328] x15: 000052eae3e14c52 x14: 0001c9c6d90f39da
[ 9.431338] x13: 0000000050f90cc6 x12: 0000000000000018
[ 9.431348] x11: 0000000000000009 x10: 0000007ffc967b00
[ 9.431359] x9 : 0000000000000010 x8 : 0000000000000000
[ 9.431369] x7 : 00000000000015ea x6 : 0000007b221dc000
[ 9.431378] x5 : 0000800000000000 x4 : 000000000000004d
[ 9.431388] x3 : 0000000000000003 x2 : 0000000000000005
[ 9.431398] x1 : 0000007ffc967970 x0 : 0000000000000000
[ 9.431408]
[ 9.432797] init: Service ‘akmd’ (pid 303) killed by signal 11
[ 10.126980] fusb302 4-0022: connection has disconnected
[ 10.127261] fusb302 4-0022: fusb302 send extcon to disable vbus 5v
[ 11.185464] capability: warning: `main’ uses 32-bit capabilities (legacy support in use)
[ 12.118274] init: Starting service ‘surfaceflinger’…
[ 12.444111] init: Service ‘surfaceflinger’ (pid 585) killed by signal 6
[ 12.444239] init: Service ‘surfaceflinger’ (pid 585) killing any children in process group
[ 12.444320] init: Service ‘zygote’ is being killed…
[ 12.518023] init: Service ‘zygote’ (pid 259) killed by signal 9
[ 12.518141] init: Service ‘zygote’ (pid 259) killing any children in process group
[ 12.518378] init: write_file: Unable to open ‘/sys/android_power/request_state’: No such file or directory
[ 12.518941] init: write_file: Unable to write to ‘/sys/power/state’: Invalid argument
[ 12.519019] init: Service ‘audioserver’ is being killed…
[ 12.519505] init: Service ‘cameraserver’ is being killed…
[ 12.519638] init: Service ‘media’ is being killed…
[ 12.519829] init: Service ‘netd’ is being killed…
[ 12.520780] init: Untracked pid 555 killed by signal 9
[ 12.523702] init: Starting service ‘zygote’…
[ 12.526019] init: Service ‘media’ (pid 304) killed by signal 9
[ 12.526076] init: Service ‘media’ (pid 304) killing any children in process group
[ 12.526778] init: Service ‘audioserver’ (pid 306) killed by signal 9
[ 12.526829] init: Service ‘audioserver’ (pid 306) killing any children in process group
[ 12.527240] init: Service ‘netd’ (pid 314) killed by signal 9
[ 12.527286] init: Service ‘netd’ (pid 314) killing any children in process group
[ 12.541557] init: Service ‘cameraserver’ (pid 307) killed by signal 9
[ 12.541632] init: Service ‘cameraserver’ (pid 307) killing any children in process group
[ 12.793022] fusb302 4-0022: connection has disconnected
[ 12.794640] fusb302 4-0022: fusb302 send extcon to disable vbus 5v
[ 14.557677] init: Starting service ‘media’…
[ 14.559389] init: Starting service ‘audioserver’…
[ 14.560856] init: Starting service ‘cameraserver’…
[ 14.562489] init: couldn’t write 648 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 14.562757] init: Starting service ‘netd’…
[ 15.136688] fusb302 4-0022: connection has disconnected
[ 15.137106] fusb302 4-0022: fusb302 send extcon to disable vbus 5v
[ 17.207486] init: Starting service ‘surfaceflinger’…
[ 17.433181] init: Service ‘surfaceflinger’ (pid 847) killed by signal 6
[ 17.433211] init: Service ‘surfaceflinger’ (pid 847) killing any children in process group
[ 17.433247] init: Service ‘zygote’ is being killed…
[ 17.474694] init: Service ‘zygote’ (pid 613) killed by signal 9
[ 17.474814] init: Service ‘zygote’ (pid 613) killing any children in process group
[ 17.475039] init: write_file: Unable to open ‘/sys/android_power/request_state’: No such file or directory
[ 17.475287] init: write_file: Unable to write to ‘/sys/power/state’: Invalid argument
[ 17.475365] init: Service ‘audioserver’ is being killed…
[ 17.475722] init: Service ‘cameraserver’ is being killed…
[ 17.475862] init: Service ‘media’ is being killed…
[ 17.480697] init: Service ‘netd’ is being killed…
[ 17.482163] init: Service ‘media’ (pid 646) killed by signal 9
[ 17.482216] init: Service ‘media’ (pid 646) killing any children in process group
[ 17.482507] init: Untracked pid 620 killed by signal 9
[ 17.485450] init: Starting service ‘zygote’…
[ 17.487169] init: Service ‘audioserver’ (pid 647) killed by signal 9
[ 17.487224] init: Service ‘audioserver’ (pid 647) killing any children in process group
[ 17.490915] init: Service ‘cameraserver’ (pid 648) killed by signal 9
[ 17.490998] init: Service ‘cameraserver’ (pid 648) killing any children in process group
[ 17.491712] init: Service ‘netd’ (pid 649) killed by signal 9
[ 17.491745] init: Service ‘netd’ (pid 649) killing any children in process group
[ 18.105570] read descriptors
[ 18.105677] read descriptors
[ 18.105747] read strings
[ 19.109162] init: Starting service ‘media’…
[ 19.110273] init: Starting service ‘audioserver’…
[ 19.110925] init: Starting service ‘cameraserver’…
[ 19.111708] init: Starting service ‘netd’…
[ 19.112768] init: couldn’t write 912 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[ 20.020208] fusb302 4-0022: connection has disconnected
[ 20.022223] fusb302 4-0022: fusb302 send extcon to disable vbus 5v
希望能被版主看到 么么哒{:4_89:}
Njzy_Njzy 发表于 2018-7-18 19:25
希望能被版主看到 么么哒
版主帮看一下 指导一下啊
我也遇到你一样的问题,我的recovery复位一直被杀死再重启,杀死再重启。。。。还没有你的系统跑的远。。。。。
楼主的问题是怎么解决的
